  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @AlCalzone Arrrgh! Schwerer Denkfehler von mir! Danke fürs aufwecken!
    Nur warum liegt das bei mir alles im node?
    pi@raspberrypi:~ $ locate libvips
    /home/iobroker/.npm/_libvips
    /home/iobroker/.npm/_libvips/libvips-8.9.0-linux-armv7.tar.gz
    /home/iobroker/.npm/_libvips/libvips-8.9.1-linux-armv7.tar.gz
    /opt/iobroker/node_modules/sharp/build/Release/.deps/Release/obj.target/libvips-cpp.stamp.d
    /opt/iobroker/node_modules/sharp/build/Release/obj.target/libvips-cpp.stamp
    /opt/iobroker/node_modules/sharp/build/libvips-cpp.target.mk
    /opt/iobroker/node_modules/sharp/install/libvips.js
    /opt/iobroker/node_modules/sharp/lib/libvips.js
    /opt/iobroker/node_modules/sharp/src/libvips
    /opt/iobroker/node_modules/sharp/src/libvips/cplusplus
    /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VConnection.cpp
    /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VError.cpp
    /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VImage.cpp
    /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/VInterpolate.cpp
    /opt/iobroker/node_modules/sharp/src/libvips/cplusplus/vips-operators.cpp
    /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so
    /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42
    /opt/iobroker/node_modules/sharp/vendor/lib/libvips-cpp.so.42.12.1
    /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so
    /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42
    /opt/iobroker/node_modules/sharp/vendor/lib/libvips.so.42.12.1
    Und sharp ist bei mir drin:
    pi@raspberrypi:/opt/iobroker $ npm list sharp --depth=2
    iobroker.inst@2.0.3 /opt/iobroker
    └─┬ iobroker.iot@1.4.14
      └── sharp@0.25.2
    Smartuser
    #74
    @Thomas-Braun @AlCalzone
    Viele Dank euch Beiden. Ich konnte jetzt erfolgreich die aktuelle libvips-version bauen.
    Jetzt funktioniert alles. :) 👍
    Ich habe es wie folgt gemacht:
    cd /tmp
    wget https://github.com/libvips/libvips/releases/download/v8.9.2/vips-8.9.2.tar.gz
    tar xf vips-8.9.2.tar.gz
    cd vips-8.9.2
    ./configure
    make
    sudo make install
    sudo ldconfig
    Danach Sharp installiert.
    cd /opt/iobroker
    npm i sharp
    Ohne Errors - Log:
    rock64@rock64:/opt/iobroker$ npm i sharp
    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    info sharp Detected globally-installed libvips v8.9.2
    info sharp Building from source via node-gyp
    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
      CXX(target) Release/obj.target/sharp/src/metadata.o
      CXX(target) Release/obj.target/sharp/src/stats.o
      CXX(target) Release/obj.target/sharp/src/operations.o
      CXX(target) Release/obj.target/sharp/src/pipeline.o
      CXX(target) Release/obj.target/sharp/src/utilities.o
      CXX(target) Release/obj.target/sharp/src/sharp.o
      SOLINK_MODULE(target) Release/obj.target/sharp.node
      COPY Release/sharp.node
    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    + sharp@0.25.2
    added 4 packages from 112 contributors in 137.029s
    22 packages are looking for funding
      run `npm fund` for details
    Zur Sicherheit nochmal den "Fixer" ausgeführt. Wahrscheinlich nicht notwendig, aber schadet ja auch nicht :)
    iobroker stop
    iobroker fix
    iobroker start
        └── sharp@0.25.2
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #75
      @Thomas-Braun Zeile 5-22 ist alles das sharp-Modul
      2-4 bin ich mir nicht sicher, sieht aber nach vorkompilierten binaries aus, die ggf von sharp bei der Installation heruntergeladen werden.
        klausiob
        #76
        @Smartuser habe Deine Installation auf meinen Raspi mit rasbian stretch ausgeführt. Hat zwar ganz schön lang gedauert. Besonders die sharp-Installation. Dabei war meine Netzwerkverbindung noch abgebrochen.
        iobroker.inst@1.3.1 /opt/iobroker
        ├─┬ iobroker.iot@1.4.10
        │ └── sharp@0.25.2  deduped
        └── sharp@0.25.2
        Habe jetzt so 5 Adapter upgedatet und die obigen Fehlermeldungen sind weg. Danke an alle.
        VG klausiob
        Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
        node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
          adaer
          schrieb am zuletzt editiert von adaer
          #77
          @Smartuser: Auch ich hatte diese lästige Meldungen und habe deine Installation auf meinen Raspi mit rasbian stretch ebenfalls ausgeführt. Alles wieder im Lot.. :)
          pi@MyRasPi:/opt/iobroker $ npm list sharp --depth=2
          iobroker.inst@1.1.2 /opt/iobroker
          ├─┬ iobroker.iot@1.4.14
          └── sharp@0.25.2
          Nochmals Danke ...
          Gruss..
          Henry
          • W Offline
            W Offline
            Wing.Stefan
            #78
            Wie kann ich auf Synology im Docker den JS-Controller updaten?
            Die gefundenen Anleitungen waren für Linux Windows usw. Im Syno Docker gibt es kein Sudo und kein SToppen von iobroker weil dann geht nichts mehr.
            suche daher schritt für schritt Anleitung
            • W Wing.Stefan
              GlasfaserG Offline
              GlasfaserG Offline
              #79
              @maestro sagte in Update js-controller und node.js:
              was meinst du damit !?
              pkill io
              iobroker update
              iobroker upgrade self
              iobroker start
              W 1 Antwort Letzte Antwort
              • GlasfaserG Glasfaser
                pkill io
                iobroker update
                iobroker start
                W Offline
                W Offline
                Wing.Stefan
                schrieb am zuletzt editiert von Wing.Stefan
                #80
                @Glasfaser
                die befehle bringen nichst weil das pkill io oder kill io nichts macht, ab befehl 3 sagt er nämlich das noch etwas läuft
                • W Wing.Stefan
                  @Glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #81
                  Klar geht das ...!!
                  Bist du auch in der richtigen Docker Konsole .
                  Zeige mal ein Screenshot
                    Klar geht das ...!!
                    W Offline
                    W Offline
                    Wing.Stefan
                    #82
                    • W Wing.Stefan
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #83
                      @maestro
                      gib mal ein
                      iobroker stop
                      pkill io
                      aber mehrmals
                      und dann
                      ps auxww|grep io
                        @maestro
                        gib mal ein
                        iobroker stop
                        pkill io
                        aber mehrmals
                        und dann
                        ps auxww|grep io
                        W Offline
                        W Offline
                        Wing.Stefan
                        #84
                        @Glasfaser said in Update js-controller und node.js:
                        ps auxww|grep io
                        root@iobroker:/opt/iobroker# iobroker stop
                        iobroker controller daemon is not running
                        root@iobroker:/opt/iobroker# ^C
                        root@iobroker:/opt/iobroker# pkill io#
                        root@iobroker:/opt/iobroker# ps auxww|grep io
                        root 1 0.0 0.0 7044 1444 pts/0 Ss+ 16:26 0:00 /bin/bash /opt/scripts/iobroker_startup.sh
                        iobroker 436 2.8 0.4 862128 78244 pts/0 Sl+ 16:26 0:24 iobroker.js-controller
                        iobroker 458 1.0 0.4 862236 77696 pts/0 Sl+ 16:26 0:09 io.admin.0
                        iobroker 473 0.2 0.1 610404 32740 pts/0 Sl+ 16:26 0:01 io.discovery.0
                        iobroker 488 0.3 0.2 680584 37396 pts/0 Sl+ 16:26 0:03 io.info.0
                        iobroker 507 0.7 0.2 678264 38040 pts/0 Sl+ 16:26 0:06 io.loxone.0
                        iobroker 990 1.2 0.2 888508 48192 pts/0 Sl+ 16:26 0:10 io.alexa2.0
                        iobroker 1005 1.2 0.5 687080 96532 pts/0 Sl+ 16:26 0:10 io.javascript.0
                        iobroker 1020 0.2 0.2 611312 33644 pts/0 Sl+ 16:27 0:01 io.simple-api.0
                        iobroker 1035 0.3 0.2 699868 43328 pts/0 Sl+ 16:27 0:03 io.tuya.0
                        root 1127 0.0 0.0 6404 980 pts/1 S+ 16:40 0:00 grep io
                        root@iobroker:/opt/iobroker# iobroker upgrade self
                        Controller is running. Please stop ioBroker first.
                        • W Wing.Stefan
                          ps auxww|grep io
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #85
                          @maestro
                          sehr merkwürdig , das noch etwas läuft ...
                          kill -9 <prozessid>
                          also
                          kill -9 436
                          kill -9 458
                          usw.
                          schau aber mit .. nach ober er dann weg ist
                          ps auxww|grep io
                          • W Offline
                            W Offline
                            Wing.Stefan
                            #86
                            kill -9 <prozessid>
                            Danke dir, danach konnte ich upgrade starten und auch mit iobroker start den iobroker starten. Meldung ist weg die js-controller 3 version ist installiert.
                            Vielen Dank nochmals und ein schönes Wochenende
                            • W Wing.Stefan
                              kill -9 <prozessid>
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #87
                              Danke dir,
                              Sehr gerne ...
                              • spicerS Offline
                                spicerS Offline
                                spicer
                                #88
                                Hallo Gemeinde
                                Mir wird das js-controller Update angeboten.
                                Darf/soll ich das machen, ohne das Probleme entstehn? Alle Adapter sind auf dem neuesten Stand.
                                Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
                                (Murphys Gesetz)
                                • spicerS spicer
                                  Hallo Gemeinde
                                  #89
                                  @spicer sagte in Update js-controller und node.js:
                                  Glaskugelmodus_ein Möglicherweise.
                                  Die Version ist jetzt stable und aus dem Beta-Testing entlassen.
                                  spicerS 1 Antwort Letzte Antwort
                                    spicerS Offline
                                    spicerS Offline
                                    spicer
                                    #90
                                    Ich meinte eher, ob die Kompatibilität zu den installierten Adaptern und ioBroker Version gewährleistet sein sollte ;)
                                    Oder ob da ev vorgängig andere Versionen installiert werden müssen.
                                    (Murphys Gesetz)
                                    • spicerS spicer
                                      #91
                                      Die aktuellen halt. Aber hat man ja eh immer am Start.
                                        spicerS Offline
                                        spicerS Offline
                                        spicer
                                        #92
                                        Genau. Habe immer brav alle Updates gemacht ^^
                                        (Murphys Gesetz)
                                        • spicerS spicer
                                          #93
                                          @spicer
                                          Dann lies hier rein:
                                          https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable
