    Tom Haase
    schrieb am zuletzt editiert von Tom Haase
    #2665
    2021-01-09 11:56:32.490 - info: shuttercontrol.0 (16900) Set ID: Buero1 pct value: 100%
    2021-01-09 11:56:32.614 - info: fhem.0 (16306) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
    2021-01-09 11:56:32.620 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
    2021-01-09 11:56:32.621 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
    2021-01-09 11:56:32.623 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
    2021-01-09 11:56:32.627 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
    2021-01-09 11:56:59.107 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
    2021-01-09 11:56:59.109 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
    2021-01-09 11:56:59.109 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
    2021-01-09 11:56:59.110 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
    2021-01-09 11:57:09.934 - info: shuttercontrol.0 (16900) Set ID: Buero1 pct value: 0%
    2021-01-09 11:57:10.055 - info: fhem.0 (16306) stateChange (out): fhem.0.Friedhelm.pct | 0 > set Friedhelm pct 0
    2021-01-09 11:57:10.061 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | state > fhem.0.Friedhelm.state drive-up
    2021-01-09 11:57:10.062 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | boolean > fhem.0.Friedhelm.state_boolean drive-up
    2021-01-09 11:57:10.063 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | value > fhem.0.Friedhelm.state_value drive-up
    2021-01-09 11:57:10.069 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send up | state > fhem.0.SD_Keeloq_AC6000.state send up
    2021-01-09 11:57:39.131 - info: fhem.0 (16306) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
    2021-01-09 11:57:39.133 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm open | state > fhem.0.Friedhelm.state open
    2021-01-09 11:57:39.133 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm open | boolean > fhem.0.Friedhelm.state_boolean true
    2021-01-09 11:57:39.134 - info: fhem.0 (16306) event FHEM: Friedhelm | ROLLO Friedhelm open | value > fhem.0.Friedhelm.state_value 2
    D simatecS 3 Antworten Letzte Antwort
    • T Tom Haase
      dos1973
      #2666
      @simatec
      Oder auch an die community
      Gibt es eigentlich auch eine Einstellung, nicht vor xx Uhr runterfahren.
      Ich steuere über Sonnenaufgang/Untergang. Im Winter ist ja schon um 16:xx sonnenuntergang. Im Sommer passt das ganz gut, aber im Winnter gehen die dann oft etwas zu früh runter. Ich habs jetzt via Zeitverzögerung geregelt.
      Und noch eine Frag
      Ich habe an der Terassentür die Fenstergriffe gekoppelt.
      Das funktioniert optimal, Tür auf, Rolle geht hoch, tür zu Rollo geht runter...
      Lässt sich das temporär deaktivieren? Über einen DP?
      • T Tom Haase
        simatecS Offline
        simatecS Offline
        simatec
        #2667
        @Tom-Haase
        Bitte den Log im Beitrag als Code darstellen (siehe Button </>)
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • T Tom Haase
          simatecS Offline
          simatecS Offline
          simatec
          #2668
          @Tom-Haase
          Das ist kein Debug Log.
          Bitte stelle shuttercontrol auf debug und poste nur den Log von shuttercontrol, während du das betroffene Fenster öffnest.
          • D dos1973
            @simatec
            Und noch eine Frag
            da_WoodyD Offline
            da_WoodyD Offline
            #2669
            @dos1973 rolladen spät schliessen in verbindung mit sommer einstellungen wird sich sicher was machen lassen.
            • T Tom Haase
                "_id": "system.adapter.shuttercontrol.0",
                "common": {
                  "name": "shuttercontrol",
                  "version": "1.1.1",
                  "title": "shuttercontrol",
                  "authors": [
                    "simatec <nais@gmx.net>"
                  "contributors": [
                    "Rene G. <info@rg-engineering.eu>"
                  "keywords": [
                    "ioBroker",
                    "Smart Home",
                    "home automation",
                    "Rollladen",
                    "Jalousie",
                    "Rollladensteuerung"
                  "license": "MIT",
                  "platform": "Javascript/Node.js",
                  "main": "main.js",
                  "icon": "shuttercontrol.png",
                  "enabled": true,
                  "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                  "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                  "loglevel": "info",
                  "mode": "daemon",
                  "type": "climate-control",
                  "compact": true,
                  "materialize": true,
                  "stopBeforeUpdate": true,
                  "plugins": {
                    "sentry": {
                      "dsn": "https://5f58f5sff6e3a90bae5414d4fc09@sentry.iobroker.net/62"
                  "installedFrom": "iobroker.shuttercontrol@1.1.1",
                  "installedVersion": "1.1.1",
                  "host": "raspberrypi"
                "native": {
                  "livingAutomatic": "livingSunriseSunset",
                  "W_shutterDownLiving": "22:00",
                  "W_shutterUpLivingMin": "05:00",
                  "W_shutterUpLivingMax": "06:00",
                  "driveDelayUpLiving": "10",
                  "WE_shutterDownLiving": "22:00",
                  "WE_shutterUpLivingMin": "05:00",
                  "WE_shutterUpLivingMax": "06:00",
                  "sleepAutomatic": "sleepTime",
                  "W_shutterDownSleep": "11:02",
                  "W_shutterUpSleepMin": "06:00",
                  "W_shutterUpSleepMax": "06:30",
                  "driveDelayUpSleep": "10",
                  "WE_shutterDownSleep": "21:00",
                  "WE_shutterUpSleepMin": "06:00",
                  "WE_shutterUpSleepMax": "07:30",
                  "childrenAutomatic": "childrenSunriseSunset",
                  "W_shutterDownChildren": "20:00",
                  "W_shutterUpChildrenMin": "06:00",
                  "W_shutterUpChildrenMax": "06:30",
                  "driveDelayUpChildren": "10",
                  "WE_shutterDownChildren": "21:00",
                  "WE_shutterUpChildrenMin": "06:00",
                  "WE_shutterUpChildrenMax": "06:30",
                  "latitude": "50.01820°",
                  "longitude": "11.54050°",
                  "sunProtEndElevation": "10",
                  "astroDelayUp": "30",
                  "astroDelayDown": "30",
                  "driveDelayUpAstro": "10",
                  "SummerStart": "01.03.",
                  "SummerEnd": "30.09.",
                  "XMasStart": "01.12.",
                  "XMasEnd": "06.01.",
                  "publicHolidays": true,
                  "publicHolInstance": "",
                  "HolidayDP": "",
                  "LateAllDown": false,
                  "LateAllDownTime": "22:15",
                  "betweenPositionTime": "22:00",
                  "noGoTime": "0",
                  "currentShutterState": false,
                  "triggerAutoSleep": "hm-rpc.0.MEQ1234567.2.STATE",
                  "triggerAutoLiving": "hm-rpc.0.MEQ1234567.2.STATE",
                  "triggerAutoChildren": "hm-rpc.0.MEQ1234567.2.STATE",
                  "heightDownSun": "30",
                  "direction": "120",
                  "type": null,
                  "directionRange": "50",
                  "actualValueTemp": "",
                  "actualValueLight": "",
                  "actualValueTempInside": "",
                  "typeDown": null,
                  "typeUp": null,
                  "triggerStateShutter": "true",
                  "triggerChangeShutter": "upDown",
                  "triggerDriveShutter": "50",
                  "autoDriveShutter": "upDown",
                  "heightDownShutter": "100",
                  "heightUpShutter": "0",
                  "triggerID": "zigbee.0.00158d00053f428f.opened",
                  "LateDown": false,
                  "inSummerNotDown": false,
                  "driveAfterClose": false,
                  "useXmasLevel": false,
                  "XmasLevel": "0",
                  "KeepSunProtect": false,
                  "betweenPosition": false,
                  "betweenPositionLevel": "50",
                  "events": [
                      "enabled": true,
                      "shutterName": "Buero1 pct",
                      "name": "fhem.0.friedhelm.pct",
                      "typeUp": "",
                      "typeDown": "",
                      "type": "",
                      "direction": "120",
                      "tempInside": "23",
                      "tempSensor": "",
                      "outsideTempSensor": "",
                      "tempOutside": "23",
                      "lightSensor": "",
                      "valueLight": "15",
                      "heightUp": "0",
                      "heightDown": "100",
                      "triggerState": "true",
                      "triggerDrive": "50",
                      "triggerChange": "upDown",
                      "elevation": "8",
                      "autoDrive": "upDown",
                      "hysteresisOutside": "5",
                      "hysteresisInside": "5",
                      "hysteresisLight": "5",
                      "currentAction": "",
                      "currentHeight": "",
                      "oldHeight": "",
                      "firstCompleteUp": "",
                      "triggerHeight": "",
                      "LateDown": false,
                      "triggerAction": "",
                      "XmasLevel": "0",
              simatecS Offline
              simatecS Offline
              simatec
              #2670
              @Tom-Haase sagte in Test Adapter shuttercontrol v1.1.x:
              system.adapter.shuttercontrol.0.json
              So funktioniert das nicht.
              Erstmal fehlen die Zeiteinstellungen für das hoch/runterfahren
              dann muss dein Triggerstate auf false (Wert des Fensterkontaktes im geschlossenen Zustand)
              Und dann bitte den debuglog posten, wenn das Fenster geöffnet wird bzw. wieder geschlossen wird
                      "enabled": true,
                      "typeUp": "",
                      "typeDown": "",
                      "type": "",
                      "direction": "120",
                      "tempInside": "23",
                      "tempSensor": "",
                      "lightSensor": "",
                      "valueLight": "15",
                      "heightUp": "0",
                      "elevation": "8",
                      "oldHeight": "",
                      "LateDown": false,
                      "XmasLevel": "0",
              • T Tom Haase
                danke für die Geduld.
                So wie oben eingestellt fährt der Rolladen nach Zeit. Alles gut!
                Als nächstes binde ich nun den Fensterkontakt ein. Der schaltet zwar, aber der Rolladen fährt nicht. Erst wenn ich die 0 und 100 tausche fährt der Rollo nach Kontakt.
                Jetzt funktioniert aber die Zeitsteuerung nicht mehr.
                Also wie eingangs oben beschrieben. Entweder oder!
                Nette Grüße
                Tom
                FoxRo
                #2671
                @Tom-Haase said in Test Adapter shuttercontrol v1.1.x:
                Nette Grüße
                Tom
                @Tom-Haase
                So wie du das hier mit dem Screenshot beschreibst vermute ich, dass Du die Trigger Tests mit offenem Rollladen machst.
                Shuttercontrol fährt den Rollladen im Trigger Fall nur, wenn die aktuelle Position tiefer (mehr zu) ist als die angeforderte Pos. (bei Dir aktuell 50).
                Also setze die Settings wie folgt:
                Rollladen beim runterfahren = 100
                Rollladen beim hochfahren = 0
                Rollladenhöhe bei öffnen des Fensters = zb.50
                Nimm mal den State von „opened“ und stelle den Wert für Fenster /Tür Sensor im geschl. Zusand auf false
                Fahre mal den Rollladen ganz nach unten und öffne dann das Fenster -> Der Rollladen fährt nun auf 50% ;-)
                Wenn nicht, teste andere Triggersettings.
                Viel Erfolg
                Roli
                • simatecS simatec
                  @Tom-Haase
                  Tom Haase
                  #2672
                  @simatec sagte in Test Adapter shuttercontrol v1.1.x:
                  es erfolgt keine Ausgabe über die Aktion im log
                  2021-01-09 15:22:34.203 - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                  2021-01-09 15:22:34.206 - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 send kill signal
                  2021-01-09 15:22:34.212 - info: shuttercontrol.0 (26394) Got terminate signal TERMINATE_YOURSELF
                  2021-01-09 15:22:34.214 - info: shuttercontrol.0 (26394) cleaned everything up...
                  2021-01-09 15:22:34.217 - info: shuttercontrol.0 (26394) terminating
                  2021-01-09 15:22:34.219 - info: shuttercontrol.0 (26394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-01-09 15:22:34.771 - info: host.raspberrypi instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2021-01-09 15:22:37.271 - info: host.raspberrypi instance system.adapter.shuttercontrol.0 started with pid 26597
                  2021-01-09 15:22:38.926 - info: shuttercontrol.0 (26597) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  2021-01-09 15:22:38.943 - info: shuttercontrol.0 (26597) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v12.20.0, js-controller: 3.1.6
                  2021-01-09 15:23:59.940 - info: fhem.0 (16306) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  • F FoxRo
                    Nette Grüße
                    Tom
                    @Tom-Haase
                    Viel Erfolg
                    Roli
                    Tom Haase
                    #2673
                    @FoxRo sagte in Test Adapter shuttercontrol v1.1.x:
                    Ja, hast recht. Also Rolladen runter.....
                    Alles genau so umgesetzt, keine Reaktion.
                    Vielen Dank für eure Geduld.
                    F 1 Antwort Letzte Antwort
                    • T Tom Haase
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #2674
                      2021-01-09 15:22:38.990 - info: shuttercontrol.0 (26597) system longitude 11.54050° latitude 50.01820°
                      Du hast die Instanz von shuttercontrol nicht auf Debuglevel. Stelle shuttercontrol so wie in meiner Signatur beschrieben auf debug
                      T MichMeinM 2 Antworten Letzte Antwort
                      • simatecS simatec
                                "enabled": true,
                                "typeUp": "",
                                "typeDown": "",
                                "type": "",
                                "direction": "120",
                                "tempInside": "23",
                                "tempSensor": "",
                                "lightSensor": "",
                                "valueLight": "15",
                                "heightUp": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": false,
                                "XmasLevel": "0",
                        Tom Haase
                        #2675
                        ok, eingetragen
                        geändert
                        wie oben schon geschriben wird keine veränderung im log angezeigt. Unter Objects kann ich aber sehen das der state sich bei offnen/schließen des Fensterkontakts ändert:
                        bei contact von true auf false
                        und wie jetzt nach eurer Anweisung hier eingestellt auf "opened"
                        also von false auf true
                        Der Kontakt arbeitet anscheinend doch, oder?
                        • T Tom Haase
                          FoxRo
                          #2676
                          .. noch einen Tipp zum Fehlersuchen
                          Bei einem Adapter Neustart verlieren die IoBroker Adapter die aktuellen Werte. Dies ist auch bei Shuttercontrol so. Also, jedes Mal wenn Du was an der Config geändert hast und der Adapter wieder grün (Status) wird, als erstes die Rollläden in eine definierte Position initialisieren. (ganz hoch oder ganz runter) ab dann weiss Shuttercontrol auch, wo der Rollladen aktuell steht und reagiert dann auch korrekt.;-)
                          Ansonsten kann es in Deinem Fall eigentlich nur noch am Triggersetting liegen. Entweder hast den falschen Datenpunkt verlinkt, auf dem Trigger-Datenpunkt kommt keine Änderung an wenn das Fenster öffnet oder der Status für geschlossen ist falsch gesetzt. Mehr Möglichkeiten gibts eigentlich nicht.
                          Viel Erfolg
                          Roli
                          • simatecS simatec
                            Tom Haase
                            #2677
                            @simatec
                            sorry das ist alles ziemliches Neuland für mich..
                            2021-01-09 16:08:52.566 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                            2021-01-09 16:08:52.575 - debug: shuttercontrol.0 (1591) save trigger height: 0% for device: Buero1 pct
                            2021-01-09 16:08:52.576 - debug: shuttercontrol.0 (1591) save trigger action: up for device: Buero1 pct
                            2021-01-09 16:08:55.365 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                            2021-01-09 16:08:55.374 - debug: shuttercontrol.0 (1591) shutter trigger released Buero1 pct already in place: 0%
                            2021-01-09 16:08:55.376 - debug: shuttercontrol.0 (1591) save back trigger action: up for device Buero1 pct
                            Das ist die Ausgabe bei öffnen und schließen des Fensterkontakts.
                            F simatecS 2 Antworten Letzte Antwort
                            • T Tom Haase
                              @simatec
                              FoxRo
                              #2678
                              @simatec
                              Das ist doch schon mal was.
                              jetzt das Ganze noch, wenn der Rollladen unten ist. ;-)
                              • T Tom Haase
                                @simatec
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #2679
                                @Tom-Haase
                                Das sieht doch recht gut aus. Jetzt fahre den Rolladen mal runter und wiederhole den Vorgang des Fenster öffnens ...
                                Bitte auch den Log posten.
                                  Tom Haase
                                  #2680
                                  Rolladen per Object "closeSleep" runtergefahren.
                                  Fensterkontakt geöffnet
                                  2021-01-09 16:56:57.523 - debug: shuttercontrol.0 (1591) start buttonAction
                                  2021-01-09 16:56:57.528 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
                                  2021-01-09 16:56:57.530 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
                                  2021-01-09 16:56:57.547 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                                  2021-01-09 16:56:57.548 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                                  2021-01-09 16:56:57.642 - info: fhem.0 (1222) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
                                  2021-01-09 16:56:57.647 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
                                  2021-01-09 16:56:57.648 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
                                  2021-01-09 16:56:57.649 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
                                  2021-01-09 16:56:57.653 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
                                  2021-01-09 16:57:24.118 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                                  2021-01-09 16:57:24.121 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
                                  2021-01-09 16:57:24.123 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
                                  2021-01-09 16:57:24.124 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
                                  2021-01-09 16:57:24.159 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                                  2021-01-09 16:57:24.160 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                                  2021-01-09 16:57:45.212 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                                  2021-01-09 16:57:45.219 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
                                  2021-01-09 16:57:45.220 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
                                  2021-01-09 16:57:47.776 - info: fhem.0 (1222) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                                    Tom Haase
                                    #2681
                                    und wenn ich den Fensterkontakt wieder schließe
                                    2021-01-09 17:00:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
                                    2021-01-09 17:00:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
                                    2021-01-09 17:00:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
                                    2021-01-09 17:00:00.082 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4141
                                    2021-01-09 17:00:01.887 - info: dwd.0 (4141) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                    2021-01-09 17:00:01.899 - info: dwd.0 (4141) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.0, js-controller: 3.1.6
                                    2021-01-09 17:00:04.124 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 4156
                                    2021-01-09 17:00:05.536 - info: daswetter.0 (4156) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                    2021-01-09 17:00:05.553 - info: daswetter.0 (4156) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
                                    2021-01-09 17:00:08.146 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4172
                                    2021-01-09 17:00:08.369 - info: dwd.0 (4141) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-01-09 17:00:08.889 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-01-09 17:00:10.413 - info: ical.0 (4172) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                    2021-01-09 17:00:10.473 - info: ical.0 (4172) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.0, js-controller: 3.1.6
                                    2021-01-09 17:00:11.504 - info: ical.0 (4172) processing URL: calendar1 https://calendar.google.com/calendar/ical/6gbrsp5mk0pf4a0dgamj7d56n4%40group.calendar.google.com/private-a5d30d07577f1b5f997d66da0421d549/basic.ics
                                    2021-01-09 17:00:16.263 - info: daswetter.0 (4156) got wrong data structure! trying to repair...
                                    2021-01-09 17:00:16.680 - info: ical.0 (4172) Terminated (NO_ERROR): Without reason
                                    2021-01-09 17:00:17.194 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                    2021-01-09 17:00:18.807 - info: daswetter.0 (4156) Terminated (NO_ERROR): Without reason
                                    2021-01-09 17:00:19.323 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                    2021-01-09 17:00:55.047 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                                    2021-01-09 17:00:55.054 - debug: shuttercontrol.0 (1591) shutter trigger released Buero1 pct already in place: 100%
                                    2021-01-09 17:00:55.055 - debug: shuttercontrol.0 (1591) save back trigger action: down for device Buero1 pct
                                    • simatecS simatec
                                      MichMeinM Offline
                                      MichMeinM Offline
                                      MichMein
                                      #2682
                                      ... so wie in meiner Signatur beschrieben auf debug
                                      Wo genau soll die denn sein 🤔 ich sehe nix
                                      Gruß Michael
                                      Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                                      • MichMeinM MichMein
                                        #2683
                                        @MichMein sagte in Test Adapter shuttercontrol v1.1.x:
                                        Wo genau soll die denn sein ich sehe nix
                                        dann musst du das aktivieren
                                        • T Tom Haase
                                          FoxRo
                                          #2684
                                          ... Rollladen wurde runtergefahren..
                                          ... Fenster wurde geöffnet ...
                                          ..an dieser Stelle müsste der Fahrauftrag kommen um auf 50% zu fahren...
                                          Im Code gibt es an dieser Stelle keine weitere Verzweigung oder Abhängigkeiten!
                                          Warum dann erst 2Sek später vom FHEM was zum "Alive" gemeldet wird weiss ich nicht, sieht aber danach aus, dass der FHEM Adapter an dieser Stelle neu gestartet wurde. (warum auch immer)
                                          Wenn das so ist, kann dieser den Fahrauftrag vom Shuttercontrol wohl nicht ausführen.
                                          Kannst Du mal in den Objekten vom Shuttercontrol / shutters schauen, was für Werte im autoState und im autoLevel für den Rollladen stehen, während Du das Fenster offen hast?
                                          Das gibt einen Hinweis, ob die Stelle von Shuttercontrol korrekt weiter durchlaufen wurde.
                                          Allenfalls gibt es noch mehr an Informationen her, wenn alle anderen Adapter, die nicht benötigt werden, stoppst und den FHEM Adapter gleich wie den Shuttercontrol auf Debug stellst.
