  4. [Gelöst] Email-Empfang Iobroker
    1.0k
    6.1k
iobrokerjavascriptmailistener2
101 Beiträge 7 Kommentatoren 16.4k Aufrufe 7 Beobachtet
  • liv-in-skyL liv-in-sky
    @sigi234
    neustart ?
    sigi234S Online
    sigi234S Online
    @liv-in-sky sagte in Email-Empfang Iobroker:
    @sigi234
    neustart ?
    Jupp.
    node-red.0	2020-12-07 16:19:45.409	info	(6672) node-red exited with 1
    node-red.0	2020-12-07 16:19:45.287	warn	(6672) 7 Dec 16:19:45 - [warn] Projects disabled : editorTheme.projects.enabled=false
    node-red.0	2020-12-07 16:19:41.610	info	(6672) Starting node-red: --max-old-space-size=128 C:\Program Files\iobroker\Test\node_modules\node-red/red.js -v --settings C:\Program Files\iobroker\Test\node_modules\iobroker.node-red/userdata/sett
    node-red.0	2020-12-07 16:19:36.589	info	(6672) node-red exited with 1
    node-red.0	2020-12-07 16:19:36.467	warn	(6672) 7 Dec 16:19:36 - [warn] Projects disabled : editorTheme.projects.enabled=false
    node-red.0	2020-12-07 16:19:32.814	info	(6672) Starting node-red: --max-old-space-size=128 C:\Program Files\iobroker\Test\node_modules\node-red/red.js -v --settings C:\Program Files\iobroker\Test\node_modules\iobroker.node-red/userdata/sett
    node-red.0	2020-12-07 16:19:27.811	info	(6672) node-red exited with 1
    node-red.0	2020-12-07 16:19:27.699	warn	(6672) 7 Dec 16:19:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
    node-red.0	2020-12-07 16:19:23.748	info	(6672) Starting node-red: --max-old-space-size=128 C:\Program Files\iobroker\Test\node_modules\node-red/red.js -v --settings C:\Program Files\iobroker\Test\node_modules\iobroker.node-red/userdata/sett
    node-red.0	2020-12-07 16:19:21.676	error	(6672) install: ["node-red-node-pushover"]
    node-red.0	2020-12-07 16:19:21.667	info	(6672) starting. Version 2.0.1 in C:/Program Files/iobroke
    Habe den Pallettenmanager aktiviert und einige nodes, denke da ist was schief gelaufen.
    • sigi234S sigi234
      @sigi234
      neustart ?
      Jupp.
      liv-in-skyL Offline
      liv-in-skyL Offline
      @sigi234 da kann ich leider nicht viel helfen - vermeide nodered adapter , wenn möglich, genau wegen solchen problemen
        sigi234S Online
        sigi234S Online
        Ich auch eigentlich. Vielleicht geht es mal mit upnp
        • sigi234S sigi234
          liv-in-skyL Offline
          liv-in-skyL Offline
          @sigi234 falls du dich damit etwas auskennst, kannst ja mal kucken, ob diese daten dort drin sind
            sigi234S Online
            sigi234S Online
            Nein nur teilweise drinnen.
            N R 2 Antworten Letzte Antwort
            • sigi234S sigi234
              N Offline
              N Offline
              NebuNC2
              schrieb am zuletzt editiert von NebuNC2
              @liv-in-sky
              Gestern 24:00 25.29 GB 729.37 MB 24.56 GB 0 Aktuelle Woche48:01 45.51 GB 1.30 GB 44.21 GB 0 Letzte Woche 168:00 199.59 GB 5.39 GB 194.20GB 0 Aktueller Monat 192:01 208.49 GB 5.92 GB 202.57 GB 0 Vormonat 720:00 640.72GB 16.35 GB 624.37 GB 0
              Irgendwas stimmt in Gesendet nicht
              N 1 Antwort Letzte Antwort
              • N NebuNC2
                @liv-in-sky
                N Offline
                N Offline
                NebuNC2
                Gesamt und Empfangen ist identisch
                • N NebuNC2
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @NebuNC2 anydesk ? wenn ja
                  ruf durch
                  • GarganoG Offline
                    GarganoG Offline
                    Gargano
                    Funktioniert das Script auch für pop3, oder nur für imap ?
                    Ich habe bei 1und1 ein pop3 Postfach, was muß ich da ändern ?
                    Viele Grüße
                    • liv-in-skyL Offline
                      liv-in-skyL Offline
                      nur zur info: man kann auch in der mailbox einen unterordner einrichten (ging bei mir beim provider im mailsetting) - wegen: das mail als read markieren - da will man nicht die ganze mailbox als read setzen lassen
                      dann kann in nodered dieser unterordner angegeben werden und man braucht keine eigene mailadresse
                      natürlich muss im mailprogramm eine umleitung (regel) für dieses mail eingerichtet werden !
                      • GarganoG Gargano
                        Viele Grüße
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @Gargano 1und 1 bietet doch imap an
                        • GarganoG Gargano
                          Viele Grüße
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @Gargano
                          nutz ich z.b. hier:
                          var maillistenerSetting = {
                                username: "xxxxxxy@online.de",    // hier Email Adresse eintragen
                                password: "yyyyy",	      // hier Passwort eintragen
                                host: "imap.1und1.de",
                                port: 993, // imap port
                                tl
                          GarganoG 1 Antwort Letzte Antwort
                            @Gargano
                            nutz ich z.b. hier:
                                  tl
                            GarganoG Offline
                            GarganoG Offline
                            Gargano
                            @liv-in-sky Ok , danke. Empfangen funktioniert.
                            Gibt es eine Doku über die Struktur vom Objekt mail ?
                            Bei mir wird für mail.text 'undefined' ausgegeben.
                            Viele Grüße
                            • GarganoG Gargano
                              Viele Grüße
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @Gargano kannst du im debug-node in nodered einstellen und ansehen
                                GarganoG Offline
                                GarganoG Offline
                                Gargano
                                @liv-in-sky Ich hab kein Nodered sondern es mit dem Javascript gemacht, daß weiter oben steht.
                                • GarganoG Gargano
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @Gargano dann sollte es stimmen
                                  hier ein beispiel von mir
                                    GarganoG Offline
                                    GarganoG Offline
                                    Gargano
                                    @liv-in-sky Ich habe nur die einfache Version genommen, hier der Code.
                                    // Quelle Original: https://github.com/chirag04/mail-listener2
                                    // Quelle Forum: https://forum.iobroker.net/topic/18501/emails-empfangen
                                    const EmailText = "javascript.0.Email.EmailText";
                                    const EmailEingang = "javascript.0.Email.Email_Eingang";
                                    createState(EmailEingang, {
                                        type: 'string',
                                        min: 0,
                                        def: 0,
                                        role: 'value'
                                    createState(EmailText, {
                                        type: 'string',
                                        min: 0,
                                        def: 0,
                                        role: 'value'
                                        var MailListener = require("mail-listener2");
                                        var mailListener = new MailListener({
                                          username: "xxxxx",    // HIER Email Adresse eintragen
                                          password: "yyyy",	      // HIER Passwort eintragen
                                          host: "imap.ionos.de",
                                          tls: true,
                                          connTimeout: 10000, // Default by node-imap
                                          authTimeout: 5000, // Default by node-imap,
                                          debug: null, // Or your custom function with only one incoming argument. Default: null
                                          tlsOptions: { rejectUnauthorized: false },
                                          mailbox: "INBOX", // HIER Postfach eingeben z.B. INBOX
                                          searchFilter: ["UNSEEN"], // the search filter being used after an IDLE notification has been retrieved
                                          markSeen: true, // all fetched email willbe marked as seen and not fetched next time
                                          fetchUnreadOnStart: true, // use it only if you want to get all unread email on lib start. Default is `false`,
                                          mailParserOptions: {streamAttachments: false}, // options to be passed to mailParser lib.
                                          attachments: false, // download attachments as they are encountered to the project directory
                                          attachmentOptions: { directory: "attachments/" } // specify a download directory for attachments
                                        mailListener.start();
                                        mailListener.on("server:connected", function(){console.log("------- imapConnected");});
                                        mailListener.on("server:disconnected", function(){console.log("------- imapDisconnected");});
                                        mailListener.on("error", function(err){console.log("MailError "+err);});
                                        mailListener.on("mail", function(mail, seqno, attributes){
                                            log("Mail from: "+mail.from[0].address);
                                            log("Name: "+mail.from[0].name);
                                            log("Subject: "+mail.subject);
                                            log("Text: "+mail.text);
                                    //     setState(EmailEingang,mail.from[0].address);  	//setze Datenpunkt mit Email-Absender (als Trigger nutzbar)
                                    //     setState(EmailText,mail.text);			//setze Datenpunkt mit kompletten Email-Inhalt
                                        // mailListener.on("attachment", function(attachment){console.log(attachment.path);}); //wenn Anhänge verarbeitet werden sollen einkommentieren
                                    mail.from[0].address,mail.from[0].name,mail.subject funktioniert. nur mail.text nicht
                                    • GarganoG Gargano
                                          type: 'string',
                                          min: 0,
                                          def: 0,
                                          role: 'value'
                                          type: 'string',
                                          min: 0,
                                          def: 0,
                                          role: 'value'
                                            tls: true,
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @Gargano
                                      das funktioniert bei mir. mail-listener4 aber sollte auch mit mail-listener2 funktionieren:
                                          type: 'string',
                                          min: 0,
                                          def: 0,
                                          role: 'value'
                                          type: 'string',
                                          min: 0,
                                          def: 0,
                                          role: 'value'
                                          var MailListener = require("mail-listener4");
                                           username: "xxxxx.de",    // hier Email Adresse eintragen
                                            password: "xxxxxxxx",	      // hier Passwort eintragen
                                            tls: true,
                                            markSeen: false, // all fetched email willbe marked as seen and not fetched next time
                                              maillistenerSetting
                                          mailListener.on("server:connected", function(){/*console.log("imapconconnected")*/;});
                                          mailListener.on("server:disconnected", function(){/*console.log("imapDisconnected");*/});
                                          mailListener.on("error", function(err){console.log(err);});
                                           //   log("Mail from: "+mail.from[0].address);
                                             // log("Name: "+mail.from[0].name);
                                             // log("Subject: "+mail.subject);
                                        @Gargano
                                            type: 'string',
                                            min: 0,
                                            def: 0,
                                            role: 'value'
                                            type: 'string',
                                            min: 0,
                                            def: 0,
                                            role: 'value'
                                              tls: true,
                                                maillistenerSetting
                                        GarganoG Offline
                                        GarganoG Offline
                                        Gargano
                                        @liv-in-sky Seltsam, bei mir geht es auch mit mail-listener4 nicht.
                                        Muß ich irgendetwas anderes noch eintragen außer in der Javascript Instanz ?
                                        • GarganoG Gargano
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @Gargano
                                          nein nur da- hast du mein script getestet - ist anders als deines
