  4. Javascript Adapter rot (out of memory)
javascript
82 Beiträge 6 Kommentatoren 12.2k Aufrufe 5 Beobachtet
  • M maxpd
    @Thomas-Braun
    Leider hat sich nach einem Neustart ein Folgeproblem ergeben. Zigbee läuft nicht mehr.
    Ich vermute ich muss npm rebuild machen. Aber in welchem Ordner genau? Ich hab mir damit schonmal das System zerschossen.
    host.iobroker	2020-05-07 20:53:15.856	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker	2020-05-07 20:53:15.855	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-05-07 20:53:15.855	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.iobroker	2020-05-07 20:53:15.855	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.iobroker	2020-05-07 20:53:15.855	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.iobroker	2020-05-07 20:53:15.852	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.iobroker	2020-05-07 20:53:15.852	error	Caught by controller[0]: ^
    host.iobroker	2020-05-07 20:53:15.852	error	Caught by controller[0]: throw e;
    host.iobroker	2020-05-07 20:53:15.851	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.iobroker	2020-05-07 20:53:15.459	info	instance system.adapter.zigbee.0 started with pid 3641
    @maxpd said in Javascript Adapter rot (out of memory):
    Versuch mal in /opt/iobroker
    iobroker rebuild iobroker.zigbee --install
    Thomas BraunT M 2 Antworten Letzte Antwort
      @maxpd sagte in Javascript Adapter rot (out of memory):
      Bei lokalisierung war Berlin drin.
      das ist Deutsch-Belgien
      @Homoran said in Javascript Adapter rot (out of memory):
      Pommes und Bier! Lecker! :-)
        @Thomas-Braun said in Javascript Adapter rot (out of memory):
        Oder auch in /opt/iobroker
        npm rebuild bindings
          maxpd
          @Thomas-Braun will er nicht.
          pi@iobroker:/opt/iobroker $ iobroker rebuild iobroker.zigbee --install
          Commands:
          iobroker setup [--objects <host>] [--states <host>] [custom]
          iobroker start
          iobroker stop
          iobroker start <adapter>
          iobroker stop <adapter>
          iobroker start all
          iobroker restart
          iobroker restart <adapter>
          iobroker info
          iobroker logs [adapter] [--watch] [--lines=1000]
          iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
          iobroker install <adapter>
          iobroker url <url> [<name>]
          iobroker del <adapter>
          iobroker del <adapter>.<instance>
          iobroker update [repository url] [--updatable/--u] [--installed/--i]
          iobroker upgrade [repository url]
          iobroker upgrade self [repository url]
          iobroker upgrade <adapter> [repository url]
          iobroker upload <pathToLocalFile> <pathIniobroker>
          iobroker upload all
          iobroker upload <adapter>
          iobroker object get <id>
          iobroker object set <id> <json-value>
          iobroker object set <id> propertyname=value
          iobroker object del <id|pattern> [--yes]
          iobroker object chmod <object-mode> [state-mode] <id>
          iobroker object chown <user> <group> <id>
          iobroker object list <id>
          iobroker state get <id>
          iobroker state getplain <id> [--pretty]
          iobroker state getvalue <id>
          iobroker state set <id> <value> [ack]
          iobroker state del <id>
          iobroker message <adapter>[.instanceid] <command> [<message>]
          iobroker list <type> [filter]
          iobroker chmod <mode> <file>
          iobroker chown <user> <group> <file>
          iobroker touch <file>
          iobroker rm <file>
          iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
          iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
          iobroker file rm <iobroker-path-to-delete>
          iobroker file sync
          iobroker user add <user> [--ingroup group] [--password pass]
          iobroker user del <user>
          iobroker user passwd <user> [--password pass]
          iobroker user enable <user>
          iobroker user disable <user>
          iobroker user get <user>
          iobroker user check <user> [--password pass]
          iobroker group add <group>
          iobroker group del <group>
          iobroker group list <group>
          iobroker group enable <group>
          iobroker group disable <group>
          iobroker group get <group>
          iobroker group adduser <group> <user>
          iobroker group deluser <group> <user>
          iobroker host this
          iobroker host <hostname>
          iobroker host set <hostname>
          iobroker host remove <hostname>
          iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
          iobroker license <license.file or license.text>
          iobroker cert create
          iobroker cert view [<certificate name>]
          iobroker clean
          iobroker backup
          iobroker restore <backup name or path>
          iobroker validate <backup name or path>
          iobroker <command> --timeout 5000
          iobroker status [all]
          iobroker repo [name]
          iobroker repo add <name> <path or url>
          iobroker repo set <name>
          iobroker repo del <name>
          iobroker uuid
          iobroker unsetup
          iobroker fix
          iobroker multihost <enable|disable> [--secure true|false]
          iobroker multihost browse
          iobroker multihost connect
          iobroker compact status
          iobroker compact <enable|on|disable|off>
          iobroker compact <adapter>.<instance> status
          iobroker compact <adapter>.<instance> group <group-id>
          iobroker compact <adapter>.<instance> <disable|off>
          iobroker compact <adapter>.<instance> <enable|on> [group-id]
          iobroker version [adapter]
          iobroker [adapter] -v
          Options:
            --help     Hilfe anzeigen  [boolean]
            --version  Version anzeigen  [boolean]
          maxpd
            maxpd
            @Thomas-Braun nee, startet damit auch noch nicht.
            maxpd
            • M maxpd
              Commands:
              iobroker start
              iobroker stop
              iobroker start all
              iobroker restart
              iobroker info
              iobroker upload all
              iobroker rm <file>
              iobroker file sync
              iobroker host this
              iobroker clean
              iobroker backup
              iobroker uuid
              iobroker unsetup
              iobroker fix
              Options:
              @maxpd
              iobroker version
                @maxpd
                iobroker version
                maxpd
                @Thomas-Braun 2.2.9
                maxpd
                • M maxpd
                  @Thomas-Braun 2.2.9
                  @maxpd
                  Möglich das 2.2.9 das noch nicht kann. Bei mir gibt es 'rebuild' in 3.0.20.
                  Dann
                  npm rebuild iobroker.zigbee
                    @maxpd
                    Dann
                    maxpd
                    @Thomas-Braun
                    Dabei hab ich das System neu aufgesetzt. Warum bin ich eine ganze Hauptversion hintendran?!
                    Auch der rebuild lässt Zigbee nicht starten. Fehler bleibt der gleiche.
                    maxpd
                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                    • M maxpd
                      @Thomas-Braun
                      @maxpd
                      Bist du auf 'default'? V3 ist glaube ich erst in 'latest' drin.
                      M 3 Antworten Letzte Antwort
                        @maxpd
                        maxpd
                        @Thomas-Braun
                        Habe das Image
                        maxpd
                        • M maxpd
                          @Thomas-Braun
                          Habe das Image
                          @maxpd Das Image hat mit iobroker nichts direkt zu tun.
                            @maxpd
                            maxpd
                            @Thomas-Braun ich vermute ^^
                            maxpd
                              @maxpd
                              maxpd
                              @maxpd
                              ich vermute ^^
                              maxpd
                              • M maxpd
                                @maxpd
                                ich vermute ^^
                                @maxpd
                                Schau mal unter dem 'Schraubenschlüssel' im Admin unter 'Verwahrungsort' nach. Dürfte aber 'default' sein.
                                Hast du die bindings neugebaut?
                                  @maxpd
                                  maxpd
                                  @maxpd
                                  maxpd
                                  • M maxpd
                                    @maxpd
                                    @maxpd Auf dem ersten Reiter.
                                    2.2.9. ist in 'default', hab gerade schon geschaut. Lass das mal da stehen.
                                    • M maxpd
                                      @Thomas-Braun
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      auch der rebuild lässt Zigbee nicht starten. Fehler bleibt der gleiche.
                                      Das ist Murks ... warum postet du hier nicht weiter !!!!
                                      Link Text
                                        maxpd
                                        Ist im Ordner /opt/iobroker eine Datei package-lock.json? -JA
                                        Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @? -JA
                                        Zeige bitte den Inhalt der Datei /opt/iobroker/package.json.
                                        pi@iobroker:/opt/iobroker $ cat package.json
                                          "name": "iobroker.inst",
                                          "version": "2.0.3",
                                          "private": true,
                                          "description": "Automation platform in node.js",
                                          "scripts": {
                                            "install": "node lib/checkVersions.js",
                                            "postinstall": "node lib/install.js",
                                            "test": "node node_modules/mocha/bin/mocha --exit"
                                          "dependencies": {
                                            "colors": "^1.3.3",
                                            "fs-extra": "^7.0.1",
                                            "iobroker": "^2.0.3",
                                            "iobroker.admin": "^4.0.9",
                                            "iobroker.chromecast": "^2.3.1",
                                            "iobroker.cloud": "^3.0.3",
                                            "iobroker.daswetter": "^2.8.1",
                                            "iobroker.denon": "^1.7.4",
                                            "iobroker.discovery": "^2.2.2",
                                            "iobroker.google-sharedlocations": "https://github.com/t4qjXH8N/ioBroker.google-sharedlocations/tarball/ec1d15964dc6f3995f744d240d8b972bf25331fe",
                                            "iobroker.history": "^1.8.7",
                                            "iobroker.hm-rega": "^2.5.5",
                                            "iobroker.hm-rpc": "^1.12.10",
                                            "iobroker.info": "^1.5.6",
                                            "iobroker.iot": "^1.4.14",
                                            "iobroker.javascript": "^4.5.1",
                                            "iobroker.js-controller": "^2.2.9",
                                            "iobroker.lgtv": "^1.1.6",
                                            "iobroker.mihome-vacuum": "^1.1.5",
                                            "iobroker.ping": "^1.3.2",
                                            "iobroker.sayit": "^1.8.2",
                                            "iobroker.shelly": "^3.1.6",
                                            "iobroker.shuttercontrol": "^0.4.3",
                                            "iobroker.socketio": "^3.0.6",
                                            "iobroker.sonoff": "^2.3.3",
                                            "iobroker.telegram": "^1.4.3",
                                            "iobroker.terminal": "^0.1.2",
                                            "iobroker.text2command": "^1.3.0",
                                            "iobroker.tr-064": "^0.4.18",
                                            "iobroker.web": "^3.0.7",
                                            "iobroker.wifilight": "https://github.com/iobroker-community-adapters/ioBroker.wifilight/tarball/3b408fefaca79abe9bb404216791b5408d3d6d52",
                                            "iobroker.yeelight-2": "^1.0.3",
                                            "iobroker.zigbee": "^1.0.4",
                                            "semver": "^5.6.0",
                                            "yargs": "^7.0.2"
                                        maxpd
                                        • M maxpd
                                            "version": "2.0.3",
                                            "private": true,
                                            "scripts": {
                                            "dependencies": {
                                              "colors": "^1.3.3",
                                              "semver": "^5.6.0",
                                              "yargs": "^7.0.2"
                                          @maxpd
                                          In den anderen Thread wurde dann deine Zeile 16 gelöscht und das Ding lief wieder. Kannst du auch mal probieren.
                                          Ich übernehme aber keine Gewähr, das deine Kiste nicht explodiert und die Katze tötet.
                                          GlasfaserG M 3 Antworten Letzte Antwort
