  4. Test Adapter time-switch v2.0.x GitHub/Latest
adaptertesttimeswitchzeitschaltuhrvis
481 Beiträge 75 Kommentatoren 182.3k Aufrufe 87 Beobachtet
  • Stephan SchleichS Stephan Schleich
    @sigi234 komisch, sieht damit nicht so wie auf deim letzten Bild aus, die Wochentage sind gleich groß geblieben und haben auch keine farbe, muss ich mich mal spielen, aber Vielen Dank 👍
    /** Time-Switch Widget **/
    app-on-off-schedule-widget {
        /* Primary color (button background, toggle switch color) */
        --ts-widget-primary-color: #337ab7;
        /* Background color of the widget */
        --ts-widget-bg-color: #424242;
        /* Background color of the triggers */
        --ts-widget-trigger-bg-color: #272727;
        /* Foreground color (font color and scrollbar color) */
        --ts-widget-fg-color: white;
        /* Font color of the switched states id */
        --ts-widget-oid-fg-color: #a5a5a5;
        /* Font color in buttons */
        --ts-widget-btn-fg-color: white;
        /* Font color of a disabled weekday */
        --ts-widget-weekdays-disabled-fg-color: red;
        /* Font color of an enabled weekday */
        --ts-widget-weekdays-enabled-fg-color: green;
        /* Font color of the name of the widget (defaults to --ts-widget-fg-color) */
        --ts-widget-name-fg-color: white;
        /* Font color of switched time (defaults to --ts-widget-fg-color) */
        --ts-widget-switched-time-fg-color: white;
        /* Font color of switched value (defaults to --ts-widget-fg-color)*/
        --ts-widget-switched-value-fg-color: white;
        /* Font color of the astro time (defaults to --ts-widget-fg-color) */
        --ts-widget-astro-time-fg-color: black;
        /* Font color of the astro time's shift */
        --ts-widget-astro-shift-fg-color: #5d5d5d;
        /* Font family used in the whole widget */
        --ts-widget-font-family: 'Roboto', 'Segoe UI', BlinkMacSystemFont, system-ui, -apple-system;
        /* Font size of the name of the widget */
        --ts-widget-name-font-size: 2em;
        /* Font size of the switched oid */
        --ts-widget-oid-font-size: 12px;
        /* Applies a filter to icons used in buttons (safe, edit, remove, cancel), for
           white use invert(1) and for black invert(0) */
        --ts-widget-img-btn-filter: invert(1);
        /* Add trigger dropdown background color */
        --ts-widget-add-trigger-dropdown-bg-color: #f1f1f1;
        /* Add trigger dropdown font color */
        --ts-widget-add-trigger-dropdown-fg-color: black;
        /* Add trigger dropdown hover background color */
        --ts-widget-add-trigger-dropdown-hover-bg-color: #ddd;
        /* ! Changing these may break the layout, change at your own risk */
        /* Font size of weekdays */
        --ts-widget-weekdays-font-size: 16px;
        /* Font size of switched value (on/off) */
        --ts-widget-switched-value-font-size: 2em;
        /* Font size of switched time */
        --ts-widget-switched-time-font-size: 2em;
        /* Font size of the astro time (e.g. Sunrise, ...) */
        --ts-widget-astro-time-font-size: 1.5em;
        /* Font size of the astro time's shift */
        --ts-widget-astro-shift-font-size: 1em;
    sigi234S Online
    sigi234S Online
    #273
    @Stephan-Schleich
    So, das Richtige!
    Stephan SchleichS 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @Stephan-Schleich
      So, das Richtige!
      Stephan SchleichS Offline
      Stephan Schleich
      #274
      @sigi234 Danke, hab's schon gefunden :)
      • walli545W walli545
        Aktuelle Test Version 2.0.0
        Veröffentlichungsdatum 14.05.2020
        Github Link https://github.com/walli545/ioBroker.time-switch
        Beschreibung des Adapters
        Der Adapter soll eine einfache Zeitschaltuhr für ioBroker bereitstellen. Diese ist über ein VIS-Widget konfigurierbar. Für jedes zu schaltende Gerät (aktuell nur z.B. Schaltsteckdosen, die an oder aus sein können) kann ein Schaltplan (schedule) angelegt werden. Für jeden Schaltplan sollte dann ein Widget in VIS angelegt werden, dort können dann beliebig viele Schaltaktionen (actions) erstellt und bearbeitet werden. Für jede Schaltaktion kann festgelegt werden, ob an/aus geschalten wird, zu welcher Uhrzeit und an welchem Wochentag.
        Die genaue Einrichtung ist in GitHub beschrieben (bis jetzt nur auf Englisch).
        Warum der Adapter?
        Der Hauptgrund für die Entwicklung war die Anschaffung von 8 Avatar WLAN Schaltsteckdosen, die mit Tasmota geflasht wurden und nun über MQTT angebunden sind. Diese wollte mein Vater (keine Programmierkenntnisse und hat sich bis jetzt auch noch nicht mit den ioBroker-Interna auseinandergesetzt) einfach über das Web Frontend in VIS programmieren, z.B. für die Weihnachtsbeleuchtung. Als ich dann auch den Thread unter https://github.com/ioBroker/AdapterRequests/issues/219 gesehen habe, habe ich mich an die Entwicklung gemacht.
        Versionen
        Eine stabile Version befindet sich auf dem master Branch und kann von https://github.com/walli545/ioBroker.time-switch/tree/master installiert werden.
        Bevor eine Version stabil wird, befindet sie sich im dev Branch und kann zum Testen von https://github.com/walli545/ioBroker.time-switch/tree/dev installiert werden.
        Bereits eingereichte Feature-Wünsche
        • Schalten von beliebigen Geräten, z.B. Rollos mit Prozentangabe
        • Bedingungen zusätzlich zur Zeit (Schalte, wenn Tür offen,. ..)
        • Schalten zu Astro-Zeiten (Sonnenaufgang, Sonnenuntergang, etc.)
        • Erstellen von Schalt-Gruppen (z.B. alle Rollos im Wohnzimmer)
        Wie und wann ich diese Features umsetze, kann ich aktuell noch nicht sagen, prinzipiell finde ich sie aber sinnvoll. Jedoch muss man schauen, wo man die Grenze zieht. Der Adapter soll ja eine simple Zeitschaltuhr und keine Javascript Alternative darstellen.
        Ich würde mich über Feedback eurerseits freuen.
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        #275
        @walli545
        Hallo Walli,
        ich habe Deinen Adapter istallier, aber wenn ich die Adaptereinstellungen öffne, kann ich zwar einen neuen Schaltplan hinzufügen, aber nicht editieren:
        Widget taucht in der Vis auf, aber ohne gültige ID geht er natürlich nicht.
        • qqolliQ qqolli
          @walli545
          Hallo Walli,
          Stephan Schleich
          #276
          @qqolli Das setzt du dann alles via Widget in der Vis
          qqolliQ 1 Antwort Letzte Antwort
            qqolliQ Offline
            qqolliQ Offline
            qqolli
            #277
            @Stephan-Schleich
            Hallo Stephan,
            wie soll das gehen? In der Anleitung steht, das das in den Adaptereinstellungen zu erfolgen hat, erst dann gibt es eine gültige ID; diese ist dann in der Vis einzutragen.
            In der Vis steht dann:
            • qqolliQ qqolli
              @Stephan-Schleich
              Hallo Stephan,
              Stephan Schleich
              #278
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                #279
                @Stephan-Schleich
                Das geht leider auch nicht:
                oder muss unter stateID[1] zwingend ein alias angegeben werden?
                • qqolliQ qqolli
                  @Stephan-Schleich
                  sigi234S Online
                  sigi234S Online
                  #280
                  @qqolli
                  Welche Version vom Adapter?
                  • sigi234S sigi234
                    @qqolli
                    qqolliQ Offline
                    qqolliQ Offline
                    qqolli
                    #281
                    @sigi234
                    Hallo Sigi,
                    es ist die v.2.1.0
                    • qqolliQ qqolli
                      @sigi234
                      Hallo Sigi,
                      es ist die v.2.1.0
                      Stephan Schleich
                      #282
                      @qqolli Lösch mal den Eintrag in der Instanz und legs neu an, wenn man manuell im Objekt was rummodelt spinnt es machmal hatte ich schon mal, konnte via Widget nix mehr editieren
                        qqolliQ Offline
                        qqolliQ Offline
                        qqolli
                        #283
                        @Stephan-Schleich
                        Das bringt leider rein gar nichts.
                        Wenn ich den Adapter neu starte bekomme ich im Log die folgende Ausgabe:
                        time-switch.0	2020-09-18 19:45:01.652	info	2
                        time-switch.0	2020-09-18 19:45:01.652	info	(27697) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.time-switch, node: v12.18.4, js-controller: 3.1.6
                        time-switch.0	2020-09-18 19:44:58.012	warn	(26761) Got terminate signal. Checking desired PID: 27697 vs own PID 26761
                        time-switch.0	2020-09-18 19:44:58.005	info	(26761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        time-switch.0	2020-09-18 19:44:58.003	info	(26761) terminating
                        time-switch.0	2020-09-18 19:44:58.002	info	(26761) cleaned everything up...
                        time-switch.0	2020-09-18 19:44:57.997	warn	(26761) Got terminate signal. Checking desired PID: 0 vs own PID 26761
                        • qqolliQ qqolli
                          @Stephan-Schleich
                          Stephan Schleich
                          #284
                          @qqolli Kein Plan dann.
                          @walli545 Die Standard Größe muss größer werden Astro wird am Anfang verdeckt
                          Stephan SchleichS qqolliQ 2 Antworten Letzte Antwort
                            Stephan Schleich
                            #285
                            @walli545 Gäbe es auch eine Möglichkeit die Automatik mit einer Anwesenheitsprüfung zu kombinieren?
                              qqolliQ Offline
                              qqolliQ Offline
                              qqolli
                              #286
                              @Stephan-Schleich
                              Kein Problem, hab ihn am Ende doch noch zum laufen gebracht :-)
                              • A AndreasW63
                                ich bin neuer Anwender des ioBroker.
                                Bisher bin ich mit der Konfiguration bzw. Einrichtung ganz gut vorangekommen.
                                Zunächst ein großes Lob an die Tester und Entwickler des Time-Switch.
                                Der Time-Switch ist eine Anwendung nach meinem Geschmack.
                                Das die Einbindung in das System vielleicht noch etwas hakelig ist, stört mich bei dem jungen Produkt nicht.
                                Allerdings habe ich mit dem Handling ein Problem bei dem ich nicht so recht weiter komme.
                                Die ersten "Schaltuhren" habe ich zum Testen auf einer separaten Seite meiner ioBroker Seite erstellt.
                                Rufe ich die Seite direkt aus dem Vis Editor auf, werden die Einträge korrekt dargestellt.
                                Rufe ich die Seite über die SliderTabs auf sieht es aus wie folgt:
                                Wo kann ich ansetzen ?
                                Gruß Andreas
                                Raspberry 4 4GB RAM
                                PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                NAME="Raspbian GNU/Linux"
                                VERSION_ID="10"
                                VERSION="10 (buster)"
                                Node.js v12.18.3
                                NPM 6.14.6
                                Admin 4.0.10
                                WEB Server 3.0.12
                                Visualisation 1.2.11
                                walli545W Offline
                                walli545W Offline
                                walli545
                                schrieb am zuletzt editiert von walli545
                                #287
                                @AndreasW63 Hallo, gibt es Fehlermeldungen in der Browserconsole (F12)? Bzw. im Adapterlog (im Admin)?
                                @qqolli Evtl. könntest du kurz beschreiben was das Problem war bzw. was du gemacht hast falls andere ebenfalls darauf stoßen
                                @Stephan-Schleich ich habe bereits das Backend für ein Feature implementiert, mit dem man zusätzlich einen State angeben kann, der vor dem auslösen geprüft wird und nur wenn dieser true ist, wird auch geschalten. Meinst du soetwas?
                                @all Sorry für meine späte Rückmeldung, aber ich komme aktuell beruflich/privat nicht viel dazu etwas zu machen deswegen habe ich auch in letzter Zeit nicht weiterentwickelt. Falls ich wieder mal Zeit habe melde ich mich hier😬
                                  Stephan Schleich
                                  #288
                                  @walli545 Perfekt, genau das meinte ich. Top 👍🏻
                                    michihorn
                                    schrieb am zuletzt editiert von michihorn
                                    #289
                                    Hallöchen sieht super aus der Adapter, kann man evtl. auchnoch irgendwie die Beschreibung des Datenpunktes ausblenden?
                                    Michael
                                    EDIT: Habs gefunden
                                      qqolliQ Offline
                                      qqolliQ Offline
                                      qqolli
                                      #290
                                      @walli545
                                      Sorry, da hast Du natürlich recht. Bei mir war es schlicht und einfach ein Leerzeichen zu viel am Ende. Hatte die ID vom Adapter kopiert und dabei ist das zusätzliche Leerzeichen am Ende reingekommen. Nachdem ich es entfernt hatte war alles gut :-)
                                      Noch eine Frage, kann man das Widget "skalieren", da es doch recht groß ist. Wenn ich es verkleinere werden viele Teile verdeckt, die man dan mittels Scrollbalken wieder sichtbar machen kann. Meine aktuelle Version ist die v.2.1.0.
                                      walli545W 1 Antwort Letzte Antwort
                                        AndreasW63
                                        schrieb am zuletzt editiert von AndreasW63
                                        #291
                                        mittlerweile habe ich mehrere Schaltuhren mit dem Adapter "time-switch" erstellt.
                                        Die Schaltuhren funktionieren mit den eingestellten Schaltzeiten ganz prima.
                                        Gerne würde ich die Uhren auch mit den Parametern "Sonnenaufgang" bzw. "Sonnenuntergang" steuern.
                                        Bisher kommen ich da nicht weiter. In den Einstellungen des Javascript Adapters habe ich unter den Astro-Einstellungen Wert mit der Bezeichnung "Sonnenaufgang" bzw. "-untergang" gefunden. Diese werden vom Adapter "time-switch" vermutlich ignoriert oder nicht ausgewertet.
                                        Wie komme ich hier weiter.
                                        Gruß Andreas
                                        • H Offline
                                          Harry94
                                          schrieb am zuletzt editiert von Harry94
                                          #292
                                          Abend allerseits,
                                          danke erstmal für die viele Mühe in dem Adapter.
                                          Habe den adapter direkt über GitHub installiert (aktuell 2.1.0)
                                          kann allerdings keinen neuen Zeitplan erstellen.
                                          Hier der Fehler aus der Browerkonsole (EDGE)
                                          index_m.html?0:89 Uncaught TypeError: Cannot read property 'onOff' of undefined
                                              at getNextOnOffScheduleId (index_m.html?0:89)
                                              at HTMLAnchorElement.<anonymous> (index_m.html?0:27)
                                              at HTMLAnchorElement.dispatch (jquery-3.2.1.min.js:3)
                                              at HTMLAnchorElement.q.handle (jquery-3.2.1.min.js:3)
                                          hier die Konsole aus Firefox
                                          ncaught TypeError: schedules is undefined
                                              getNextOnOffScheduleId https://192.168.xxx.xxx:xxxxx/adapter/time-switch/index_m.html?0:89
                                              load https://192.168.xxx.xxx:xxxxx/adapter/time-switch/index_m.html?0:27
                                              jQuery 2
                                                  dispatch
                                                  handle
                                          index_m.html:89:17
                                              jQuery 2
                                                  dispatch
                                                  handle
                                          hoffe ich kann damit irgendwie helfen.
                                          Lg
