  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 326.8k Aufrufe 63 Beobachtet
  • H Habedere
    @Thomas-Braun sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
    @Glasfaser
    iobroker rebuild mbus
    root@orangepizero:/opt/iobroker# iobroker rebuild mbus
    npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
    In file included from ../../nan/nan_converters.h:67:0,
                     from ../../nan/nan.h:221,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
    ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
           val->To ## TYPE(isolate->GetCurrentContext())                            \
    ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
     X(Boolean)
    In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
                     from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
                     from ../../nan/nan.h:52,
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
                     V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
    ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
       return val->NAME ## Value(isolate->GetCurrentContext());                     \
    ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
     X(bool, Boolean)
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
                     V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
    In file included from ../../nan/nan_new.h:189:0,
                     from ../../nan/nan.h:222,
    ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
    ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                               , obj));
    In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
       static MaybeLocal<Function> New(
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
    In file included from ../src/./serialport.h:6:0,
    ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
    ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
                     Local<String> ToString(Isolate* isolate) const);
    ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
    ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
                     bool Set(Local<Value> key, Local<Value> value));
    ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
    ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         New(persistentHandle)->Set(key, value);
    ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
    ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         New(persistentHandle)->Set(index, value);
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
                     bool Set(uint32_t index, Local<Value> value));
    ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
    ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Get(New(key).ToLocalChecked()));
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
       V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
    ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
    ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return scope.Escape(New(persistentHandle)->Get(key));
    ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
    ../../nan/nan.h:1884:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return scope.Escape(New(persistentHandle)->Get(index));
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3557:51: note: declared here
       V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
    In file included from /usr/include/c++/6/cassert:44:0,
                     from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node_object_wrap.h:26,
                     from ../../nan/nan.h:54,
    ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
    ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
         assert(persistent().IsNearDeath());
    In file included from ../../nan/nan.h:2698:0,
    ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
    ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
         persistent().MarkIndependent();
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:570:22: note: declared here
           V8_INLINE void MarkIndependent());
    ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
    ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
         assert(wrap->handle_.IsNearDeath());
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
       v8::String::Utf8Value path(info[0]->ToString());
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
       v8::Local<v8::Object> options = info[1]->ToObject();
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
       V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                     Local<Object> ToObject(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    ../../nan/nan.h:1655:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
       void init(v8::Handle<v8::Object> target) {
    ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
    In file included from ../../nan/nan.h:52:0,
    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
     NODE_MODULE(serialport, init);
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
    make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.13-sunxi
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.mbus/node_modules/serialport
    gyp ERR! node -v v12.18.4
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_36_22_957Z-debug.log
    Rebuild mbus done
    root@orangepizero:/opt/iobroker# root@orangepizero:/opt/iobroker# iobroker rebuild mbus
    -bash: root@orangepizero:/opt/iobroker#: No such file or directory
     X(Boolean)
    root@orangepizero:/opt/iobroker# npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
    -bash: syntax error near unexpected token `('
     X(bool, Boolean)
    root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_converters.h:67:0,
    Could not find the database of available applications, run update-command-not-found as root to fix this
    In: command not found
    root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:221,
    root@orangepizero:/opt/iobroker#                  from ../src/./serialport.h:6,
    from: can't read /var/mail/../src/./serialport.h:6,
    root@orangepizero:/opt/iobroker#                  from ../src/serialport.cpp:1:
    from: can't read /var/mail/../src/serialport.cpp:1:
    root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#        val->To ## TYPE(isolate->GetCurrentContext())                            \
                               , obj));
    ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8val-: command not found
    root@orangepizero:/opt/iobroker#                                                    ^
    ^: command not found
    root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
    -bash: ../../nan/nan_converters_43_inl.h:22:1:: No such file or directory
    root@orangepizero:/opt/iobroker#  X(Boolean)
    -bash: syntax error near unexpected token `Boolean'
    root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
    root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
    from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
    root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
    from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
    root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:52,
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59:: No such file or directory
    root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3:: No such file or directory
    root@orangepizero:/opt/iobroker#    declarator __attribute__((deprecated(message)))
    root@orangepizero:/opt/iobroker#    ^~~~~~~~~~
    ^~~~~~~~~~: command not found
    root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#    return val->NAME ## Value(isolate->GetCurrentContext());                     \
    -bash: return: val-: numeric argument required
    -bash: return: can only `return' from a function or sourced script
    root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
    -bash: ../../nan/nan_converters_43_inl.h:40:1:: No such file or directory
    root@orangepizero:/opt/iobroker#  X(bool, Boolean)
    -bash: syntax error near unexpected token `bool,'
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51:: No such file or directory
    root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
    root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_new.h:189:0,
    root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:222,
    root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
    root@orangepizero:/opt/iobroker#                            , obj));
    -bash: syntax error near unexpected token `)'
    root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
    root@orangepizero:/opt/iobroker#    static MaybeLocal<Function> New(
    ^~~: command not found
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
    -bash: v8::Context: No such file or directory
    root@orangepizero:/opt/iobroker# In file included from ../src/./serialport.h:6:0,
    root@orangepizero:/opt/iobroker# ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#        v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31:: No such file or directory
    root@orangepizero:/opt/iobroker#                  Local<String> ToString(Isolate* isolate) const);
    root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
    -bash: syntax error near unexpected token `persistentHandle'
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22:: No such file or directory
    root@orangepizero:/opt/iobroker#                  bool Set(Local<Value> key, Local<Value> value));
    root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(key, value);
    root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
    root@orangepizero:/opt/iobroker# ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(index, value);
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22:: No such file or directory
    root@orangepizero:/opt/iobroker#                  bool Set(uint32_t index, Local<Value> value));
    root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
    root@orangepizero:/opt/iobroker# ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#          New(persistentHandle)->Get(New(key).ToLocalChecked()));
    root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
    -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51:: No such file or directory
    root@orangepizero:/opt/iobroker#    V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
    -bash: syntax error near unexpected token `"Use maybe version",'
    root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
    root@orangepizero:/opt/iobroker# ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    root@orangepizero:/opt/iobroker#      return scope.Escape(New(persistentHandle)->Get(key));
    selbes spiel in grün...
    GlasfaserG Offline
    GlasfaserG Offline
    @Habedere
    siehe über dein Beitrag !
    • GlasfaserG Glasfaser
      @Habedere
      installiere ihn neu :
      Habedere
      @Glasfaser sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
      @Habedere
      alles klar - ich probiers...
      • H Habedere
        @Habedere
        @Habedere
        root@orangepizero
        Bitte nicht als root anmelden. Da läuft doch bestimmt das debian-artiges?
        H 2 Antworten Letzte Antwort
          @Habedere
          root@orangepizero
          Habedere
          @Habedere
          root@orangepizero
          Welcome to ARMBIAN 5.69 stable Debian GNU/Linux 9 (stretch) 4.19.13-sunxi
          System load: 1.46 0.55 0.20 Up time: 1 min
          Memory usage: 39 % of 493MB IP: 192.168.178.4
          CPU temp: 54°C
          Usage of /: 8% of 29G
          Hmm auf dem Orange bin ich so selten drauf - der ist nur für den Mbus da.
          PS: Der Mbus Adapter läuft wieder :) THX @all
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
          • H Habedere
            @Habedere
            root@orangepizero
            CPU temp: 54°C
            GlasfaserG Offline
            GlasfaserG Offline
            @Habedere sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
            sehr schön .... ;)
            • H Habedere
              @Habedere
              root@orangepizero
              CPU temp: 54°C
              @Habedere Auch selten meldet man sich nicht als root an. NIE ist die Devise.
              H 1 Antwort Letzte Antwort
                Habedere
                Du siehst - es fehlt an Grundlagen ;) Ich google mich von einer Anleitung zum nächsten Thread im Forum :)
                Das muss ich also mal als nächstes angehen 👍
                • C Offline
                  cop2810
                  Hallo Community , ich habe in Problem. Bin nu im raspberry Geschäft und habe nach der Anleitung oben gearbeitet bis ich folgenden Fehler bekam.
                  Was muss ich machen um das wieder glatt zu ziehen?
                  Stephan
                  • C cop2810
                    Stephan
                    @cop2810
                    Bitte keine Screenshots sondern Text auch als Text (in CodeTags) ins Forum.
                    Und bitte einen eigenen Thread eröffnen.
                    C 1 Antwort Letzte Antwort
                      @cop2810
                      cop2810
                      @Thomas-Braun Sorry, wusste nicht, dass das so geht.
                      permitted by applicable law.
                      Last login: Wed Oct 28 09:14:06 2020 from 192.168.178.70
                      pi@raspberrypi:~ $ iobroker stop
                      pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                      pi@raspberrypi:~ $ apt update
                      N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird        ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                      E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13:        Keine Berechtigung)
                      E: Das Verzeichnis /vDebian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
                      W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - Remov        eCaches (13: Keine Berechtigung)
                      W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - Re        moveCaches (13: Keine Berechtigung)
                      • C cop2810
                        @cop2810 Bitte einen neuen Thread eröffnen.
                        Und da bitte CodeTags </> verwenden.
                          @Habedere
                          root@orangepizero
                          Habedere
                          @Habedere
                          root@orangepizero
                          So jetzt ist es mal wieder soweit... der Orange ist abgestürzt und kommt nicht mehr in die Pötte :(
                          Wie kann ich mich denn mit einem non-Root Benutzer anmelden?
                          FInde da nirgends was passendes :(
                          • H Habedere
                            @Habedere
                            root@orangepizero
                            @Habedere Bitte einen eigenen Thread eröffnen. Das hat mit node nichts zu tun.
                            O 1 Antwort Letzte Antwort
                              O Online
                              O Online
                              Oli
                              @Thomas-Braun
                              super Anleitung, vielen Dank dafür, aber jetzt meine Frage, kann ich Nodejs auch auf einer Dockerinstallation updaten?
                              Mein ioBroker läuft als Docker auf einer Qnap und bis jetzt sind alles Versuche kläglich gescheitert, mit der Meldung, dass die aktuellste Version schon installiert sei.
                              Oliver
                              Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                              • O Oli
                                @Thomas-Braun
                                @Oli
                                Von Docker hab ich keine Ahnung. Die Meinungen gehen da wohl auseinander wie das da zu aktualisieren sei.
                                Bitte aber einen eigenen Thread dazu eröffnen.
                                • O Oli
                                  @Thomas-Braun
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  @Oli sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
                                  Ich (Synology Docker, Buanet) machs und funktioniert.
                                  ° Fixer ---> iob fix
                                    Murph
                                    Wollte nur mal als Hinweis geben, steht ev. schon irgendwo, hab's aber nicht gesehen.
                                    Weil ich auch gesucht hatte...
                                    Unter Debian Buster gibt es ja standartmäßig kein sudo mehr, wenn man in der Kommandozeile su eingibt kann man nach der Kennworteingabe als root arbeiten.
                                    Des weiteren gibt es ja auch den Befehl service nicht mehr, diesen kann man einfach mit systemctl ersetzen.
                                    • M Murph
                                      @Murph
                                      In einer Standard-Installation von Debian Buster ist sudo immer aktiv für den ersten Standard-User. Eben weil der root auf Eis gelegt ist.
                                      Und systemctl wird auch schon seit dem switch auf systemd vor einigen Jahren verwendet.
                                        @Murph
                                        Murph
                                        @Thomas-Braun
                                        Wollte ja nur darauf hin weisen weil ev. so Leute wie ich da nicht so leicht darauf kommen. Wenn man die Befehle mit voran gestelltem sudo ausführt, so wie in dem Howto beschrieben, funktioniert es ja nicht...
                                        • M Murph
                                          @Thomas-Braun
                                          @Murph
                                          Was soll denn das für eine Installation sein, die ohne sudo daher kommt? Eine ordentliche Standard-Installation kann es nicht sein.
                                          Wenn das nicht vorhanden sein sollte (warum auch immer) wird es dann höchste Zeit das richtig einzurichten.
                                          Zu service:
                                          pi@raspberrypi:~ $ service
                                          Usage: service < option > | --status-all | [ service_name [ command | --full-restart ] ]
                                          Also in einem Raspberry OS gibt es das natürlich.
