  4. Test Adapter deConz v2.0.x
    6.4k
deconzconbeephoscon
196 Beiträge 38 Kommentatoren 45.0k Aufrufe 38 Beobachtet
  • Jey CeeJ Jey Cee
    @LoxDUS sagte in Test Adapter deConz v2.0.x:
    hässliche Fehlermeldungen im Zusammenhang mit der neuen Adapter Version
    Was für Fehlermeldungen?
    LoxDUS
    #170
    @Jey-Cee
    2020-10-11 01:18:57.984  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a prom
    ise which was not handled with .catch().
    2020-10-11 01:18:57.988  - error: deconz.0 (27633) unhandled promise rejection: Cannot read property 'id' of undefined
    2020-10-11 01:18:57.998  - error: deconz.0 (27633) TypeError: Cannot read property 'id' of undefined
        at handleWSmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:2325:54)
        at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-10-11 01:18:58.001  - info: deconz.0 (27633) cleaned everything up...
    2020-10-11 01:18:58.083  - info: deconz.0 (27633) terminating
    2020-10-11 01:18:58.084  - info: deconz.0 (27633) Terminated (NO_ERROR): Without reason
    2020-10-11 01:18:58.705  - error: host.IOBROKER2 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejec
    ting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-10-11 01:18:58.706  - error: host.IOBROKER2 Caught by controller[0]: TypeError: Cannot read property 'id' of undefined
    2020-10-11 01:18:58.706  - error: host.IOBROKER2 Caught by controller[0]:     at handleWSmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:2325:54)
    2020-10-11 01:18:58.710  - error: host.IOBROKER2 Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-10-11 01:18:58.711  - info: host.IOBROKER2 instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-10-11 01:18:58.711  - info: host.IOBROKER2 Restart adapter system.adapter.deconz.0 because enabled
    dieser Fehler tritt hin und wieder auf.
    Kann biete mich gerne auch als Tester an.
    Viele Grüße und vielen Dank für den Adapter
    Artur
    • Jey CeeJ Jey Cee
      Es gibt immer mehr Meldungen das Geräte die als Licht in deConz geführt werden mehr als einen Kanal haben. Aufgrund der neuen Struktur werden die aber nicht Berücksichtigt.
      Deshalb installiert bitte die v2 nicht. Wer die v2 verwendet und von dem Problem betroffen ist sollte am besten zur v1 zurück gehen, es wird noch eine Weile keine Lösung dafür geben.
      Mir stellt sich jetzt die Frage was ich machen soll. Hier 3 Möglichkeiten die ich sehe:
      1. Einen Schritt zurück gehen und die Geräte wieder Splitten, die MAC wird weiterhin verwendet plus Erweiterung.
        Der Aufwand wäre sehr gering, aber es wird wieder Unübersichtlicher und es gibt keine Garantie das es ohne Probleme funktioniert.
      2. Eigene Geräte Definitionen verwenden.
        Sehr Aufwändig, bedeutet den Adapter zu großen Teilen neu zu schreiben und erfordert das für jedes neue Gerät eine Definition angelegt werden muss. Im Gegenzug bedeutet das eine sehr Starke Kontrolle darüber wie Geräte in ioBroker dargestellt werden.
      3. Ich stell die Arbeit am Adapter ein weil mir langsam die Lust an deConz vergeht. Immer wieder gibt es Änderungen die Probleme verursachen und ein Überarbeiten nötig machen. Vieles ist gar nicht Dokumentiert und das es Lampen gibt die sich als 2 Geräte ausgeben wusste ich bisher gar nicht. Sonst hätte ich das Berücksichtigen können.
      Berchemer
      schrieb am zuletzt editiert von Berchemer
      #171
      @Jey-Cee sagte in Test Adapter deConz v2.0.x:
      Keine Ahnung, wie das passiert. Nachdem ich vor einiger Zeit mein weiter oben geschildertes Problem hatte, danach alles upgedatet und nun kapiert habe, wie der Adapter funktioniert, habe ich überhaupt keine Probleme:
      Ich habe mindestens 10 Steckdosen, 4 LED-Strahler, Wassersensoren, Bewegungs- und Vibrationsmelder und bin auf dem RaspBerry, auf welchem Phoscon im Zusammenhang mit einem RaspBee 1 läuft auf der aktuellsten Firmware- und Software-Version .
      Da ich die Tage bei IKEA vorbeifahren und mir zum Testen eine Stecke und den dazugehörige Fernbedienung holen wollte, wäre ich für weiter so im Programm.
      An der 2er finde ich insbesondere die Zusammenführung der Sensorkanäle der Energiemesssteckdosen sehr gut. Endlich habe ich bei allen Steckdosen Energie- und Power-Objekte in einem Unterordner und nicht mehr in Zweien, wie in der 1er Version.
      Da ich mich vorher erfolglos oder immer mit Problemen am Zigbee-Stick versucht habe und dort regelmäßig verzweifelt bin. Bitte weitermachen :-)👍
      • PrastojP Offline
        PrastojP Offline
        Prastoj
        schrieb am zuletzt editiert von Prastoj
        #172
        @LoxDUS
        Dann les ein paar Beiträge weiter oben. Mit der 2. Version gibt es Probleme Bei RGBW Lampen wegen 2 verschiedenen Kanälen.
        Installier wieder die Version 1. Dann sind die Probleme erstmal weg, bis das Problem behoben wurde
          skokarl
          #173
          Redet eigentlich jemand bei der Fehlersuche über den aktuell installierten deconz Treiber ?
          Die bringen dort auch alle Nase lang neue Versionen raus.
          Ich will jetzt hier nicht klugscheissern......ist mir aber mal aufgefallen.
          Link Text
          • Jey CeeJ Jey Cee
            Steff75
            #174
            @Jey-Cee Hi. Danke für deinen Adapter! Ich hoffe, das es weitergeht.
            Ich habe die Version 2 jetzt ca. 2 Wochen installiert und es funktioniert soweit ganz gut. Es gibt nur diesen einen Schönheitsfehler, dass wenn ich in Phoscon etwas neues einrichte, mir der Adapter dann teilweise Namen von Geräten ändert. Das war mit Version 1 nicht der Fall.
            So habe ich gestern zum Beispiel einen neuen Fenster-/Türkontaktsensor mit Phoscon verbunden. Der Adapter hat diesen dann auch angezeigt, aber er hat dann in einem Zug auch zwei andere Geräte als Fenster-/Türkontaktsensor umbenannt (den virtuellen Tageslichtsensor und einen Tradfri an/aus Schalter.
            Ähnlich war es auch, als ich neulich in Phoscon eine Sensorsteuerung mit dem Tradfri Bewegungsmelder erstellt hatte. Da wurden danach auch einige Geräte umbenannt.
            Evt. könnte man da einen Schreibschutz einbauen, der automatisches Umbenennen verhindert, wenn sowas möglich wäre?
            Vielen Dank!
            • S skokarl
              Link Text
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #175
              @skokarl ja die deConz Version hat auch Bedeutung und es wäre Super wenn ich die auch immer wüsste oder ihr bevor ihr ne Fehlermeldung raus haut einfach auf die Aktuellste geht.
              @Steff75 eigentlich dürften andere Geräte nicht umbenannt werden. Das ist definitiv ein Fehler.
              @Steff75 sagte in Test Adapter deConz v2.0.x:
              Ich hab mich noch nicht Endgültig entschieden wie es weiter geht, aber es wird wohl weiter gehen.
              So oder so wird es wohl erst im Dezember weiter gehen.
              An dieser Stelle auch nochmal eine Dakeschön an alle die mir eine Spende haben zu kommen lassen.
              Persönlicher Support
              Spenden -> paypal.me/J3YC33
              • Jey CeeJ Jey Cee
                skokarl
                #176
                @Jey-Cee
                Wie macht man unter Linux das Update auf eine neuere Version ?
                Bisher hatte ich immer nur die aktuelle Version genommen wenn ich die NUC neu aufgesetzt hatte.
                Aktuelle Version Stable 2.05.84
                • S skokarl
                  @Jey-Cee
                  #177
                  @skokarl
                  iobroker update
                  iobroker upgrade
                    @skokarl
                    iobroker update
                    iobroker upgrade
                    skokarl
                    #178
                    @Thomas-Braun sagte in Test Adapter deConz v2.0.x:
                    @skokarl
                    iobroker update
                    iobroker upgrade
                    Ich lade doch die 2.05.84 erst runter.....dann muss sie entpackt werden.....und dann ?
                    oder bin ich jetzt völlg falsch ?
                    Neue Installation läuft so
                    sudo gpasswd -a $USER dialout
                    wget http://deconz.dresden-elektronik.de/ubuntu/stable/deconz-2.05.81-qt5.deb
                    sudo dpkg -i deconz-2.05.81-qt5.deb
                    sudo apt --fix-broken install
                    sudo systemctl enable deconz
                    sudo systemctl start deconz
                    Thomas BraunT Jey CeeJ 2 Antworten Letzte Antwort
                    • S skokarl
                      @skokarl
                      iobroker update
                      iobroker upgrade
                      #179
                      @skokarl Quark. Einmal das Repo gescheit einrichten und dann geht das per apt.
                      • S skokarl
                        @skokarl
                        iobroker update
                        iobroker upgrade
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        schrieb am zuletzt editiert von Jey Cee
                        #180
                        @skokarl sagte in Test Adapter deConz v2.0.x:
                        Nein ist richtig wenn du die Beta testen willst, aber wenn du stable haben willst ist hier die Anleitung dazu. Dann geht ein Update wie @Thomas-Braun das beschrieben hat.
                        • Jey CeeJ Jey Cee
                          #181
                          @Jey-Cee Für die Betas gibt es auch ein entsprechendes Repo.
                          • Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            #182
                            Ich suche 5-10 deConz Nutzer die möglichst viele Unterschiedliche Geräte haben.
                            Wichtig ist das ihr nicht Paranoid seit und kein Problem damit habt das Daten an mich gesendet werden.
                            Für alles weitere schreibt mich bitte hier im Chat an oder auf Discord @realwax kannst du mich mal bitte auf discord (https://discord.com/invite/HwUCwsH)
                            capitaenzC 1 Antwort Letzte Antwort
                            • Jey CeeJ Jey Cee
                              capitaenzC Offline
                              capitaenzC Offline
                              capitaenz
                              #183
                              Habe eine kurze Verständnisfrage:
                              Mir wird ein Update angeboten:
                              deConz ZigBee 1.3.10 -> 1.3.11
                              Auf Github finde ich zur 1.3.11 nichts mehr, nur noch zur 2.x.x
                              Was wurde geändert und welche Version ist die richtige/aktuelle stable?
                              ioBroker auf Synology DS920+ (SSD Raid / 20GB RAM) im VMM
                              AsgothianA Jey CeeJ 2 Antworten Letzte Antwort
                              • capitaenzC capitaenz
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #184
                                @capitaenz
                                Die aktuelle Stable ist 1.3.11
                                Die aktuelle Latest ist 2.0.5
                                A.
                                  Jey CeeJ Online
                                  Jey CeeJ Online
                                  Jey Cee
                                  #185
                                  @capitaenz nur ein Bugfix der unter ungünstigen umständen den RAM Verbrauch für deConz nach oben getrieben hat. Außerdem hat das auch zu Verzögerungen geführt.
                                  capitaenzC haselchenH 2 Antworten Letzte Antwort
                                  • Jey CeeJ Jey Cee
                                    capitaenzC Offline
                                    capitaenzC Offline
                                    capitaenz
                                    #186
                                    @Jey-Cee Danke für die Info, Verzögerungen kann ich tatsächlich ausmachen...
                                    • Jey CeeJ Jey Cee
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #187
                                      @Jey-Cee
                                      Hey...habe gerade mal die Objekte gecheckt und gesehen, dass mein Conbee Stick im Lights Ordner als Configurations Tool aufgeführt ist?!
                                      Bug oder richtig?
                                      • haselchenH haselchen
                                        @Jey-Cee
                                        Bug oder richtig?
                                        Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #188
                                        @haselchen weder noch. Keine Ahnung warum deconz das über die Api ausgibt.
                                          Steff75
                                          #189
                                          @Jey-Cee Moin, ich habe mir meinen ersten smarten Heizkörperthermostat gegönnt. Es ist der Danfoss Ally geworden.
                                          Ich habe diesen auch erfolgreich über meinen Conbee 2 mit deconz verbunden und dein Adapter zeigt auch die Datenpunkte an.
                                          Nun das Problem mit dem Datenpunkt heatsetpoint:
                                          Wenn ich innerhalb des ioBrokers den Wert von heatsetpoint verändere, wird dieser eingetragene Wert nicht auf den Thermostat übertragen. Im Log vom Adapter finde ich auch keine Fehlermeldung oder Bestätigungen von einem Request.
                                          Per Rest-API kann ich den heatsetpoint jedoch erfolgreich setzen, z.B. mit curl
                                          curl -X PUT http://192.168.178.31:8077/api/xxxxxxxxxx/sensors/21/config \
                                              -H 'Content-Type: application/json' \
                                              -d '{"heatsetpoint": 2100}'
                                          Änderungen über die Rest-API oder durch manuelles Regeln am Thermostat werden anders herum aber schon im Datenpunkt heatsetpoint aktualisiert.
                                          Hast du evt. eine Ahnung, woran es liegen könnte?
                                          Falls benötigt, hier weitere Details zum Danfoss Ally:
                                          https://github.com/dresden-elektronik/deconz-rest-plugin/issues/2983
                                          Vielen Dank!
