7.6k Beiträge 296 Kommentatoren 8.9m Aufrufe 201 Beobachtet
  • s.bormannS s.bormann
    @MarkoFFM sagte in Test Adapter iQontrol 1.2.x:
    ich war jetzt schon länger nicht mehr im iobroker unterwegs und wollte soeben die Adapter updaten. Aktuell wird mir der iQontrol Adapter in Version 1.0.0 als installiert angezeigt mit einem verfügbaren Update auf 1.1.5.
    Update-Log:
    $ ./iobroker upgrade iqontrol
    Update iqontrol from @1.0.0 to @1.1.5
    NPM version: 6.11.3
    npm install iobroker.iqontrol@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR!
    stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-09-10T15_25_37_625Z-debug.log
    upload [20] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/img/materialize-colorpicker/alpha.png materialize-colorpicker/img/materialize-colorpicker/alpha.png image/png
    upload [19] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/img/materialize-colorpicker/alpha-horizontal.png materialize-colorpicker/img/materialize-colorpicker/alpha-horizontal.png image/png
    upload [18] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/css/materialize-colorpicker.min.css materialize-colorpicker/css/materialize-colorpicker.min.css text/css
    upload [17] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/css/materialize-colorpicker.css materialize-colorpicker/css/materialize-colorpicker.css text/css
    upload [16] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/jQueryIcons.jpg jQueryIcons.jpg image/jpeg
    upload [15] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/iqontrol.png iqontrol.png image/png
    upload [14] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/index_m.js index_m.js application/javascript
    upload [13] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/index_m.html index_m.html text/html
    upload [12] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/img/info-big.png img/info-big.png image/png
    upload [11] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_verdana.png fonts/font_verdana.png image/png
    upload [10] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_trebuchet.png fonts/font_trebuchet.png image/png
    upload [9] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_times.png fonts/font_times.png image/png
    upload [8] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_impact.png fonts/font_impact.png image/png
    upload [500] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/userimages/usericons/inbuilt/panic_on.png userimages/usericons/inbuilt/panic_on.png image/png
    upload [7] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_georgia.png fonts/font_georgia.png image/png
    upload [6] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_garamond.png fonts/font_garamond.png image/png
    upload [5] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_courier.png fonts/font_courier.png image/png
    upload [4] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_comic.png fonts/font_comic.png image/png
    upload [3] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_arial.png fonts/font_arial.png image/png
    upload [2] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/custom_m.html custom_m.html text/html
    upload [1] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/conn.js conn.js application/javascript
    upload [0] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/admin.d.ts admin.d.ts video/mp2t
    upload [450] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/userimages/usericons/inbuilt/button.png userimages/usericons/inbuilt/button.png image/png
    upload [400] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-svg/tag-white.svg jquery/images/icons-svg/tag-white.svg image/svg+xml
    upload [350] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-svg/cloud-white.svg jquery/images/icons-svg/cloud-white.svg image/svg+xml
    upload [300] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-png/tag-white.png jquery/images/icons-png/tag-white.png image/png
    upload [250] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-png/cloud-white.png jquery/images/icons-png/cloud-white.png image/png
    upload [200] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/index.html index.html text/html
    upload [150] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/window_toplight_closed.png images/icons/window_toplight_closed.png image/png
    upload [100] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/kitchenhood_on.png images/icons/kitchenhood_on.png image/png
    upload [90] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/indicator_grey.png images/icons/indicator_grey.png image/png
    upload [80] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/garagedoor_opened.png images/icons/garagedoor_opened.png image/png
    upload [70] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/fire_off.png images/icons/fire_off.png image/png
    upload [60] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/camera_ptz_on.png images/icons/camera_ptz_on.png image/png
    upload [50] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/blind_closed.png images/icons/blind_closed.png image/png
    upload [40] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/battery_50.png images/icons/battery_50.png image/png
    upload [30] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/hue.png images/hue.png image/png
    upload [20] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/config.png images/config.png image/png
    upload [19] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/colortemperature.png images/colortemperature.png image/png
    upload [18] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/color.png images/color.png image/png
    upload [17] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/brightness.png images/brightness.png image/png
    upload [16] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/battery.png images/battery.png image/png
    upload [15] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/background.png images/background.png image/png
    upload [14] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [13] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [12] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [11] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [10] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [9] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/es/translations.json i18n/es/translations.json application/json
    upload [6] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/en/translations.json i18n/en/translations.json application/json
    upload [5] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/de/translations.json i18n/de/translations.json application/json
    upload [4] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon_big.png favicon_big.png image/png
    upload [3] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon.png favicon.png image/png
    upload [2] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [1] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/conn.js conn.js application/javascript
    upload [0] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/cache.manifest cache.manifest text/cache-manifest
    Update "system.adapter.iqontrol.0"
    Adapter "iqontrol" updated
    process exited with code 0
    Jedoch scheint das Update nicht wirklich zu funktionieren. Auch nach dem Update steht dort als installierte Version 1.0.0.
    Was kann ich tun? Vielen Dank für Eure Unterstützung.
    Versuch mal den Install-Fixer drüber laufen zu lassen. Ich meine mich zu erinnern, dass gyp-Probleme mit Schreibrechten zu tun hatte...
    https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
    Befehl:
    curl -sL https://iobroker.net/fix.sh | bash -
    M
    M
    MarkoFFM
    #2906
    @s-bormann said in Test Adapter iQontrol 1.2.x:
    Hallo s.bormann,
    vielen Dank. Nach dem Fix scheint es geklappt zu haben. Nun wird die 1.1.5 als installiert angezeigt. Wie kriege ich die neuen Versionen installiert? Aktuell ist ja v1.2.3.
    Toll, wie hier das ganze supportet wird, weiter so!
    • B blackeagle998
      @CrazyFloyd
      Zum Thema wechselnde Wetter-Symbole:
      In der iQontrol Instanz gehst du auf Bilder und erstellst im Ordner /usericons einen neuen Ordner, meiner heißt "wetter".
      Dort lädst du die Wettersymbole aus folgender .zip Datei hoch:
      Wettersymbole.zip
      Das sollte dann so aussehen:
      Danach erstellst du eine Kachel (meine sind vom Typ Wert, Temperatursensor geht auch) und gibst im Feld ICON folgendes ein:
      ./../iqontrol.meta/userimages/usericons/wetter/1.png|./../iqontrol.meta/userimages/usericons/wetter/{daswetter.0.NextHours.Location_1.Day_1.symbol_value}.png
      kurze Erklärung:
      Wenn die Seite geladen wird, nimmt er erstmal als ICON die Bilddatei
      "./../iqontrol.meta/userimages/usericons/wetter/1.png".
      Danach zieht er sich vom Server die Bilddatei "./../iqontrol.meta/userimages/usericons/wetter/{daswetter.0.NextHours.Location_1.Day_1.symbol_value}.png", wobei {daswetter.0.NextHours.Location_1.Day_1.symbol_value} der Wert des Datenpunktes ist. Da sich dieser ändern kann, ändert sich dann auch das gezogene PNG file und somit hat man dynamische ICONs.
      Achtung:
      Wenn dein ICON-Ordner nicht "wetter" heißt, musst du das natürlich beim ICON Link anpassen.
      C
      C
      CrazyFloyd
      #2907
      @blackeagle998 sagte in Test Adapter iQontrol 1.2.x:
      @CrazyFloyd
      Wettersymbole.zip
      kurze Erklärung:
      Achtung:
      Danke dir herzlichst. Was alles so geht. Mann lernt nie aus.
      • C CrazyFloyd
        @CrazyFloyd
        Wettersymbole.zip
        kurze Erklärung:
        Achtung:
        B
        B
        biker1602
        #2908
        @CrazyFloyd said in Test Adapter iQontrol 1.2.x:
        Ich finde das interessant und würde das auch gerne versuchen aber ich finde wenn ich die Kachel als Wert erstelle nicht den Ordner ICON wo man das einfügen soll. Die Wettersymbole habe ich alle importiert.
        B 2 Antworten Letzte Antwort
        • B blackeagle998
          @CrazyFloyd
          Wettersymbole.zip
          kurze Erklärung:
          Achtung:
          V
          V
          verkel
          #2909
          Super gut erklärt. Danke das hab ich auch mal sofort umgesetzt. Da kann man ja fast ein Wiki machen😊 👍
          • B biker1602
            B
            B
            blackeagle998
            #2910
            @biker1602
            Du kannst doch bei jeder Kachel ein Icon auswählen, bei manchen Kacheln sogar zwei Icons je für aktiv und inaktiv.
            Und genau da kopierst du den Text von mir rein.
            Einen Ordner gibt es nur da, wo du die Bilder hochladen musst.
            Ist das so etwas verständlicher?
            • B biker1602
              B
              B
              blackeagle998
              #2911
              @biker1602
              Schau mal hier (in den Einstellungen der Kachel):
              • B
                B
                blackeagle998
                #2912
                @s-bormann
                Gibt es eine Möglichkeit hinter einer Kachel einen Zeilenumbruch festzulegen ohne eine Unterüberschrift verwenden zu müssen?
                • B blackeagle998
                  @CrazyFloyd
                  Wettersymbole.zip
                  kurze Erklärung:
                  Achtung:
                  M
                  M
                  martinschm
                  schrieb am zuletzt editiert von martinschm
                  #2913
                  @blackeagle998 said in Test Adapter iQontrol 1.2.x:
                  @CrazyFloyd
                  Wettersymbole.zip
                  kurze Erklärung:
                  Achtung:
                  danke für die Anleitung. Ich hab es so gemacht und die Infos werden auch richtig angezeigt. Ich suche nur irgendwie den Wert für die aktuelle Temperatur. Mir wird der maxvalue und der minvalue angezeigt, aber wo finde ich den aktuellen Wert?
                  Ich habe übrigens einen anderen Pfad zum Icon genommen, das der Pfad oben bei mir nicht funktioniert:
                  ./../iqontrol.meta/userimages/usericons/wetter/1.png|./../iqontrol.meta/userimages/usericons/wetter/{daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value}.png
                  Liegt evtl dran welches XML man einbindet.
                  @blackeagle998 : Wie hast du die Beschriftung der Kachel dynamisch gemacht? Also das da immer das entsprechende Datum steht?
                  ciao
                  Martin
                  K B 2 Antworten Letzte Antwort
                  • V
                    V
                    Vod
                    #2914
                    Wer "Weitere Informationen" gleich aufgeklappt haben möchte:
                    der sucht in
                    /opt/iobroker/node_modules/iobroker.iqontrol/www/index.js
                    /opt/iobroker/iobroker-data/files/iqontrol/index.js
                    (weiß nicht genau wo, habe beide geändert) nach <div id='DialogAdditionalInfosContent'>
                    2 Zeilen drüber muss div Parameter um fett hervorgehobenen Text ergänzt werden:
                    dialogContent += "<div data-role='collapsible' class='collapsibleAnimated' data-iconpos='right' data-inset='true' data-collapsed='false' >";
                    Dann muss iobroker restart ausgeführt werden (Instanzen IQontrol & web.0 neuzustarten hat nichts gebracht).
                    Bestimmt kann jemand meine Lösung verbessern:)
                    @s-bormann vllt. als Feature?
                    • V Vod
                      der sucht in
                      D
                      D
                      DragonDope
                      #2915
                      @Vod said in Test Adapter iQontrol 1.2.x:
                      der sucht in
                      Super!
                      Genau das habe ich mir immer gewünscht. Vielleicht wäre es möglich das als Option für die Geräte hinzuzufügen?
                        @CrazyFloyd sagte in Test Adapter iQontrol 1.2.x:
                        @s-bormann sagte in Test Adapter iQontrol 1.2.x:
                        Guten Morgen, ich habe einmal einen großen Wunsch. Besteht die Möglichkeit im Heizungs Thermostat Modul einen Punkt zu implementieren womit das Thermostat wieder in den Auto Modus gebracht werden kann nachdem die Temperatur vorher manuell geändert wurde. Bei meinen Tado Thermostaten benötige ich einfach einen kurzen True Impuls für den Datenpunkt "Clear Overlay". Ansonsten besten Dank für die hervorragende Arbeit. Macht immer noch richtig Spass das Modul zu nutzen.
                        Unter CONTOL_MODE kann man einen Datenpunkt angeben, den man mit dem Schraubenschlüssel weiter konfigurieren kann. Hier kann man eine VALUE-List anlegen, die die verschiedenen Betriebsmodi enthält. Man kann dann über die TARGET_VALUE_LIST verschiedene Ziel-Datenpunkte angeben, auf die der Befehl ggf. weitergeleitet werden soll. Damit denke ich, es sollte gehen... Schau mal hier:
                        https://github.com/sbormann/ioBroker.iqontrol#modifying-datapoint-configuration
                        Wenn Du es hinbekommen hast, poste mal bitte (am besten mit Screenshot), wie es genau für Tado geht, dann können wir das in das WIKI für andere Benutzer stellen:
                        https://github.com/sbormann/ioBroker.iqontrol/wiki
                        Bin schon am basteln und es ganz gut hinbekommen. Mir ist dabei was aufgefallen. Wenn ich den Haken "Add option to enter free text" weg nehme wird meine angelegte Value List nicht mehr angezeigt.
                        eine ValueList wird angezeigt, wenn eine ValueList definiert wurde und
                        • bei type numbers exakt so viele Einträge in der ValueList enthalten sind, wie zwischen min und max des Datenpunktes liegen oder
                        • bei type boolean, der nicht die Rolle "switch" hat oder
                        • bei type string oder
                        • wenn "Add option to enter free text" aktiviert ist
                        C
                        C
                        CrazyFloyd
                        #2916
                        Ich habs jetzt verstanden. Danke dir.
                        • C CrazyFloyd
                          s.bormannS
                          s.bormannS
                          s.bormann
                          #2917
                          Musste auch wieder nachlesen, wie das genau ist. Habe es jetzt mal der readme hinzugefügt. VG
                          • D DragonDope
                            der sucht in
                            Super!
                            s.bormannS
                            s.bormannS
                            s.bormann
                            #2918
                            @DragonDope sagte in Test Adapter iQontrol 1.2.x:
                            der sucht in
                            Super!
                            Ich schreib es mir auf und setzte mich demnächst dran. VG!
                            • V verkel
                              s.bormannS
                              s.bormannS
                              s.bormann
                              #2919
                              @verkel sagte in Test Adapter iQontrol 1.2.x:
                              Gerne, das wiki ist offen für jeden:
                              • M MarkoFFM
                                Hallo s.bormann,
                                s.bormannS
                                s.bormannS
                                s.bormann
                                #2920
                                Hallo s.bormann,
                                Hi, cool, dass das geklappt hat.
                                1.1.5 ist stable. Wenn man auch Betaversionen installieren möchte, dann muss man in den ioBroker-Einstellungen den Verwahr-Ort auf "latest" stellen.
                                Alternativ kannst Du iQontrol auch über das Github (= Katzen)-Symbol updaten lassen (dazu muss man glaube ich die Experteneinstellungen aktivieren - und nach dem Install noch ein Upload machen - wie, steht in der Troubleshooting-Sektion der iQontrol-Readme).
                                VG!
                                • V vepman
                                  Gibt es eine Möglichkeit eine Geräte-Kachel direkt aufzurufen?
                                  Bei den Views habe ich das mit Hilfe der simple-api hingekriegt.
                                  Aber die geniale Fernbedienung hätte ich gerne als Verknüpfung auf dem Homescreen.
                                  s.bormannS
                                  s.bormannS
                                  s.bormann
                                  #2921
                                  @vepman sagte in Test Adapter iQontrol 1.2.x:
                                  Versuch mal die aktuelle github-Version, da kann man das machen:
                                  URL-Parameters
                                  • The frontend is called via http[s]://<url or ip of iobroker>:<port of web adapter>/iqontrol/index.html
                                    • <port of web adapter> is usually 8082
                                  • To open a specified instance you can add namespace=iqontrol.<instance-number> as URL-parameter
                                  • To open a specified view as homepage you can add home=<viewID> as URL-parameter
                                    • <viewID> needs to be formated like iqontrol.<insctance-number>.Views.<view-name>
                                    • Note: this is case-sensitive!
                                  • To open a specified dialog on loading the page you can add openDialog=<deviceID> as URL-parameter
                                    • <deviceID> needs to formated like iqontrol.<insctance-number>.Views.<view-name>.devices.<device-number> where <device-number> starts from 0 (so the first device on a view has device-number 0)
                                  • To set or override return after time settings, use the following parameters:
                                    • returnAfterTimeTreshold=<time in seconds> to set the time, after wich the destination view is called. Use 0 to disable return after time feature.
                                    • returnAfterTimeDestiationView=<viewID> to set the view, wich is called after the treshold. If not specified, the home view will be used.
                                    • These options are helpful, if you call iQontrol from an wall mounted tablet, wich should automatically return to home-view after beeing used
                                  Example:
                                  • https://192.168.1.1:8082/iqontrol/index.html?namespace=iqontrol.1&home=iqontrol.1.Views.Living-Room
                                    • Note upper and lower case
                                  V 1 Antwort Letzte Antwort
                                  • B blackeagle998
                                    @s-bormann
                                    Ja, die Versionen sind aktuell:
                                    iQontrol: 1.2.3
                                    Sonos: 2.1.0
                                    Das Cover ist auch definitiv an der URL hinterlegt, sonst würde er es beim Reload der iQontrol Seite nicht anzeigen.
                                    Die genannten Felder ändern sich, sobald ich ein neues Album abspiele.
                                    Auszug aus der Entwicklerkonsole:
                                    index.js:3705 Return after time - timer started (treshold: 300s, destinationView: )
                                    index.js:6179 CLICK
                                    index.js:2624 Button 0_userdata.0.Sonos.Play.Album.Kinder.Vaiana --> 1
                                    index.js:2221 >>>>>> setState 0_userdata.0.Sonos.Play.Album.Kinder.Vaiana: true --> 1
                                    index.js:2250        converted state to boolean. New value is: true
                                    index.js:3889 Find active Toolbar Index
                                    index.js:1643 deliverState done
                                    index.js:2439 >> ack: false val: true newVal: true
                                    index.js:5998 Add timestamp to Player with value <b>Disney - Die Eiskönigin</b> - Die Eiskönigin - Völlig Unverfroren (Das Original-Hörspiel zum Film) - <i>Kapitel 01: Die Eiskönigin</i>
                                    index.js:5936 ["active"]
                                    index.js:5954 Shuffle! resizeObserver 100
                                    index.js:5958 Shuffle! resizeObserver 1250
                                    index.js:5998 Add timestamp to Player with value <i>Kapitel 01: Vaiana</i>
                                    index.js:5998 Add timestamp to Player with value Vaiana (Das Original-Hörspiel zum Film) - <i>Kapitel 01: Vaiana</i>
                                    2index.js:5998 Add timestamp to Player with value <b>Disney - Vaiana</b> - Vaiana (Das Original-Hörspiel zum Film) - <i>Kapitel 01: Vaiana</i>
                                    3index.js:5998 Add timestamp to Player with value <b>Disney - Vaiana</b> - Vaiana (Das Original-Hörspiel zum Film) - <i>Kapitel 01: Vaiana</i>
                                    index.js:2317 << preventUpdate dexpired.
                                    index.js:6154 Starting marquee
                                    Wenn ich sonst noch was liefern kann, lass es mich wissen :-)
                                    s.bormannS
                                    s.bormannS
                                    s.bormann
                                    #2922
                                    @s-bormann
                                    iQontrol: 1.2.3
                                    Sonos: 2.1.0
                                    index.js:6179 CLICK
                                    Probiers mal bitte mit der aktuellen Github-Version.
                                      URL-Parameters
                                      Example:
                                      V
                                      V
                                      vepman
                                      #2923
                                      @s-bormann
                                      Erstmal Danke für deinen tollen Einsatz.
                                      Leider geht es mit devices bei mir nicht.
                                      Als Beispiel habe ich die Wohnzimmer Deckenlampe, welche das 1. Device in Licht ist, genommen:
                                      http://192.168.0.2:8082/iqontrol/index.html?namespace=iqontrol.0&home=iqontrol.0.Views.Licht.devices.0
                                      klappt nicht.
                                      Der Aufruf des Views geht:
                                      • V vepman
                                        @s-bormann
                                        klappt nicht.
                                        s.bormannS
                                        s.bormannS
                                        s.bormann
                                        #2924
                                        @vepman nimm nicht home=, sondern openDialog
                                          V
                                          V
                                          vepman
                                          schrieb am zuletzt editiert von vepman
                                          #2925
                                          @s-bormann
                                          Jau, geht teilweise.
                                          Pad und Zahlen sind nicht da.
                                          So per URL-Aufruf:
                                          So über die Kachel:
                                          84.3k
