  • T Tom Haase
    2021-01-09 11:56:32.490 - info: shuttercontrol.0 (16900) Set ID: Buero1 pct value: 100%
    2021-01-09 11:56:32.614 - info: fhem.0 (16306) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
    2021-01-09 11:56:32.620 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
    2021-01-09 11:56:32.621 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
    2021-01-09 11:56:32.623 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
    2021-01-09 11:56:32.627 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
    2021-01-09 11:56:59.107 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
    2021-01-09 11:56:59.109 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
    2021-01-09 11:56:59.109 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
    2021-01-09 11:56:59.110 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
    2021-01-09 11:57:09.934 - info: shuttercontrol.0 (16900) Set ID: Buero1 pct value: 0%
    2021-01-09 11:57:10.055 - info: fhem.0 (16306) stateChange (out): fhem.0.Friedhelm.pct | 0 > set Friedhelm pct 0
    2021-01-09 11:57:10.061 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | state > fhem.0.Friedhelm.state drive-up
    2021-01-09 11:57:10.062 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | boolean > fhem.0.Friedhelm.state_boolean drive-up
    2021-01-09 11:57:10.063 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | value > fhem.0.Friedhelm.state_value drive-up
    2021-01-09 11:57:10.069 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send up | state > fhem.0.SD_Keeloq_AC6000.state send up
    2021-01-09 11:57:39.131 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
    2021-01-09 11:57:39.133 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm open | state > fhem.0.Friedhelm.state open
    2021-01-09 11:57:39.133 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm open | boolean > fhem.0.Friedhelm.state_boolean true
    2021-01-09 11:57:39.134 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm open | value > fhem.0.Friedhelm.state_value 2
    simatecS Offline
    simatecS Offline
    simatec
    #2667
    @Tom-Haase
    Bitte den Log im Beitrag als Code darstellen (siehe Button </>)
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • T Tom Haase
      simatecS Offline
      simatecS Offline
      simatec
      #2668
      @Tom-Haase
      Das ist kein Debug Log.
      Bitte stelle shuttercontrol auf debug und poste nur den Log von shuttercontrol, während du das betroffene Fenster öffnest.
      • D dos1973
        @simatec
        Oder auch an die community
        Gibt es eigentlich auch eine Einstellung, nicht vor xx Uhr runterfahren.
        Ich steuere über Sonnenaufgang/Untergang. Im Winter ist ja schon um 16:xx sonnenuntergang. Im Sommer passt das ganz gut, aber im Winnter gehen die dann oft etwas zu früh runter. Ich habs jetzt via Zeitverzögerung geregelt.
        Und noch eine Frag
        Ich habe an der Terassentür die Fenstergriffe gekoppelt.
        Das funktioniert optimal, Tür auf, Rolle geht hoch, tür zu Rollo geht runter...
        Lässt sich das temporär deaktivieren? Über einen DP?
        da_WoodyD Offline
        da_WoodyD Offline
        #2669
        @dos1973 rolladen spät schliessen in verbindung mit sommer einstellungen wird sich sicher was machen lassen.
        • T Tom Haase
            "_id": "system.adapter.shuttercontrol.0",
            "common": {
              "name": "shuttercontrol",
              "version": "1.1.1",
              "title": "shuttercontrol",
              "authors": [
                "simatec <nais@gmx.net>"
              "contributors": [
                "Rene G. <info@rg-engineering.eu>"
              "keywords": [
                "ioBroker",
                "Smart Home",
                "home automation",
                "Rollladen",
                "Jalousie",
                "Rollladensteuerung"
              "license": "MIT",
              "platform": "Javascript/Node.js",
              "main": "main.js",
              "icon": "shuttercontrol.png",
              "enabled": true,
              "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
              "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
              "loglevel": "info",
              "mode": "daemon",
              "type": "climate-control",
              "compact": true,
              "materialize": true,
              "stopBeforeUpdate": true,
              "plugins": {
                "sentry": {
                  "dsn": "https://5f58f5sff6e3a90bae5414d4fc09@sentry.iobroker.net/62"
              "installedFrom": "iobroker.shuttercontrol@1.1.1",
              "installedVersion": "1.1.1",
              "host": "raspberrypi"
            "native": {
              "livingAutomatic": "livingSunriseSunset",
              "W_shutterDownLiving": "22:00",
              "W_shutterUpLivingMin": "05:00",
              "W_shutterUpLivingMax": "06:00",
              "driveDelayUpLiving": "10",
              "WE_shutterDownLiving": "22:00",
              "WE_shutterUpLivingMin": "05:00",
              "WE_shutterUpLivingMax": "06:00",
              "sleepAutomatic": "sleepTime",
              "W_shutterDownSleep": "11:02",
              "W_shutterUpSleepMin": "06:00",
              "W_shutterUpSleepMax": "06:30",
              "driveDelayUpSleep": "10",
              "WE_shutterDownSleep": "21:00",
              "WE_shutterUpSleepMin": "06:00",
              "WE_shutterUpSleepMax": "07:30",
              "childrenAutomatic": "childrenSunriseSunset",
              "W_shutterDownChildren": "20:00",
              "W_shutterUpChildrenMin": "06:00",
              "W_shutterUpChildrenMax": "06:30",
              "driveDelayUpChildren": "10",
              "WE_shutterDownChildren": "21:00",
              "WE_shutterUpChildrenMin": "06:00",
              "WE_shutterUpChildrenMax": "06:30",
              "latitude": "50.01820°",
              "longitude": "11.54050°",
              "sunProtEndElevation": "10",
              "astroDelayUp": "30",
              "astroDelayDown": "30",
              "driveDelayUpAstro": "10",
              "SummerStart": "01.03.",
              "SummerEnd": "30.09.",
              "XMasStart": "01.12.",
              "XMasEnd": "06.01.",
              "publicHolidays": true,
              "publicHolInstance": "",
              "HolidayDP": "",
              "LateAllDown": false,
              "LateAllDownTime": "22:15",
              "betweenPositionTime": "22:00",
              "noGoTime": "0",
              "currentShutterState": false,
              "triggerAutoSleep": "hm-rpc.0.MEQ1234567.2.STATE",
              "triggerAutoLiving": "hm-rpc.0.MEQ1234567.2.STATE",
              "triggerAutoChildren": "hm-rpc.0.MEQ1234567.2.STATE",
              "heightDownSun": "30",
              "direction": "120",
              "type": null,
              "directionRange": "50",
              "actualValueTemp": "",
              "actualValueLight": "",
              "actualValueTempInside": "",
              "typeDown": null,
              "typeUp": null,
              "triggerStateShutter": "true",
              "triggerChangeShutter": "upDown",
              "triggerDriveShutter": "50",
              "autoDriveShutter": "upDown",
              "heightDownShutter": "100",
              "heightUpShutter": "0",
              "triggerID": "zigbee.0.00158d00053f428f.opened",
              "LateDown": false,
              "inSummerNotDown": false,
              "driveAfterClose": false,
              "useXmasLevel": false,
              "XmasLevel": "0",
              "KeepSunProtect": false,
              "betweenPosition": false,
              "betweenPositionLevel": "50",
              "events": [
                  "enabled": true,
                  "shutterName": "Buero1 pct",
                  "name": "fhem.0.friedhelm.pct",
                  "typeUp": "",
                  "typeDown": "",
                  "type": "",
                  "direction": "120",
                  "tempInside": "23",
                  "tempSensor": "",
                  "outsideTempSensor": "",
                  "tempOutside": "23",
                  "lightSensor": "",
                  "valueLight": "15",
                  "heightUp": "0",
                  "heightDown": "100",
                  "triggerState": "true",
                  "triggerDrive": "50",
                  "triggerChange": "upDown",
                  "elevation": "8",
                  "autoDrive": "upDown",
                  "hysteresisOutside": "5",
                  "hysteresisInside": "5",
                  "hysteresisLight": "5",
                  "currentAction": "",
                  "currentHeight": "",
                  "oldHeight": "",
                  "firstCompleteUp": "",
                  "triggerHeight": "",
                  "LateDown": false,
                  "triggerAction": "",
                  "XmasLevel": "0",
          simatecS Offline
          simatecS Offline
          simatec
          #2670
          @Tom-Haase sagte in Test Adapter shuttercontrol v1.1.x:
          system.adapter.shuttercontrol.0.json
          So funktioniert das nicht.
          Erstmal fehlen die Zeiteinstellungen für das hoch/runterfahren
          dann muss dein Triggerstate auf false (Wert des Fensterkontaktes im geschlossenen Zustand)
          Und dann bitte den debuglog posten, wenn das Fenster geöffnet wird bzw. wieder geschlossen wird
                  "enabled": true,
                  "typeUp": "",
                  "typeDown": "",
                  "type": "",
                  "direction": "120",
                  "tempInside": "23",
                  "tempSensor": "",
                  "lightSensor": "",
                  "valueLight": "15",
                  "heightUp": "0",
                  "elevation": "8",
                  "oldHeight": "",
                  "LateDown": false,
                  "XmasLevel": "0",
          • T Tom Haase
            danke für die Geduld.
            So wie oben eingestellt fährt der Rolladen nach Zeit. Alles gut!
            Als nächstes binde ich nun den Fensterkontakt ein. Der schaltet zwar, aber der Rolladen fährt nicht. Erst wenn ich die 0 und 100 tausche fährt der Rollo nach Kontakt.
            Jetzt funktioniert aber die Zeitsteuerung nicht mehr.
            Also wie eingangs oben beschrieben. Entweder oder!
            Nette Grüße
            Tom
            FoxRo
            #2671
            @Tom-Haase said in Test Adapter shuttercontrol v1.1.x:
            Nette Grüße
            Tom
            @Tom-Haase
            So wie du das hier mit dem Screenshot beschreibst vermute ich, dass Du die Trigger Tests mit offenem Rollladen machst.
            Shuttercontrol fährt den Rollladen im Trigger Fall nur, wenn die aktuelle Position tiefer (mehr zu) ist als die angeforderte Pos. (bei Dir aktuell 50).
            Also setze die Settings wie folgt:
            Rollladen beim runterfahren = 100
            Rollladen beim hochfahren = 0
            Rollladenhöhe bei öffnen des Fensters = zb.50
            Nimm mal den State von „opened“ und stelle den Wert für Fenster /Tür Sensor im geschl. Zusand auf false
            Fahre mal den Rollladen ganz nach unten und öffne dann das Fenster -> Der Rollladen fährt nun auf 50% ;-)
            Wenn nicht, teste andere Triggersettings.
            Viel Erfolg
            Roli
            • simatecS simatec
              @Tom-Haase
              Tom Haase
              schrieb am zuletzt editiert von Tom Haase
              #2672
              @simatec sagte in Test Adapter shuttercontrol v1.1.x:
              es erfolgt keine Ausgabe über die Aktion im log
              2021-01-09 15:22:34.203 - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
              2021-01-09 15:22:34.206 - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 send kill signal
              2021-01-09 15:22:34.212 - info: shuttercontrol.0 (26394) Got terminate signal TERMINATE_YOURSELF
              2021-01-09 15:22:34.214 - info: shuttercontrol.0 (26394) cleaned everything up...
              2021-01-09 15:22:34.217 - info: shuttercontrol.0 (26394) terminating
              2021-01-09 15:22:34.219 - info: shuttercontrol.0 (26394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2021-01-09 15:22:34.771 - info: host.raspberrypi instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2021-01-09 15:22:37.271 - info: host.raspberrypi instance system.adapter.shuttercontrol.0 started with pid 26597
              2021-01-09 15:22:38.926 - info: shuttercontrol.0 (26597) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2021-01-09 15:22:38.943 - info: shuttercontrol.0 (26597) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v12.20.0, js-controller: 3.1.6
              2021-01-09 15:23:59.940 - info: fhem.0 (16306) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
              • F FoxRo
                Nette Grüße
                Tom
                @Tom-Haase
                Viel Erfolg
                Roli
                Tom Haase
                #2673
                @FoxRo sagte in Test Adapter shuttercontrol v1.1.x:
                Ja, hast recht. Also Rolladen runter.....
                Alles genau so umgesetzt, keine Reaktion.
                Vielen Dank für eure Geduld.
                F 1 Antwort Letzte Antwort
                • T Tom Haase
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #2674
                  2021-01-09 15:22:38.990 - info: shuttercontrol.0 (26597) system longitude 11.54050° latitude 50.01820°
                  Du hast die Instanz von shuttercontrol nicht auf Debuglevel. Stelle shuttercontrol so wie in meiner Signatur beschrieben auf debug
                  T MichMeinM 2 Antworten Letzte Antwort
                  • simatecS simatec
                            "enabled": true,
                            "typeUp": "",
                            "typeDown": "",
                            "type": "",
                            "direction": "120",
                            "tempInside": "23",
                            "tempSensor": "",
                            "lightSensor": "",
                            "valueLight": "15",
                            "heightUp": "0",
                            "elevation": "8",
                            "oldHeight": "",
                            "LateDown": false,
                            "XmasLevel": "0",
                    Tom Haase
                    #2675
                    ok, eingetragen
                    geändert
                    wie oben schon geschriben wird keine veränderung im log angezeigt. Unter Objects kann ich aber sehen das der state sich bei offnen/schließen des Fensterkontakts ändert:
                    bei contact von true auf false
                    und wie jetzt nach eurer Anweisung hier eingestellt auf "opened"
                    also von false auf true
                    Der Kontakt arbeitet anscheinend doch, oder?
                    • T Tom Haase
                      FoxRo
                      #2676
                      .. noch einen Tipp zum Fehlersuchen
                      Bei einem Adapter Neustart verlieren die IoBroker Adapter die aktuellen Werte. Dies ist auch bei Shuttercontrol so. Also, jedes Mal wenn Du was an der Config geändert hast und der Adapter wieder grün (Status) wird, als erstes die Rollläden in eine definierte Position initialisieren. (ganz hoch oder ganz runter) ab dann weiss Shuttercontrol auch, wo der Rollladen aktuell steht und reagiert dann auch korrekt.;-)
                      Ansonsten kann es in Deinem Fall eigentlich nur noch am Triggersetting liegen. Entweder hast den falschen Datenpunkt verlinkt, auf dem Trigger-Datenpunkt kommt keine Änderung an wenn das Fenster öffnet oder der Status für geschlossen ist falsch gesetzt. Mehr Möglichkeiten gibts eigentlich nicht.
                      Viel Erfolg
                      Roli
                      • simatecS simatec
                        Tom Haase
                        #2677
                        @simatec
                        sorry das ist alles ziemliches Neuland für mich..
                        2021-01-09 16:08:52.566 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                        2021-01-09 16:08:52.575 - debug: shuttercontrol.0 (1591) save trigger height: 0% for device: Buero1 pct
                        2021-01-09 16:08:52.576 - debug: shuttercontrol.0 (1591) save trigger action: up for device: Buero1 pct
                        2021-01-09 16:08:55.365 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                        2021-01-09 16:08:55.374 - debug: shuttercontrol.0 (1591) shutter trigger released Buero1 pct already in place: 0%
                        2021-01-09 16:08:55.376 - debug: shuttercontrol.0 (1591) save back trigger action: up for device Buero1 pct
                        Das ist die Ausgabe bei öffnen und schließen des Fensterkontakts.
                        F simatecS 2 Antworten Letzte Antwort
                        • T Tom Haase
                          @simatec
                          FoxRo
                          #2678
                          @simatec
                          Das ist doch schon mal was.
                          jetzt das Ganze noch, wenn der Rollladen unten ist. ;-)
                          • T Tom Haase
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #2679
                            @Tom-Haase
                            Das sieht doch recht gut aus. Jetzt fahre den Rolladen mal runter und wiederhole den Vorgang des Fenster öffnens ...
                            Bitte auch den Log posten.
                              Tom Haase
                              #2680
                              Rolladen per Object "closeSleep" runtergefahren.
                              Fensterkontakt geöffnet
                              2021-01-09 16:56:57.523 - debug: shuttercontrol.0 (1591) start buttonAction
                              2021-01-09 16:56:57.528 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
                              2021-01-09 16:56:57.530 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
                              2021-01-09 16:56:57.547 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                              2021-01-09 16:56:57.548 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                              2021-01-09 16:56:57.642 - info: fhem.0 (1222) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
                              2021-01-09 16:56:57.647 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
                              2021-01-09 16:56:57.648 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
                              2021-01-09 16:56:57.649 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
                              2021-01-09 16:56:57.653 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
                              2021-01-09 16:57:24.118 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                              2021-01-09 16:57:24.121 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
                              2021-01-09 16:57:24.123 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
                              2021-01-09 16:57:24.124 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
                              2021-01-09 16:57:24.159 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                              2021-01-09 16:57:24.160 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                              2021-01-09 16:57:45.212 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                              2021-01-09 16:57:45.219 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
                              2021-01-09 16:57:45.220 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
                              2021-01-09 16:57:47.776 - info: fhem.0 (1222) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                                Tom Haase
                                #2681
                                und wenn ich den Fensterkontakt wieder schließe
                                2021-01-09 17:00:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
                                2021-01-09 17:00:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
                                2021-01-09 17:00:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
                                2021-01-09 17:00:00.082 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4141
                                2021-01-09 17:00:01.887 - info: dwd.0 (4141) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2021-01-09 17:00:01.899 - info: dwd.0 (4141) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.0, js-controller: 3.1.6
                                2021-01-09 17:00:04.124 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 4156
                                2021-01-09 17:00:05.536 - info: daswetter.0 (4156) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2021-01-09 17:00:05.553 - info: daswetter.0 (4156) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
                                2021-01-09 17:00:08.146 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4172
                                2021-01-09 17:00:08.369 - info: dwd.0 (4141) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-01-09 17:00:08.889 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-01-09 17:00:10.413 - info: ical.0 (4172) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2021-01-09 17:00:10.473 - info: ical.0 (4172) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.0, js-controller: 3.1.6
                                2021-01-09 17:00:11.504 - info: ical.0 (4172) processing URL: calendar1 https://calendar.google.com/calendar/ical/6gbrsp5mk0pf4a0dgamj7d56n4%40group.calendar.google.com/private-a5d30d07577f1b5f997d66da0421d549/basic.ics
                                2021-01-09 17:00:16.263 - info: daswetter.0 (4156) got wrong data structure! trying to repair...
                                2021-01-09 17:00:16.680 - info: ical.0 (4172) Terminated (NO_ERROR): Without reason
                                2021-01-09 17:00:17.194 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                2021-01-09 17:00:18.807 - info: daswetter.0 (4156) Terminated (NO_ERROR): Without reason
                                2021-01-09 17:00:19.323 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                2021-01-09 17:00:55.047 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                                2021-01-09 17:00:55.054 - debug: shuttercontrol.0 (1591) shutter trigger released Buero1 pct already in place: 100%
                                2021-01-09 17:00:55.055 - debug: shuttercontrol.0 (1591) save back trigger action: down for device Buero1 pct
                                • simatecS simatec
                                  MichMeinM Offline
                                  MichMeinM Offline
                                  MichMein
                                  #2682
                                  ... so wie in meiner Signatur beschrieben auf debug
                                  Wo genau soll die denn sein 🤔 ich sehe nix
                                  Gruß Michael
                                  Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                                  • MichMeinM MichMein
                                    #2683
                                    @MichMein sagte in Test Adapter shuttercontrol v1.1.x:
                                    Wo genau soll die denn sein ich sehe nix
                                    dann musst du das aktivieren
                                    • T Tom Haase
                                      FoxRo
                                      #2684
                                      ... Rollladen wurde runtergefahren..
                                      ... Fenster wurde geöffnet ...
                                      ..an dieser Stelle müsste der Fahrauftrag kommen um auf 50% zu fahren...
                                      Im Code gibt es an dieser Stelle keine weitere Verzweigung oder Abhängigkeiten!
                                      Warum dann erst 2Sek später vom FHEM was zum "Alive" gemeldet wird weiss ich nicht, sieht aber danach aus, dass der FHEM Adapter an dieser Stelle neu gestartet wurde. (warum auch immer)
                                      Wenn das so ist, kann dieser den Fahrauftrag vom Shuttercontrol wohl nicht ausführen.
                                      Kannst Du mal in den Objekten vom Shuttercontrol / shutters schauen, was für Werte im autoState und im autoLevel für den Rollladen stehen, während Du das Fenster offen hast?
                                      Das gibt einen Hinweis, ob die Stelle von Shuttercontrol korrekt weiter durchlaufen wurde.
                                      Allenfalls gibt es noch mehr an Informationen her, wenn alle anderen Adapter, die nicht benötigt werden, stoppst und den FHEM Adapter gleich wie den Shuttercontrol auf Debug stellst.
                                      • F FoxRo
                                        Tom Haase
                                        #2685
                                        und so sieht es bei geschlossenem Rollo aus:
                                          Tom Haase
                                          #2686
                                          Puuuh!
                                          Rolladen per "closeSleep" manuell heruntergefahren, dann den Fensterkontakt geöffnet
                                          2021-01-09 18:34:58.573 - debug: fhem.0 (8023) [setAlive] start setAlive 300 sec
                                          2021-01-09 18:34:58.581 - info: fhem.0 (8023) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                                          2021-01-09 18:34:58.583 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213698576,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698576}
                                          2021-01-09 18:34:58.592 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
                                          2021-01-09 18:34:58.594 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
                                          2021-01-09 18:34:58.596 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
                                          2021-01-09 18:34:58.653 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610213698647,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398597}
                                          2021-01-09 18:34:58.656 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213098621}
                                          2021-01-09 18:34:58.659 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 19 {"val":19,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                                          2021-01-09 18:34:58.663 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 57 {"val":57,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                                          2021-01-09 18:34:58.666 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 1 {"val":1,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                                          2021-01-09 18:34:58.670 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut 114 {"val":114,"ack":true,"ts":1610213698649,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698649}
                                          2021-01-09 18:34:58.677 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213698673,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398609}
                                          2021-01-09 18:34:58.680 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610213698678,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698678}
                                          2021-01-09 18:35:00.011 - debug: shuttercontrol.0 (1591) calculate astrodata ...
                                          2021-01-09 18:35:00.012 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
                                          2021-01-09 18:35:00.013 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
                                          2021-01-09 18:39:23.313 - debug: shuttercontrol.0 (1591) start buttonAction
                                          2021-01-09 18:39:23.316 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
                                          2021-01-09 18:39:23.318 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
                                          2021-01-09 18:39:23.324 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":100,"ack":false,"ts":1610213963319,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610213963319}
                                          2021-01-09 18:39:23.328 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                                          2021-01-09 18:39:23.329 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                                          2021-01-09 18:39:23.434 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
                                          2021-01-09 18:39:23.436 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-100"
                                          2021-01-09 18:39:23.437 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-100 | reading > fhem.0.Friedhelm.command pct-100
                                          2021-01-09 18:39:23.438 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 100"
                                          2021-01-09 18:39:23.439 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 100 | reading > fhem.0.Friedhelm.desired_pct 100
                                          2021-01-09 18:39:23.440 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-down"
                                          2021-01-09 18:39:23.440 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-down | reading > fhem.0.Friedhelm.last_drive drive-down
                                          2021-01-09 18:39:23.441 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-down"
                                          2021-01-09 18:39:23.442 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
                                          2021-01-09 18:39:23.443 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
                                          2021-01-09 18:39:23.444 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
                                          2021-01-09 18:39:23.445 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
                                          2021-01-09 18:39:23.445 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
                                          2021-01-09 18:39:23.446 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: down"
                                          2021-01-09 18:39:23.447 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: down | reading > fhem.0.SD_Keeloq_AC6000.button down
                                          2021-01-09 18:39:23.448 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                                          2021-01-09 18:39:23.449 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                                          2021-01-09 18:39:23.449 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9226"
                                          2021-01-09 18:39:23.450 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9226 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9226
                                          2021-01-09 18:39:23.451 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send down"
                                          2021-01-09 18:39:23.452 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
                                          2021-01-09 18:39:23.453 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down"
                                          2021-01-09 18:39:23.453 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down
                                          2021-01-09 18:39:23.454 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                                          2021-01-09 18:39:23.455 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                                          2021-01-09 18:39:23.481 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-100 {"val":"pct-100","ack":true,"ts":1610213963474,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963474}
                                          2021-01-09 18:39:23.482 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 100 {"val":"100","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                                          2021-01-09 18:39:23.486 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                                          2021-01-09 18:39:23.490 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                                          2021-01-09 18:39:23.491 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                                          2021-01-09 18:39:23.495 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-down {"val":"drive-down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                                          2021-01-09 18:39:23.496 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button down {"val":"down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                                          2021-01-09 18:39:23.497 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9226 {"val":"9226","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                                          2021-01-09 18:39:23.501 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send down {"val":"send down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                                          2021-01-09 18:39:23.502 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down {"val":"down","ack":true,"ts":1610213963478,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963478}
                                          2021-01-09 18:39:50.099 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 100"
                                          2021-01-09 18:39:50.100 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 100 | reading > fhem.0.Friedhelm.pct 100
                                          2021-01-09 18:39:50.101 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
                                          2021-01-09 18:39:50.102 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
                                          2021-01-09 18:39:50.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                                          2021-01-09 18:39:50.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                                          2021-01-09 18:39:50.104 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9227"
                                          2021-01-09 18:39:50.105 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9227 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9227
                                          2021-01-09 18:39:50.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
                                          2021-01-09 18:39:50.106 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                                          2021-01-09 18:39:50.107 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
                                          2021-01-09 18:39:50.108 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
                                          2021-01-09 18:39:50.109 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                                          2021-01-09 18:39:50.109 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                                          2021-01-09 18:39:50.110 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm closed"
                                          2021-01-09 18:39:50.111 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
                                          2021-01-09 18:39:50.112 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
                                          2021-01-09 18:39:50.113 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
                                          2021-01-09 18:39:50.140 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":"100","ack":true,"ts":1610213990132,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990132}
                                          2021-01-09 18:39:50.141 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610213990133,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990133}
                                          2021-01-09 18:39:50.148 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                                          2021-01-09 18:39:50.147 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9227 {"val":"9227","ack":true,"ts":1610213990134,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990134}
                                          2021-01-09 18:39:50.148 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                                          2021-01-09 18:39:50.151 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610213990134,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990134}
                                          2021-01-09 18:39:50.155 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610213990137,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990137}
                                          2021-01-09 18:39:50.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state closed {"val":"closed","ack":true,"ts":1610213990138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990138}
                                          2021-01-09 18:39:50.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean false {"val":false,"ack":true,"ts":1610213990138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990138}
                                          2021-01-09 18:39:50.157 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 0 {"val":0,"ack":true,"ts":1610213990139,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990139}
                                          2021-01-09 18:39:54.744 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                                          2021-01-09 18:39:54.749 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
                                          2021-01-09 18:39:54.750 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
                                          2021-01-09 18:39:58.576 - debug: fhem.0 (8023) [setAlive] start setAlive 300 sec
                                          2021-01-09 18:39:58.584 - info: fhem.0 (8023) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                                          2021-01-09 18:39:58.585 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213998579,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998579}
                                          2021-01-09 18:39:58.595 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
                                          2021-01-09 18:39:58.596 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
                                          2021-01-09 18:39:58.599 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
                                          2021-01-09 18:39:58.627 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610213998620,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398597}
                                          2021-01-09 18:39:58.630 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610213998621,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213098621}
                                          2021-01-09 18:39:58.641 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 18 {"val":18,"ack":true,"ts":1610213998622,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998622}
                                          2021-01-09 18:39:58.645 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 47 {"val":47,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998623}
                                          2021-01-09 18:39:58.649 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 1 {"val":1,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                                          2021-01-09 18:39:58.650 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut 111 {"val":111,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998623}
                                          2021-01-09 18:39:58.655 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213998649,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398609}
                                          2021-01-09 18:39:58.662 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610213998658,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998658}
                                          2021-01-09 18:40:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
                                          2021-01-09 18:40:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
                                          2021-01-09 18:40:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
