  4. Test Adapter KNX v1.0.x
knx adapter
719 Beiträge 93 Kommentatoren 295.1k Aufrufe 85 Beobachtet
  • L
    L
    loverz
    #245
    Hall zusammen,
    ich wollte mal kurz auf diese Warnungen aufmerksam machen:
    knx.0	2020-10-07 12:27:55.576	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.575	warn	(2002) Object Zentral.Zeit.Datum_Zeit is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.521	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.521	warn	(2002) Object Zentral.Zeit.Uhrzeit is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.501	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.500	warn	(2002) Object Zentral.Zeit.Datum is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.065	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.064	warn	(2002) Object EG.Beleuchtung.Esstisch_Background_Sättigung_ändern is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.050	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.049	warn	(2002) Object EG.Beleuchtung.Esstisch_Background_Helligkeit_ändern is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.034	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.034	warn	(2002) Object EG.Beleuchtung.Esstisch_Helligkeit_ändern is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.021	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.020	warn	(2002) Object EG.Beleuchtung.Esstisch_Background_Farbe_ändern is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:55.005	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:55.005	warn	(2002) Object EG.Beleuchtung.Esstisch_Farbtemperatur_ändern is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:54.943	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:54.943	warn	(2002) Object EG.Beleuchtung.Wohnzimmer_Spots_dimmen_relativ is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:54.923	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:54.923	warn	(2002) Object EG.Beleuchtung.Kinderzimmer_Spots_dimmen_relativ is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:54.904	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:54.903	warn	(2002) Object EG.Beleuchtung.Esszimmer_Spots_dimmen_relativ is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    knx.0	2020-10-07 12:27:54.872	warn	(2002) This object will not be created in future versions. Please report this to the developer.
    knx.0	2020-10-07 12:27:54.871	warn	(2002) Object EG.Beleuchtung.Schlafzimmer_Spots_dimmen_relativ is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    • L loverz
      Hall zusammen,
      GlasfaserG
      GlasfaserG
      #246
      @loverz
      Welche Adapterversion ?
      L 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @loverz
        L
        L
        loverz
        #247
        @Glasfaser
        1.0.39
        • F
          F
          felixbleyl
          schrieb am zuletzt editiert von felixbleyl
          #248
          in Verbindung mit Siemens KNX Raumthermostaten kommt es bei mir regelmäßig zu Abbrüchen des Adapters, hier der Auszug aus dem Log:
          knx.0 2020-10-10 14:05:13.950 info (2733) Connected - local UDP Server listening on 192.168.178.21:55605
          knx.0 2020-10-10 14:05:13.947 info (2733) Using UDP with local IP: 192.168.178.21
          knx.0 2020-10-10 14:05:11.959 info (2733) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_RESPONSE(16) to STATE_NOT_CONNECTED(0).
          knx.0 2020-10-10 14:05:11.951 info (2733) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
          knx.0 2020-10-10 14:05:11.946 info (2733) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_READY(7) to STATE_NOT_CONNECTED(0).
          knx.0 2020-10-10 14:02:20.349 info (2733) Connected - local UDP Server listening on 192.168.178.21:33321
          knx.0 2020-10-10 14:02:20.347 info (2733) Using UDP with local IP: 192.168.178.21
          knx.0 2020-10-10 14:02:18.358 info (2733) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_RESPONSE(16) to STATE_NOT_CONNECTED(0).
          knx.0 2020-10-10 14:02:18.352 info (2733) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
          knx.0 2020-10-10 14:02:18.347 info (2733) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_READY(7) to STATE_NOT_CONNECTED(0).
          In der ETS (GruppenMonitor) sehe ich das die Raumthermostate irgendeine Information auf den Bus Senden, welche wahrscheinlich den Adapter in die Knie zwingen.
          Ich vermute das das Telegram mit der Ziel-Adresse: HVAC/DistrSegmH 1 das Problem verursacht, leider finde ich keine Option das Telegram im Gerät auszuschalten. Ich denke es liegt am LTE-Mode des Thermostates
          Hat jemand eine Idee das Problem zu lösen ?
          Bzw. Kann man bei dem KNX Adapter einstellen, wie er sich bei Unbekannten Telegrammen verhalten soll ? Eventuell das er Unbekannte Telegramme ignoriert ?
          Vielen Dank
          Felix
          • S
            S
            sourex
            #249
            Hi.
            Ich wollte seid einiger Zeit mal wieder versuchen meinen Stripe vernünftig über IO zu steuern da ich bei Github gelesen habe das Chefkoch mal die dazugehörigen Datenpunkte eingepflegt hat.
            Mein Aktor ist ein MDT der den Stripe auf den GT2 über HSV wunderbar ansteuert.
            Kann mir jemand bestätigen das das mit IOBroker überhaupt funktioniert bevor ich das unmögliche versuche ? :)
            Gesteuert werden sollen Helligkeit und Farbe.
            Sättigung wer schön aber kein Muss.
            Diverse Collerpicker Widgets funktionieren leider nicht da sie alle auf Hue Basis arbeiten.
            chefkoch009C 1 Antwort Letzte Antwort
            • S sourex
              Hi.
              chefkoch009C
              chefkoch009C
              chefkoch009
              #250
              @sourex Hast du mal 6-Byte Objekt versucht?
              • chefkoch009C chefkoch009
                S
                S
                sourex
                #251
                hier kannst du in etwa sehen was ich schon versuch habe.
                Mit den 6 Byte hatte ich es noch nicht versucht da die ganzen Verknüpfungen dann weg sind. Unter Openhab hat das ganze ja auch ohne einen einzelnen Weißwert geklappt.
                Dachte mir dann muss das doch auch hier so gehen.
                • Philipp S.P
                  Philipp S.P
                  Philipp S.
                  #252
                  Hallo liebe Community,
                  ich hätte auch mal ein Problem mit dem Adapter. Ich gehe mal stark davon aus das es ein Fehler meinerseits ist, dabei stehe ich jedoch schon ein paar Tage auf dem Schlauch.
                  Und zwar habe ich eine GA zum Schalten meines Lichtes und eine GA als Rückmeldeobjekt. Diese sind wie hier in dem Tread auch schon beschrieben wie folgt benannt:
                  knx.0.Licht.Rueckmeldung_Beleuchtung.Beleuchtung_OG_Flur_Ein_Aus
                  knx.0.Licht.Rueckmeldung_Beleuchtung.Beleuchtung_OG_Flur_Ein_Aus_STATUS
                  Mein Problöem besteht nun darin, das in der Vis die Anzeige nur in eine Richtung Funktioniert. Schalte ich das Licht in der Vis an, steht diese folglich auf "Ein". Schalte ich dann das Licht am Schalter aus so ändert sich die Anzeige (Schiebeschalter in der Vis auf "Aus".
                  Schalte ich jedoch das licht am Schalter an, so wird der Schiebeschalter in der VIS nicht aktualisiert.
                  Ist das Problem auch bei anderen bekannt? gibt es dazu eine Lösung? über Hilfe wäre ich sehr dankbar. Die beiden RAWs der Gruppenadressen habe ich unten mal angehängt.
                  Philipp
                    "_id": "knx.0.Licht.Schalten.Beleuchtung_OG_Flur_Ein_Aus",
                    "type": "state",
                    "common": {
                      "name": "Beleuchtung OG Flur Ein/Aus",
                      "type": "boolean",
                      "role": "value",
                      "unit": "",
                      "read": false,
                      "write": true,
                      "update": true,
                      "max": true,
                      "min": false
                    "native": {
                      "dpt": "DPT1.001",
                      "address": "1/1/15",
                      "addressRefId": "P-043C-0_GA-210",
                      "statusGARefId": "P-043C-0_GA-106",
                      "actGARefId": "",
                      "objRef": "O-0_R-11001",
                      "devName": "M-0083_A-008A-25-6CE4",
                      "devInst": "P-043C-0_DI-56",
                      "objectSize": ""
                    "from": "system.adapter.knx.0",
                    "user": "system.user.admin",
                    "ts": 1603573898012,
                    "acl": {
                      "object": 1638,
                      "owner": "system.user.admin",
                      "state": 1638
                    "ts": 1603573898022,
                    "common": {
                      "name": "Beleuchtung OG Flur Ein/Aus STATUS",
                      "type": "boolean",
                      "role": "indicator",
                      "unit": "",
                      "read": true,
                      "write": true,
                      "update": true,
                      "max": true,
                      "min": false
                    "native": {
                      "dpt": "DPT1.011",
                      "address": "1/4/15",
                      "addressRefId": "P-043C-0_GA-106",
                      "statusGARefId": "",
                      "actGARefId": "P-043C-0_GA-210",
                      "objRef": "O-65_R-223",
                      "objectSize": ""
                    "acl": {
                      "object": 1638,
                      "state": 1638
                    "_id": "knx.0.Licht.Rueckmeldung_Beleuchtung.Beleuchtung_OG_Flur_Ein_Aus_STATUS",
                    "type": "state"
                  TheBamT 1 Antwort Letzte Antwort
                  • Philipp S.P Philipp S.
                    Philipp
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "role": "value",
                        "unit": "",
                        "read": false,
                        "write": true,
                        "update": true,
                        "max": true,
                        "min": false
                      "native": {
                        "dpt": "DPT1.001",
                        "actGARefId": "",
                        "objectSize": ""
                      "acl": {
                        "object": 1638,
                        "state": 1638
                      "common": {
                        "type": "boolean",
                        "unit": "",
                        "read": true,
                        "write": true,
                        "update": true,
                        "max": true,
                        "min": false
                      "native": {
                        "dpt": "DPT1.011",
                        "objectSize": ""
                      "acl": {
                        "object": 1638,
                        "state": 1638
                      "type": "state"
                    TheBamT
                    TheBamT
                    TheBam
                    #253
                    @Philipp-Stopp
                    In deinem ersten DP steht in Zeile 9 bei read ein false drin. Das würde ich mal zu true ändern und im 2. DP bin ich mir bei der role nicht sicher ob da value rein muss. Probier die beiden Sachen mal aus.
                    GarfonsoG 1 Antwort Letzte Antwort
                    • Philipp S.P
                      Philipp S.P
                      Philipp S.
                      #254
                      @ThaBam Hallo,
                      vielen Dank für die Info. Ich habe beide Optionen unabhängig voneinander und auch zusammen ausprobiert, leider ohne Erfolg. Was zu sagen ist, in den Objekten wird der Wert des Rückmeldeobjektes Umgeschaltet. Dort Sehe ich sowohl das sich ändernde Schaltobjekt als auch die Veränderung in dem Rückmeldeobjekt. Lediglich der Schiebeschalter reagiert nicht.
                      Gibt es noch weitere Lösungsansätze?
                      Philipp
                      • TheBamT TheBam
                        @Philipp-Stopp
                        GarfonsoG
                        GarfonsoG
                        Garfonso
                        #255
                        @ThaBam said in Test Adapter KNX v1.0.x:
                        @Philipp-Stopp
                        Nein bitte read bei der ActGA auf false lassen. Sonst kannst du nicht mehr aus ioBroker raus steuern! (der adapter interpretiert das dann so, dass du dann ein GroupValueRead machen willst und nicht den GroupValue schreiben willst!).
                        @Philipp-S
                        Das Problem hört sich etwas strange an... also ein Ausschalten siehst du in der Vis, aber ein einschalten nicht? Siehst du im Admin-Tab Objekte, dass sich die Objekte ändern, wenn du im KNX schaltest?
                        Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                        Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                        Philipp S.P 1 Antwort Letzte Antwort
                          @ThaBam Hallo,
                          Philipp
                          M
                          M
                          mpenno
                          #256
                          @Philipp-S
                          Beim Testen und Probieren verschiedener Werte der RAW Daten habe ich die Erfahrung gemacht, das es hilfreich ist den KNX Adapter nach einer Änderung neu zu starten.
                          • GarfonsoG Garfonso
                            @Philipp-Stopp
                            @Philipp-S
                            Philipp S.P
                            Philipp S.P
                            Philipp S.
                            #257
                            @Garfonso Hallo,
                            ich habe das im ActGA wieder auf false zurückgestellt.
                            Unter den Objekten sehe ich, dass sich beim ausschalten via KNX sowohl die ActGA sowie die StatusGA ändern. Beide Zeigen also den "richtigen" Status an.
                            @mpenno EIn neustart des Adapters hat meine Situation nicht verändert.
                              @Garfonso Hallo,
                              GarfonsoG
                              GarfonsoG
                              Garfonso
                              #258
                              @Philipp-S said in Test Adapter KNX v1.0.x:
                              @Garfonso Hallo,
                              War dein Problem nicht das "anschalten"?
                              -> kommt ein und aus beides bei den ioBroker Objekten an? -> dann wäre es kein KNX / KNX-Adapter Problem.
                              Hast du das Objekt für die ActGA in Vis eingestellt?
                              • 123brokerei1 123brokerei
                                nachdem sich @chefkoch009 sehr viel Zeit genommen hat um mit mir am Rechner zusammen die Benennung der Datenpunkte gemeinsam durch zugehen, funktioniert jetzt auch das Dimmen über den Absolutwert einwandfrei.
                                An der Stelle nochmals vielen DANK an @chefkoch009
                                Ich möchte kurz, soweit mir möglich, wiedergeben, was gemacht wurde:
                                1: Benennung der GAs dahingehend angepasst, dass z.B.
                                • "... Schalten" und "... Schalten Staus", sowie
                                • "... Wert Dimmen" und "... Wert Dimmen Staus"
                                immer identisch heißen. Der Adapter kann so über die Namensübereinstimmung den Aktorwert mit den Statuswert verknüpfen.
                                Dies war allerdings bei mir trotz identischer Benennung nicht möglich, weshalb
                                2: manuell die "statusGARefId" und "addressRefId" der beiden zusammengehörenden Werte angepasst wurden.
                                Zu mehr reicht mein Hintergrund leider nicht.
                                S
                                S
                                spencer85
                                #259
                                Ich habe das gleiche Problem wie @123brokerei
                                Bei mir heißen die werte Identisch und hinten "Schalten und Schalten Status" und "Dimmwert und Dimmwert Status" Die wurden bei mir auch nicht erkannt.
                                Bedeutet das, dass ich jetzt alle manuell verknüpfen muss? über statusGARefId und actGARefID?
                                Das gleiche Problem habe ich bei Jalousien... Also muss ich alles manuell machen? Ich verstehe nicht warum bei mir die Heuristik versagt. Kann es sein, dass keine Namen verglichen werden wenn die GAs in unterschiedlichen Mittelgruppen liegen. Z.B. 2/2/3 mit 2/5/3?
                                Vielleicht könnte mir dazu jemand Feedback geben. Danke
                                  @Garfonso Hallo,
                                  Philipp S.P
                                  Philipp S.P
                                  Philipp S.
                                  #260
                                  @Garfonso Ja beide Objekte kommen in den Objekten an. Ich glaube das deren Verknüpfung nicht richtig funktioniert?! oder muss ich diese Verknüpfung manuell in der VIS herstellen? Dann wäre dies ei Problem in der VIS bzw. dort ein Fehler von mir.
                                  Muss ich in der VIS die SchaltGA und die StatusGA beide verknüpfen? wenn ja Wie?
                                  Philipp
                                    Philipp
                                    GarfonsoG
                                    GarfonsoG
                                    Garfonso
                                    #261
                                    @Philipp-S
                                    Wenn die Objekte richtig verknüpft sind, also Schaltvorgänge "im KNX" auch bei der SchaltGA angezeigt werden (nicht "nur" bei der StatusGA), dann ist alles richtig. Deine Objekte sehen in der Hinsicht auch gut aus.
                                    Also eigentlich sollte alles gehen, wenn du die SchaltGA nimmst...
                                    Zwei Sachen fallen mir noch ein:
                                    Kann es vielleicht sein, dass manche Schaltvorgänge nicht bei der richtigen Gruppe ankommen? Also ein Problem bei der KNX-Konfiguration vorliegt?
                                    Oder kann es sein, dass die Vis einfach, wenn du guckst, die Verbindung verliert und daher kein Update rein kommt?
                                      @Philipp-S
                                      Philipp S.P
                                      Philipp S.P
                                      Philipp S.
                                      schrieb am zuletzt editiert von Philipp S.
                                      #262
                                      @Garfonso Hallo,
                                      Vielen Dank für deine Rückmeldung. In den Objekten ändern sich beim schalten beide Objekte...
                                      Leider verstehe ich deine beiden Anmerkungen nicht ganz. Was meinst du mit Verbindung verlieren in der Visualisierung? Wo kann ich das sehen. In der KNX Einstellung kann es eigentlich nicht liegen, da ich ja sowohl das Licht schalten kann und auch die LED des Lichtschalter welche ich mit der StatusGA verknüpft habe...
                                      Ich glaube auch das ich das Problem in der vis suchen muss... Ich habe den Verdacht dass der Schiebeschalter nicht aktualisiert wird?! Macht das Sinn? Bzw was kann ich da verstellen?
                                      Gruß und vielen Dank,
                                      Philipp
                                        @Garfonso Hallo,
                                        Philipp
                                        GarfonsoG
                                        GarfonsoG
                                        Garfonso
                                        #263
                                        Naja, die Visualisierung braucht eine dauerhafte Verbindung zum Server, damit sie Updates bekommt. Das kann natürlich unterbrochen werden. Wäre aber nur zu prüfen, wenn es hin und wieder nicht funktioniert. Und dann würden auch andere Datenpunkte nicht aktualisiert.
                                        Welches Widget nutzt du denn genau? Mich verwirrt total, dass du siehst, dass sich die Lichter ausschalten, aber nicht, wenn sie sich anschalten. Das kann ich mir irgendwie kaum erklären... :-/
                                          Philipp S.P
                                          Philipp S.P
                                          Philipp S.
                                          #264
                                          @Garfonso Hallo,
                                          ich verwende den Switch: "fancyswitch - Schieber dunkel Ein/Aus"
                                          Ich habe es jetzt schon mit mehreren Lichtern im Haus Probiert. jedoch immer mit dem gleichen ernüchternden erfolg.
                                          Philipp
                                          84.2k
