  4. Apple Homekit Siri
Apple Homekit Siri
250 Beiträge 49 Kommentatoren 90.4k Aufrufe
  • V
    V
    venni
    #201
    ! @jack77:
    ! > Ich kriege Homekit einfach nicht installiert.
    Kriege immer folgenden Fehler…
    ` > $ ./iobroker add homekit
    npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
    #include <dns_sd.h>^
    compilation terminated.
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    gyp
    ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack at emitTwo (events.js:87:13)
    gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
    gyp ERR! System Linux 4.1.19-v7+
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR!
    cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
    gyp ERR! node -v v4.4.3gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    npm
    ERR!
    Linux 4.1.19-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.4.3
    npm ERR! npm v2.15.1
    npm ERR! code ELIFECYCLE
    npm ERR! mdns@2.2.11 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the mdns package,npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs mdns
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm ERR! npm owner ls mdns
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.homekit: 1
    ERROR: process exited with code 25</dns_sd.h> `
    ioBroker ist auf einem Raspi2 mit Debian Jessie installiert.
    Kann mir einer helfen `
    ich habe exakt das gleiche Problem in der gleichen Konstellation.
    Es lässt sich nicht installieren und die Fehlermeldungen sind identisch.
    Pi2 mit Jessie.
    Hat das jemand in dieser Konstellation am laufen?
    Wenn die Installation schon nicht klappt, dürften doch mehrere das Problem haben.
    Frank
    • S
      S
      simpixo
      #202
      Ich kann den Adapter auch nicht installieren, der bricht bei der Installation mit der gleichen Fehlermeldung ab
      Ich habe den iobroker auf einem Pi3 + Jessi laufen! Alles andere funktioniert
      Adrian
      Gesendet von meinem iPhone mit Tapatalk
      • Alex1808A
        Alex1808A
        Alex1808
        #203
        @simpixo:
        Ich kann den Adapter auch nicht installieren, der bricht bei der Installation mit der gleichen Fehlermeldung ab `
        Ich glaube das hängt mit nodejs version zusammen, hatte auch mahl Installation Problem vom HomeKit. Benutze jetzt immer das Aktuelle vom nodesource.com
        Welche nodejs version ist momentan installiert?
        Vielleicht wird das euch helfen, aber dran denken das kann System zerschießen, also zuerst ein Backup machen.
        Kurz gefasste Anleitung zum umstieg (alles wird unter "root" durchgeführt):
        1.
        apt-get update && apt-get upgrade
        2.
        apt-get --purge remove node
        apt-get --purge remove nodejs
        apt-get auto remove
        3.
        reboot
        4.
        curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
        apt-get install -y nodejs
        apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
        npm install -g node-gyp
        5.
        reboot
        • V
          V
          venni
          #204
          Danke für den Hinweis!
          Ich habe 4.4.7 installiert.
          Was ist denn die aktuelle aus dem nodesource.com repo für den raspberry?
          Auf Anhieb habe ich dort nichts über die aktuelle Version gefunden.
          Würde ja nur Sinn machen es zu ändern, wenn die Version tatsächlich differiert.
          UPDATE:
          OK, ist die gleiche Version 4.4.7.
          Aber es funktioniert dann tadellos. :shock:
          Vielen Dank für den Tipp!
          • Alex1808A
            Alex1808A
            Alex1808
            #205
            @venni:
            Vielen Dank für den Tipp! `
            ich freue mich dass es funktioniert hat :)
            • C
              C
              chka
              #206
              Ich bekomme es einfach nicht mit Eve gekoppelt, er bricht immer wieder ab. Des Weiteren kann ich es auch nur auf dem master iobroker installieren (Multihost)
              INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
              Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
              RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
              • eric2905E
                eric2905E
                eric2905
                #207
                bei mir schmiert der Adapter leider ab:
                host-iobroker 2016-07-17 17:22:49.995 info Restart adapter system.adapter.homekit.0 because enabled
                host-iobroker 2016-07-17 17:22:49.994 error instance system.adapter.homekit.0 terminated with code 0 (OK)
                Error: 2016-07-17 17:22:49.973 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Error: 2016-07-17 17:22:49.973 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
                Error: 2016-07-17 17:22:49.973 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
                Error: 2016-07-17 17:22:49.973 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                Error: 2016-07-17 17:22:49.973 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                Error: 2016-07-17 17:22:49.973 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
                Error: 2016-07-17 17:22:49.973 error at require (internal/module.js:12:17)
                Error: 2016-07-17 17:22:49.973 error at Module.require (module.js:353:17)
                Error: 2016-07-17 17:22:49.973 error at Function.Module._load (module.js:276:25)
                Error: 2016-07-17 17:22:49.973 error at Function.Module._resolveFilename (module.js:325:15)
                Error: 2016-07-17 17:22:49.973 error Cannot find module 'hap-nodejs/node_modules/node-persist'
                uncaught 2016-07-17 17:22:49.972 error exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
                homekit-0 2016-07-17 17:22:49.940 info hap-nodejs starting...
                homekit-0 2016-07-17 17:22:49.938 debug received all objects
                homekit-0 2016-07-17 17:22:49.533 debug received all states
                homekit-0 2016-07-17 17:22:48.532 debug requesting all objects
                homekit-0 2016-07-17 17:22:48.528 debug requesting all states
                homekit-0 2016-07-17 17:22:48.524 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
                homekit-0 2016-07-17 17:22:48.424 debug statesDB connected
                homekit-0 2016-07-17 17:22:48.414 debug objectDB connected
                host-iobroker 2016-07-17 17:22:47.762 info instance system.adapter.homekit.0 started with pid 7095
                Jemand ne Idee?
                __Nachtrag 19.07.2016:
                Habe den Adapter jetzt komplett deaktiviert, gelöscht und neu eingebunden - leider ohne Erfolg.
                Werde heute Abend nochmal auf die Suche nach 'hap-nodejs/node_modules/node-persist" gehen, was ja anscheinend nicht gefunden wird.__
                Danke und Gruß,
                Eric
                • R
                  R
                  Rookman
                  #208
                  Hallo zusammen, gibt es im HomeKit Adapter die Möglichkeit nur Geräte eines bestimmten Gewerk anzuzeigen?
                  Auch versuche ich verzweifelt meine Dreh-Fenster-Kontakte mit einzubinden aber leider ohne Erfolg, kann mir hier jemand behilflich sein?
                  Es werden auch meine ganzen Programme mit ausgegeben, was ich auch nicht möchte, da gibt es doch bestimmt einen Trick ;-)
                  Viele Grüße Rookman
                  • M
                    M
                    Michy
                    #209
                    Nabend,
                    habe mir heute die Beta2 von IOS 10 für mein Iphone geladen und die beinhaltet auch die neue Apple "Home Smart Home" -App.
                    Verbinden konnte ich die App mit dem HomeKit des IoBrokers ohne Probleme. Beim Einrichten der einzelnen Homematic-Geräte und meiner Hue-Lampen
                    sind jedoch immer wieder die Meldungen "Die Verbindung des Gerätes wurde unterbrochen, überprüfen Sie die Internetverbindung" aufgetreten.
                    Nachdem ich dann alle Meldungen immer wieder ignoriert hatte und alle Geräte eingebunden waren, kam ich dann auf die Hauptansicht.
                    Und da ist es passiert. Der HomeKit Adapter stürzt ab- jedes mal wenn ich die App neu starte.
                    Im Log des Iobrokers wird mir dazu folgendes angezeigt.
                    TypeError:	2016-07-26 18:38:32.897	error	at HAPServer._handleCharacteristics (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
                    TypeError:	2016-07-26 18:38:32.897	error	at HAPServer.emit (events.js:175:7)
                    TypeError:	2016-07-26 18:38:32.897	error	at emitThree (events.js:97:13)
                    TypeError:	2016-07-26 18:38:32.897	error	at Bridge.Accessory._handleGetCharacteristics (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
                    TypeError:	2016-07-26 18:38:32.897	error	at Array.forEach (native)
                    TypeError:	2016-07-26 18:38:32.897	error	at Bridge. (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
                    TypeError:	2016-07-26 18:38:32.897	error	at Characteristic.getValue (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
                    TypeError:	2016-07-26 18:38:32.897	error	at emit (events.js:172:7)
                    TypeError:	2016-07-26 18:38:32.897	error	at emitTwo (events.js:87:13)
                    TypeError:	2016-07-26 18:38:32.897	error	at null. (/root/node_modules/iobroker.homekit/main.js:759:37)
                    TypeError:	2016-07-26 18:38:32.897	error	Cannot read property 'val' of undefined
                    uncaught	2016-07-26 18:38:32.892	error	exception: Cannot read property 'val' of undefined
                    Die Node/Nodejs Versionen habe ich mithilfe des vorherigen Posts aktualisiert.
                    Wäre super wenn mir da wer weiterhelfen kann, würde gerne die Hauseigenen Systeme von Apple für die Steuerung der Geräte über den IOBroker
                    nutzen.
                    VG Michy
                    • BluefoxB
                      #210
                      Kannst du die version probieren?
                      cd /opt/iobroker
                      npm install https://github.com/ioBroker/ioBroker.homekit/tarball/master --production
                      • M
                        M
                        Michy
                        #211
                        @Bluefox:
                        cd /opt/iobroker
                        die Version 0.1.4 habe ich vorher deinstalliert - die neue Version 0.1.5. einmal über SSH und per Terminal installiert. Lief alles sauber durch und habe auch jeweils neugestartet. Bei der Installation über SSH habe ich den IOBroker zusätzlich gestoppt.
                        Leider ist der Adapter nicht unter "Instanzen" aufgeführt und unter Objekte wird mir auch nichts angezeigt.
                        Nachtrag: HomeKit 0.1.4 installiert und per Terminal die von dir genannte Version installiert. Auch kein Erfolg.
                        Vielleicht mache ich was falsch?
                        VG Michy
                        • jens.mausJ
                          jens.mausJ
                          jens.maus
                          #212
                          Also bei mir funktioniert leider auch mit der 0.1.5 version die Kopplung an mein iPhone immer noch nicht. ioBroker wird zwar als Gerät angezeigt und ich kann auch den Code eingeben, aber dann kommt immer "Gerät konnte nicht hinzugefügt werden". Habe schon verschiedenes probiert von Pincode ändern über Username ändern usw. Leider alles ohne Erfolg inkl. zich mal komplett neu installieren. Das problem hatte ich schon mit iOS 9 und der Eve App und nun mit iOS 10 und der von Apple nativen HomeKit app geht es leider immer noch nicht.
                          Hat irgendwer eine Idee wie man das Problem eingrenzen kann?
                          RaspberryMatic @ PromoxVE mit ~190 HomeMatic Geräten + ioBroker – GitHub – GitHub Sponsors / PayPal
                          • S
                            S
                            schnallibert
                            #213
                            Hallo, danke für den Adapter!! Funktioniert super, Installation war einfach. Habe erst vor zwei tagen ioBroker mal testweise auf einer neu erstellten Debian Jessie VM installiert und dann den Homekit Adapter installiert.
                            Derzeit habe ich Testweise die CCU2 und die Hue's eingebunden.
                            Ich würde gerne die Temperatur des HM-TC-IT-WM-W-EU auslesen und in der Insteon+ App anzeigen lassen. (im Übrigen bringt die EVE App den Homekit Adapter zum crashen… passiert aber auch bei der nfarina variante)
                            Der HM-TC-IT-WM-W-EU wird in der App auch angezeigt. Jedoch nur dass das Gerät von Homematic seie und dessen Seriennummer.
                            Die Hues hat er lustigerweise auch gleich mit reingepackt, scheinbar weil es die Rolle level.dimmer benutzt....
                            Was genau muss bei Name und bei der Rolle definiert sein und von was wird ein "funktionierendes" Temperatur Accesorie abhängig gemacht?
                            • M
                              M
                              Michy
                              #214
                              @jens.maus:
                              Hat irgendwer eine Idee wie man das Problem eingrenzen kann? `
                              stürzt der HomeKit Adapter mit Version 0.1.5. ab? Wenn ja, dann wäre der Log mal interessant.
                              Wenn der Fehler mit Version 0.1.4. weg, ist könnte es sein, dass wir einen Schritt weiter sind. 8-)
                              Gruß Michy
                              • jens.mausJ
                                jens.mausJ
                                jens.maus
                                #215
                                @Michy:
                                @jens.maus:
                                Wenn der Fehler mit Version 0.1.4. weg, ist könnte es sein, dass wir einen Schritt weiter sind. 8-) `
                                Also ich sehe hier nicht das irgendetwas abstürzt. Ich bin nur einfach nicht in der Lage ioBroker in der HomeKit App auf iOS hinzuzufügen. Habe hier schon alles mögliche probiert, ohne erfolg, leider… Ich wüsste jetzt auch nicht wie ich das problem Debuggen sollte.
                                • C
                                  C
                                  chka
                                  #216
                                  eben noch mal ausprobiert das gleiche wie bei Jens
                                  • eric2905E
                                    eric2905E
                                    eric2905
                                    #217
                                    bei mir schmiert der Adapter ab.
                                    Hier das Log dazu:
                                    host-iobroker 2016-07-28 21:21:14.848 info instance system.adapter.homekit.0 started with pid 1734
                                    host-iobroker 2016-07-28 21:21:04.884 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                                    tankerkoenig-0 2016-07-28 21:21:04.371 info force terminating adapter after 1 minute
                                    host-iobroker 2016-07-28 21:20:44.842 info Restart adapter system.adapter.homekit.0 because enabled
                                    host-iobroker 2016-07-28 21:20:44.841 error instance system.adapter.homekit.0 terminated with code 0 (OK)
                                    Error: 2016-07-28 21:20:44.822 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                    Error: 2016-07-28 21:20:44.822 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
                                    Error: 2016-07-28 21:20:44.822 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
                                    Error: 2016-07-28 21:20:44.822 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                                    Error: 2016-07-28 21:20:44.822 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                                    Error: 2016-07-28 21:20:44.822 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
                                    Error: 2016-07-28 21:20:44.822 error at require (internal/module.js:12:17)
                                    Error: 2016-07-28 21:20:44.822 error at Module.require (module.js:353:17)
                                    Error: 2016-07-28 21:20:44.822 error at Function.Module._load (module.js:276:25)
                                    Error: 2016-07-28 21:20:44.822 error at Function.Module._resolveFilename (module.js:325:15)
                                    Error: 2016-07-28 21:20:44.822 error Cannot find module 'hap-nodejs/node_modules/node-persist'
                                    uncaught 2016-07-28 21:20:44.821 error exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
                                    homekit-0 2016-07-28 21:20:44.789 info hap-nodejs starting...
                                    homekit-0 2016-07-28 21:20:44.787 debug received all objects
                                    homekit-0 2016-07-28 21:20:44.394 debug received all states
                                    homekit-0 2016-07-28 21:20:43.344 debug requesting all objects
                                    homekit-0 2016-07-28 21:20:43.340 debug requesting all states
                                    homekit-0 2016-07-28 21:20:43.336 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.homekit
                                    homekit-0 2016-07-28 21:20:43.244 debug statesDB connected
                                    homekit-0 2016-07-28 21:20:43.231 debug objectDB connected
                                    host-iobroker 2016-07-28 21:20:42.559 info instance system.adapter.homekit.0 started with pid 1725
                                    Die Installation des Adapters lief ohne Probleme durch (Errorcode 0).
                                    Fehlt dem Adapter irgendwas an Installationsfiles?
                                    Gruß,
                                    Eric
                                    • M
                                      M
                                      Michy
                                      #218
                                      Diese Fehler:
                                      schließen für mich auf das Fehlen von Modul node-persist hin…
                                      Die Version 0.1.5 bekomme ich übrigens nicht installiert.
                                      Hat die schon jemand installiert und getestet?!
                                      Gruß Michy
                                      • BluefoxB
                                        #219
                                        Es wird node 4.x.x gebraucht.
                                        • jens.mausJ
                                          jens.mausJ
                                          jens.maus
                                          #220
                                          @Bluefox:
                                          Es wird node 4.x.x gebraucht. `
                                          Vielleicht solltest du überlegen das minimum an nodejs version auf 4.x.x zu pumpen und beim start von ioBroker darauf zu prüfen?
                                          Ich habe hier aber node 4.4.7 und dort bekomme ich aber trotzdem nicht das homekit mit ioBroker verbunden - es schmiert aber auch nicht ab?!?!
                                          84.2k
