  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.9k Aufrufe 94 Beobachtet
  • WebrangerW Offline
    WebrangerW Offline
    Webranger
    #604
    Komisch .......
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
      WebrangerW Offline
      Webranger
      schrieb am zuletzt editiert von Webranger
      #605
      Hab immer noch diese Fehler im log
      coronavirus-statistics.0	2020-05-25 19:00:54.708	info	(15619) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      coronavirus-statistics.0	2020-05-25 19:00:54.285	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":415,"GEN":"Berlin Tempelhof-Schöneberg","BEZ":"Bezirk","death_rate":3.6036036036036,"cases":666,"deaths":24,"cases_per_100k":189.3
      coronavirus-statistics.0	2020-05-25 19:00:54.284	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":414,"GEN":"Berlin Friedrichshain-Kreuzberg","BEZ":"Bezirk","death_rate":1.15830115830116,"cases":518,"deaths":6,"cases_per_100k":1
      coronavirus-statistics.0	2020-05-25 19:00:54.275	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":413,"GEN":"Berlin Mitte","BEZ":"Bezirk","death_rate":1.2565445026178,"cases":955,"deaths":12,"cases_per_100k":248.586570598586,"ca
      coronavirus-statistics.0	2020-05-25 19:00:54.274	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":412,"GEN":"Berlin Steglitz-Zehlendorf","BEZ":"Bezirk","death_rate":2.41187384044527,"cases":539,"deaths":13,"cases_per_100k":174.6
      coronavirus-statistics.0	2020-05-25 19:00:54.273	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":411,"GEN":"Berlin Spandau","BEZ":"Bezirk","death_rate":2.66666666666667,"cases":300,"deaths":8,"cases_per_100k":122.962410391143,"
      coronavirus-statistics.0	2020-05-25 19:00:54.272	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":410,"GEN":"Berlin Marzahn-Hellersdorf","BEZ":"Bezirk","death_rate":0.84985835694051,"cases":353,"deaths":3,"cases_per_100k":131.44
      coronavirus-statistics.0	2020-05-25 19:00:54.261	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":409,"GEN":"Berlin Lichtenberg","BEZ":"Bezirk","death_rate":3.44827586206897,"cases":290,"deaths":10,"cases_per_100k":99.5018047568
      coronavirus-statistics.0	2020-05-25 19:00:54.260	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":408,"GEN":"Berlin Neukölln","BEZ":"Bezirk","death_rate":4.32432432432432,"cases":740,"deaths":32,"cases_per_100k":224.452593489055
      coronavirus-statistics.0	2020-05-25 19:00:54.255	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":407,"GEN":"Berlin Pankow","BEZ":"Bezirk","death_rate":4.14285714285714,"cases":700,"deaths":29,"cases_per_100k":171.667504567582,"
      coronavirus-statistics.0	2020-05-25 19:00:54.254	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":406,"GEN":"Berlin Treptow-Köpenick","BEZ":"Bezirk","death_rate":2.89855072463768,"cases":345,"deaths":10,"cases_per_100k":127.2344
      coronavirus-statistics.0	2020-05-25 19:00:54.253	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":405,"GEN":"Berlin Charlottenburg-Wilmersdorf","BEZ":"Bezirk","death_rate":2.97297297297297,"cases":740,"deaths":22,"cases_per_100k
      coronavirus-statistics.0	2020-05-25 19:00:54.241	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":404,"GEN":"Berlin Reinickendorf","BEZ":"Bezirk","death_rate":4.43548387096774,"cases":496,"deaths":22,"cases_per_100k":187.0110283
      und diese:
      coronavirus-statistics.0	2020-05-25 19:00:28.066	warn	(15619) State attribute definition missing for + criticalPerOneMillion
      coronavirus-statistics.0	2020-05-25 19:00:27.834	warn	(15619) State attribute definition missing for + recoveredPerOneMillion
      coronavirus-statistics.0	2020-05-25 19:00:27.497	warn	(15619) State attribute definition missing for + activePerOneMillion
      coronavirus-statistics.0	2020-05-25 19:00:27.282	warn	(15619) State attribute definition missing for + population
      Hab ich was überlesen was ich machen muss und gibt es da schon eine Lösung?
      Gruss
      crunchipC K 2 Antworten Letzte Antwort
      • WebrangerW Webranger
        und diese:
        Gruss
        crunchipC Abwesend
        crunchipC Abwesend
        #606
        @Webranger habs manuell geändert
        https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/pull/52
          und diese:
          Gruss
          Kampfratte
          #607
          @Webranger der Pull Request liegt Dutchman schon seit geraumer Zeit vor.
          Bis er es integriert hat, kannst du den Adapter incl. des Pull requests auch von meinem Fork installieren
          https://github.com/Kampfratte/ioBroker.coronavirus-statistics
          Lg
          crunchipC M 2 Antworten Letzte Antwort
          • K Kampfratte
            Lg
            crunchipC Abwesend
            crunchipC Abwesend
            #608
            @Kampfratte gibt schon wieder was zu tun😜
            	(26469) State attribute definition missing for + todayRecovered
            Ah...hast du schon...grad gesehen
              Coffeelover
              #609
              @crunchip sagte in Test Coronavirus Statistics for ioBroker:
              +1
              • K Kampfratte
                Lg
                Michi68
                #610
                Danke @Kampfratte
                hat er schon gemacht einfach noch mal von hier https://github.com/Kampfratte/ioBroker.coronavirus-statistics
                die zwei main.js, stateAttr.js austauschen
                  Kampfratte
                  #611
                  @crunchip jupp, ist schon gemacht und auch wieder gleich per Pull Request weiter gegeben worden :)
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #612
                    Hi all,
                    Sorry ich hatte eine kleine (notwendige) Auszeit um bissl zur ruhe zu kommen, werden ab dieser/spaetestens nieste Woche wieder aktiver unterwegs sein.
                    (manchmal hat man solche Momente)
                    Cheers,
                    Dutch
                    ChaotC K 2 Antworten Letzte Antwort
                    • DutchmanD Dutchman
                      Hi all,
                      Cheers,
                      Dutch
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #613
                      @Dutchman
                      In das Ruhe liegt der Kraft.
                      Ales Gut!
                        Hi all,
                        Cheers,
                        Dutch
                        Kampfratte
                        #614
                        @Dutchman kein Ding. Braucht jeder mal, denke ich.
                        Heute kam wieder ne Meldung, die ich angepasst habe und auch gleich per Pull Request angepasst habe.
                        • sigi234S sigi234
                          @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
                          @Scrounger sagte in Test Coronavirus Statistics for ioBroker:
                          Ihr müsst für die Graphen Eure eigenen History Instanzen und Datenpunkte eintragen
                          Habe ich
                          Es gehen keine meiner Charts mehr , dreht ständig im Kreis
                          Vis-materialdesign-Chart-Line-History
                          Edit:
                          Mit Update erledigt.
                          #615
                          Hallo @sigi234 und @Scrounger ,
                          danke erst mal an alle hier für diesen tollen Adapter und Idden für Views.
                          Ich habe Scroungers View vom 19.3. hier mal testweise implementiert. Ich bin noch Anfänger, steige nach un d nach mehr durch. Mi Chats hatte ich noch nichts zu tun.
                          Bei mir werden auch keine Charts angezeigt. Klar, ich habe die materila-design-widgets in der neusten Version installiert. Auch iobroker läuft in der neusten Version auf meinem pi3.
                          Frage: Muss ich noch sql oder history installieren?
                          Danke schon mal,
                          vsa
                          C 1 Antwort Letzte Antwort
                            Danke schon mal,
                            vsa
                            Coffeelover
                            schrieb am zuletzt editiert von Coffeelover
                            #616
                            @vsa sagte in Test Coronavirus Statistics for ioBroker:
                            Ja. Der einfachste Weg ist: History Adapter installieren und dann die Datenpunkte, die in das Chart sollen im Reiter Objekte mit dem Schraubenschlüssel zur Historisierung "aktivieren".
                            PS: Zum lernen hast du dir mit der View von Scrounger eine ziemlich komplexe rausgesucht, weil diese aus Detailviews je Land und der Patternview inkl. persönlich angelegter Datenpunkte zum Umschalten usw. besteht. Der Start wäre also zunächst das einzelne Länderview ans Laufen zu bringen.
                            • C Coffeelover
                              #617
                              @Coffeelover
                              danke, das ist schon mal eine Hilfe. SQL auch?
                              VG vsa
                                @Coffeelover
                                VG vsa
                                Coffeelover
                                #618
                                @vsa Nein, beide Lösungen (History und SQL) erfüllen in dem Fall den gleichen Anwendungszweck: Sie speichern kontinuierlich oder bei Änderungen Datensätze ab, welche dann im Widget dargestellt werden können. SQL ist mächtiger, weil du darüber SQL-Abfragen etc. ausführen kannst. Nur für die Charts genügt History.
                                • C Coffeelover
                                  #619
                                  @Coffeelover Vielen Dank. Dann wage ich mich mal an ein Detailview eines Landes ran...
                                    Coffeelover
                                    #620
                                    @vsa Die Scrounger ja z.B. auch hochgeladen hat... ;-)
                                    • C Coffeelover
                                      #621
                                      Hallo @Coffeelover und alle zusammen,
                                      mittelmäßig gut durchgestiegen. Siehe Bilder.
                                      • die Views gehen bei mir
                                      • die detailviews habe ich weitgehenst angepasst, sodass die Infos unter den Icons richtig zu den Werten angezeigt werden
                                      • history adapter installiert und loggt die Werte von coronavirus-statistics.0 mit
                                      Was muss ich noch malchen, dass die Chart angezeigt wird? Irgendetwas muss ich übersehen haben :-(
                                      VG vsa
                                        VG vsa
                                        Coffeelover
                                        #622
                                        @vsa: Der Datenpunkt 0_userdata.0.vis.Corona.timeInterval scheint mir nicht angelegt oder nicht richtig verlinkt. DU musst dazu auf der Admin-Oberfläche unter Objects mit Plus einen Datenpunkt vom Typ Zahl hinzufügen und bei "Zeitintervall über Objekt steuern" im Widget eintragen.
                                        • C Coffeelover
                                          #623
                                          @Coffeelover Fast super! Danke für den Tipp. Der DP war da, jedoch wie du schon vermutet hast a) falsch verlinkt und b) vom Typ String. Ich habe auf Typ Zahl gesetzt.
                                          Sorry für die erneute Nachfrage....
                                          Ich sehe nun einen Chart. Warum auch immer plötzlich nicht die Tagesdarstellung sondern in Jahren... Ich habe nichts verändert an anderen Einstellungen...
