  4. Backup von IoBroker auf WDMycloud oder FritzNAS
wdmycloudbackup auf nas
51 Beiträge 7 Kommentatoren 5.6k Aufrufe 6 Beobachtet
    @NicoR
    Bist du mit ioBroker in einem Container?
    Habe gerade nach der Fehlermeldung gegoogelt und gefunden:
    in container: sudo: setrlimit(RLIMIT_CORE): Operation not permitted ...
    N 1 Antwort Letzte Antwort
    • N NicoR
      @UncleSam
      Hier nochmal der Log:
      backitup.0	2021-01-04 14:53:36.528	debug	(24212) [iobroker] exec: done
      backitup.0	2021-01-04 14:53:36.377	debug	(24212) [iobroker/history] backitup.0.history.json
      backitup.0	2021-01-04 14:53:36.377	debug	(24212) [iobroker/history] backitup.0.history.html
      backitup.0	2021-01-04 14:53:36.220	debug	(24212) [iobroker/whatsapp] done
      backitup.0	2021-01-04 14:53:36.220	debug	(24212) sendTo "send" to system.adapter.whatsapp-cmb.0 from system.adapter.backitup.0
      backitup.0	2021-01-04 14:53:36.219	debug	(24212) [iobroker/whatsapp] [iobroker] used WhatsApp-Instance: whatsapp-cmb.0
      backitup.0	2021-01-04 14:53:35.615	debug	(24212) [iobroker/clean] done
      backitup.0	2021-01-04 14:53:35.614	debug	(24212) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      backitup.0	2021-01-04 14:53:35.163	debug	(24212) [iobroker/cifs] done
      backitup.0	2021-01-04 14:53:34.109	debug	(24212) [iobroker/iobroker] done
      backitup.0	2021-01-04 14:53:33.087	debug	(24212) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_01_04-13_53_30_backupiobroker.tar.gz
      backitup.0	2021-01-04 14:53:31.993	debug	(24212) [iobroker/iobroker] host.IoBroker 3135 objects saved
      backitup.0	2021-01-04 14:53:31.972	debug	(24212) [iobroker/iobroker] host.IoBroker 2514 states saved
      backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] Try 'mount --help' for more information.
      backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] mount: bad usage
      backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] sudo: setrlimit(RLIMIT_CORE): Operation not permitted
      backitup.0	2021-01-04 14:53:30.291	debug	(24212) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/ /FRITZ.NAS/Backups/IoBroker /opt/iobroker
      backitup.0	2021-01-04 14:53:30.290	debug	(24212) [iobroker/mount] Try 'mount --help' for more information.
      backitup.0	2021-01-04 14:53:30.290	debug	(24212) [iobroker/mount] mount: bad usage
      backitup.0	2021-01-04 14:53:30.288	debug	(24212) [iobroker/mount] sudo: setrlimit(RLIMIT_CORE): Operation not permitted
      backitup.0	2021-01-04 14:53:30.288	debug	(24212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/ /FRITZ.NAS/Backups/IoBroker /opt/iobroke
      backitup.0	2021-01-04 14:53:30.266	debug	(24212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
      MOD-Edit: Code in code-tags gesetzt!
      Also ich habe auf einem Laptop Proxmox installiert. Auf einer damit erstellten VM läuft ein Ubunto mit dem iobroker drauf.Js Version 3.1.6
      @NicoR sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
      @Homoran
      Also virtualisierter Kram. Da bin ich dann auch raus. Da bin ich zu doof für... :-D
        @NicoR
        N Offline
        N Offline
        NicoR
        @Homoran
        Ja ist in einem LXC Container
        • N NicoR
          @Homoran
          @NicoR
          Ich dachte in einer VM?
          Na egal, bin ich so oder so raus.
          • N NicoR
            @UncleSam
            UncleSamU Offline
            UncleSamU Offline
            UncleSam
            Ich bin ja kein CIFS/SMB Spezialist, aber stimmt das da: zwischen IP und Pfad hat es eine Lücke.
            Normalerweise sollte das doch ungefähr so aussehen:
            sudo mount -t cifs -o <options> //WIN_SHARE_IP/<share_name> /mnt/win_share
            Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
            ♡-lichen Dank an meine Sponsoren
            • N NicoR
              @Homoran
              LXC Container
              das ist keine VM
              • UncleSamU UncleSam
                @UncleSam
                Adlerauge!
                Stimmt, da darf kein Leerzeichen sein.
                  @NicoR
                  N Offline
                  N Offline
                  NicoR
                  @Thomas-Braun Ja sorry. Hatte ich vergessen. Ich bin bei dem Thema ja leider auch raus.😲
                  • UncleSamU Offline
                    UncleSamU Offline
                    UncleSam
                    Von https://bayton.org/docs/linux/lxd/mount-cifssmb-shares-rw-in-lxd-containers/:
                    One of the biggest limitations with LXD I’ve found to date is the inability to mount remote shares on unprivileged containers. While it’s still not possible at this point to mount CIFS shares from within a container directly, I’ve figured out a way to get around this by first mounting the shares on the LXD host and then using lxd config device add to mount them in my containers from there.
                    Wenn das so ist, dann findest du hier möglicherweise eine Lösung:
                    https://forum.proxmox.com/threads/solved-expose-cifs-share-to-lxc-container.44757/
                    Ansonsten würde ich den Mount einfach auf dem Proxmox machen und dann das Lokale Verzeichnis in den Container mounten.
                      @UncleSam sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                      Aber wo kommt die her, in der Konfig steht die IP und der share.
                      Die IP ist ohne / am ende, also auch kein Leerzeichen dort. Das wird beim zusammenbau hinzugefügt.
                      Entweder ist das in der Konfig vor dem Pfad zum share, oder dort gehört kein führender / hin
                      @NicoR
                      Ist vor dem /FRITZ.NAS ein Leerzeichen?
                      Wenn ja, löschen, wenn nein, bitte mal ohne / versuchen.
                      Ich bin bei Containern nämlich sonst auch raus
                        @NicoR
                        N Offline
                        N Offline
                        NicoR
                        @Homoran
                        War kein Leerzeichen. Hab es jetzt mal entfernt. Denke ist aber immer noch der gleiche Fehler.
                        Hier der Log:
                        backitup.0 2021-01-04 16:17:44.233 debug (25569) [iobroker] exec: done
                        backitup.0 2021-01-04 16:17:44.082 debug (25569) [iobroker/history] backitup.0.history.json
                        backitup.0 2021-01-04 16:17:44.081 debug (25569) [iobroker/history] backitup.0.history.html
                        whatsapp-cmb.0 2021-01-04 16:17:43.925 info (13000) Send BackItUp: Die Sicherung wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!! mount: Error: Command failed: sudo mount -t cifs -o username=Backup,password=,rw,file_
                        backitup.0 2021-01-04 16:17:43.923 debug (25569) [iobroker/whatsapp] done
                        backitup.0 2021-01-04 16:17:43.923 debug (25569) sendTo "send" to system.adapter.whatsapp-cmb.0 from system.adapter.backitup.0
                        backitup.0 2021-01-04 16:17:43.922 debug (25569) [iobroker/whatsapp] [iobroker] used WhatsApp-Instance: whatsapp-cmb.0
                        backitup.0 2021-01-04 16:17:43.317 debug (25569) [iobroker/clean] done
                        backitup.0 2021-01-04 16:17:43.317 debug (25569) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                        backitup.0 2021-01-04 16:17:42.866 debug (25569) [iobroker/cifs] done
                        backitup.0 2021-01-04 16:17:41.811 debug (25569) [iobroker/iobroker] done
                        backitup.0 2021-01-04 16:17:40.793 debug (25569) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_01_04-15_17_38_backupiobroker.tar.gz
                        backitup.0 2021-01-04 16:17:39.682 debug (25569) [iobroker/iobroker] host.IoBroker 3135 objects saved
                        backitup.0 2021-01-04 16:17:39.661 debug (25569) [iobroker/iobroker] host.IoBroker 2514 states saved
                        backitup.0 2021-01-04 16:17:37.965 debug (25569) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                        backitup.0 2021-01-04 16:17:37.965 debug (25569) [iobroker/mount] mount error(1): Operation not permitted
                        backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] sudo: setrlimit(RLIMIT_CORE): Operation not permitted
                        backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=
                        ,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/FRITZ.NAS/FRITZNAS/Backups/IoBroker /opt/i
                        backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                        backitup.0 2021-01-04 16:17:37.964 debug (25569) [iobroker/mount] mount error(1): Operation not permitted
                        backitup.0 2021-01-04 16:17:37.963 debug (25569) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/FRITZ.NAS/FRITZNAS/Backups/IoBroker /opt/
                        backitup.0 2021-01-04 16:17:37.940 debug (25569) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                          So ist meien Konfig im Adapter.
                          ich bin bei der Fritte immer irritiert. Auf der läuft es anscheinend anders, als auf der Syno, die ich verwende.
                          Die Freigabe mit /FRITZ.NAS/Backups/IoBroker kommt mir seltsam vor, weil
                          • IMHO hier kein führendes / hingehört
                          • FRITZ.NAS kein Bestandteil der Freigabe sein sollte, weil das ja der IP des Servers entspricht, oder? (aber da kann ich mich irren)
                          F Online
                          F Online
                          fastfoot
                          @Homoran sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                          tust du(dich irren) :-) die Fritz Freigabe hat immer //ip_der_fb/fritz.nas/Ordner, wobei fritz.nas abhängig von den Einstellungen ist. siehe hier
                          • F fastfoot
                            @fastfoot sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                            tust du(dich irren)
                            war ja auch vollkommen im Bereich des Möglichen 😂
                            aber dann darf der sharename doch nicht mit (noch) einem / beginnen
                            Ein / wird doch schon vom Adapter hinzugefügt
                            F 1 Antwort Letzte Antwort
                              tust du(dich irren)
                              F Online
                              F Online
                              fastfoot
                              meine Angabe hatte sich auf den mount Befehl in der Konsole bezogen, wenn Backitup den Slash selbst hinzufügt, sollte man ihn wohl weglassen, könnte aber gut sein dass das 'verziehen' wird
                              • F fastfoot
                                @fastfoot @Homoran
                                Wie gesagt, in meiner Konfig steht das führende / auch drin. Und es funktioniert...
                                Ob es vom Adapter rausgefiltert wird kann ich gar nicht sagen, hab aber auch keine Lust mal ohne / zu probieren. :-D
                                  @fastfoot @Homoran
                                  @Thomas-Braun sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                                  in meiner eben nicht - und wir hatten bereits mindestens einen Fall, bei dem die Entfernung des führenden / eine Heilung eines Problems bewirkte
                                  Das soll ja auch der User mit dem Problem machen.
                                  Kann ja (mal wieder) ohne weiters sein, dass es nicht auf allen Systemen zu Problemen führt
                                  • N NicoR
                                    So ist meien Konfig im Adapter. Benutzer wurde mit entsprechender Freigabe in der Fritzbox angelegt.
                                    crunchipC Offline
                                    crunchipC Offline
                                    @NicoR ich habe das auf nen externen Stick, der an der Fritte hängt ( Ordner Backup, Unterordner IoBroker) und meine config ist
                                    /Backup/IoBroker
                                    Also ohne das
                                    /Fritz.Nas/
                                    Möglichkeit wäre noch per Ftp
                                    Per Ftp kommt das
                                    /Fritz.Nas/
                                    noch davor, wie bereits erwähnt, sofern man die Fritzbox nicht umbenannt hat, ansonsten den Namen entsprechend anpassen)
                                    Frage nebenbei, ist überhaupt Platz auf dem internen Speicher?
                                    HomoranH F N 3 Antworten Letzte Antwort
                                      /Backup/IoBroker
                                      Also ohne das
                                      /Fritz.Nas/
                                      Per Ftp kommt das
                                      /Fritz.Nas/
                                      @crunchip
                                      so hatte ich es auch im Kopf.
                                      Auch den Unterschied zu NFS
                                        /Backup/IoBroker
                                        Also ohne das
                                        /Fritz.Nas/
                                        Per Ftp kommt das
                                        /Fritz.Nas/
                                        F Online
                                        F Online
                                        fastfoot
                                        @crunchip sagte in Backup von IoBroker auf WDMycloud oder FritzNAS:
                                        /Backup/IoBroker
                                        Also ohne das
                                        /Fritz.Nas/
                                        Also hier ist fritz.nas zwingend notwendig, sowohl im Explorer als auch beim mount mit cifs, sehr seltsam...
                                        • F fastfoot
                                          /Backup/IoBroker
                                          Also ohne das
                                          /Fritz.Nas/
                                          so sieht es bei mir mit CIFS auf die Syno auf allen meinen Installationen aus
                                          Beim Hostnamen optional die IP
