  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 605.7k Aufrufe 89 Beobachtet
  • apollon77A apollon77
    @Thisoft ip ist korrekt? Port auch? Es sieht so aus als ob die dB Verbindung geschlossen wird. Sagt das logfile der Datenbank irgendwas?
    Downgrade gern mal auf sql 1.9.x und schau was da passiert. Würde mich aber wundern wenn es da tut.
    ThisoftT Offline
    ThisoftT Offline
    Thisoft
    #735
    @apollon77 Auch wenn Du's nicht erwartest, aber die Version 1.9.5 funktioniert. Was mir dabei allerdings auffällt, er führt beim Starten automatisch ein Rebuild aus:
    2020-05-03 11:34:26.099 - info: host.ioBroker-Ubuntu Adapter system.adapter.sql.0 needs rebuild and will be restarted afterwards.
    2020-05-03 11:34:26.099 - info: host.ioBroker-Ubuntu system.adapter.sql.0 will be rebuilt
    2020-05-03 11:34:26.099 - warn: host.ioBroker-Ubuntu adapter "sql" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2020-05-03 11:34:26.100 - info: host.ioBroker-Ubuntu iobroker rebuild sql --install
    2020-05-03 11:34:26.240 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.sql"
    2020-05-03 11:34:40.150 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: ../deps/libmagic/src/fsmagic.c: In function ‘file_fsmagic’:../deps/libmagic/src/fsmagic.c:223:13: warning: In the GNU C Library, "major" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "major", include directly. If you did not intend to use a system-defined macro "major", you should undefine it after including . COMMA, (long)major(sb->st_rdev), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:224:13: warning: In the GNU C Library, "minor" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "minor", include directly. If you did not intend to use a system-defined macro "minor", you should undefine it after including . (long)minor(sb->st_rdev)) == -1) ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:258:13: warning: In the GNU C Library, "major" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "major", include directly. If you did not intend to use a system-defined macro "major", you should undefine it after including . COMMA, (long)major(sb->st_rdev), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../deps/libmagic/src/fsmagic.c:259:13: warning: In the GNU C Library, "minor" is defined by . For historical compatibility, it is currently defined by as well, but we plan to remove this soon. To use "minor", include directly. If you did not intend to use a system-defined macro "minor", you should undefine it after including . (long)minor(sb->st_rdev)) == -1) ^~~~~~~~~~~~~~~~~~~~~~~~~~~
    2020-05-03 11:34:45.056 - info: host.ioBroker-Ubuntu iobroker npm-rebuild:
    2020-05-03 11:34:45.057 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: Rebuild sql done
    2020-05-03 11:34:46.060 - info: host.ioBroker-Ubuntu iobroker npm-rebuild: exit 0
    2020-05-03 11:34:46.082 - info: host.ioBroker-Ubuntu instance system.adapter.sql.0 started with pid 7239
    Wenn ich wieder auf die 1.12 gehe macht er das nicht - und es funktioniert eben auch nicht...
    Übrigens, ich hab einen MS-SQLServer im Einsatz. Ist der vielleicht zu selten um genug getestet zu sein ;-) ?
    22 HM-Geräte; PivCCU2 auf RasPi
    ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
      @Marty56 hm ... klingt nach einem issue für Vis wo sich GitHub freut.
      Marty56
      #736
      @apollon77 Würde ich natürlich machen, aber ich stehe mit dem VIS auf Kriegsfuß und blicke bis heute bei dem Tool nicht durch. Ich habe über die Zeit vermutlich irgendwo in den Verzeichnissen herumgefummelt und ich würde nicht ausschließen, dass ich da Mist gebaut habe und dass die Warnings drauf zurückzuführen sind.
      HW:NUC (16 GB Ram)
      OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
        @Peoples Jupp. So soll es quasi sein.
        liv-in-skyL Offline
        liv-in-skyL Offline
        #737
        @apollon77
        vis alleine ist das nicht
        habe auch von sayit meldungen - leider weiß ich nicht mehr, wo diese dateien herkommen (ob das standard dateien sind oder ob ich kopiert habe) - sayit habe ich schon ewig nicht mehr angesehen - die dateien liegen unter
        readFile	2020-05-03 16:03:35.104	warn	will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
        sayit.0	2020-05-03 16:03:35.103	warn	(423) readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
        readFile	2020-05-03 16:03:35.100	warn	will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
        sayit.0	2020-05-03 16:03:35.064	warn	(423) readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
        muss bei jedem adapter ein git issue angelegt werden ?
        crunchipC apollon77A 2 Antworten Letzte Antwort
        • liv-in-skyL liv-in-sky
          @apollon77
          crunchipC Offline
          crunchipC Offline
          #738
          @liv-in-sky hehe, ich schon wieder
          scheinbar standard Dateien, die habe ich auch, habe sie auch bereits gelöscht und werden wieder angelegt
            liv-in-skyL Offline
            liv-in-skyL Offline
            #739
            @crunchip bekommst du die warnungen auch im log ?
              crunchipC Offline
              crunchipC Offline
              #740
              @liv-in-sky ja
                @liv-in-sky ja
                liv-in-skyL Offline
                liv-in-skyL Offline
                #741
                @crunchip diese files finde ich wenigstens - die anderen von weiter oben finde ich nicht mal - da scheint tatsächlich irgendwo in der vis noch etwas altes zu stehen ???
                  crunchipC Offline
                  crunchipC Offline
                  #742
                  @liv-in-sky welche meinst du?
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #743
                    @crunchip
                    https://forum.iobroker.net/post/424007
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      #744
                      @liv-in-sky hat ich doch direkt ein post darunter geschrieben,
                      ah...editiert, ...
                      dazu hab ich leider keine Idee
                      • E Offline
                        e-i-k-e
                        schrieb am zuletzt editiert von e-i-k-e
                        #745
                        Moin,
                        js.controller läuft auf 3.0.20.
                        Habe soeben ein update von node.js 10 auf 12 gewagt.
                        Bis auf einen Adapter läuft alles.
                        Der SQL-Adapter (Version 1.12.3) steht auf Gelb.
                        Auszug aus dem log.
                        sql.0	2020-05-03 14:39:38.818	error	(12037) TypeError: Cannot read property 'close' of undefined
                        sql.0	2020-05-03 16:39:38.818	error	(12037) TypeError: Cannot read property 'close' of undefined
                        sql.0	2020-05-03 16:37:38.810	error	(12037) TypeError: Cannot read property 'close' of undefined
                        sql.0	2020-05-03 16:37:38.809	error	(12037) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                        sql.0	2020-05-03 16:37:08.808	error	(12037) TypeError: Cannot read property 'close' of undefined
                        sql.0	2020-05-03 16:37:08.807	error	(12037) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                        Auch nach einem Downgrade auf 1.9.5 läuft der Adapter nicht.
                        sql.0	2020-05-03 15:13:43.535	error	(5376) TypeError: Cannot read property 'borrow' of undefined
                        sql.0	2020-05-03 15:13:43.534	error	(5376) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                        sql.0	2020-05-03 15:13:43.498	info	(5376) starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.sql, node: v12.16.3, js-controller: 3.0.20
                        Gibt es dazu Lösungen?
                        Edit: SQL wurde soeben grün. Habe iobroker rebuild sql --install ausgeführt. iobroker rebuild sql brachte keine Besserung.
                        Nachdem ich wieder auf die aktuelle Version 1.12.3 gesprungen bin, war der Adapter wieder gelb. Ein erneutes iobroker rebuild sql --install konnte den Fehler beheben.
                        • ThisoftT Thisoft
                          apollon77A Online
                          apollon77A Online
                          #746
                          @Thisoft vor allem der Mssql war in 1.11 kaputt und haben wir mit einigen Usern im Forum getestet. Daher sollte an sich tun.
                          Ich schaue nochmal heute Abend. Bitte mach nochmal die 1.12 und Starterin debug und zeig mal das log davon bitte.
                          ThisoftT 1 Antwort Letzte Antwort
                            @apollon77
                            apollon77A Online
                            apollon77A Online
                            #747
                            @liv-in-sky sayit schon bekannt.
                              apollon77A Online
                              apollon77A Online
                              #748
                              @liv-in-sky jetzt macht euch keinen Kopf. Die Meldungen fliegen wieder raus in der finalen Version
                              • E e-i-k-e
                                Moin,
                                Auszug aus dem log.
                                apollon77A Online
                                apollon77A Online
                                #749
                                @e-i-k-e ja klar. Sind verschiedene Versionen von SQLite drin und das will gebaut werden. Ich baue mal noch was ein das das rebuild automatisch passiert.
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #750
                                  @apollon77 danke
                                  • E Offline
                                    e-i-k-e
                                    #751
                                    Slave: (Raspberry/Rasbian) Update von node.js 10 auf 12, js.controller 2.0.30
                                    RPI-Adapter wird zwar Grün, die GPIO lassen sich allerdings nicht steuern.
                                    LOG:
                                    rpi2.3	2020-05-03 17:48:33.112	warn	(11922) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                    rpi2.3	2020-05-03 17:48:33.050	info	(11922) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                    rpi2.3	2020-05-03 17:48:27.832	info	(11412) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    rpi2.3	2020-05-03 17:48:27.830	info	(11412) terminating
                                    rpi2.3	2020-05-03 17:48:27.828	info	(11412) Got terminate signal TERMINATE_YOURSELF
                                    rpi2.3	2020-05-03 17:47:53.595	error	(11412) GPIO is not initialized!
                                    rpi2.3	2020-05-03 17:47:51.593	error	(11412) GPIO is not initialized!
                                    rpi2.3	2020-05-03 17:42:47.016	error	(11412) GPIO is not initialized!
                                    rpi2.3	2020-05-03 17:42:19.480	warn	(11412) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                    rpi2.3	2020-05-03 17:42:19.416	info	(11412) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                    rpi2.3	2020-05-03 17:42:14.061	info	(10753) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    rpi2.3	2020-05-03 17:42:14.059	info	(10753) terminating
                                    rpi2.3	2020-05-03 17:42:14.056	info	(10753) Got terminate signal TERMINATE_YOURSELF
                                    rpi2.3	2020-05-03 17:38:00.253	error	(10753) GPIO is not initialized!
                                    rpi2.3	2020-05-03 17:35:34.761	warn	(10753) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                    rpi2.3	2020-05-03 17:35:34.713	info	(10753) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                    rpi2.3	2020-05-03 17:31:14.638	info	(17396) Got terminate signal TERMINATE_YOURSELF
                                    rpi2.3	2020-05-03 17:31:14.619	info	(17396) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    rpi2.3	2020-05-03 17:02:08.103	error	(17396) read ECONNRESET
                                    Ein Down-/Upgrade des Adapters brachte keine Änderung.
                                    Erst nachdem in den Adapter händisch gelöscht und neu Installiert habe, werden die GPIO angesteuert.
                                    LOG:
                                    rpi2.3	2020-05-03 18:14:07.761	warn	(14278) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                    rpi2.3	2020-05-03 18:14:07.706	info	(14278) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                    rpi2.3	2020-05-03 18:14:02.762	info	(14154) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    rpi2.3	2020-05-03 18:14:02.760	info	(14154) terminating
                                    rpi2.3	2020-05-03 18:14:02.756	info	(14154) Got terminate signal TERMINATE_YOURSELF
                                    rpi2.3	2020-05-03 18:13:08.638	info	(14154) GPIO ports are not configured
                                    rpi2.3	2020-05-03 18:13:08.575	error	(14154) No Value found for cpu_frequency
                                    rpi2.3	2020-05-03 18:13:04.520	warn	(14154) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                                    rpi2.3	2020-05-03 18:13:04.443	info	(14154) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.16.3, js-controller: 3.0.20
                                    • J Offline
                                      jhg
                                      #752
                                      ich habe nach dem Update auf js. 3.0.20 das Problem, dass mein Serialport nicht mehr funktioniert.
                                      Habe von dem Update auf 3.0.20 noch node auf 12.16.3 aktualisiert.
                                      Folgender Fehlermeldung:
                                      prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
                                      gyp ERR! clean error
                                      gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
                                      gyp ERR! System Linux 4.19.97-v7+
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                                      gyp ERR! node -v v12.16.3
                                      gyp ERR! node-gyp -v v5.1.0
                                      gyp ERR! not ok
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! serialport@6.2.2 install: prebuild-install || node-gyp rebuild
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the serialport@6.2.2 install script.
                                      Jemand einen Tipp, wie ich das beheben kann.
                                      • J jhg
                                        gyp ERR! not ok
                                        npm ERR! errno 1
                                        npm ERR!
                                        #753
                                        @jhg said in js-controller 3.0 jetzt im Latest!:
                                        permission denied
                                        Da stimmen die Rechte nicht.
                                        iobroker fix
                                        mal ausgeführt? Danach evtl. mal 'discovery' rebuilden.
                                        • J Offline
                                          jhg
                                          #754
                                          Ja, Fix habe ich laufenlassen.
                                          Keine Änderung
                                          Wie starte ich ein discovery rebuild?
                                          Evtl. noch als Ergänzung:
                                          Das Problem ist auf dem slave, denn dort hängt der Volkszähler am Raspi.
