  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.5k Aufrufe 35 Beobachtet
  • G guergen
    @Jey-Cee Jetzt war die (1)-Version da:
    Eingetragen, gelesen, eingetragen, eingelesen:
    enocean.0	2020-12-07 12:41:53.010	debug	(1207) Message for ID 008bab19 has been received.
    enocean.0	2020-12-07 12:41:53.006	debug	(1207) 55000707017af650008bab193003ffffffff4300
    enocean.0	2020-12-07 12:41:31.749	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:31.749	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:31.740	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:31.740	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:31.736	info	(1207) state 018d0a0a.CMD changed: 4 (ack = true) state: {"val":4,"ack":true,"ts":1607341291734,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341291734}
    enocean.0	2020-12-07 12:41:26.056	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:26.056	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:26.039	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:26.039	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:26.035	info	(1207) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607341286033,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341286033}
    enocean.0	2020-12-07 12:41:23.945	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:23.944	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:23.923	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:23.923	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:23.915	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341283911,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733}
    enocean.0	2020-12-07 12:41:19.786	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:19.786	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:19.770	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:19.769	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:19.738	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341279733,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733}
    enocean.0	2020-12-07 12:41:16.795	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:16.795	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:16.781	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:16.781	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:16.778	info	(1207) state 018d0a0a.CMD changed: 5 (ack = false) state: {"val":5,"ack":false,"ts":1607341276775,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341276775}
    enocean.0	2020-12-07 12:41:08.191	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:08.190	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:08.181	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:08.180	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:08.177	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341268174,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575}
    enocean.0	2020-12-07 12:41:00.594	debug	(1207) Packet type 2 received: 02
    enocean.0	2020-12-07 12:41:00.593	debug	(1207) 55000100026503
    enocean.0	2020-12-07 12:41:00.583	debug	(1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092
    enocean.0	2020-12-07 12:41:00.582	warn	(1207) The data length for a 4BS telegram is incorrect. The length is 0
    enocean.0	2020-12-07 12:41:00.578	info	(1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341260575,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575}
    enocean.0	2020-12-07 12:40:40.688	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.679	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.666	debug	(1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:40:40.665	info	(1207) Create objects for TF-13-06 from ELTAKO with id: 018d0a0a
    enocean.0	2020-12-07 12:40:40.665	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.665	info	(1207) new device
    enocean.0	2020-12-07 12:40:40.663	debug	(1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:40:40.663	info	(1207) Create objects for TF-13-07 from ELTAKO with id: 018d0a0a
    enocean.0	2020-12-07 12:40:40.662	info	(1207) undefined
    enocean.0	2020-12-07 12:40:40.661	info	(1207) new device
    enocean.0	2020-12-07 12:39:42.598	debug	(1207) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:39:42.558	debug	(1207) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:39:42.557	debug	(1207) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-07 12:39:42.556	info	(1207) ["/dev/ttyUSB0"]
    Datenpunkte sind da, allerdings auf "write false" habe sie auf "write true" geändert, der FUD reagiert aber nicht.
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #245
    @guergen mach mal das Objekt vom device auf und schau in Raw.
    Das sollte exakt (bis auf die ID) so aus sehen:
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    G 2 Antworten Letzte Antwort
    • Jey CeeJ Jey Cee
      guergen
      #246
      @Jey-Cee
        "type": "device",
        "common": {
          "name": "Licht Wohnzimmer"
        "native": {
          "id": "018d0a0a",
          "eep": [
            "TF-13-06"
          "manufacturer": "ELTAKO"
        "from": "system.adapter.enocean.0",
        "user": "system.user.admin",
        "ts": 1607341240700,
        "_id": "enocean.0.018d0a0a",
        "acl": {
          "owner": "system.user.admin",
          "object": 1636
      TF-13-07 ist nicht drin
      • Jey CeeJ Jey Cee
        guergen
        #247
        @Jey-Cee Von Hand nachtragen hat nichts gebracht
        • T TheAriba
          @Jey-Cee nein, habe nur den TF61D und den FSR61.
          TF61D lässt sich nicht anlernen.
          FSR61 muss ich morgen testen, ist in der Garage bei mir.
          TF61D 584de13
          enocean.0	2020-12-06 20:38:32.353	info	(20156) state enocean.0.gateway.teachin deleted
          enocean.0	2020-12-06 20:38:32.346	info	(20156) Teachin mode de-activated
          enocean.0	2020-12-06 19:37:46.216	debug	(20156) 55000707017ad5090582de300000ffffffff4c00
          enocean.0	2020-12-06 19:37:45.896	debug	(20156) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-06 19:37:45.893	debug	(20156) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-06 19:37:45.892	debug	(20156) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-06 19:37:45.891	info	(20156) ["/dev/ttyAMA0","/dev/ttyUSB0"]
          Der TF 100L lässt sich leider auch nicht einlernen. Restaret den Adapter sogar... EnoceanID 5936c86
          host.raspberrypi	2020-12-06 19:47:35.828	info	Restart adapter system.adapter.enocean.0 because enabled
          host.raspberrypi	2020-12-06 19:47:35.818	info	instance system.adapter.enocean.0 terminated with code 0 (NO_ERROR)
          enocean.0	2020-12-06 19:47:35.271	info	(22429) Terminated (NO_ERROR): Without reason
          enocean.0	2020-12-06 19:47:35.266	info	(22429) terminating
          enocean.0	2020-12-06 19:47:35.256	info	(22429) The serial port was closed.
          enocean.0	2020-12-06 19:47:35.247	info	(22429) cleaned everything up...
          enocean.0	2020-12-06 19:47:35.244	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
          enocean.0	2020-12-06 19:47:35.244	error	at runMicrotasks (<anonymous>)
          enocean.0	2020-12-06 19:47:35.244	error	at handleTeachIn.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:452:12)
          enocean.0	2020-12-06 19:47:35.244	error	at addEltakoDevice (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:681:36)
          enocean.0	2020-12-06 19:47:35.244	error	(22429) TypeError: Cannot read property 'name' of undefined
          enocean.0	2020-12-06 19:47:35.242	error	(22429) unhandled promise rejection: Cannot read property 'name' of undefined
          Unhandled	2020-12-06 19:47:35.241	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          enocean.0	2020-12-06 19:47:35.232	debug	(22429) 55000e070140d100d0fe030301007705936c860000ffffffff4a00
          enocean.0	2020-12-06 19:47:35.056	debug	(22429) 55000d0701fdd100d0ff0000041405936c860000ffffffff4600
          enocean.0	2020-12-06 19:47:34.528	debug	(22429) 55000707017af600fef5796b2000ffffffff3a00
          enocean.0	2020-12-06 19:47:33.008	debug	(22429) 55000707017af65005936c863000ffffffff4300
          enocean.0	2020-12-06 19:47:32.704	debug	(22429) 55000707017af610fef5796b3000ffffffff3c00
          enocean.0	2020-12-06 19:47:32.496	debug	(22429) 55000707017af67005936c863000ffffffff3d00
          enocean.0	2020-12-06 19:47:32.416	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
          enocean.0	2020-12-06 19:47:32.224	debug	(22429) 55000707017af610fef5796b3000ffffffff3c00
          enocean.0	2020-12-06 19:47:32.048	debug	(22429) 55000707017af65005936c863000ffffffff4300
          enocean.0	2020-12-06 19:47:31.984	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
          enocean.0	2020-12-06 19:47:31.776	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
          enocean.0	2020-12-06 19:47:31.584	debug	(22429) 55000707017af67005936c863000ffffffff4000
          enocean.0	2020-12-06 19:47:31.520	debug	(22429) 55000707017af600fef5796b2000ffffffff3c00
          enocean.0	2020-12-06 19:47:31.377	debug	(22429) 55000707017af67005936c863000ffffffff4300
          enocean.0	2020-12-06 19:47:31.344	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
          enocean.0	2020-12-06 19:47:31.088	debug	(22429) 55000707017af600fef5796b2000ffffffff3d00
          enocean.0	2020-12-06 19:47:30.896	debug	(22429) 55000707017af610fef5796b3000ffffffff3d00
          enocean.0	2020-12-06 19:47:16.182	debug	(22429) Message for ID 0583fcec has been received.
          enocean.0	2020-12-06 19:47:16.179	debug	(22429) 55000707017ad5090583fcec0000ffffffff4f00
          enocean.0	2020-12-06 19:47:08.184	debug	(22429) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-06 19:47:08.181	debug	(22429) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-06 19:47:08.174	debug	(22429) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-06 19:47:08.173	info	(22429) ["/dev/ttyAMA0","/dev/ttyUSB0"]
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          #248
          @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.2.x:
          Hm der sendet auch kein Teachin telegram.
          @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
          Tausch die beiden mal, also 07 oben und 96 unten.
          G 1 Antwort Letzte Antwort
          • Jey CeeJ Jey Cee
            guergen
            #249
            @Jey-Cee Ändert nichts... reagiert nicht auch nicht auf CMD
            enocean.0	2020-12-07 14:33:42.140	debug	(1268) system.adapter.admin.0: logging true
            enocean.0	2020-12-07 14:33:32.071	debug	(1268) Packet type 2 received: 02
            enocean.0	2020-12-07 14:33:32.070	debug	(1268) 55000100026500
            enocean.0	2020-12-07 14:33:32.047	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
            enocean.0	2020-12-07 14:33:32.042	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348012040,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
            enocean.0	2020-12-07 14:33:27.448	debug	(1268) Packet type 2 received: 02
            enocean.0	2020-12-07 14:33:27.448	debug	(1268) 55000100026500
            enocean.0	2020-12-07 14:33:27.431	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
            enocean.0	2020-12-07 14:33:27.427	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348007424,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424}
            enocean.0	2020-12-07 14:32:07.860	debug	(1268) Packet type 2 received: 02
            enocean.0	2020-12-07 14:32:07.860	debug	(1268) 55000100026500
            enocean.0	2020-12-07 14:32:07.841	debug	(1268) Sent data: 55000a0701eba502000008ffd07c000000018d0a0aff000b
            enocean.0	2020-12-07 14:32:07.838	info	(1268) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607347927834,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347927834}
            enocean.0	2020-12-07 14:32:03.063	debug	(1268) Packet type 2 received: 02
            enocean.0	2020-12-07 14:32:03.063	debug	(1268) 55000100026500
            enocean.0	2020-12-07 14:32:03.037	debug	(1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004
            enocean.0	2020-12-07 14:32:03.031	info	(1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607347923028,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347923028}
            enocean.0	2020-12-07 14:31:53.435	debug	(1268) Packet type 2 received: 02
            enocean.0	2020-12-07 14:31:53.434	debug	(1268) 55000100026500
            enocean.0	2020-12-07 14:31:53.410	debug	(1268) Sent data: 55000a0701eba502260009ffd07c000000018d0a0aff00ea
            enocean.0	2020-12-07 14:31:53.400	info	(1268) state 018d0a0a.CMD changed: 3 (ack = false) state: {"val":3,"ack":false,"ts":1607347913396,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347913396}
            enocean.0	2020-12-07 14:31:36.417	debug	(1268) Message for ID 018d0a0a has been received.
            enocean.0	2020-12-07 14:31:36.416	debug	(1268) 55000a0701eba502260009018d0a0a0003ffffffff3d00
            enocean.0	2020-12-07 14:35:00.306	debug	(1268) system.adapter.admin.0: logging true
            enocean.0	2020-12-07 14:34:58.536	debug	(1268) Message for ID 018d0a0a has been received.
            enocean.0	2020-12-07 14:34:58.535	debug	(1268) 55000a0701eba502000008018d0a0a0003ffffffff3d00
            enocean.0	2020-12-07 14:34:56.921	debug	(1268) Message for ID 018d0a0a has been received.
            enocean.0	2020-12-07 14:34:56.920	debug	(1268) 55000707017af650018d0a0a3003ffffffff3d00
            enocean.0	2020-12-07 14:34:56.313	debug	(1268) Message for ID fefe5a51 has been received.
            enocean.0	2020-12-07 14:34:56.311	debug	(1268) 55000707017af600fefe5a512003ffffffff3700
            enocean.0	2020-12-07 14:34:56.057	debug	(1268) Message for ID fefe5a51 has been received.
            enocean.0	2020-12-07 14:34:56.056	debug	(1268) 55000707017af610fefe5a512003ffffffff3d00
            enocean.0	2020-12-07 14:34:53.802	debug	(1268) system.adapter.admin.0: logging false
            enocean.0	2020-12-07 14:34:52.282	debug	(1268) Message for ID 018d0a0a has been received.
            enocean.0	2020-12-07 14:34:52.281	debug	(1268) 55000a0701eba5023d0009018d0a0a0003ffffffff3d00
            enocean.0	2020-12-07 14:34:50.427	debug	(1268) Message for ID fefe5a51 has been received.
            enocean.0	2020-12-07 14:34:50.426	debug	(1268) 55000707017af600fefe5a512003ffffffff3800
            enocean.0	2020-12-07 14:34:48.738	debug	(1268) Message for ID fefe5a51 has been received.
            enocean.0	2020-12-07 14:34:48.730	debug	(1268) 55000707017af610fefe5a513003ffffffff3800
            Der Taster ist der fefe5a51
            • G guergen
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #250
              Das ist logisch weil das Anlernen ja auch schon nicht funktioniert hat. Das heist du musst den Aktor nochmal in den Anlernmodus bringen und dann das Teachin telegram senden.
              • Jey CeeJ Jey Cee
                guergen
                #251
                @Jey-Cee Jetzt, wo alles eingetragen ist? Mache ich!
                • Jey CeeJ Jey Cee
                  guergen
                  #252
                  @Jey-Cee Ja, jetzt läuft es. Nur die Bedienung scheint etwas kompliziert zu sein, erst den level eintragen und dann cmd auf 3 setzen
                  • G guergen
                    guergen
                    #253
                    @Jey-Cee die Unit "%"fehlt noch im LVL und die write habe ich auf true geändert.
                    Jetzt muss ich mir noch überlegen, wie der cmd mit den Prozent übergeben wird,,,,
                    • Jey CeeJ Jey Cee
                      @EnoceanEltako ernsthaft. Ich glaub ich geb auf.
                      mustang
                      #254
                      @Jey-Cee
                      Hab jetzt auch gerade mal folgendes gemacht:
                      Adapter 0.1.8 deinstalliert
                      Adapter 0.2.1 installiert
                      einen zurückgesetzten TF61J entsprechend Schritt 1 und 2 am Adapter eingerichtet.
                      Der TF61J lässt sich auch bei mir nicht steuern!
                      enocean.0	2020-12-07 14:56:20.676	debug	(4944) Message for ID 051b86c2 has been received.
                      enocean.0	2020-12-07 14:56:20.648	debug	(4944) 55000e070140d100d0fe0303010076051b86c20000ffffffff4900
                      enocean.0	2020-12-07 14:56:20.061	info	(4944) Create objects for F6-02-02 from ELTAKO with id: 051b86c2
                      enocean.0	2020-12-07 14:56:20.060	info	(4944) undefined
                      enocean.0	2020-12-07 14:56:20.045	debug	(4944) Message for ID 058cd41c has been received.
                      enocean.0	2020-12-07 14:56:20.034	debug	(4944) 550009070156a5fff80d058cd41c8100051b86c24400
                      enocean.0	2020-12-07 14:56:20.022	debug	(4944) Packet type 2 received: 02
                      enocean.0	2020-12-07 14:56:20.022	debug	(4944) 55000100026500
                      enocean.0	2020-12-07 14:56:19.969	info	(4944) Create objects for TF-01-01 from ELTAKO with id: 051b86c2
                      enocean.0	2020-12-07 14:56:19.969	info	(4944) undefined
                      enocean.0	2020-12-07 14:56:19.969	debug	(4944) Sent data: 550009070156a5fff80d804e614e0001051b86c2ff00da
                      enocean.0	2020-12-07 14:56:19.968	info	(4944) Eltako TF61J-230V detected
                      enocean.0	2020-12-07 14:56:19.958	debug	(4944) 55000d0701fdd100d0ff00000436051b86c20000ffffffff4700
                      Der TF61J hat im Lernmodus auch nicht bestätigt, daß ein Sender erkannt wurde.
                      enocean.0	2020-12-07 14:58:31.943	info	(4944) state 051b86c2.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607349511940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349511940}
                      enocean.0	2020-12-07 14:58:30.527	debug	(4944) Message for ID 058cd41c has been received.
                      enocean.0	2020-12-07 14:58:30.524	debug	(4944) 55000807013da50100058cd41c8100051b86c24400
                      enocean.0	2020-12-07 14:58:30.508	debug	(4944) Packet type 2 received: 02
                      enocean.0	2020-12-07 14:58:30.508	debug	(4944) 55000100026500
                      enocean.0	2020-12-07 14:58:30.482	debug	(4944) Sent data: 55000807013da50100000801000000051b86c2ff0010
                      enocean.0	2020-12-07 14:58:30.474	info	(4944) state 051b86c2.CMD changed: 2 (ack = false) state: {"val":2,"ack":false,"ts":1607349510468,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349510468}
                      enocean.0	2020-12-07 14:58:27.672	debug	(4944) Message for ID 058cd41c has been received.
                      enocean.0	2020-12-07 14:58:27.672	debug	(4944) 55000807013da50000058cd41c8100051b86c24400
                      enocean.0	2020-12-07 14:58:27.641	debug	(4944) Packet type 2 received: 02
                      enocean.0	2020-12-07 14:58:27.641	debug	(4944) 55000100026500
                      enocean.0	2020-12-07 14:58:27.618	debug	(4944) Sent data: 55000807013da50000010801000000051b86c2ff00a8
                      enocean.0	2020-12-07 14:58:27.612	info	(4944) state 051b86c2.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607349507606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349507606}
                      enocean.0	2020-12-07 14:58:22.262	debug	(4944) Message for ID 051b86c2 has been received.
                      enocean.0	2020-12-07 14:58:22.261	debug	(4944) 55000e070140d100d0fe0303000000051b86c20000ffffffff4a00
                      Die Kommandos wurden alle nicht vom TF61J erkannt.
                      • G guergen
                        guergen
                        #255
                        @Jey-Cee Den zweiten, der ja mit der "alten "Version eingetragen wurde, habe ich jetzt auch rein bekommenFUD auf LRN gestellt, Teach in (4) und schon kann er die Werte annehmen!
                        Uups, jetzt reagieren beide auf alles....
                        • G guergen
                          Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          #256
                          @guergen musst ihn nochmal löschen und nue anlernen.
                          @mustang das teachin telegram wurde gesendet, kann sein das es nicht ankam. Ich hab gerade ein update gemacht da werden die Telegrame 2 mal gesendet. Kannst du das bitte testen, Version bleibt gleich.
                          G M 2 Antworten Letzte Antwort
                          • Jey CeeJ Jey Cee
                            guergen
                            #257
                            @Jey-Cee Ja, jetzt geht es, zu Fuß den TF-13-07 drüber schreiben
                            • Jey CeeJ Jey Cee
                              mustang
                              schrieb am zuletzt editiert von mustang
                              #258
                              @Jey-Cee
                              kann jetzt nicht die USB-Schnittstelle nicht auswählen - im Log:
                              host.kksmart	2020-12-07 15:29:30.448	info	Restart adapter system.adapter.enocean.0 because enabled
                              host.kksmart	2020-12-07 15:29:30.448	error	instance system.adapter.enocean.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                              host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                              host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enocean/lib/definitions/EEPinclude.js:77:10)
                              host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                              host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                              host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Object.Module._extensions..json (internal/modules/cjs/loader.js:797:27)
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at JSON.parse (<anonymous>)
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.enocean/lib/definitions/eep/TF-13/TF-13-06.json: Unexpected token ' in JSON at position 614
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: ^
                              host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: throw err;
                              host.kksmart	2020-12-07 15:29:30.444	error	Caught by controller[0]: internal/modules/cjs/loader.js:800
                              • M mustang
                                @Jey-Cee
                                Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #259
                                @mustang habs gefixt, nochmal installieren.
                                M G 2 Antworten Letzte Antwort
                                • Jey CeeJ Jey Cee
                                  mustang
                                  #260
                                  @Jey-Cee
                                  Der Adapter macht jetzt keine Restarts mehr, nur leider lässt sich der TF61J (frisch resettet) wieder nicht steuern, obwohl laut Log zwei Telegramme gesendet wurden.
                                  • M mustang
                                    @Jey-Cee
                                    TheAriba
                                    schrieb am zuletzt editiert von TheAriba
                                    #261
                                    @mustang @Jey-Cee weitermachen. Aufgeben ist keine Option :)
                                    Wie kann ich denn irgendwie helfen?
                                    Edit: bringt es evtl. was den Adapter komplett zu löschen?
                                    • Jey CeeJ Jey Cee
                                      guergen
                                      #262
                                      @Jey-Cee So, mit Hilfe eines kleinen Scripts, kann ich den Leuchten im VIS einen Prozentsatz mitgeben und ein/aus schalten!
                                      Danke!
                                      • T TheAriba
                                        mustang
                                        #263
                                        @EnoceanEltako
                                        leider bringt löschen/neuinstallieren nichts - so hab ich das gemacht...
                                        • G guergen
                                          Danke!
                                          TheAriba
                                          #264
                                          @guergen magst du das mal sharen? Dann könnte der nächste das vllt. direkt nutzen :)
                                          Ich selber hab kein solchen Aktor.
