  4. Fehler bei Update diverser Adapter.
install adapter update
71 Beiträge 5 Kommentatoren 8.5k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @Landmilch
    npm install iobroker.js-controller
    Landmilch
    @Glasfaser said in Fehler bei Update diverser Adapter.:
    Besser, aber leider am Ende auch mit Fehlermeldungen.
    pi@iobroker:/opt/iobroker $ npm install js-controller
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/js-controller - Not found
    npm ERR! 404
    npm ERR! 404  'js-controller@latest' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     /home/iobroker/.npm/_logs/2020-05-06T21_59_22_132Z-debug.log
    pi@iobroker:/opt/iobroker $ start iobroker
    -bash: start: Kommando nicht gefunden.
    pi@iobroker:/opt/iobroker $ iobroker start
    pi@iobroker:/opt/iobroker $ npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > node-aead-crypto@2.2.0 preinstall /opt/iobroker/node_modules/node-aead-crypto
    > node lib/preinstall.js
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    > iobroker.js-controller@3.0.20 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.4
    > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
    > node lib/checkVersions.js
    NPM version: 6.14.4
    > iobroker.js-controller@3.0.20 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object system.certificates updated
    > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
    > node lib/install.js
    │ Manual installation of ioBroker is no longer supported  │
    │ on Linux, OSX and FreeBSD!                              │
    │ Please refer to the documentation on how to install it! │
    │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.0 (node_modules/node-aead-crypto):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.0 preinstall: `node lib/preinstall.js`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! code ELIFECYCLE
    npm ERR! errno 100
    npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
    npm ERR! Exit status 100
    npm ERR!
    npm ERR! Failed at the iobroker@2.0.3 postinstall script.
    npm ERR!     /home/iobroker/.npm/_logs/2020-05-06T22_03_45_381Z-debug.log```
    • L Landmilch
      npm ERR! code E404
      npm ERR! 404
      npm ERR! 404
      NPM version: 6.14.4
      NPM version: 6.14.4
      > node lib/install.js
      npm ERR! errno 100
      npm ERR!
      @Landmilch
      iobroker upgrade self
      Aber den hatten wir glaube ich schon versucht.
      L GlasfaserG 2 Antworten Letzte Antwort
        @Landmilch
        Landmilch
        @Thomas-Braun said in Fehler bei Update diverser Adapter.:
        pi@iobroker:/opt/iobroker $ iobroker upgrade self
        Host    "iobroker"       is up to date.
          @Landmilch
          GlasfaserG Offline
          GlasfaserG Offline
          @Thomas-Braun
          Ich will hier nicht reingrätschen ...
          Vielleicht lief der npm rebuild nicht sauber durch !?
          L 1 Antwort Letzte Antwort
            @Thomas-Braun
            Landmilch
            @Thomas-Braun
            Vielleicht lief der npm rebulid nicht sauber durch !?
            Soll ich den noch einmal durchlaufen lassen?
            Wenn ja, wie?
            • L Landmilch
              @Landmilch
              iobroker rebuild self --install
                @Landmilch
                Landmilch
                @Landmilch
                Hab iobroker gestoppt. Dann rebuild ausgeführt. Danach iobroker wieder gestartet.
                Das ist das Ergebnis
                npm install iobroker.history@1.9.6 --loglevel error --prefix "/opt/iobroker" (System call)
                npm ERR! errno 100
                npm ERR!
                npm ERR!     /home/iobroker/.npm/_logs/2020-05-06T22_16_24_745Z-debug.log
                host.iobroker Cannot install iobroker.history@1.9.6: 100
                • L Landmilch
                  @Landmilch
                  npm ERR! errno 100
                  npm ERR!
                  @Landmilch Keine Ahnung dann.
                  which iobroker
                  L 2 Antworten Letzte Antwort
                    which iobroker
                    Landmilch
                    which iobroker
                    pi@iobroker:/opt/iobroker $ which iobroker
                    /usr/bin/iobroker
                    • L Landmilch
                      which iobroker
                      /usr/bin/iobroker
                      @Landmilch
                      ls -la /usr/bin/iobroker
                        which iobroker
                        Landmilch
                        which iobroker
                        @Thomas-Braun @Glasfaser @paul53
                        Danke für euren Einsatz. Ich bin für heute raus. Muss jetzt erst mal schlafen. Morgen noch mal ausgeschlafen ran.
                          @Landmilch
                          Landmilch
                          Voila
                          pi@iobroker:/opt/iobroker $ ls -la /usr/bin/iobroker
                          lrwxrwxrwx 1 root root 22 Mai  6 23:22 /usr/bin/iobroker -> /opt/iobroker/iobroker
                          • L Landmilch
                            Voila
                            @Landmilch
                            Nicht dass dein hostname 'iobroker' da für Trouble sorgt...
                              @Landmilch
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @Thomas-Braun
                              Bei jeder Fehlermeldung ist im Log ein Link :
                              als würde das System denken es hat eine alte Version installiert .
                              Thomas BraunT L 2 Antworten Letzte Antwort
                                @Thomas-Braun
                                Oder zwei Installationen.
                                  @Thomas-Braun
                                  Landmilch
                                  @Thomas-Braun
                                  Kann ich das System umbenennen?
                                    Landmilch
                                    #66
                                    Wenn das so ist, wie kann ich das prüfen?
                                    • L Landmilch
                                      @Thomas-Braun
                                      #67
                                      @Landmilch
                                      Kannst du hier ändern:
                                      sudo nano /etc/hostname
                                      sudo nano /etc/hosts
                                      Danach einmal rebooten, am besten.
                                      • AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #68
                                        @Landmilch
                                        iobroker@2.0.3 ist das Kern-Paket, dass beim Installieren benötigt wird. Deine Installation denkt wohl, dass das fehlt und bricht daraufhin alle npm-Installationen ab. Eigentlich sollte es auch gar nicht installiert sein, sondern enthält nur die Dateien, die zur Installation benötigt werden. Aus deiner Post-Historie vermute ich, dass du es ausversehen installiert hast, weil du Befehle nicht richtig abgetippt hast.
                                        Bitte genau lesen, nicht wie oben immer mal wieder Teile übersehen! Und bitte meine Antwort abwarten, nicht draus irgendwelchen Handlungsbedarf ableiten.
                                        1. Ist im Ordner /opt/iobroker eine Datei package-lock.json?
                                        2. Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @?
                                        3. Zeige bitte den Inhalt der Datei /opt/iobroker/package.json.
                                        • AlCalzoneA AlCalzone
                                          @Landmilch
                                          Landmilch
                                          schrieb am zuletzt editiert von Landmilch
                                          #69
                                          @AlCalzone said in Fehler bei Update diverser Adapter.:
                                          @Landmilch
                                          1. Ist im Ordner /opt/iobroker eine Datei package-lock.json? JA
                                          2. Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @? NEIN
                                          Voila.
                                          pi@homebrain:/opt/iobroker $ cat package.json
                                            "name": "iobroker.inst",
                                            "version": "2.0.3",
                                            "private": true,
                                            "description": "Automation platform in node.js",
                                            "scripts": {
                                              "install": "node lib/checkVersions.js",
                                              "postinstall": "node lib/install.js",
                                              "test": "node node_modules/mocha/bin/mocha --exit"
                                            "dependencies": {
                                              "colors": "^1.3.3",
                                              "fs-extra": "^7.0.1",
                                              "iobroker": "^2.0.3",
                                              "iobroker.admin": "^4.1.1",
                                              "iobroker.backitup": "^1.5.6",
                                              "iobroker.bmw": "^1.4.0",
                                              "iobroker.cloud": "^3.0.3",
                                              "iobroker.coronavirus-statistics": "^0.5.9",
                                              "iobroker.daswetter": "^2.8.1",
                                              "iobroker.discovergy": "^0.5.4",
                                              "iobroker.discovery": "^2.3.5",
                                              "iobroker.dwd": "^2.4.8",
                                              "iobroker.feiertage": "^1.0.19",
                                              "iobroker.find-my-iphone": "^0.2.17",
                                              "iobroker.fritzdect": "^0.3.2",
                                              "iobroker.history": "^1.9.5",
                                              "iobroker.hs100": "^1.1.2",
                                              "iobroker.ical": "^1.7.0",
                                              "iobroker.icons-material-png": "^0.1.0",
                                              "iobroker.influxdb": "^1.8.4",
                                              "iobroker.info": "^1.7.1",
                                              "iobroker.javascript": "^4.5.1",
                                              "iobroker.js-controller": "^3.0.20",
                                              "iobroker.luftdaten": "0.0.11",
                                              "iobroker.mobile": "^0.5.0",
                                              "iobroker.rpi2": "^1.2.0",
                                              "iobroker.samsung_tizen": "https://github.com/dahuby/iobroker.samsung_tizen/tarball/master",
                                              "iobroker.sayit": "^1.8.2",
                                              "iobroker.scenes": "^1.1.0",
                                              "iobroker.shuttercontrol": "^0.5.0",
                                              "iobroker.simple-api": "^2.4.4",
                                              "iobroker.sonos": "^2.0.1",
                                              "iobroker.spotify-premium": "^1.0.0",
                                              "iobroker.telegram": "^1.5.8",
                                              "iobroker.text2command": "^1.3.0",
                                              "iobroker.tr-064": "^4.0.1",
                                              "iobroker.tradfri": "^2.6.2",
                                              "iobroker.vis": "^1.2.6",
                                              "iobroker.web": "^3.0.7",
                                              "iobroker.yahka": "^0.11.0",
                                              "semver": "^5.6.0",
                                              "yargs": "^7.0.2"
                                          pi@homebrain:/opt/iobroker $ ls
                                          backups                   CHANGELOG_INSTALLER_LINUX.md  INSTALLER_INFO.txt  iobroker-data  log           package-lock.json
                                          cache                     fix_installation.sh           iob                 lib            node_modules  README.md
                                          CHANGELOG_FIXER_LINUX.md  install                       iobroker            LICENSE        package.json  reinstall.js
                                          pi@homebrain:/opt/iobroker/node_modules $ ls
                                          abort-controller            es6-promise                      jsonfile                     rasha
                                          accepts                     es-abstract                      json-schema                  raw-body
                                          acme                        escape-html                      json-schema-traverse         rc
                                          acme-dns-01-cli             escape-string-regexp             json-stringify-safe          read
                                          acme-v2                     es-to-primitive                  jsonwebtoken                 readable-stream
                                          after                       etag                             jsprim                       readdirp
                                          agent-base                  eventemitter3                    jszip                        readline-sync
                                          ajv                         events                           jwa                          read-pkg
                                          alcalzone-shared            event-stream                     jws                          read-pkg-up
                                          ansi-regex                  event-target-shim                keypairs                     redis-commands
                                          ansi-styles                 expand-template                  kuler                        redis-errors
                                          anymatch                    express                          lcid                         redis-parser
                                          aproba                      express-fileupload               le-acme-core                 reduce-flatten
                                          are-we-there-yet            express-session                  le-challenge-fs              reflect-metadata
                                          arg                         extend                           le-sni-auto                  regenerator-runtime
                                          array-back                  extsprintf                       le-store-certbot             regexp.prototype.flags
                                          arraybuffer.slice           eyes                             lie                          request
                                          array-ext                   fast-deep-equal                  loadavg-windows              request-promise
                                          array-flatten               fast-json-stable-stringify       load-json-file               request-promise-core
                                          array.prototype.findindex   fast-safe-stringify              locate-path                  request-promise-native
                                          arrify                      fast-srp-hap                     lodash                       require-directory
                                          asap                        fast-text-encoding               lodash.assignin              require-main-filename
                                          asn1                        fecha                            lodash.bind                  resolve
                                          assert-plus                 file-stream-rotator              lodash.camelcase             respjs
                                          async                       file-type                        lodash.defaults              retry
                                          asynckit                    file-uri-to-path                 lodash.defaultto             revalidator
                                          async-limiter               fill-range                       lodash.filter                rimraf
                                          async-retry                 finalhandler                     lodash.flatten               @root
                                          aws4                        find-replace                     lodash.foreach               rpi-gpio
                                          aws-sdk                     find-up                          lodash.groupby               rrule
                                          aws-sign2                   follow-redirects                 lodash.includes              rsa-compat
                                          axios                       forever-agent                    lodash.isboolean             safe-buffer
                                          babel-runtime               form-data                        lodash.isequal               safer-buffer
                                          backo2                      forwarded                        lodash.isinteger             safe-replace
                                          balanced-match              @frankjoke                       lodash.isnumber              sax
                                          base64-arraybuffer          fresh                            lodash.isplainobject         semver
                                          base64id                    fritzapi                         lodash.isstring              send
                                          base64-js                   from                             lodash.map                   @sentry
                                          bcrypt-pbkdf                fs-constants                     lodash.merge                 @serialport
                                          better-assert               fs-extra                         lodash.once                  serialport
                                          bignumber.js                fs-minipass                      lodash.pick                  serve-static
                                          binary-extensions           fs.realpath                      lodash.reduce                set-blocking
                                          bindings                    ftp                              lodash.reject                set-immediate-shim
                                          bl                          ftp-response-parser              lodash.some                  setprototypeof
                                          blob                        function-bind                    logform                      signal-exit
                                          bluebird                    gauge                            loglevel                     simple-concat
                                          body-parser                 gaxios                           long                         simple-get
                                          bonjour-hap                 gcp-metadata                     long-timeout                 simple-swizzle
                                          boolbase                    get-caller-file                  lru-cache                    sntp
                                          boom                        getpass                          lru_map                      socket.io
                                          brace-expansion             github-from-package              luxon                        socket.io-adapter
                                          braces                      glob                             macaddress                   socket.io-client
                                          buffer                      glob-parent                      map-stream                   socket.io-parser
                                          buffer-alloc                glossy                           mdns                         socksv5
                                          buffer-alloc-unsafe         googleapis                       mdns-discovery               soef
                                          buffer-equal-constant-time  googleapis-common                mdns-server                  sonos-discovery
                                          buffer-fill                 google-auth-library              media-typer                  sorted-array-functions
                                          buffer-from                 google-p12-pem                   merge-descriptors            source-map
                                          buffer-indexof              graceful-fs                      methods                      source-map-support
                                          buffer-shims                greenlock                        micro                        spdx-correct
                                          busboy                      greenlock-store-fs               mime                         spdx-exceptions
                                          bytes                       gtoken                           mime-db                      spdx-expression-parse
                                          callsite                    hap-nodejs                       mime-types                   spdx-license-ids
                                          camelcase                   har-schema                       mimic-response               split
                                          caseless                    har-validator                    minimatch                    sprintf-js
                                          castv2                      has                              minimist                     sshpk
                                          castv2-client               has-binary2                      minipass                     stack-trace
                                          cert-info                   has-cors                         minizlib                     standard-as-callback
                                          chalk                       has-flag                         mkdirp                       statuses
                                          cheerio                     has-symbols                      mkdirp-classic               stealthy-require
                                          chokidar                    has-unicode                      moment                       stream-combiner
                                          chownr                      hawk                             moment-timezone              streamsearch
                                          cli                         hoek                             ms                           string_decoder
                                          cliff                       hosted-git-info                  multicast-dns                string.prototype.trimend
                                          cliui                       html-entities                    multicast-dns-service-types  string.prototype.trimleft
                                          cloneextend                 htmlparser2                      mute-stream                  string.prototype.trimright
                                          cluster-key-slot            http-errors                      nan                          string.prototype.trimstart
                                          co                          http-signature                   napi-build-utils             stringstream
                                          code-point-at               https-proxy-agent                ncp                          string-width
                                          coffee-compiler             i                                negotiator                   strip-ansi
                                          coffee-script               iconv-lite                       netmask                      strip-bom
                                          color                       ieee754                          node-abi                     strip-json-comments
                                          color-convert               immediate                        node-coap-client             suncalc
                                          color-name                  indexof                          node-dtls-client             suncalc2
                                          colornames                  inflight                         node.extend                  supports-color
                                          colors                      influx                           node-fetch                   sync-exec
                                          colorspace                  inherits                         node-forge                   systeminformation
                                          color-string                ini                              node-ical                    table-layout
                                          combined-stream             invert-kv                        node-mndp                    tar
                                          commander                   @iobroker                        node-persist                 tar-fs
                                          command-line-args           iobroker.admin                   node-schedule                targz
                                          command-line-usage          iobroker.backitup                node-ssdp                    tar-stream
                                          component-bind              iobroker.bmw                     node-telegram-bot-api        text-hex
                                          component-emitter           iobroker.cloud                   node-tradfri-client          through
                                          component-inherit           iobroker.coronavirus-statistics  node-wol                     thunky
                                          concat-map                  iobroker.daswetter               noop-logger                  to-array
                                          connect-flash               iobroker.discovergy              normalize-package-data       to-buffer
                                          console-control-strings     iobroker.discovery               normalize-path               toidentifier
                                          content-disposition         iobroker.dwd                     npmlog                       to-regex-range
                                          content-type                iobroker.feiertage               nth-check                    tough-cookie
                                          cookie                      iobroker.find-my-iphone          number-is-nan                tough-cookie-filestore
                                          cookie-parser               iobroker.fritzdect               oauth-sign                   tplink-smarthome-api
                                          cookie-signature            iobroker.history                 object-assign                tplink-smarthome-crypto
                                          core-js                     iobroker.hs100                   object.assign                triple-beam
                                          core-util-is                iobroker.ical                    object-component             tr-O64
                                          country-list-js             iobroker.icons-material-png      object-hash                  tslib
                                          cron-parser                 iobroker.influxdb                object-inspect               tunnel-agent
                                          cryptiles                   iobroker.info                    object-is                    tweetnacl
                                          css-select                  iobroker.javascript              object-keys                  type-is
                                          css-what                    iobroker.js-controller           once                         @types
                                          cycle                       iobroker.luftdaten               one-time                     typescript
                                          daemonize2                  iobroker.mobile                  on-finished                  typical
                                          dashdash                    iobroker.objects-redis           on-headers                   uid-safe
                                          debug                       iobroker.rpi2                    os-locale                    universalify
                                          decache                     iobroker.samsung_tizen           os-tmpdir                    unix-dgram
                                          decamelize                  iobroker.sayit                   pako                         unorm
                                          decimal.js                  iobroker.scenes                  parse-json                   unpipe
                                          decompress-response         iobroker.shuttercontrol          parse-listing                uri-js
                                          deep-clone                  iobroker.simple-api              parseqs                      url
                                          deep-equal                  iobroker.socketio                parseuri                     url-template
                                          deep-extend                 iobroker.sonos                   parseurl                     ursa-optional
                                          define-properties           iobroker.spotify-premium         passport                     util
                                          delayed-stream              iobroker.telegram                passport-local               util-deprecate
                                          delegates                   iobroker.text2command            passport.socketio            utile
                                          denque                      iobroker.tr-064                  passport-strategy            utils-merge
                                          depd                        iobroker.tradfri                 path-exists                  uuid
                                          destroy                     iobroker.vis                     path-is-absolute             validate-npm-package-license
                                          detect-libc                 iobroker.web                     path-parse                   vary
                                          dev-null                    iobroker.yahka                   path-to-regexp               verror
                                          dgram                       ioredis                          path-type                    vinyl-sourcemaps-apply
                                          diagnostics                 ip                               pause                        virtual-tsc
                                          dicer                       ipaddr.js                        pause-stream                 vm2
                                          diskusage                   is                               performance-now              wake_on_lan
                                          dns-equal                   is-arguments                     picomatch                    weak-daemon
                                          dns-packet                  isarray                          pidusage                     which-module
                                          dns-txt                     is-arrayish                      pify                         which-pm-runs
                                          domelementtype              is-binary-path                   pinkie                       wide-align
                                          domhandler                  is-callable                      pinkie-promise               winston
                                          dom-serializer              is-date-object                   pkginfo                      winston-daily-rotate-file
                                          domutils                    is-extglob                       p-limit                      winston-syslog
                                          dropbox-v2-api              is-fullwidth-code-point          p-locate                     winston-transport
                                          duplexer                    is-generator-function            prebuild-install             wordwrapjs
                                          ecc-jsbn                    is-glob                          process-nextick-args         wrap-ansi
                                          ecdsa-sig-formatter         is-nan                           promise                      wrappy
                                          eckles                      is-number                        prompt                       ws
                                          ee-first                    is-port-reachable                @protobufjs                  xml2js
                                          emoji-regex                 is-regex                         protobufjs                   xml2json-light
                                          enabled                     is-stream                        proxy-addr                   xmlbuilder
                                          encodeurl                   isstream                         psl                          xml-flow
                                          end-of-stream               is-symbol                        p-try                        xmlhttprequest-ssl
                                          engine.io                   is-typedarray                    pump                         xregexp
                                          engine.io-client            is-utf8                          punycode                     xtend
                                          engine.io-parser            jmespath                         pyconf                       y18n
                                          entities                    jsbn                             qs                           yallist
                                          env-variable                jsftp                            querystring                  yargs
                                          epoll                       jsonata                          random-bytes                 yargs-parser
                                          error-ex                    json-bigint                      range-parser                 yeast
