  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 715.0k Aufrufe 89 Beobachtet
  • MaufloM
    MaufloM
    Mauflo
    #806
    Habe gerade den Radar2 Adapter upgedatet und ein paar beunruhigende Infos während der Installationsphase erhalten. Muss ich da etwas beachten? Denn nach der Installation (die letztendlich funktioniert hat) läuft der Adapter ohne Probleme:
    $ ./iobroker upgrade radar2
    Update radar2 from @1.0.9 to @1.2.5
    NPM version: 6.14.4
    npm install iobroker.radar2@1.2.5 --loglevel error --prefix "/opt/iobroker" (System call)
    prebuild-install
    info begin
     Prebuild-install version 5.3.3
    prebuild-install
     info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/e00ec3-usb-v1.6.3-node-v64-linux-arm.tar.gz
    prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-linux-arm.tar.gz
    prebuild-install
     http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-linux-arm.tar.gz
    prebuild-install
     WARN install No prebuilt binaries found (target=10.20.1 runtime=node arch=arm libc= platform=linux)
    In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/node_usb.cc:1:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2232:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from ../src/node_usb.h:14,                 from ../src/node_usb.cc:1:../src/node_usb.cc: At global scope:/home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/node_usb.cc:95:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(usb_bindings, Initialize) ^~~~~~~~~~~
    ../src/node_usb.cc: In function ‘void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)’:../src/node_usb.cc:151:58: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]  Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);                                                          ^In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/node_usb.cc:1:../node_modules/nan/nan.h:1001:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    In file included from ../src/node_usb.h:12,                 from ../src/node_usb.cc:1:/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../node_modules/nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/device.cc:1:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2232:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/device.cc: In member function ‘void Req::submit(Device*, v8::Local<v8::Function>, uv_work_cb, uv_work_cb)’:../src/device.cc:220:70: warning: cast between incompatible function types from ‘uv_work_cb’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), &req, backend, (uv_after_work_cb) after);        ^~~~~
    ../src/device.cc: In static member function ‘static void Req::default_after(uv_work_t*)’:../src/device.cc:237:64: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]    Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);        ^In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/device.cc:1:../node_modules/nan/nan.h:959:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/device.cc:237:64: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]    Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);        ^In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/device.cc:1:../node_modules/nan/nan.h:959:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    In file included from ../src/node_usb.h:12,                 from ../src/device.cc:1:/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/transfer.cc:1:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2232:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/transfer.cc: In function ‘void handleCompletion(Transfer*)’:../src/transfer.cc:126:72: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);        ^In file included from ../src/helpers.h:3,                 from ../src/node_usb.h:21,                 from ../src/transfer.cc:1:../node_modules/nan/nan.h:959:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    In file included from ../src/node_usb.h:12,                 from ../src/transfer.cc:1:/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from /home/iobroker/.cache/node-gyp/10.20.1/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:578:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
    In file included from /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:63,                 from /home/iobroker/.cache/node-gyp/10.20.1/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../../../nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    upload [13] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
    Update "system.adapter.radar2.0"
    upload [12] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
    upload [11] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
    upload [10] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
    upload [9] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/de/translations.json i18n/de/translations.json application/json
    Adapter "radar2" updated
    process exited with code 0
    Danke für Rückmeldungen!
    RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
    harrymH Thomas BraunT 2 Antworten Letzte Antwort
    • MaufloM Mauflo
      NPM version: 6.14.4
      prebuild-install
      info begin
      prebuild-install
      prebuild-install
      prebuild-install
      harrymH
      harrymH
      harrym
      #807
      `Adapter "radar2" updated
      process exited with code 0`
      was willste mehr?
      ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
      • MaufloM Mauflo
        NPM version: 6.14.4
        prebuild-install
        info begin
        prebuild-install
        prebuild-install
        prebuild-install
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        #808
        @Mauflo Weiß gar nicht was du da beunruhigend findest. Sind ganz normale Meldungen, wenn ein Modul baut.
        Da keine vorkompilierten binairies für deine node-Version gefunden wurden muss halt selber kompiliert werden:
        MaufloM 1 Antwort Letzte Antwort
        • J Jan1
          @dtp
          Ich bin kein Freund von "ich nehme was fertiges, weil ich kein Plan habe", denn so lernst einfach nix dazu.
          Schau Dir mal meine letzten eigenen Threads an, da habe ich meine Fragen meist selber beantwortet weil ich mittlerweile einfach durch viel probieren und mal Google fragen doch schon ne Menge weiß,um mir selber helfen zu können ;-)
          D
          D
          dtp
          #809
          @Jan1 sagte in js-controller 3.0 jetzt im Latest!:
          Kann man so oder so sehen. Oder programmierst du deine Betriebssysteme und Hardwaretreiber auch alle selbst?
          Es gibt sehr gute Docker-Container-Abbilder für die Synology DiskStations. Eins davon ist das ioBroker-Abbild von buanet. Natürlich könnte ich dort jetzt auf node.js v12.x upgraden, aber wozu, wenn im Moment alles rund mit meinen Adaptern läuft?
          Ich habe schon genügend Baustellen am Wickel. Neben der HomeMatic kam nun noch ein 3D-Drucker hinzu. Und da muss ich mich aktuell erst mal in Fusion 360 einarbeiten. Ach ja, und einen Beruf habe ich neben der Familie auch noch. Dank Corona kann ich meinen Job zwar zur Zeit zu 90 % im Home Office ausüben, aber die Kinder (9 und 11) wollen tagsüber von meiner Frau, die ebenfalls berufstätig ist, und mir auch noch schulisch betreut werden.
          Nee, nee, da lass ich node.js lieber so, wie es ist. 😇
          • D dtp
            J
            J
            Jan1
            #810
            @dtp
            Da vergleichst aber schön Äpfel mit Birnen.
            Ich hab auch nicht geschrieben, dass man das nicht tun sollte, sondern, dass ich kein Freund davon bin ;-)
            Das Problem ist eben, dass Du nicht 100% weißt, was alles drin steckt und das kann zum Problem werden. Ist auch der Grund warum ich keine fertigen Scripte von hier verwende. Ich kann kein Java Script und wenn dann eins nicht mehr läuft, bin ich aufgeschmissen. Da bastle ich mir was mit Blockly und weiß was drin ist und versteh die Logik, da auf meinem Mist gewachsen. Das als kleines Beispiel was ich damit ausdrücken möchte, mehr nicht.
            • apollon77A apollon77
              @frankjoke lass am beste im Telegram dazu schreiben
              liv-in-skyL
              liv-in-skyL
              #811
              @apollon77
              hi- ist das thema hier relevant für den js-3 controller https://forum.iobroker.net/topic/32962/ordner-in-iobroker-explodiert-backup-objects
              es werden die files im ordner .../iobroker-data/backup-objects/.. nicht gelöscht - das problem war schon vor js-cont.3
              • liv-in-skyL liv-in-sky
                @apollon77
                apollon77A
                apollon77A
                #812
                @liv-in-sky Wo ist das GitHub Issue? :-)
                  MaufloM
                  MaufloM
                  Mauflo
                  #813
                  @Thomas-Braun danke, ich dachte es mir, war aber nicht sicher!
                    liv-in-skyL
                    liv-in-skyL
                    #814
                    @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                    hier: https://github.com/ioBroker/ioBroker.js-controller/issues/866 :-)
                    • D
                      D
                      dtp
                      #815
                      @Jan1
                      Ich habe aber auch nicht geschrieben, dass du behauptet hättest, dass man das nicht tun soll. ;)
                      Blockly ist aber doch jetzt das, was du eigentlich nicht nutzen willst. Schließlich handelt es sich um ein GUI für Javascript. Und ich habe schon von einigen gelesen, dass sie den von Blockly erzeugten Scriptcode erst mal optimiert haben, weil er nicht gerade effizient geschrieben ist.
                      Ich z.B. schreibe da lieber direkt in Javascript, statt Blockly zu nutzen, weil ich die einzelnen Schritte so besser kontrollieren und verstehen kann. Und ich bin jetzt auch beileibe kein Javascript-Experte. ;)
                      • D dtp
                        @Jan1
                        J
                        J
                        Jan1
                        #816
                        @dtp
                        Ich kann kein Java Script und dass Blockly nicht optimales Java Script ist, ist auchklar und war nur ein Beispiel. Du liebst anscheinend den Vergleich Äpfel mit Birnen ;-)
                        • J Jan1
                          @dtp
                          D
                          D
                          dtp
                          schrieb am zuletzt editiert von dtp
                          #817
                          @Jan1
                          Öh, ich habe doch nur deinen eigenen Vergleich aufgegriffen. Also wer hat dann Äpfel mit Birnen verglichen?
                          Und es ging um deine eigene Aussage, dass du gerne verstehen möchtest, was passiert. Ergo kann man diesbezüglich durchaus ein Docker Image mit Blockly vergleichen, da beide auf Software-Level basieren, die unter dem User-Level liegen.
                          Zudem haben Docker-Images den großen Vorteil, dass man sie ohne Gefahr für die eigentlichen Daten problemlos wieder entfernen kann, wenn sie Probleme bereiten.
                          • D dtp
                            @Jan1
                            J
                            J
                            Jan1
                            #818
                            @dtp
                            Das war auf die Aussage zu selber programmieren des OS bezogen und alles selber machen, da das zu hoch gegriffen ist. Und nun wird mein Beispiel zum Verständnis wieder etwas aus dem Zusammenhang gezogen.
                            Ist aber alles nicht negativ gemeint, falls Du das falsch verstanden hattest.
                            • M
                              M
                              mcchickents
                              #819
                              Guten Tag,
                              ich habe das Problem das es bei mir kein Tr64 in der Version 4.0.0 gibt. Die Liste habe ich auch schon aktualisiert. Anbei ein Bild. Vieleicht kann mir ja jemand helfen.tr64.JPG
                              Noch eine weitere Frage wie kann man hier im Forum in einem Thread nach bestimmten Wörtern Suchen?
                              Gruß Julian
                              J wendy2702W 2 Antworten Letzte Antwort
                              • M mcchickents
                                Guten Tag,
                                Gruß Julian
                                J
                                J
                                Jan1
                                #820
                                @mcchickents
                                Du bist nicht im latest REPO und im default ist das bestimmt der letzte Stand
                                • M
                                  M
                                  mcchickents
                                  #821
                                  @Jan1 said in js-controller 3.0 jetzt im Latest!:
                                  REPO
                                  Danke für die Schnelle antwort. Bei mir ist das hinterlegt.
                                  • M mcchickents
                                    REPO
                                    J
                                    J
                                    Jan1
                                    #822
                                    @mcchickents
                                    Das ist auch der falsche Reiter, hier steht nur was man eins vorher auswählen kann ;-)
                                    • M
                                      M
                                      mcchickents
                                      #823
                                      Danke 👍
                                      • M mcchickents
                                        Guten Tag,
                                        Gruß Julian
                                        wendy2702W
                                        wendy2702W
                                        #824
                                        @mcchickents sagte in js-controller 3.0 jetzt im Latest!:
                                        Mit
                                        STRG + F
                                        • wendy2702W wendy2702
                                          Mit
                                          STRG + F
                                          M
                                          M
                                          mcchickents
                                          #825
                                          @wendy2702
                                          Strg+F durchsucht aber nur in den Antworten die schon offen sind. was in dem thread mit 824 antworten nicht so gut funktioniert
                                          33.2k
                                          84.4k
