  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.5k Aufrufe 35 Beobachtet
  • G guergen
    @Jey-Cee die (1) ist bei mir nicht drin... hatte mich schon gewundert...
    Lade JETZT noch einmal von git!
    guergen
    #242
    @Jey-Cee Jetzt war die (1)-Version da:
    Eingetragen, gelesen, eingetragen, eingelesen:
    enocean.0	2020-12-07 12:41:53.010	debug	(1207) Message for ID 008bab19 has been received.
    enocean.0	2020-12-07 12:41:53.006	debug	(1207) 55000707017af650008bab193003ffffffff4300
    enocean.0	2020-12-07 12:41:31.749	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:31.749	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:31.740	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:31.740	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:31.736	info	(1207) state 018d0a0a.CMD changed: 4 (ack = true) state: {"val":4,"ack":true,"ts":1607341291734,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341291734}
    enocean.0	2020-12-07 12:41:26.056	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:26.056	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:26.039	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:26.039	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:26.035	info	(1207) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607341286033,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341286033}
    enocean.0	2020-12-07 12:41:23.945	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:23.944	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:23.923	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:23.923	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:23.915	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341283911,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733}
    enocean.0	2020-12-07 12:41:19.786	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:19.786	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:19.770	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:19.769	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:19.738	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341279733,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733}
    enocean.0	2020-12-07 12:41:16.795	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:16.795	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:16.781	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:16.781	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:16.778	info	(1207) state 018d0a0a.CMD changed: 5 (ack = false) state: {"val":5,"ack":false,"ts":1607341276775,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341276775}
    enocean.0	2020-12-07 12:41:08.191	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:08.190	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:08.181	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:08.180	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:08.177	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341268174,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575}
    enocean.0	2020-12-07 12:41:00.594	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:00.593	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:00.583	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:00.582	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:00.578	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341260575,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575}
    enocean.0	2020-12-07 12:40:40.688	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.679	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.666	debug	(1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:40:40.665	info	(1207) Create objects for TF-13-06 from ELTAKO with id: 018d0a0a
    enocean.0	2020-12-07 12:40:40.665	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.665	info	(1207) new device
    enocean.0	2020-12-07 12:40:40.663	debug	(1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:40:40.663	info	(1207) Create objects for TF-13-07 from ELTAKO with id: 018d0a0a
    enocean.0	2020-12-07 12:40:40.662	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.661	info	(1207) new device
    enocean.0	2020-12-07 12:39:42.598	debug	(1207) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:39:42.558	debug	(1207) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:39:42.557	debug	(1207) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:39:42.556	info	(1207) ["/dev/ttyUSB0"]
    Datenpunkte sind da, allerdings auf "write false" habe sie auf "write true" geändert, der FUD reagiert aber nicht.
      TheAriba
      #243
      also ich kann leider auch die TF61J nicht bedienen.
      • T TheAriba
        Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        #244
        @EnoceanEltako ernsthaft. Ich glaub ich geb auf.
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        • G guergen
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          #245
          @guergen mach mal das Objekt vom device auf und schau in Raw.
          Das sollte exakt (bis auf die ID) so aus sehen:
          G 2 Antworten Letzte Antwort
          • Jey CeeJ Jey Cee
            guergen
            #246
            @Jey-Cee
              "type": "device",
              "common": {
                "name": "Licht Wohnzimmer"
              "native": {
                "id": "018d0a0a",
                "eep": [
                  "TF-13-06"
                "manufacturer": "ELTAKO"
              "from": "system.adapter.enocean.0",
              "user": "system.user.admin",
              "ts": 1607341240700,
              "_id": "enocean.0.018d0a0a",
              "acl": {
                "owner": "system.user.admin",
                "object": 1636
            TF-13-07 ist nicht drin
            • Jey CeeJ Jey Cee
              guergen
              #247
              @Jey-Cee Von Hand nachtragen hat nichts gebracht
              • T TheAriba
                @Jey-Cee nein, habe nur den TF61D und den FSR61.
                TF61D lässt sich nicht anlernen.
                FSR61 muss ich morgen testen, ist in der Garage bei mir.
                TF61D 584de13
                enocean.0	2020-12-06 20:38:32.353	info	(20156) state enocean.0.gateway.teachin deleted
                enocean.0	2020-12-06 20:38:32.346	info	(20156) Teachin mode de-activated
                enocean.0	2020-12-06 19:37:46.216	debug	(20156) 55000707017ad5090582de300000ffffffff4c00
                enocean.0	2020-12-06 19:37:45.896	debug	(20156) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:37:45.893	debug	(20156) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:37:45.892	debug	(20156) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:37:45.891	info	(20156) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                Der TF 100L lässt sich leider auch nicht einlernen. Restaret den Adapter sogar... EnoceanID 5936c86
                host.raspberrypi	2020-12-06 19:47:35.828	info	Restart adapter system.adapter.enocean.0 because enabled
                host.raspberrypi	2020-12-06 19:47:35.818	info	instance system.adapter.enocean.0 terminated with code 0 (NO_ERROR)
                enocean.0	2020-12-06 19:47:35.271	info	(22429) Terminated (NO_ERROR): Without reason
                enocean.0	2020-12-06 19:47:35.266	info	(22429) terminating
                enocean.0	2020-12-06 19:47:35.256	info	(22429) The serial port was closed.
                enocean.0	2020-12-06 19:47:35.247	info	(22429) cleaned everything up...
                enocean.0	2020-12-06 19:47:35.244	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                enocean.0	2020-12-06 19:47:35.244	error	at runMicrotasks (<anonymous>)
                enocean.0	2020-12-06 19:47:35.244	error	at handleTeachIn.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:452:12)
                enocean.0	2020-12-06 19:47:35.244	error	at addEltakoDevice (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:681:36)
                enocean.0	2020-12-06 19:47:35.244	error	(22429) TypeError: Cannot read property 'name' of undefined
                enocean.0	2020-12-06 19:47:35.242	error	(22429) unhandled promise rejection: Cannot read property 'name' of undefined
                Unhandled	2020-12-06 19:47:35.241	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                enocean.0	2020-12-06 19:47:35.232	debug	(22429) 55000e070140d100d0fe030301007705936c860000ffffffff4a00
                enocean.0	2020-12-06 19:47:35.056	debug	(22429) 55000d0701fdd100d0ff0000041405936c860000ffffffff4600
                enocean.0	2020-12-06 19:47:34.528	debug	(22429) 55000707017af600fef5796b2000ffffffff3a00
                enocean.0	2020-12-06 19:47:33.008	debug	(22429) 55000707017af65005936c863000ffffffff4300
                enocean.0	2020-12-06 19:47:32.704	debug	(22429) 55000707017af610fef5796b3000ffffffff3c00
                enocean.0	2020-12-06 19:47:32.496	debug	(22429) 55000707017af67005936c863000ffffffff3d00
                enocean.0	2020-12-06 19:47:32.416	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
                enocean.0	2020-12-06 19:47:32.224	debug	(22429) 55000707017af610fef5796b3000ffffffff3c00
                enocean.0	2020-12-06 19:47:32.048	debug	(22429) 55000707017af65005936c863000ffffffff4300
                enocean.0	2020-12-06 19:47:31.984	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
                enocean.0	2020-12-06 19:47:31.776	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
                enocean.0	2020-12-06 19:47:31.584	debug	(22429) 55000707017af67005936c863000ffffffff4000
                enocean.0	2020-12-06 19:47:31.520	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
                enocean.0	2020-12-06 19:47:31.377	debug	(22429) 55000707017af67005936c863000ffffffff4300
                enocean.0	2020-12-06 19:47:31.344	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
                enocean.0	2020-12-06 19:47:31.088	debug	(22429) 55000707017af600fef5796b2000ffffffff3d00
                enocean.0	2020-12-06 19:47:30.896	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
                enocean.0	2020-12-06 19:47:16.182	debug	(22429) Message for ID 0583fcec has been received.
                enocean.0	2020-12-06 19:47:16.179	debug	(22429) 55000707017ad5090583fcec0000ffffffff4f00
                enocean.0	2020-12-06 19:47:08.184	debug	(22429) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:47:08.181	debug	(22429) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:47:08.174	debug	(22429) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:47:08.173	info	(22429) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                #248
                @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.2.x:
                Hm der sendet auch kein Teachin telegram.
                @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
                Tausch die beiden mal, also 07 oben und 96 unten.
                G 1 Antwort Letzte Antwort
                • Jey CeeJ Jey Cee
                  guergen
                  #249
                  @Jey-Cee Ändert nichts... reagiert nicht auch nicht auf CMD
                  enocean.0	2020-12-07 14:33:42.140	debug	(1268) system.adapter.admin.0: logging true
                  enocean.0	2020-12-07 14:33:32.071	debug	(1268) Packet type 2 received: 02
                  enocean.0	2020-12-07 14:33:32.070	debug	(1268) 55000100026500
                  enocean.0	2020-12-07 14:33:32.047	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
                  enocean.0	2020-12-07 14:33:32.042	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348012040,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
                  enocean.0	2020-12-07 14:33:27.448	debug	(1268) Packet type 2 received: 02
                  enocean.0	2020-12-07 14:33:27.448	debug	(1268) 55000100026500
                  enocean.0	2020-12-07 14:33:27.431	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
                  enocean.0	2020-12-07 14:33:27.427	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348007424,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
                  enocean.0	2020-12-07 14:32:07.860	debug	(1268) Packet type 2 received: 02
                  enocean.0	2020-12-07 14:32:07.860	debug	(1268) 55000100026500
                  enocean.0	2020-12-07 14:32:07.841	debug	(1268) Sent data: 55000a0701eba502000008ffd07c000000018d0a0aff000b
                  enocean.0	2020-12-07 14:32:07.838	info	(1268) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607347927834,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347927834}
                  enocean.0	2020-12-07 14:32:03.063	debug	(1268) Packet type 2 received: 02
                  enocean.0	2020-12-07 14:32:03.063	debug	(1268) 55000100026500
                  enocean.0	2020-12-07 14:32:03.037	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
                  enocean.0	2020-12-07 14:32:03.031	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607347923028,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347923028}
                  enocean.0	2020-12-07 14:31:53.435	debug	(1268) Packet type 2 received: 02
                  enocean.0	2020-12-07 14:31:53.434	debug	(1268) 55000100026500
                  enocean.0	2020-12-07 14:31:53.410	debug	(1268) Sent data: 55000a0701eba502260009ffd07c000000018d0a0aff00ea
                  enocean.0	2020-12-07 14:31:53.400	info	(1268) state 018d0a0a.CMD changed: 3 (ack = false) state: {"val":3,"ack":false,"ts":1607347913396,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347913396}
                  enocean.0	2020-12-07 14:31:36.417	debug	(1268) Message for ID 018d0a0a has been received.
                  enocean.0	2020-12-07 14:31:36.416	debug	(1268) 55000a0701eba502260009018d0a0a0003ffffffff3d00
                  enocean.0	2020-12-07 14:35:00.306	debug	(1268) system.adapter.admin.0: logging true
                  enocean.0	2020-12-07 14:34:58.536	debug	(1268) Message for ID 018d0a0a has been received.
                  enocean.0	2020-12-07 14:34:58.535	debug	(1268) 55000a0701eba502000008018d0a0a0003ffffffff3d00
                  enocean.0	2020-12-07 14:34:56.921	debug	(1268) Message for ID 018d0a0a has been received.
                  enocean.0	2020-12-07 14:34:56.920	debug	(1268) 55000707017af650018d0a0a3003ffffffff3d00
                  enocean.0	2020-12-07 14:34:56.313	debug	(1268) Message for ID fefe5a51 has been received.
                  enocean.0	2020-12-07 14:34:56.311	debug	(1268) 55000707017af600fefe5a512003ffffffff3700
                  enocean.0	2020-12-07 14:34:56.057	debug	(1268) Message for ID fefe5a51 has been received.
                  enocean.0	2020-12-07 14:34:56.056	debug	(1268) 55000707017af610fefe5a512003ffffffff3d00
                  enocean.0	2020-12-07 14:34:53.802	debug	(1268) system.adapter.admin.0: logging false
                  enocean.0	2020-12-07 14:34:52.282	debug	(1268) Message for ID 018d0a0a has been received.
                  enocean.0	2020-12-07 14:34:52.281	debug	(1268) 55000a0701eba5023d0009018d0a0a0003ffffffff3d00
                  enocean.0	2020-12-07 14:34:50.427	debug	(1268) Message for ID fefe5a51 has been received.
                  enocean.0	2020-12-07 14:34:50.426	debug	(1268) 55000707017af600fefe5a512003ffffffff3800
                  enocean.0	2020-12-07 14:34:48.738	debug	(1268) Message for ID fefe5a51 has been received.
                  enocean.0	2020-12-07 14:34:48.730	debug	(1268) 55000707017af610fefe5a513003ffffffff3800
                  Der Taster ist der fefe5a51
                  • G guergen
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #250
                    Das ist logisch weil das Anlernen ja auch schon nicht funktioniert hat. Das heist du musst den Aktor nochmal in den Anlernmodus bringen und dann das Teachin telegram senden.
                    • Jey CeeJ Jey Cee
                      guergen
                      #251
                      @Jey-Cee Jetzt, wo alles eingetragen ist? Mache ich!
                      • Jey CeeJ Jey Cee
                        guergen
                        #252
                        @Jey-Cee Ja, jetzt läuft es. Nur die Bedienung scheint etwas kompliziert zu sein, erst den level eintragen und dann cmd auf 3 setzen
                        • G guergen
                          guergen
                          #253
                          @Jey-Cee die Unit "%"fehlt noch im LVL und die write habe ich auf true geändert.
                          Jetzt muss ich mir noch überlegen, wie der cmd mit den Prozent übergeben wird,,,,
                          • Jey CeeJ Jey Cee
                            mustang
                            #254
                            @Jey-Cee
                            Hab jetzt auch gerade mal folgendes gemacht:
                            Adapter 0.1.8 deinstalliert
                            Adapter 0.2.1 installiert
                            einen zurückgesetzten TF61J entsprechend Schritt 1 und 2 am Adapter eingerichtet.
                            Der TF61J lässt sich auch bei mir nicht steuern!
                            enocean.0	2020-12-07 14:56:20.676	debug	(4944) Message for ID 051b86c2 has been received.
                            enocean.0	2020-12-07 14:56:20.648	debug	(4944) 55000e070140d100d0fe0303010076051b86c20000ffffffff4900
                            enocean.0	2020-12-07 14:56:20.061	info	(4944) Create objects for F6-02-02 from ELTAKO with id: 051b86c2
                            enocean.0	2020-12-07 14:56:20.060	info	(4944) undefined
                            enocean.0	2020-12-07 14:56:20.045	debug	(4944) Message for ID 058cd41c has been received.
                            enocean.0	2020-12-07 14:56:20.034	debug	(4944) 550009070156a5fff80d058cd41c8100051b86c24400
                            enocean.0	2020-12-07 14:56:20.022	debug	(4944) Packet type 2 received: 02
                            enocean.0	2020-12-07 14:56:20.022	debug	(4944) 55000100026500
                            enocean.0	2020-12-07 14:56:19.969	info	(4944) Create objects for TF-01-01 from ELTAKO with id: 051b86c2
                            enocean.0	2020-12-07 14:56:19.969	info	(4944) undefined
                            enocean.0	2020-12-07 14:56:19.969	debug	(4944) Sent data: 550009070156a5fff80d804e614e0001051b86c2ff00da
                            enocean.0	2020-12-07 14:56:19.968	info	(4944) Eltako TF61J-230V detected
                            enocean.0	2020-12-07 14:56:19.958	debug	(4944) 55000d0701fdd100d0ff00000436051b86c20000ffffffff4700
                            Der TF61J hat im Lernmodus auch nicht bestätigt, daß ein Sender erkannt wurde.
                            enocean.0	2020-12-07 14:58:31.943	info	(4944) state 051b86c2.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607349511940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349511940}
                            enocean.0	2020-12-07 14:58:30.527	debug	(4944) Message for ID 058cd41c has been received.
                            enocean.0	2020-12-07 14:58:30.524	debug	(4944) 55000807013da50100058cd41c8100051b86c24400
                            enocean.0	2020-12-07 14:58:30.508	debug	(4944) Packet type 2 received: 02
                            enocean.0	2020-12-07 14:58:30.508	debug	(4944) 55000100026500
                            enocean.0	2020-12-07 14:58:30.482	debug	(4944) Sent data: 55000807013da50100000801000000051b86c2ff0010
                            enocean.0	2020-12-07 14:58:30.474	info	(4944) state 051b86c2.CMD changed: 2 (ack = false) state: {"val":2,"ack":false,"ts":1607349510468,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349510468}
                            enocean.0	2020-12-07 14:58:27.672	debug	(4944) Message for ID 058cd41c has been received.
                            enocean.0	2020-12-07 14:58:27.672	debug	(4944) 55000807013da50000058cd41c8100051b86c24400
                            enocean.0	2020-12-07 14:58:27.641	debug	(4944) Packet type 2 received: 02
                            enocean.0	2020-12-07 14:58:27.641	debug	(4944) 55000100026500
                            enocean.0	2020-12-07 14:58:27.618	debug	(4944) Sent data: 55000807013da50000010801000000051b86c2ff00a8
                            enocean.0	2020-12-07 14:58:27.612	info	(4944) state 051b86c2.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607349507606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349507606}
                            enocean.0	2020-12-07 14:58:22.262	debug	(4944) Message for ID 051b86c2 has been received.
                            enocean.0	2020-12-07 14:58:22.261	debug	(4944) 55000e070140d100d0fe0303000000051b86c20000ffffffff4a00
                            Die Kommandos wurden alle nicht vom TF61J erkannt.
                            • G guergen
                              guergen
                              #255
                              @Jey-Cee Den zweiten, der ja mit der "alten "Version eingetragen wurde, habe ich jetzt auch rein bekommenFUD auf LRN gestellt, Teach in (4) und schon kann er die Werte annehmen!
                              Uups, jetzt reagieren beide auf alles....
                              • G guergen
                                Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #256
                                @guergen musst ihn nochmal löschen und nue anlernen.
                                @mustang das teachin telegram wurde gesendet, kann sein das es nicht ankam. Ich hab gerade ein update gemacht da werden die Telegrame 2 mal gesendet. Kannst du das bitte testen, Version bleibt gleich.
                                G M 2 Antworten Letzte Antwort
                                • Jey CeeJ Jey Cee
                                  guergen
                                  #257
                                  @Jey-Cee Ja, jetzt geht es, zu Fuß den TF-13-07 drüber schreiben
                                  • Jey CeeJ Jey Cee
                                    mustang
                                    schrieb am zuletzt editiert von mustang
                                    #258
                                    @Jey-Cee
                                    kann jetzt nicht die USB-Schnittstelle nicht auswählen - im Log:
                                    host.kksmart	2020-12-07 15:29:30.448	info	Restart adapter system.adapter.enocean.0 because enabled
                                    host.kksmart	2020-12-07 15:29:30.448	error	instance system.adapter.enocean.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                    host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                    host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enocean/lib/definitions/EEPinclude.js:77:10)
                                    host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                    host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                    host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Object.Module._extensions..json (internal/modules/cjs/loader.js:797:27)
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at JSON.parse (<anonymous>)
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.enocean/lib/definitions/eep/TF-13/TF-13-06.json: Unexpected token ' in JSON at position 614
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: ^
                                    host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: throw err;
                                    host.kksmart	2020-12-07 15:29:30.444	error	Caught by controller[0]: internal/modules/cjs/loader.js:800
                                    • M mustang
                                      @Jey-Cee
                                      Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      #259
                                      @mustang habs gefixt, nochmal installieren.
                                      M G 2 Antworten Letzte Antwort
                                      • Jey CeeJ Jey Cee
                                        mustang
                                        #260
                                        @Jey-Cee
                                        Der Adapter macht jetzt keine Restarts mehr, nur leider lässt sich der TF61J (frisch resettet) wieder nicht steuern, obwohl laut Log zwei Telegramme gesendet wurden.
                                        • M mustang
                                          @Jey-Cee
                                          TheAriba
                                          schrieb am zuletzt editiert von TheAriba
                                          #261
                                          @mustang @Jey-Cee weitermachen. Aufgeben ist keine Option :)
                                          Wie kann ich denn irgendwie helfen?
                                          Edit: bringt es evtl. was den Adapter komplett zu löschen?
