  4. Apple Homekit Siri
Apple Homekit Siri
250 Beiträge 49 Kommentatoren 90.4k Aufrufe
  • ruhr70R
    ruhr70R
    ruhr70
    #183
    Wollte es schnell auf dem neuen Rechner auch mal installieren (über die Weboberfläche Admin):
    Erhalte auch die Fehlermeldungen:
    $ ./iobroker add homekit
    npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
    gyp
    WARN
    EACCES
    user "root" does not have permission to access the dev dir "/root/.node-gyp/4.4.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519/.node-gyp"
    ! gyp
    WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.4.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519/.node-gyp"
    ! gyp
    WARN EACCES
    EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns/.node-gyp"
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    compilation terminated.
    ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    gyp
    ERR! build error
    gyp
    ERR! stack
    Error: make failed with exit code: 2gyp ERR! stack
    at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp
    ERR!
    stack
    at emitTwo (events.js:87:13)gyp ERR!
    stack
    at ChildProcess.emit (events.js:172:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
    gyp ERR! System Linux 4.4.0-21-generic
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
    gyp
    ERR! node -v v4.4.3gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    ! gyp
    WARN
    WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/.node-gyp"
    npm
    ERR! Linux 4.4.0-21-generic
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.4.3
    npm ERR! npm v2.15.1
    npm ERR! code ELIFECYCLE
    ! npm ERR! mdns@2.2.11 install: node-gyp rebuild
    npm
    ERR! Exit status 1npm ERR!
    npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the mdns package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs mdns
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls mdns
    npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! ERROR: host.ubuntu1604server Cannot install iobroker.homekit: 1
    essentials sind installiert.
    ubuntu 16.04 Server
    node v4.4.3
    npm 2.15.1
    js-controller 0.8.10
    admin 1.0.3
    • HomoranH
      #184
      Hallo MIchael,
      du hast EACCESS!
      selbst der user root hat keinen Zugriff auf die Dateien!?!
      @ruhr70:
      user "root" does not have permission to access the dev dir "/root/.node-gyp/4.4.3" `
      und das auch noch im /root Verzeichnis
      Bin zwar auch kein Linux-Experte, aber da war mal was. Hast du da was als normaler User installiert und die Rechte liegen beim Besitzer?
      • ruhr70R
        ruhr70R
        ruhr70
        #185
        @Homoran:
        Hallo MIchael,
        du hast EACCESS!
        @ruhr70:
        Rainer `
        na da sind wir doch schon zu zweit ;-) (kein Linux Experte).
        Auf das root-Verzeichnis kommt nur der User root. Gerade noch einmal probiert.
        Und es ist leer.
        • HomoranH
          #186
          @ruhr70:
          Und es ist leer. `
          aber du siehst schon den Punkt:@ruhr70:
          user "root" does not have permission to access the dev dir "/root/****<size size="150">.</size>****node-gyp/4.4.3" `
          sind das dann nicht versteckte Systemdateien?
          So soeht es bei mir aus:
          • ruhr70R
            ruhr70R
            ruhr70
            #187
            @Homoran:
            user "root" does not have permission to access the dev dir "/root/****<size size="150">.</size>****node-gyp/4.4.3" sind das dann nicht versteckte Systemdateien?
            OK, Punkt für Dich ;-)
            ja, die Dateien sind da. Hatten die notwendigen Rechte.
            Und jetzt wird sich jeder Linux/Security-Profi an den Kopf fassen. Ich habe die dann noch einmal hochgesetzt (auf 777).
            (für das Verzeichnis 4.4.3 auch)
            Es bleibt wie es ist. Geht nicht.
            • HomoranH
              #188
              @ruhr70:
              OK, Punkt für Dich ;-) `
              Hatte ihn ja auch extra rot angemalt ;-)
              @ruhr70:
              Ich habe die dann noch einmal hochgesetzt (auf 777). `
              hätte ich jetzt auch gemacht.
              @ruhr70:
              Es bleibt wie es ist. Geht nicht. `
              Und genau das gab es schon mal :(
              Da muss dann leider der blaue Fuchs noch mal ran - der schafft das!
              • ruhr70R
                ruhr70R
                ruhr70
                #189
                @Homoran:
                Da muss dann leider der blaue Fuchs noch mal ran - der schafft das! `
                Der schafft alles!
                Ich habe den Adapter aber auch nur auf Grund des Threads installiert, weil ich sehen wollte, wie es bei mir ist :-)
                War erst einmal als Feedback gedacht.
                Wobei der Homekit-Adapter dann später auf jeden Fall produktiv zum Einsatz kommen soll.
                • C
                  C
                  chka
                  #190
                  @Bormann:
                  Bei mir hat nach ewigem rumprobieren die Installation geklappt. Eve findet die Homebridge auch, aber nach der Pin-Abfrage geht es nicht weiter. Das Log gibt keine Hinweise… Habe einen Raspi 3. Ist da jemand schon weiter gekommen?
                  VG! `
                  Bei mir das gleiche egal ob eve oder andere homekit apps
                  INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
                  Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
                  RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
                  • D
                    D
                    DiJaexxl
                    #191
                    ich habe einmal eine Frage Richtung Client App auf dem iDevice.
                    Was habt Ihr für Apps auf iPhone und iPad installiert?
                    Gruss aus Bensberg
                    Dirk
                    • N
                      N
                      Nicku
                      #192
                      Guten Abend,
                      ich lese schon eine Weile hier im Forum mit.
                      Leider habe ich auch ein Problem mit dem Homekit-Adapter und hier noch keine passende Lösung gefunden.
                      Ich habe den Adapter installiert bekommen, kann mich auch mit Eve mit der Bridge verbinden und auch die Geräte werden angezeigt. Allerdings läuft er instabil und ich bekomme keinen Status, bzw. kann keine Geräte schalten. Folgendes steht im Log beim Absturz:
                      ! homekit.0 2016-05-01 11:59:14 info homekit.0 Bridge 'ioBroker Bridge' successfully published
                      ! homekit.0 2016-05-01 11:59:14 info homekit.0 hap-nodejs starting…
                      ! homekit.0 2016-05-01 11:59:11 info homekit.0 starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
                      ! homematic-pi 2016-05-01 11:59:06 info host.homematic-pi instance system.adapter.homekit.0 started with pid 29580
                      ! host-homematic-pi 2016-05-01 11:58:52 info Update repository "default" under "conf/sources-dist.json"
                      ! host-homematic-pi 2016-05-01 11:58:36 info Restart adapter system.adapter.homekit.0 because enabled
                      ! host-homematic-pi 2016-05-01 11:58:36 error instance system.adapter.homekit.0 terminated with code 0 (OK)
                      ! TypeError: 2016-05-01 11:58:36 error at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
                      ! TypeError: 2016-05-01 11:58:36 error at HAPServer.emit (events.js:175:7)
                      ! TypeError: 2016-05-01 11:58:36 error at emitThree (events.js:97:13)
                      ! TypeError: 2016-05-01 11:58:36 error at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
                      ! TypeError: 2016-05-01 11:58:36 error at Array.forEach (native)
                      ! TypeError: 2016-05-01 11:58:36 error at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
                      ! TypeError: 2016-05-01 11:58:36 error at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
                      ! TypeError: 2016-05-01 11:58:36 error at emit (events.js:172:7)
                      ! TypeError: 2016-05-01 11:58:36 error at emitTwo (events.js:87:13)
                      ! TypeError: 2016-05-01 11:58:36 error at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:759:37)
                      ! TypeError: 2016-05-01 11:58:36 error Cannot read property 'val' of undefined
                      ! uncaught 2016-05-01 11:58:36 error exception: Cannot read property 'val' of undefined
                      Folgendes, wenn ich versuche ein Gerät zu schalten:
                      ! hm-rpc.0 2016-05-01 11:59:57 error hm-rpc.0 binrpc -> setValue: no dpType for hm-rpc.0.LEQ0476884.1undefined!
                      ! hm-rpc.0 2016-05-01 11:59:52 error hm-rpc.0 binrpc -> setValue: no dpType for hm-rpc.0.LEQ0476884.1undefined!
                      Leider komme ich hier seit Tagen nicht weiter.
                      Hast jemande eine Idee? Danke für die Hilfe.
                      • L
                        L
                        Lenz2k3
                        #193
                        Also bei mir funktioniert es perfekt!
                        Ist es auch möglich die Virtuelle Fernbedienung aus der CCU2 einzubinden? Ich würde darüber dann gerne CCU2-Programme auslösen können? Bei dem homekit-Adapter habe ich jetzt zum Beispiel folgendens Gerät eingebunden:
                        Switch State HM-RCV-50 11.PRESS_SHORT
                        in der Elgato-App erkennt er aber kein neues Gerät?
                        Viele Grüße,
                        Lenz
                        • B
                          B
                          Bormann
                          #194
                          Hi Lenz2k3,
                          Kannst Du kurz beschreiben, wie Du den Adapter ans Laufen gebracht hast? Ging es einfach so, oder musstest Du etwas spezielles installieren bzw. einstellen?
                          Danke und VG,
                          Sebastian
                          • L
                            L
                            Lenz2k3
                            #195
                            Ich hatte die selbe Fehlermeldung wie hier oft beschrieben und wollte dann Homebridge installieren auf meinem Raspi. Dann habe ich folgenden Befehl ausgeführt:
                            sudo apt-get install libavahi-compat-libdnssd-dev
                            Danach ging es irgendwie…. (Mehr Glück als Verstand :geek: )
                            • B
                              B
                              Bormann
                              #196
                              Probiere ich auch mal! Danke!
                              • B
                                B
                                Bormann
                                #197
                                Hmm, das hatte ich wohl schon mal versucht, jedenfalls ist dieses Paket schon bei mir installiert. Hat noch jemand Ideen? Ich komme beim Verbinden mit Eve bis zur Pin Abfrage - dann bricht Eve ab. Das Log bleibt leer…
                                • L
                                  L
                                  Lenz2k3
                                  #198
                                  Falls es dich tröstet: Bei mir funktioniert es mitterlweile auch nicht mehr. Keine Ahnung warum. Hab den Adapter mehrfach neu installiert. Die Elgato Evo App findet das Gerät aber nicht mehr und ich kann keine Verbindung aufbauen. Es waren aber auch ohnehin noch nicht so viele Geräte dort verfügbar im Adapter.
                                  Vielleicht muss man einfach abwarten bis es eine aktuellere Version gibt :)
                                  • C
                                    C
                                    chaos99
                                    #199
                                    Wenn der Adapter nicht im Netzwerk , also eve gefunden wird , einfach im Adapter Einstellungen mal Mac Adresse Namen ändern , Mac Adresse zB einen Buchstaben tauschen , dann geht es wieder ,
                                    Es ist lange nichts mehr passiert und ich kenne mich leider gar nicht mit Programmierung aus ,
                                    Aber es gehen das wired 12 Modul nicht und auch wired Jalousie aktoren gehen nicht ,
                                    • B
                                      B
                                      Bobohne
                                      #200
                                      Hallo!
                                      Ich möchte das auch sehr gerne realisieren.
                                      Mein ioBroker läuft allerdings auf einem 64-bit Windows 7. Die Installation von Homekit bricht wegen Inkompatibilität ab.
                                      Bekommt man das trotzdem irgendwie zum Laufen?
                                      Wenn nein meine Weitere Frage:
                                      Gibt es auf iOS oder Android eine Möglichkeit der Sprachsteuerung mit der ich http-get Befehle an die HM XML-API absetzen kann? Das würde mir schon reichen. Im Idealfall hört das ganze dann auf ein "Codewort" wie bei der App Home Commander (die ja meines Wissens nicht weiter entwickelt wird oder?).
                                      Sorry für die Anfängerfragen…
                                      Danke!!
                                      lg
                                      Michael
                                      • V
                                        V
                                        venni
                                        #201
                                        ! @jack77:
                                        ! > Ich kriege Homekit einfach nicht installiert.
                                        Kriege immer folgenden Fehler…
                                        ` > $ ./iobroker add homekit
                                        npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
                                        In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
                                        #include <dns_sd.h>^
                                        make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                                        gyp
                                        ERR! build error
                                        gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                        gyp ERR! stack at emitTwo (events.js:87:13)
                                        gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                                        gyp ERR! System Linux 4.1.19-v7+
                                        gyp ERR!
                                        gyp ERR! node -v v4.4.3gyp ERR! node-gyp -v v3.3.1
                                        gyp ERR! not ok
                                        npm
                                        ERR!
                                        Linux 4.1.19-v7+
                                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.4.3
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! This is most likely a problem with the mdns package,npm ERR! not with npm itself.
                                        npm ERR! npm ERR! npm owner ls mdns
                                        ERROR: host.raspberrypi Cannot install iobroker.homekit: 1
                                        ERROR: process exited with code 25</dns_sd.h> `
                                        ioBroker ist auf einem Raspi2 mit Debian Jessie installiert.
                                        Kann mir einer helfen `
                                        ich habe exakt das gleiche Problem in der gleichen Konstellation.
                                        Es lässt sich nicht installieren und die Fehlermeldungen sind identisch.
                                        Pi2 mit Jessie.
                                        Hat das jemand in dieser Konstellation am laufen?
                                        Wenn die Installation schon nicht klappt, dürften doch mehrere das Problem haben.
                                        Frank
                                        • S
                                          S
                                          simpixo
                                          #202
                                          Ich kann den Adapter auch nicht installieren, der bricht bei der Installation mit der gleichen Fehlermeldung ab
                                          Ich habe den iobroker auf einem Pi3 + Jessi laufen! Alles andere funktioniert
                                          Adrian
                                          Gesendet von meinem iPhone mit Tapatalk
                                          84.2k
