  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser
    npm i canvas
    Smartuser
    #68
    @Thomas-Braun sagte in Update js-controller und node.js:
    npm i canvas
    Es lief eine Weile, am Ende dieses Ergebnis:
    make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    In file included from ../src/common.cc:23:
    /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
     #include <glib-object.h>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + canvas@2.6.1
    updated 1 package in 158.31s
    22 packages are looking for funding
      run `npm fund` for details
    rock64@rock64:/opt/iobroker$
    • S Smartuser
      npm i canvas
      gyp ERR! not ok
      + canvas@2.6.1
      #69
      @Smartuser
      Sorry, irgendwas übersehe ich. Ich hab nur keinen Schimmer was.
      Muss sich einer anschauen, der in node tiefer drin ist.
      Auf meinem Raspberry mit ARMV7l Architektur baut der Kram.
      Keine Ahnung, ob das mit deiner AARCH64 zusammenhängt.
        @Smartuser
        Smartuser
        #70
        @Smartuser
        Auf meinem Raspberry mit ARMV71 Architektur baut der Kram.
        Ok .... danke für deine Mühe. 👍 👍 👏
        Eventuell nehm ich mal ein ayufan Image für den Rock64, vielleicht geht es damit
        • S Smartuser
          @Smartuser
          #71
          @Smartuser
          Ich installier mir das OS immer selber. Dann weiß ich auch mehr oder weniger was da läuft.
            @Smartuser
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #72
            @Thomas-Braun @Smartuser
            libvips ist gar kein npm-Paket. Da könnt ihr lange probieren
            ==> https://libvips.github.io/libvips/install.html#building-libvips-from-a-source-tarball
            Danach kann sharp rebuilded werden.
            • AlCalzoneA AlCalzone
              #73
              @AlCalzone Arrrgh! Schwerer Denkfehler von mir! Danke fürs aufwecken!
              Nur warum liegt das bei mir alles im node?
              pi@raspberrypi:~ $ locate libvips
              /home/iobroker/.npm/_libvips
              /home/iobroker/.npm/_libvips/libvips-8.9.0-linux-armv7.tar.gz
              /home/iobroker/.npm/_libvips/libvips-8.9.1-linux-armv7.tar.gz
              /opt/iobroker/node_modules/sharp/build/Release/.deps/Release/obj.target/libvips-cpp.stamp.d
              /opt/iobroker/node_modules/sharp/build/Release/obj.target/libvips-cpp.stamp
              /opt/iobroker/node_modules/sharp/build/libvips-cpp.target.mk
              /opt/iobroker/node_modules/sharp/install/libvips.js
              /opt/iobroker/node_modules/sharp/lib/libvips.js
              /opt/iobroker/node_modules/sharp/src/libvips
              /opt/iobroker/node_modules/sharp/src/libvips/cplusplus
              /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VConnection.cpp
              /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VError.cpp
              /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VImage.cpp
              /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VInterpolate.cpp
              /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/vips-operators.cpp
              /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so
              /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42
              /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42.12.1
              /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so
              /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42
              /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42.12.1
              Und sharp ist bei mir drin:
              pi@raspberrypi:/opt/iobroker $ npm list sharp --depth=2
              iobroker.inst@2.0.3 /opt/iobroker
              └─┬ iobroker.iot@1.4.14
                └── sharp@0.25.2
              S AlCalzoneA 2 Antworten Letzte Antwort
                  └── sharp@0.25.2
                Smartuser
                #74
                @Thomas-Braun @AlCalzone
                Viele Dank euch Beiden. Ich konnte jetzt erfolgreich die aktuelle libvips-version bauen.
                Jetzt funktioniert alles. :) 👍
                Ich habe es wie folgt gemacht:
                cd /tmp
                wget https://github.com/libvips/libvips/releases/download/v8.9.2/vips-8.9.2.tar.gz
                tar xf vips-8.9.2.tar.gz
                cd vips-8.9.2
                ./configure
                make
                sudo make install
                sudo ldconfig
                Danach Sharp installiert.
                cd /opt/iobroker
                npm i sharp
                Ohne Errors - Log:
                rock64@rock64:/opt/iobroker$ npm i sharp
                info sharp Detected globally-installed libvips v8.9.2
                info sharp Building from source via node-gyp
                  CXX(target) Release/obj.target/sharp/src/metadata.o
                  CXX(target) Release/obj.target/sharp/src/stats.o
                  CXX(target) Release/obj.target/sharp/src/operations.o
                  CXX(target) Release/obj.target/sharp/src/pipeline.o
                  CXX(target) Release/obj.target/sharp/src/utilities.o
                  CXX(target) Release/obj.target/sharp/src/sharp.o
                  SOLINK_MODULE(target) Release/obj.target/sharp.node
                  COPY Release/sharp.node
                + sharp@0.25.2
                added 4 packages from 112 contributors in 137.029s
                Zur Sicherheit nochmal den "Fixer" ausgeführt. Wahrscheinlich nicht notwendig, aber schadet ja auch nicht :)
                iobroker stop
                iobroker fix
                iobroker start
                    └── sharp@0.25.2
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #75
                  @Thomas-Braun Zeile 5-22 ist alles das sharp-Modul
                  2-4 bin ich mir nicht sicher, sieht aber nach vorkompilierten binaries aus, die ggf von sharp bei der Installation heruntergeladen werden.
                    klausiob
                    #76
                    @Smartuser habe Deine Installation auf meinen Raspi mit rasbian stretch ausgeführt. Hat zwar ganz schön lang gedauert. Besonders die sharp-Installation. Dabei war meine Netzwerkverbindung noch abgebrochen.
                    iobroker.inst@1.3.1 /opt/iobroker
                    ├─┬ iobroker.iot@1.4.10
                    │ └── sharp@0.25.2  deduped
                    └── sharp@0.25.2
                    Habe jetzt so 5 Adapter upgedatet und die obigen Fehlermeldungen sind weg. Danke an alle.
                    VG klausiob
                    Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                    node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                      adaer
                      schrieb am zuletzt editiert von adaer
                      #77
                      @Smartuser: Auch ich hatte diese lästige Meldungen und habe deine Installation auf meinen Raspi mit rasbian stretch ebenfalls ausgeführt. Alles wieder im Lot.. :)
                      pi@MyRasPi:/opt/iobroker $ npm list sharp --depth=2
                      iobroker.inst@1.1.2 /opt/iobroker
                      ├─┬ iobroker.iot@1.4.14
                      └── sharp@0.25.2
                      Nochmals Danke ...
                      Gruss..
                      Henry
                      • W Offline
                        W Offline
                        Wing.Stefan
                        #78
                        Wie kann ich auf Synology im Docker den JS-Controller updaten?
                        Die gefundenen Anleitungen waren für Linux Windows usw. Im Syno Docker gibt es kein Sudo und kein SToppen von iobroker weil dann geht nichts mehr.
                        suche daher schritt für schritt Anleitung
                        • W Wing.Stefan
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #79
                          @maestro sagte in Update js-controller und node.js:
                          was meinst du damit !?
                          pkill io
                          iobroker update
                          iobroker upgrade self
                          iobroker start
                          W 1 Antwort Letzte Antwort
                          • GlasfaserG Glasfaser
                            pkill io
                            iobroker update
                            iobroker start
                            W Offline
                            W Offline
                            Wing.Stefan
                            schrieb am zuletzt editiert von Wing.Stefan
                            #80
                            @Glasfaser
                            die befehle bringen nichst weil das pkill io oder kill io nichts macht, ab befehl 3 sagt er nämlich das noch etwas läuft
                            • W Wing.Stefan
                              @Glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #81
                              Klar geht das ...!!
                              Bist du auch in der richtigen Docker Konsole .
                              Zeige mal ein Screenshot
                                Klar geht das ...!!
                                W Offline
                                W Offline
                                Wing.Stefan
                                #82
                                • W Wing.Stefan
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #83
                                  @maestro
                                  gib mal ein
                                  iobroker stop
                                  pkill io
                                  aber mehrmals
                                  und dann
                                  ps auxww|grep io
                                    @maestro
                                    gib mal ein
                                    iobroker stop
                                    pkill io
                                    aber mehrmals
                                    und dann
                                    ps auxww|grep io
                                    W Offline
                                    W Offline
                                    Wing.Stefan
                                    #84
                                    @Glasfaser said in Update js-controller und node.js:
                                    ps auxww|grep io
                                    root@iobroker:/opt/iobroker# iobroker stop
                                    iobroker controller daemon is not running
                                    root@iobroker:/opt/iobroker# ^C
                                    root@iobroker:/opt/iobroker# pkill io#
                                    root@iobroker:/opt/iobroker# ps auxww|grep io
                                    root 1 0.0 0.0 7044 1444 pts/0 Ss+ 16:26 0:00 /bin/bash /opt/scripts/iobroker_startup.sh
                                    iobroker 436 2.8 0.4 862128 78244 pts/0 Sl+ 16:26 0:24 iobroker.js-controller
                                    iobroker 458 1.0 0.4 862236 77696 pts/0 Sl+ 16:26 0:09 io.admin.0
                                    iobroker 473 0.2 0.1 610404 32740 pts/0 Sl+ 16:26 0:01 io.discovery.0
                                    iobroker 488 0.3 0.2 680584 37396 pts/0 Sl+ 16:26 0:03 io.info.0
                                    iobroker 507 0.7 0.2 678264 38040 pts/0 Sl+ 16:26 0:06 io.loxone.0
                                    iobroker 990 1.2 0.2 888508 48192 pts/0 Sl+ 16:26 0:10 io.alexa2.0
                                    iobroker 1005 1.2 0.5 687080 96532 pts/0 Sl+ 16:26 0:10 io.javascript.0
                                    iobroker 1020 0.2 0.2 611312 33644 pts/0 Sl+ 16:27 0:01 io.simple-api.0
                                    iobroker 1035 0.3 0.2 699868 43328 pts/0 Sl+ 16:27 0:03 io.tuya.0
                                    root 1127 0.0 0.0 6404 980 pts/1 S+ 16:40 0:00 grep io
                                    root@iobroker:/opt/iobroker# iobroker upgrade self
                                    Controller is running. Please stop ioBroker first.
                                    • W Wing.Stefan
                                      ps auxww|grep io
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #85
                                      @maestro
                                      sehr merkwürdig , das noch etwas läuft ...
                                      kill -9 <prozessid>
                                      also
                                      kill -9 436
                                      kill -9 458
                                      usw.
                                      schau aber mit .. nach ober er dann weg ist
                                      ps auxww|grep io
                                      • W Offline
                                        W Offline
                                        Wing.Stefan
                                        #86
                                        kill -9 <prozessid>
                                        Danke dir, danach konnte ich upgrade starten und auch mit iobroker start den iobroker starten. Meldung ist weg die js-controller 3 version ist installiert.
                                        Vielen Dank nochmals und ein schönes Wochenende
                                        • W Wing.Stefan
                                          kill -9 <prozessid>
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #87
                                          Danke dir,
                                          Sehr gerne ...
