  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 326.8k Aufrufe 63 Beobachtet
  • GlasfaserG Glasfaser
    @Habedere sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
    Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    cd /opt/iobroker
    npm rebuild
    @Glasfaser
    iobroker rebuild mbus
    GlasfaserG H 2 Antworten Letzte Antwort
      @Glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      @Thomas-Braun
      ...ja ... eigentlich wird es auch selbst behoben ..
      . wollte aber sicher gehen und alles nochmal per "npm rebuild" durchführen lassen .
        cd /opt/iobroker
        npm rebuild
        Habedere
        @Glasfaser sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
        cd /opt/iobroker
        npm rebuild
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in d        efinition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           data->callback.Call(2, argv);
        In file included from ../src/./serialport.h:6:0,
                         from ../src/serialport.cpp:1:
        ../../nan/nan.h:1674:3: note: declared here
           Call(int argc, v8::Local<v8::Value> argv[]) const {
        ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
        ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           data->callback.Call(1, argv);
        ../src/serialport.cpp: At global scope:
        ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
           void init(v8::Handle<v8::Object> target) {
        ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
        ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ toke        n
        ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
        In file included from ../../nan/nan.h:53:0,
                         from ../src/./serialport.h:6,
        ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
         NODE_MODULE(serialport, init);
        /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in defi        nition of macro ‘NODE_MODULE_X’
               (node::addon_register_func) (regfunc),                          \
        ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
        serialport.target.mk:112: recipe for target 'Release/obj.target/serialport/src/s        erialport.o' failed
        make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/iobroker.discovery/node_modu        les/serialport/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module        s/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces        s.js:275:12)
        gyp ERR! System Linux 4.19.13-sunxi
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialpo        rt
        gyp ERR! node -v v12.18.4
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the serialport@6.2.2 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_31_30_970Z-debug.log
        • H Habedere
          cd /opt/iobroker
          npm rebuild
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          GlasfaserG Offline
          GlasfaserG Offline
          @Habedere
          installiere ihn neu :
          H 1 Antwort Letzte Antwort
            @Glasfaser
            Habedere
            @Thomas-Braun sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
            @Glasfaser
            root@orangepizero:/opt/iobroker# iobroker rebuild mbus
            npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
            In file included from ../../nan/nan_converters.h:67:0,
                             from ../../nan/nan.h:221,
            ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
            ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
                   val->To ## TYPE(isolate->GetCurrentContext())                            \
            ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
             X(Boolean)
            In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
                             from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
                             from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
                             from ../../nan/nan.h:52,
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
                             V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
            ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
            ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
               return val->NAME ## Value(isolate->GetCurrentContext());                     \
            ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
             X(bool, Boolean)
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
                             V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
            In file included from ../../nan/nan_new.h:189:0,
                             from ../../nan/nan.h:222,
            ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
            ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                       , obj));
            In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
               static MaybeLocal<Function> New(
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
            ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
            ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
                             Local<String> ToString(Isolate* isolate) const);
            ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
            ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
                             bool Set(Local<Value> key, Local<Value> value));
            ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
            ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 New(persistentHandle)->Set(key, value);
            ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
            ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 New(persistentHandle)->Set(index, value);
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
                             bool Set(uint32_t index, Local<Value> value));
            ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
            ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     New(persistentHandle)->Get(New(key).ToLocalChecked()));
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
               V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
            ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
            ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 return scope.Escape(New(persistentHandle)->Get(key));
            ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
            ../../nan/nan.h:1884:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 return scope.Escape(New(persistentHandle)->Get(index));
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3557:51: note: declared here
               V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
            In file included from /usr/include/c++/6/cassert:44:0,
                             from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node_object_wrap.h:26,
                             from ../../nan/nan.h:54,
            ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
            ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
                 assert(persistent().IsNearDeath());
            In file included from ../../nan/nan.h:2698:0,
            ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
            ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
                 persistent().MarkIndependent();
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:570:22: note: declared here
                   V8_INLINE void MarkIndependent());
            ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
            ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
                 assert(wrap->handle_.IsNearDeath());
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
               v8::String::Utf8Value path(info[0]->ToString());
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
               V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
            ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
               v8::Local<v8::Object> options = info[1]->ToObject();
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
               V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                             Local<Object> ToObject(Isolate* isolate) const);
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
            ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
            ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../../nan/nan.h:1655:3: note: declared here
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
            ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
            ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
            ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
            ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
            ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
            ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
            ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
            ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
            ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
            ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
            ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
            ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
            In file included from ../../nan/nan.h:52:0,
            /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.mbus/node_modules/serialport
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_36_22_957Z-debug.log
            Rebuild mbus done
            root@orangepizero:/opt/iobroker# root@orangepizero:/opt/iobroker# iobroker rebuild mbus
            -bash: root@orangepizero:/opt/iobroker#: No such file or directory
             X(Boolean)
            root@orangepizero:/opt/iobroker# npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
            -bash: syntax error near unexpected token `('
             X(bool, Boolean)
            root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_converters.h:67:0,
            Could not find the database of available applications, run update-command-not-found as root to fix this
            In: command not found
            root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:221,
            root@orangepizero:/opt/iobroker#                  from ../src/./serialport.h:6,
            from: can't read /var/mail/../src/./serialport.h:6,
            root@orangepizero:/opt/iobroker#                  from ../src/serialport.cpp:1:
            from: can't read /var/mail/../src/serialport.cpp:1:
            root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#        val->To ## TYPE(isolate->GetCurrentContext())                            \
                                       , obj));
            ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8val-: command not found
            root@orangepizero:/opt/iobroker#                                                    ^
            ^: command not found
            root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
            -bash: ../../nan/nan_converters_43_inl.h:22:1:: No such file or directory
            root@orangepizero:/opt/iobroker#  X(Boolean)
            -bash: syntax error near unexpected token `Boolean'
            root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
            root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
            from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
            root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
            from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
            root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:52,
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59:: No such file or directory
            root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3:: No such file or directory
            root@orangepizero:/opt/iobroker#    declarator __attribute__((deprecated(message)))
            root@orangepizero:/opt/iobroker#    ^~~~~~~~~~
            ^~~~~~~~~~: command not found
            root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#    return val->NAME ## Value(isolate->GetCurrentContext());                     \
            -bash: return: val-: numeric argument required
            -bash: return: can only `return' from a function or sourced script
            root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
            -bash: ../../nan/nan_converters_43_inl.h:40:1:: No such file or directory
            root@orangepizero:/opt/iobroker#  X(bool, Boolean)
            -bash: syntax error near unexpected token `bool,'
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51:: No such file or directory
            root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
            root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_new.h:189:0,
            root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:222,
            root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
            root@orangepizero:/opt/iobroker#                            , obj));
            -bash: syntax error near unexpected token `)'
            root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
            root@orangepizero:/opt/iobroker#    static MaybeLocal<Function> New(
            ^~~: command not found
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
            -bash: v8::Context: No such file or directory
            root@orangepizero:/opt/iobroker# In file included from ../src/./serialport.h:6:0,
            root@orangepizero:/opt/iobroker# ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#        v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31:: No such file or directory
            root@orangepizero:/opt/iobroker#                  Local<String> ToString(Isolate* isolate) const);
            root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
            -bash: syntax error near unexpected token `persistentHandle'
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22:: No such file or directory
            root@orangepizero:/opt/iobroker#                  bool Set(Local<Value> key, Local<Value> value));
            root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(key, value);
            root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
            root@orangepizero:/opt/iobroker# ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(index, value);
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22:: No such file or directory
            root@orangepizero:/opt/iobroker#                  bool Set(uint32_t index, Local<Value> value));
            root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
            root@orangepizero:/opt/iobroker# ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#          New(persistentHandle)->Get(New(key).ToLocalChecked()));
            root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
            -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51:: No such file or directory
            root@orangepizero:/opt/iobroker#    V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
            -bash: syntax error near unexpected token `"Use maybe version",'
            root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
            root@orangepizero:/opt/iobroker# ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
            root@orangepizero:/opt/iobroker#      return scope.Escape(New(persistentHandle)->Get(key));
            selbes spiel in grün...
            • H Habedere
              @Glasfaser
               X(Boolean)
               X(bool, Boolean)
                                         , obj));
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              Rebuild mbus done
               X(Boolean)
               X(bool, Boolean)
                                         , obj));
              GlasfaserG Offline
              GlasfaserG Offline
              @Habedere
              siehe über dein Beitrag !
                @Habedere
                Habedere
                @Habedere
                alles klar - ich probiers...
                • H Habedere
                  @Habedere
                  @Habedere
                  root@orangepizero
                  Bitte nicht als root anmelden. Da läuft doch bestimmt das debian-artiges?
                    @Habedere
                    root@orangepizero
                    Habedere
                    @Habedere
                    root@orangepizero
                    Welcome to ARMBIAN 5.69 stable Debian GNU/Linux 9 (stretch) 4.19.13-sunxi
                    System load: 1.46 0.55 0.20 Up time: 1 min
                    Memory usage: 39 % of 493MB IP: 192.168.178.4
                    CPU temp: 54°C
                    Usage of /: 8% of 29G
                    Hmm auf dem Orange bin ich so selten drauf - der ist nur für den Mbus da.
                    PS: Der Mbus Adapter läuft wieder :) THX @all
                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                    • H Habedere
                      @Habedere
                      root@orangepizero
                      CPU temp: 54°C
                      GlasfaserG Offline
                      GlasfaserG Offline
                      sehr schön .... ;)
                      • H Habedere
                        @Habedere
                        root@orangepizero
                        CPU temp: 54°C
                        @Habedere Auch selten meldet man sich nicht als root an. NIE ist die Devise.
                          Habedere
                          Du siehst - es fehlt an Grundlagen ;) Ich google mich von einer Anleitung zum nächsten Thread im Forum :)
                          Das muss ich also mal als nächstes angehen 👍
                          • C Offline
                            cop2810
                            Hallo Community , ich habe in Problem. Bin nu im raspberry Geschäft und habe nach der Anleitung oben gearbeitet bis ich folgenden Fehler bekam.
                            Was muss ich machen um das wieder glatt zu ziehen?
                            Stephan
                            • C cop2810
                              Stephan
                              @cop2810
                              Bitte keine Screenshots sondern Text auch als Text (in CodeTags) ins Forum.
                              Und bitte einen eigenen Thread eröffnen.
                              C 1 Antwort Letzte Antwort
                                @cop2810
                                cop2810
                                @Thomas-Braun Sorry, wusste nicht, dass das so geht.
                                permitted by applicable law.
                                Last login: Wed Oct 28 09:14:06 2020 from 192.168.178.70
                                pi@raspberrypi:~ $ iobroker stop
                                pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                                pi@raspberrypi:~ $ apt update
                                N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird        ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                                E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13:        Keine Berechtigung)
                                E: Das Verzeichnis /vDebian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
                                W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - Remov        eCaches (13: Keine Berechtigung)
                                W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - Re        moveCaches (13: Keine Berechtigung)
                                • C cop2810
                                  @cop2810 Bitte einen neuen Thread eröffnen.
                                  Und da bitte CodeTags </> verwenden.
                                    @Habedere
                                    root@orangepizero
                                    Habedere
                                    @Habedere
                                    root@orangepizero
                                    So jetzt ist es mal wieder soweit... der Orange ist abgestürzt und kommt nicht mehr in die Pötte :(
                                    Wie kann ich mich denn mit einem non-Root Benutzer anmelden?
                                    FInde da nirgends was passendes :(
                                    • H Habedere
                                      @Habedere
                                      root@orangepizero
                                      @Habedere Bitte einen eigenen Thread eröffnen. Das hat mit node nichts zu tun.
                                      O 1 Antwort Letzte Antwort
                                        O Online
                                        O Online
                                        Oli
                                        @Thomas-Braun
                                        super Anleitung, vielen Dank dafür, aber jetzt meine Frage, kann ich Nodejs auch auf einer Dockerinstallation updaten?
                                        Mein ioBroker läuft als Docker auf einer Qnap und bis jetzt sind alles Versuche kläglich gescheitert, mit der Meldung, dass die aktuellste Version schon installiert sei.
                                        Oliver
                                        Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                                        • O Oli
                                          @Thomas-Braun
                                          @Oli
                                          Von Docker hab ich keine Ahnung. Die Meinungen gehen da wohl auseinander wie das da zu aktualisieren sei.
                                          Bitte aber einen eigenen Thread dazu eröffnen.
