  4. [Gelöst] Email-Empfang Iobroker
    1.0k
    6.1k
iobrokerjavascriptmailistener2
101 Beiträge 7 Kommentatoren 16.4k Aufrufe 7 Beobachtet
  • liv-in-skyL liv-in-sky
    @sigi234
    so sieht meine mail aus:
    sigi234S Online
    sigi234S Online
    @liv-in-sky
    Meine auch, aber komme jetzt nicht mehr auf Node Red
    node-red.0	2020-12-07 16:10:09.450	info	(17572) node-red exited with 1
    node-red.0	2020-12-07 16:10:09.350	error	(17572) 7 Dec 16:10:09 - [error] Error: port in use
    node-red.0	2020-12-07 16:10:09.350	error	(17572) 7 Dec 16:10:09 - [error] Unable to listen on http://127.0.0.1:1880/
    • sigi234S sigi234
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      @sigi234
      neustart ?
        @sigi234
        neustart ?
        sigi234S Online
        sigi234S Online
        @liv-in-sky sagte in Email-Empfang Iobroker:
        @sigi234
        neustart ?
        Jupp.
        node-red.0	2020-12-07 16:19:45.409	info	(6672) node-red exited with 1
        node-red.0	2020-12-07 16:19:45.287	warn	(6672) 7 Dec 16:19:45 - [warn] Projects disabled : editorTheme.projects.enabled=false
        node-red.0	2020-12-07 16:19:41.610	info	(6672) Starting node-red: --max-old-space-size=128 C:\Program Files\iobroker\Test\node_modules\node-red/red.js -v --settings C:\Program Files\iobroker\Test\node_modules\iobroker.node-red/userdata/sett
        node-red.0	2020-12-07 16:19:36.589	info	(6672) node-red exited with 1
        node-red.0	2020-12-07 16:19:36.467	warn	(6672) 7 Dec 16:19:36 - [warn] Projects disabled : editorTheme.projects.enabled=false
        node-red.0	2020-12-07 16:19:32.814	info	(6672) Starting node-red: --max-old-space-size=128 C:\Program Files\iobroker\Test\node_modules\node-red/red.js -v --settings C:\Program Files\iobroker\Test\node_modules\iobroker.node-red/userdata/sett
        node-red.0	2020-12-07 16:19:27.811	info	(6672) node-red exited with 1
        node-red.0	2020-12-07 16:19:27.699	warn	(6672) 7 Dec 16:19:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
        node-red.0	2020-12-07 16:19:23.748	info	(6672) Starting node-red: --max-old-space-size=128 C:\Program Files\iobroker\Test\node_modules\node-red/red.js -v --settings C:\Program Files\iobroker\Test\node_modules\iobroker.node-red/userdata/sett
        node-red.0	2020-12-07 16:19:21.676	error	(6672) install: ["node-red-node-pushover"]
        node-red.0	2020-12-07 16:19:21.667	info	(6672) starting. Version 2.0.1 in C:/Program Files/iobroke
        Habe den Pallettenmanager aktiviert und einige nodes, denke da ist was schief gelaufen.
        • sigi234S sigi234
          @sigi234
          neustart ?
          Jupp.
          liv-in-skyL Offline
          liv-in-skyL Offline
          @sigi234 da kann ich leider nicht viel helfen - vermeide nodered adapter , wenn möglich, genau wegen solchen problemen
            sigi234S Online
            sigi234S Online
            Ich auch eigentlich. Vielleicht geht es mal mit upnp
            • sigi234S sigi234
              liv-in-skyL Offline
              liv-in-skyL Offline
              @sigi234 falls du dich damit etwas auskennst, kannst ja mal kucken, ob diese daten dort drin sind
                sigi234S Online
                sigi234S Online
                Nein nur teilweise drinnen.
                N R 2 Antworten Letzte Antwort
                • sigi234S sigi234
                  N Offline
                  N Offline
                  NebuNC2
                  schrieb am zuletzt editiert von NebuNC2
                  @liv-in-sky
                  Gestern 24:00 25.29 GB 729.37 MB 24.56 GB 0 Aktuelle Woche48:01 45.51 GB 1.30 GB 44.21 GB 0 Letzte Woche 168:00 199.59 GB 5.39 GB 194.20GB 0 Aktueller Monat 192:01 208.49 GB 5.92 GB 202.57 GB 0 Vormonat 720:00 640.72GB 16.35 GB 624.37 GB 0
                  Irgendwas stimmt in Gesendet nicht
                  N 1 Antwort Letzte Antwort
                  • N NebuNC2
                    @liv-in-sky
                    N Offline
                    N Offline
                    NebuNC2
                    Gesamt und Empfangen ist identisch
                    • N NebuNC2
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @NebuNC2 anydesk ? wenn ja
                      ruf durch
                      • GarganoG Offline
                        GarganoG Offline
                        Gargano
                        Funktioniert das Script auch für pop3, oder nur für imap ?
                        Ich habe bei 1und1 ein pop3 Postfach, was muß ich da ändern ?
                        Viele Grüße
                        • liv-in-skyL Offline
                          liv-in-skyL Offline
                          nur zur info: man kann auch in der mailbox einen unterordner einrichten (ging bei mir beim provider im mailsetting) - wegen: das mail als read markieren - da will man nicht die ganze mailbox als read setzen lassen
                          dann kann in nodered dieser unterordner angegeben werden und man braucht keine eigene mailadresse
                          natürlich muss im mailprogramm eine umleitung (regel) für dieses mail eingerichtet werden !
                          • GarganoG Gargano
                            Viele Grüße
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @Gargano 1und 1 bietet doch imap an
                            • GarganoG Gargano
                              Viele Grüße
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @Gargano
                              nutz ich z.b. hier:
                              var maillistenerSetting = {
                                    username: "xxxxxxy@online.de",    // hier Email Adresse eintragen
                                    password: "yyyyy",	      // hier Passwort eintragen
                                    host: "imap.1und1.de",
                                    port: 993, // imap port
                                    tl
                              GarganoG 1 Antwort Letzte Antwort
                                @Gargano
                                nutz ich z.b. hier:
                                      tl
                                GarganoG Offline
                                GarganoG Offline
                                Gargano
                                @liv-in-sky Ok , danke. Empfangen funktioniert.
                                Gibt es eine Doku über die Struktur vom Objekt mail ?
                                Bei mir wird für mail.text 'undefined' ausgegeben.
                                Viele Grüße
                                • GarganoG Gargano
                                  Viele Grüße
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @Gargano kannst du im debug-node in nodered einstellen und ansehen
                                    GarganoG Offline
                                    GarganoG Offline
                                    Gargano
                                    @liv-in-sky Ich hab kein Nodered sondern es mit dem Javascript gemacht, daß weiter oben steht.
                                    • GarganoG Gargano
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @Gargano dann sollte es stimmen
                                      hier ein beispiel von mir
                                        GarganoG Offline
                                        GarganoG Offline
                                        Gargano
                                        @liv-in-sky Ich habe nur die einfache Version genommen, hier der Code.
                                        // Quelle Original: https://github.com/chirag04/mail-listener2
                                        // Quelle Forum: https://forum.iobroker.net/topic/18501/emails-empfangen
                                        const EmailText = "javascript.0.Email.EmailText";
                                        const EmailEingang = "javascript.0.Email.Email_Eingang";
                                        createState(EmailEingang, {
                                            type: 'string',
                                            min: 0,
                                            def: 0,
                                            role: 'value'
                                        createState(EmailText, {
                                            type: 'string',
                                            min: 0,
                                            def: 0,
                                            role: 'value'
                                            var MailListener = require("mail-listener2");
                                            var mailListener = new MailListener({
                                              username: "xxxxx",    // HIER Email Adresse eintragen
                                              password: "yyyy",	      // HIER Passwort eintragen
                                              host: "imap.ionos.de",
                                              tls: true,
                                              connTimeout: 10000, // Default by node-imap
                                              authTimeout: 5000, // Default by node-imap,
                                              debug: null, // Or your custom function with only one incoming argument. Default: null
                                              tlsOptions: { rejectUnauthorized: false },
                                              mailbox: "INBOX", // HIER Postfach eingeben z.B. INBOX
                                              searchFilter: ["UNSEEN"], // the search filter being used after an IDLE notification has been retrieved
                                              markSeen: true, // all fetched email willbe marked as seen and not fetched next time
                                              fetchUnreadOnStart: true, // use it only if you want to get all unread email on lib start. Default is `false`,
                                              mailParserOptions: {streamAttachments: false}, // options to be passed to mailParser lib.
                                              attachments: false, // download attachments as they are encountered to the project directory
                                              attachmentOptions: { directory: "attachments/" } // specify a download directory for attachments
                                            mailListener.start();
                                            mailListener.on("server:connected", function(){console.log("------- imapConnected");});
                                            mailListener.on("server:disconnected", function(){console.log("------- imapDisconnected");});
                                            mailListener.on("error", function(err){console.log("MailError "+err);});
                                            mailListener.on("mail", function(mail, seqno, attributes){
                                                log("Mail from: "+mail.from[0].address);
                                                log("Name: "+mail.from[0].name);
                                                log("Subject: "+mail.subject);
                                                log("Text: "+mail.text);
                                        //     setState(EmailEingang,mail.from[0].address);  	//setze Datenpunkt mit Email-Absender (als Trigger nutzbar)
                                        //     setState(EmailText,mail.text);			//setze Datenpunkt mit kompletten Email-Inhalt
                                            // mailListener.on("attachment", function(attachment){console.log(attachment.path);}); //wenn Anhänge verarbeitet werden sollen einkommentieren
                                        mail.from[0].address,mail.from[0].name,mail.subject funktioniert. nur mail.text nicht
                                        • GarganoG Gargano
                                              type: 'string',
                                              min: 0,
                                              def: 0,
                                              role: 'value'
                                              type: 'string',
                                              min: 0,
                                              def: 0,
                                              role: 'value'
                                                tls: true,
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @Gargano
                                          das funktioniert bei mir. mail-listener4 aber sollte auch mit mail-listener2 funktionieren:
                                              type: 'string',
                                              min: 0,
                                              def: 0,
                                              role: 'value'
                                              type: 'string',
                                              min: 0,
                                              def: 0,
                                              role: 'value'
                                              var MailListener = require("mail-listener4");
                                               username: "xxxxx.de",    // hier Email Adresse eintragen
                                                password: "xxxxxxxx",	      // hier Passwort eintragen
                                                tls: true,
                                                markSeen: false, // all fetched email willbe marked as seen and not fetched next time
                                                  maillistenerSetting
                                              mailListener.on("server:connected", function(){/*console.log("imapconconnected")*/;});
                                              mailListener.on("server:disconnected", function(){/*console.log("imapDisconnected");*/});
                                              mailListener.on("error", function(err){console.log(err);});
                                               //   log("Mail from: "+mail.from[0].address);
                                                 // log("Name: "+mail.from[0].name);
                                                 // log("Subject: "+mail.subject);
