  4. Iobroker.admin update Probleme
114 Beiträge 13 Kommentatoren 26.8k Aufrufe 4 Beobachtet
  • D dali3
    ja auf einer Proxmox-VM, welche Node und NPM Version wäre richtig?
    admin.0	2020-06-25 00:13:40.799	info	(6884) Use link "http://localhost:8081" to configure.
    admin.0	2020-06-25 00:13:40.799	info	(6884) http server listening on port 8081
    admin.0	2020-06-25 00:13:40.741	info	(6884) received all objects
    host.iobroker	2020-06-25 00:13:40.579	info	iobroker exit 0
    admin.0	2020-06-25 00:13:40.130	info	(6884) requesting all objects
    admin.0	2020-06-25 00:13:40.129	info	(6884) requesting all states
    admin.0	2020-06-25 00:13:40.117	info	(6884) starting. Version 3.7.8 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.1, js-controller: 3.1.4
    host.iobroker	2020-06-25 00:13:39.514	info	instance system.adapter.admin.0 started with pid 6884
    host.iobroker	2020-06-25 00:13:39.491	info	"system.adapter.admin.0" enabled
    host.iobroker	2020-06-25 00:13:39.480	info	iobroker host.iobroker Adapter "system.adapter.admin.0" is started
    host.iobroker	2020-06-25 00:13:39.480	info	iobroker Adapter "admin" updated
    host.iobroker	2020-06-25 00:13:39.423	info	iobroker upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    host.iobroker	2020-06-25 00:13:39.370	info	iobroker upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    host.iobroker	2020-06-25 00:13:39.317	info	iobroker upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    host.iobroker	2020-06-25 00:13:39.230	info	iobroker upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    host.iobroker	2020-06-25 00:13:39.209	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-06-24T22_13_39_205Z-debug.log
    host.iobroker	2020-06-25 00:13:39.203	info	iobroker Not compatible with your version of node/npm: parser@0.1.4npm ERR! notsup Not compatible with your version of node/npm: parser@0.1.4npm ERR! notsup Required: {"node":"0.4-0.9"}npm ERR! nots
    host.iobroker	2020-06-25 00:13:39.203	info	iobroker npm ERR! notsup Unsupported engine for parser@0.1.4: wanted: {"node":"0.4-0.9"} (current: {"node":"12.18.1","npm":"6.14.5"})npm ERR! notsup
    host.iobroker	2020-06-25 00:13:39.203	info	iobroker ERR! code ENOTSUP
    host.iobroker	2020-06-25 00:13:39.202	info	iobroker npm
    host.iobroker	2020-06-25 00:13:33.236	info	instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    host.iobroker	2020-06-25 00:13:32.888	info	iobroker npm install iobroker.admin@4.0.10 --loglevel error --prefix "/opt/iobroker" (System call)
    host.iobroker	2020-06-25 00:13:32.888	info	iobroker NPM version: 6.14.5
    admin.0	2020-06-25 00:13:32.712	info	(5859) Terminated (NO_ERROR): Without reason
    admin.0	2020-06-25 00:13:32.712	info	(5859) terminating
    admin.0	2020-06-25 00:13:32.707	info	(5859) Got terminate signal TERMINATE_YOURSELF
    admin.0	2020-06-25 00:13:32.704	info	(5859) terminating http server on port 8081
    host.iobroker	2020-06-25 00:13:32.702	info	stopInstance system.adapter.admin.0 send kill signal
    admin.0	2020-06-25 00:13:32.701	info	(5859) Adapter is disabled => stop
    host.iobroker	2020-06-25 00:13:32.701	info	stopInstance system.adapter.admin.0 (force=false, process=true)
    host.iobroker	2020-06-25 00:13:32.701	info	"system.adapter.admin.0" disabled
    host.iobroker	2020-06-25 00:13:32.684	info	iobroker host.iobroker Adapter "system.adapter.admin.0" is stopped.
    host.iobroker	2020-06-25 00:13:32.675	info	iobroker Update admin from @3.7.8 to @4.0.10
    host.iobroker	2020-06-25 00:13:31.704	info	iobroker upgrade admin
    haselchenH Offline
    haselchenH Offline
    haselchen
    #76
    @dali3
    Puh, Proxmox ist nicht so meine Baustelle.
    Da bin ich leider raus.
    • haselchenH haselchen
      @dali3
      dali3
      #77
      @haselchen welche Node und NPM Version wäre richtig?
      Systeminfo:
      Iobroker Pro, Surface 3 (Mobil), Acer T272 (Wand), Raspberry Pi 3, NUC, Synology DS212j (BackUp), Google Home, Xiaomi Aqara (Sensoren, Fühler, Kamera, LED), Revo Superconnect, Philips Hue, IKEA Tradfri...
      • D dali3
        haselchenH Offline
        haselchenH Offline
        haselchen
        #78
        @dali3
        Richtig oder falsch gibt es nicht.
        Bei mir auf ner Synology läuft 10.21.0
        Ich kenne mich mit Proxmox nicht aus.
        Wenn du weisst , wie Du auf ne 10er Nodejs Version kommst, würde ich damit erstmal anfangen.
          @dali3
          dali3
          schrieb am zuletzt editiert von dali3
          #79
          @haselchen Theoretisch sollte dies mit der 12er laufen?
          Was ist hier genau nicht supportet?
          Diesen Fehler bekomme ich auch bei gewissen anderen Adapter wenn ich diese Updaten möchte.
          Systeminfo:
          • D dali3
            haselchenH Offline
            haselchenH Offline
            haselchen
            #80
            @dali3
            Wie gesagt, ich kenne mich mit Proxmox und der Umgebung nicht aus.
            Ich kann dir dabei wirklich nicht weiterhelfen.
            Wenn du nen Terminal hast und das so funktioniert wie beim Raspi etc. , könntest du mal nen Update machen.
            apt-get update
            apt-get dist-upgrade
            Mehr fällt mir dazu leider nicht ein.
              @dali3
              apt-get update
              dali3
              #81
              Habe nun das ganze System neu aufgesetzt auf dem Proxmox / NUC...
              jedoch kommt der Fehler wieder....
              hat mir eventuell jemand einen Tipp?
              Update admin from @4.0.10 to @4.1.7
              host.iobroker2 Adapter "system.adapter.admin.0" is stopped.
              NPM version: 6.14.6
              npm install iobroker.admin@4.1.7 --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! code ENOTSUP
              npm ERR! notsup Unsupported engine for parser@0.1.4: wanted: {"node":"0.4-0.9"} (current: {"node":"10.22.0","npm":"6.14.6"})
              npm ERR! notsup Actual:   {"npm":"6.14.6","node":"10.22.0"}
              npm ERR!     /home/iobroker/.npm/_logs/2020-08-29T20_09_01_886Z-debug.log
              host.iobroker2 Adapter "system.adapter.admin.0" is started
              Systeminfo:
              • D dali3
                NPM version: 6.14.6
                #82
                @dali3
                cd /opt/iobroker
                npm ls parser
                Wobei ich mir jetzt bei einem frisch aufgesetzten System nicht erklären kann wo so eine alte Dependency herkommt. Was hast du denn da gemacht?
                  @dali3
                  cd /opt/iobroker
                  npm ls parser
                  dali3
                  #83
                  @Thomas-Braun
                  Habe eus neu aufgesetzt und das Backup eingespielt :(
                  iobroker@iobroker2:/opt/iobroker$ sudo npm ls parser
                  iobroker.inst@2.0.3 /opt/iobroker
                  `-- iobroker.javascript@4.1.12
                    `-- UNMET DEPENDENCY parser@^0.1.4
                  npm ERR! missing: parser@^0.1.4, required by iobroker.javascript@4.1.12
                  iobroker@iobroker2:/opt/iobroker$ iobroker@iobroker2:/opt/iobroker$ sudo npm ls parser
                  -bash: iobroker@iobroker2:/opt/iobroker$: No such file or directory
                  iobroker@iobroker2:/opt/iobroker$ iobroker.inst@2.0.3 /opt/iobroker
                  -bash: iobroker.inst@2.0.3: command not found
                  iobroker@iobroker2:/opt/iobroker$ `-- iobroker.javascript@4.1.12
                  -bash: --: command not found
                  iobroker@iobroker2:/opt/iobroker$ npm ERR! missing: parser@^0.1.4, required by iobroker.javascript@4.1.1
                  Hier die Ausgabe :(
                  Systeminfo:
                  • D dali3
                    @Thomas-Braun
                    Hier die Ausgabe :(
                    #84
                    @dali3
                    npm-Befehle nicht mit sudo ausführen!
                    iobroker fix
                    Danach
                    iobroker update
                    iobroker upgrade
                    mal probieren. Wird aber vermutlich auf die gleiche Meldung laufen.
                    Bei mir ist parser jedenfalls keine dependency von iobroker.javascript:
                    ├─┬ iobroker.javascript@4.6.26
                    │ ├── @iobroker/adapter-core@2.4.0 deduped
                    │ ├── @types/node@14.6.1
                    │ ├─┬ @types/request@2.48.5
                    │ │ ├── @types/caseless@0.12.2
                    │ │ ├── @types/node@14.6.1
                    │ │ ├── @types/tough-cookie@4.0.0
                    │ │ └─┬ form-data@2.5.1
                    │ │   ├── asynckit@0.4.0 deduped
                    │ │   ├── combined-stream@1.0.8 deduped
                    │ │   └── mime-types@2.1.27 deduped
                    Ist nodeJS bei dir sauber?
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      @dali3
                      iobroker fix
                      Danach
                      iobroker update
                      iobroker upgrade
                      dali3
                      #85
                      @Thomas-Braun
                      Iobroker fix hab ich schon probiert:
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      genau beim update/upgrade erhalte ich die gleich fehlermeldung :(
                      hier die Version:
                      iobroker@iobroker2:/opt/iobroker$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      v10.22.0
                      /usr/bin/node
                      v10.22.0
                      /usr/bin/npm
                      6.14.6
                      nodejs:
                        Installed: 10.22.0-1nodesource1
                        Candidate: 10.22.0-1nodesource1
                        Version table:
                       *** 10.22.0-1nodesource1 500
                              500 https://deb.nodesource.com/node_10.x buster/main amd64 Packages
                           10.21.0~dfsg-1~deb10u1 500
                              500 http://ftp.debian.org/debian buster/main amd64 Packages
                              500 http://security.debian.org buster/updates/main amd64 Packages
                      Danke dir für die Unterstützung! :)
                      Systeminfo:
                      • D dali3
                        @Thomas-Braun
                        hier die Version:
                        /usr/bin/nodejs
                        v10.22.0
                        /usr/bin/node
                        v10.22.0
                        /usr/bin/npm
                        6.14.6
                        nodejs:
                          Version table:
                        #86
                        @dali3
                        Zunächst würde ich node auf die Version 12 heben.
                        Dann
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                          @dali3
                          Dann
                          cd /opt/iobroker
                          dali3
                          #87
                          @Thomas-Braun
                          Update:
                          /usr/bin/nodejs
                          v12.18.3
                          /usr/bin/node
                          v12.18.3
                          /usr/bin/npm
                          6.14.6
                          nodejs:
                            Installed: 12.18.3-1nodesource1
                            Candidate: 12.18.3-1nodesource1
                            Version table:
                           *** 12.18.3-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                          Feedback Befehl - sudo -H -u iobroker npm install iobroker.js-controller:
                          iobroker@iobroker2:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                          npm ERR! notsup Unsupported engine for parser@0.1.4: wanted: {"node":"0.4-0.9"} (current: {"node":"12.18.3","npm":"6.14.6"})
                          npm ERR! notsup Actual:   {"npm":"6.14.6","node":"12.18.3"}
                          npm ERR!     /home/iobroker/.npm/_logs/2020-08-30T13_05_34_749Z-debug.log
                          Systeminfo:
                          • D dali3
                            @Thomas-Braun
                            Update:
                            /usr/bin/nodejs
                            v12.18.3
                            /usr/bin/node
                            v12.18.3
                            /usr/bin/npm
                            6.14.6
                            nodejs:
                              Version table:
                            #88
                            @dali3
                            sudo -H -u iobroker npm install iobroker.javascript
                              @dali3
                              #89
                              @Thomas-Braun
                              @dali3
                              aber bitte nur im iobroker-Verzeichnis!
                                @Thomas-Braun
                                @dali3
                                #90
                                @Homoran Das setze ich voraus.
                                  #91
                                  @Thomas-Braun sagte in Iobroker.admin update Probleme:
                                  Du schon ;-)
                                  und er ist "eigentlich" da bisher auch drin. Wollte nur sicher gehen, dass das auch so bleibt
                                    Du schon ;-)
                                    dali3
                                    #92
                                    @Homoran & @Thomas-Braun
                                    Wieder dasselbe :(
                                    iobroker@iobroker2:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.javascript
                                    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                    npm ERR!     /home/iobroker/.npm/_logs/2020-08-30T16_55_42_259Z-debug.log
                                    Systeminfo:
                                    • D dali3
                                      Wieder dasselbe :(
                                      #93
                                      @dali3 was mich da wundert ist die dependency auf einen parser@0.1.4
                                      den gibt es mittlerweile als 1.0.7, voraisgesetzt dass der iobroker.parser gemeint ist
                                      Thomas BraunT D 2 Antworten Letzte Antwort
                                        #94
                                        @Homoran
                                        Was mich noch mehr wundert ist der part:
                                        Diese SemVer ist ja aus der frühen Kreidezeit.
                                          dali3
                                          #95
                                          @Homoran
                                          Leider bin ich da wirklich ein Laie :(
                                          habe aber keinen Adapter namens "Parser" installiert. War auch meine erste Vermutung.
                                          Systeminfo:
