  4. JavaScript
  5. [Vorlage] Generisches Fensteroffenskript + Vis
    apollon77A
javascripttemplatemonitoring
768 Beiträge 81 Kommentatoren 347.3k Aufrufe 97 Beobachtet
  • S Saschag
    wenn ich das Skript von Hand starte klappt alles, nur wie wird nach Skript "automatisch" angesprochen? bzw. habe folgenden Fehler im Log -- wenn das "WC Fenster" geschlossen wird
    javascript.0	2020-04-17 09:11:17.656	error	(22900) at processImmediate (timers.js:658:5)
    javascript.0	2020-04-17 09:11:17.656	error	(22900) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-04-17 09:11:17.655	error	(22900) at runCallback (timers.js:705:18)
    javascript.0	2020-04-17 09:11:17.654	error	(22900) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
    javascript.0	2020-04-17 09:11:17.653	error	(22900) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:450:25)
    javascript.0	2020-04-17 09:11:17.652	error	(22900) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1122:38)
    javascript.0	2020-04-17 09:11:17.652	error	(22900) at Object.<anonymous> (script.js.common.FensterScript:572:17)
    javascript.0	2020-04-17 09:11:17.650	error	(22900) at CheckWindow (script.js.common.FensterScript:436:38)
    javascript.0	2020-04-17 09:11:17.650	error	(22900) at Meldung (script.js.common.FensterScript:173:21)
    javascript.0	2020-04-17 09:11:17.648	error	(22900) Error in callback: ReferenceError: Say is not defined
    javascript.0	2020-04-17 09:11:17.645	info	(22900) script.js.common.FensterScript: Reaching Meldung, msg= WC Fenster geschlossen!
    javascript.0	2020-04-17 09:11:17.644	info	(22900) script.js.common.FensterScript: WC Fenster geschlossen.
    javascript.0	2020-04-17 09:11:17.643	info	(22900) script.js.common.FensterScript: reaching CheckWindow, SensorVal[18]=closed SensorOldVal=open TempRoom=WC
    javascript.0	2020-04-17 09:11:17.641	info	(22900) script.js.common.FensterScript: Reaching GetRoom x=18
    javascript.0	2020-04-17 09:11:17.640	info	(22900) script.js.common.FensterScript: Trigger= 18 Wert= false Alter Wert= true
    Danke und Grüße
    P
    P
    Pittini
    #82
    @Saschag sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
    wenn ich das Skript von Hand starte klappt alles, nur wie wird nach Skript "automatisch" angesprochen? bzw. habe ich folgend Fehler im Log
    Ich verstehe nicht so ganz was Du meinst mit "wie wird nach Skript "automatisch" angesprochen?" .
    Dessen ungeachtet seh ich anhand des Logs dass Du einen Konfigurationsfehler in Zeile 23 haben dürftest. Stell UseSay mal auf false wie es im Kommentar direkt daneben auch gefordert wird.
    • P Pittini
      S
      S
      Saschag
      schrieb am zuletzt editiert von Saschag
      #83
      @Pittini
      Okay, etwas kompliziert ausgedrückt ;-(
      Also wenn ich das Skript von Hand aktualisiere werden die zustände erkannt und geändert, aber halt nicht automatisch. Könnte dies am Log-Fehler liegen (Habe ich überlesen und natürlich gleich geändert)
      Vielen Dank!
      Edit: Es lag am Fehler. ;-)
      Tolles Skript!!
      P 1 Antwort Letzte Antwort
      • S Saschag
        @Pittini
        Vielen Dank!
        Tolles Skript!!
        P
        P
        Pittini
        #84
        Zum Verständnis. Bei Skriptstart waren die Gegebenheit eben so dass das Skript keine Meldung ausgeben wollte. Machst jetzt ein Fenster auf oder zu, versucht das Skript das zu melden. Und beim melden versuchte es die Funktion Say anzusprechen welche Du nicht hast aber aktiviert hattest.
        S 2 Antworten Letzte Antwort
        • P Pittini
          S
          S
          Saschag
          #85
          @Pittini
          Super Support, Danke dafür!
          • P Pittini
            S
            S
            Saschag
            #86
            @Pittini
            sollte deinScript auch mit AQARA Tür/Fensterkontakt funktionieren??
            • S Saschag
              @Pittini
              P
              P
              Pittini
              #87
              Sollte nicht nur, tuts auch definitiv, hab selber etliche davon im Einsatz.
              • P Pittini
                S
                S
                Saschag
                #88
                @Pittini
                👍 gleich mal einen bestellt 😉
                • P Pittini
                  Update 1.3.0 auf Git
                  9.4.20 (V 1.3.0)
                  • Add: Unterstriche werden in Meldungen nun als Leerzeichen ausgegeben. Ae, ue, oe, wird in Meldungen nun als ä, ü, ö ausgegeben.
                  • Change: offen/geschlossen Zeiten werden nicht mehr als Zeitstempel angezeigt sondern die jeweilige Dauer berechnet und minütlich aktualisiert.
                  • Add: Pro Raum konfigurierbare Lüftungsempfehlung integriert. Bei Skriptneustarts wird bereits vorhandene geschlossen Zeit berücksichtigt.
                  • Change: Tabellenfarben jetzt heller / freundlicher.
                  • Fix: Ignorieren von geöffneten Fenstern bei Skriptstart behoben, wenn diese in einem Raum mit mehreren/zweiflügeligen Fenstern waren und das geöffnete Fenster in der Aufzählung vor dem geschlossenen gelistet war.
                  O
                  O
                  Oli
                  #89
                  @Pittini
                  sorry, aber ich habe mir das Script und die Anleitung jetzt zig mal durchgelesen und wahrscheinlich doch überlesen.
                  Wo stelle ich die Lüftungsempfehlung pro Raum ein, im Script, oder manuell im jeweiligen Datenpunkt?
                  Oliver
                  • O Oli
                    @Pittini
                    P
                    P
                    Pittini
                    schrieb am zuletzt editiert von Pittini
                    #90
                    @Oli sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                    Im Skript kannst Du nur globale Sachen fürs ganze Skript einstellen, also fällt das logischerweise schon mal weg. Bleiben die Datenpunkte über, da ist es sowohl dokumentiert als auch in der Beschreibung zu finden.
                    Inked2020-04-22 14_12_34-Pittini_iobroker-Fensterauswertung_ Zählt geöffnete Fenster pro Raum und gesamt._LI.jpg
                    • C
                      C
                      Chaibi87
                      schrieb am zuletzt editiert von Chaibi87
                      #91
                      erstmal Respekt für die Arbeit die man in so etwas investiert ;)
                      ich habe soweit alles eingestellt und bekomme nun im Log im JS Adapter folgende Ausgabe...
                      Es handelt sich bei mir um Fensterkontakte die an ein Homematic Wired HMW-Sen-SC-12-DR angeschlossen sind.
                      Woran könnte das liegen?
                      Danke im Vorraus...
                      Jan
                      • C Chaibi87
                        Danke im Vorraus...
                        Jan
                        P
                        P
                        Pittini
                        #92
                        @Chaibi87 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                        Fehlkonfiguration (steht ja auch im Log). Es wurde vermutlich ein ganzer Channel als "Verschluss" definiert und nicht nur der eine Datenpunkt der das öffnen/schliessen abbildet, wie in der Anleitung ganz klar gefordert. Zeig mal Konfig von nem Sensor im Objektbaum als Screenshot.
                        • C
                          C
                          Chaibi87
                          #93
                          Ok Sorry, werde das so mal testen. Das kommt davon wenn man die readme nicht liest ;)
                          Hatte es so eingefügt und nach den Kommentaren im Skript eingestellt. Ich habe die stable version genommen, dort steht im Kommentar hinter der Variable "Verschluss" noch kein Hinweis dazu. Abgesehen davon sollte man natürlich zuerst die Anleitung lesen ;)
                          • C
                            C
                            Chaibi87
                            #94
                            Also jetzt funktioniert auf jeden Fall alles bei mir. Ich habe jetzt nicht den kompletten Verlauf hier gelesen, aber hast du schon daran gedacht eine Funktion einzubauen, um einzelne Fenster ohne Meldung schalten zu können? Wenn ich in der Küche ein Fenster habe welches ich offen lassen möchte, dann schalte ich über eine Variable die Meldungen inaktiv.
                            Gruß Jan
                            • C Chaibi87
                              Gruß Jan
                              P
                              P
                              Pittini
                              #95
                              Wenn ein Fenster (sensor) nicht berücksichtigt werden soll brauch man ihn ja nur die Funktion "Verschluss" wegnehmen. Aber wenn ich Dich richtig verstehe soll das in den Anzeigen weiterhin drin sein, aber keine Meldung auslösen? Die Idee ist nicht schlecht, wird aber, da das Skript raumbasiert arbeitet, dann so sein dass man bestimmte Räume von der Meldung ausnehmen kann. Wär das so in Deinem Sinne?
                              • C
                                C
                                Chaibi87
                                #96
                                Ja das wäre ja über ein anderes Ereignis ja schlecht machbar. Genau, es wäre ja sinnvoll einen Raum ausschließen zu können. Ich denke dabei an einen Anwendungsfall z.B. wenn ich mich in einem Raum befinde und der Bewegungsmelder eine Bewegung erkannt hat, brauche ich keine Meldung, dass ein Fenster o.ä. offen ist. So könnte man über ein seperates Skript die Variable z.B. "msg_mute" oder "msg_inactive" steuern.
                                • P Pittini
                                  Dominik F.D
                                  Dominik F.D
                                  Dominik F.
                                  #97
                                  @Pittini
                                  Ich habe für mich auch ein kleines Problem und weiß nicht wie ich das lösen kann, vielleicht passt das ja zu dem Thema.
                                  Ich nutze dein Skript um meine Heizung, sobald ein Fenster in einem Raum mehr als 10 Minuten offen ist, herunter zu fahren. Ich habe jetzt eine Terassentür die mit einem HM IP Drehgriffkontakt läuft. Wenn ich die Terassentür jetzt zu mache, den Drehgriffkontakt aber auf offen lassen, dann wird das Fenster ja als offen angezeigt. Das ist auch gut so, weil ich möchte ja auch überprüfen ob irgendwo ein Fenster offen ist. Nur geht dann natürlich auch die Heizung aus^^ Habe schon mal an einen zweiten Kontakt am Fenster gedacht der wirklich nur anzeigt, ob die Tür geöffnet ist unabhängig von der Stellung des Griffes, nur dann hätte ich n Fenster mehr in der Anzeige, was verwirrend in der Anzeige sein könnte. Ich hoffe ich hab mich verständlich ausgedrückt^^
                                  Vielleicht passt das ja zu dem Vorschlag von Chaibi887
                                  • Dominik F.D Dominik F.
                                    @Pittini
                                    P
                                    P
                                    Pittini
                                    #98
                                    @Dominik-F sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                    Sorry aber das is halt einfach Käse dann. Mach den Griff halt einfach zu wenn zu ist. Der nächste macht das Fenster auf und dreht den Griff auf zu, das wär der gleiche Käse. Wenn Du das weiterhin so machen willst mußt halt wirklich nen 2ten Sensor für auf/zu nehmen und den ersten aus der Konfig nehmen. Wodurch Du jedoch die gekippt erkennung verlierst die im nächsten update drin ist mit gesonderter Anzeige und Meldung 👅
                                    • C Chaibi87
                                      P
                                      P
                                      Pittini
                                      #99
                                      Da ich eh grad an dem Skript rumbau, schau ich mal das ich das mit reinkrieg, da es tatsächlich Sinn macht.
                                      • P Pittini
                                        Dominik F.D
                                        Dominik F.D
                                        Dominik F.
                                        #100
                                        @Pittini
                                        Ich glaube ich konnte den Sinn dahinter einfach nicht richtig erklären :D Wenn wir im Garten arbeiten dann machen wir die Tür zu, jedoch bleibt der Drehgriff offen weil wir ja sonst nicht mehr ins Haus kommen. Wenn du keine Idee hast, dann werde ich wohl n zweiten Sensor an die Tür machen müssen und den in das Heizungsscript integrieren. War halt nur so schön einfach mit deinem Fensterscript ^^
                                          @Pittini
                                          P
                                          P
                                          Pittini
                                          #101
                                          Ok, jetzt versteh ich zwar den Sinn dahinter, was aber ja nix dran ändert dass das Skript nicht auf was reagieren kann was nicht gemeldet wird. Das wär dann ein Hellsehskript. Da wirste wohl um nen 2ten Sensor der den tatsächlichen Status und nicht den Griffstatus meldet nicht rumkommen.
                                          83.9k
