  4. Update js-controller und node.js
update js-controller node.js
93 Beiträge 10 Kommentatoren 74.3k Aufrufe 10 Beobachtet
  • S Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    @Smartuser
    npm i libvips@8.9.1
    rock64@rock64:/opt/iobroker$ npm i libvips@8.9.1
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for libvips@8.9.1.
    npm ERR! notarget In most cases you or one of your dependencies are requesting
    npm ERR! notarget a package version that doesn't exist.
    npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_47_31_974Z-debug.log
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @Smartuser Komisch. Die Kiste baut oben, aber mit den falschen sourcen. Keine Ahnung wie man den auf latest oder eine Version >= 8.9.1 bringen kann.
    npm i libvips@latest
    :-D
    • Thomas BraunT
      Thomas BraunT
      Seltsamerweise baut das bei mir, denn da liegen auch die richtigen Quelltexte.
      /home/iobroker/.npm/_libvips
      /home/iobroker/.npm/_libvips/libvips-8.9.0-linux-armv7.tar.gz
      /home/iobroker/.npm/_libvips/libvips-8.9.1-linux-armv7.tar.gz
        :-D
        S
        S
        Smartuser
        :-D
        Ich versteh es gleich gar nicht ;) :D
        rock64@rock64:/opt/iobroker$ npm i libvips@latest
        > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
        > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
        ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
        info sharp Attempting to build from source via node-gyp but this may fail due to the above error
        info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
        make: Entering directory '/opt/iobroker/node_modules/sharp/build'
          CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
          AR(target) Release/obj.target/../node-addon-api/src/nothing.a
          COPY Release/nothing.a
          TOUCH Release/obj.target/libvips-cpp.stamp
          CXX(target) Release/obj.target/sharp/src/common.o
        In file included from ../src/common.cc:23:
        /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
         #include <glib-object.h>
        compilation terminated.
        make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! System Linux 4.4.213-rockchip64
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/sharp
        gyp ERR! node -v v12.16.3
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        + libvips@0.0.2
        updated 1 package in 49.631s
        22 packages are looking for funding
          run `npm fund` for details
        • S Smartuser
          :-D
          gyp ERR! not ok
          + libvips@0.0.2
          Thomas BraunT
          Thomas BraunT
          @Smartuser
          npm i vips
            @Smartuser
            npm i vips
            S
            S
            Smartuser
            #66
            npm i vips
            rock64@rock64:/opt/iobroker$ npm i vips
            gyp ERR! not ok
            + vips@1.0.0
            added 1 package from 1 contributor in 44.674s
            • S Smartuser
              npm i vips
              gyp ERR! not ok
              + vips@1.0.0
              Thomas BraunT
              Thomas BraunT
              #67
              @Smartuser
              npm i canvas
                @Smartuser
                npm i canvas
                S
                S
                Smartuser
                #68
                npm i canvas
                Es lief eine Weile, am Ende dieses Ergebnis:
                make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
                gyp ERR! not ok
                + canvas@2.6.1
                updated 1 package in 158.31s
                • S Smartuser
                  npm i canvas
                  gyp ERR! not ok
                  + canvas@2.6.1
                  Thomas BraunT
                  Thomas BraunT
                  #69
                  @Smartuser
                  Sorry, irgendwas übersehe ich. Ich hab nur keinen Schimmer was.
                  Muss sich einer anschauen, der in node tiefer drin ist.
                  Auf meinem Raspberry mit ARMV7l Architektur baut der Kram.
                  Keine Ahnung, ob das mit deiner AARCH64 zusammenhängt.
                    @Smartuser
                    S
                    S
                    Smartuser
                    #70
                    @Smartuser
                    Auf meinem Raspberry mit ARMV71 Architektur baut der Kram.
                    Ok .... danke für deine Mühe. 👍 👍 👏
                    Eventuell nehm ich mal ein ayufan Image für den Rock64, vielleicht geht es damit
                    • S Smartuser
                      @Smartuser
                      Thomas BraunT
                      Thomas BraunT
                      #71
                      @Smartuser
                      Ich installier mir das OS immer selber. Dann weiß ich auch mehr oder weniger was da läuft.
                        @Smartuser
                        AlCalzoneA
                        AlCalzoneA
                        AlCalzone
                        #72
                        @Thomas-Braun @Smartuser
                        libvips ist gar kein npm-Paket. Da könnt ihr lange probieren
                        ==> https://libvips.github.io/libvips/install.html#building-libvips-from-a-source-tarball
                        Danach kann sharp rebuilded werden.
                        • AlCalzoneA AlCalzone
                          Thomas BraunT
                          Thomas BraunT
                          #73
                          @AlCalzone Arrrgh! Schwerer Denkfehler von mir! Danke fürs aufwecken!
                          Nur warum liegt das bei mir alles im node?
                          pi@raspberrypi:~ $ locate libvips
                          /opt/iobroker/node_modules/sharp/build/Release/.deps/Release/obj.target/libvips-cpp.stamp.d
                          /opt/iobroker/node_modules/sharp/build/Release/obj.target/libvips-cpp.stamp
                          /opt/iobroker/node_modules/sharp/build/libvips-cpp.target.mk
                          /opt/iobroker/node_modules/sharp/install/libvips.js
                          /opt/iobroker/node_modules/sharp/lib/libvips.js
                          /opt/iobroker/node_modules/sharp/src/libvips
                          /opt/iobroker/node_modules/sharp/src/libvips/cplusplus
                          /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VConnection.cpp
                          /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VError.cpp
                          /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VImage.cpp
                          /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VInterpolate.cpp
                          /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/vips-operators.cpp
                          /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so
                          /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42
                          /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42.12.1
                          /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so
                          /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42
                          /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42.12.1
                          Und sharp ist bei mir drin:
                          pi@raspberrypi:/opt/iobroker $ npm list sharp --depth=2
                          iobroker.inst@2.0.3 /opt/iobroker
                          └─┬ iobroker.iot@1.4.14
                            └── sharp@0.25.2
                          S AlCalzoneA 2 Antworten Letzte Antwort
                              └── sharp@0.25.2
                            S
                            S
                            Smartuser
                            #74
                            @Thomas-Braun @AlCalzone
                            Viele Dank euch Beiden. Ich konnte jetzt erfolgreich die aktuelle libvips-version bauen.
                            Jetzt funktioniert alles. :) 👍
                            Ich habe es wie folgt gemacht:
                            cd /tmp
                            wget https://github.com/libvips/libvips/releases/download/v8.9.2/vips-8.9.2.tar.gz
                            tar xf vips-8.9.2.tar.gz
                            cd vips-8.9.2
                            ./configure
                            make
                            sudo make install
                            sudo ldconfig
                            Danach Sharp installiert.
                            cd /opt/iobroker
                            npm i sharp
                            Ohne Errors - Log:
                            rock64@rock64:/opt/iobroker$ npm i sharp
                            info sharp Detected globally-installed libvips v8.9.2
                            info sharp Building from source via node-gyp
                              CXX(target) Release/obj.target/sharp/src/metadata.o
                              CXX(target) Release/obj.target/sharp/src/stats.o
                              CXX(target) Release/obj.target/sharp/src/operations.o
                              CXX(target) Release/obj.target/sharp/src/pipeline.o
                              CXX(target) Release/obj.target/sharp/src/utilities.o
                              CXX(target) Release/obj.target/sharp/src/sharp.o
                              SOLINK_MODULE(target) Release/obj.target/sharp.node
                              COPY Release/sharp.node
                            + sharp@0.25.2
                            added 4 packages from 112 contributors in 137.029s
                            Zur Sicherheit nochmal den "Fixer" ausgeführt. Wahrscheinlich nicht notwendig, aber schadet ja auch nicht :)
                            iobroker stop
                            iobroker fix
                            iobroker start
                                └── sharp@0.25.2
                              AlCalzoneA
                              AlCalzoneA
                              AlCalzone
                              #75
                              @Thomas-Braun Zeile 5-22 ist alles das sharp-Modul
                              2-4 bin ich mir nicht sicher, sieht aber nach vorkompilierten binaries aus, die ggf von sharp bei der Installation heruntergeladen werden.
                              • K
                                K
                                klausiob
                                #76
                                @Smartuser habe Deine Installation auf meinen Raspi mit rasbian stretch ausgeführt. Hat zwar ganz schön lang gedauert. Besonders die sharp-Installation. Dabei war meine Netzwerkverbindung noch abgebrochen.
                                iobroker.inst@1.3.1 /opt/iobroker
                                ├─┬ iobroker.iot@1.4.10
                                │ └── sharp@0.25.2  deduped
                                └── sharp@0.25.2
                                Habe jetzt so 5 Adapter upgedatet und die obigen Fehlermeldungen sind weg. Danke an alle.
                                VG klausiob
                                Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                                node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                                • A
                                  A
                                  adaer
                                  schrieb am zuletzt editiert von adaer
                                  #77
                                  @Smartuser: Auch ich hatte diese lästige Meldungen und habe deine Installation auf meinen Raspi mit rasbian stretch ebenfalls ausgeführt. Alles wieder im Lot.. :)
                                  pi@MyRasPi:/opt/iobroker $ npm list sharp --depth=2
                                  iobroker.inst@1.1.2 /opt/iobroker
                                  ├─┬ iobroker.iot@1.4.14
                                  └── sharp@0.25.2
                                  Nochmals Danke ...
                                  Gruss..
                                  Henry
                                  • W
                                    W
                                    Wing.Stefan
                                    #78
                                    Wie kann ich auf Synology im Docker den JS-Controller updaten?
                                    Die gefundenen Anleitungen waren für Linux Windows usw. Im Syno Docker gibt es kein Sudo und kein SToppen von iobroker weil dann geht nichts mehr.
                                    suche daher schritt für schritt Anleitung
                                    • W Wing.Stefan
                                      GlasfaserG
                                      GlasfaserG
                                      #79
                                      @maestro sagte in Update js-controller und node.js:
                                      was meinst du damit !?
                                      pkill io
                                      iobroker update
                                      iobroker upgrade self
                                      iobroker start
                                      W 1 Antwort Letzte Antwort
                                      • GlasfaserG Glasfaser
                                        pkill io
                                        iobroker update
                                        iobroker start
                                        W
                                        W
                                        Wing.Stefan
                                        schrieb am zuletzt editiert von Wing.Stefan
                                        #80
                                        @Glasfaser
                                        die befehle bringen nichst weil das pkill io oder kill io nichts macht, ab befehl 3 sagt er nämlich das noch etwas läuft
                                        • W Wing.Stefan
                                          @Glasfaser
                                          GlasfaserG
                                          GlasfaserG
                                          #81
                                          Klar geht das ...!!
                                          Bist du auch in der richtigen Docker Konsole .
                                          Zeige mal ein Screenshot
                                          84.2k
