Homematic IP Einbindung
Also habe heute meine neue Funk-Schalt-Messsteckdose aus der Homematic IP Serie bekommen.
Direktes Anlernen an der CCU2 ging schnell und problemlos.
Kann sie auch schalten aus der CCU2.
Im ioBroker dann eine neue Instanz von hm-rpc auf Port 2010 angelegt und die Steckdose ist im ioBroker!
Habe diese auch nur einmal drin - nicht doppelt.
Super!
Einzig im Log stehen ein paar Warnings:
hm-rpc-1 2016-04-27 19:21:31 info starting. Version 1.1.3 in C:/ioBroker/node_modules/iobroker.hm-rpc
hm-rpc-1 2016-04-27 19:21:28 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
hm-rpc-1 2016-04-27 19:21:28 info setObject hm-rpc.meta.VALUES.HMIP-PSM.COND_SWITCH_TRANSMITTER.1
hm-rpc-1 2016-04-27 19:21:27 info xmlrpc -> getParamsetDescription ["0001D3C990BC12:7","VALUES"]
hm-rpc-1 2016-04-27 19:21:27 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"FREQUENCY":{"MAX":70.47,"UNIT":"Hz","CONTROL":"POWERMETER_PSM.FREQUENCY","M
hm-rpc-1 2016-04-27 19:21:27 info setObject hm-rpc.meta.VALUES.HMIP-PSM.ENERGIE_METER_TRANSMITTER.1
hm-rpc-1 2016-04-27 19:21:27 info xmlrpc -> getParamsetDescription ["0001D3C990BC12:6","VALUES"]
hm-rpc-1 2016-04-27 19:21:27 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"MAX":true,"CONTROL":"SWITCH.STATE","MIN":false,"ID":"STATE","OPERA
hm-rpc-1 2016-04-27 19:21:27 info setObject hm-rpc.meta.VALUES.HMIP-PSM.SWITCH_VIRTUAL_RECEIVER.1
hm-rpc-1 2016-04-27 19:21:27 info xmlrpc -> getParamsetDescription ["0001D3C990BC12:3","VALUES"]
hm-rpc-1 2016-04-27 19:21:27 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"MAX":true,"MIN":false,"ID":"STATE","OPERATIONS":5,"FLAGS":1,"DEFAU
hm-rpc-1 2016-04-27 19:21:27 info setObject hm-rpc.meta.VALUES.HMIP-PSM.SWITCH_TRANSMITTER.1
hm-rpc-1 2016-04-27 19:21:26 info xmlrpc -> getParamsetDescription ["0001D3C990BC12:2","VALUES"]
hm-rpc-1 2016-04-27 19:21:26 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESS_LONG":{"MAX":true,"CONTROL":"BUTTON_NO_FUNCTION.LONG","MIN":false,"ID
hm-rpc-1 2016-04-27 19:21:26 info setObject hm-rpc.meta.VALUES.HMIP-PSM.KEY_TRANSCEIVER.1
hm-rpc-1 2016-04-27 19:21:26 info xmlrpc -> getParamsetDescription ["0001D3C990BC12:1","VALUES"]
Dahätte ich auch selber drauf kommen können :roll: filename="Bildschirmfoto 2016-04-27 um 18.17.32.png" index="1">~~
Die Einträge sin aber leider doppelt und 3 fach filename="Bildschirmfoto 2016-04-27 um 18.16.50.png" index="1">~~ich kann hm ip schalten Danke `
Ich habe es genau so eingestellt wie du es beschrieben hast. Bei mir geht es nicht. filename="2016-05-24 18_04_34-ioBroker.admin.png" index="0">~~ filename="2016-05-24 17_59_45-ioBroker.admin.png" index="1">~~
Ich habe es genauso wie du eingetragen, bekommen aber anscheinend keine Verbindung zum Port 2010.
nmap sagt mir komischerweise etwas von Mail auf Port 2010:
2010/tcp open http Mercury/32 Mail Transport httpd
|_hadoop-datanode-info:
|_hadoop-jobtracker-info:
|_hadoop-tasktracker-info:
|_hbase-master-info:
|_http-favicon: Unknown favicon MD5: D41D8CD98F00B204E9800998ECF8427E
| http-methods:
|_ Supported Methods: GET HEAD POST OPTIONS
|_http-title: Site doesn't have a title.
filename="2016-05-24 18_13_22-ioBroker.admin.png" index="0">~~
filename="2016-05-24 17_59_45-ioBroker.admin.png" index="1">~~nmap sagt mir komischerweise etwas von Mail auf Port 2010:
|_hbase-master-info:
| http-methods:
|_http-title: Site doesn't have a title. `
Da hat er xmlrpc benutzt. Bei dir steht binrpc. Vielleicht liegt es daran? -
Hallo Bluefox,
du hast nochne PN im HM Forum ;-)
http://homematic-forum.de/forum/viewtop … 11#p274945
allerdings auf den ersten Blick alles doppelt.
Und derzeit keine Werte zu den kanälen - abwarten … `
Bluefox hat gerade eine neue Version zum testen in Github eingestellt.Habe sie gerade installiert, wird wohl in den nächsten Tagen freigegeben.
Wie bekommt man jetzt die Namen zu den Seriennummern? `
Die hm-rega Instanz bitte restarten, wenn neue Geräte eingelesen oder installiert wurden.Gruß
Dann ist dein Rechner zu langsam ;-)
Nicht der ioBroker Server (der RasPi3), sondern der auf dem du arbeitest.
Es kommt manchmal vor, dass die responsezeit für das js dann zu lange dauert.
Wenn es nur manchmal vorkommt keine Panik, wenn regelmäßig nitte beobachten, ob da ein System bei ist. Sollte nicht der Fall sein.
Hallo
ich bin noch auf der Suche nach den Namen der HMIP Geräte
Ich habe zusätzlich einen hm-rega.1 Adapter eingerichtet. Der greift auf den hm-rpc1 zu , welcher auf Port 2010 XML konfiguriert ist.
Leider werden so die Namen der HMIP Geräte auch nicht geholt und die Namen der normalen HM Geräte werden noch mal aus gelesen :(
PS ja hm-rega1 war inzwischen auch mal grün :)
Hallo
PS ja hm-rega1 war inzwischen auch mal grün :) `
Habe selber keine IP-Geräte daher kein test aber mal so n Gedanke….
Da du die Geräte doppelt siehst, liegt das nicht an dem RPC ? Kann mir vorstellen das dein 2ter RPC auf port 2010 die IP-Geräte & Bidcos Geräte weiter gibt.
Probier doch mal den ersten aus zu schalten und nur dem neuen port verbinden vielleicht hilft das ?
Hallo
erst mal meine derzeitige Konfig.
Ein rpc auf Port 2001 für HM Classic
Ein rpc auf Port 2010 für HMIP
Den Versuch die Namen über einen zweiten HM rega zu holen, habe ich gestrichen.
Im Log File habe ich jetzt Einträge entdeckt, die mir nicht gefallen.
Das die Bilder für die HMIP Geräte nicht gefunden werden, ist mir klar und wird ich dann in Zukunft wohl auch geben.
hm-rpc-1 2016-06-08 23:01:50.091 warn No image for "HMIP-eTRV" found. hm-rpc-1 2016-06-08 23:01:50.090 warn No image for "HMIP-SWDO" found. hm-rpc-1 2016-06-08 23:01:50.089 warn No image for "HMIP-WTH" found.Andere Einträge müllen mit allerdings das Log File voll :(
hm-rpc-1 2016-06-08 23:01:50.088 info xmlrpc <- newDevices 20 hm-rpc-1 2016-06-08 23:01:49.579 info device 000313C9906EDE deleted Delete 2016-06-08 23:01:49.579 info channel hm-rpc.1.000313C9906EDE.0 hm-rpc-1 2016-06-08 23:01:49.579 info channel 000313C9906EDE.0 "000313C9906EDE.0" deleted Delete 2016-06-08 23:01:49.578 info channel hm-rpc.1.000313C9906EDE.1 hm-rpc-1 2016-06-08 23:01:49.578 info channel 000313C9906EDE.1 "000313C9906EDE.1" deleted Delete 2016-06-08 23:01:49.578 info channel hm-rpc.1.000313C9906EDE.2 hm-rpc-1 2016-06-08 23:01:49.578 info channel 000313C9906EDE.2 "000313C9906EDE.2" deleted Delete 2016-06-08 23:01:49.578 info channel hm-rpc.1.000313C9906EDE.3 hm-rpc-1 2016-06-08 23:01:49.577 info channel 000313C9906EDE.3 "000313C9906EDE.3" deleted Delete 2016-06-08 23:01:49.577 info channel hm-rpc.1.000313C9906EDE.4 hm-rpc-1 2016-06-08 23:01:49.577 info channel 000313C9906EDE.4 "000313C9906EDE.4" deleted Delete 2016-06-08 23:01:49.577 info channel hm-rpc.1.000313C9906EDE.5 hm-rpc-1 2016-06-08 23:01:49.576 info channel 000313C9906EDE.5 "000313C9906EDE.5" deleted Delete 2016-06-08 23:01:49.576 info channel hm-rpc.1.000313C9906EDE.6 hm-rpc-1 2016-06-08 23:01:49.576 info channel 000313C9906EDE.6 "000313C9906EDE.6" deleted hm-rpc-1 2016-06-08 23:01:49.575 info device 0000D3C98C9B3A deleted Delete 2016-06-08 23:01:49.575 info channel hm-rpc.1.0000D3C98C9B3A.0 hm-rpc-1 2016-06-08 23:01:49.575 info channel 0000D3C98C9B3A.0 "0000D3C98C9B3A.0" deleted Delete 2016-06-08 23:01:49.575 info channel hm-rpc.1.0000D3C98C9B3A.1 hm-rpc-1 2016-06-08 23:01:49.574 info channel 0000D3C98C9B3A.1 "0000D3C98C9B3A.1" deleted hm-rpc-1 2016-06-08 23:01:49.574 info device 000393C98D1E6A deleted Delete 2016-06-08 23:01:49.574 info channel hm-rpc.1.000393C98D1E6A.0 hm-rpc-1 2016-06-08 23:01:49.573 info channel 000393C98D1E6A.0 "000393C98D1E6A.0" deleted Delete 2016-06-08 23:01:49.573 info channel hm-rpc.1.000393C98D1E6A.1 hm-rpc-1 2016-06-08 23:01:49.573 info channel 000393C98D1E6A.1 "000393C98D1E6A.1" deleted Delete 2016-06-08 23:01:49.573 info channel hm-rpc.1.000393C98D1E6A.2 hm-rpc-1 2016-06-08 23:01:49.572 info channel 000393C98D1E6A.2 "000393C98D1E6A.2" deleted Delete 2016-06-08 23:01:49.572 info channel hm-rpc.1.000393C98D1E6A.3 hm-rpc-1 2016-06-08 23:01:49.572 info channel 000393C98D1E6A.3 "000393C98D1E6A.3" deleted Delete 2016-06-08 23:01:49.571 info channel hm-rpc.1.000393C98D1E6A.4 hm-rpc-1 2016-06-08 23:01:49.571 info channel 000393C98D1E6A.4 "000393C98D1E6A.4" deleted Delete 2016-06-08 23:01:49.570 info channel hm-rpc.1.000393C98D1E6A.5 hm-rpc-1 2016-06-08 23:01:49.569 info channel 000393C98D1E6A.5 "000393C98D1E6A.5" deleted hm-rpc-1 2016-06-08 23:01:49.568 info xmlrpc <- deleteDevices 18 hm-rpc-1 2016-06-08 23:01:49.406 info xmlrpc -> 18 devices hm-rpc-1 2016-06-08 23:01:49.314 info xmlrpc <- listDevices ["hm-rpc.1"]Und das etwa alle 5 min :(
Du kannst die loglevel für jeden einzelnen Adapter und da sogar für jede einzelne Instanz einstellen.
dazu gehst du auf den Reiter Instanzen, wählst ganz oben links das Icon admin ("Männchen") aus und suchst dir dann deinen gewünschten loglevel in der Spalte "log Stufe" aus.
alternativ kannst du dir einfach im pulldown des logs die logstufen für alle instanzen filtern
Probier doch mal den ersten aus zu schalten und nur dem neuen port verbinden vielleicht hilft das ? `
Hallo
Wenn ich nur einen RPC auf PORT 2010 XML laufen lasse und Rega darauf zugreift, dann habe ich zwar die normalen HM UND die HMIP Geräte, aber Namen für die HMIP Geräte habe ich trotz dem nicht.
Und XML ist für die CCU nicht so toll, oder?
Jedenfalls ist das auch nicht die Lösung.
Spannend ist nur, dass auf Port 2010 die ganzen nicht HMIP Geräte auch noch mal raus geliefert werden. Das soll bestimmt nicht so sein :( Aber mit den Schnittstellen der CCU müssen sich wohl eher Anwendungsprogrammierer auseinander setzen …
Spannend ist nur, dass auf Port 2010 die ganzen nicht HMIP Geräte auch noch mal raus geliefert werden. Das soll bestimmt nicht so sein :( Aber mit den Schnittstellen der CCU müssen sich wohl eher Anwendungsprogrammierer auseinander setzen … `
Bluefox ist dran, hat gerade eine Vorabversion in Arbeit, in der dann IP mit abgedeckt sein soll.Ich fürchte nur, dass auch er keine Hardware zum Testen hat.
Rainer `
Hallo
Testen ist kein Problem.
Ich hatte mir 2 HMIP-PSM und jeweils einen Wand und Heizungsthermostaten geholt. Mangels vollständiger Softwareunterstützung durch die CCU wird die Gewährleistung abgelaufen sein, bevor die Geräte ein mal vollständig funktioniert haben :(
Nur ein HMIP TFK ist mit mäßigem Erfolg im Einsatz. Der ist zu weit weg von der CCU und die Lan Adapter können kein HMIP :(
Eigentlich alles Gründe derzeit einen weiten Bogen um HMIP zu machen. Aber das ist ein anderes Thema …
