  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.5k Aufrufe 78 Beobachtet
  • Master67M Master67
    @afuerhoff japp grade gemacht und nur mal mein Handy eingetragen... läuft nicht, aber man kann gut erkennen das es Problemen mit der FB gibt.
    host.ioBroker	2020-11-29 13:45:00.006	warn	instance system.adapter.coronavirus-statistics.0 already running with pid 30385
    fb-checkpresence.0	2020-11-29 13:44:53.726	warn	(26675) can not get active state from member GalaxyS8
    fb-checkpresence.0	2020-11-29 13:44:53.721	warn	(26675) connectionCheck: "can not connect to fritzbox!"
    fb-checkpresence.0	2020-11-29 13:44:53.721	error	(26675) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
    javascript.0	2020-11-29 13:44:13.901	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
    fb-checkpresence.0	2020-11-29 13:44:03.683	info	(26675) createMemberObjects finished successfully
    influxdb.0	2020-11-29 13:44:03.682	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
    fb-checkpresence.0	2020-11-29 13:44:03.598	info	(26675) createGlobalObjects finished successfully
    fb-checkpresence.0	2020-11-29 13:44:03.506	info	(26675) service DeviceConfig1-Reboot is supported
    fb-checkpresence.0	2020-11-29 13:44:03.500	warn	(26675) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2020-11-29 13:44:03.500	warn	(26675) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0	2020-11-29 13:44:03.499	info	(26675) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2020-11-29 13:44:03.494	info	(26675) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2020-11-29 13:44:03.489	info	(26675) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2020-11-29 13:44:03.484	info	(26675) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2020-11-29 13:44:03.478	info	(26675) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2020-11-29 13:44:03.474	info	(26675) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-11-29 13:44:03.469	info	(26675) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-11-29 13:44:03.464	info	(26675) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2020-11-29 13:44:03.459	info	(26675) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-11-29 13:44:03.410	info	(26675) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0	2020-11-29 13:44:03.400	info	(26675) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
    host.ioBroker	2020-11-29 13:44:02.660	info	instance system.adapter.fb-checkpresence.0 started with pid 26675
    #123
    @Master67 hast du "Anmeldung mit FRITZ!Box-Benutzernamen und Kennwort" eingestellt?
    Master67M 1 Antwort Letzte Antwort
      Master67M Offline
      Master67M Offline
      Master67
      #124
      @Brainbug.... Japp sogar schon zweimal ;-)
      Wie schon gesagt, die einzige Änderung ist das der "IPv4-Status: Account temporär deaktiviert" wurde!
      Ich habe den ioBroker neu gestarte, auch die FB, den Adapter neu Installiert, den Benutzer in der FB erneuert, sowie PW,
      mehr fällt mir auch nicht ein was man da noch machen kann!
      Gruß Master67
      afuerhoffA 2 Antworten Letzte Antwort
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #125
        @Master67 sagte in Test Adapter fb-checkpresence v1.1.x:
        Ich bin auch gerade am Ende. Melde mich, wenn ich neue Ideen habe.
        blink335B 1 Antwort Letzte Antwort
        • afuerhoffA afuerhoff
          blink335B Offline
          blink335B Offline
          blink335
          #126
          @afuerhoff @Master67
          Hallo in die Runde...
          ...ich nutze den adapter nicht aber hatte mir gerade diesen thread interessehalber durchgelesen und mir fiel dann folgendes dazu ein.
          Weiss nicht ob es euch weiterhilft bzw damit was zu tun hat, aber meine Fritzbox hatte gestern ein update gemacht und seitdem habe ich bzgl der Anmeldung ein merkwürdiges verhalten.
          Wenn ich mich auf der Fritzbox mit den login daten anmelden will ist beim 1. Und sporadisch auch beim 2. Versuch mein PW falsch ?!?!:man-shrugging:
          Anfangs dachte ich schon ich vertippe mich laufend...aber dies ist nicht der fall 🙄
          Nach 2 bzw 3x iger Eingabe klappt der login an dann.
          Vielleicht gehts dem Adapter ja ähnlich.
          Sollte ich völlig am Thema vorbeischreiben ignoriert es einfach :man-raising-hand:
          Mfg Adi
          afuerhoffA Master67M 2 Antworten Letzte Antwort
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #127
            @Master67
            Hallo, kannst Du einmal einen neuen Teststand von Github laden. Adapter danach einmal neu starten.
            • blink335B blink335
              Mfg Adi
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #128
              @blink335 sagte in Test Adapter fb-checkpresence v1.1.x:
              Ist ja interessant. Das ist mir auch schon aufgefallen. Ist aber nicht immer so und daher hatte ich gedacht dass es wohl an mir liegt.
              blink335B Master67M 2 Antworten Letzte Antwort
                Mfg Adi
                Master67M Offline
                Master67M Offline
                Master67
                #129
                @blink335 hmmmm...... kommt mir bekannt vor, dachte aber erst das es am meiner PW Verwaltung in Google liegt da sind noch drei weitere FBs hinterlegt!
                @afuerhoff .... werde ich gleich versuchen !
                Gruß Master67
                  blink335B Offline
                  blink335B Offline
                  blink335
                  #130
                  @afuerhoff naja ich eben anfangs auch :-)
                    Master67M Offline
                    Master67M Offline
                    Master67
                    schrieb am zuletzt editiert von Master67
                    #131
                    @afuerhoff ..... JA... so läuft es !!!!
                    Ich habe sogar die Hardcore Variante gefahren... alles angehakt und er wurde dennoch Grün...!
                    Stelle den jetzt mal auf "Normal" Einstellung zurück, mal sehen ob er dann noch Grün wird :-)
                    Edit: alle Varianten durch, der Adapter startet bei jeder Einstellung normal bis Grün durch ;)
                    Gruß Master67
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #132
                      @Master67
                      Super, dann war das ja der entscheidende Tipp von @blink335 .
                      PS: Die Testversion hast du dann nicht mehr geladen?
                        @Master67
                        Master67M Offline
                        Master67M Offline
                        Master67
                        #133
                        @afuerhoff ... doch die von Github?.... ja ich dachte da ist die Lösung drin, weil an der FB habe ich nichts verändert!
                        Gruß Master67
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #134
                          @Master67
                          Ok. Dann hatte ich das eben falsch verstanden.
                            @Grizzelbee sagte in Test Adapter fb-checkpresence v1.1.x:
                            5G oder 2,4G eingebucht ist. Ist ja in aller Regel sowohl unterschiedliche MAC als auch IP.
                            Eine Person mehrfach anzulegen wird vom Adapter nicht unterstützt. Es werden dann in der Reihenfolge der Anlage die Daten nacheinander überschrieben. Der letzte Eintrag sollte dann gewinnen. Man kann es zwar so eintragen, aber das Verhalten ist nicht das gewünschte.
                            Im Handy kann man zu jedem WLAN Netz wählen, welche MAC verwendet werden soll.
                            -> zufällig oder Telefons-MAC. Das funktioniert bei Iphone und bei Android.
                            GrizzelbeeG Offline
                            GrizzelbeeG Offline
                            Grizzelbee
                            schrieb am zuletzt editiert von Grizzelbee
                            #135
                            @grizzelbee sagte:
                            5G oder 2,4G eingebucht ist. Ist ja in aller Regel sowohl unterschiedliche MAC als auch IP.>
                            @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                            Hmmm. Ich quäle mich gerade ein wenig bei dem Gedanken das bei jedem Handy (jetzt und in Zukunft) einstellen zu müssen - zumal das z.B. bei Huawei gar nicht geht. Und wenn ich die letzen Beiträge hier so lese, haben viele das Problem.
                            Wäre es nicht sowohl für dich als Entwickler als auch für die Nutzer einfacher sich von der physikalischen Ebene eine Stufe zu entfernen und eine logische Zwischenebene einzuziehen?
                            Ich meine: Wenn die Geräte sich an der Fritzbox anmelden (egal mit welcher MAC) tun sie das (zumindest bei mir) immer mit einem Namen, der im Gerät eingestellt ist (den sehe ich in der FB als DHCP-Namen) - den setzen die meisten Menschen eh individuell - nicht zuletzt um verschiedene Telefone auch im Auto unterscheiden zu können. Dein Adapter liest diesen Namen aktuell auch schon aus der FB aus und verwendet ihn als Vorschlag für das aktuelle Familienmitglied.
                            Was wäre, wenn du diesen Namen als Basis für die Verwaltung verwenden würdest und die MAC/IP nur sekundär, falls sie gebraucht wird. Die könnte ja vermutlich bei jedem Kontakt mit der FB aktualisiert werden (falls sie sich geändert hat).
                            Also zum Beispiel:
                            anstatt:
                            PapasAndroide --> MAC: 4711-> IP: 192.xxx.xxx.xxx
                            Mamas_iPhone --> MAC: 4712-> IP: 192.xxx.xxx.xxx
                            vielleicht besser:
                            Vater-----> PapasAndroide --> MAC: 4711-> IP: 192.xxx.xxx.xxx
                            Mutter --> Mamas_iPhone --> MAC: 4712-> IP: 192.xxx.xxx.xxx
                            Müsste das nicht die ganzen MAC-Gewürfel-Probleme lösen?
                            Das hätte auch beim Handy-Wechsel den Vorteil, das ich mein neues Telefon nur genauso zu nennen bräuchte wie das alte und schon funktioniert die Präsenzerkennung.
                            viele Grüße
                            grizzelbee
                            • GrizzelbeeG Grizzelbee
                              @grizzelbee sagte:
                              Also zum Beispiel:
                              anstatt:
                              vielleicht besser:
                              viele Grüße
                              grizzelbee
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #136
                              @Grizzelbee
                              Bin ich schon dran. Allerdings müssen die Namen nicht eindeutig sein. Das kann zu Problemen führen.
                              Ist allerdings etwas Aufwand und verändert die Abfrage der Daten. Wird ne Weile dauern.
                              GrizzelbeeG 1 Antwort Letzte Antwort
                                @Grizzelbee
                                GrizzelbeeG Offline
                                GrizzelbeeG Offline
                                Grizzelbee
                                #137
                                @Grizzelbee
                                Bin ich schon dran.
                                Ich freue mich! :) 👍
                                  @McOnno
                                  So wie es jetzt eingestellt ist. Kannst du auch keine Funktion haben. Ist ja nichts zu tun für den Adapter.
                                  Du solltest die Familymember wieder aktivieren. Nur nicht use-ip verwenden. Dann sollte es funktionieren. Im Bild ist jedenfalls kein Fehler zu erkennen. Man kann erkennen welche Services unterstützt werden und welche nicht.
                                  Es sollte sogar mit den Devices funktionieren. Nur Mesh wird nicht unterstützt.
                                  McOnno
                                  #138
                                  @afuerhoff Inzwischen ist die neue Fritte da!
                                  Adapter ist auf grün und somit alles i.O.! 👍
                                  • M McOnno
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #139
                                    @McOnno sagte in Test Adapter fb-checkpresence v1.1.x:
                                    Danke für die Rückmeldung und viel Spaß mit der neuen Fritte.
                                    Stephan SchleichS 1 Antwort Letzte Antwort
                                      Stephan SchleichS Offline
                                      Stephan Schleich
                                      schrieb am zuletzt editiert von Stephan Schleich
                                      #140
                                      @afuerhoff Bezüglich des Familien Aktualisierungsintervalls scheint es bei 10 Sekunden Probleme zu geben dort wurde der Presence Wert nicht upgedated bei 20 Sekunden jedoch schon, keine Fehler im Log
                                      Edit: Ab 11 Sekunden gehts
                                      C afuerhoffA 2 Antworten Letzte Antwort
                                      • Stephan SchleichS Stephan Schleich
                                        Conquest
                                        #141
                                        @afuerhoff
                                        Hallo ich habe seit dem Update auf 1.1.0 einen Error im Log.
                                        Kannst du damit was anfangen?
                                        • C Conquest
                                          @afuerhoff
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #142
                                          @Conquest sagte in Test Adapter fb-checkpresence v1.1.x:
                                          Hallo, das ist kein wirklicher Fehler. Der Adapter kann dann von der Fritzbox die Devicelist nicht abrufen. Hab ich bei mir auch hin und wieder, da ich parallel noch das Testsystem mit einer Instanz betreibe. Hast du evtl. 2 Adapter Instanzen an Laufen? Auf welcher Fritzbox läuft Dein Adapter?
                                          Bei mir ist es eine 7490.
                                          C 1 Antwort Letzte Antwort
