  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 419.2k Aufrufe 63 Beobachtet
  • GlasfaserG Glasfaser
    @Habedere sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
    Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    cd /opt/iobroker
    npm rebuild
    H
    H
    Habedere
    @Glasfaser sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
    cd /opt/iobroker
    npm rebuild
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in d        efinition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6:0,
                     from ../src/serialport.cpp:1:
    ../../nan/nan.h:1674:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
       void init(v8::Handle<v8::Object> target) {
    ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ toke        n
    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
    In file included from ../../nan/nan.h:53:0,
                     from ../src/./serialport.h:6,
    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
     NODE_MODULE(serialport, init);
    /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in defi        nition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
    serialport.target.mk:112: recipe for target 'Release/obj.target/serialport/src/s        erialport.o' failed
    make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.discovery/node_modu        les/serialport/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module        s/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces        s.js:275:12)
    gyp ERR! System Linux 4.19.13-sunxi
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialpo        rt
    gyp ERR! node -v v12.18.4
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_31_30_970Z-debug.log
    • H Habedere
      cd /opt/iobroker
      npm rebuild
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      GlasfaserG
      GlasfaserG
      @Habedere
      installiere ihn neu :
      H 1 Antwort Letzte Antwort
        @Glasfaser
        iobroker rebuild mbus
        H
        H
        Habedere
        @Thomas-Braun sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
        @Glasfaser
        root@orangepizero:/opt/iobroker# iobroker rebuild mbus
        npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
        In file included from ../../nan/nan_converters.h:67:0,
                         from ../../nan/nan.h:221,
        ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
        ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
               val->To ## TYPE(isolate->GetCurrentContext())                            \
        ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
         X(Boolean)
        In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
                         from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
                         from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
                         from ../../nan/nan.h:52,
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
                         V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
        ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
        ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
           return val->NAME ## Value(isolate->GetCurrentContext());                     \
        ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
         X(bool, Boolean)
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
                         V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
        In file included from ../../nan/nan_new.h:189:0,
                         from ../../nan/nan.h:222,
        ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
        ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                   , obj));
        In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
           static MaybeLocal<Function> New(
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
        ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
        ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
                         Local<String> ToString(Isolate* isolate) const);
        ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
        ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
                         bool Set(Local<Value> key, Local<Value> value));
        ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
        ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Set(key, value);
        ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
        ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Set(index, value);
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
                         bool Set(uint32_t index, Local<Value> value));
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
        ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 New(persistentHandle)->Get(New(key).ToLocalChecked()));
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
           V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
        ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             return scope.Escape(New(persistentHandle)->Get(key));
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
        ../../nan/nan.h:1884:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             return scope.Escape(New(persistentHandle)->Get(index));
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3557:51: note: declared here
           V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
        In file included from /usr/include/c++/6/cassert:44:0,
                         from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node_object_wrap.h:26,
                         from ../../nan/nan.h:54,
        ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
        ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
             assert(persistent().IsNearDeath());
        In file included from ../../nan/nan.h:2698:0,
        ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
        ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
             persistent().MarkIndependent();
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:570:22: note: declared here
               V8_INLINE void MarkIndependent());
        ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
        ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
             assert(wrap->handle_.IsNearDeath());
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
           v8::String::Utf8Value path(info[0]->ToString());
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
           V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
        ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
           v8::Local<v8::Object> options = info[1]->ToObject();
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
           V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                         Local<Object> ToObject(Isolate* isolate) const);
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
        ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
        ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../../nan/nan.h:1655:3: note: declared here
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
        ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
        ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
        ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
        ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
        ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
        ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
        ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
        ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
        ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
        ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
        ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
        ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
        In file included from ../../nan/nan.h:52:0,
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.mbus/node_modules/serialport
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_36_22_957Z-debug.log
        Rebuild mbus done
        root@orangepizero:/opt/iobroker# root@orangepizero:/opt/iobroker# iobroker rebuild mbus
        -bash: root@orangepizero:/opt/iobroker#: No such file or directory
         X(Boolean)
        root@orangepizero:/opt/iobroker# npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
        -bash: syntax error near unexpected token `('
         X(bool, Boolean)
        root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_converters.h:67:0,
        Could not find the database of available applications, run update-command-not-found as root to fix this
        In: command not found
        root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:221,
        root@orangepizero:/opt/iobroker#                  from ../src/./serialport.h:6,
        from: can't read /var/mail/../src/./serialport.h:6,
        root@orangepizero:/opt/iobroker#                  from ../src/serialport.cpp:1:
        from: can't read /var/mail/../src/serialport.cpp:1:
        root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#        val->To ## TYPE(isolate->GetCurrentContext())                            \
                                   , obj));
        ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8val-: command not found
        root@orangepizero:/opt/iobroker#                                                    ^
        ^: command not found
        root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
        -bash: ../../nan/nan_converters_43_inl.h:22:1:: No such file or directory
        root@orangepizero:/opt/iobroker#  X(Boolean)
        -bash: syntax error near unexpected token `Boolean'
        root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
        root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
        from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
        root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
        from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
        root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:52,
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59:: No such file or directory
        root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3:: No such file or directory
        root@orangepizero:/opt/iobroker#    declarator __attribute__((deprecated(message)))
        root@orangepizero:/opt/iobroker#    ^~~~~~~~~~
        ^~~~~~~~~~: command not found
        root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#    return val->NAME ## Value(isolate->GetCurrentContext());                     \
        -bash: return: val-: numeric argument required
        -bash: return: can only `return' from a function or sourced script
        root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
        -bash: ../../nan/nan_converters_43_inl.h:40:1:: No such file or directory
        root@orangepizero:/opt/iobroker#  X(bool, Boolean)
        -bash: syntax error near unexpected token `bool,'
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51:: No such file or directory
        root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
        root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_new.h:189:0,
        root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:222,
        root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
        root@orangepizero:/opt/iobroker#                            , obj));
        -bash: syntax error near unexpected token `)'
        root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
        root@orangepizero:/opt/iobroker#    static MaybeLocal<Function> New(
        ^~~: command not found
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
        -bash: v8::Context: No such file or directory
        root@orangepizero:/opt/iobroker# In file included from ../src/./serialport.h:6:0,
        root@orangepizero:/opt/iobroker# ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#        v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31:: No such file or directory
        root@orangepizero:/opt/iobroker#                  Local<String> ToString(Isolate* isolate) const);
        root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
        -bash: syntax error near unexpected token `persistentHandle'
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22:: No such file or directory
        root@orangepizero:/opt/iobroker#                  bool Set(Local<Value> key, Local<Value> value));
        root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(key, value);
        root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
        root@orangepizero:/opt/iobroker# ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(index, value);
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22:: No such file or directory
        root@orangepizero:/opt/iobroker#                  bool Set(uint32_t index, Local<Value> value));
        root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
        root@orangepizero:/opt/iobroker# ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#          New(persistentHandle)->Get(New(key).ToLocalChecked()));
        root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
        -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51:: No such file or directory
        root@orangepizero:/opt/iobroker#    V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
        -bash: syntax error near unexpected token `"Use maybe version",'
        root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
        root@orangepizero:/opt/iobroker# ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        root@orangepizero:/opt/iobroker#      return scope.Escape(New(persistentHandle)->Get(key));
        selbes spiel in grün...
        • H Habedere
          @Glasfaser
           X(Boolean)
           X(bool, Boolean)
                                     , obj));
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          Rebuild mbus done
           X(Boolean)
           X(bool, Boolean)
                                     , obj));
          GlasfaserG
          GlasfaserG
          @Habedere
          siehe über dein Beitrag !
            @Habedere
            H
            H
            Habedere
            @Habedere
            alles klar - ich probiers...
            • H Habedere
              @Habedere
              Thomas BraunT
              Thomas BraunT
              Most Active Developer
              @Habedere
              root@orangepizero
              Bitte nicht als root anmelden. Da läuft doch bestimmt das debian-artiges?
              H 2 Antworten Letzte Antwort
                @Habedere
                root@orangepizero
                H
                H
                Habedere
                @Habedere
                root@orangepizero
                Welcome to ARMBIAN 5.69 stable Debian GNU/Linux 9 (stretch) 4.19.13-sunxi
                System load: 1.46 0.55 0.20 Up time: 1 min
                Memory usage: 39 % of 493MB IP: 192.168.178.4
                CPU temp: 54°C
                Usage of /: 8% of 29G
                Hmm auf dem Orange bin ich so selten drauf - der ist nur für den Mbus da.
                PS: Der Mbus Adapter läuft wieder :) THX @all
                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                • H Habedere
                  @Habedere
                  root@orangepizero
                  CPU temp: 54°C
                  GlasfaserG
                  GlasfaserG
                  sehr schön .... ;)
                  • H Habedere
                    @Habedere
                    root@orangepizero
                    CPU temp: 54°C
                    Thomas BraunT
                    Thomas BraunT
                    @Habedere Auch selten meldet man sich nicht als root an. NIE ist die Devise.
                      H
                      H
                      Habedere
                      Du siehst - es fehlt an Grundlagen ;) Ich google mich von einer Anleitung zum nächsten Thread im Forum :)
                      Das muss ich also mal als nächstes angehen 👍
                      • C
                        C
                        cop2810
                        Hallo Community , ich habe in Problem. Bin nu im raspberry Geschäft und habe nach der Anleitung oben gearbeitet bis ich folgenden Fehler bekam.
                        Was muss ich machen um das wieder glatt zu ziehen?
                        Stephan
                        • C cop2810
                          Stephan
                          Thomas BraunT
                          Thomas BraunT
                          @cop2810
                          Bitte keine Screenshots sondern Text auch als Text (in CodeTags) ins Forum.
                          Und bitte einen eigenen Thread eröffnen.
                          C 1 Antwort Letzte Antwort
                            @cop2810
                            C
                            C
                            cop2810
                            @Thomas-Braun Sorry, wusste nicht, dass das so geht.
                            permitted by applicable law.
                            Last login: Wed Oct 28 09:14:06 2020 from 192.168.178.70
                            pi@raspberrypi:~ $ iobroker stop
                            pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                            pi@raspberrypi:~ $ apt update
                            N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird        ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                            E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13:        Keine Berechtigung)
                            E: Das Verzeichnis /vDebian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                            E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
                            W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - Remov        eCaches (13: Keine Berechtigung)
                            W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - Re        moveCaches (13: Keine Berechtigung)
                            • C cop2810
                              Thomas BraunT
                              Thomas BraunT
                              @cop2810 Bitte einen neuen Thread eröffnen.
                              Und da bitte CodeTags </> verwenden.
                                @Habedere
                                root@orangepizero
                                H
                                H
                                Habedere
                                @Habedere
                                root@orangepizero
                                So jetzt ist es mal wieder soweit... der Orange ist abgestürzt und kommt nicht mehr in die Pötte :(
                                Wie kann ich mich denn mit einem non-Root Benutzer anmelden?
                                FInde da nirgends was passendes :(
                                • H Habedere
                                  @Habedere
                                  root@orangepizero
                                  Thomas BraunT
                                  Thomas BraunT
                                  @Habedere Bitte einen eigenen Thread eröffnen. Das hat mit node nichts zu tun.
                                  O 1 Antwort Letzte Antwort
                                    O
                                    O
                                    Oli
                                    @Thomas-Braun
                                    super Anleitung, vielen Dank dafür, aber jetzt meine Frage, kann ich Nodejs auch auf einer Dockerinstallation updaten?
                                    Mein ioBroker läuft als Docker auf einer Qnap und bis jetzt sind alles Versuche kläglich gescheitert, mit der Meldung, dass die aktuellste Version schon installiert sei.
                                    Oliver
                                    Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                                    • O Oli
                                      @Thomas-Braun
                                      Thomas BraunT
                                      Thomas BraunT
                                      @Oli
                                      Von Docker hab ich keine Ahnung. Die Meinungen gehen da wohl auseinander wie das da zu aktualisieren sei.
                                      Bitte aber einen eigenen Thread dazu eröffnen.
                                      • O Oli
                                        @Thomas-Braun
                                        NegaleinN
                                        NegaleinN
                                        Negalein
                                        @Oli sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
                                        Ich (Synology Docker, Buanet) machs und funktioniert.
                                        ° Fixer ---> iob fix
                                        • M
                                          M
                                          Murph
                                          Wollte nur mal als Hinweis geben, steht ev. schon irgendwo, hab's aber nicht gesehen.
                                          Weil ich auch gesucht hatte...
                                          Unter Debian Buster gibt es ja standartmäßig kein sudo mehr, wenn man in der Kommandozeile su eingibt kann man nach der Kennworteingabe als root arbeiten.
                                          Des weiteren gibt es ja auch den Befehl service nicht mehr, diesen kann man einfach mit systemctl ersetzen.
                                          33.2k
                                          84.3k
