  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser Komisch. Die Kiste baut oben, aber mit den falschen sourcen. Keine Ahnung wie man den auf latest oder eine Version >= 8.9.1 bringen kann.
    npm i libvips@latest
    :-D
    Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    :-D
    Ich versteh es gleich gar nicht ;) :D
    rock64@rock64:/opt/iobroker$ npm i libvips@latest
    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    In file included from ../src/common.cc:23:
    /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
     #include <glib-object.h>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + libvips@0.0.2
    updated 1 package in 49.631s
    22 packages are looking for funding
      run `npm fund` for details
    • S Smartuser
      :-D
      gyp ERR! not ok
      + libvips@0.0.2
      @Smartuser
      npm i vips
        @Smartuser
        npm i vips
        Smartuser
        #66
        npm i vips
        rock64@rock64:/opt/iobroker$ npm i vips
        gyp ERR! not ok
        + vips@1.0.0
        added 1 package from 1 contributor in 44.674s
        • S Smartuser
          npm i vips
          gyp ERR! not ok
          + vips@1.0.0
          #67
          @Smartuser
          npm i canvas
            @Smartuser
            npm i canvas
            Smartuser
            #68
            npm i canvas
            Es lief eine Weile, am Ende dieses Ergebnis:
            make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
            gyp ERR! not ok
            + canvas@2.6.1
            updated 1 package in 158.31s
            • S Smartuser
              npm i canvas
              gyp ERR! not ok
              + canvas@2.6.1
              #69
              @Smartuser
              Sorry, irgendwas übersehe ich. Ich hab nur keinen Schimmer was.
              Muss sich einer anschauen, der in node tiefer drin ist.
              Auf meinem Raspberry mit ARMV7l Architektur baut der Kram.
              Keine Ahnung, ob das mit deiner AARCH64 zusammenhängt.
                @Smartuser
                Smartuser
                #70
                @Smartuser
                Auf meinem Raspberry mit ARMV71 Architektur baut der Kram.
                Ok .... danke für deine Mühe. 👍 👍 👏
                Eventuell nehm ich mal ein ayufan Image für den Rock64, vielleicht geht es damit
                • S Smartuser
                  @Smartuser
                  #71
                  @Smartuser
                  Ich installier mir das OS immer selber. Dann weiß ich auch mehr oder weniger was da läuft.
                    @Smartuser
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #72
                    @Thomas-Braun @Smartuser
                    libvips ist gar kein npm-Paket. Da könnt ihr lange probieren
                    ==> https://libvips.github.io/libvips/install.html#building-libvips-from-a-source-tarball
                    Danach kann sharp rebuilded werden.
                    • AlCalzoneA AlCalzone
                      #73
                      @AlCalzone Arrrgh! Schwerer Denkfehler von mir! Danke fürs aufwecken!
                      Nur warum liegt das bei mir alles im node?
                      pi@raspberrypi:~ $ locate libvips
                      /home/iobroker/.npm/_libvips
                      /home/iobroker/.npm/_libvips/libvips-8.9.0-linux-armv7.tar.gz
                      /home/iobroker/.npm/_libvips/libvips-8.9.1-linux-armv7.tar.gz
                      /opt/iobroker/node_modules/sharp/build/Release/.deps/Release/obj.target/libvips-cpp.stamp.d
                      /opt/iobroker/node_modules/sharp/build/Release/obj.target/libvips-cpp.stamp
                      /opt/iobroker/node_modules/sharp/build/libvips-cpp.target.mk
                      /opt/iobroker/node_modules/sharp/install/libvips.js
                      /opt/iobroker/node_modules/sharp/lib/libvips.js
                      /opt/iobroker/node_modules/sharp/src/libvips
                      /opt/iobroker/node_modules/sharp/src/libvips/cplusplus
                      /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VConnection.cpp
                      /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VError.cpp
                      /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VImage.cpp
                      /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VInterpolate.cpp
                      /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/vips-operators.cpp
                      /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so
                      /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42
                      /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42.12.1
                      /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so
                      /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42
                      /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42.12.1
                      Und sharp ist bei mir drin:
                      pi@raspberrypi:/opt/iobroker $ npm list sharp --depth=2
                      iobroker.inst@2.0.3 /opt/iobroker
                      └─┬ iobroker.iot@1.4.14
                        └── sharp@0.25.2
                      S AlCalzoneA 2 Antworten Letzte Antwort
                          └── sharp@0.25.2
                        Smartuser
                        #74
                        @Thomas-Braun @AlCalzone
                        Viele Dank euch Beiden. Ich konnte jetzt erfolgreich die aktuelle libvips-version bauen.
                        Jetzt funktioniert alles. :) 👍
                        Ich habe es wie folgt gemacht:
                        cd /tmp
                        wget https://github.com/libvips/libvips/releases/download/v8.9.2/vips-8.9.2.tar.gz
                        tar xf vips-8.9.2.tar.gz
                        cd vips-8.9.2
                        ./configure
                        make
                        sudo make install
                        sudo ldconfig
                        Danach Sharp installiert.
                        cd /opt/iobroker
                        npm i sharp
                        Ohne Errors - Log:
                        rock64@rock64:/opt/iobroker$ npm i sharp
                        info sharp Detected globally-installed libvips v8.9.2
                        info sharp Building from source via node-gyp
                          CXX(target) Release/obj.target/sharp/src/metadata.o
                          CXX(target) Release/obj.target/sharp/src/stats.o
                          CXX(target) Release/obj.target/sharp/src/operations.o
                          CXX(target) Release/obj.target/sharp/src/pipeline.o
                          CXX(target) Release/obj.target/sharp/src/utilities.o
                          CXX(target) Release/obj.target/sharp/src/sharp.o
                          SOLINK_MODULE(target) Release/obj.target/sharp.node
                          COPY Release/sharp.node
                        + sharp@0.25.2
                        added 4 packages from 112 contributors in 137.029s
                        Zur Sicherheit nochmal den "Fixer" ausgeführt. Wahrscheinlich nicht notwendig, aber schadet ja auch nicht :)
                        iobroker stop
                        iobroker fix
                        iobroker start
                            └── sharp@0.25.2
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #75
                          @Thomas-Braun Zeile 5-22 ist alles das sharp-Modul
                          2-4 bin ich mir nicht sicher, sieht aber nach vorkompilierten binaries aus, die ggf von sharp bei der Installation heruntergeladen werden.
                            klausiob
                            #76
                            @Smartuser habe Deine Installation auf meinen Raspi mit rasbian stretch ausgeführt. Hat zwar ganz schön lang gedauert. Besonders die sharp-Installation. Dabei war meine Netzwerkverbindung noch abgebrochen.
                            iobroker.inst@1.3.1 /opt/iobroker
                            ├─┬ iobroker.iot@1.4.10
                            │ └── sharp@0.25.2  deduped
                            └── sharp@0.25.2
                            Habe jetzt so 5 Adapter upgedatet und die obigen Fehlermeldungen sind weg. Danke an alle.
                            VG klausiob
                            Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                            node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                              adaer
                              schrieb am zuletzt editiert von adaer
                              #77
                              @Smartuser: Auch ich hatte diese lästige Meldungen und habe deine Installation auf meinen Raspi mit rasbian stretch ebenfalls ausgeführt. Alles wieder im Lot.. :)
                              pi@MyRasPi:/opt/iobroker $ npm list sharp --depth=2
                              iobroker.inst@1.1.2 /opt/iobroker
                              ├─┬ iobroker.iot@1.4.14
                              └── sharp@0.25.2
                              Nochmals Danke ...
                              Gruss..
                              Henry
                              • W Offline
                                W Offline
                                Wing.Stefan
                                #78
                                Wie kann ich auf Synology im Docker den JS-Controller updaten?
                                Die gefundenen Anleitungen waren für Linux Windows usw. Im Syno Docker gibt es kein Sudo und kein SToppen von iobroker weil dann geht nichts mehr.
                                suche daher schritt für schritt Anleitung
                                • W Wing.Stefan
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #79
                                  @maestro sagte in Update js-controller und node.js:
                                  was meinst du damit !?
                                  pkill io
                                  iobroker update
                                  iobroker upgrade self
                                  iobroker start
                                  W 1 Antwort Letzte Antwort
                                  • GlasfaserG Glasfaser
                                    pkill io
                                    iobroker update
                                    iobroker start
                                    W Offline
                                    W Offline
                                    Wing.Stefan
                                    schrieb am zuletzt editiert von Wing.Stefan
                                    #80
                                    @Glasfaser
                                    die befehle bringen nichst weil das pkill io oder kill io nichts macht, ab befehl 3 sagt er nämlich das noch etwas läuft
                                    • W Wing.Stefan
                                      @Glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #81
                                      Klar geht das ...!!
                                      Bist du auch in der richtigen Docker Konsole .
                                      Zeige mal ein Screenshot
                                        Klar geht das ...!!
                                        W Offline
                                        W Offline
                                        Wing.Stefan
                                        #82
                                        • W Wing.Stefan
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #83
                                          @maestro
                                          gib mal ein
                                          iobroker stop
                                          pkill io
                                          aber mehrmals
                                          und dann
                                          ps auxww|grep io
