    1.0k
  • E Offline
    exv2
    #2017
    Hallo
    ich versuche seit Tagen die Sonnenschutzfunktion zum arbeiten zu überreden leider gänzlich ohne Erfolg.
    Ich bin jetzt am ende und finde meinen Fehler nicht. Kann im eventuell einer helfen.
    Was wird benötigt um zu helfen?
    Diese Zeile im Log ist für mich unverständlich.
    EG Wohnzimmer Fenster: Check basis for sunprotect. Height:0 > HeightDownSun: 80 AND Height:0 == currentHeight:0 AND currentHeight:0 == heightUp:0
    "native": {
        "livingAutomatic": "livingSunriseSunset",
        "W_shutterDownLiving": "22:00",
        "W_shutterUpLivingMin": "07:00",
        "W_shutterUpLivingMax": "07:30",
        "driveDelayUpLiving": "10",
        "WE_shutterDownLiving": "22:00",
        "WE_shutterUpLivingMin": "08:00",
        "WE_shutterUpLivingMax": "09:00",
        "sleepAutomatic": "sleepSunriseSunset",
        "W_shutterDownSleep": "22:00",
        "W_shutterUpSleepMin": "07:00",
        "W_shutterUpSleepMax": "07:30",
        "driveDelayUpSleep": "10",
        "WE_shutterDownSleep": "22:00",
        "WE_shutterUpSleepMin": "08:00",
        "WE_shutterUpSleepMax": "09:00",
        "latitude": "52.71439660",
        "longitude": "13.27626290",
        "astroDelayUp": "30",
        "astroDelayDown": "30",
        "driveDelayUpAstro": "10",
        "sunProtEndElevation": "10",
        "HolidayDP": "",
        "triggerAutoSleep": "",
        "triggerAutoLiving": "",
        "LateAllDown": false,
        "LateAllDownTime": "",
        "SummerStart": "01.03.",
        "SummerEnd": "30.09.",
        "currentShutterState": false,
        "publicHolidays": true,
        "publicHolInstance": "feiertage.0",
        "heightDownSun": "80",
        "direction": "120",
        "type": "only outside temperature",
        "directionRange": "50",
        "actualValueTemp": "hm-rega.0.2640",
        "actualValueLight": "zigbee.0.04cf8cdf3c787eff.illuminance",
        "actualValueTempInside": "",
        "typeDown": "living",
        "typeUp": "living",
        "triggerStateShutter": "true",
        "triggerChangeShutter": "off",
        "triggerDriveShutter": "100",
        "autoDriveShutter": "off",
        "heightDownShutter": "100",
        "heightUpShutter": "0",
        "triggerID": "",
        "LateDown": false,
        "inSummerNotDown": false,
        "events": [
            "enabled": true,
            "shutterName": "EG Wohnzimmer Fenster",
            "name": "homepilot20.0.Actuator.2-14234511.Position",
            "triggerID": "",
            "typeUp": "living",
            "direction": "120",
            "tempInside": "23",
            "tempSensor": "",
            "outsideTempSensor": "hm-rega.0.2640",
            "tempOutside": "23",
            "lightSensor": "zigbee.0.04cf8cdf3c787eff.illuminance",
            "valueLight": "30000",
            "heightUp": "0",
            "heightDown": "100",
            "triggerState": "true",
            "triggerDrive": "100",
            "triggerChange": "off",
            "elevation": "",
            "autoDrive": "off",
            "hysteresisOutside": "0",
            "hysteresisInside": "5",
            "hysteresisLight": "0",
            "currentAction": "",
            "currentHeight": "",
            "oldHeight": "",
            "firstCompleteUp": "",
            "triggerHeight": "",
            "LateDown": false,
    • E exv2
      Hallo
      "native": {
          "HolidayDP": "",
          "direction": "120",
          "typeUp": "living",
          "triggerID": "",
          "LateDown": false,
          "events": [
              "enabled": true,
              "triggerID": "",
              "typeUp": "living",
              "direction": "120",
              "tempInside": "23",
              "tempSensor": "",
              "heightUp": "0",
              "elevation": "",
              "autoDrive": "off",
              "oldHeight": "",
              "LateDown": false,
      andi2055
      #2018
      @exv2
      Das ist das Log der Prüfung, ob der Sonnenschutz angefahren werden soll
      -> Aktuelle Höhe ist 0. Diese ist KLEINER als 80 und damit FALSE und deshalb wird kein Sonnenschutz angefahren
      Normalerweise ist es so als Beispiel: Rollladen auf 100% = AUF
      Sonnenschutzhöhe = 30% = "fast zu"
      wenn die anderen Kriterien erfüllt sind, dann wird der Sonnenschutz angefahren.
      Kann es sein, dass bei dir offen/geschlossen vertauscht ist? Also offen = 0%
      E 1 Antwort Letzte Antwort
      • A andi2055
        @exv2
        exv2
        #2019
        @andi2055
        Ah OK Danke
        bei mir ist hoch 0% und runter 100%
        Für das normale hoch und runter fahren funktioniert das ganze.
        Mal sehen was ich da machen kann.
        • E exv2
          @andi2055
          Ah OK Danke
          andi2055
          #2020
          @simatec
          Darf aktuell auf/zu so über die Einstellungen beliebig festgelegt werden (laut Einstellung ist es möglich).
          Ist das so vorgesehen?
          Beim Sonnenschutz wird und wurde das so nicht berücksichtigt mit den kleiner/größer Vergleichen
          Ist das nur beim Sonnenschutz ein Problem?
          Bug oder Feature-Request?
          • A andi2055
            @simatec
            exv2
            #2021
            @andi2055
            Es ist nur beim Sonnenschutz das Problem. Aber ich habe noch einen inverten DP dann muss ich den nehmen und die Einstellungen anpassen.
            Ich versuche das dann mal und gebe bescheid ob es dann klappt.
            Ich habe Gurtwickler von Rademacher und diese per Homepilot20 in ioBroker.
            • E exv2
              @andi2055
              simatecS Offline
              simatecS Offline
              simatec
              #2022
              @exv2 sagte in Test Adapter shuttercontrol v0.6.x:
              Ja entweder so, oder mit der Alias Funktion von iobroker.
              Shuttercontrol benötigt für die Funktion 0% = geschlossen und 100% = offen
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • tobasiumT Offline
                tobasiumT Offline
                tobasium
                #2023
                Guten Morgen,
                ich hab ein komisches Problem. Meine Rolladen fahren Teilweise den Sonnenschutz andere nicht. Was übersehe ich?
                Eigentlich sollte dieser Rolladen Morgens runterfahren, das tut er aber nicht.
                Rolladen die Himmelsrichtung 210 haben fahren bei mir Mittags ganz normal.
                Woran könnte dies liegen?
                Ich verzweifle langsam.
                Danke vorab
                • simatecS simatec
                  exv2
                  #2024
                  @simatec
                  habe gestern den inverten DP eingestellt.
                  Runter und hoch fahre haben geklappt.
                  Runterfahren zur Beschattung hat auch geklappt. nur der Rollladen fährt nicht wieder hoch.
                  Der Sollwert ist 30000 und wir haben seit einer Stunde nur noch werte um 2000.
                  Anbei die Configuration. Ich mache bestimmt was falsch.
                  "native": {
                      "sunProtEndElevation": "65",
                      "HolidayDP": "",
                      "heightDownSun": "20",
                      "direction": "120",
                      "typeUp": "living",
                      "heightDownShutter": "0",
                      "heightUpShutter": "100",
                      "triggerID": "",
                      "LateDown": false,
                      "events": [
                          "enabled": true,
                          "shutterName": "Position_inverted EG Wohnzimmer Fenster",
                          "name": "homepilot20.0.Actuator.2-14234511.Position_inverted",
                          "triggerID": "",
                          "typeUp": "living",
                          "direction": "120",
                          "tempInside": "23",
                          "tempSensor": "",
                          "heightUp": "100",
                          "heightDown": "0",
                          "elevation": "",
                          "autoDrive": "off",
                          "hysteresisLight": "5",
                          "oldHeight": "",
                          "LateDown": false,
                  • E exv2
                    @simatec
                    "native": {
                        "HolidayDP": "",
                        "direction": "120",
                        "typeUp": "living",
                        "triggerID": "",
                        "LateDown": false,
                        "events": [
                            "enabled": true,
                            "triggerID": "",
                            "typeUp": "living",
                            "direction": "120",
                            "tempInside": "23",
                            "tempSensor": "",
                            "heightUp": "100",
                            "heightDown": "0",
                            "elevation": "",
                            "autoDrive": "off",
                            "oldHeight": "",
                            "LateDown": false,
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2025
                    @exv2
                    Ich kann mich erinnern, dass hier mal ein User einen Bug gemeldet hat.
                    Bin aber nicht sicher, ob der behoben wurde.
                    Trage mal den Lichtsensor bei Außentemperatur ein und die Werte dann dementsprechend auch.
                    Eventuell ist da ein fehler beim Lichtsensor
                    B E 2 Antworten Letzte Antwort
                    • simatecS simatec
                      @exv2
                      bishop
                      #2026
                      @simatec
                      in der log steht
                      "autoDrive": "off",
                      sollte da nicht "updown" stehen damit er fährt?
                      • simatecS simatec
                        @exv2
                        exv2
                        #2027
                        @simatec
                        Habe ich pobehalber mal getauscht aber keine reaktion.
                        Noch ne andere Idee?
                        • tobasiumT tobasium
                          Guten Morgen,
                          Danke vorab
                          andi2055
                          #2028
                          @tobasium
                          Ich habe einen meiner Rollladen gestern testweise auf ähnliche Werte gestellt. Dieser ist heute Morgen korrekt in den Sonnenschutz gefahren.
                          Stelle deinen doch mal exakt so ein wie dein anderer, der funktioniert. Oder du hast mit diesem einen Rollladen irgendein anderes Problem?!
                          @simatec
                          Ich habe dir einen PR gesendet für den Bug von exv2. Ungetestet, aber ich denke das ist das Problem
                          • simatecS Offline
                            simatecS Offline
                            simatec
                            #2029
                            Ab sofort ist die Version 0.7.2 auf Github und auch im latest verfügbar ...
                            Changelog
                            0.7.2 (2020-06-26)
                            • (simatec) Bugfix sunprotect for outsidetemp
                            • (simatec) better translation for all languages
                            • (simatec) better overview in the user interface
                              steimi
                              schrieb am zuletzt editiert von steimi
                              #2030
                              Irgendwie hat sich bei mir ein Fehler eingeschlichen. Ich habe eingestellt das er in der Arbeitswoche spätestens 21:30 die Rollos runterfahren soll, am Wochenende um 22:00. Heute am Freitag hat er die Rollos um 21:51 runter gefahren, statt um 21:30 - 21:31 war Sonnenuntergang und ich habe eine Verzögerung von 20 Minuten. Vorigen Sonntag hat er die Rollos um 21:30 runtergefahren, obwohl mMn ja noch Wochenende ist. Scheint so als zählen Fr/Sa zum Wochenende und nicht Sa/So.
                              Ist das richtig so oder habe ich ein Verständnisproblem?
                              Dabei kommt gleich der Wunsch/Gedanke auf die Tage für die Wochenende-Schaltung konfigurierbar zu machen.
                              system.adapter.shuttercontrol.0.json
                              • S steimi
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #2031
                                @steimi
                                Freitag gehört beim runterfahren zum Wochenende und Sonntag beim runterfahren zur Arbeitswoche
                                • 2 Offline
                                  2 Offline
                                  2hot4you
                                  #2032
                                  Mir ist mit Version 0.7.2 folgendes aufgefallen.
                                  Jalousien sind im Sonnenschutz bei > 14.000 lux hochgefahren, obwohl in den Einstellungen
                                  der Sollwert bei 9000 und die Hysterese bei 40 steht
                                  Die Türen habe ich mit einen Homatic Fenstergriff Kontakt überwacht. Wenn die Tür abends offen steht, geht die Jalousie nicht runter, was auch so gewollt ist, jedoch wenn ich morgens die Tür schließe, fährt die Jalousie herunter . Beide Türen stehen bei Art der Steuerung auf Wohnbereich und Schlafbereich (Automatik)
                                  FredFF simatecS 2 Antworten Letzte Antwort
                                  • 2 2hot4you
                                    FredFF Online
                                    FredFF Online
                                    FredF
                                    Most Active Forum Testing
                                    #2033
                                    @2hot4you
                                    @simatec
                                    Ich verstehe das bei Sollwert 9000 und Hysterese 40 so:
                                    Sonnenschutz aktiv ab 5400
                                    Sonnenschutz inaktiv ab 12600
                                    • 2 2hot4you
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #2034
                                      @2hot4you
                                      Bitte mache mal genaue Angaben zu deiner Config
                                      2 1 Antwort Letzte Antwort
                                      • FredFF FredF
                                        @2hot4you
                                        @simatec
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #2035
                                        @FredF
                                        Nein die Hysterese greift nur nach unten.
                                        Größer 9000 Lux geht der Rollladen in Sonnenschutz.
                                        Um Schwankungen abzufangen, gibt es dann die Hysterese nach unten, damit der Rollladen nicht ständig hoch und runter fährt
                                        • simatecS simatec
                                          @FredF
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          #2036
                                          @simatec
                                          Also im Fall von 2hot4you:
                                          Der Sonnenschutz ist aktiv ab 9000 Lux und bleibt aktiv bis der Wert unter 5400 Lux fällt
