  4. JavaScript
  5. [Vorlage] Flexibles Timerskript + Vis
javascripttemplate
500 Beiträge 40 Kommentatoren 165.5k Aufrufe 63 Beobachtet
  • S Saschag
    @Pittini
    Ich habe häufiger das Problem dass der Javascriptadapter abstürzt beim hinzufügen eines neuen Timers
    javascript.0	2020-08-15 22:20:03.237	info	(10516) received all objects
    javascript.0	2020-08-15 22:20:01.859	info	(10516) received all states
    javascript.0	2020-08-15 22:19:59.847	info	(10516) requesting all objects
    javascript.0	2020-08-15 22:19:59.845	info	(10516) requesting all states
    javascript.0	2020-08-15 22:19:59.751	info	(10516) starting. Version 4.6.17 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.3, js-controller: 3.1.6
    javascript.0	2020-08-15 22:19:26.560	error	(8468) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2020-08-15 22:19:26.560	error	(8468) at runMicrotasks (<anonymous>)
    javascript.0	2020-08-15 22:19:26.560	error	(8468) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2020-08-15 22:19:26.559	error	(8468) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-08-15 22:19:26.559	error	(8468) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:547:55
    javascript.0	2020-08-15 22:19:26.559	error	(8468) at script.js.Timer.TimerV217:260:17
    javascript.0	2020-08-15 22:19:26.559	error	(8468) at FillTimerArray (script.js.Timer.TimerV217:281:9)
    javascript.0	2020-08-15 22:19:26.559	error	(8468) at CreateDeviceTrigger (script.js.Timer.TimerV217:1056:5)
    javascript.0	2020-08-15 22:19:26.558	error	(8468) at on (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1151:28)
    javascript.0	2020-08-15 22:19:26.558	error	(8468) at Object.subscribe (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:112)
    javascript.0	2020-08-15 22:19:26.557	error	(8468) script.js.Timer.TimerV217: TypeError: Cannot read property 'period' of null
    Eine Idee und Danke im Voraus
    Pittini
    #266
    @Saschag sagte in [Vorlage] Flexibles Timerskript + Vis:
    N komplettes Log wär schon hilfreich.
    • R Offline
      rotamint
      #267
      Hallo, guten Abend zusammen! Ich brauche bitte (mal wieder) Eure Hilfe. Ich habe den Aktor der Poolpumpe getauscht und einen neuen Namen vergeben. Die Timer haben sich nicht löschen lassen, daher habe ich in der Java-Instanz alles gelöscht ....
      Auch das Script habe ich neu installiert, auch wenn ich nicht wüsste, in welchem Zusammenhang es stehen sollte, dass ich immernoch folgende Meldung erhalte
      Sonoff.0.Poolpumpe war der alte Aktor, der existiert nicht mehr, und ich bin der Meinung, ich habe auch alles entsprechend gelöscht.
      Wer hat eine Idee, wo der Fehler versteckt sein könnte?
      Danke für Eure Hilfe!
      Schönen Abend, Gruß Stefan.
      P 1 Antwort Letzte Antwort
      • R rotamint
        Pittini
        #268
        @rotamint sagte in [Vorlage] Flexibles Timerskript + Vis:
        Das sieht mir nach ner Leiche in den Aufzählungen aus. Wenn man nen Dp löscht, der ner Funktion zugeordnet war, wird diese Zuordnung manchmal nicht gelöscht. Geh mal in Aufzählungen > Funktionen und kontrollier bei TimerTarget ob da der alte Dp noch aufgeführt ist. Wenn ja, dort löschen, dann sollte es wieder klappen.
        R 1 Antwort Letzte Antwort
        • P Pittini
          rotamint
          #269
          @Pittini Perfekt! Wieder einmal vielen Dank für Deine schnelle & kompetente Hilfe. Genau dort hatte sich der Fehler versteckt :)
          Danke. Stefan.
          • P Pittini
            Thread zum Timerskript unter: https://github.com/Pittini/iobroker-Timer
            deta
            #270
            Hallo, ich hab auch mal was wieder :-)
            @Pittini , gestern warum auch immer waren alle einzelnen Positionen weg. Vielleicht hat es mit dem Skript Engerie Update gestern zu tun gehabt, es kam ja heute bereits wieder ein Update davon.
            Wie auch immer es waren alle Postionen weg 😞
            Musste alle wieder neu eintragen, wollte kein Backup der letzten Tage komplett wieder einspielen.
            Es geht wieder alles.
            Was super wäre:
            1. Backup Möglichkeit der einzelnen Positionen, einfach irgendwo ein Button, draufklicken und die Postionen werden gespeichert. Sollte es noch mal passieren, Restore Button um die Positionen wieder einzuspielen. Dann spart man sich die ganze Arbeit.
            2. Sortierung nach Zeit der Positionen. Das diese ggf. nicht durcheinander sind. z.b. hab ich vergessen einmal eine Ausschaltzeit einzugeben, kann man nachträglich, aber dann ist diese an der letzten Position.
            So das war erst mal. Vielleicht kann man gelegentlich mal Einbauen.
            • D deta
              Was super wäre:
              Pittini
              #271
              @deta sagte in [Vorlage] Flexibles Timerskript + Vis:
              Was super wäre:
              Hm, sorry, wirds beides nicht geben, aus unterschiedlichen Gründen.
              Backup wirds nicht geben weil, der Datenverlust kam ja nicht durchn Skriptfehler. In dem Fall wäre der einfachste Backup Weg wohln Screenshot, dann ist das doch fix wieder eingetragen. Von wieviel Timern sprechen wir denn?
              Die Sache mit dem sortieren nach Zeit fände ich sinnvoll, hab auch schon mal drüber nachgedacht, war mir aber ehrlich gesagt zuviel Aufwand. Mal sehen, vieleicht is mir ja mal langweilig 😊 .
              D Dominik F.D 2 Antworten Letzte Antwort
              • P Pittini
                Was super wäre:
                deta
                #272
                @Pittini sagte in [Vorlage] Flexibles Timerskript + Vis:
                Was super wäre:
                War nicht das große drama, aber wäre eine gute Erleichterung, kommt ja nicht jeden Tag vor, aber warum das mit einmal weg war, keine Ahnung. Alles andere lief.
                Jup, hat ja keine Eile :-) So wie du Lust und Laune hast.
                • P Pittini
                  Was super wäre:
                  Dominik F.D Offline
                  Dominik F.D Offline
                  Dominik F.
                  #273
                  @Pittini
                  Ich weiß nicht ob es hier schon angemerkt wurde oder schon gelöst wurde weil ich jetzt länger nicht mehr so intensiv dem Thread folgen konnte.
                  Mir ist aufgefallen, dass wenn ich z.B. Beginn Sonnenuntergang als Zeit auswähle, der richtige Zeitpunkt ausgewählt wird, sich aber über ein paar Tage hinweg nicht selbstständig aktualisiert. Erst beim erneuten speichern eines Timers wird der Zeitpunkt aktualisiert. Ich könnte mir vorstellen, dass dies nicht von dir gewollt ist.
                  • Rene55R Offline
                    Rene55R Offline
                    Rene55
                    #274
                    @Pittini Vielen Dank für das tolle Script - hat nach den Anweisungen zur Installation auch bei mir als relativem Neuling sofort geklappt. Ich habe nur festgetellt, dass beim Löschen von Timern etwas nicht stimmt. Wenn ich Timer 5 löschen will muss ich auf Timer 6 einstellen, sonst wird der falsche Eintrag gelöscht. Somit kann ich den letzten Timer auch nicht löschen. Liegt das an mir oder hat sonst jemand auch diesen Effekt.
                    Danke fürs nachschauen.
                    F 1 Antwort Letzte Antwort
                    • Rene55R Rene55
                      F Online
                      F Online
                      fastfoot
                      #275
                      @Rene55 sagte in [Vorlage] Flexibles Timerskript + Vis:
                      siehe hier, @Pittini kann es aber nicht nachvollziehen
                      • Rene55R Offline
                        Rene55R Offline
                        Rene55
                        #276
                        @fastfoot Danke für die prompte Antwort. Ich habe es daraufhin gerade nochmals versucht: Angewählt habe Timer 4 -> und Timer 3 wurde gelöscht. Scheint also reproduzierbar zu sein.
                        • Rene55R Rene55
                          F Online
                          F Online
                          fastfoot
                          #277
                          Ja, ist es. Der erste und letzte Timer lassen sich aber problemlos löschen. Im Beitrag darunter habe ich meine Lösung dazu gepostet
                          • Rene55R Offline
                            Rene55R Offline
                            Rene55
                            #278
                            @fastfoot Ich hab diese Änderung mal eingebaut. Timer lassen sich dann richtig löschen. Außer Timer 1 - den krieg ich nicht weg!
                            Noch eine Idee?
                            • Rene55R Rene55
                              Noch eine Idee?
                              F Online
                              F Online
                              fastfoot
                              #279
                              Noch eine Idee?
                              Nur wenn es nicht der einzige ist, ansonsten schon
                              • Rene55R Offline
                                Rene55R Offline
                                Rene55
                                #280
                                @fastfoot Sorry falsch ausgedrückt. Timer 1 ist im Moment bei mir der letzte - unlöschbar?
                                • Rene55R Rene55
                                  F Online
                                  F Online
                                  fastfoot
                                  #281
                                  nee, sollte schon funktionieren, solange es mehrere sind. Evtl. kommt das noch von der ungepatchten Version. Ich würde alle Datenpunkte unter javascript.0.Timer löschen und neu aufbauen, geht doch schnell :-)
                                  • Rene55R Offline
                                    Rene55R Offline
                                    Rene55
                                    #282
                                    @fastfoot es sind eben gerade nicht mehrere sondern es ist der "allereinzigste" Timer.
                                    Weiß denn jemand, ob es nochmal eine neue Version von @Pittini geben wird?
                                    • Rene55R Rene55
                                      F Online
                                      F Online
                                      fastfoot
                                      #283
                                      Der einzigste Timer wird absichtlich nicht gelöscht. Deshalb der Tipp mit den Datenpunkten. Wenn Du das Skript aber weiterverwenden willst, warum änderst du dann den Timer nicht ab?
                                      • Rene55R Offline
                                        Rene55R Offline
                                        Rene55
                                        #284
                                        @fastfoot Wenn das so ist, kann ich damit leben. Sollte der Fall eintreten, dass ich auch den letzten Timer weghaben will (was wahrscheinlich nicht vorkommen wird), kann ich das Script ja auch stoppen!
                                        Schlimmer war das Löschen der falschen Timer - das habe ja mit deiner Änderung ja hinbekommen. Danke dafür und auch für die schnelle Hilfe.
                                        • P Offline
                                          Pittini
                                          #285
                                          Der letzte Timer kann nicht gelöscht werden was Absicht ist, ein Timerskript ohne Timer is sinnfrei.
                                          Das Löschproblem hatte ich schon gefixt, nur vergessen hochzuladen.
                                          Changelog
                                          V2.1.8 (22.09.2020)
                                          • Fix: Problem beim löschen von Timern behoben. (fastfood)
