jarvis v2.2.0 - just another remarkable vis
@Zefau said in jarvis v2.1.0 - just another remarkable vis:
@JayR bitte auf Github in den issues nach der Version suchen
Ich bekomme einen Fehler beim updaten:
$ ./iobroker url "https://github.com/Zefau/ioBroker.jarvis" Unable to subscribe to evicted Keyspace events from Redis Server: Error: Connection is closed. install https://github.com/Zefau/ioBroker.jarvis/tarball/011407ef70661424211ac281febf74532a335772 NPM version: 6.14.8npm install https://github.com/Zefau/ioBroker.jarvis/tarball/011407ef70661424211ac281febf74532a335772 --loglevel error --prefix "/opt/iobroker" (System call) npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.jarvisnpm ERR! errno -13npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.jarvis'npm ERR! [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.jarvis'] {npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'access',npm ERR! path: '/opt/iobroker/node_modules/iobroker.jarvis'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator. npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-01-03T11_22_31_655Z-debug.log ERROR: host.Collector Cannot install https://github.com/Zefau/ioBroker.jarvis/tarball/011407ef70661424211ac281febf74532a335772: 243 ERROR: process exited with code 25 -
@Bloody sagte in jarvis v2.1.0 - just another remarkable vis:
seit der 2.2.0-beta.2 funktionieren folgende Farbveränderungen und Icon Geblinke nicht mehr. Gestern erst mit der 2.1 konfiguriert gehabt.
Was geht denn konkret nicht?
Die Anzeige war in Firefox und Chrome bisher unterschiedlich und mit v2.2 wurde es angeglichen.
Eigentlich sollten die Batteriestände ähnlich dem Müll unter 5% blinken, rot angezeigt und ein ICON mit Ausrufezeichen angezeigt werden. Stattdessen passiert gar nichts. Icon wird grün angezeigt und blinkt auch nicht und auch nicht das richtige Icon. Zudem ab 50% eigentlich gelb aber auch das funktioniert nicht mehr.
Eigentlich müsste es ähnlich dem Altpapier aussehen. Da funktioniert es komischerweise noch. Natürlich mit anderen Werten, siehe auch oben im Spoiler.
@Stephan-Schleich said in jarvis v2.1.0 - just another remarkable vis:
@Bloody @Zefau ist das blinken mittlerweile nativ in Jarvis oder muss man es immernoch manuell hinterlegen?
Es muss noch manuell hinterlegt werden.
Hallo @Zefau,
ich habe mir gerade die aktuelle Version von Github gezogen und danach - zugegebenermaßen das erste Mal - versucht, eine Gruppe für die Beleuchtung im OG anzulegen. Leider tut sich da exakt nix. ;)
Ich habe dazu einfach im Layout im Widget der bestehenden einzelnen Lampen manuell eine Gruppe hinzugefügt, die auch grundsätzlich über eine Switch Action verfügt. Leider lässt sich diese im View hinterher nicht schalten. Passt da noch was nicht oder hab ich evtl. was falsch verstanden?
Des Weiteren wird mir in der Konsole angezeigt, dass es Probleme mit der Webfont gibt:
downloadable font: Failed to convert WOFF 2.0 font to SFNT (font-family: "Material Design Icons" style:normal weight:400 stretch:100 src index:1) source: http://xxx/jarvis/fonts/materialdesignicons-webfont.woff2?v=5.8.55und
downloadable font: rejected by sanitizer (font-family: "Material Design Icons" style:normal weight:400 stretch:100 src index:1) source: http://xxx/jarvis/fonts/materialdesignicons-webfont.woff2?v=5.8.55In Ermangelung anderer Rückmeldungen beantworte ich mir das hier einfach mal selbst - vielleicht steht ja der ein oder andere vor demselben Problem:
Ein Trennstreifen hat nicht nur optische Funktion, er trennt tatsächlich auch die Logik bei der Gruppenzugehörigkeit. Ich hatte ihn aus optischen Gründen quasi in einem Atemzug mit der Gruppe angelegt und beides an erste bzw. zweite Position verschoben. Ist mir allerdings erst nach einigem Hin und Her aufgefallen.
@dabbeljuh sagte in jarvis v2.1.0 - just another remarkable vis:
Mach gerne ein Feature Request auf, dann baue ich eine Option ein, dass das Unterbrechen der Gruppe wahlweise passiert (oder nicht).
@Zefau, der Feature Request ist angelegt. Mir persönlich würde es auch genügen, wenn ich die Position des automatisch eingefügten Trennstreifens beeinflussen könnte, da es mir in erster Linie um die Optik ging. Eventuell wäre diesbezüglich auch ein kurzer Hinweis am/beim Trenner im Widget hilfreich.
Am Tablet wird mir für beide Tabs 2 Spalten anzeigt, also bei Heizung nur der halbe Bildschirm. Ist das so gewollt oder muss ich etwas anderes einstellen, damit der Tab Dashboard 2 Spalten und Heizung 1 breite Spalte hat?
@Zefau : Ich bekomme nach dem Update den folgenden Fehler:
@JayR sagte in jarvis v2.1.0 - just another remarkable vis:
Liegt wohl an der fehlgeschlagenen Installation. Die Dateien sind nicht da (daher
404). Mach mal nen Upload und wenn das nicht geht, installier' nochmal. -
Ich habe eine Anzeigevariante : {"0":"ECO","1":"Power"}
Jedoch bekomme ich bei "1" nicht "Power" angezeigt sondern "Geräte Status" Sobald ich "Power" zu z.b. ".Power" ändere bekomme ich ".Power" angezeigt.
Ist "Power" irgendwie/irgendwo anders formatiert ?
@Johannes-Bauerstatter sagte in jarvis v2.1.0 - just another remarkable vis:
@Zefau Danke. Das hätte ich schon probiert, aber ich möchte in einem Tab 2 Spalten und in einem anderen Tab 1 Spalte einstellen. Ist das am Tablet möglich? Mit den Einstellungen kann ich nur generell auf 1 oder 2 Spalten umstellen.
Das geht nicht. Da müsstest du zwei jarvis erstellen.
@Zefau Ok. Vielen Dank.
Hi Johannes,
probier mal die Einstellung "alle" unter "Theme Einstellung -> Spalten auf mittleren Bildschirm".
Wenn ich dich richtig verstanden habe, ist es bei dir ähnlich wie bei mir.
(Und schau das du auf der letzen Beta Version bist, sonst ist alles bisschen klein
Gruß,
Simon -
erst mal an @Zefau großes Kompliment für den super VIS für ioBroker. Genau so etwas einfaches hab ich immer gesucht und man hat super schnell eine übersichtliche Darstellung der Haussteuerung.
Vorab: Ich erstelle die Geräte und Datenpunkte meist manuell, da ich damit genau definieren kann, was ich auch später visualisieren will und muss mich nicht so arg durchwühlen. Derzeit verwende ich die Version
2.2.0-beta2- sowohl am Rechner und am Android-Tablet. Leider gibt es hier ein paar Darstellungsprobleme.Zum einen das Thema der Spaltendarstellung. Wenn man in den Theme-Einstellungen bei mittlerem Bildschirm auf "alle" umstellt (das passt zum Tablet), dann werden alle 12 Spalten angezeigt und damit die 3 Spalten zusammengequetscht. Da ich manche Ansichten habe, in denn nur eine oder zwei Spalten sind, dann wird viel Platz "verschenkt":
Beim Rechner werden die Spalten entsprechend auf die Bildschirmbreite "gezogen". Wäre schön, wenn sich das irgendwie beheben lässt.
Ansonsten habe ich noch das Problem, dass Farben unterschiedlich dargestellt werden:
So habe ich mir für verschiedene Regionen ein "Corona-Dashboard" erstellt und beim Datenpunkt- und Icon-Stil folgende Farbregeln hinterlegt:{"<200":{"color":"#ec1500","fontWeight":"bold"},"<150":{"color":"#cb4335","fontWeight":"bold"},"<100":{"color":"#f1c40f","fontWeight":"bold"},"<50":{"color":"#1e8449"},">=200":{"color":"#c96cef","fontWeight":"bold"}}Am Rechner führt das zu folgender Darstellung:
Auf dem Tablet werden aber nur zwei Farben dargestellt:
Gilt übrigens auch für die Darstellung des Füllstandes (rechts - sollte beides Mal "rot" sein).
Will natürlich nicht ausschließen, dass ich einen Fehler im JSON gemacht habe.
Zum Schluss vielleicht noch den ein Feature Request:
Bei manchen iFrames, die ich einbinde bekomme ich eine Fehlermeldung, dass ich das nicht darf. Das ist meist ein Schutzmechanismus von Webseiten-Betreibern um Angriffe abzuwehren. Gibt es hierfür ggf. eine Alternative? Beispiel hierfür wäre https://my.arlo.com Die Seite kann ich nicht per iFrame einbinden.
Danke für die Hilfestellung. Ich teste gerne weiter. Vielleicht können wir auch mal einen eigenen Thread auf machen mit "Zeigt eure jarvis-Dashboards". Kann man ggf. viel von lernen - auch wie man über ioBroker, eigene Datenpunkte und Skripte bedingte Anzeigen bauen kann oder Steuerungen weiter verfeinern kann.
Viele Grüße
Michael -
@wolkenschaufler ändern sich die Graphen bei Dir wenn DU das Fenster größer oder kleiner machst? Ich bekomme das mit den Graphen aus dem Material Designpaket nicht hin.
@stephan1827 Sorry, hab das überlesen. Ja, die Graphen ändern sich bei mir.
@wolkenschaufler hast du das hier auch eingestellt?
@watcherkb Nein, habe ich nicht. Ich habs in der URL eingetragen, siehe Parameter refresh:
http://192.168.188.15:3000/d-solo/u6BWOqJMk/jarvis?orgId=1&refresh=10s&from=now-7d&to=now&theme=light&panelId=8
