  • B bishop
    @simatec
    läuft soweit alles gut bei mir mit Shuttercontrol.
    Nur heute morgen ist der Rollladen im Schlafzimmer nicht hochgefahren wie normal immer um 8:30Uhr.
    Kann es daran liegen das meine Frau nachts das Fenster auf gemacht hat dadurch der Rollladen dann ein stück hochfährt damit Luft rein kommt.
    Ist somit die Automatik zum morgens Hochfahren ausgeschalten?
     "enabled": true,
            "shutterName": "Schlafzimmer",
            "name": "sonoff.0.RolladenSchlafzimmer.ShutterPosition1",
            "triggerID": "zigbee.0.00158d000276c5c2.opened",
            "typeUp": "sleep",
            "typeDown": "sunset",
            "type": "outside temperature and direction",
            "heightDownSun": "5",
            "direction": "245",
            "directionRange": "45",
            "tempInside": "23",
            "tempSensor": "",
            "outsideTempSensor": "sonoff.0.Hochbeet94.BME280_Temperature",
            "tempOutside": "27",
            "lightSensor": "javascript.0.Sonne.sonne_hinten",
            "valueLight": "5",
            "heightUp": "100",
            "heightDown": "0",
            "triggerState": "false",
            "triggerDrive": "5",
            "triggerChange": "onlyUp",
            "elevation": "8",
            "autoDrive": "off",
            "hysteresisOutside": "10",
            "hysteresisInside": "5",
            "hysteresisLight": "0",
            "currentAction": "",
            "currentHeight": "",
            "oldHeight": "",
            "firstCompleteUp": "",
            "triggerHeight": ""
    "native": {
        "livingAutomatic": "livingSunriseSunset",
        "W_shutterDownLiving": "21:00",
        "WE_shutterDownLiving": "21:00",
        "WE_shutterUpLiving": "07:30",
        "W_shutterUpLivingMin": "06:50",
        "W_shutterUpLivingMax": "06:55",
        "driveDelayUpLiving": "2",
        "sleepAutomatic": "sleepSunriseSunset",
        "W_shutterDownSleep": "19:00",
        "WE_shutterDownSleep": "19:15",
        "WE_shutterUpSleep": "08:30",
        "W_shutterUpSleepMin": "06:20",
        "W_shutterUpSleepMax": "06:30",
        "driveDelayUpSleep": "2",
        "latitude": "47.18669",
        "longitude": "7.23639",
        "astroDelayUp": "0",
        "astroDelayDown": "-15",
        "driveDelayUpAstro": "2",
        "sunProtEndElevation": "10",
        "currentShutterState": true,
        "publicHolidays": true,
        "publicHolInstance": "feiertage.0",
        "triggerAutoSleep": "",
        "triggerAutoLiving": "",
        "direction": "245",
        "actualValueTemp": "sonoff.0.Hochbeet94.BME280_Temperature",
        "actualValueLight": "javascript.0.Sonne.sonne_hinten",
        "actualValueTempInside": "",
        "typeUp": "sleep",
        "triggerStateShutter": "false",
        "triggerChangeShutter": "onlyUp",
        "triggerDriveShutter": "5",
        "autoDriveShutter": "off",
        "heightDownShutter": "0",
        "heightUpShutter": "100",
        "events": [
    sollte das Hochfahren normal immer funktionieren?
    FredFF Online
    FredFF Online
    FredF
    Most Active Forum Testing
    #1942
    @bishop
    Den Automatikbetrieb bei Triggerabweichung mit Auf und Ab einstellen dann sollte es gehen
      MartyBr
      #1943
      @simatec
      Hallo simatec, jetzt bei den hohen Temperaturen und der Sonneneinstrahlung hat der shuttercontrol seine "Beschattungs-Taufe" erhalten. Ich nehme hier die Himmelrichtung, die Differenztemperatur des Weathermans und die Innentemperatur als Trigger.
      Es funktioniert alles !!!!! 👍
      Herzlichen Dank auch von mir für den genialen Adapter.
      Martin
      Homematic und Homematic IP
      • M MartyBr
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #1944
        @MartyBr
        Bei mir läuft er auch seit über einem Jahr Produktiv und tut das was er soll ;-)
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • L Offline
          lonsimbt
          #1945
          auch bei mir läuft shuttercontrol grundsätzlich. Ich würde mir aber wünschen, dass die Rolläden erst beim Unterschreiten einer bestimmten Helligkeit gefahren werden können.
          Probleme macht bei mir aber noch der Sonnenschutz. Insbesondere meine Markise will nicht fahren. Hier der Auszug aus dem LOG:
          2020-06-02 15:04:23.919 - debug: shuttercontrol.0 (9220) outsidetemperature changed: hm-rpc.0.OEQ0675239.2.TEMPERATURE Value: 29.5
          2020-06-02 15:04:23.919 - debug: shuttercontrol.0 (9220) Lightsensor changed: hm-rpc.0.OEQ0675239.3.TEMPERATURE Value: 30.1
          2020-06-02 15:05:00.001 - debug: shuttercontrol.0 (9220) calculate astrodata ...
          2020-06-02 15:05:00.001 - debug: shuttercontrol.0 (9220) Sun Azimut: 221.3°
          2020-06-02 15:05:00.002 - debug: shuttercontrol.0 (9220) Sun Elevation: 55.5°
          Und hier die Konfiguration der Markise:
                  "enabled": true,
                  "shutterName": "Markise_EZ:1.LEVEL",
                  "name": "hm-rpc.0.MEQXXXXXXX.1.LEVEL",
                  "triggerID": "",
                  "typeUp": "off",
                  "typeDown": "off",
                  "heightDownSun": "40",
                  "direction": "250",
                  "directionRange": "30",
                  "tempInside": "",
                  "tempSensor": "",
                  "outsideTempSensor": "",
                  "tempOutside": "",
                  "lightSensor": "hm-rpc.0.OEQXXXXXXX.3.TEMPERATURE",
                  "valueLight": "20",
                  "heightUp": "100",
                  "heightDown": "0",
                  "triggerState": "true",
                  "triggerDrive": "100",
                  "triggerChange": "off",
                  "elevation": "",
                  "autoDrive": "off",
                  "hysteresisOutside": "",
                  "hysteresisInside": "",
                  "hysteresisLight": "5",
                  "oldHeight": "",
                  "triggerHeight": ""
          Mi dem Überschreiten des Azimuts von 220 hätte nach meinem Verständnis die Markise, die zu dem Zeitpunkt komplett eingefahren war (100 %), fahren sollen. Das hat sie aber nicht getan. Hat jemand eine Idee?
          Gruß Marco
          iobroker im Container (debian Bullseye) unter proxmox 7.1
          debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
          40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
          • simatecS simatec
            @MartyBr
            MartyBr
            #1946
            @simatec
            Ich benötigte die drei Werte Himmelsrichtung, die Differenztemperatur des Weathermans und die Innentemperatur in einer <und> Verknüpfung.
            Ich werde mir noch ein Script schreiben, um die Differenztemperatur in Abhängigkeit von der Außentemperatur zu erhalten. Bei 30°C Außentemperatur erhalte ich niedrigere Diff.Temperature als bei 10°C bei gleicher Sonneneinstrahlung. Im ersten Fall will ich Beschatten, im zweiten Fall nutze ich die Sonnenenergie als Wärmequelle für das Haus.
            Aber mit der und-Funktion kann ich den Adapter nun produktiv nutzen.
            Martin
              dj.tifosi
              schrieb am zuletzt editiert von dj.tifosi
              #1947
              leider haben Shuttercontrol und ich ein paar Anlaufschwierigkeiten:
              Und zwar hat heute der Aussperrschutz versagt, der eigentlich aufgrund des geöffneten Fensters den Sonnenschutz aussetzen sollte. Und ich frage mich, war das ein Anwenderfehler von mir oder ein Bug?
              Der Fehler ist folgendermaßen entstanden:
              • Ausgangssituation: Rolladen der Küchenbalkontür war in Sonnenschutz-Position (30 % Behanghöhe)
              • 18:51 Uhr: Frau fuhr manuell (über Taster am Aktor) das Küchenrollo hoch und öffnete die Balkontür (Position vom Drehgriff mit Homematic Fensterdrehgriffsensor von geschlossen auf offen gedreht)
              • 18:55 Uhr: Ohne Zutun fuhr der Rolladen wieder auf 30 % Behanghöhe
              • 18:58 Uhr: Ich schloss und öffnete anschließend das Küchenfenster -> Folglich öffnete der Rolladen wie gewünscht auf 100 % Behangöhe wegen der Statusänderung am Fensterdrehgriffsensor (vgl. Config "autoDrive": "upDown")
              • 19:00 Uhr Ohne etwas geändert zu haben, fuhr erneut der Rolladen wieder auf 30 % Behanghöhe und sperrte meine Frau, die inzwischen auf den Balkon gelaufen war aus, die sich sehr darüber freute, zum Glück war ich noch drinnen und konnte eingreifen :-P
              Ich poste mal das zugehörige Log (habe den Adapter anschließend runter gefahren, damit der Haussegen nach diesem Negativerlebnis nicht weiter schief hängt):
              2020-06-02 18:51:52.704  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:51:59.036  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) TriggerID changed: hm-rpc.1.LEQ1251236.1.STATE
              2020-06-02 18:51:59.039  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) save trigger height: 42%
              2020-06-02 18:51:59.039  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Set ID: Rolladenaktor Küche.LEVEL value: 100%
              2020-06-02 18:51:59.041  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:51:59.307  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:52:12.194  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:55:00.003  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Sun Azimut: 282.1°
              2020-06-02 18:55:00.003  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Sun Elevation: 19°
              2020-06-02 18:55:02.009  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Sunprotect for Rolladenaktor Küche.LEVEL is active
              2020-06-02 18:55:02.009  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Set ID: Rolladenaktor Küche.LEVEL value: 30%
              2020-06-02 18:55:02.009  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) save current height: 30% from Rolladenaktor Küche.LEVEL
              2020-06-02 18:55:02.011  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:55:02.199  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:55:21.365  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:58:36.053  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) TriggerID changed: hm-rpc.1.LEQ1251236.1.STATE
              2020-06-02 18:58:40.303  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) TriggerID changed: hm-rpc.1.LEQ1251236.1.STATE
              2020-06-02 18:58:40.305  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) save trigger height: 30%
              2020-06-02 18:58:40.305  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Set ID: Rolladenaktor Küche.LEVEL value: 100%
              2020-06-02 18:58:40.306  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:58:40.573  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 18:59:02.912  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 19:00:00.003  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Sun Azimut: 283.1°
              2020-06-02 19:00:00.004  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Sun Elevation: 18.2°
              2020-06-02 19:00:02.007  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Sunprotect for Rolladenaktor Küche.LEVEL is active
              2020-06-02 19:00:02.008  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) Set ID: Rolladenaktor Küche.LEVEL value: 30%
              2020-06-02 19:00:02.008  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) save current height: 30% from Rolladenaktor Küche.LEVEL
              2020-06-02 19:00:02.009  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 19:00:02.184  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 19:00:10.164  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 19:00:18.365  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) shutter state changed: hm-rpc.1.LEQ0606830.1.LEVEL
              2020-06-02 19:00:54.240  - ESC[34mdebugESC[39m: shuttercontrol.0 (16190) system.adapter.admin.0: logging true
              2020-06-02 19:02:46.625  - ESC[32minfoESC[39m: shuttercontrol.0 (16190) Adapter is disabled => stop
              2020-06-02 19:02:46.626  - ESC[32minfoESC[39m: shuttercontrol.0 (16190) cleaned everything up...
              2020-06-02 19:02:46.627  - ESC[32minfoESC[39m: shuttercontrol.0 (16190) terminating
              2020-06-02 19:02:46.628  - ESC[32minfoESC[39m: shuttercontrol.0 (16190) Terminated (NO_ERROR): Without reason
              2020-06-02 19:02:46.629  - ESC[32minfoESC[39m: host.iobroker "system.adapter.shuttercontrol.0" disabled
              2020-06-02 19:02:46.629  - ESC[32minfoESC[39m: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
              2020-06-02 19:02:46.631  - ESC[32minfoESC[39m: shuttercontrol.0 (16190) Got terminate signal TERMINATE_YOURSELF
              2020-06-02 19:02:46.633  - ESC[32minfoESC[39m: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
              2020-06-02 19:02:47.135  - ESC[32minfoESC[39m: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 0 (NO_ERROR)
              Und hier ist meine Konfiguration, habe als Einstellung "triggerChange": "upDown" gewählt, da man hierdurch ja laut Beschreibung in der Doku den Aussperrschutz aktiviert und natürlich habe ich mit "triggerID": "hm-rpc.1.LEQ1251236.1.STATE" auch meinen Homematic Drehgriffkontakt in die Steuerung eingebunden:
                "_id": "system.adapter.shuttercontrol.0",
                "common": {
                  "name": "shuttercontrol",
                  "version": "0.4.3",
                  "title": "shuttercontrol",
                  "authors": [
                    "simatec <nais@gmx.net>"
                  "keywords": [
                    "ioBroker",
                    "Smart Home",
                    "home automation",
                    "Rollladen",
                    "Jalousie",
                    "Rollladensteuerung"
                  "license": "MIT",
                  "platform": "Javascript/Node.js",
                  "main": "main.js",
                  "icon": "shuttercontrol.png",
                  "enabled": false,
                  "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                  "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                  "loglevel": "debug",
                  "mode": "daemon",
                  "type": "climate-control",
                  "compact": true,
                  "materialize": true,
                  "stopBeforeUpdate": true,
                  "dependencies": [
                      "admin": ">=3.0.0"
                  "installedFrom": "iobroker.shuttercontrol@0.4.3",
                  "installedVersion": "0.4.3",
                  "host": "iobroker"
                "native": {
                  "W_shutterDownLiving": "22:00",
                  "WE_shutterDownLiving": "22:00",
                  "WE_shutterUpLiving": "08:00",
                  "W_shutterUpLivingMin": "06:30",
                  "W_shutterUpLivingMax": "07:00",
                  "driveDelayUpLiving": "0",
                  "W_shutterDownSleep": "20:00",
                  "WE_shutterDownSleep": "21:00",
                  "WE_shutterUpSleep": "10:30",
                  "W_shutterUpSleepMin": "06:00",
                  "driveDelayUpSleep": "10",
                  "latitude": "52.520007",
                  "longitude": "13.404954",
                  "astroDelayUp": "30",
                  "astroDelayDown": "30",
                  "driveDelayUpAstro": "10",
                  "sunProtEndElevation": "8",
                  "currentShutterState": false,
                  "publicHolInstance": "",
                  "triggerAutoSleep": "hm-rpc.0.MEQ1234567.2.STATE",
                  "triggerAutoLiving": "hm-rpc.0.MEQ1234567.2.STATE",
                  "heightDownSun": "30",
                  "direction": "300",
                  "type": "in- & outside temperature and direction",
                  "directionRange": "60",
                  "actualValueTemp": "openweathermap.0.forecast.current.temperature",
                  "actualValueLight": "javascript.0.Sonnenverschattung.SonnigInt",
                  "actualValueTempInside": "hm-rpc.1.LEQ0997348.1.TEMPERATURE",
                  "typeDown": "off",
                  "typeUp": "living",
                  "triggerStateShutter": "0",
                  "triggerChangeShutter": "upDown",
                  "triggerDriveShutter": "100",
                  "autoDriveShutter": "upDown",
                  "triggerID": "hm-rpc.1.LEQ1251236.1.STATE",
                  "events": [
                      "enabled": true,
                      "shutterName": "Rolladenaktor Küche.LEVEL",
                      "name": "hm-rpc.1.LEQ0606830.1.LEVEL",
                      "typeUp": "living",
                      "typeDown": "off",
                      "direction": "300",
                      "tempInside": "19",
                      "tempSensor": "hm-rpc.1.LEQ0997348.1.TEMPERATURE",
                      "outsideTempSensor": "openweathermap.0.forecast.current.temperature",
                      "tempOutside": "20",
                      "lightSensor": "javascript.0.Sonnenverschattung.SonnigInt",
                      "valueLight": "100",
                      "heightUp": "100",
                      "heightDown": "0",
                      "triggerState": "0",
                      "triggerChange": "upDown",
                      "elevation": "8",
                      "autoDrive": "upDown",
                      "triggerHeight": ""
              Und außerdem sollte doch eigentlich auch nach dem manuellem Fahren des Rolladens die Automatik deaktiviert sein, war sie aber in diesem Fall nicht.
              Könnte mir bitte jemand helfen, ob ich hier noch irgendwo einen (Denk-)fehler bei der Konfiguration habe? Oder liegt hier möglicherweise noch ein Bug in dem Adapter vor?
              Vielen Dank!
              B simatecS 2 Antworten Letzte Antwort
              • FredFF FredF
                @bishop
                bishop
                #1948
                @FredF
                danke, werde ich so probieren.
                • D dj.tifosi
                    "common": {
                      "version": "0.4.3",
                      "authors": [
                      "keywords": [
                        "ioBroker",
                        "Smart Home",
                        "home automation",
                        "Rollladen",
                        "Jalousie",
                      "license": "MIT",
                      "main": "main.js",
                      "enabled": false,
                      "mode": "daemon",
                      "compact": true,
                      "dependencies": [
                          "admin": ">=3.0.0"
                      "host": "iobroker"
                    "native": {
                      "direction": "300",
                      "typeDown": "off",
                      "typeUp": "living",
                      "events": [
                          "enabled": true,
                          "typeUp": "living",
                          "typeDown": "off",
                          "direction": "300",
                          "tempInside": "19",
                          "heightUp": "100",
                          "heightDown": "0",
                          "elevation": "8",
                          "triggerHeight": ""
                  Vielen Dank!
                  bishop
                  #1949
                  @dj-tifosi sagte in Test Adapter shuttercontrol v0.6.x:
                  wenn ich das jetzt richtig verstanden habe, wird dadurch die Automatik nicht abgeschalten.
                  Bei mir läuft es aber auch noch nicht so wie ich oder besser gesagt meine Frau das gerne hätte, bin auch noch am testen..
                  • M MartyBr
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #1950
                    @MartyBr
                    In der aktuellen Version auf der latest Repo sind die als Und-Verknüpfung drin ...
                    M L 2 Antworten Letzte Antwort
                    • D dj.tifosi
                        "common": {
                          "version": "0.4.3",
                          "authors": [
                          "keywords": [
                            "ioBroker",
                            "Smart Home",
                            "home automation",
                            "Rollladen",
                            "Jalousie",
                          "license": "MIT",
                          "main": "main.js",
                          "enabled": false,
                          "mode": "daemon",
                          "compact": true,
                          "dependencies": [
                              "admin": ">=3.0.0"
                          "host": "iobroker"
                        "native": {
                          "direction": "300",
                          "typeDown": "off",
                          "typeUp": "living",
                          "events": [
                              "enabled": true,
                              "typeUp": "living",
                              "typeDown": "off",
                              "direction": "300",
                              "tempInside": "19",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "8",
                              "triggerHeight": ""
                      Vielen Dank!
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #1951
                      Du erlaubst dem Rolladen trotz geöffnetem Fenster in beide Richtungen zu fahren.
                      Da liegt dein Problem.
                      Ändere das in "Nur auf"
                      Solange das Fenster dann offen ist, wird hier nicht gefahren.
                      Grundsätzlich halte ich aber ein automatisches Fahren einer Terrassentür für kritisch.
                      Meine fährt nur bei Abwesenheit hoch und runter. Ansonsten fährt der Rolladen nur morgens automatisch hoch.
                      Das alles kann man aber über shuttercontrol ohne zusätzliche Scripte lösen.
                      • simatecS simatec
                        dj.tifosi
                        #1952
                        @simatec ok vielen Dank für die Antwort, ich werde das mal ausprobieren.
                        Aber laut der Beschreibung zu diesem Parameter finde ich in der Doku folgendes:
                        Fahren bei Änderung: Pulldown zur Auswahl der Funktion, die bei Bewegung des Griffs durchgeführt werden soll
                        Aus: keine Bewegung
                        nur Auf: Beim Öffnen der Tür fährt der Rollladen auf und verbleibt dort
                        nur Ab: Nach Schließen der Tür fährt der Rollladen auf die Verdunklungsposition
                        Auf und Ab: Der Rollladen öffnet sich mit der Tür und fährt mit dem Schließen wieder runter
                        Bin daher nur davon ausgegangen, dass wenn ich "Auf und Ab" verwende das Rollo nur hochfährt, wenn ich den Drehgriff öffne und das Rollo gerade zu war und umgekehrt dass das Rollo runter fährt, aber erst dann wenn ich den Drehgriff wieder schließe.
                        Dass es aber schließen darf, obwohl der Drehgriff auf offen steht, erschließt sich mir jetzt nicht aus der Beschreibung, im Gegenteil es widerspricht der Beschreibung bei "Auf und Ab", nun verstehe ich ein wenig Bahnhof. Ich probiere es trotzdem mal aus.
                        Was ich gerne hätte ist, dass das Rollo immer dann auf 30% fährt, wenn die Sonnenachutz-Bedingungen (Innentemperatur, Außentemperatur, Helligkeit und Sonnenstand) alle erfüllt sind UND wenn zusätzlich der Drehgriff geschlossen ist.
                        Wird der Drehgriff geöffnet soll der Aussperrschutz greifen und es soll jegliche Automatik aussetzen und das solange, wie der Drehgriff geöffnet ist.
                        Wird der Drehgriff wieder geschlossen, soll der Aussperrschutz deaktivieren und die Automatik soll wieder wie zuvor greifen, das heißt der Sonnenachutz soll wieder aktiv werden.
                        Wenn beim Öffnen des Drehgriffs auch direkt das Rollo hochgeht ist "nice to have" aber kein Muss.
                        An welchen Einstellungen muss ich drehen, um diese Anforderungen möglichst gut umzusetzen?
                        • D dj.tifosi
                          Aus: keine Bewegung
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #1953
                          @dj-tifosi
                          Ich glaube wir reden nicht von der gleichen Einstellung.
                          Hier geht es um "Automatikbetrieb bei Triggerabweichung" und nicht um "Fahren bei Änderung"
                          Stelle mal folgendes ein:
                          Fahren bei Änderung = auf und ab
                          Automatikbetrieb bei Triggerabweichung = nur auf
                          https://github.com/simatec/ioBroker.shuttercontrol/blob/master/docs/de/shuttercontrol.md#zusatzeinstellungen
                          • simatecS simatec
                            @dj-tifosi
                            dj.tifosi
                            #1954
                            @simatec ah, jetzt verstehe ich, vielen Dank.
                            Es geht um den Parameter "Automatikbetrieb bei Triggerabweichung", wenn ich den auf "nur Auf" setze, erlaube ich Shuttercontrol nur eine Fahrt nach oben, falls das Rollo gerade in Sonnenschutz-Posotion bei geöffnetem Fenster ist.
                            Ich verbiete aber umgekehrt dadurch eine Fahrt nach unten in die Sonnenschutz-Posotion, falls das Rollo gerade offen ist bei geöffnetem Fenster.
                            Habe ich das so richtig verstanden? Dann werde ich das heute mal testen.
                            Und setzt denn die Automatik auch bei dieser Einstellung wieder ein, nachdem ich das Fenster schließe? Also fährt er dann erneut in die Sonnenschutz-Posotion oder verbleibt er dann bis zum Tagesende in der manuellen Steuerung, nachdem das Fenster einmalig manuell oder durch Öffnen des Drehgriffs hochgefahren wurde?
                            • D dj.tifosi
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #1955
                              @dj-tifosi
                              Du setzt die Automatik mit dieser Einstellung nur solange aus, bis das Fenster wieder geschlossen wird.
                              coyoteC 1 Antwort Letzte Antwort
                              • simatecS simatec
                                @dj-tifosi
                                coyoteC Offline
                                coyoteC Offline
                                coyote
                                #1956
                                @simatec ich habe momentan auch Probleme mit dem Sonnenschutz, habe meine Markise folgendermaßen eingestellt:
                                        "enabled": true,
                                        "shutterName": "Wintergartenmarkise",
                                        "name": "hm-rpc.1.PEQ07XXXX.3.LEVEL",
                                        "triggerID": "",
                                        "typeUp": "off",
                                        "typeDown": "off",
                                        "type": "only direction",
                                        "heightDownSun": "0",
                                        "direction": "190",
                                        "directionRange": "100",
                                        "tempInside": "",
                                        "tempSensor": "",
                                        "tempOutside": "",
                                        "lightSensor": "",
                                        "valueLight": "",
                                        "heightUp": "100",
                                        "heightDown": "0",
                                        "elevation": "",
                                        "autoDrive": "off",
                                        "hysteresisLight": "",
                                        "oldHeight": "",
                                        "triggerHeight": ""
                                Fahren tut sie aber nicht beim erreichen des Azimuts, wo liegt mein Fehler? Finde ihn nicht.
                                Testweise hatte ich 190° Himmelsrichtung eingestellt und 1° +/-, das hat funktioniert. Es kommt auch nichts im Debug log.
                                Zum weiteren Test habe ich gestern meinen Rolladen im Flur auch abgeändert, dieser wollte aber heute auch nicht fahren, ging letztes Jahr einwandfrei.
                                        "enabled": true,
                                        "shutterName": "Rolladen Flur",
                                        "name": "hm-rpc.1.MEQ11XXXXX.3.LEVEL",
                                        "triggerID": "",
                                        "typeUp": "living-auto",
                                        "typeDown": "living-auto",
                                        "direction": "190",
                                        "tempInside": "",
                                        "tempSensor": "",
                                        "outsideTempSensor": "wiffi-wz.0.root.192_168_66_134.w_temperatur",
                                        "tempOutside": "13",
                                        "lightSensor": "",
                                        "valueLight": "",
                                        "heightUp": "100",
                                        "heightDown": "0",
                                        "elevation": "0",
                                        "autoDrive": "off",
                                        "oldHeight": "",
                                        "triggerHeight": ""
                                • FoggF Fogg
                                  @UHT said in Test Adapter shuttercontrol v0.6.x:
                                  Ich hab Homematic Aktoren im Einsatz, da ist 0% geschlossen und 100% geöffnet, das finde ich unlogisch,
                                  Daran habe ich mich gewöhnt :) Es zu drehen würde ich nicht empfehlen, wenn du vordefinierte Visualisierungen benutzt passen die nicht mehr 🐶
                                  U Offline
                                  U Offline
                                  UHT
                                  #1957
                                  @Fogg
                                  Nutze ich nicht, und da ich auch andere Aktoren habe wo ich nicht drehen kann, habe ich eh beides gemischt. Daher wäre konfigurierbar deutlich universeller.
                                  • coyoteC coyote
                                            "enabled": true,
                                            "triggerID": "",
                                            "typeUp": "off",
                                            "typeDown": "off",
                                            "direction": "190",
                                            "tempInside": "",
                                            "tempSensor": "",
                                            "tempOutside": "",
                                            "lightSensor": "",
                                            "valueLight": "",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "triggerHeight": ""
                                            "enabled": true,
                                            "triggerID": "",
                                            "direction": "190",
                                            "tempInside": "",
                                            "tempSensor": "",
                                            "lightSensor": "",
                                            "valueLight": "",
                                            "heightUp": "100",
                                            "heightDown": "0",
                                            "elevation": "0",
                                            "autoDrive": "off",
                                            "oldHeight": "",
                                            "triggerHeight": ""
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #1958
                                    @coyote
                                    du hast den Aussperrschutz aktiv
                                    "autoDrive": "off",
                                    • simatecS simatec
                                      @coyote
                                      "autoDrive": "off",
                                      coyoteC Offline
                                      coyoteC Offline
                                      coyote
                                      #1959
                                      @simatec dachte wenn ich gar keine Auslöser ID eintrage, wird das gar nicht erst geprüft. Geht aber jetzt 👍 Danke.
                                      In deiner Beschreibung ist es aber etwas komisch formuliert oder sehe ich das falsch?
                                      Irgendwie ist "AUS" und "AUF/AB" doch laut der Beschreibung das Gleiche oder?
                                      Rollläden dürfen sich bewegen, egal wie der Sensor steht.
                                      • coyoteC coyote
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #1960
                                        @coyote
                                        Das sollte dann überabeitet werden ... Da muss ich die Beschreibung mal komplett durchgehen.
                                        Die hatte damals Rainer geschrieben. Vielleicht gab es da Abstimmungsprobleme
                                        • simatecS simatec
                                          @coyote
                                          coyoteC Offline
                                          coyoteC Offline
                                          coyote
                                          #1961
                                          @simatec kurze Frage habe ich noch. Ich habe noch einen Regensensor, der "true" wird wenn es regnet.
                                          Dann sollte doch diese Einstellung passen oder?
                                          Wenn er Regen meldet, müsste die Markise einfahren und wenn kein Regen, darf die Markise aus und einfahren, richtig?
