js-controller 3.0/3.1 jetzt im Latest!
Ist also nicht ungewöhnlich oder wie ist das gemeint?
So viel tritt das bei mir nicht auf.
Frage von Noob:
nach js-controller update funkt backitup nicht mehr.
kann mir bitte jemand sagen was hier schief gelaufen ist?Danke im Voraus.
host.raspberrypi 2020-05-01 12:56:19.026 info Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json" host.raspberrypi 2020-05-01 12:56:07.650 info Restart adapter system.adapter.backitup.0 because enabled host.raspberrypi 2020-05-01 12:56:07.649 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) host.raspberrypi 2020-05-01 12:56:07.649 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:840:9 host.raspberrypi 2020-05-01 12:56:07.648 error Caught by controller[1]: at detectLatestBackupFile (/opt/iobroker/node_modules/iobroker.backitup/main.js:699:33) host.raspberrypi 2020-05-01 12:56:07.648 error Caught by controller[1]: at Array.map (<anonymous>) host.raspberrypi 2020-05-01 12:56:07.648 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:699:48 host.raspberrypi 2020-05-01 12:56:07.648 error Caught by controller[1]: at new Promise (<anonymous>) host.raspberrypi 2020-05-01 12:56:07.647 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:700:13 host.raspberrypi 2020-05-01 12:56:07.647 error Caught by controller[1]: at module.exports (/opt/iobroker/node_modules/iobroker.backitup/lib/list.js:72:36) host.raspberrypi 2020-05-01 12:56:07.647 error Caught by controller[1]: at Object.list (/opt/iobroker/node_modules/iobroker.backitup/lib/list/googledrive.js:6:24) host.raspberrypi 2020-05-01 12:56:07.647 error Caught by controller[1]: at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31) host.raspberrypi 2020-05-01 12:56:07.646 error Caught by controller[1]: at JSON.parse (<anonymous>) host.raspberrypi 2020-05-01 12:56:07.646 error Caught by controller[1]: SyntaxError: Unexpected token ' in JSON at position 1 host.raspberrypi 2020-05-01 12:56:07.645 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected backitup.0 2020-05-01 12:56:07.108 info (20766) Terminated (NO_ERROR): Without reason backitup.0 2020-05-01 12:56:07.106 info (20766) terminating backitup.0 2020-05-01 12:56:07.057 info (20766) cleaned everything up... backitup.0 2020-05-01 12:56:07.055 error (20766) SyntaxError: Unexpected token ' in JSON at position 1 at JSON.parse (<anonymous>) at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31) at O backitup.0 2020-05-01 12:56:07.049 error (20766) uncaught exception: Unexpected token ' in JSON at position 1 backitup.0 2020-05-01 12:56:06.962 info (20766) [iobroker] backup was activated at 02:00 every 3 day(s) backitup.0 2020-05-01 12:56:06.903 info (20766) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.16.3, js-controller: 3.0.20 host.raspberrypi 2020-05-01 12:56:02.989 info instance system.adapter.backitup.0 started with pid 20766pi@raspberrypi:~ $ node -v v12.16.3 pi@raspberrypi:~ $ iobroker status iobroker is running on this host. At least one iobroker host is running. Objects type: file States type: file pi@raspberrypi:~ $ npm -v 6.14.4RAM 3.81 GB System Betriebszeit 14 T. 01:25:12 Festplatte Größe 28.98 GB Festplatte frei 22.98 GB Anzahl der Adapter 346 Betriebszeit 13:25:16 Aktive Instanzen 21raspberrypi Typ: js-controller Titel: JS controller OS: linux Verfügbar: 3.0.20 Installiert: 3.0.20 Ereignisse: ⇥26 / ↦15 -
Habe die Version 3.0.20 installiert. Soweit keine Probleme. Gut Arbeit.
Im Log File habe jetzt ein paar Warnings, z. B.
readFile 2020-05-01 14:05:43.635 warn will not read this file (devices/cpu.png) in future versions: icons-open-icon-library-png is not an object of type "meta"
Es handelt sich da wohl um eigene Icons, die ich in VIS verwende.
Bei dem Update vom VIS Module gab es auch mal eine Memory Warnung, aber nach Abschuss der Installation war wieder ausreichend Memory frei.
Bei Zigbee Adapter gab es die Warnung
zigbee.0 2020-05-01 14:05:07.228 warn (COMPACT) no connection to objects DB
Er scheint aber zu laufen.
Ich habe auch versucht auf die neueste Version (4.5.1) der Script Engine upzudaten, aber die Installation scheint nicht zu funktionieren und es wird immer noch 4.4.3 angezeigt.
2020-05-01 14:18:19.059 - info: host.ioBroker-RasPi4 iobroker Update javascript from @4.4.3 to @4.5.1 2020-05-01 14:18:21.640 - info: host.ioBroker-RasPi4 iobroker NPM version: 6.11.3 2020-05-01 14:18:21.646 - info: host.ioBroker-RasPi4 iobroker npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call) 2020-05-01 14:19:25.371 - info: host.ioBroker-RasPi4 iobroker npm 2020-05-01 14:19:25.377 - info: host.ioBroker-RasPi4 iobroker ERR! code ENOTSUPnpm ERR! notsup 2020-05-01 14:19:25.383 - info: host.ioBroker-RasPi4 iobroker Unsupported engine for puppeteer@3.0.2: wanted: {"node":">=10.18.1"} (current: {"node":"10.17.0","npm":"6.11.3"})npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Required: {"node":">=10.18.1"}npm ERR! notsup Actual: {"npm":"6.11.3","node":"10.17.0"} 2020-05-01 14:19:25.473 - info: host.ioBroker-RasPi4 iobroker 2020-05-01 14:19:25.478 - info: host.ioBroker-RasPi4 iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-01T12_19_25_434Z-debug.log 2020-05-01 14:19:25.985 - info: host.ioBroker-RasPi4 iobroker Update "system.adapter.javascript.0" 2020-05-01 14:19:26.178 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 (force=false, process=true) 2020-05-01 14:19:26.197 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 send kill signal 2020-05-01 14:19:26.197 - info: javascript.0 (3513) Got terminate signal TERMINATE_YOURSELF 2020-05-01 14:19:26.208 - info: javascript.0 (3513) Stop script script.js.common.Heizung 2020-05-01 14:19:26.215 - info: javascript.0 (3513) Stop script script.js.common.Jalousien 2020-05-01 14:19:26.220 - info: javascript.0 (3513) Stop script script.js.common.Licht_und_Schalter 2020-05-01 14:19:26.224 - info: javascript.0 (3513) Stop script script.js.common.Sicherheit 2020-05-01 14:19:26.228 - info: javascript.0 (3513) Stop script script.js.common.Sound 2020-05-01 14:19:26.231 - info: javascript.0 (3513) Stop script script.js.common.Systeminfo 2020-05-01 14:19:26.235 - info: javascript.0 (3513) Stop script script.js.common.Waschen 2020-05-01 14:19:26.237 - info: javascript.0 (3513) Stop script script.js.common.Tagescharakteristik 2020-05-01 14:19:26.240 - info: javascript.0 (3513) Stop script script.js.common.Email_und_Telegram_über_IFTTT_senden 2020-05-01 14:19:26.243 - info: javascript.0 (3513) Stop script script.js.common.Batteriezustände_und_Fensteröffnungen 2020-05-01 14:19:26.248 - info: javascript.0 (3513) Stop script script.js.common.Feuchte_und_Belüftung 2020-05-01 14:19:26.251 - info: javascript.0 (3513) Stop script script.js.common.Telefonanrufe_verarbeiten 2020-05-01 14:19:26.253 - info: javascript.0 (3513) Stop script script.js.common.Presence 2020-05-01 14:19:26.256 - info: javascript.0 (3513) Stop script script.js.common.Wetter_und_Bewässerung_mit_Promisses 2020-05-01 14:19:26.260 - info: javascript.0 (3513) terminating 2020-05-01 14:19:26.263 - info: javascript.0 (3513) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2020-05-01 14:19:26.875 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2020-05-01 14:19:29.332 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 started with pid 3893Edit: code tags
@Marty56 Dein node ist zu alt. Auf eine aktuelle 10er bringen, ich würde aber direkt auf node 12 springen.
@Marty56
mal etwas OT ... Du hast bereits 700 post hier, und packst dennoch die LOGs nicht in code-Tags, das kann ich nicht nachvollziehen ... es gibt so viele User die von unterwegs mobil hier reinschauen und versuchen zu unterstützen, für die ist so eine Antwort einfach schei... -
@Marty56
@BBTown
Und er schafft es auch nicht den ersten Post zu lesen, in dem sehr deutlich steht, dass mindestens Node 10 vorausgesetzt wird.@Jan1 said in js-controller 3.0 jetzt im Latest!:
@BBTown
Und er schafft es auch nicht den ersten Post zu lesen, in dem sehr deutlich steht, dass mindestens Node 10 vorausgesetzt wird.node10 hat er ja, allerdings ist die minor version auch zu alt:
"node":"10.17.0 -
@BBTown
"node":"10.17.0@Thomas-Braun
Die wird doch mit nem System Update hochgezogen und das sollte wohl auch ab und an gemacht werden. -
@apollon77 sagte in js-controller 3.0 jetzt im Latest!:
@oFbEQnpoLKKl6mbY5e13 Leg es bitte an bzw reopen wenn falsch geschlossen. Kriegen wir alles irgendwie hin
Der Fehler ist nicht mehr aufgetaucht, sodass ich jetzt erst mal abwarte.
Allerdings melden beim Start meines Containers verschiedene Adapter und nicht immer dieselben:
warn (329) no connection to objects DB@oFbEQnpoLKKl6mbY5e13 der fehler passiert wenn ein Adapter zu lange braucht um die Verbindung mit der iobroker dB zu bekommen. Kann es sein das in den Situationen recht viel Last auf der Liste herrschen? Wie geht es den Prozessen/cpu/RAM ...?
Frage von Noob:
@apollon77
Heute macht mein NAS ein RAID-Scrubbing, da ist es ziemlich träge. Das dauert auch fast den ganzen Tag. Ich beobachte das. -
@BBTown
"node":"10.17.0@Thomas-Braun exakr. Formal muss der js Adapter das korrekt angeben. Legt bitte jemand ein issue dort an?
@apollon77
Heute macht mein NAS ein RAID-Scrubbing, da ist es ziemlich träge. Das dauert auch fast den ganzen Tag. Ich beobachte das.@oFbEQnpoLKKl6mbY5e13 das wär eine Vermutung weil damit i/o Träger ist.
@Marty56
@Thomas-Braun
Die wird doch mit nem System Update hochgezogen und das sollte wohl auch ab und an gemacht werden.@Jan1 said in js-controller 3.0 jetzt im Latest!:
Aber auch nur, wenn man ein Repo für node hat und halt auch das Gesamtsystem ab und an frisch hält. Ich würde das wenigstens so einmal im Monat machen.
@Thomas-Braun
Auf dem Pi und jetzt mit Debian auf dem Beelink war das auf alle Fälle immer so :-) -
So, jetzt wage ich mich an den Kram und was ist?
Ich krieg es ja nicht mal hin NodeJS auf V12 upzudaten. :( (wie man es macht, steht wohl nirgends, nur dass man muss?)
Ich weiß schon, wieso ich die ganze Zeit bei V1 geblieben bin... das lief wenigstens.
