js-controller 3.0/3.1 jetzt im Latest!
seit dem update funktioniert der alexa controller nicht mehr hier ein ausschnitt aus dem log
Hey All,
nach Rückmeldungen, ein paar Sentry Reports und noch einigen Themen gibt es ab demnächst/in ein paar Stunden die 3.0.15 auf npm im Latest:
3.0.15 (2020-04-21) Release Elena
- (Apollon77) Adjust ID checking to allow numbers for non foreign id's for now but log warn
- (foxriver76/Apollon77) Adjust extendObject logic and only set state when state was not defined before
- (Apollon77) check that path is found before using it on rebuild CLI command (Sentry issue)
- (foxriver76) fix error on caught process exceptions
- (foxriver76) make sure that procs[id] is not undefined in some cases (Sentry IOBROKER-JS-CONTROLLER-E/G)
- (foxriver76/Apollon77) handle weird case where io-package.json from controller is not on normal place when getInstalledInfo is called (Sentry IOBROKER-JS-CONTROLLER-B/C/D/F/H)
- (foxriver76) fix bug for some cases where common.def is used on creation of foreign objects
- (Apollon77) make sure error cases are handled on zip file creation for objects (Sentry IOBROKER-JS-CONTROLLER-J)
3.0.15
iot.0 2020-04-22 10:06:37.366 warn the module (for instance, using `npm rebuild` or `npm install`). iot.0 2020-04-22 10:06:37.366 warn NODE_MODULE_VERSION 72. Please try re-compiling or re-installing iot.0 2020-04-22 10:06:37.366 warn NODE_MODULE_VERSION 64. This version of Node.js requires iot.0 2020-04-22 10:06:37.366 warn was compiled against a different Node.js version using iot.0 2020-04-22 10:06:37.366 warn (613) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'npm rebuild iot.0 habe ich schon gemacht
@Jan1 jap die kommt seh aber grad das nodejs version 14 angegeben wird obwohl bei
nodejs -v
v12.16.2
ich nehm mal nen backup und versuch das update noch einmal -
@Jan1 pi@TopZPi:~ $ node -v
v14.0.0
pi@TopZPi:~ $ nodejs -v
v12.16.2
pi@TopZPi:~ $ npm -v
6.14.4hmm ok wie bekomm ich das node nu wieder auf 12.16.2? D:
Hey All,
@apollon77
js-controller 3.0.15 und admin 4.0.9bei mir werden in der Adapter Übersicht keine installierten Instanzen mehr angezeigt und es gibt auch keinen Upload Pfeil
auch ohne Sternchen bleibt die Spalte installiert leer
@apollon77
@Jan1 sagte in js-controller 3.0 jetzt im Latest!:
@dslraser
3.0.15?
Gibts da schon wieder ein Update? -
@Kibbles
Du hast wohl im falschen Verzeichnis ein Node Update durchgeführt und nun zwei Node Versionen laufen. Versuch beide zu deinstallieren, bis gar keine mehr da ist und dann auf 12, 14 ist noch etwas zu früh. -
@Jan1 danke node komplett runtergeschmissen v12 neu intalliert das fix script laufen lassen und nun scheint alles zu funktionieren!
@apollon77
@dslraser sagte in js-controller 3.0 jetzt im Latest!:
@apollon77
Kann ich bestätigen, sobald man nach Adapter mit Instanzen filtert, bleibt die Liste leer.
@apollon77
@Jan1 Das liegt vermutlich daran das auch nicht angezeigt wird welche Insatnz installiert ist.
Zumindest bei mir ist die Spalte "Insatlliert" leer.@Chaot
@apollon77
Ja das ist bei mir auch der Fall, da scheint beim Adapter und Instanz Handling ein Bug drin zu sein, da ich selbst nach einem erfolgreichen Downgrade eines Adpters immer noch die alte Versionsnummer drinstehen habe.
Hier mal ein Beispiel mit dem iQontrol der bei mir in der aktuellen Version nicht läuft:$ ./iobroker upgrade iqontrol@0.3.1 Update iqontrol from @0.3.1 to @0.3.1 NPM version: 6.14.4 npm install iobroker.iqontrol@0.3.1 --loglevel error --prefix "/opt/iobroker" (System call) upload [20] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/img/materialize-colorpicker/alpha.png materialize-colorpicker/img/materialize-colorpicker/alpha.png image/png upload [19] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/img/materialize-colorpicker/alpha-horizontal.png materialize-colorpicker/img/materialize-colorpicker/alpha-horizontal.png image/png upload [18] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/css/materialize-colorpicker.min.css materialize-colorpicker/css/materialize-colorpicker.min.css text/css upload [17] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/materialize-colorpicker/css/materialize-colorpicker.css materialize-colorpicker/css/materialize-colorpicker.css text/css upload [16] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/jQueryIcons.jpg jQueryIcons.jpg image/jpeg upload [15] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/iqontrol.png iqontrol.png image/png upload [14] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/index_m.js index_m.js application/javascript upload [13] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/index_m.html index_m.html text/html upload [12] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/img/info-big.png img/info-big.png image/png upload [11] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_verdana.png fonts/font_verdana.png image/png upload [10] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_trebuchet.png fonts/font_trebuchet.png image/png upload [9] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_times.png fonts/font_times.png image/png upload [8] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_impact.png fonts/font_impact.png image/png upload [7] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_georgia.png fonts/font_georgia.png image/png upload [6] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_garamond.png fonts/font_garamond.png image/png upload [5] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_courier.png fonts/font_courier.png image/png upload [4] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_comic.png fonts/font_comic.png image/png upload [3] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fonts/font_arial.png fonts/font_arial.png image/png upload [2] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/custom_m.html custom_m.html text/html upload [450] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/userimages/usericons/inbuilt/light_on.png userimages/usericons/inbuilt/light_on.png image/png upload [1] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/conn.js conn.js application/javascript upload [0] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/admin.d.ts admin.d.ts video/mp2t upload [400] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/userimages/usericons/inbuilt/bell_off.png userimages/usericons/inbuilt/bell_off.png image/png upload [350] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-svg/power-white.svg jquery/images/icons-svg/power-white.svg image/svg+xml upload [300] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-svg/carat-d-white.svg jquery/images/icons-svg/carat-d-white.svg image/svg+xml upload [250] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-png/power-white.png jquery/images/icons-png/power-white.png image/png upload [200] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-png/carat-d-white.png jquery/images/icons-png/carat-d-white.png image/png upload [150] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/startup-images/iphonexr_splash.png images/startup-images/iphonexr_splash.png image/png upload [100] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/kitchenhood_on.png images/icons/kitchenhood_on.png image/png upload [90] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/indicator_grey.png images/icons/indicator_grey.png image/png upload [80] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/garagedoor_opened.png images/icons/garagedoor_opened.png image/png upload [70] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/fire_off.png images/icons/fire_off.png image/png upload [60] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/camera_ptz_on.png images/icons/camera_ptz_on.png image/png upload [50] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/blind_closed.png images/icons/blind_closed.png image/png upload [40] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/battery_50.png images/icons/battery_50.png image/png upload [30] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/hue.png images/hue.png image/png upload [20] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/config.png images/config.png image/png upload [19] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/colortemperature.png images/colortemperature.png image/png upload [18] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/color.png images/color.png image/png upload [17] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/brightness.png images/brightness.png image/png upload [16] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/battery.png images/battery.png image/png upload [15] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/background.png images/background.png image/png upload [14] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [13] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/ru/translations.json i18n/ru/translations.json application/json upload [12] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/pt/translations.json i18n/pt/translations.json application/json upload [11] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/pl/translations.json i18n/pl/translations.json application/json upload [10] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/nl/translations.json i18n/nl/translations.json application/json upload [9] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/it/translations.json i18n/it/translations.json application/json upload [8] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/es/translations.json i18n/es/translations.json application/json upload [6] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/en/translations.json i18n/en/translations.json application/json upload [5] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/de/translations.json i18n/de/translations.json application/json upload [4] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon_big.png favicon_big.png image/png upload [3] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon.png favicon.png image/png upload [2] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon.ico favicon.ico image/vnd.microsoft.icon upload [1] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/conn.js conn.js application/javascript upload [0] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/cache.manifest cache.manifest text/cache-manifest Update "system.adapter.iqontrol.0" Adapter "iqontrol" updated process exited with code 0steht aber noch so in der Übersicht:
Hab zwei mal ein Downgrade durchgeführt, weil ich dachte es hat nicht funktioniert. Man sieht aber im Log, dass schon die 0.3.1 drauf war ;-)
trotz des nicht aktuellen iQontrol sieht es auch so im info Addapter aus :
@apollon77
@dslraser
Das hatte ich heute morgen exakt genauso. Bin per Rollback schnell wieder auf 3.0.14 und alles wieder okay.
@dirk1962
wie hast das denn gemacht? Bei mir kommt das wenn ich es versuche:root@Beelink:~# cd /opt/iobroker root@Beelink:/opt/iobroker# iobroker status iobroker is not running on this host. No iobroker host is running. Objects type: file States type: file root@Beelink:/opt/iobroker# npm install iobroker.js-controller@version npm ERR! code ETARGET npm ERR! notarget No matching version found for iobroker.js-controller@version. npm ERR! notarget In most cases you or one of your dependencies are requesting npm ERR! notarget a package version that doesn't exist. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-04-22T09_53_15_432Z-debug.log root@Beelink:/opt/iobroker# root@Beelink:~# cd /opt/iobroker -bash: root@Beelink:~#: -
