  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 605.7k Aufrufe 89 Beobachtet
  • A amsernat
    Frage von Noob:
    nach js-controller update funkt backitup nicht mehr.
    kann mir bitte jemand sagen was hier schief gelaufen ist?
    Danke im Voraus.
    host.raspberrypi	2020-05-01 12:56:19.026	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    host.raspberrypi	2020-05-01 12:56:07.650	info	Restart adapter system.adapter.backitup.0 because enabled
    host.raspberrypi	2020-05-01 12:56:07.649	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-05-01 12:56:07.649	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:840:9
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at detectLatestBackupFile (/opt/iobroker/node_modules/iobroker.backitup/main.js:699:33)
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at Array.map (<anonymous>)
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:699:48
    host.raspberrypi	2020-05-01 12:56:07.648	error	Caught by controller[1]: at new Promise (<anonymous>)
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/main.js:700:13
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at module.exports (/opt/iobroker/node_modules/iobroker.backitup/lib/list.js:72:36)
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at Object.list (/opt/iobroker/node_modules/iobroker.backitup/lib/list/googledrive.js:6:24)
    host.raspberrypi	2020-05-01 12:56:07.647	error	Caught by controller[1]: at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31)
    host.raspberrypi	2020-05-01 12:56:07.646	error	Caught by controller[1]: at JSON.parse (<anonymous>)
    host.raspberrypi	2020-05-01 12:56:07.646	error	Caught by controller[1]: SyntaxError: Unexpected token ' in JSON at position 1
    host.raspberrypi	2020-05-01 12:56:07.645	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    backitup.0	2020-05-01 12:56:07.108	info	(20766) Terminated (NO_ERROR): Without reason
    backitup.0	2020-05-01 12:56:07.106	info	(20766) terminating
    backitup.0	2020-05-01 12:56:07.057	info	(20766) cleaned everything up...
    backitup.0	2020-05-01 12:56:07.055	error	(20766) SyntaxError: Unexpected token ' in JSON at position 1 at JSON.parse (<anonymous>) at new GoogleDrive (/opt/iobroker/node_modules/iobroker.backitup/lib/googleDriveLib.js:15:31) at O
    backitup.0	2020-05-01 12:56:07.049	error	(20766) uncaught exception: Unexpected token ' in JSON at position 1
    backitup.0	2020-05-01 12:56:06.962	info	(20766) [iobroker] backup was activated at 02:00 every 3 day(s)
    backitup.0	2020-05-01 12:56:06.903	info	(20766) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.16.3, js-controller: 3.0.20
    host.raspberrypi	2020-05-01 12:56:02.989	info	instance system.adapter.backitup.0 started with pid 20766
    pi@raspberrypi:~ $ node -v
    v12.16.3
    pi@raspberrypi:~ $ iobroker status
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $ npm -v
    6.14.4
    RAM
    3.81 GB
    System Betriebszeit
    14 T. 01:25:12
    Festplatte Größe
    28.98 GB
    Festplatte frei
    22.98 GB
    Anzahl der Adapter
    346
    Betriebszeit
    13:25:16
    Aktive Instanzen
    21
    raspberrypi
    Typ: js-controller
    Titel: JS controller
    OS: linux
    Verfügbar: 3.0.20
    Installiert: 3.0.20
    Ereignisse: ⇥26 / ↦15
    #629
    @amsernat irgend ein json file ist kaputt. Speicher mal die konfig neu. Hat nix mit Controller zu tun. Bitte in einem der backitup threads fragen Oder-Neiße-Linie anlegen.
    • apollon77A apollon77
      @oFbEQnpoLKKl6mbY5e13 der fehler passiert wenn ein Adapter zu lange braucht um die Verbindung mit der iobroker dB zu bekommen. Kann es sein das in den Situationen recht viel Last auf der Liste herrschen? Wie geht es den Prozessen/cpu/RAM ...?
      O Offline
      O Offline
      #630
      @apollon77
      Heute macht mein NAS ein RAID-Scrubbing, da ist es ziemlich träge. Das dauert auch fast den ganzen Tag. Ich beobachte das.
      • M Marty56
        Habe die Version 3.0.20 installiert. Soweit keine Probleme. Gut Arbeit.
        Im Log File habe jetzt ein paar Warnings, z. B.
        readFile 2020-05-01 14:05:43.635 warn will not read this file (devices/cpu.png) in future versions: icons-open-icon-library-png is not an object of type "meta"
        Es handelt sich da wohl um eigene Icons, die ich in VIS verwende.
        Bei dem Update vom VIS Module gab es auch mal eine Memory Warnung, aber nach Abschuss der Installation war wieder ausreichend Memory frei.
        Bei Zigbee Adapter gab es die Warnung
        zigbee.0 2020-05-01 14:05:07.228 warn (COMPACT) no connection to objects DB
        Er scheint aber zu laufen.
        Ich habe auch versucht auf die neueste Version (4.5.1) der Script Engine upzudaten, aber die Installation scheint nicht zu funktionieren und es wird immer noch 4.4.3 angezeigt.
        2020-05-01 14:18:19.059 - info: host.ioBroker-RasPi4 iobroker Update javascript from @4.4.3 to @4.5.1
        2020-05-01 14:18:21.640 - info: host.ioBroker-RasPi4 iobroker NPM version: 6.11.3
        2020-05-01 14:18:21.646 - info: host.ioBroker-RasPi4 iobroker npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
        2020-05-01 14:19:25.371 - info: host.ioBroker-RasPi4 iobroker npm
        2020-05-01 14:19:25.377 - info: host.ioBroker-RasPi4 iobroker ERR! code ENOTSUPnpm ERR! notsup
        2020-05-01 14:19:25.383 - info: host.ioBroker-RasPi4 iobroker Unsupported engine for puppeteer@3.0.2: wanted: {"node":">=10.18.1"} (current: {"node":"10.17.0","npm":"6.11.3"})npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Not compatible with your version of node/npm: puppeteer@3.0.2npm ERR! notsup Required: {"node":">=10.18.1"}npm ERR! notsup Actual: {"npm":"6.11.3","node":"10.17.0"}
        2020-05-01 14:19:25.473 - info: host.ioBroker-RasPi4 iobroker
        2020-05-01 14:19:25.478 - info: host.ioBroker-RasPi4 iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-01T12_19_25_434Z-debug.log
        2020-05-01 14:19:25.985 - info: host.ioBroker-RasPi4 iobroker Update "system.adapter.javascript.0"
        2020-05-01 14:19:26.178 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 (force=false, process=true)
        2020-05-01 14:19:26.197 - info: host.ioBroker-RasPi4 stopInstance system.adapter.javascript.0 send kill signal
        2020-05-01 14:19:26.197 - info: javascript.0 (3513) Got terminate signal TERMINATE_YOURSELF
        2020-05-01 14:19:26.208 - info: javascript.0 (3513) Stop script script.js.common.Heizung
        2020-05-01 14:19:26.215 - info: javascript.0 (3513) Stop script script.js.common.Jalousien
        2020-05-01 14:19:26.220 - info: javascript.0 (3513) Stop script script.js.common.Licht_und_Schalter
        2020-05-01 14:19:26.224 - info: javascript.0 (3513) Stop script script.js.common.Sicherheit
        2020-05-01 14:19:26.228 - info: javascript.0 (3513) Stop script script.js.common.Sound
        2020-05-01 14:19:26.231 - info: javascript.0 (3513) Stop script script.js.common.Systeminfo
        2020-05-01 14:19:26.235 - info: javascript.0 (3513) Stop script script.js.common.Waschen
        2020-05-01 14:19:26.237 - info: javascript.0 (3513) Stop script script.js.common.Tagescharakteristik
        2020-05-01 14:19:26.240 - info: javascript.0 (3513) Stop script script.js.common.Email_und_Telegram_über_IFTTT_senden
        2020-05-01 14:19:26.243 - info: javascript.0 (3513) Stop script script.js.common.Batteriezustände_und_Fensteröffnungen
        2020-05-01 14:19:26.248 - info: javascript.0 (3513) Stop script script.js.common.Feuchte_und_Belüftung
        2020-05-01 14:19:26.251 - info: javascript.0 (3513) Stop script script.js.common.Telefonanrufe_verarbeiten
        2020-05-01 14:19:26.253 - info: javascript.0 (3513) Stop script script.js.common.Presence
        2020-05-01 14:19:26.256 - info: javascript.0 (3513) Stop script script.js.common.Wetter_und_Bewässerung_mit_Promisses
        2020-05-01 14:19:26.260 - info: javascript.0 (3513) terminating
        2020-05-01 14:19:26.263 - info: javascript.0 (3513) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-05-01 14:19:26.875 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2020-05-01 14:19:29.332 - info: host.ioBroker-RasPi4 instance system.adapter.javascript.0 started with pid 3893
        Edit: code tags
        #631
        @Marty56 zu dem Icon Thema. Eigene icons in eigenen Verzeichnissen sind schon seit controller 2.2 „böse“. Bitte sauber aufsetzen oder in einen Ordner bewegen wo sie erlaubt sind.
          @Jan1 said in js-controller 3.0 jetzt im Latest!:
          @BBTown
          Und er schafft es auch nicht den ersten Post zu lesen, in dem sehr deutlich steht, dass mindestens Node 10 vorausgesetzt wird.
          node10 hat er ja, allerdings ist die minor version auch zu alt:
          "node":"10.17.0
          #632
          @Thomas-Braun exakr. Formal muss der js Adapter das korrekt angeben. Legt bitte jemand ein issue dort an?
          • O oFbEQnpoLKKl6mbY5e13
            @apollon77
            #633
            @oFbEQnpoLKKl6mbY5e13 das wär eine Vermutung weil damit i/o Träger ist.
            • BBTownB BBTown
              @Marty56
              mal etwas OT ... Du hast bereits 700 post hier, und packst dennoch die LOGs nicht in code-Tags, das kann ich nicht nachvollziehen ... es gibt so viele User die von unterwegs mobil hier reinschauen und versuchen zu unterstützen, für die ist so eine Antwort einfach schei...
              #634
              @BBTown ich hab’s mal gefixt.
              • J Jan1
                @Thomas-Braun
                Die wird doch mit nem System Update hochgezogen und das sollte wohl auch ab und an gemacht werden.
                #635
                Aber auch nur, wenn man ein Repo für node hat und halt auch das Gesamtsystem ab und an frisch hält. Ich würde das wenigstens so einmal im Monat machen.
                  Jan1
                  #636
                  @Thomas-Braun
                  Auf dem Pi und jetzt mit Debian auf dem Beelink war das auf alle Fälle immer so :-)
                  • padrinoP Offline
                    padrinoP Offline
                    padrino
                    #637
                    So, jetzt wage ich mich an den Kram und was ist?
                    Ich krieg es ja nicht mal hin NodeJS auf V12 upzudaten. :( (wie man es macht, steht wohl nirgends, nur dass man muss?)
                    Ich weiß schon, wieso ich die ganze Zeit bei V1 geblieben bin... das lief wenigstens. 😢
                    BBTownB 1 Antwort Letzte Antwort
                    • padrinoP padrino
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      #638
                      @padrino
                      ernsthaft, jetzt???????????????
                      • BBTownB BBTown
                        @padrino
                        Jan1
                        #639
                        @BBTown
                        Das blinkt nicht, deshalb wir es gerne übersehen ;-)
                        padrinoP M 2 Antworten Letzte Antwort
                        • J Jan1
                          @BBTown
                          padrinoP Offline
                          padrinoP Offline
                          padrino
                          #640
                          @BBTown
                          Geh Dir mal 'n Bier holen, das beruhigt. :)
                          @Jan1
                          Vermutlich. ;)
                          Aber da ich fast nur mobil hier unterwegs bin, muss ich sagen, so weit runter scroll ich eigentlich nie. 😌
                          J BBTownB 2 Antworten Letzte Antwort
                          • padrinoP padrino
                            @BBTown
                            @Jan1
                            Vermutlich. ;)
                            Jan1
                            #641
                            @padrino
                            Das wird in jedem Thread oben eingeblendet, also irgendwann muss man den roten Kasten einfach mal bemerken :-)
                            • J Jan1
                              @BBTown
                              mameier1234
                              #642
                              @Jan1 Ist aber schon erstaunlich... Hab ich auch noch nie gesehen (duck und weg....)
                              Grüße,
                              Martin
                              • M mameier1234
                                Jan1
                                #643
                                @mameier1234
                                Das brennt auch in den Augen wenn man zu lange drauf schaut 😁
                                • padrinoP padrino
                                  @BBTown
                                  @Jan1
                                  Vermutlich. ;)
                                  BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  schrieb am zuletzt editiert von BBTown
                                  #644
                                  @padrino sagte in js-controller 3.0 jetzt im Latest!:
                                  Wenn ich das jedes mal machen würde/müßte, dann wäre ich womöglich schwerer Alkoholiker 😎
                                  Aber ernsthaft jetzt, Du bist doch schon etwas dabei, da wirst Du doch schon mehr als einmal nod/nodejs aktualisiert haben ....
                                  • J Jan1
                                    @mameier1234
                                    mameier1234
                                    #645
                                    @Jan1 sagte in js-controller 3.0 jetzt im Latest!:
                                    @mameier1234
                                    Ja.. jetzt ganz doll !!
                                    Das liegt wohl einfach daran, dass die meisten Threads, in denen man sich tummelt ziemlich lang sind.. und das ja leider nur ganz oben angezeigt wird..
                                    Könnte das nicht rechts mit nach unten wandern ? Genug Platz ist ja da...
                                    Grüße,
                                    Martin
                                    BBTownB J 2 Antworten Letzte Antwort
                                    • M mameier1234
                                      @mameier1234
                                      BBTownB Offline
                                      BBTownB Offline
                                      BBTown
                                      #646
                                      @mameier1234 sagte in js-controller 3.0 jetzt im Latest!:
                                      bei mir tut es das, aber auch nur bis die alternativen Threads (die zum Thema passen könnten) unten eingeblendet werden, dann hört das "Mitlaufen" auf
                                      • M mameier1234
                                        @mameier1234
                                        Jan1
                                        #647
                                        @mameier1234
                                        Aus dem Grund steht es auch auf der Übersichtsseite ganz oben und da fängt man in der Regel auch immer an😉
                                        • M Marty56
                                          Edit: code tags
                                          #648
                                          @Marty56 sagte in js-controller 3.0 jetzt im Latest!:
                                          puppeteer
                                          DIe interessante Frageist wo "puppeteer" als Dependency herkommt? im Javascript adapter wäre mit das nicht bekannt und hab es bei mir auch nicht gefunden. Also ist es irgendeine andere Abhängigkeit von irgendwoher ... mach mal "npm ls" und ssuch bitte wo das als depenedncy ist.
                                          ? joergeliJ M 3 Antworten Letzte Antwort
