  4. Test Adapter Husqvarna Automower v0.3.x
husqvarnaautomower
439 Beiträge 73 Kommentatoren 172.4k Aufrufe 62 Beobachtet
  • M matze0815
    ich habe seit geraumer Zeit einen 430x im Einsatz. Diesen würde ich gerne über den Adapter in den Iobroker einbinden.
    Habe den Adapter installalliert von Github.
    Jedoch wird weder in Objekte noch in Instanzen angezeigt.
    Neuinstallation des Adapter und reboot vom Raspberry brachte keine änderung.
    Was mache ich falsch?
    LOG bei der Installation:
    "$ ./iobroker url "https://github.com/truegreyhound/ioBroker.husq-automower" --debug
    install https://github.com/truegreyhound/ioBroker.husq-automower/tarball/e63e7ee2227701f18e256433f4ae97ac540c602b
    NPM version: 6.14.4
    npm install https://github.com/truegreyhound/ioBroker.husq-automower/tarball/e63e7ee2227701f18e256433f4ae97ac540c602b --loglevel error --prefix "/opt/iobroker" (System call)
    canvas@2.6.1 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error: gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.21.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.21.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    • iobroker.husq-automower@1.0.2added 1 package from 1 contributor in 17.243s
      22 packages are looking for funding run npm fund for details
      upload [4] husq-automower.admin /opt/iobroker/node_modules/iobroker.husq-automower/admin/words.js words.js application/javascript
      upload [3] husq-automower.admin /opt/iobroker/node_modules/iobroker.husq-automower/admin/index_m.html index_m.html text/html
      upload [2] husq-automower.admin /opt/iobroker/node_modules/iobroker.husq-automower/admin/index.html index.html text/html
      upload [1] husq-automower.admin /opt/iobroker/node_modules/iobroker.husq-automower/admin/husq-automower2.png husq-automower2.png image/png
      upload [0] husq-automower.admin /opt/iobroker/node_modules/iobroker.husq-automower/admin/husq-automower.png husq-automower.png image/png
      process exited with code 0"
    K
    K
    klassisch
    #177
    @matze0815 sagte in Test Adapter Husqvarna Automower v0.3.x:
    Nur der Vollständigkeit halber und weil mir das selbst auch schon passiert ist: Installieren des Adapters alleine reicht nicht. Man muß auch noch eine Instanz anlegen (+) Zeichen im Adaptermenue.
    • M
      M
      matze0815
      #178
      Ins Menü vom Adapter komm ich ja auch nicht...
      • M
        M
        matze0815
        #179
        Ah, jetzt hab ich's verstanden.
        Erzeugen der Instanz hat geholfen!
        DANKE
        • BoronsbruderB
          BoronsbruderB
          Boronsbruder
          #180
          @greyhound
          Diese Fehlermeldung bringt der Adapter beim Erst-Start
          2020-06-21 09:16:20.698 - info: husq-automower.0 (29341) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.husq-automower, node: v12.18.1, js-controller: 3.1.5
          2020-06-21 09:16:20.715 - info: husq-automower.0 (29341) Logged off.
          2020-06-21 09:16:21.306 - info: husq-automower.0 (29341) Logged on. Checking for mowers.
          2020-06-21 09:16:21.716 - error: husq-automower.0 (29341) uncaught exception: mobjMower.getStatus is not a function
          2020-06-21 09:16:21.717 - error: husq-automower.0 (29341) TypeError: mobjMower.getStatus is not a function
          at Timeout.updateStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.husq-automower/main.js:991:15)
          at listOnTimeout (internal/timers.js:549:17)
          at processTimers (internal/timers.js:492:7)
          2020-06-21 09:16:21.717 - info: husq-automower.0 (29341) Logged off.
          2020-06-21 09:16:21.718 - info: husq-automower.0 (29341) cleaned everything up...
          2020-06-21 09:16:21.721 - info: husq-automower.0 (29341) terminating
          2020-06-21 09:16:21.722 - info: husq-automower.0 (29341) Terminated (NO_ERROR): Without reason
          2020-06-21 09:16:21.732 - info: husq-automower.0 (29341) connected, mowersListUpdated, found 1 mower(s)
          Nach dem er sich neugestartet hat, kommt der Fehler nicht mehr.
          Achj und den
          husq-automower.0	2020-06-21 09:17:26.451	warn	(30443) checkAMatHome >> homeLocation.latitude and/or homeLocation.longitude not set or failure on reading!
          Fehler hab ich auch...
          Trotzdem mal ein Danke für die Arbeit die du dir gemacht hast!
          • K
            K
            Kanumouse
            #181
            weiß jemand, ob man auch die Google Maps Anzeige mit der Fahrspurkennzeichnung, analog der APP, hinbekommt?
            Wenn ja, wie?
            • K Kanumouse
              Wenn ja, wie?
              A
              A
              Andy200877
              #182
              @Kanumouse
              Das würde mich auch sehr interessieren, jedoch so wie ich es verstanden habe, kostet der Google-Api-Key jetzt wohl, bzw. ist nicht mehr so einfach nutzbar.
              Aber vielleicht hat ja jemand anderes mehr Ahnung davon...
              https://github.com/Andy200877/intex_poollampe
              • BoronsbruderB
                BoronsbruderB
                Boronsbruder
                schrieb am zuletzt editiert von Boronsbruder
                #183
                Guten Abend zusammen!
                Seit einigen Tagen (ältestes Log vom 18.07.) bekomme ich ständig den
                husq-automower.0	2020-07-25 21:32:52.002	info	(12139) Terminated (NO_ERROR): Without reason
                husq-automower.0	2020-07-25 21:32:52.001	info	(12139) terminating
                husq-automower.0	2020-07-25 21:32:51.997	info	(12139) cleaned everything up...
                husq-automower.0	2020-07-25 21:32:51.996	info	(12139) Logged off.
                husq-automower.0	2020-07-25 21:32:51.995	error	at processTimers (internal/timers.js:492:7)
                husq-automower.0	2020-07-25 21:32:51.995	error	at listOnTimeout (internal/timers.js:549:17)
                husq-automower.0	2020-07-25 21:32:51.995	error	at Timeout.updateStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.husq-automower/main.js:991:15)
                husq-automower.0	2020-07-25 21:32:51.995	error	(12139) TypeError: mobjMower.getStatus is not a function
                husq-automower.0	2020-07-25 21:32:51.994	error	(12139) uncaught exception: mobjMower.getStatus is not a function
                husq-automower.0	2020-07-25 21:32:50.992	info	(12139) Logged off.
                husq-automower.0	2020-07-25 21:32:50.975	info	(12139) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.husq-automower, node: v12.18.3, js-controller: 3.1.6
                der dann irgendwann in
                husq-automower.0	2020-07-25 21:34:01.263	info	(12686) Terminated (NO_ERROR): Without reason
                husq-automower.0	2020-07-25 21:34:01.262	info	(12686) terminating
                husq-automower.0	2020-07-25 21:34:01.257	info	(12686) cleaned everything up...
                husq-automower.0	2020-07-25 21:34:01.256	info	(12686) Logged off.
                husq-automower.0	2020-07-25 21:34:01.255	error	(12686) TypeError: mobjMower.getStatus is not a function at Timeout.updateStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.husq-automower/main.js:991:15) at listOnTimeout (internal/
                husq-automower.0	2020-07-25 21:34:01.254	error	(12686) uncaught exception: mobjMower.getStatus is not a function
                husq-automower.0	2020-07-25 21:34:00.252	info	(12686) Logged off.
                übergeht.
                Nur mit abgeschalteter "Erweiterte Statistik" startet der Adapter durch.
                Hat das noch jemand?
                greyhoundG D 2 Antworten Letzte Antwort
                • BoronsbruderB Boronsbruder
                  übergeht.
                  greyhoundG
                  greyhoundG
                  greyhound
                  #184
                  @Boronsbruder
                  Hat sich das Problem inzwischen erledigt?
                  Wenn nicht, dann lasse den Adapter bitte im debug-Modus laufen und poste das Log.
                  Hast du das System, auf dem ioBroker läuft, auch schon mal rebootet?
                  ioBroker auf ODROID-XU4 / Influx u. a. auf FUJITSU D3400-B, Celeron G3900, 16 GB RAM / CCU2 / Nuki
                  greyhoundG 1 Antwort Letzte Antwort
                  • greyhoundG greyhound
                    @Boronsbruder
                    greyhoundG
                    greyhoundG
                    greyhound
                    schrieb am zuletzt editiert von greyhound
                    #185
                    Es gab eine kleine Diskussion zu den GPS-Daten der Homelocation.
                    Husqvarna central point record, stammt aus dem GPS-Datensatz, sollen Koordinaten der Basis sein
                    mower.homeLocation.longitudeCP
                    mower.homeLocation.latitudeCP
                    Kopie der CP-Werte, werden gesetzt, wenn diese hier leer, Idee war zu erkennen, ob diese sich ändern
                    Voraussetzung ist, dass die GPS-Daten kommen und dort eine 0 steht.
                    Die GPS-Daten müssten in den DPs mit den Rohdaten zu finden sein.
                    Bin bei der Vorbereitung eines Updates des "alten" Adapters. Werde das bei mir aber auch noch einmal prüfen.
                      übergeht.
                      D
                      D
                      Dirni
                      #186
                      @Boronsbruder
                      Habe die gleiche Fehlermeldung
                      • D Dirni
                        @Boronsbruder
                        A
                        A
                        Andy200877
                        #187
                        @Dirni sagte in Test Adapter Husqvarna Automower v0.3.x:
                        Kann es evtl. mit der Softwareversion des Mähers zusammen hängen ?
                        Mein 315X läuft nun seit 2,5 Jahren wunderbar mit der gleichen Software und mein Adapter macht auch keine Probleme (0.3.10)
                        D C 2 Antworten Letzte Antwort
                        • A Andy200877
                          D
                          D
                          Dirni
                          #188
                          @Andy200877
                          Habe einen 430X
                          • A Andy200877
                            C
                            C
                            checkitout
                            #189
                            @Andy200877
                            ich denke nicht das es an der Softwareversion des Mähers liegt,
                            verwende zur Zeit einen 435X AWD mit der neuesten Software,
                            (Softwareupdate war wegen den Neigungssensoren notwendig)
                            Ich hab auch lange gerumgetüftelt bis das Ding am Laufen war,
                            hab mich langsam an die diversen Versionen der Adapter herangetastet,
                            jetzt habe ich eine stabile Umgebung aud einem RPI3 die ich nicht mehr angreife
                            keine updates-kein garnix ... "dont touch a running system"
                            den Rest habe ich auf einen RPI4 geschoben und mit IOBroker zusammengefüht.
                            H 1 Antwort Letzte Antwort
                            • C checkitout
                              @Andy200877
                              H
                              H
                              hartwigm
                              #190
                              @checkitout
                              Ich habe seid einer Woche auch einen 435 AWD am laufen. und der läuft bislang Fehlerfrei mit dem Adapter und der aktuellsten Software.
                              Was mich noch nicht gefunden habe ist die Möglichkeit der Schnitthöhe sowie die Scheinwerfer an/aus zu schalten.
                              Wenn ich Bewegung im Garten detektiere würde ich gerne den scheinwerfer anschalten.
                              • H hartwigm
                                @checkitout
                                D
                                D
                                Dirni
                                #191
                                @hartwigm
                                Ich hab nichts anderes gemacht wie den Adapter Installiert und meine Daten eingegeben, muß man sonst noch was machen ?
                                lg
                                • D Dirni
                                  @hartwigm
                                  lg
                                  H
                                  H
                                  hartwigm
                                  #192
                                  @Dirni
                                  nein nicht wirklich.
                                  Hast Du Fehler im Log?
                                  Geht die smartphone App von Husquarna problemlos?
                                  Wenn das geht, brauchst Du nur die Daten entsprechend eingeben. Am Anfang hatte ich im Log immer wieder Registierungsfehler, das war aber nach ein paar Stunden weg. Vermutlich war da auf Husquarnaseite noch nicht alles frei.
                                  • H hartwigm
                                    @Dirni
                                    D
                                    D
                                    Dirni
                                    #193
                                    @hartwigm
                                    App geh tadellos. Ja hab manchmal Fehler in der LOG ich werde es weiter beobachten.
                                    lg
                                    • BoronsbruderB
                                      BoronsbruderB
                                      Boronsbruder
                                      #194
                                      @greyhound
                                      Ich hatte den Haken bei "schreibe erweiterte Statistik" rausgenommen, damit lief der Adapter wieder ohne Probleme.
                                      Nachdem ich deinen Post gelesen habe, habe ich versucht den Fehler wieder zu reproduzieren und "leider" tritt er nicht mehr auf...
                                      Ja, ich hatte den Adapter de- und wiederinstalliert mit Reboots des Docker-Containers und des Servers auf dem Docker läuft.
                                      In der Zwischenzeit habe ich allerdings den Server auf ein neues Mainboard umgezogen und einiges am Betriebssystem rumgebastelt. Vielleicht hat irgendwas den Fehler terminiert ? Leider kann ich aber nicht mal kurz den Altzustand herstellen 😆
                                      BoronsbruderB 1 Antwort Letzte Antwort
                                      • H hartwigm
                                        @checkitout
                                        C
                                        C
                                        checkitout
                                        #195
                                        @hartwigm
                                        ja Schnitthöhe und Scheinwerfer habe ich auch noch nicht geschafft ,
                                        aber das wird sicher eine "mower.action" sein,
                                        da bei mir die "stop bei Regen Funktion" nicht laufen will hab ich ein kleines Blockly mit dem Regensensor mit der mower.action gebastelt - funktioniert sehr gut.
                                        LG C
                                        A greyhoundG 2 Antworten Letzte Antwort
                                          @greyhound
                                          BoronsbruderB
                                          BoronsbruderB
                                          Boronsbruder
                                          #196
                                          @greyhound
                                          Ich hätte dir jetzt ein Error-Log...
                                          Ist nachdem Aktualisieren meines Docker-Containers entstanden...
                                          Ich würde es dir zukommen lassen, möchte es aber hier nicht posten, da die ganzen GPS-Daten drin stehen...
                                          Nur etwas ist mir aufgefallen, dass im Log
                                          die letzten LastLocations als
                                          {\\\"latitude\\\":12.1234567,\\\"longitude\\\":12.1234567,\\\"gpsStatus\\\":\\\"USING_GPS_MAP\\\"}
                                          Anstatt
                                          {\"latitude\":12.1234567,\"longitude\":12.1234567,\"gpsStatus\":\"USING_GPS_MAP\"}
                                          unter "syncConfig idStates:" stehen...
                                          84.2k
