  4. Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5
    6.3k
zigbee adapterjs controller update
51 Beiträge 10 Kommentatoren 7.6k Aufrufe 9 Beobachtet
  • G Offline
    gifftstaub
    Push
    Ich habe nun folgendes gemacht.
    pi@raspberrypi:/opt/iobroker/node_modules/serialport $ npm install --production
    > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=12.18.0 runtime=node arch=arm libc= platform=linux)
    make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird betreten
      CXX(target) Release/obj.target/bindings/src/serialport.o
    In file included from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
      CXX(target) Release/obj.target/bindings/src/serialport_unix.o
    In file included from ../src/serialport.h:6,
                     from ../src/serialport_unix.cpp:2:
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
      CXX(target) Release/obj.target/bindings/src/poller.o
    In file included from ../src/poller.cpp:1:
      CXX(target) Release/obj.target/bindings/src/serialport_linux.o
      SOLINK_MODULE(target) Release/obj.target/bindings.node
      COPY Release/bindings.node
    make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird verlassen
    > serialport@8.0.8 postinstall /opt/iobroker/node_modules/serialport
    > node thank-you.js
    Thank you for using serialport!
    If you rely on this package, please consider supporting our open collective:
    > https://opencollective.com/serialport/donate
    npm notice created a lockfile as package-lock.json. You should commit this file.
    added 73 packages from 43 contributors and audited 78 packages in 16.172s
    1 package is looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    pi@raspberrypi:/opt/iobroker/node_modules/serialport $ npm fund
    serialport@8.0.8
    └─┬ https://github.com/sponsors/sindresorhus
      └── mimic-response@2.1.0
    liegt das Problem an der 12.18.0?
    lg
    • G gifftstaub
      Push
      > node thank-you.js
      serialport@8.0.8
      lg
      @gifftstaub
      Nein, mit 12.18.0 hat das grundsätzlich nichts zu tun, denn:
      pi@raspberrypi:/opt/iobroker $ nodejs -v
      v12.18.0
      pi@raspberrypi:/opt/iobroker $ npm ls serialport
      iobroker.inst@2.0.3 /opt/iobroker
      ├─┬ iobroker.discovery@2.3.7
      │ └── serialport@8.0.8
      └─┬ iobroker.zigbee@1.1.1
        └─┬ zigbee-herdsman@0.12.83
          └── serialport@8.0.7
      G 1 Antwort Letzte Antwort
        @gifftstaub
        v12.18.0
        gifftstaub
        @Thomas-Braun
        könnte der Stick defekt sein?
        └─┬ iobroker.zigbee@1.0.0
          └─┬ zigbee-herdsman@0.12.95
        lg
        • G gifftstaub
          @Thomas-Braun
          lg
          @gifftstaub
          Hast du eigentlich im Raspberry auch den Serialport in
          sudo raspi-config
          aktiviert?
          Geht unter 5 - P6 - No - Yes
            @gifftstaub
            sudo raspi-config
            aktiviert?
            gifftstaub
            @Thomas-Braun
            eingentlich ja am serialport war ich nocch nie dran.
            ich habe das mal proformer gemacht wie du beschrieben hast, nach einem reboot immer noch die gleichen Meldungen.
            zigbee.0	2020-06-16 14:21:14.793	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
            zigbee.0	2020-06-16 14:21:14.793	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
            zigbee.0	2020-06-16 14:21:14.793	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
            zigbee.0	2020-06-16 14:21:14.793	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
            zigbee.0	2020-06-16 14:21:14.793	error	at new Promise (<anonymous>)
            zigbee.0	2020-06-16 14:21:14.793	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
            zigbee.0	2020-06-16 14:21:14.793	error	at Generator.next (<anonymous>)
            zigbee.0	2020-06-16 14:21:14.793	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
            zigbee.0	2020-06-16 14:21:14.793	error	(2686) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
            zigbee.0	2020-06-16 14:21:14.792	error	(2686) Failed to start Zigbee
            zigbee.0	2020-06-16 14:21:14.554	info	(2686) Starting Zigbee...
            lg
            • G gifftstaub
              @Thomas-Braun
              lg
              @gifftstaub sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
              Da greift wohl schon irgendwas anderes drauf zu. Hast du noch deConz parallel laufen?
                gifftstaub
                @Thomas-Braun
                nein nur zigbee
                • G Offline
                  gifftstaub
                  liste der Installierten Adapter
                  Used repository: latest
                  hash unchanged, use cached sources
                  update done
                  Adapter    "accuweather"   : 1.1.3
                  Adapter    "admin"         : 4.1.1    , installed 4.1.1
                  Adapter    "alarm"         : 0.7.5
                  Adapter    "alexa2"        : 3.1.2    , installed 3.1.2
                  Adapter    "alpha2"        : 1.0.0
                  Adapter    "amazon-dash"   : 1.1.0
                  Adapter    "artnet"        : 1.2.2
                  Adapter    "asterisk"      : 1.0.6
                  Adapter    "asuswrt"       : 1.0.1
                  Adapter    "b-control-em"  : 0.2.1
                  Adapter    "backitup"      : 1.5.8    , installed 1.5.8
                  Adapter    "beckhoff"      : 1.2.2
                  Adapter    "benq"          : 0.2.2
                  Adapter    "binance"       : 1.1.2
                  Adapter    "ble"           : 0.11.6
                  Adapter    "blink4home"    : 0.1.1
                  Adapter    "bmw"           : 1.4.0
                  Adapter    "boblight"      : 0.0.1
                  Adapter    "bosesoundtouch": 0.9.2
                  Adapter    "botvac"        : 1.0.0
                  Adapter    "bring"         : 1.7.2
                  Adapter    "broadlink2"    : 2.0.3
                  Adapter    "bsblan"        : 0.1.2
                  Adapter    "bshb"          : 0.1.10
                  Adapter    "calendar"      : 1.2.0
                  Adapter    "cameras"       : 0.1.2
                  Adapter    "chromecast"    : 2.3.1
                  Adapter    "cloud"         : 3.0.3
                  Adapter    "comfoair"      : 1.1.1
                  Adapter    "contact"       : 1.1.3
                  Adapter    "contactid"     : 1.0.0
                  Adapter    "coronavirus-statistics": 0.5.9
                  Adapter    "corrently"     : 0.0.2
                  Adapter    "countdown"     : 1.1.0
                  Adapter    "cul"           : 1.2.1
                  Adapter    "daikin"        : 1.0.5
                  Adapter    "daswetter"     : 3.0.1
                  Adapter    "deconz"        : 1.3.9
                  Adapter    "denon"         : 1.7.7
                  Adapter    "devices"       : 0.3.6
                  Adapter    "digitalstrom"  : 2.0.5
                  Adapter    "discovergy"    : 0.5.4
                  Adapter    "discovery"     : 2.3.7    , installed 2.3.7
                  Adapter    "doorbird"      : 0.1.5
                  Adapter    "ds18b20"       : 1.1.4
                  Adapter    "dwd"           : 2.4.10
                  Adapter    "ebus"          : 2.0.0
                  Adapter    "ecovacs-deebot": 1.0.3
                  Adapter    "egigeozone"    : 0.1.2
                  Adapter    "ekey"          : 1.1.0
                  Adapter    "email"         : 1.0.7    , installed 1.0.7
                  Adapter    "emby"          : 1.0.2
                  Adapter    "energymanager" : 1.2.2
                  Adapter    "enet"          : 1.0.1
                  Adapter    "epson_stylus_px830": 0.2.1
                  Adapter    "exchangerates" : 0.0.13
                  Adapter    "fakeroku"      : 0.2.1
                  Adapter    "fb-checkpresence": 1.0.3
                  Adapter    "feiertage"     : 1.0.19
                  Adapter    "fhem"          : 1.5.2
                  Adapter    "find-my-iphone": 0.2.17
                  Adapter    "firetv"        : 1.0.0
                  Adapter    "fitbit-api"    : 0.1.1
                  Adapter    "flot"          : 1.10.0
                  Adapter    "foobar2000"    : 2.0.3
                  Adapter    "fritzbox"      : 0.2.1
                  Adapter    "fritzdect"     : 0.3.2
                  Adapter    "fronius"       : 1.0.5
                  Adapter    "fullcalendar"  : 1.1.0
                  Adapter    "fullybrowser"  : 1.0.3
                  Adapter    "g-homa"        : 0.5.3
                  Adapter    "geofency"      : 0.3.2
                  Adapter    "gruenbeck"     : 0.0.18
                  Adapter    "habpanel"      : 0.4.1
                  Adapter    "haier"         : 1.0.3
                  Adapter    "ham"           : 1.1.2
                  Adapter    "ham-wemo"      : 1.0.1
                  Adapter    "harmony"       : 1.2.2
                  Adapter    "hass-mqtt"     : 0.0.7
                  Adapter    "heatingcontrol": 0.5.6
                  Adapter    "heytech"       : 0.2.0
                  Adapter    "hid"           : 0.1.17
                  Adapter    "hilink"        : 0.2.7
                  Adapter    "history"       : 1.9.8    , installed 1.9.8
                  Adapter    "hm-rega"       : 2.6.14
                  Adapter    "hm-rpc"        : 1.14.10
                  Adapter    "hmip"          : 1.0.1
                  Adapter    "hombot"        : 0.1.3
                  Adapter    "homeconnect"   : 0.0.30
                  Adapter    "homee"         : 1.0.7
                  Adapter    "homepilot"     : 1.1.4
                  Adapter    "hp-ilo"        : 1.0.5
                  Adapter    "hs100"         : 2.0.0
                  Adapter    "hue"           : 3.3.5
                  Adapter    "hue-extended"  : 1.3.2
                  Adapter    "hyperion"      : 0.0.9
                  Adapter    "i2c"           : 0.0.6
                  Adapter    "ical"          : 1.7.0    , installed 1.7.0
                  Adapter    "icons-addictive-flavour-png": 0.1.0
                  Adapter    "icons-fatcow-hosting": 0.1.0
                  Adapter    "icons-icons8"  : 0.0.1
                  Adapter    "icons-material-png": 0.1.0
                  Adapter    "icons-material-svg": 0.1.0
                  Adapter    "icons-mfd-png" : 1.0.2
                  Adapter    "icons-mfd-svg" : 1.0.2
                  Adapter    "icons-open-icon-library-png": 0.1.2
                  Adapter    "icons-ultimate-png": 1.0.1
                  Adapter    "influxdb"      : 1.8.6
                  Adapter    "info"          : 1.7.5    , installed 1.7.5
                  Adapter    "innogy-smarthome": 0.3.4
                  Adapter    "intesishome"   : 0.1.2
                  Adapter    "iogo"          : 0.5.10
                  Adapter    "iot"           : 1.5.3    , installed 1.5.3
                  Adapter    "iqontrol"      : 1.1.0    , installed 1.1.0
                  Adapter    "javascript"    : 4.6.17   , installed 4.6.17
                  Adapter    "jeelink"       : 0.1.3
                  Controller "js-controller" : 3.1.5    , installed 3.1.5
                  Adapter    "js2fs"         : 0.1.5
                  Adapter    "kecontact"     : 0.1.0
                  Adapter    "klf200"        : 0.9.5
                  Adapter    "km200"         : 2.0.3
                  Adapter    "knmi-weather"  : 0.2.0
                  Adapter    "knx"           : 1.0.41
                  Adapter    "kodi"          : 2.0.4
                  Adapter    "kress"         : 2.5.5
                  Adapter    "lametric"      : 0.0.9
                  Adapter    "landroid"      : 1.0.3
                  Adapter    "lcn"           : 0.6.3
                  Adapter    "legrand-ecocompteur": 0.0.4
                  Adapter    "letrika_comgw" : 0.0.5
                  Adapter    "lgtv"          : 1.1.6
                  Adapter    "lgtv-rs"       : 0.1.0
                  Adapter    "lgtv11"        : 1.0.5
                  Adapter    "lifx"          : 0.1.1
                  Adapter    "lightify"      : 0.2.16
                  Adapter    "link"          : 0.5.9
                  Adapter    "linkeddevices" : 1.1.4
                  Adapter    "logparser"     : 0.4.11
                  Adapter    "lovelace"      : 1.1.0
                  Adapter    "loxone"        : 1.0.0
                  Adapter    "luftdaten"     : 0.0.15
                  Adapter    "lupusec"       : 1.2.7
                  Adapter    "luxtronik1"    : 0.2.3
                  Adapter    "material"      : 0.13.8
                  Adapter    "maxcube"       : 0.1.2
                  Adapter    "maxcul"        : 1.3.0
                  Adapter    "mbus"          : 2.2.0
                  Adapter    "mclighting"    : 0.1.1
                  Adapter    "megad"         : 1.2.1
                  Adapter    "megadd"        : 0.2.0
                  Adapter    "megaesp"       : 0.1.0
                  Adapter    "mercedesme"    : 0.0.21
                  Adapter    "mercury"       : 0.1.1
                  Adapter    "meross"        : 1.4.1
                  Adapter    "meteoalarm"    : 1.1.0
                  Adapter    "midea"         : 0.0.6
                  Adapter    "miele"         : 0.1.5
                  Adapter    "mielecloudservice": 1.2.4
                  Adapter    "mihome"        : 1.3.0
                  Adapter    "mihome-airpurifier": 0.1.8
                  Adapter    "mihome-lamp"   : 1.1.0
                  Adapter    "mihome-plug"   : 0.2.1
                  Adapter    "mihome-vacuum" : 2.0.7
                  Adapter    "miio"          : 0.0.13
                  Adapter    "mikrotik"      : 1.0.12
                  Adapter    "milight"       : 0.3.6
                  Adapter    "milight-smart-light": 0.6.0
                  Adapter    "mobile"        : 0.5.0
                  Adapter    "modbus"        : 3.1.3
                  Adapter    "moma"          : 1.2.6
                  Adapter    "mpd"           : 1.0.5
                  Adapter    "mqtt"          : 2.1.3
                  Adapter    "mqtt-client"   : 1.3.1
                  Adapter    "multicast"     : 0.1.5
                  Adapter    "musiccast"     : 0.1.3
                  Adapter    "mydlink"       : 1.1.2
                  Adapter    "myq"           : 0.1.1
                  Adapter    "mysensors"     : 2.0.1
                  Adapter    "myvbus"        : 0.0.6
                  Adapter    "nanoleaf-lightpanels": 0.8.2
                  Adapter    "nello"         : 2.0.8
                  Adapter    "netatmo"       : 1.3.1
                  Adapter    "nibeuplink"    : 0.3.0
                  Adapter    "nina"          : 0.0.23
                  Adapter    "node-red"      : 1.17.2
                  Adapter    "noolitef"      : 0.0.2
                  Adapter    "nuki"          : 1.2.3
                  Adapter    "nuki-extended" : 2.2.5    , installed 2.2.5
                  Adapter    "nut"           : 1.1.3
                  Adapter    "octoprint"     : 0.0.4
                  Adapter    "odl"           : 1.0.5
                  Adapter    "oilfox"        : 2.1.0
                  Adapter    "onkyo"         : 2.0.3
                  Adapter    "onvif"         : 0.4.3
                  Adapter    "openhab"       : 1.1.0
                  Adapter    "openligadb"    : 1.2.0
                  Adapter    "opentherm"     : 0.1.9
                  Adapter    "openweathermap": 0.1.0
                  Adapter    "opi"           : 0.1.1
                  Adapter    "oppoplayer"    : 0.2.1
                  Adapter    "owfs"          : 0.6.4
                  Adapter    "owntracks"     : 0.6.3
                  Adapter    "panasonic-viera": 1.0.2
                  Adapter    "parser"        : 1.0.7
                  Adapter    "paw"           : 0.3.2
                  Adapter    "phantomjs"     : 1.0.1
                  Adapter    "pi-hole"       : 1.2.3
                  Adapter    "piface"        : 1.0.0
                  Adapter    "pimatic"       : 0.3.0
                  Adapter    "ping"          : 1.4.7
                  Adapter    "places"        : 0.7.0
                  Adapter    "plenticore"    : 2.1.3
                  Adapter    "plex"          : 0.8.11
                  Adapter    "plexconnect"   : 0.0.7
                  Adapter    "pollenflug"    : 1.0.6
                  Adapter    "primelab"      : 1.0.2
                  Adapter    "proxmox"       : 1.0.2
                  Adapter    "proxy"         : 1.2.1
                  Adapter    "pushbullet"    : 0.0.11
                  Adapter    "pushover"      : 2.0.2
                  Adapter    "pushsafer"     : 0.1.8
                  Adapter    "radar2"        : 2.0.1
                  Adapter    "radiohead"     : 1.0.7
                  Adapter    "rainbird"      : 0.2.2
                  Adapter    "rflink"        : 2.1.5
                  Adapter    "rickshaw"      : 1.0.0
                  Adapter    "ring"          : 1.1.3
                  Adapter    "roadtraffic"   : 0.2.0
                  Adapter    "robonect"      : 0.1.3
                  Adapter    "roomba"        : 1.1.1
                  Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                  Adapter    "rssfeed"       : 0.0.28
                  Adapter    "s7"            : 1.1.8
                  Adapter    "samsung"       : 0.2.9
                  Adapter    "sanext"        : 0.0.4
                  Adapter    "sayit"         : 1.9.8
                  Adapter    "sbfspot"       : 3.0.0
                  Adapter    "scenes"        : 2.0.7    , installed 1.1.0 [Updateable]
                  Adapter    "schoolfree"    : 0.6.2
                  Adapter    "senec"         : 1.0.9
                  Adapter    "shelly"        : 3.3.1
                  Adapter    "shuttercontrol": 0.6.2
                  Adapter    "sia"           : 1.0.4
                  Adapter    "siegenia"      : 1.0.0
                  Adapter    "simple-api"    : 2.4.6    , installed 2.4.6
                  Adapter    "sma-em"        : 0.5.7
                  Adapter    "smappee"       : 0.2.2
                  Adapter    "smartmeter"    : 3.1.2
                  Adapter    "snips"         : 1.5.0
                  Adapter    "snmp"          : 0.5.0
                  Adapter    "socketio"      : 3.0.9    , installed 3.0.9
                  Adapter    "solarlog"      : 2.0.0
                  Adapter    "solarviewdatareader": 0.2.1
                  Adapter    "solarwetter"   : 1.0.0
                  Adapter    "sonnen"        : 1.5.2
                  Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                  Adapter    "sonos"         : 2.1.0    , installed 2.1.0
                  Adapter    "sonus"         : 0.1.1
                  Adapter    "sony-bravia"   : 1.0.1
                  Adapter    "sourceanalytix": 0.4.2
                  Adapter    "spotify-premium": 1.0.0
                  Adapter    "sql"           : 1.13.1
                  Adapter    "squeezebox"    : 1.0.0
                  Adapter    "squeezeboxrpc" : 1.2.1
                  Adapter    "starline"      : 1.0.0
                  Adapter    "statistics"    : 0.2.2
                  Adapter    "stiebel-isg"   : 1.4.11
                  Adapter    "stockmarket"   : 0.0.2
                  Adapter    "sunnyportal"   : 0.1.5
                  Adapter    "swiss-weather-api": 0.2.0
                  Adapter    "synology"      : 0.1.18
                  Adapter    "systeminfo"    : 0.3.1
                  Adapter    "tado"          : 0.1.9
                  Adapter    "tahoma"        : 0.3.3
                  Adapter    "tankerkoenig"  : 2.0.9
                  Adapter    "telegram"      : 1.5.9    , installed 1.5.9
                  Adapter    "terminal"      : 0.1.2
                  Adapter    "tesla-motors"  : 0.2.3
                  Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                  Adapter    "tileboard"     : 0.1.1
                  Adapter    "tinker"        : 1.1.0
                  Adapter    "tino"          : 0.1.3
                  Adapter    "tinyrx4"       : 0.1.5
                  Adapter    "tr-064"        : 4.0.7
                  Adapter    "tradfri"       : 2.6.3
                  Adapter    "trashschedule" : 0.0.9    , installed 0.0.9
                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                  Adapter    "tuya"          : 3.3.5
                  Adapter    "tvspielfilm"   : 2.0.1
                  Adapter    "unifi"         : 0.5.5
                  Adapter    "unifi-protect" : 0.0.11
                  Adapter    "upnp"          : 1.0.16
                  Adapter    "vaillant"      : 0.0.10
                  Adapter    "valloxmv"      : 1.0.3
                  Adapter    "vcard"         : 0.0.9
                  Adapter    "vedirect"      : 0.1.0
                  Adapter    "velux"         : 0.0.6
                  Adapter    "viessmann"     : 1.2.4
                  Adapter    "viessmannapi"  : 1.3.2
                  Adapter    "virtualpowermeter": 1.2.1
                  Adapter    "vis"           : 1.2.6    , installed 1.2.6
                  Adapter    "vis-bars"      : 0.1.4
                  Adapter    "vis-canvas-gauges": 0.1.5
                  Adapter    "vis-colorpicker": 1.2.0
                  Adapter    "vis-fancyswitch": 1.1.0
                  Adapter    "vis-google-fonts": 0.1.0
                  Adapter    "vis-history"   : 1.0.0
                  Adapter    "vis-hqwidgets" : 1.1.4    , installed 1.1.4
                  Adapter    "vis-inventwo"  : 1.3.8
                  Adapter    "vis-jqui-mfd"  : 1.0.12
                  Adapter    "vis-justgage"  : 1.0.2
                  Adapter    "vis-keyboard"  : 0.0.2
                  Adapter    "vis-lcars"     : 1.0.4
                  Adapter    "vis-map"       : 1.0.4
                  Adapter    "vis-material"  : 0.1.3
                  Adapter    "vis-material-webfont": 0.0.3
                  Adapter    "vis-materialdesign": 0.3.14
                  Adapter    "vis-metro"     : 1.1.2
                  Adapter    "vis-players"   : 0.1.6
                  Adapter    "vis-plumb"     : 1.0.2
                  Adapter    "vis-rgraph"    : 0.0.2
                  Adapter    "vis-timeandweather": 1.1.7
                  Adapter    "vis-weather"   : 2.5.2
                  Adapter    "vodafone-speedtest": 0.0.5
                  Adapter    "volvo"         : 0.0.2
                  Adapter    "vr200"         : 1.0.0
                  Adapter    "vw-connect"    : 0.0.16
                  Adapter    "weatherunderground": 3.2.1
                  Adapter    "web"           : 3.0.9    , installed 3.0.9
                  Adapter    "web-speedy"    : 0.2.0
                  Adapter    "weishaupt-wem" : 0.0.8
                  Adapter    "wiffi-wz"      : 2.2.0
                  Adapter    "wifilight"     : 1.1.0
                  Adapter    "windows-control": 0.1.3
                  Adapter    "wlanthermo-nano": 0.1.1
                  Adapter    "wled"          : 0.5.0
                  Adapter    "wm-bus"        : 0.3.1
                  Adapter    "wolf"          : 1.2.0
                  Adapter    "worx"          : 1.0.2
                  Adapter    "xbox"          : 0.6.5
                  Adapter    "xs1"           : 1.0.2
                  Adapter    "yahka"         : 0.11.0
                  Adapter    "yamaha"        : 0.3.19
                  Adapter    "yeelight-2"    : 1.0.3
                  Adapter    "youtube"       : 0.0.11
                  Adapter    "yr"            : 2.0.3
                  Adapter    "zigbee"        : 1.1.1    , installed 1.1.1
                  Adapter    "zoneminder"    : 0.3.3
                  Adapter    "zont"          : 0.5.4
                  Adapter    "zwave"         : 2.0.1
                  Adapter    "zwave2"        : 1.3.3
                  da ist auch nichts dabei was mein usb blockieren sollte.
                  lg
                  • G gifftstaub
                    update done
                    lg
                    @gifftstaub
                    Deaktivier mal den 'discovery' Adapter. Soweit ich weiß fragt der auch den serialport an.
                      @gifftstaub
                      gifftstaub
                      schrieb am zuletzt editiert von gifftstaub
                      @Thomas-Braun said in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                      @gifftstaub
                      nein das liegt nicht am 'discovery' Adapter Serial ist nicht angehackt.
                      lg
                      Edit: Morgen kommt ein neuer USB Stick bericht folgt.
                      • G Offline
                        gifftstaub
                        Nabend Zusammen,
                        Kurzes Feedback zum Porblem mit dem CC2531 Stick.
                        Alte Stick ist Platt keine Ahnung wie das Passiert ist.
                        Neuer Stick ran und siehe da läuft Sofort mit Adapter ( Zigbee 1.1.1 ) und folgende Komponenten.
                        JS controller: 3.1.5
                        Node : v12.18.0
                        Node.js: v12.18.0
                        NPM: 6.14.4
                        Ich möchte mich bei allem sehr bedanken für die Hilfestellung 👍
                        lg
                        • P Offline
                          P-A-L-A-D-I-N
                          Ich kann neuerdings meine Zigbee-Geräte nicht mehr steuern. In den Objekten werden auch falsche Angaben gemacht bez. ein/aus, Temperatur etc.
                          Am System oder Adapter habe ich nichts verändert! Da Neustarts etc. nichts gebracht haben, habe ich dann von Github die neueste Version gezogen - hat aber auch nichts gebracht.
                          Hier das Log, wenn ich versuche, mein Arbeitszimmerlicht zu schalten:
                          zigbee.0	2020-06-17 22:35:45.628	error	(10296) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"s
                          zigbee.0	2020-06-17 22:35:41.258	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65)
                          zigbee.0	2020-06-17 22:35:41.258	error	at Generator.throw (<anonymous>)
                          zigbee.0	2020-06-17 22:35:41.258	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:365:23)
                          zigbee.0	2020-06-17 22:35:41.258	error	(10296) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,
                          fritzdect.0	2020-06-17 22:35:15.828	warn	(12152) DECT200_34:31:C4:D3:D6:E3 is not present, check the device connection, no values are written
                          Wäre toll, wenn mir jemand helfen könnte!
                          JB_SullivanJ ldittmarL 2 Antworten Letzte Antwort
                          • P P-A-L-A-D-I-N
                            JB_SullivanJ Offline
                            JB_Sullivan
                            @P-A-L-A-D-I-N
                            ggf. ein COM Port Problem? Hatte ich auch nach nodesjs Update auf 12.18 mit rflink.
                            npm rebuild gemacht bzw. npm install serialport --build-from-source?
                            P 1 Antwort Letzte Antwort
                            • JB_SullivanJ JB_Sullivan
                              @P-A-L-A-D-I-N
                              P-A-L-A-D-I-N
                              schrieb am zuletzt editiert von P-A-L-A-D-I-N
                              @JB_Sullivan sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                              Hat leider nichts gebracht! Ich mache jetzt aber mal sicherheitshalber noch einen Neustart und schaue dann nochmal.
                              EDIT: Neustart hat auch nichts gebracht. Scheinbar besteht keine Verbindung mehr zu den Zigbee-Geräten, obwohl der Port stimmt. In der Übersicht bei "Netzwerkkarte" ist auch alles auf rot und es sind keinerlei Verbindungen mehr zu den Geräten eingezeichnet.
                              • P Offline
                                P-A-L-A-D-I-N
                                Das Aus- und Einstecken des USB-Adapters hat kurzzeitig geholfen - die Geräte waren in der Übersicht wieder zu sehen. Allerdings war die Freude nur von sehr, sehr kurzer Dauer. Jetzt ist wieder alles weg...
                                Hier noch das Log des letzten Schaltversuchs:
                                zigbee.0	2020-06-19 11:53:55.434	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                zigbee.0	2020-06-19 11:53:51.065	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"s
                                zigbee.0	2020-06-19 11:53:25.956	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65))
                                zigbee.0	2020-06-19 11:53:25.956	error	at Generator.throw (<anonymous>)
                                zigbee.0	2020-06-19 11:53:25.956	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:255:23)
                                zigbee.0	2020-06-19 11:53:25.956	error	(19452) Failed to configure 0x000d6f000fabe64e COSensor-EM, attempt 1 (Error: Bind 0x000d6f000fabe64e/1 genPowerCfg from '0x00124b0018e20893/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
                                zigbee.0	2020-06-19 11:53:15.837	info	(19452) Zigbee started
                                zigbee.0	2020-06-19 11:53:15.837	info	(19452) 0x00158d0003cefef4 (addr 33236): LLKZMK11LM - Xiaomi Aqara wireless relay controller (Router)
                                zigbee.0	2020-06-19 11:53:15.835	info	(19452) 0x000d6f000fabe64e (addr 36585): HS1CA-E - HEIMAN Smart carbon monoxide sensor (EndDevice)
                                zigbee.0	2020-06-19 11:53:15.834	info	(19452) 0x00158d000340d5ad (addr 663): JTQJ-BF-01LM/BW - Xiaomi MiJia gas leak detector (Router)
                                zigbee.0	2020-06-19 11:53:15.833	info	(19452) 0x7cb03eaa0a01e0f8 (addr 58413): AB3257001NJ - OSRAM Smart+ plug (Router)
                                zigbee.0	2020-06-19 11:53:15.832	info	(19452) 0x7cb03eaa0a01bfef (addr 53682): AB3257001NJ - OSRAM Smart+ plug (Router)
                                zigbee.0	2020-06-19 11:53:15.831	info	(19452) 0x84182600000f3893 (addr 44117): AB3257001NJ - OSRAM Smart+ plug (Router)
                                zigbee.0	2020-06-19 11:53:15.830	info	(19452) 0x00158d00036b9140 (addr 15766): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0	2020-06-19 11:53:15.829	info	(19452) 0x00158d00032300c0 (addr 12784): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0	2020-06-19 11:53:15.828	info	(19452) 0x00158d000349c4d0 (addr 4916): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0	2020-06-19 11:53:15.824	info	(19452) Configuring 0x000d6f000fabe64e COSensor-EM
                                zigbee.0	2020-06-19 11:53:15.818	info	(19452) Currently 9 devices are joined:
                                zigbee.0	2020-06-19 11:53:15.764	info	(19452) --> transmitPower : normal
                                zigbee.0	2020-06-19 11:53:15.740	info	(19452) Disable LED
                                zigbee.0	2020-06-19 11:53:15.689	info	(19452) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190425}}
                                zigbee.0	2020-06-19 11:53:13.296	info	(19452) Starting Zigbee...
                                zigbee.0	2020-06-19 11:53:13.237	info	(19452) starting. Version 1.1.1 in C:/ioBroker/Zuhause/node_modules/iobroker.zigbee, node: v12.18.0, js-controller: 3.1.4
                                • P Offline
                                  P-A-L-A-D-I-N
                                  Noch ein Nachtrag (wegen der Übersichtlichkeit als getrennter Beitrag):
                                  In der Übersicht des Adapters ("Netzwerkkarte") waren die Geräte zwischenzeitlich, auch ohne Aus- und Einstecken des USB-Sticks, wieder grün und um den Coordinator herum versammelt. Aber: Das Licht läßt sich trotzdem, auch in diesem Zustand, nicht schalten.
                                  Hier noch das Log des Schaltversuchs (im o.g. Zustand mit grünen Verbindungen in der Übersicht):
                                  info.0	2020-06-19 13:14:30.839	info	(11556) Popup news was read...
                                  zigbee.0	2020-06-19 13:14:21.861	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                  zigbee.0	2020-06-19 13:14:17.316	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65)
                                  zigbee.0	2020-06-19 13:14:17.316	error	at Generator.throw (<anonymous>)
                                  zigbee.0	2020-06-19 13:14:17.316	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:365:23)
                                  zigbee.0	2020-06-19 13:14:17.316	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                  info.0	2020-06-19 12:44:30.904	info	(11556) Popup news was read...
                                  Es muß also irgendetwas mit diesem verfluchten JS- und Node-Gelump zu tun haben - wie eigentlich immer, wenn es mal wieder klemmt!
                                  Keine Ahnung, warum die Entwickler des ioBroker nicht einfach mal eine stabile Version bestehen lassen und man da ständig irgendwas herumbasteln muß! Mich als einfachen Nutzer kotzt das alles jedenfalls einfach nur noch tierisch an! Ich möchte keine abgehobenen Schickimickisachen machen und auf Teufel komm raus den allerneusten "Controller XY, Node, NPM, WeißderTeufelwas" da stehen haben, sondern einfach nur ein stabiles, gerne auch "veraltetes", System betreiben, das solide seine Arbeit verrichtet! Es kann ja wohl nicht sein, daß ich alle zwei Wochen spätestens wieder stundenlang dasitze und auf Fehlersuche gehen muß, nur weil wieder irgendein verk... Update (wohlgemerkt auf "default", nicht auf "latest") alles zerschossen hat und meine ganze Beleuchtung oder irgendein anderes Zeug dann nicht mehr funktioniert! 👿
                                  arteckA apollon77A 2 Antworten Letzte Antwort
                                  • P P-A-L-A-D-I-N
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @P-A-L-A-D-I-N also an der node12 liegts nicht.. allerdings auf Linux
                                    @P-A-L-A-D-I-N sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                                    und wo ist das Problem.. hättest einfach alles so bestehen lassen wie es war.. also was regst dich auf ??
                                    wenn dich das System so ankotzt.. es gibt genug käufliche Systeme wo du für Support bezahlst.. also WO IST DAS PROBLEM
                                    ausserdem wen man mit BILLIG WARE, was du vor dir liegen hast laut dem Log
                                    also ein CC2531 zusätzlich mit einer Firmware von April die ehhh kaputt war, da wir ein BUG hatten versuch ein System aufzubauen was stabil laufen soll.. na dann holla im Not..
                                    also besorg dir erstmal ordentliche Hardware es gibt genug alternativen im Marktplatz
                                    dann bringst dein System zum laufen und dann und NUR DANN wenns nicht läuft dann kannst du MICH UND NUR MICH wenns um Zigbee geht anpöbeln.. ansonsten erspare mir dein Palaver...
                                    • Thomas BraunT Online
                                      An node 14 und js-controller 3.1.6 liegt es auch nicht (wiederum auf Linux):
                                      2020-06-19 15:22:11.887  - info: host.brokerslave "system.adapter.zigbee.0" enabled
                                      2020-06-19 15:22:11.995  - info: host.brokerslave instance system.adapter.zigbee.0 started with pid 19145
                                      2020-06-19 15:22:16.343  - info: zigbee.0 (19145) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.4.0, js-controller: 3.1.6
                                      2020-06-19 15:22:16.439  - info: zigbee.0 (19145) Starting Zigbee...
                                      2020-06-19 15:22:17.021  - info: zigbee.0 (19145) Coordinator firmware version: {"type":"RaspBee","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":53,"maintrel":0,"revisio
                                      n":"0x26350500"}}
                                      2020-06-19 15:22:17.227  - info: zigbee.0 (19145) Unable to disable LED, unsupported function.
                                      2020-06-19 15:22:17.228  - info: zigbee.0 (19145)   --> transmitPower : normal
                                      2020-06-19 15:22:17.231  - info: zigbee.0 (19145) Unable to set transmit power, unsupported function.
                                      2020-06-19 15:22:17.234  - info: zigbee.0 (19145) Currently no devices.
                                      2020-06-19 15:22:17.236  - info: zigbee.0 (19145) Zigbee started
                                        n":"0x26350500"}}
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @Thomas-Braun das ist der cc2531 in Verbindung mit der Firmware vom April 2019
                                        • arteckA arteck
                                          @arteck sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                                          Bei mir nicht. Hier werkelt ein RaspBee mit der letzten Firmware. ;-)
