  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.5k Aufrufe 35 Beobachtet
  • Jey CeeJ Jey Cee
    @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
    jedoch sendet der Stick scheinbar nichts
    Ob und was gesendet wird siehst du ja im log wenn auf debug gestellt ist.
    guergen
    #234
    @Jey-Cee Im Log werden Daten gesendet:
    enocean.0	2020-12-06 14:35:49.103	debug	(522) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-06 14:35:49.100	debug	(522) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-06 14:35:49.097	debug	(522) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-06 14:35:49.096	info	(522) ["/dev/ttyUSB0"]
    enocean.0	2020-12-06 14:35:46.860	debug	(522) Packet type 2 received: 02
    enocean.0	2020-12-06 14:35:46.859	debug	(522) 5500050102db00ffd07c000a
    enocean.0	2020-12-06 14:35:46.844	debug	(522) Sent data: 5500010005700838
    enocean.0	2020-12-06 14:35:46.844	debug	(522) Packet type 2 received: 02
    enocean.0	2020-12-06 14:35:46.844	debug	(522) 5500030002b3000100
    enocean.0	2020-12-06 14:35:46.829	debug	(522) Sent data: 55000100057025fb
    enocean.0	2020-12-06 14:35:46.733	debug	(522) Packet type 2 received: 02
    enocean.0	2020-12-06 14:35:46.732	debug	(522) 5500030002b3000000
    enocean.0	2020-12-06 14:35:46.718	debug	(522) Sent data: 5500010005700a36
    enocean.0	2020-12-06 14:35:46.718	debug	(522) Packet type 2 received: 02
    enocean.0	2020-12-06 14:35:46.717	debug	(522) 55002100022600020f000002060900058ba0f8454f0103474154455741594354524c0000000000
    enocean.0	2020-12-06 14:35:46.696	debug	(522) Sent data: 5500010005700309
    enocean.0	2020-12-06 14:35:46.501	info	(522) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.enocean, node: v12.20.0, js-controller: 3.1.6
    enocean.0	2020-12-06 14:35:45.170	debug	(522) statesDB connected
    enocean.0	2020-12-06 14:35:45.169	debug	(522) States connected to redis: 192.168.1.201:9000
    enocean.0	2020-12-06 14:35:45.149	debug	(522) States create System PubSub Client
    enocean.0	2020-12-06 14:35:45.146	debug	(522) States create User PubSub Client
    enocean.0	2020-12-06 14:35:45.074	debug	(522) Redis States: Use Redis connection: 192.168.1.201:9000
    enocean.0	2020-12-06 14:35:45.072	debug	(522) objectDB connected
    enocean.0	2020-12-06 14:35:45.068	debug	(522) Objects connected to redis: 192.168.1.201:9001
    enocean.0	2020-12-06 14:35:45.050	debug	(522) Objects client initialize lua scripts
    enocean.0	2020-12-06 14:35:45.050	debug	(522) Objects create User PubSub Client
    enocean.0	2020-12-06 14:35:45.049	debug	(522) Objects create System PubSub Client
    enocean.0	2020-12-06 14:35:45.040	debug	(522) Objects client ready ... initialize now
    enocean.0	2020-12-06 14:35:45.001	debug	(522) Redis Objects: Use Redis connection: 192.168.1.201:9001
    Aber der FUD sollte nach dem erfolgreichen koppeln mit dem Blinken aufhören. Das macht er nicht.
    DP werden auch keine angelegt.
    G 1 Antwort Letzte Antwort
    • G guergen
      guergen
      #235
      Jetzt habe ich Teach in mit einem FT55 gestartet, dann erscheint folgendes im Log:
      enocean.0	2020-12-06 15:19:23.714	info	(578) Teach-In: RPS (F6) Telegram detected, you have to add this device manually if it wasn't added right now. The ID is "fefe5a51"
      enocean.0	2020-12-06 15:19:23.713	info	(578) EEP F6-03-xx detected and added to devices
      enocean.0	2020-12-06 15:19:23.708	info	(578) Create objects for F6-02-02 from Enocean GmbH with id: fefe5a51
      enocean.0	2020-12-06 15:19:23.706	debug	(578) 55000707017af600fefe5a512003ffffffff3600
      enocean.0	2020-12-06 15:19:22.949	info	(578) Teach-In: RPS (F6) Telegram detected, you have to add this device manually if it wasn't added right now. The ID is "018d0a0a"
      enocean.0	2020-12-06 15:19:22.949	info	(578) EEP F6-02-xx detected and added to devices
      enocean.0	2020-12-06 15:19:22.699	info	(578) Create objects for F6-02-02 from Enocean GmbH with id: 018d0a0a
      enocean.0	2020-12-06 15:19:22.698	debug	(578) 55000707017af670018d0a0a3002ffffffff3c00
      enocean.0	2020-12-06 15:19:22.037	info	(578) Teach-In: RPS (F6) Telegram detected, you have to add this device manually if it wasn't added right now. The ID is "fefe5a51"
      enocean.0	2020-12-06 15:19:22.036	info	(578) EEP F6-02-xx detected and added to devices
      enocean.0	2020-12-06 15:19:22.030	info	(578) Create objects for F6-02-02 from Enocean GmbH with id: fefe5a51
      enocean.0	2020-12-06 15:19:22.026	debug	(578) 55000707017af610fefe5a513003ffffffff3600
      Der Stick bekommt also das Telegram vom FUD (018d0a0a) mit. Vielleicht hilft das ja
      • Jey CeeJ Jey Cee
        @Tobias-Schnurr @guergen bitte mal von Github neu installieren, die Version bleibt gleich. Für die FUD habe ich jetzt ein zweites Gerät angelegt für manuelles Teachin.
        @teddy diese Frage erübrigt sich von selbst wenn du die Anweisungen im Adapter befolgst.
        TheAriba
        #236
        @Jey-Cee ist die neue Version auf git? Müssen bereits angelernte Aktoren gelöscht und neu angelernt werden? Grüße ✌️
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          #237
          @teddy ich hab dir ne PN geschickt.
          @guergen du hast aber schon das hier ausgewählt:
          und dann gelesen was da steht?
          Sieht für mich nämlich nicht so aus.
          @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.2.x:
          Das ist noch keine Wirklich neue Version, da sind jetzt nur Änderungen drin die mir jemand anderes gegenprüfen muss ob sie Funktionieren.
          Wenn sich deine Geräte jetzt alle Steuern lassen wie sie sollen dann nicht.
          Persönlicher Support
          Spenden -> paypal.me/J3YC33
          T G 2 Antworten Letzte Antwort
          • Jey CeeJ Jey Cee
            TheAriba
            #238
            @Jey-Cee ok was muss denn alles geprüft werden?
            Kann das morgen im Laufe des Tages tun.
            Hab jetzt einfach mal drüber installiert und einen neuen Jalousieaktor angelernt, hat wieder nen anderen gesteuert. Muss diesen mal auch nochmal im Auslieferungszustand zurücksetzen. Prüfe ich morgen nochmal, kann ich jetzt nicht mehr ist das Zimmer meiner Tochter :)
            • T TheAriba
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #239
              @EnoceanEltako geht nur um Geräte anlernen, aber du hast keinen FUD61 oder?
              Den TF61D und FSR61 kannst du Testen, die sind beide drin.
              • Jey CeeJ Jey Cee
                TheAriba
                schrieb am zuletzt editiert von TheAriba
                #240
                @Jey-Cee nein, habe nur den TF61D und den FSR61.
                TF61D lässt sich nicht anlernen.
                FSR61 muss ich morgen testen, ist in der Garage bei mir.
                TF61D 584de13
                enocean.0	2020-12-06 20:38:32.353	info	(20156) state enocean.0.gateway.teachin deleted
                enocean.0	2020-12-06 20:38:32.346	info	(20156) Teachin mode de-activated
                enocean.0	2020-12-06 19:37:46.216	debug	(20156) 55000707017ad5090582de300000ffffffff4c00
                enocean.0	2020-12-06 19:37:45.896	debug	(20156) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:37:45.893	debug	(20156) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:37:45.892	debug	(20156) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:37:45.891	info	(20156) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                Der TF 100L lässt sich leider auch nicht einlernen. Restaret den Adapter sogar... EnoceanID 5936c86
                host.raspberrypi	2020-12-06 19:47:35.828	info	Restart adapter system.adapter.enocean.0 because enabled
                host.raspberrypi	2020-12-06 19:47:35.818	info	instance system.adapter.enocean.0 terminated with code 0 (NO_ERROR)
                enocean.0	2020-12-06 19:47:35.271	info	(22429) Terminated (NO_ERROR): Without reason
                enocean.0	2020-12-06 19:47:35.266	info	(22429) terminating
                enocean.0	2020-12-06 19:47:35.256	info	(22429) The serial port was closed.
                enocean.0	2020-12-06 19:47:35.247	info	(22429) cleaned everything up...
                enocean.0	2020-12-06 19:47:35.244	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                enocean.0	2020-12-06 19:47:35.244	error	at runMicrotasks (<anonymous>)
                enocean.0	2020-12-06 19:47:35.244	error	at handleTeachIn.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:452:12)
                enocean.0	2020-12-06 19:47:35.244	error	at addEltakoDevice (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:681:36)
                enocean.0	2020-12-06 19:47:35.244	error	(22429) TypeError: Cannot read property 'name' of undefined
                enocean.0	2020-12-06 19:47:35.242	error	(22429) unhandled promise rejection: Cannot read property 'name' of undefined
                Unhandled	2020-12-06 19:47:35.241	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                enocean.0	2020-12-06 19:47:35.232	debug	(22429) 55000e070140d100d0fe030301007705936c860000ffffffff4a00
                enocean.0	2020-12-06 19:47:35.056	debug	(22429) 55000d0701fdd100d0ff0000041405936c860000ffffffff4600
                enocean.0	2020-12-06 19:47:34.528	debug	(22429) 55000707017af600fef5796b2000ffffffff3a00
                enocean.0	2020-12-06 19:47:33.008	debug	(22429) 55000707017af65005936c863000ffffffff4300
                enocean.0	2020-12-06 19:47:32.704	debug	(22429) 55000707017af610fef5796b3000ffffffff3c00
                enocean.0	2020-12-06 19:47:32.496	debug	(22429) 55000707017af67005936c863000ffffffff3d00
                enocean.0	2020-12-06 19:47:32.416	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
                enocean.0	2020-12-06 19:47:32.224	debug	(22429) 55000707017af610fef5796b3000ffffffff3c00
                enocean.0	2020-12-06 19:47:32.048	debug	(22429) 55000707017af65005936c863000ffffffff4300
                enocean.0	2020-12-06 19:47:31.984	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
                enocean.0	2020-12-06 19:47:31.776	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
                enocean.0	2020-12-06 19:47:31.584	debug	(22429) 55000707017af67005936c863000ffffffff4000
                enocean.0	2020-12-06 19:47:31.520	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
                enocean.0	2020-12-06 19:47:31.377	debug	(22429) 55000707017af67005936c863000ffffffff4300
                enocean.0	2020-12-06 19:47:31.344	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
                enocean.0	2020-12-06 19:47:31.088	debug	(22429) 55000707017af600fef5796b2000ffffffff3d00
                enocean.0	2020-12-06 19:47:30.896	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
                enocean.0	2020-12-06 19:47:16.182	debug	(22429) Message for ID 0583fcec has been received.
                enocean.0	2020-12-06 19:47:16.179	debug	(22429) 55000707017ad5090583fcec0000ffffffff4f00
                enocean.0	2020-12-06 19:47:08.184	debug	(22429) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:47:08.181	debug	(22429) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:47:08.174	debug	(22429) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                enocean.0	2020-12-06 19:47:08.173	info	(22429) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                • Jey CeeJ Jey Cee
                  guergen
                  #241
                  @Jey-Cee die (1) ist bei mir nicht drin... hatte mich schon gewundert...
                  Lade JETZT noch einmal von git!
                  • G guergen
                    guergen
                    #242
                    @Jey-Cee Jetzt war die (1)-Version da:
                    Eingetragen, gelesen, eingetragen, eingelesen:
                    enocean.0	2020-12-07 12:41:53.010	debug	(1207) Message for ID 008bab19 has been received.
                    enocean.0	2020-12-07 12:41:53.006	debug	(1207) 55000707017af650008bab193003ffffffff4300
                    enocean.0	2020-12-07 12:41:31.749	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:31.749	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:31.740	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:31.740	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:31.736	info	(1207) state 018d0a0a.CMD changed: 4 (ack = true) state: {"val":4,"ack":true,"ts":1607341291734,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341291734}
                    enocean.0	2020-12-07 12:41:26.056	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:26.056	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:26.039	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:26.039	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:26.035	info	(1207) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607341286033,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341286033}
                    enocean.0	2020-12-07 12:41:23.945	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:23.944	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:23.923	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:23.923	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:23.915	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341283911,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733}
                    enocean.0	2020-12-07 12:41:19.786	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:19.786	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:19.770	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:19.769	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:19.738	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341279733,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733}
                    enocean.0	2020-12-07 12:41:16.795	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:16.795	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:16.781	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:16.781	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:16.778	info	(1207) state 018d0a0a.CMD changed: 5 (ack = false) state: {"val":5,"ack":false,"ts":1607341276775,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341276775}
                    enocean.0	2020-12-07 12:41:08.191	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:08.190	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:08.181	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:08.180	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:08.177	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341268174,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575}
                    enocean.0	2020-12-07 12:41:00.594	debug	(1207) Packet type 2 received: 02
                    enocean.0	2020-12-07 12:41:00.593	debug	(1207) 55000100026503
                    enocean.0	2020-12-07 12:41:00.583	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
                    enocean.0	2020-12-07 12:41:00.582	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
                    enocean.0	2020-12-07 12:41:00.578	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341260575,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575}
                    enocean.0	2020-12-07 12:40:40.688	info	(1207) undefined
                    enocean.0	2020-12-07 12:40:40.679	info	(1207) undefined
                    enocean.0	2020-12-07 12:40:40.666	debug	(1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
                    enocean.0	2020-12-07 12:40:40.665	info	(1207) Create objects for TF-13-06 from ELTAKO with id: 018d0a0a
                    enocean.0	2020-12-07 12:40:40.665	info	(1207) undefined
                    enocean.0	2020-12-07 12:40:40.665	info	(1207) new device
                    enocean.0	2020-12-07 12:40:40.663	debug	(1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
                    enocean.0	2020-12-07 12:40:40.663	info	(1207) Create objects for TF-13-07 from ELTAKO with id: 018d0a0a
                    enocean.0	2020-12-07 12:40:40.662	info	(1207) undefined
                    enocean.0	2020-12-07 12:40:40.661	info	(1207) new device
                    enocean.0	2020-12-07 12:39:42.598	debug	(1207) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                    enocean.0	2020-12-07 12:39:42.558	debug	(1207) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                    enocean.0	2020-12-07 12:39:42.557	debug	(1207) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                    enocean.0	2020-12-07 12:39:42.556	info	(1207) ["/dev/ttyUSB0"]
                    Datenpunkte sind da, allerdings auf "write false" habe sie auf "write true" geändert, der FUD reagiert aber nicht.
                      TheAriba
                      #243
                      also ich kann leider auch die TF61J nicht bedienen.
                      • T TheAriba
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #244
                        @EnoceanEltako ernsthaft. Ich glaub ich geb auf.
                        • G guergen
                          Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          #245
                          @guergen mach mal das Objekt vom device auf und schau in Raw.
                          Das sollte exakt (bis auf die ID) so aus sehen:
                          • Jey CeeJ Jey Cee
                            guergen
                            #246
                            @Jey-Cee
                              "type": "device",
                              "common": {
                                "name": "Licht Wohnzimmer"
                              "native": {
                                "id": "018d0a0a",
                                "eep": [
                                  "TF-13-06"
                                "manufacturer": "ELTAKO"
                              "from": "system.adapter.enocean.0",
                              "user": "system.user.admin",
                              "ts": 1607341240700,
                              "_id": "enocean.0.018d0a0a",
                              "acl": {
                                "owner": "system.user.admin",
                                "object": 1636
                            TF-13-07 ist nicht drin
                            • Jey CeeJ Jey Cee
                              guergen
                              #247
                              @Jey-Cee Von Hand nachtragen hat nichts gebracht
                              • T TheAriba
                                TF61D 584de13
                                Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #248
                                Hm der sendet auch kein Teachin telegram.
                                Tausch die beiden mal, also 07 oben und 96 unten.
                                • Jey CeeJ Jey Cee
                                  guergen
                                  #249
                                  @Jey-Cee Ändert nichts... reagiert nicht auch nicht auf CMD
                                  enocean.0	2020-12-07 14:33:42.140	debug	(1268) system.adapter.admin.0: logging true
                                  enocean.0	2020-12-07 14:33:32.071	debug	(1268) Packet type 2 received: 02
                                  enocean.0	2020-12-07 14:33:32.070	debug	(1268) 55000100026500
                                  enocean.0	2020-12-07 14:33:32.047	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
                                  enocean.0	2020-12-07 14:33:32.042	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348012040,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
                                  enocean.0	2020-12-07 14:33:27.448	debug	(1268) Packet type 2 received: 02
                                  enocean.0	2020-12-07 14:33:27.448	debug	(1268) 55000100026500
                                  enocean.0	2020-12-07 14:33:27.431	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
                                  enocean.0	2020-12-07 14:33:27.427	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348007424,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
                                  enocean.0	2020-12-07 14:32:07.860	debug	(1268) Packet type 2 received: 02
                                  enocean.0	2020-12-07 14:32:07.860	debug	(1268) 55000100026500
                                  enocean.0	2020-12-07 14:32:07.841	debug	(1268) Sent data: 55000a0701eba502000008ffd07c000000018d0a0aff000b
                                  enocean.0	2020-12-07 14:32:07.838	info	(1268) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607347927834,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347927834}
                                  enocean.0	2020-12-07 14:32:03.063	debug	(1268) Packet type 2 received: 02
                                  enocean.0	2020-12-07 14:32:03.063	debug	(1268) 55000100026500
                                  enocean.0	2020-12-07 14:32:03.037	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
                                  enocean.0	2020-12-07 14:32:03.031	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607347923028,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347923028}
                                  enocean.0	2020-12-07 14:31:53.435	debug	(1268) Packet type 2 received: 02
                                  enocean.0	2020-12-07 14:31:53.434	debug	(1268) 55000100026500
                                  enocean.0	2020-12-07 14:31:53.410	debug	(1268) Sent data: 55000a0701eba502260009ffd07c000000018d0a0aff00ea
                                  enocean.0	2020-12-07 14:31:53.400	info	(1268) state 018d0a0a.CMD changed: 3 (ack = false) state: {"val":3,"ack":false,"ts":1607347913396,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347913396}
                                  enocean.0	2020-12-07 14:31:36.417	debug	(1268) Message for ID 018d0a0a has been received.
                                  enocean.0	2020-12-07 14:31:36.416	debug	(1268) 55000a0701eba502260009018d0a0a0003ffffffff3d00
                                  enocean.0	2020-12-07 14:35:00.306	debug	(1268) system.adapter.admin.0: logging true
                                  enocean.0	2020-12-07 14:34:58.536	debug	(1268) Message for ID 018d0a0a has been received.
                                  enocean.0	2020-12-07 14:34:58.535	debug	(1268) 55000a0701eba502000008018d0a0a0003ffffffff3d00
                                  enocean.0	2020-12-07 14:34:56.921	debug	(1268) Message for ID 018d0a0a has been received.
                                  enocean.0	2020-12-07 14:34:56.920	debug	(1268) 55000707017af650018d0a0a3003ffffffff3d00
                                  enocean.0	2020-12-07 14:34:56.313	debug	(1268) Message for ID fefe5a51 has been received.
                                  enocean.0	2020-12-07 14:34:56.311	debug	(1268) 55000707017af600fefe5a512003ffffffff3700
                                  enocean.0	2020-12-07 14:34:56.057	debug	(1268) Message for ID fefe5a51 has been received.
                                  enocean.0	2020-12-07 14:34:56.056	debug	(1268) 55000707017af610fefe5a512003ffffffff3d00
                                  enocean.0	2020-12-07 14:34:53.802	debug	(1268) system.adapter.admin.0: logging false
                                  enocean.0	2020-12-07 14:34:52.282	debug	(1268) Message for ID 018d0a0a has been received.
                                  enocean.0	2020-12-07 14:34:52.281	debug	(1268) 55000a0701eba5023d0009018d0a0a0003ffffffff3d00
                                  enocean.0	2020-12-07 14:34:50.427	debug	(1268) Message for ID fefe5a51 has been received.
                                  enocean.0	2020-12-07 14:34:50.426	debug	(1268) 55000707017af600fefe5a512003ffffffff3800
                                  enocean.0	2020-12-07 14:34:48.738	debug	(1268) Message for ID fefe5a51 has been received.
                                  enocean.0	2020-12-07 14:34:48.730	debug	(1268) 55000707017af610fefe5a513003ffffffff3800
                                  Der Taster ist der fefe5a51
                                  • G guergen
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #250
                                    Das ist logisch weil das Anlernen ja auch schon nicht funktioniert hat. Das heist du musst den Aktor nochmal in den Anlernmodus bringen und dann das Teachin telegram senden.
                                    • Jey CeeJ Jey Cee
                                      guergen
                                      #251
                                      @Jey-Cee Jetzt, wo alles eingetragen ist? Mache ich!
                                      • Jey CeeJ Jey Cee
                                        guergen
                                        #252
                                        @Jey-Cee Ja, jetzt läuft es. Nur die Bedienung scheint etwas kompliziert zu sein, erst den level eintragen und dann cmd auf 3 setzen
                                        • G guergen
                                          guergen
                                          #253
                                          @Jey-Cee die Unit "%"fehlt noch im LVL und die write habe ich auf true geändert.
                                          Jetzt muss ich mir noch überlegen, wie der cmd mit den Prozent übergeben wird,,,,
