  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.4k Aufrufe 35 Beobachtet
  • Jey CeeJ Jey Cee
    @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.2.x:
    TF61D lässt sich nicht anlernen.
    Hm der sendet auch kein Teachin telegram.
    @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
    @Jey-Cee Von Hand nachtragen hat nichts gebracht
    Tausch die beiden mal, also 07 oben und 96 unten.
    guergen
    #249
    @Jey-Cee Ändert nichts... reagiert nicht auch nicht auf CMD
    enocean.0	2020-12-07 14:33:42.140	debug	(1268) system.adapter.admin.0: logging true
    enocean.0	2020-12-07 14:33:32.071	debug	(1268) Packet type 2 received: 02
    enocean.0	2020-12-07 14:33:32.070	debug	(1268) 55000100026500
    enocean.0	2020-12-07 14:33:32.047	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
    enocean.0	2020-12-07 14:33:32.042	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348012040,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
    enocean.0	2020-12-07 14:33:27.448	debug	(1268) Packet type 2 received: 02
    enocean.0	2020-12-07 14:33:27.448	debug	(1268) 55000100026500
    enocean.0	2020-12-07 14:33:27.431	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
    enocean.0	2020-12-07 14:33:27.427	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348007424,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
    enocean.0	2020-12-07 14:32:07.860	debug	(1268) Packet type 2 received: 02
    enocean.0	2020-12-07 14:32:07.860	debug	(1268) 55000100026500
    enocean.0	2020-12-07 14:32:07.841	debug	(1268) Sent data: 55000a0701eba502000008ffd07c000000018d0a0aff000b
    enocean.0	2020-12-07 14:32:07.838	info	(1268) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607347927834,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347927834}
    enocean.0	2020-12-07 14:32:03.063	debug	(1268) Packet type 2 received: 02
    enocean.0	2020-12-07 14:32:03.063	debug	(1268) 55000100026500
    enocean.0	2020-12-07 14:32:03.037	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
    enocean.0	2020-12-07 14:32:03.031	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607347923028,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347923028}
    enocean.0	2020-12-07 14:31:53.435	debug	(1268) Packet type 2 received: 02
    enocean.0	2020-12-07 14:31:53.434	debug	(1268) 55000100026500
    enocean.0	2020-12-07 14:31:53.410	debug	(1268) Sent data: 55000a0701eba502260009ffd07c000000018d0a0aff00ea
    enocean.0	2020-12-07 14:31:53.400	info	(1268) state 018d0a0a.CMD changed: 3 (ack = false) state: {"val":3,"ack":false,"ts":1607347913396,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347913396}
    enocean.0	2020-12-07 14:31:36.417	debug	(1268) Message for ID 018d0a0a has been received.
    enocean.0	2020-12-07 14:31:36.416	debug	(1268) 55000a0701eba502260009018d0a0a0003ffffffff3d00
    enocean.0	2020-12-07 14:35:00.306	debug	(1268) system.adapter.admin.0: logging true
    enocean.0	2020-12-07 14:34:58.536	debug	(1268) Message for ID 018d0a0a has been received.
    enocean.0	2020-12-07 14:34:58.535	debug	(1268) 55000a0701eba502000008018d0a0a0003ffffffff3d00
    enocean.0	2020-12-07 14:34:56.921	debug	(1268) Message for ID 018d0a0a has been received.
    enocean.0	2020-12-07 14:34:56.920	debug	(1268) 55000707017af650018d0a0a3003ffffffff3d00
    enocean.0	2020-12-07 14:34:56.313	debug	(1268) Message for ID fefe5a51 has been received.
    enocean.0	2020-12-07 14:34:56.311	debug	(1268) 55000707017af600fefe5a512003ffffffff3700
    enocean.0	2020-12-07 14:34:56.057	debug	(1268) Message for ID fefe5a51 has been received.
    enocean.0	2020-12-07 14:34:56.056	debug	(1268) 55000707017af610fefe5a512003ffffffff3d00
    enocean.0	2020-12-07 14:34:53.802	debug	(1268) system.adapter.admin.0: logging false
    enocean.0	2020-12-07 14:34:52.282	debug	(1268) Message for ID 018d0a0a has been received.
    enocean.0	2020-12-07 14:34:52.281	debug	(1268) 55000a0701eba5023d0009018d0a0a0003ffffffff3d00
    enocean.0	2020-12-07 14:34:50.427	debug	(1268) Message for ID fefe5a51 has been received.
    enocean.0	2020-12-07 14:34:50.426	debug	(1268) 55000707017af600fefe5a512003ffffffff3800
    enocean.0	2020-12-07 14:34:48.738	debug	(1268) Message for ID fefe5a51 has been received.
    enocean.0	2020-12-07 14:34:48.730	debug	(1268) 55000707017af610fefe5a513003ffffffff3800
    Der Taster ist der fefe5a51
    • G guergen
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      #250
      Das ist logisch weil das Anlernen ja auch schon nicht funktioniert hat. Das heist du musst den Aktor nochmal in den Anlernmodus bringen und dann das Teachin telegram senden.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      G 2 Antworten Letzte Antwort
      • Jey CeeJ Jey Cee
        guergen
        #251
        @Jey-Cee Jetzt, wo alles eingetragen ist? Mache ich!
        • Jey CeeJ Jey Cee
          guergen
          #252
          @Jey-Cee Ja, jetzt läuft es. Nur die Bedienung scheint etwas kompliziert zu sein, erst den level eintragen und dann cmd auf 3 setzen
          G 1 Antwort Letzte Antwort
          • G guergen
            guergen
            #253
            @Jey-Cee die Unit "%"fehlt noch im LVL und die write habe ich auf true geändert.
            Jetzt muss ich mir noch überlegen, wie der cmd mit den Prozent übergeben wird,,,,
            • Jey CeeJ Jey Cee
              @EnoceanEltako ernsthaft. Ich glaub ich geb auf.
              mustang
              #254
              @Jey-Cee
              Hab jetzt auch gerade mal folgendes gemacht:
              Adapter 0.1.8 deinstalliert
              Adapter 0.2.1 installiert
              einen zurückgesetzten TF61J entsprechend Schritt 1 und 2 am Adapter eingerichtet.
              Der TF61J lässt sich auch bei mir nicht steuern!
              enocean.0	2020-12-07 14:56:20.676	debug	(4944) Message for ID 051b86c2 has been received.
              enocean.0	2020-12-07 14:56:20.648	debug	(4944) 55000e070140d100d0fe0303010076051b86c20000ffffffff4900
              enocean.0	2020-12-07 14:56:20.061	info	(4944) Create objects for F6-02-02 from ELTAKO with id: 051b86c2
              enocean.0	2020-12-07 14:56:20.060	info	(4944) undefined
              enocean.0	2020-12-07 14:56:20.045	debug	(4944) Message for ID 058cd41c has been received.
              enocean.0	2020-12-07 14:56:20.034	debug	(4944) 550009070156a5fff80d058cd41c8100051b86c24400
              enocean.0	2020-12-07 14:56:20.022	debug	(4944) Packet type 2 received: 02
              enocean.0	2020-12-07 14:56:20.022	debug	(4944) 55000100026500
              enocean.0	2020-12-07 14:56:19.969	info	(4944) Create objects for TF-01-01 from ELTAKO with id: 051b86c2
              enocean.0	2020-12-07 14:56:19.969	info	(4944) undefined
              enocean.0	2020-12-07 14:56:19.969	debug	(4944) Sent data: 550009070156a5fff80d804e614e0001051b86c2ff00da
              enocean.0	2020-12-07 14:56:19.968	info	(4944) Eltako TF61J-230V detected
              enocean.0	2020-12-07 14:56:19.958	debug	(4944) 55000d0701fdd100d0ff00000436051b86c20000ffffffff4700
              Der TF61J hat im Lernmodus auch nicht bestätigt, daß ein Sender erkannt wurde.
              enocean.0	2020-12-07 14:58:31.943	info	(4944) state 051b86c2.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607349511940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349511940}
              enocean.0	2020-12-07 14:58:30.527	debug	(4944) Message for ID 058cd41c has been received.
              enocean.0	2020-12-07 14:58:30.524	debug	(4944) 55000807013da50100058cd41c8100051b86c24400
              enocean.0	2020-12-07 14:58:30.508	debug	(4944) Packet type 2 received: 02
              enocean.0	2020-12-07 14:58:30.508	debug	(4944) 55000100026500
              enocean.0	2020-12-07 14:58:30.482	debug	(4944) Sent data: 55000807013da50100000801000000051b86c2ff0010
              enocean.0	2020-12-07 14:58:30.474	info	(4944) state 051b86c2.CMD changed: 2 (ack = false) state: {"val":2,"ack":false,"ts":1607349510468,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349510468}
              enocean.0	2020-12-07 14:58:27.672	debug	(4944) Message for ID 058cd41c has been received.
              enocean.0	2020-12-07 14:58:27.672	debug	(4944) 55000807013da50000058cd41c8100051b86c24400
              enocean.0	2020-12-07 14:58:27.641	debug	(4944) Packet type 2 received: 02
              enocean.0	2020-12-07 14:58:27.641	debug	(4944) 55000100026500
              enocean.0	2020-12-07 14:58:27.618	debug	(4944) Sent data: 55000807013da50000010801000000051b86c2ff00a8
              enocean.0	2020-12-07 14:58:27.612	info	(4944) state 051b86c2.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607349507606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349507606}
              enocean.0	2020-12-07 14:58:22.262	debug	(4944) Message for ID 051b86c2 has been received.
              enocean.0	2020-12-07 14:58:22.261	debug	(4944) 55000e070140d100d0fe0303000000051b86c20000ffffffff4a00
              Die Kommandos wurden alle nicht vom TF61J erkannt.
              • G guergen
                guergen
                #255
                @Jey-Cee Den zweiten, der ja mit der "alten "Version eingetragen wurde, habe ich jetzt auch rein bekommenFUD auf LRN gestellt, Teach in (4) und schon kann er die Werte annehmen!
                Uups, jetzt reagieren beide auf alles....
                • G guergen
                  Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  #256
                  @guergen musst ihn nochmal löschen und nue anlernen.
                  @mustang das teachin telegram wurde gesendet, kann sein das es nicht ankam. Ich hab gerade ein update gemacht da werden die Telegrame 2 mal gesendet. Kannst du das bitte testen, Version bleibt gleich.
                  G M 2 Antworten Letzte Antwort
                  • Jey CeeJ Jey Cee
                    guergen
                    #257
                    @Jey-Cee Ja, jetzt geht es, zu Fuß den TF-13-07 drüber schreiben
                    • Jey CeeJ Jey Cee
                      mustang
                      schrieb am zuletzt editiert von mustang
                      #258
                      @Jey-Cee
                      kann jetzt nicht die USB-Schnittstelle nicht auswählen - im Log:
                      host.kksmart	2020-12-07 15:29:30.448	info	Restart adapter system.adapter.enocean.0 because enabled
                      host.kksmart	2020-12-07 15:29:30.448	error	instance system.adapter.enocean.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enocean/lib/definitions/EEPinclude.js:77:10)
                      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Object.Module._extensions..json (internal/modules/cjs/loader.js:797:27)
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at JSON.parse (<anonymous>)
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.enocean/lib/definitions/eep/TF-13/TF-13-06.json: Unexpected token ' in JSON at position 614
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: ^
                      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: throw err;
                      host.kksmart	2020-12-07 15:29:30.444	error	Caught by controller[0]: internal/modules/cjs/loader.js:800
                      • M mustang
                        @Jey-Cee
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #259
                        @mustang habs gefixt, nochmal installieren.
                        M G 2 Antworten Letzte Antwort
                        • Jey CeeJ Jey Cee
                          mustang
                          #260
                          @Jey-Cee
                          Der Adapter macht jetzt keine Restarts mehr, nur leider lässt sich der TF61J (frisch resettet) wieder nicht steuern, obwohl laut Log zwei Telegramme gesendet wurden.
                          • M mustang
                            @Jey-Cee
                            TheAriba
                            schrieb am zuletzt editiert von TheAriba
                            #261
                            @mustang @Jey-Cee weitermachen. Aufgeben ist keine Option :)
                            Wie kann ich denn irgendwie helfen?
                            Edit: bringt es evtl. was den Adapter komplett zu löschen?
                            • Jey CeeJ Jey Cee
                              guergen
                              #262
                              @Jey-Cee So, mit Hilfe eines kleinen Scripts, kann ich den Leuchten im VIS einen Prozentsatz mitgeben und ein/aus schalten!
                              Danke!
                              • T TheAriba
                                mustang
                                #263
                                @EnoceanEltako
                                leider bringt löschen/neuinstallieren nichts - so hab ich das gemacht...
                                • G guergen
                                  Danke!
                                  TheAriba
                                  #264
                                  @guergen magst du das mal sharen? Dann könnte der nächste das vllt. direkt nutzen :)
                                  Ich selber hab kein solchen Aktor.
                                  • T TheAriba
                                    guergen
                                    #265
                                    @EnoceanEltako Kein Problem, schnell mit Blockly zusammengeclickt...:
                                    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="8#Gqm:!ZB2}.8ppS/LIZ" x="138" y="63">
                                      <field name="OID">enocean.0.018d089e.LVL</field>
                                      <statement name="STATEMENT">
                                        <block type="controls_if" id="i$yRHT]H]*=Sxi;,6cD7">
                                          <value name="IF0">
                                            <block type="logic_compare" id="m#g$B%~/b,XeABP@HOMo">
                                              <field name="OP">NEQ</field>
                                              <value name="A">
                                                <block type="on_source" id="qZFy@RHw0Wb)W0Ao)5HI">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="on_source" id=".7b|8@jFz9qrJslJRs8O">
                                                  <field name="ATTR">oldState.val</field>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <statement name="DO0">
                                            <block type="control" id="b(t/x(+E0%w^fhLC/$WI">
                                              <field name="OID">enocean.0.018d089e.CMD</field>
                                              <value name="VALUE">
                                                <block type="math_number" id="^fqcrPw.;Z:C+5.`_B*]">
                                                  <field name="NUM">3</field>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                    Dann kann ich den Level-Wert übergeben und der Command 3 für Set Level wird gesendet.
                                    0 und 100 funktioniert selbstverständlich auch!
                                    • Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      #266
                                      Wie sind den bei euch die rssi Werte der Aktoren? Je höher der Wert desto schlechter der Empfang.
                                      Ich hab einen Zwischenstecker der lässt sich Steuern, im Test Setup hat das immer Funktioniert. Jetzt ist er im Einsatz für die Weihnachtsbeleuchtung, da reagiert er so gut wie gar nicht.
                                      Da der letzte rssi Wert bei 88 lag dachte ich es liegt am Empfang, also habe ich ihn direkt eingeschalten. Wodurch er ein Telegram sendet.
                                      Zu meiner Überraschung kam das auch an, aber der rssi lag bei 99.
                                      Also hab ich den USB Stick an eine andere Stelle gestellt. Der rssi lag dann bei 79 und der Zwischenstecker hat wieder Zuverlässig geschalten.
                                      Meine Schlussfolgerung, die Sendeleistung ist geringer als die Empangsempfindlichkeit. Demnach sollte der rssi Wert immer unter gut unter 80 liegen um eine Zuverlässige Übertragung zu Gewährleisten.
                                      • Jey CeeJ Jey Cee
                                        guergen
                                        #267
                                        @Jey-Cee der Beste Wert ist -55dB der Schlechteste -70dB
                                        • Jey CeeJ Jey Cee
                                          mustang
                                          #268
                                          @Jey-Cee
                                          Bei meinem TF61J liegt der zwischen -82 und -92 - und der funktioniert damit seit Anfang Oktober einwandfrei.
                                          Den Test für eine neue Version mache ich mit einem TF61J auf dem Tisch neben der Antenne. Da kann es normal nicht zu Verlusten von Telegrammen kommen.
