  4. Fritzbox tr064 Anruferbild
48 Beiträge 5 Kommentatoren 9.6k Aufrufe 5 Beobachtet
  • F fastfoot
    @D3ltoroxp sagte in Fritzbox tr064 Anruferbild:
    Das kommt beim Import.
    Falsch kopiert? Hier noch einmal als Bild und der Export dazu
    <variables>
    <variable type="timeout" id="timeout">timeout</variable>
    <variable id="PO_Er88JZ#r/k,)=|+W">Anrufername</variable>
    <variable id="$Y-WWBt%3A}x?lw-o?wN">Anrufernummer</variable>
    <variable id="ykk,z6|+S8DSC#.T=Yt.">command</variable>
    </variables>
    <block type="on" id="l1O_GvAVwV6Qa}gi5ol" inline="true" x="-38" y="-163">
    <field name="OID">tr-064.0.callmonitor.ringing</field>
    <statement name="STATEMENT">
    <block type="controls_if" id="~b:DDcG3WDH)ZhNRkjoE">
    <value name="IF0">
    <block type="on_source" id="ZsKxF5kZJ9eIM}nyZ5Eb">
    </block>
    </value>
    <statement name="DO0">
    <block type="timeouts_cleartimeout" id="+c|9MczfFy!kVD{$~;)N">
    <next>
    <block type="timeouts_settimeout" id="nPTA6UZZKD5#k9JWu;JA">
    <field name="DELAY">1500</field>
    <field name="UNIT">ms</field>
    <block type="variables_set" id="lM;E-f8bHJp}:WpzIa9F">
    <field name="VAR" id="PO_Er88JZ#r/k,)=|+W">Anrufername</field>
    <value name="VALUE">
    <block type="get_value" id="U7z3Ah4ti3oCeOIb4[;">
    <field name="OID">tr-064.0.callmonitor.inbound.callerName</field>
    </block>
    </value>
    <next>
    <block type="variables_set" id="t.MD}IVnzqTV]-04sv7O">
    <field name="VAR" id="$Y-WWBt%3A}x?lw-o?wN">Anrufernummer</field>
    <block type="get_value" id="QKdp!]RDa[E[o%S_PcE">
    <field name="OID">tr-064.0.callmonitor.inbound.caller</field>
    </block>
    </value>
    <next>
    <block type="variables_set" id="YDG3(!0co^3h=3wxgAFT">
    <field name="VAR" id="ykk,z6|+S8DSC#.T=Yt.">command</field>
    <block type="text_join" id="[E2/PI?5IHk~ge65q_B," inline="false">
    <value name="ADD0">
    <block type="text" id="u6}klLH4o-JN_}_svYu7">
    <field name="TEXT">curl -sL "</field>
    </block>
    </value>
    <value name="ADD1">
    <block type="get_attr" id="|3Z(StsoECt+6yWZ2oa"> <value name="PATH"> <shadow type="text" id="v:5n6{_[Ltw(uw}Kj-gy"> <field name="TEXT">imageurlcaller</field> </shadow> </value> <value name="OBJECT"> <block type="get_value" id="Lzx6|^ZFk#)/C63VR|"> <field name="ATTR">val</field> <field name="OID">tr-064.0.callmonitor.inbound.json</field> </block> </value> </block> </value> <value name="ADD2"> <block type="text" id="rIZ?85/JEHobWZ}A?lcz"> <field name="TEXT">" &gt;img.jpg</field> </block> </value> </block> </value> <next> <block type="controls_if" id="CW^Rdf96BFFOPxb@p5Wa"> <value name="IF0"> <block type="logic_compare" id="]1ZYuOh~doV(;}@ynR"> <field name="OP">GT</field> <value name="A"> <block type="text_length" id="vKua*^#|TX_/7x0Q;=]O"> <value name="VALUE"> <shadow type="text" id="R8H[}jNQN99UicM?b43Z"> <field name="TEXT">abc</field> </shadow> <block type="variables_get" id="=,.4OQX#)pEpM3!IXl4+"> <field name="VAR" id="ykk,z6|+S8DSC#.T=Yt.">command</field> </block> </value> </block> </value> <value name="B"> <block type="math_number" id="10m1%8r-0JX2[Uu4vcGh"> <field name="NUM">100</field> </block> </value> </block> </value> <statement name="DO0"> <block type="exec" id="6VteYu;VN*S}N*XO]8AH" inline="true"> <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation> <field name="WITH_STATEMENT">TRUE</field> <field name="LOG"></field> <value name="COMMAND"> <shadow type="text" id="k:5tbr),O~0E[#k0qV
    <field name="TEXT"></field>
    </shadow>
    <block type="variables_get" id="^+:Wv].HZz9}TCmAPJ!y">
    </block>
    </value>
    <block type="sendto_custom" id=":JZCN2W-jDA}?YJE#E~d">
    <mutation xmlns="http://www.w3.org/1999/xhtml" items="text,caption,user,parse_mode" with_statement="false"></mutation>
    <field name="INSTANCE">telegram.0</field>
    <field name="COMMAND">send</field>
    <field name="WITH_STATEMENT">FALSE</field>
    <value name="ARG0">
    <shadow type="text" id="2UgH29(w#w0P-WjVLff,">
    </shadow>
    <block type="text" id="S6}KDco%EUdN^M,E!pG:">
    <field name="TEXT">img.jpg</field>
    </block>
    </value>
    <value name="ARG1">
    <shadow type="text" id="2[jnAhD+%80?z]t~Weq8">
    </shadow>
    <block type="text_join" id="Bjmro
    /-P=bq9X;41_">
    <value name="ADD0">
    <block type="text" id="wHFLh2T;(kx$L=^Vv|pj">
    <field name="TEXT">Anruf von </field>
    </block>
    </value>
    <value name="ADD1">
    <block type="variables_get" id="g.///^qK@vgkx.)$Z*$p">
    </block>
    </value>
    <value name="ADD2">
    <block type="variables_get" id=".0trD(7la{G]VTza=Jp">
    </block>
    </value>
    </block>
    </value>
    <value name="ARG2">
    <shadow type="text" id=")eQ8~}i)x@Z:a*]]@feI">
    </shadow>
    </value>
    <value name="ARG3">
    <shadow type="text" id="IZAc=s.1%tc;R#|T=kbX">
    </shadow>
    <block type="text" id="aiwoow2#6|mRI0#8GuR7">
    <field name="TEXT">HTML</field>
    </block>
    </value>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </statement>
    <statement name="ELSE">
    <block type="timeouts_cleartimeout" id="h[ZC?AVy%P|fAj(0C~`I">
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </xml>
    MCU
    @fastfoot Muss mal kurz nachfragen, nutzt du einen besonderen User für die FritzBox? pi, iobroker?
    Ich habe es mal umgesetzt, bekomme aber immer die xml-Datei mit keine Berechtigung!
    Welche Version hat der telegram-Adapter?
    Vielen Dank.
    D3ltoroxpD F 2 Antworten Letzte Antwort
    • M MCU
      Vielen Dank.
      D3ltoroxpD Offline
      D3ltoroxpD Offline
      D3ltoroxp
      @MCU said in Fritzbox tr064 Anruferbild:
      Vielen Dank.
      Das muss ich auch Fragen, da das Script ja die gleiche URL holt, die schon im DP steht und diese eben bei mir auch nicht geht, wie bei @MCU
      Keine Berechtigung, denke ich. Ich habe aber auf der FritzBox nen eigenen Nutzer angelegt für iobroker. Auch der tr hat meines Wissens nen eigenen User. Beide sollten aber Zugriff auf den Speicher haben.
      curl -sL "http://192.168.178.1:49000/download.lua?path=/var/InternerSpeicher/FRITZ/fonpix/1571935862-0.jpg&sid=xxxxxxxxxx&pbid=0" >img.jpg
      Wenn das nicht klappt nehme ich @MCU Vorschlag und lade alle Bilder auf den NUC, diese Werden dann per Script sichtbar oder nicht sichtbar gemacht. Ich versuche das mit Image 8 Widget. Und per Script dann den Namen eine Zahl zuweisen, dann sollte das klappen.
      Ausser man kommt irgendwie direkt ans Bild.
      • D3ltoroxpD D3ltoroxp
        Vielen Dank.
        MCU
        @D3ltoroxp Bei mir funktioniert es nicht wegen der Google-Berechtigung. Ich versuche noch mit dem schönem BLOCKLY von @fastfoot das Bild von Google zu bekommen.
        @fastfoot Ist das BLOCKLY auch im Einsatz für Google-Kontakte oder nur für lokale Kontakte (FritzBox) ?
        • D3ltoroxpD Offline
          D3ltoroxpD Offline
          D3ltoroxp
          Schade, im TR Adapter gibt es ja sogar nen DP
          tr-064.0.callmonitor.inbound.id
          Leider steht dort immer 0. Kann man hier irgendwo in der FritzBox den Kontakten eine ID geben ?
            MCU
            @D3ltoroxp Steht evtl. bei dir im tr-064.0.phonebook.image etwas, wenn angerufen wird?
            • M MCU
              bahnuhrB Offline
              bahnuhrB Offline
              bahnuhr
              @MCU sagte in Fritzbox tr064 Anruferbild:
              Für Google musst du o.g. Adapter nehmen.
              (vgl. meine Anmerkung oben).
              Dafür geht das Script nicht.
              Danke.
              • bahnuhrB bahnuhr
                MCU
                @bahnuhr Adapter "Kontakte" habe ich gefunden. Danke.
                • M MCU
                  bahnuhrB Offline
                  bahnuhrB Offline
                  bahnuhr
                  du brauchst diesen hier:
                  https://forum.iobroker.net/topic/27797/test-adapter-contact-v1-1-x
                  Danke.
                  • M MCU
                    Vielen Dank.
                    F Online
                    F Online
                    fastfoot
                    Vielen Dank.
                    der tr Adapter ist aus dem Latest. Das Skript kann nur funktionieren, kurz nachdem ein Anruf reinkommt, da die Session-ID sehr schnell abläuft. Wenn man die URL später abruft, dann erscheint das XML mit der Fehlermeldung.
                    Das Skript funktioniert mit den FB-internen Bildern, bei Google habe ich keine hinterlegt. DA aber auch das Fritz-Phone diese wohl nicht anzeigt, kann es auch mit dem Skript nicht funktionieren
                    bahnuhrB D3ltoroxpD 2 Antworten Letzte Antwort
                    • F fastfoot
                      Vielen Dank.
                      bahnuhrB Offline
                      bahnuhrB Offline
                      bahnuhr
                      @fastfoot sagte in Fritzbox tr064 Anruferbild:
                      Das stimmt so nicht.
                      Das Fritz!Fon zeigt die Google Bilder an.
                      Bei dem Script oder die URL vom TR-064 funktioniert hingegen nicht.
                      Danke.
                      F 1 Antwort Letzte Antwort
                      • bahnuhrB bahnuhr
                        F Online
                        F Online
                        fastfoot
                        @bahnuhr sagte in Fritzbox tr064 Anruferbild:
                        Oh, das hatte ich anders gelesen, wie gesagt, ich habe in den G-Kontakten keine Bilder. Werde das mal selbst testen
                        Wie testest du das Skript unter WIN, denke da gibt es kein curl?
                        • F fastfoot
                          Vielen Dank.
                          D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          @fastfoot said in Fritzbox tr064 Anruferbild:
                          Hm, das Script kommt doch direkt, habs mal probiert, aber auch auf Telegram, wird kein Bild mitgeschickt.
                          Dann müsste das Bild ja während der SessionID abgerufen werden. Da das Script ja direkt auf ringring reagiert.
                          • F fastfoot
                            bahnuhrB Offline
                            bahnuhrB Offline
                            bahnuhr
                            Das ist richtig.
                            Aber ich hab mich schon 2-3 Jahren mit dem Thema beschäftigt.
                            u.a. mit dem damaligen Entwickler vom tr-064 Adapter soef; dort in verschiedenen issue.
                            Und dann Kontakte per Mail mit AVM um eben an die Bilder zu kommen.
                            Habe selber ein C4 (oder C5) und da werden die Bilder durchgereicht von der Fritz.Box da dort ja der google Kalender eingebunden ist.
                            mfg
                            Danke.
                              F Online
                              F Online
                              fastfoot
                              Das Bild wird bei mir in /opt/iobroker als img.jpg abgespeichert
                              D3ltoroxpD 1 Antwort Letzte Antwort
                              • F fastfoot
                                D3ltoroxpD Offline
                                D3ltoroxpD Offline
                                D3ltoroxp
                                @fastfoot Dann müsste das doch im Telegram mit folgen ?
                                  F Online
                                  F Online
                                  fastfoot
                                  schon, aber erst solltest du checken ob das Bild denn da ist :-) Sollte bei nichtgelingen von curl eine Größe von 0 haben, oder aber das XML mit der Fehlermeldung als Inhalt haben.
                                  • F fastfoot
                                    D3ltoroxpD Offline
                                    D3ltoroxpD Offline
                                    D3ltoroxp
                                    @fastfoot Hm kann da keine img.jpg sehen
                                      F Online
                                      F Online
                                      fastfoot
                                      das würde bedeuten dass das exec nicht aufgerufen wurde. Sonst musst du halt noch einen Pfad angeben, statt >img.jpg dann >/opt/iobroker/img.jpg
                                      • bahnuhrB bahnuhr
                                        Das ist richtig.
                                        mfg
                                        F Online
                                        F Online
                                        fastfoot
                                        Habe ich jetzt getestet, wird bei mir auch angezeigt. Auch ein Pfad wird im tr064 angezeigt, der darauf hindeutet dass das Bild von Google geladen werden soll. Leider klappt das nicht, als Ergebnis wird 404 not found zurückgegeben, kein Authentifizierungsfehler. Ich habe es auch mit dem Request-Block probiert, gleiches Ergebnis
                                        so sieht die URL aus: http://192.168.178.1:49000/download.lua?path=https://www.google.com/m8/feeds/photos/media/username%40gmail.com/412xxxxxxea808xx,240,\"SR1WAGxxxxxxxxxxxGoIYzcKKBxxxxxXdRI.\"&sid=91b6xxxxxxxx7e79&pbid=240
