  4. JavaScript
  5. Shelly Verbrauchs-Historie für Tag, Woche, Monat, Jahr
144 Beiträge 27 Kommentatoren 34.2k Aufrufe 30 Beobachtet
    Warnmeldungen:
    avascript.0	2020-10-01 21:27:49.393	warn	(4700) at processTimers (internal/timers.js:497:7)
    javascript.0	2020-10-01 21:27:49.392	warn	(4700) at listOnTimeout (internal/timers.js:554:17)
    javascript.0	2020-10-01 21:27:49.392	warn	(4700) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-10-01 21:27:49.391	warn	(4700) at Object.shelly_verbrauch_tag (script.js.Datenpunkte.ShellyVerbrauch:130:5)
    javascript.0	2020-10-01 21:27:49.391	warn	(4700) at aktualisiere_namen (script.js.Datenpunkte.ShellyVerbrauch:157:19)
    javascript.0	2020-10-01 21:27:49.391	warn	(4700) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:785:29)
    javascript.0	2020-10-01 21:27:49.390	warn	(4700) at script.js.Datenpunkte.ShellyVerbrauch:158:9
    javascript.0	2020-10-01 21:27:49.390	warn	(4700) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
    javascript.0	2020-10-01 21:27:49.389	warn	(4700) You are assigning a object to the state "javascript.0.ShellyVerbrauch.SHSW-1#0588A5#1.name" which expects a string. Please fix your code to use a string or change the state type to object. Thi
    javascript.0	2020-10-01 21:27:49.388	warn	(4700) at processTimers (internal/timers.js:497:7)
    javascript.0	2020-10-01 21:27:49.387	warn	(4700) at listOnTimeout (internal/timers.js:554:17)
    javascript.0	2020-10-01 21:27:49.387	warn	(4700) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-10-01 21:27:49.387	warn	(4700) at Object.shelly_verbrauch_tag (script.js.Datenpunkte.ShellyVerbrauch:130:5)
    javascript.0	2020-10-01 21:27:49.386	warn	(4700) at aktualisiere_namen (script.js.Datenpunkte.ShellyVerbrauch:157:19)
    javascript.0	2020-10-01 21:27:49.386	warn	(4700) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:785:29)
    javascript.0	2020-10-01 21:27:49.386	warn	(4700) at script.js.Datenpunkte.ShellyVerbrauch:158:9
    javascript.0	2020-10-01 21:27:49.385	warn	(4700) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
    javascript.0	2020-10-01 21:27:49.384	warn	(4700) You are assigning a object to the state "javascript.0.ShellyVerbrauch.SHPLG-S#7A09EB#1.name" which expects a string. Please fix your code to use a string or change the state type to object. Th
    javascript.0	2020-10-01 21:27:49.383	warn	(4700) at processTimers (internal/timers.js:497:7)
    javascript.0	2020-10-01 21:27:49.383	warn	(4700) at listOnTimeout (internal/timers.js:554:17)
    javascript.0	2020-10-01 21:27:49.382	warn	(4700) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-10-01 21:27:49.382	warn	(4700) at Object.shelly_verbrauch_tag (script.js.Datenpunkte.ShellyVerbrauch:130:5)
    javascript.0	2020-10-01 21:27:49.381	warn	(4700) at aktualisiere_namen (script.js.Datenpunkte.ShellyVerbrauch:157:19)
    javascript.0	2020-10-01 21:27:49.381	warn	(4700) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:785:29)
    javascript.0	2020-10-01 21:27:49.380	warn	(4700) at script.js.Datenpunkte.ShellyVerbrauch:158:9
    javascript.0	2020-10-01 21:27:49.378	warn	(4700) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
    javascript.0	2020-10-01 21:27:49.374	warn	(4700) You are assigning a object to the state "javascript.0.ShellyVerbrauch.SHHT-1#E00FD8#1.name" which expects a string. Please fix your code to use a string or change the state type to object. Thi
    SKBS Offline
    SKBS Offline
    SKB
    @Yetiberg aktuellen Skript-Adapter installiert?
    • SKBS SKB
      @SKB Ja habe ich
      SKBS 1 Antwort Letzte Antwort
        @SKB Ja habe ich
        SKBS Offline
        SKBS Offline
        SKB
        @Yetiberg kannst Du mir bitte mal als Screenshot den aufgeklappten Datenpunkt des Shelly zeigen, um den es geht? Ich vermute, der Datenpunkt des Namen wird nicht einwandfrei gelesen oder gespeichert.
        • ? Offline
          Das macht er ja beim einlesen aller Shellys
          Da wird der Datenpunkt falsch angelegt wo er meckert.
          • SKBS SKB
            @frankthegreat Wie wird denn da der Verbrauch protokolliert?
            Bei jedem ein- und ausschalten ein neuer Wert?
            Durchgehend steigender Wert bis Reset und dann start bei Null?
            frankthegreatF Offline
            frankthegreat
            @SKB sagte in Shelly Verbrauchs-Historie für Tag, Woche, Monat, Jahr:
            Da wird wohl alle paar Sekunden ein neuer Wert geschrieben:
              SKBS Offline
              SKBS Offline
              SKB
              @Yetiberg Schaue ich mir im Laufe des Morgens an. Ich habe hier schon eine Vermutung. Du könntest zum Testen mal einen Namen im Datenpunkt "name" anlegen und schauen, ob das Skript dann läuft. Dann haben wir den Fehler gefunden ;)
              • SKBS SKB
                SKBS Offline
                SKBS Offline
                SKB
                @Yetiberg ... Fehler sollte in Zeile 158 liegen. Ändere die mal bitte in:
                setState(shelly_DP_Name(id),String(getState(id).val));
                dann sollte es ohne Warnings laufen :)
                XsevX 1 Antwort Letzte Antwort
                • SKBS SKB
                  XsevX Offline
                  XsevX Offline
                  Xsev
                  schrieb am zuletzt editiert von Xsev
                  @SKB Skript läuft soweit gut bei mir ohne Warnungen.
                  Einzig der "aktueller Wert" und "alter Wert" erschließen sich nicht ganz für mich bzw. hab ich da teilweise komische Werte, siehe Screen. Sollte der aktuelle Wert nicht den live Wert angeben und alter nicht den letzten live vor dem abschalten? Die Verbraucher die da mit über 500 Watt und 800W angegeben sind haben ca. 30W und sind zum Screenshot Zeitpunkt ausgeschaltet.
                  EDIT!!!
                  Sorry habs kapiert, das sind Wh und nicht W..... alles klaro!! Danke!
                  • XsevX Xsev
                    EDIT!!!
                    SKBS Offline
                    SKBS Offline
                    SKB
                    @Xsev Prima, wenn es bei Dir ohne Probleme läuft :)
                    Genau, alter Wert ist der alte Wert vor dem erneuten Auslesen und neuer Wert ist der aktuelle ausgelesene Wert. Daraus wird dannd ie Differenz gebildet.
                    Seit eben habe ich auch das Problem von @Yetiberg Yetiberg beseitigt und die Version 1.1 auf der Seite bereitgestellt. Hier hat sich die Zeile 158 geändert.
                    • SKBS SKB
                      @SKB
                      Habe erst jetzt Zeit gehabt das neue Script zu Testen.
                      Läuft nun ohne Warnmeldungen.
                      Nun werde ich mal beobachten wie das Script läuft.
                        @SKB
                        SKBS Offline
                        SKBS Offline
                        SKB
                        @Yetiberg Prima :)
                        Dürfte ich dich fragen, welches Widget (die gelben Bereiche) das ist?
                        • SKBS SKB
                          @Yetiberg Prima :)
                          @SKB Ist das - Border - Widget
                          • DutchmanD Dutchman
                            warum separate script, genau dafuer hab ich sourceanalytix gebaut das man solche script nicht mehr braucht und der macht genau das....
                            und dan nicht nur den verbrauch, auch die kosten usw...
                            canim
                            @Dutchman said in Shelly Verbrauchs-Historie für Tag, Woche, Monat, Jahr:
                            sourceanalytix
                            Hast ja was schönes gemacht, kann ich aber nicht nutzen. In der To Do steht Dokumentation :D, wäre geil.
                            Hab den Adapter installiert, komme auch auf die Konfig. Seite mit dem Preisen ETc. aber wo kann ich mein Datenpunkt Wählen was er Tracken sollen? Habe bei
                            Objekte nicht den Ordner wie auf dein Bild. Hab derzeit Probleme mit Coap bei Shelly,sodass mein Aktueller Stromwert nicht mehr aktualisiert. Hab derzeit mein SHelly über MQTT / Http laufen,sodass ich den Wert bekomme. Wenn man die Funktion Aktiviert, werden meine Daten über Cload nicht mehr gespeichert. Deswegen wäre ne Doku über dein Script nicht schlecht.
                            Platform: linux
                            os: linux
                            Architecture: arm
                            CPUs: 4
                            Speed: 1600 MHz
                            Model: ARMv7 Processor rev 3 (v7l)
                            RAM: 3.7 GB
                            System uptime: 01:07:12
                            Node.js: v12.18.4
                            NPM: 6.14.6
                            Disk size: 14.3 GiB
                            Disk free: 10.3 GiB
                            adapters count: 369
                            Uptime: 01:07:07
                            Active instances: 20
                            -1
                            • C canim
                              sourceanalytix
                              Platform: linux
                              os: linux
                              Architecture: arm
                              CPUs: 4
                              Speed: 1600 MHz
                              RAM: 3.7 GB
                              Node.js: v12.18.4
                              NPM: 6.14.6
                              Disk size: 14.3 GiB
                              Disk free: 10.3 GiB
                              adapters count: 369
                              Uptime: 01:07:07
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              @canim sagte in Shelly Verbrauchs-Historie für Tag, Woche, Monat, Jahr:
                              ist ein Arbeit :),drück mal auf den schraubschluessel beim state
                              -1
                                SKBS Offline
                                SKBS Offline
                                SKB
                                @Dutchman und @canim,
                                Ich wäre Euch sehr verbunden, wenn Ihr in meinem Beitrag eben nicht von anderen Adaptern sprechen würdet - das verwirrt.
                                Danke ;)
                                C 1 Antwort Letzte Antwort
                                • SKBS SKB
                                  Danke ;)
                                  canim
                                  @SKB Sorry hast recht, hab nebenbei erstmal dein Laufen :)
                                  @Dutchman -.-,darauf muss man erstmal kommen.danke!Rest ist selbsterklärend
                                  • MalleRalleM Offline
                                    MalleRalleM Offline
                                    MalleRalle
                                    schrieb am zuletzt editiert von MalleRalle
                                    Funktioniert übrigens auch sehr gut mit TP-Link Steckdosen wenn man das Script dementsprechend umbaut.
                                    Noch ein Datenpunkt in den hs100 Adapter und ein Blockly dazu und läuft.
                                    MalleRalleM 1 Antwort Letzte Antwort
                                    • MalleRalleM MalleRalle
                                      MalleRalleM Offline
                                      MalleRalleM Offline
                                      MalleRalle
                                      @SKB
                                      `Letztes Jahr´ hat er heute Nacht nicht aktualisiert.
                                        @SKB
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        @MalleRalle
                                        Das tut mir sehr Leid.
                                        Ich habe das Skript entsprechend angepasst ;)
                                        Alles Gute im neuen Jahr :)
                                        • I Offline
                                          I Offline
                                          IOBaer
                                          Tolles Skript. Ist es ein Problem, wenn der Shelly und/oder ioBroker nachts um 00:00 Uhr manchmal nicht verfügbar ist? Danke.
