  5. Fenster und andere Geräte zählen opt. Alexa Ansagen
    apollon77A
blocklyjavascript
1.2k Beiträge 41 Kommentatoren 605.3k Aufrufe 71 Beobachtet
  • sigi234S sigi234
    @dslraser sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
    Wird an der Version liegen...(Beta). Ich habe noch nix mit await drinn...
    Bin mal auf JS 4.6.26
    javascript.0	2020-10-27 09:31:53.994	error	(19584) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at runMicrotasks (<anonymous>)
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at C:\Program Files\iobroker\Test\node_modules\standard-as-callback\built\index.js:19:49
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at tryCatcher (C:\Program Files\iobroker\Test\node_modules\standard-as-callback\built\utils.js:11:23)
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:616:17
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:1139:17
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:1555:17
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at prepareScript (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:1502:37)
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at compile (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:1279:28)
    javascript.0	2020-10-27 09:31:53.993	error	(19584) at Object.createScript (vm.js:261:10)
    javascript.0	2020-10-27 09:31:53.992	error	(19584) at new Script (vm.js:88:7)
    javascript.0	2020-10-27 09:31:53.992	error	(19584) SyntaxError: missing ) after argument list
    javascript.0	2020-10-27 09:31:53.992	error	(19584) ^^^^^
    javascript.0	2020-10-27 09:31:53.992	error	(19584) liste_Batterien_aktiv_voll_leer.push(String(await getParentName(Batterien_aktiv_voll_leer)) + ' fast leer');
    javascript.0	2020-10-27 09:31:53.992	error	at script.js.Alexa.Fenster_Liv:267
    javascript.0	2020-10-27 09:31:53.992	error	(19584) script.js.Alexa.Fenster_Liv compile failed:
    Edit:
    Habe mal die 2 Batterien auf false gesetzt, damit läuft das Skript.
    dslraserD
    dslraserD
    dslraser
    #899
    @sigi234 sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
    Kam die Fehlermeldung da auch, oder läuft es damit ?
    • dslraserD dslraser
      sigi234S
      sigi234S
      #900
      Die kam da auch
      • sigi234S sigi234
        Die kam da auch
        dslraserD
        dslraserD
        dslraser
        #901
        Die kam da auch
        Hattest Du nach dem Downgrade und upload des Adapters das Blockly mal angehalten und neu gestartet ?
        Wie gesagt, ich habe den Fehler nicht.
        Edit: weil in der Fehlermeldung immer noch was von await steht...?
          Die kam da auch
          sigi234S
          sigi234S
          #902
          Die kam da auch
          Nein, nein
          • sigi234S sigi234
            Die kam da auch
            Nein, nein
            dslraserD
            dslraserD
            dslraser
            #903
            @sigi234
            Keine Ahnung ob das schon richtig läuft ?
            (und wie gesagt, in Deiner Fehlermeldung steht immer noch was von await drinn ? )
              @sigi234
              sigi234S
              sigi234S
              #904
              @dslraser
              Läuft jetzt mit JS 4.6.26
              • dslraserD
                dslraserD
                dslraser
                #905
                @AlCalzone
                Könntest Du mal ab hier lesen ?
                Irgendwas scheint mit der aktuellen JS Engine (4.9.4) noch nicht zu passen.
                Mit 4.6.26 läuft das Blockly.
                  @AlCalzone
                  AlCalzoneA
                  AlCalzoneA
                  AlCalzone
                  #906
                  @dslraser Mit Blockly hab ich nichts am Hut. Bitte Issue bei Github aufmachen, damit Bluefox sich das ansehen kann. Wir wollen zeitnah noch eine neue Version releasen, weil TypeScript in 4.9.4 immer noch nicht sauber arbeitet. Da könnte man das noch unterbringen.
                  • AlCalzoneA AlCalzone
                    dslraserD
                    dslraserD
                    dslraser
                    #907
                    @AlCalzone sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                    erledigt
                    https://github.com/ioBroker/ioBroker.javascript/issues/691
                      erledigt
                      AlCalzoneA
                      AlCalzoneA
                      AlCalzone
                      #908
                      @dslraser Danke - könnt ihr identifizieren, was der Ausgangsblock für Zeile 267 ist? Oder das betroffene Skript/Blockly teilen?
                      Würde die Fehlersuche vermutlich etwas vereinfachen.
                        dslraserD
                        dslraserD
                        dslraser
                        #909
                        Das Blockly ist als zip Datei in einem Spoiler im ersten Beitrag zu finden.
                        Ich habe die Funktion (das ist die erste Funktion die ausgeführt werden soll, davon gibt es noch mehr in dem Blockly)
                        hier mal aus der JS Ansicht raus kopiert, ist dort im Spoiler:
                        https://forum.iobroker.net/post/510233
                        Bei @sigi234 Beiträgen gibt es einen Screenshot
                        Edit: das ist die gleiche Funktion in der 4.9.4)
                        Vergleich mit 4.6.26
                        EDIT 2:
                        Hier noch das Blockly (Achtung, das Blockly ist sehr groß und der Import dauert je nach genutzter Maschine einen Moment)
                        Komplettblockly_speak_alias-0-8.txt.zip
                          EDIT 2:
                          AlCalzoneA
                          AlCalzoneA
                          AlCalzone
                          #910
                          Könntest du mal nur mit dieser einen Funktion ein Test-Blockly erstellen und das exportieren?
                            dslraserD
                            dslraserD
                            dslraser
                            #911
                            @AlCalzone
                            Muss ich später probieren, dauert dann noch etwas. (aber, ich habe noch 4.6.26 drauf) Soll ich das damit machen ?
                              @AlCalzone
                              AlCalzoneA
                              AlCalzoneA
                              AlCalzone
                              #912
                              @dslraser Es reicht ein möglichst einfaches Blockly, das in 4.9.4 den Fehler zeigt.
                                dslraserD
                                dslraserD
                                dslraser
                                #913
                                ich habe jetzt mal alles bis auf die Variante "Batterien_voll_leer_zaehlen" raus gelöscht. Ich denke der Rest wird trotzdem benötigt, das das Blockly überhaupt läuft. Jetzt sind es noch:
                                Komplett sind es:
                                Das Blockly legt halt auch alle benötigten Datenpunkte selbst an und löscht sie bei Bedarf auch wieder, wenn die Auswahl auf false gestellt wird. Hier vielleicht mal die kleine Version (1:1 so lassen) zum probieren. Ich kann es mangels 4.9.4 nicht probieren, da ich auch keine Testmaschine habe und erst up und dann wieder downgraden müßte.
                                Bei 4.6.26 läuft es so jedenfalls noch, gerade probiert.
                                Batterien_voll_leer.txt.zip
                                  Komplett sind es:
                                  AlCalzoneA
                                  AlCalzoneA
                                  AlCalzone
                                  #914
                                  @dslraser Ok damit ist es in 4.9.4 reproduzierbar
                                  Edit: Boar, wie kann man sich das freiwillig antun?! Ich bin mehr mit Scrollen beschäftigt als sonst was.
                                  dslraserD sigi234S 2 Antworten Letzte Antwort
                                    dslraserD
                                    dslraserD
                                    dslraser
                                    #915
                                    ich schiebe das auf dem Mac mit zwei Fingern durch die Gegend (ohne Scrollbar, geht ja jetzt, ging vor ner Weile noch nicht)
                                    K AlCalzoneA 2 Antworten Letzte Antwort
                                      K
                                      K
                                      Kueppert
                                      #916
                                      @dslraser auf meinem kleinen NUC is nicht mal was mit Scrollen ^^ hab das Bockly 0.7 und 0.8 vergleichen wollen...hab nach 10 Minuten aufgegeben. Muss dafür später an meinen performanten Rechner :)
                                        AlCalzoneA
                                        AlCalzoneA
                                        AlCalzone
                                        #917
                                        @dslraser Trotzdem, mir ist der Informationsgehalt pro cm² zu wenig :D
                                        Nichtsdestotrotz, Fehler gefunden - Bei in Blockly definierten Funktionen fehlt im Gegensatz zu den JavaScript-Funktionen das async-Keyword. Jetzt nur noch rausfinden, wie man das fixen kann.
                                          sigi234S
                                          sigi234S
                                          #918
                                          Das Blockly zwingt meinen Pc fast in Knie.😀
                                          84.0k
