  4. Test Adapter SmartControl 0.3.x-0.6.x Latest
    1.0k
    6.1k
testadaptersmartcontrolbewegungsmelderiftttlichterzeitplan
1.0k Beiträge 93 Kommentatoren 411.8k Aufrufe 88 Beobachtet
  • MichMeinM Offline
    MichMeinM Offline
    MichMein
    #268
    Hi, kann das im vorigen Beitrag von mir beschriebene bitte mal einer von euch kontrollieren?
    Gruß Michael
    Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
    • SlowmanS Offline
      SlowmanS Offline
      Slowman
      #269
      Weiß nicht, wie ich diesen Fehler/Info weg bekomme.
      smartcontrol.0	2020-10-24 15:29:58.094	info	(26450) Timer 'Motion', trigger 'Licht Steinzaun BWM 1', target Licht Steinzaun: - Timeout of '30' seconds reached, target is already turned off, so not turning off again.
      smartcontrol.0	2020-10-24 15:29:28.307	info	(26450) Motion sensor Licht Steinzaun BWM 2 changed to false, but no zone name or zone target names found which were switched on before.
      smartcontrol.0	2020-10-24 15:29:28.302	info	(26450) Motion sensor Licht Steinzaun BWM 2 changed to false, but no zone name or zone target names found which were switched on before.
      smartcontrol.0	2020-10-24 15:29:28.092	info	(26450) Motion sensor 'Licht Steinzaun BWM 1', zone 'Licht Steinzaun Zone': No more motion, so we set 30s timer.
      smartcontrol.0	2020-10-24 15:29:28.090	info	(26450) Motion sensor 'Licht Steinzaun BWM 1', zone 'Licht Steinzaun Zone': No more motion, so we set 30s timer.
      smartcontrol.0	2020-10-24 15:29:13.254	info	(26450) Trigger [Licht Steinzaun BWM 1] activated but current brightness of 1178 is >= threshold of 10 -> Motion disregarded.
      smartcontrol.0	2020-10-24 15:29:13.252	info	(26450) Trigger 'Licht Steinzaun BWM 1' was already activated 0.01 seconds ago and is ignored. Must be at least 3 seconds.
      smartcontrol.0	2020-10-24 15:29:08.734	info	(26450) Subscribing to all target devices and trigger states. 0 trigger schedules activated...
      MicM 1 Antwort Letzte Antwort
      • MicM Mic
        SmartControl
        Aktuelle Test Version 0.6.x
        Veröffentlichungsdatum 0.3.x ab 12.09.2020 (seit 23.09.20 im Latest Repository)
        Github Link https://github.com/Mic-M/ioBroker.smartcontrol
        Permanenter Forum-Link ioBroker Forum: Smart Control
        Neu mit 0.3.0
        Breaking Changes
        • (Mic-M) Entire adapter code refactored. Therefore, tests are required to verify if these massive changes do not affect the adapter functionality. However, none of your existing adapter configuration should be lost and will be kept if you upgrade from 0.2.0+. But please check ALL of your configuration, since new options were added which
          can have an effect to your existing configuration.
        • (Mic-M) New feature: Implemented issue #22 - Motion sensors timeout, e.g. for Homematic sensors: Motion sensor timer will now start once a motion sensor is set to false. In previous adapter versions, it was started once set to true. Note: This change will cause that per your existing adapter configuration, the timer end will be reached later (so: once no motion detected any longer + the seconds you have set)
        • (Mic-M) New feature: Time triggers - added options for additional conditions for 'any' or 'all'. issue #24
        • (Mic-M) New feature: Zones > Execution - added options for additional conditions for 'any' or 'all'.
        • (Mic-M) Many fixes under the hood
        Was macht dieser Adapter?
        In unserer Heim-Automation haben wir ja diverse Auslöser, z.B. Bewegungsmelder im Flur löst aus, ein Wandschalter wird gedrückt, oder eine bestimmte Zeit tritt ein (z.B. 30 Minuten nach Sonnenuntergang, oder Mo-Fr um 7:00, usw.), zu der wir was schalten möchten.
        Dieser Adapter führt nun das ganze zusammen, also
        1. Auslöser lösen aus oder bestimmte Zeitpunkte (wie Mo-Fr um 7:00) treten ein
        2. Optional zusätzliche Bedingungen (jemand anwesend?, Fenster im Bad offen, Feiertag heute, usw.)
        3. Zu schaltende Zielgeräte
        Das ganze führt man dann gemäß IFTTT in Zonen zusammen.
        Ziel ist, hiermit viele JavaScripts und Blockly abzulösen und hierfür eine anwenderfreundliche Möglichkeit zu bieten.
        Auszug aus den Features
        • Auslöser: hier können Bewegungsmelder, Datenpunkte, oder Zeiten definiert werden. Es werden dabei auch Taster unterstützt.
        • Smarte Bewegungsmelder-Schaltung: mehrere Bewegungsmelder pro Raum, Berücksichtung Helligkeit, automatischer Ausschalttimer (optional aber nicht gesetzt, falls Zielgeräte bereits vor Bewegung an waren), Optional Ignorierung Helligkeit falls Ausschalt-Timer noch läuft (damit auch wiederkehrende Bewegungen erfasst werden trotz Licht an), ...
        • Pro definierter Zone können dann zur Ausführung detaillierte Zeitpläne mit Bedingungen hinterlegt werden.
        • Unterstützung von Astro-Zeiten (z.B. Sonnenuntergang) mit "Offset", also Zeitdifferenz.
        Ein paar Beispiel-Anwendungen (Use Cases):
        • Flurlicht-Steuerung mit Bewegungsmeldern, Lichtschaltern, etc. (Ablösung Bewegungsmelder-Script)
        • Kaffeemaschine täglich morgens einschalten. Mo-Fr um 6:30 Uhr, Sa/So um 8:00 Uhr, Feiertags auch um 8:00 Uhr. Aber nie einschalten, wenn keiner anwesend.
        • Bad wird am Mo-Fr zwischen 7:00-9:00 betreten (falls nicht Feiertag): Licht an und das Radio einschalten. Falls nach 5 Minuten keine Bewegung mehr: ausschalten.
        • Staubsaugerroboter-Integration
        Bisherige Threads
        Alle Erklärungen zum Adapter sind jeweils im 1. Beitrag:
        • 18.08. - 12.09.2020: Test Adapter SmartControl 0.2.x GitHub
        • 19.07. - 18.08.2020: Teste Adapter SmartControl 0.1.x-beta.x
        • 10.07. - 19.07.2020 : Aufruf: Neuen SmartControl-Adapter 0.1.0-alpha.x testen
        • 23.05. - 10.07.2020 : Planung neuer Adapter: Smart Control
        • 25.04.2020 : Umfrage: Welchen Adapter soll ich als nächstes entwickeln?
        FAQ / Use Cases (Anwendungs-Fälle/Szenarien)
        https://forum.iobroker.net/topic/36237/smart-control-adapter-faq-use-cases
        Adapter-Anleitung / Dokumentation
        Diese ist direkt und ohne Umwege in den Adapter-Optionen integriert, ihr werdet es sehen ;-)
        Screenshots der Adapter-Optionen
        Einstiegsseite:
        Zonen:
        Zonen - Button "Ausführung":
        Definition der Zielgeräte:
        Auslöser:
        Wie Testen?
        Infos zum Testen findest du im Adapter selbst:
        Wohin mit Bugs / Fehlerberichten oder Erweiterungswünschen?
        Da der Adapter noch jung und in fortlaufender Erweiterung ist, könnt ihr diese gerne hier posten (anders als es bereits in den Adapter-Optionen steht).
        Wichtig: Fehler (Bugs) bitte immer aussagekräftig beschreiben, am besten mit
        1. Screenshots, soweit möglicherweise hilfreich für mich als Entwickler
        2. Log-Auszug (in Code-Tags)
        3. Adapter-Optionen-Export, sofern als sinnvoll erachtet, Diese bekommt ihr so: ganz oben rechts in den SmartControl-Adapter-Optionen den blauen Button mit dem "Pfeil nach unten" anklicken.
        Was wurde alles seit der letzten Version geändert?
        Siehe Change Log
        CKMartensC Offline
        CKMartensC Offline
        CKMartens
        #270
        @Mic Hallo und schönen Abend,
        Mir ist nur gerade aufgefallen das heute aufgrund der Zeitumstellung die Astrozeiten nicht passen. So ist z. B. Sunset_Start 18:05 im Adapter unter Info, aber in der jetzigen Winterzeit ist es 17:05 Uhr.
        da_WoodyD MicM 2 Antworten Letzte Antwort
        • CKMartensC CKMartens
          da_WoodyD Online
          da_WoodyD Online
          #271
          @CKMartens das dauert manchmal einen tag...
          CKMartensC 1 Antwort Letzte Antwort
          • da_WoodyD da_Woody
            CKMartensC Offline
            CKMartensC Offline
            CKMartens
            #272
            @da_Woody das liegt eher daran wann der Adapter die Astrozeiten für den heutigen Tag errechnet. Wenn er es vor 3 Uhr macht, dann kommt er auf die 18:05. Werden die Astrozeiten nach 3 Uhr (was ja dann zu 2 Uhr wird) kommt 17:05 raus. Ist halt unangenehm da dann bei der Zeitumstellung jeweils die Daten fur eine eventuellen Außenbeleuchtung nicht passen.
              da_WoodyD Online
              da_WoodyD Online
              #273
              @CKMartens i know, aber wegen dem einen tag...
                MicM Offline
                MicM Offline
                Mic
                schrieb am zuletzt editiert von Mic
                #274
                Neue Version 0.5.8 (fix von 0.5.7)
                • (Mic-M) Various code fixes and improvements
                • (Mic-M) Potentially fix of issue #35 - to be tested
                • (Mic-M) Enhancement for 'Target Devices': Add table to call URLs als target (implementation of issue #1)
                Als Neuerung gibt es nun die Möglichkeit, URLs als Zielgeräte aufzurufen, z.B.
                Diese sind dann unter ZONEN entsprechend auswählbar:
                Außerdem gibt es diese Datenpunkte:
                • .call - hiermit könnt ihr auch "manuell", also auch ohne weiterer Konfigurationen in den Adapter-Optionen, die URL aufrufen. Z.B. per Blockly/JS etc.
                • .response - hier bekommt ihr die Antwort des URL-Aufrufs in den Datenpunkt.
                mrbungle64M 1 Antwort Letzte Antwort
                  MicM Offline
                  MicM Offline
                  Mic
                  #275
                  @CKMartens sagte in Test Adapter SmartControl 0.3.x-0.5.x Latest:
                  So ist es :) Smart Control aktualisiert jeweils im um 0:00.
                  Mach bitte gerne ein Github-Issue auf. Wird allerdings mit niedriger Prio bearbeitet und ich hab ja jetzt ein halbes Jahr Zeit 😁
                  Man muss dann auf jeden Fall sehen, das möglichst ressourcenschonend zu prüfen, da jede Nacht ausgeführt für nur 2x im Jahr.
                  • MichMeinM MichMein
                    Frage und Bitte an ALLE SC Nutzer,
                    habt ihr auch mehrfache Einträge der gleichen auslösenden Zone im DP des json Log? Könntet ihr das mal kontrollieren!?
                    Auf Wunsch könnte ich ne html Datei zur Verfügung stellen (aber erst morgen früh), in diese kann man den Inhalt des json kopieren und bekommt das anschließend im Browser in einer Tabelle ausgegeben.
                    Vielen Dank
                    MicM Offline
                    MicM Offline
                    Mic
                    #276
                    @MichMein sagte in Test Adapter SmartControl 0.3.x-0.5.x Latest:
                    Vielen Dank
                    Siehe hier: https://github.com/Mic-M/ioBroker.smartcontrol/issues/35
                    Bitte mal mit Version 0.5.8 testen und im Github-Issue berichten.
                    • SlowmanS Slowman
                      MicM Offline
                      MicM Offline
                      Mic
                      #277
                      @Slowman sagte in Test Adapter SmartControl 0.3.x-0.5.x Latest:
                      Ist kein Fehler, sondern eine Info.
                      Kannst du hier deaktivieren:
                      da_WoodyD SlowmanS 2 Antworten Letzte Antwort
                      • MicM Mic
                        da_WoodyD Online
                        da_WoodyD Online
                        #278
                        @Mic hi!
                        hab gerade ein feature request gemacht...
                        issue#37
                        • MicM Mic
                          SlowmanS Offline
                          SlowmanS Offline
                          Slowman
                          #279
                          @Mic
                          Vielen Dank !!!!
                          • MicM Mic
                            mrbungle64M Offline
                            mrbungle64M Offline
                            mrbungle64
                            #280
                            @Mic said in Test Adapter SmartControl 0.3.x-0.5.x Latest:
                            Hallo @Mic
                            erst mal danke für das Update von heute 👍
                            aktuell ist es aber leider nicht möglich DNS-Namen bei den URLs zu verwenden (nur IP-Adressen scheinen zu funktionieren). Ich habe ein paar Fälle getestet, nachdem meine Ziel URL nicht funktioniert hatte.
                            Als Beispiel die URL aus der Hilfe mit einem DNS-Namen anstatt der IP-Adresse:
                            [Config Table 'Targets: URLs'] - URL 'http://raspberrypi/relay/0?turn=on' is not a valid URL.
                            Soll ich einen Issue auf GitHub erstellen oder möchtest Du es Dir direkt anschauen?
                            • mrbungle64M mrbungle64
                              Hallo @Mic
                              MicM Offline
                              MicM Offline
                              Mic
                              #281
                              @mrbungle64 sagte in Test Adapter SmartControl 0.3.x-0.5.x Latest:
                              Hallo @Mic
                              Danke für deine Rückmeldung.
                              Bitte Github-Issue. Ich hab wohl eine zu strenge Prüfung der URL eingebaut ;)
                              • MicM Mic
                                Hallo @Mic
                                MicM Offline
                                MicM Offline
                                Mic
                                #282
                                Neue Version 0.5.9
                                • (Mic-M) Breaking Change New feature: 'Target Devices' -> 'Target URLs': added separate URL field to switch device off. This is breaking, since adapter admin config will have blank fields of 'Target URLs' once you update the adapter, and state ids will change as well.
                                • (Mic-M) Enhancement: 'Target Devices' -> 'Target URLs' : Allow DNS name
                                Zum ersten Punkt: nun kann auch eine URL zum Ausschalten definiert werden:
                                  sandro_gera
                                  #283
                                  Hallo an alle,
                                  ich wollte gerade über Github den Adapter installieren und habe folgende Fehlermeldung bekommen, kann mir jemand helfen?
                                  $ ./iobroker url "https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/admin/adapter.md"
                                  install https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/admin/adapter.md/tarball/dbe94231b926f6b2c7629b3772253b06e265b1af
                                  NPM version: 6.14.8
                                  npm install https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/admin/adapter.md/tarball/dbe94231b926f6b2c7629b3772253b06e265b1af --loglevel error --prefix "/opt/iobroker" (System call)
                                  npm ERR! code E404
                                  npm ERR! 404 Not Found - GET https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/admin/adapter.md/tarball/dbe94231b926f6b2c7629b3772253b06e265b1afnpm ERR! 404 npm ERR! 404 'https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/admin/adapter.md/tarball/dbe94231b926f6b2c7629b3772253b06e265b1af' is not in the npm registry.npm ERR! 404 Your package name is not valid, because npm ERR! 404 1. name can only contain URL-friendly charactersnpm ERR! 404 2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
                                  npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-10-29T14_44_15_328Z-debug.log
                                  ERROR: host.RaspBee-II-Phoscon Cannot install https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/admin/adapter.md/tarball/dbe94231b926f6b2c7629b3772253b06e265b1af: 1
                                  Vielen Dank im Voraus
                                  Master RPI4 8GB, Slave RPI3 1GB
                                  Node.js v18.17.1, npm: 9.6.7,
                                  JS-Controller: 5.0.16
                                  • S sandro_gera
                                    Hallo an alle,
                                    NPM version: 6.14.8
                                    npm ERR! code E404
                                    Kueppert
                                    schrieb am zuletzt editiert von Kueppert
                                    #284
                                    @sandro_gera äh, wo haste denn den link da her? Ich installiere zum Spaß gerade den Adapter nochmal drüber, meiner lautet anders...
                                    $ ./iobroker url "https://github.com/Mic-M/ioBroker.smartcontrol/tarball/master" smartcontrol --debug
                                    install https://github.com/Mic-M/ioBroker.smartcontrol/tarball/master
                                    • K Kueppert
                                      sandro_gera
                                      #285
                                      @Kueppert
                                      Hi den hatte ich da her
                                      • S sandro_gera
                                        @Kueppert
                                        Kueppert
                                        #286
                                        @sandro_gera ist aber falsch. Siehe einfach den 1. Post hier im Thread ;)
                                        S da_WoodyD 2 Antworten Letzte Antwort
                                        • K Kueppert
                                          sandro_gera
                                          #287
                                          @Kueppert
                                          ok danke dir dann versuch ich das gleich nochmal.
                                          Tja das war die Stafe für meine Dummheit
