  4. Backup von IoBroker auf WDMycloud oder FritzNAS
wdmycloudbackup auf nas
51 Beiträge 7 Kommentatoren 5.6k Aufrufe 6 Beobachtet
  • N NicoR
    @UncleSam
    Hier nochmal der Log:
    backitup.0	2021-01-04 14:53:36.528	debug	(24212) [iobroker] exec: done
    backitup.0	2021-01-04 14:53:36.377	debug	(24212) [iobroker/history] backitup.0.history.json
    backitup.0	2021-01-04 14:53:36.377	debug	(24212) [iobroker/history] backitup.0.history.html
    backitup.0	2021-01-04 14:53:36.220	debug	(24212) [iobroker/whatsapp] done
    backitup.0	2021-01-04 14:53:36.220	debug	(24212) sendTo "send" to system.adapter.whatsapp-cmb.0 from system.adapter.backitup.0
    backitup.0	2021-01-04 14:53:36.219	debug	(24212) [iobroker/whatsapp] [iobroker] used WhatsApp-Instance: whatsapp-cmb.0
    backitup.0	2021-01-04 14:53:35.615	debug	(24212) [iobroker/clean] done
    backitup.0	2021-01-04 14:53:35.614	debug	(24212) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0	2021-01-04 14:53:35.163	debug	(24212) [iobroker/cifs] done
    backitup.0	2021-01-04 14:53:34.109	debug	(24212) [iobroker/iobroker] done
    backitup.0	2021-01-04 14:53:33.087	debug	(24212) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_01_04-13_53_30_backupiobroker.tar.gz
    backitup.0	2021-01-04 14:53:31.993	debug	(24212) [iobroker/iobroker] host.IoBroker 3135 objects saved
    backitup.0	2021-01-04 14:53:31.972	debug	(24212) [iobroker/iobroker] host.IoBroker 2514 states saved
    backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] Try 'mount --help' for more information.
    backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] mount: bad usage
    backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] sudo: setrlimit(RLIMIT_CORE): Operation not permitted
    backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/ /FRITZ.NAS/Backups/IoBroker /opt/iobroker
    backitup.0	2021-01-04 14:53:30.290	debug	(24212) [iobroker/mount] Try 'mount --help' for more information.
    backitup.0	2021-01-04 14:53:30.290	debug	(24212) [iobroker/mount] mount: bad usage
    backitup.0	2021-01-04 14:53:30.288	debug	(24212) [iobroker/mount] sudo: setrlimit(RLIMIT_CORE): Operation not permitted
    backitup.0	2021-01-04 14:53:30.288	debug	(24212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/ /FRITZ.NAS/Backups/IoBroker /opt/iobroke
    backitup.0	2021-01-04 14:53:30.266	debug	(24212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
    MOD-Edit: Code in code-tags gesetzt!
    Also ich habe auf einem Laptop Proxmox installiert. Auf einer damit erstellten VM läuft ein Ubunto mit dem iobroker drauf.Js Version 3.1.6
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @NicoR sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
    Ich bin ja kein CIFS/SMB Spezialist, aber stimmt das da: zwischen IP und Pfad hat es eine Lücke.
    Normalerweise sollte das doch ungefähr so aussehen:
    sudo mount -t cifs -o <options> //WIN_SHARE_IP/<share_name> /mnt/win_share
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • N NicoR
      @Homoran
      Ja ist in einem LXC Container
      LXC Container
      das ist keine VM
      • UncleSamU UncleSam
        @UncleSam
        Adlerauge!
        Stimmt, da darf kein Leerzeichen sein.
          @NicoR
          Ich dachte in einer VM?
          Na egal, bin ich so oder so raus.
          N Offline
          N Offline
          NicoR
          @Thomas-Braun Ja sorry. Hatte ich vergessen. Ich bin bei dem Thema ja leider auch raus.😲
          • UncleSamU Offline
            UncleSamU Offline
            UncleSam
            Von https://bayton.org/docs/linux/lxd/mount-cifssmb-shares-rw-in-lxd-containers/:
            One of the biggest limitations with LXD I’ve found to date is the inability to mount remote shares on unprivileged containers. While it’s still not possible at this point to mount CIFS shares from within a container directly, I’ve figured out a way to get around this by first mounting the shares on the LXD host and then using lxd config device add to mount them in my containers from there.
            Wenn das so ist, dann findest du hier möglicherweise eine Lösung:
            https://forum.proxmox.com/threads/solved-expose-cifs-share-to-lxc-container.44757/
            Ansonsten würde ich den Mount einfach auf dem Proxmox machen und dann das Lokale Verzeichnis in den Container mounten.
              @UncleSam sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
              Aber wo kommt die her, in der Konfig steht die IP und der share.
              Die IP ist ohne / am ende, also auch kein Leerzeichen dort. Das wird beim zusammenbau hinzugefügt.
              Entweder ist das in der Konfig vor dem Pfad zum share, oder dort gehört kein führender / hin
              @NicoR
              Ist vor dem /FRITZ.NAS ein Leerzeichen?
              Wenn ja, löschen, wenn nein, bitte mal ohne / versuchen.
              Ich bin bei Containern nämlich sonst auch raus
              N 1 Antwort Letzte Antwort
                @NicoR
                N Offline
                N Offline
                NicoR
                @Homoran
                War kein Leerzeichen. Hab es jetzt mal entfernt. Denke ist aber immer noch der gleiche Fehler.
                Hier der Log:
                backitup.0 2021-01-04 16:17:44.233 debug (25569) [iobroker] exec: done
                backitup.0 2021-01-04 16:17:44.082 debug (25569) [iobroker/history] backitup.0.history.json
                backitup.0 2021-01-04 16:17:44.081 debug (25569) [iobroker/history] backitup.0.history.html
                whatsapp-cmb.0 2021-01-04 16:17:43.925 info (13000) Send BackItUp: Die Sicherung wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!! mount: Error: Command failed: sudo mount -t cifs -o username=Backup,password=,rw,file_
                backitup.0 2021-01-04 16:17:43.923 debug (25569) [iobroker/whatsapp] done
                backitup.0 2021-01-04 16:17:43.923 debug (25569) sendTo "send" to system.adapter.whatsapp-cmb.0 from system.adapter.backitup.0
                backitup.0 2021-01-04 16:17:43.922 debug (25569) [iobroker/whatsapp] [iobroker] used WhatsApp-Instance: whatsapp-cmb.0
                backitup.0 2021-01-04 16:17:43.317 debug (25569) [iobroker/clean] done
                backitup.0 2021-01-04 16:17:43.317 debug (25569) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                backitup.0 2021-01-04 16:17:42.866 debug (25569) [iobroker/cifs] done
                backitup.0 2021-01-04 16:17:41.811 debug (25569) [iobroker/iobroker] done
                backitup.0 2021-01-04 16:17:40.793 debug (25569) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_01_04-15_17_38_backupiobroker.tar.gz
                backitup.0 2021-01-04 16:17:39.682 debug (25569) [iobroker/iobroker] host.IoBroker 3135 objects saved
                backitup.0 2021-01-04 16:17:39.661 debug (25569) [iobroker/iobroker] host.IoBroker 2514 states saved
                backitup.0 2021-01-04 16:17:37.965 debug (25569) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                backitup.0 2021-01-04 16:17:37.965 debug (25569) [iobroker/mount] mount error(1): Operation not permitted
                backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] sudo: setrlimit(RLIMIT_CORE): Operation not permitted
                backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=
                ,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/FRITZ.NAS/FRITZNAS/Backups/IoBroker /opt/i
                backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] mount error(1): Operation not permitted
                backitup.0 2021-01-04 16:17:37.963 debug (25569) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/FRITZ.NAS/FRITZNAS/Backups/IoBroker /opt/
                backitup.0 2021-01-04 16:17:37.940 debug (25569) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                  So ist meien Konfig im Adapter.
                  ich bin bei der Fritte immer irritiert. Auf der läuft es anscheinend anders, als auf der Syno, die ich verwende.
                  Die Freigabe mit /FRITZ.NAS/Backups/IoBroker kommt mir seltsam vor, weil
                  • IMHO hier kein führendes / hingehört
                  • FRITZ.NAS kein Bestandteil der Freigabe sein sollte, weil das ja der IP des Servers entspricht, oder? (aber da kann ich mich irren)
                  F Online
                  F Online
                  fastfoot
                  @Homoran sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                  tust du(dich irren) :-) die Fritz Freigabe hat immer //ip_der_fb/fritz.nas/Ordner, wobei fritz.nas abhängig von den Einstellungen ist. siehe hier
                  • F fastfoot
                    @fastfoot sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                    tust du(dich irren)
                    war ja auch vollkommen im Bereich des Möglichen 😂
                    aber dann darf der sharename doch nicht mit (noch) einem / beginnen
                    Ein / wird doch schon vom Adapter hinzugefügt
                    F 1 Antwort Letzte Antwort
                      tust du(dich irren)
                      F Online
                      F Online
                      fastfoot
                      meine Angabe hatte sich auf den mount Befehl in der Konsole bezogen, wenn Backitup den Slash selbst hinzufügt, sollte man ihn wohl weglassen, könnte aber gut sein dass das 'verziehen' wird
                      • F fastfoot
                        @fastfoot @Homoran
                        Wie gesagt, in meiner Konfig steht das führende / auch drin. Und es funktioniert...
                        Ob es vom Adapter rausgefiltert wird kann ich gar nicht sagen, hab aber auch keine Lust mal ohne / zu probieren. :-D
                          @fastfoot @Homoran
                          @Thomas-Braun sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                          in meiner eben nicht - und wir hatten bereits mindestens einen Fall, bei dem die Entfernung des führenden / eine Heilung eines Problems bewirkte
                          Das soll ja auch der User mit dem Problem machen.
                          Kann ja (mal wieder) ohne weiters sein, dass es nicht auf allen Systemen zu Problemen führt
                          • N NicoR
                            So ist meien Konfig im Adapter. Benutzer wurde mit entsprechender Freigabe in der Fritzbox angelegt.
                            crunchipC Offline
                            crunchipC Offline
                            @NicoR ich habe das auf nen externen Stick, der an der Fritte hängt ( Ordner Backup, Unterordner IoBroker) und meine config ist
                            /Backup/IoBroker
                            Also ohne das
                            /Fritz.Nas/
                            Möglichkeit wäre noch per Ftp
                            Per Ftp kommt das
                            /Fritz.Nas/
                            noch davor, wie bereits erwähnt, sofern man die Fritzbox nicht umbenannt hat, ansonsten den Namen entsprechend anpassen)
                            Frage nebenbei, ist überhaupt Platz auf dem internen Speicher?
                            HomoranH F N 3 Antworten Letzte Antwort
                              /Backup/IoBroker
                              Also ohne das
                              /Fritz.Nas/
                              Per Ftp kommt das
                              /Fritz.Nas/
                              @crunchip
                              so hatte ich es auch im Kopf.
                              Auch den Unterschied zu NFS
                                /Backup/IoBroker
                                Also ohne das
                                /Fritz.Nas/
                                Per Ftp kommt das
                                /Fritz.Nas/
                                F Online
                                F Online
                                fastfoot
                                @crunchip sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                                /Backup/IoBroker
                                Also ohne das
                                /Fritz.Nas/
                                Also hier ist fritz.nas zwingend notwendig, sowohl im Explorer als auch beim mount mit cifs, sehr seltsam...
                                • F fastfoot
                                  /Backup/IoBroker
                                  Also ohne das
                                  /Fritz.Nas/
                                  so sieht es bei mir mit CIFS auf die Syno auf allen meinen Installationen aus
                                  Beim Hostnamen optional die IP
                                    F Online
                                    F Online
                                    fastfoot
                                    ja, 'normale' shares brauchen nur die ip + Ordnername, das ist bei meiner NAS auch so, oder bei einer Freigabe auf dem Laptop. Bei der FritzBox brauche ich aber zwingend ip/fritz.nas/Ordnername. Habe es in Backitup mit und ohne probiert, ohne fritz.nas bekomme ich einen mount Fehler. Bei der Angabe des Pfads ist Backitup gnädig, es funktioniert jeweils mit und ohne vorangestellten Slash, im Bild mit
                                      /Backup/IoBroker
                                      Also ohne das
                                      /Fritz.Nas/
                                      Per Ftp kommt das
                                      /Fritz.Nas/
                                      N Offline
                                      N Offline
                                      NicoR
                                      @crunchip ich habe es jetzt in allen Variationen getestet. Hab auch ein USB Stick an der Fritzbox. Extra neu besorgt und mit 16Gb.
                                      Auch mit Ftp bekomme ich nix rüber.
                                      backitup.0	2021-01-04 19:39:59.682	debug	(29011) system.adapter.admin.0: logging true
                                      backitup.0	2021-01-04 19:39:47.749	debug	(29011) [iobroker] exec: done
                                      backitup.0	2021-01-04 19:39:47.598	debug	(29011) [iobroker/history] backitup.0.history.json
                                      backitup.0	2021-01-04 19:39:47.597	debug	(29011) [iobroker/history] backitup.0.history.html
                                      backitup.0	2021-01-04 19:39:47.436	debug	(29011) [iobroker/whatsapp] done
                                      backitup.0	2021-01-04 19:39:47.433	debug	(29011) sendTo "send" to system.adapter.whatsapp-cmb.0 from system.adapter.backitup.0
                                      whatsapp-cmb.0	2021-01-04 19:39:47.434	info	ftp: Error: /Backups\IoBroker/iobroker_2021_01_04-19_39_41_backupiobroker.tar.gz: Permission denied. to das musste hier nicht stehen
                                      whatsapp-cmb.0	2021-01-04 19:39:47.434	info	Die Sicherung wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!!
                                      whatsapp-cmb.0	2021-01-04 19:39:47.434	info	(13000) Send BackItUp:
                                      backitup.0	2021-01-04 19:39:47.430	debug	(29011) [iobroker/whatsapp] [iobroker] used WhatsApp-Instance: whatsapp-cmb.0
                                      backitup.0	2021-01-04 19:39:46.824	debug	(29011) [iobroker/clean] done
                                      backitup.0	2021-01-04 19:39:46.823	debug	(29011) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                      backitup.0	2021-01-04 19:39:46.221	debug	(29011) [iobroker/ftp] done
                                      backitup.0	2021-01-04 19:39:46.221	debug	(29011) [iobroker/ftp] Error: /Backups\IoBroker/iobroker_2021_01_04-19_39_41_backupiobroker.tar.gz: Permission denied.
                                      backitup.0	2021-01-04 19:39:46.215	debug	(29011) [iobroker/ftp] Send iobroker_2021_01_04-19_39_41_backupiobroker.tar.gz
                                      backitup.0	2021-01-04 19:39:46.214	debug	(29011) [iobroker/ftp] FTP connected.
                                      backitup.0	2021-01-04 19:39:45.042	debug	(29011) [iobroker/iobroker] done
                                      backitup.0	2021-01-04 19:39:44.020	debug	(29011) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_01_04-19_39_41_backupiobroker.tar.gz
                                      backitup.0	2021-01-04 19:39:42.957	debug	(29011) [iobroker/iobroker] host.IoBroker 3135 objects saved
                                      backitup.0	2021-01-04 19:39:42.937	debug	(29011) [iobroker/iobroker] host.IoBroker 2514 states saved
                                      backitup.0	2021-01-04 19:39:41.347	debug	(29011) Backup has started ...
                                      backitup.0	2021-01-04 19:39:40.654	debug	(29011) No backup file was found
                                      backitup.0	2021-01-04 19:39:38.653	error	(29011) FTP: Error: /Backups/IoBroker: Permission denied.
                                      backitup.0	2021-01-04 19:39:38.648	debug	(29011) FTP: connected.
                                      backitup.0	2021-01-04 19:39:38.351	debug	(29011) [ccu] 10 30 01 */3 * *
                                      backitup.0	2021-01-04 19:39:38.347	info	(29011) [ccu] backup was activated at 01:30 every 3 day(s)
                                      backitup.0	2021-01-04 19:39:38.347	debug	(29011) [iobroker] 10 00 02 */1 * *
                                      backitup.0	2021-01-04 19:39:38.340	info	(29011) [iobroker] backup was activated at 02:00 every 1 day(s)
                                      backitup.0	2021-01-04 19:39:38.276	info	(29011) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.0, js-controller: 3.1.6
                                      backitup.0	2021-01-04 19:39:37.998	debug	(29011) Plugin sentry Initialize Plugin (enabled=true)
                                      backitup.0	2021-01-04 19:39:37.535	debug	(29011) statesDB connected
                                      backitup.0	2021-01-04 19:39:37.535	debug	(29011) States connected to redis: 127.0.0.1:9000
                                      backitup.0	2021-01-04 19:39:37.529	debug	(29011) States create System PubSub Client
                                      backitup.0	2021-01-04 19:39:37.528	debug	(29011) States create User PubSub Client
                                      backitup.0	2021-01-04 19:39:37.524	debug	(29011) Redis States: Use Redis connection: 127.0.0.1:9000
                                      backitup.0	2021-01-04 19:39:37.523	debug	(29011) objectDB connected
                                      backitup.0	2021-01-04 19:39:37.519	debug	(29011) Objects connected to redis: 127.0.0.1:9001
                                      backitup.0	2021-01-04 19:39:37.495	debug	(29011) Objects client initialize lua scripts
                                      backitup.0	2021-01-04 19:39:37.494	debug	(29011) Objects create User PubSub Client
                                      backitup.0	2021-01-04 19:39:37.494	debug	(29011) Objects create System PubSub Client
                                      backitup.0	2021-01-04 19:39:37.492	debug	(29011) Objects client ready ... initialize now
                                      backitup.0	2021-01-04 19:39:37.427	debug	(29011) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.IoBroker	2021-01-04 19:39:36.077	info	instance system.adapter.backitup.0 started with pid 29011
                                      host.IoBroker	2021-01-04 19:39:33.574	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      backitup.0	2021-01-04 19:39:33.058	info	(28925) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      backitup.0	2021-01-04 19:39:33.058	debug	(28925) Plugin sentry destroyed
                                      backitup.0	2021-01-04 19:39:33.057	info	(28925) terminating
                                      backitup.0	2021-01-04 19:39:33.057	info	(28925) cleaned everything up...
                                      backitup.0	2021-01-04 19:39:33.056	info	(28925) Got terminate signal TERMINATE_YOURSELF
                                      host.IoBroker	2021-01-04 19:39:33.054	info	stopInstance system.adapter.backitup.0 send kill signal
                                      host.IoBroker	2021-01-04 19:39:33.053	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
                                      MOD-Edit: Code in code-tags gesetzt und private Daten entfernt!
                                      Ich denke ich probiere mal das Backup direkt in Proxmox zu erschlagen. Vielleicht liegt es wirklich an dem LXC Container😵
                                      UncleSamU crunchipC 2 Antworten Letzte Antwort
                                      • N NicoR
                                        UncleSamU Offline
                                        UncleSamU Offline
                                        UncleSam
                                        @NicoR Bitte Code Tags </> verwenden!
                                        FTP müsste auch im Container gehen, aber du hast noch irgendwelche \ Backslash drin. Es müssen immer alles / Slashes sein.
                                          N Offline
                                          N Offline
                                          NicoR
                                          @UncleSam ok ich suche es mit nochmal an mit den slashes. Was genau meinst du mit Code Tags? Sorry für die Frage aber bin absolut neu hier.
                                          UncleSamU 1 Antwort Letzte Antwort
