  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 607.1k Aufrufe 89 Beobachtet
  • F Flugschüler
    Wie komme ich wieder zurück auf js 2.2.9?
    dslraserD Offline
    dslraserD Offline
    dslraser
    #107
    @Flugschüler
    npm install iobroker.js-controller@2.2.9
    • wendy2702W wendy2702
      Update von 3.0.13 nach 3.0.14.
      @apollon77 : Sayit upload hatte ich vorher gemacht. Jetzt kommt das:
      2020-04-21 20:58:15.785  - warn: readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.1 is not an object of type "meta"
      2020-04-21 20:58:15.809  - warn: readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.1 is not an object of type "meta"
      2020-04-21 20:58:15.812  - warn: readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.1 is not an object of type "meta"
      2020-04-21 20:58:15.813  - warn: readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.1 is not an object of type "meta"
      Und das hier beim Yamaha Adapter: (Sorry falls es schon erwähnt wurde)
      2020-04-21 20:59:08.020  - warn: yamaha.0 (32612) Object yamaha.0.Commands.volumeUp is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-04-21 20:59:08.020  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
      2020-04-21 20:59:08.022  - warn: yamaha.0 (32612) Object yamaha.0.Commands.volumeDown is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-04-21 20:59:08.022  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
      2020-04-21 20:59:08.023  - warn: yamaha.0 (32612) Object yamaha.0.Commands.adjustVolume is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-04-21 20:59:08.024  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
      2020-04-21 20:59:08.027  - warn: yamaha.0 (32612) Object yamaha.0.volume is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-04-21 20:59:08.027  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
      Issue für Yamaha: https://github.com/iobroker-community-adapters/ioBroker.yamaha-community/issues/14
      #108
      @wendy2702 sagte in js-controller 3.0 jetzt im Latest!:
      Ja da muss wohl im adapter noch was getan werden
      • JB_SullivanJ JB_Sullivan
        Nach dem Update auf 3.0.14 und Admin 4.0.9 habe ich jetzt einen bunten Strauß an Warn und Fehlermeldungen von verschiedenen Adaptern (vorher NULL Fehlermeldungen)
        tr-064.0	2020-04-21 21:35:37.299	error	(10884) Password error: Please re-enter the password in Admin. Stopping
        fritzbox.0	2020-04-21 21:35:41.038	warn	(6452) restartConnection: 10.IP.IP.
        fritzbox.0	2020-04-21 21:35:41.035	info	(6452) adapter connected to fritzbox: 10.IP.IP.
        innogy-smarthome.0	2020-04-21 21:37:02.227	debug	(8720) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
        innogy-smarthome.0	2020-04-21 21:37:02.202	info	(8720) Terminated (NO_ERROR): Without reason
        innogy-smarthome.0	2020-04-21 21:37:02.200	info	(8720) terminating
        innogy-smarthome.0	2020-04-21 21:37:02.192	debug	(8720) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
        innogy-smarthome.0	2020-04-21 21:37:02.188	error	at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
        innogy-smarthome.0	2020-04-21 21:37:02.188	error	(8720) Error: read ECONNRESET
        innogy-smarthome.0	2020-04-21 21:37:02.188	error	(8720) uncaught exception: read ECONNRESET
        Irgendwie hat man das Gefühl, das alles was mit FritzBox zu tun hat gerade kollabiert.
        tr-064.0	2020-04-21 21:49:03.583	warn	at process.topLevelDomainCallback (domain.js:126:23)
        tr-064.0	2020-04-21 21:49:03.583	warn	at processImmediate (timers.js:658:5)
        tr-064.0	2020-04-21 21:49:03.583	warn	at tryOnImmediate (timers.js:676:5)
        tr-064.0	2020-04-21 21:49:03.583	warn	at runCallback (timers.js:705:18)
        tr-064.0	2020-04-21 21:49:03.583	warn	at Immediate.setImmediate (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:234:41)
        tr-064.0	2020-04-21 21:49:03.583	warn	at change (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\adapter.js:5228:34)
        tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.EventEmitter.emit (domain.js:448:20)
        tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.emit (events.js:198:13)
        tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.adapter.on.obj (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:92:41)
        tr-064.0	2020-04-21 21:49:03.583	warn	at onMessage (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:255:25)
        tr-064.0	2020-04-21 21:49:03.583	warn	(3316) TypeError: Cannot read property 'forEachHostEntry' of undefined
        tr-064.0	2020-04-21 21:49:03.561	warn	(3316) States system pmessage io.messagebox.system.adapter.tr-064.0 {"command":"discovery","message":{"onlyActive":true,"reread":false},"from":"system.adapter.admin.0","callback":{"message":{"onlyAct
        tr-064.0	2020-04-21 21:48:58.819	error	(3316) Password error: Please re-enter the password in Admin. Stopping
        tr-064.0	2020-04-21 21:48:58.798	info	(3316) starting. Version 4.0.0 in C:/iobroker/GLT/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.0.14
        host.GLT	2020-04-21 21:48:56.999	info	instance system.adapter.tr-064.0 started with pid 3316
        host.GLT	2020-04-21 21:48:56.978	info	"system.adapter.tr-064.0" enabled
        #109
        @JB_Sullivan Am besten die Adapter stoppen, dann tr-064 mit Admin 4.0.9 das Passwort neu eingeben und neu speichern. und dann starten. Wenn der läuft dann die anderen nach und nach starten
        • F Flugschüler
          Hallo!
          bin noch neu hier im Forum
          bei mir kommt immer das und dann startet mein js adapter neu.
          Kann mir vieleicht irgend wer helfen?
          host.raspberrypi	2020-04-21 20:49:09.462	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
          host.raspberrypi	2020-04-21 20:49:09.462	error	Caught by controller[1]: Error: connect EHOSTUNREACH 192.168.1.140:22
          host.raspberrypi	2020-04-21 20:49:09.461	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
          #110
          @Flugschüler Hast du irgendein Skript was versucht sich irgendwo auf den SSH Port 22 zu verbinden? In dem Skript ist scheinbar keine Fehler gerscheit abgefangen und der Host 192.168.1.140ist nicht erreichbar
            @wendy2702 Na klar, alles kontrolliert und auch nochmal eingegeben - no way.
            FritzDect Adapter genau das gleiche - immer Passwort Fehler, aber das PW ist 100%ig richtig
            fritzdect.0	2020-04-21 21:56:02.467	error	(11792) Did not get session id- invalid username or password?
            fritzdect.0	2020-04-21 21:56:02.467	error	(11792) fritzbox returned this "0000000000000000"
            fritzdect.0	2020-04-21 21:56:00.477	info	(11792) SWITCH ID: 087610244490 identified for command (state) : true
            fritzdect.0	2020-04-21 21:55:46.252	error	(11792) Did not get session id- invalid username or password?
            fritzdect.0	2020-04-21 21:55:46.251	error	(11792) fritzbox returned this "0000000000000000"
            Das interessante daran ist, das alle Instanzen grün sind.
            #111
            @JB_Sullivan ggf. mal 10 mins aus lassen. Ich hatte solche Effekte auch als die FB überlastet war
            • F Flugschüler
              cd /opt/iobroker
              sudo iobroker stop
              sudo iobroker update
              sudo iobroker upgrade self
              sudo iobroker start
              Das hab ich gemacht hab jetzt js controller 3.0.14 und der startet andauernd neu.
              Ich glaube ich hab den Fehler gefunden.
              Habe ein Blockly das einen ssh Befehl sendet, wenn das ausgeführt wird startet der js controller neu, aber warum?
              Beim der Version 2.2.9 hats noch funktioniert.
              #112
              @Flugschüler sicher das der Controller neu startet? Da log würde ich gern komplett sehen! Oben sah es aus als ob nur der JavaScript Adapter neu startet!
              • F Flugschüler
                @wendy2702 Nicht ganz, ich brauche das Blockly um einen anderen Raspberry herunter zu fahren. Hat beim alten js ja funktioniert.
                #113
                @Flugschüler Die Meldung sagt aber EHOSTUNREACH" als der Host ist im Netzwerk nicht erreichbar! Und Fehlerbehandlung fehlt für genau solche Fälle
                • IccubeI Iccube
                  nach dem update auf 3.0.14 und Admin 4.0.9 habe ich folgende Warnmeldung
                  2020-04-21 22:22:10.934 - warn: writeFile will not write this file (/htmlinfo.html) in future versions: iqontrol.meta is not an object of type "meta"
                  2020-04-21 22:22:10.939 - warn: writeFile will not write this file (htmlinfo.html) in future versions: iqontrol.meta is not an object of type "meta"
                  Kann mir einer sagen was das heißt habe den iqontrol adapter nicht installiert
                  #114
                  @Iccube mach mal ein "iobroker ipload iqontrol"
                  Elektroniker86E 1 Antwort Letzte Antwort
                    @BBTown
                    Ich habe jetzt den ganzen PC (win10) auf dem ioB läuft nochmal komplett neu gestartet - ich lasse mich überraschen.
                    Gut - die Fehler oben sind jetzt weg - aber alles was FritzBox Adapter betrifft funktioniert noch immer nicht.
                    Lt. Fritzbox log kommt in der Tat vom ioBroker PC eine (bzw. dutzenden) Anfragen mit falschem Passwort. Das PW ist aber zu 100% richtig was ich verwende, dafür lege ich meine Hand ins Feuer.
                    Was für Passwort Anfragen sendet denn ALLE Adapter die mit etwas mit der Fritte zu tun haben wollen?
                    #115
                    @JB_Sullivan mach doch mal alle aus die zur Fritte verbinden. Starte einen und seh was bei der Fritzbox ankommt. Dann findest DU raus welcher es ist. Versuche beidem das Passwort im Admin neu einzugeben und zu speichern. Sag mal wer schult ist dann schau ich mal rein
                    • M miggedy
                      Habe von nodejs 10 auf 12 geupdated (wie gewünscht) ohne rebuild. Alle Adapter funktionierten nach einem einfachen iobroker start außer der BLE adapter der folgende Fehler zeigte:
                      ble.0	2020-04-21 22:12:58.582	error	(31045) unhandled promise rejection: TypeError: Cannot read property 'on' of undefined
                      ble.0	2020-04-21 22:12:58.580	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      ble.0	2020-04-21 22:12:58.580	error	at fulfilled (/opt/iobroker/node_modules/iobroker.ble/build/main.js:5:58)
                      ble.0	2020-04-21 22:12:58.580	error	at Generator.next (<anonymous>)
                      ble.0	2020-04-21 22:12:58.580	error	at /opt/iobroker/node_modules/iobroker.ble/build/main.js:97:19
                      ble.0	2020-04-21 22:12:58.580	error	(31045) TypeError: Cannot read property 'on' of undefined
                      ble.0	2020-04-21 22:12:58.579	error	(31045) uncaught exception: Cannot read property 'on' of undefined
                      ble.0	2020-04-21 22:12:58.574	error	the module (for instance, using `npm rebuild` or `npm install`).
                      ble.0	2020-04-21 22:12:58.574	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                      ble.0	2020-04-21 22:12:58.574	error	NODE_MODULE_VERSION 64. This version of Node.js requires
                      ble.0	2020-04-21 22:12:58.574	error	was compiled against a different Node.js version using
                      ble.0	2020-04-21 22:12:58.574	error	(31045) Terminating because The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
                      iobroker rebuild ble behob das Problem nicht, iobroker rebuild ble --install tat es allerdings. Ist dies etwas was an den js-controller berichtet werden sollte (zur Verbessrung des neuen auto-rebuild) oder ein Problem im BLE Adapter?
                      #116
                      @miggedy Am Ende siehe erster Post. Einige Adapter fangen das ab ... dann muss man manuell rebuilden
                      F 1 Antwort Letzte Antwort
                      • apollon77A apollon77
                        Flugschüler
                        #117
                        @apollon77 Ja der Java script Adapter startet ca. alle 2 Minuten neu.
                        • F Flugschüler
                          #118
                          @Flugschüler Dann finde mal raus warum der Host da nicht erreichbar ist. Kannst DU "ping IP" machen? und am Ende Fehlt die ein "try/catch Fehlerbehandlung um so einen Fehler abzusichern (wäre aber Thema für einen anderen thread)
                          • apollon77A Offline
                            #119
                            Hey All,
                            nach Rückmeldungen, ein paar Sentry Reports und noch einigen Themen gibt es ab demnächst/in ein paar Stunden die 3.0.15 auf npm im Latest:
                            3.0.15 (2020-04-21) Release Elena
                            • (Apollon77) Adjust ID checking to allow numbers for non foreign id's for now but log warn
                            • (foxriver76/Apollon77) Adjust extendObject logic and only set state when state was not defined before
                            • (Apollon77) check that path is found before using it on rebuild CLI command (Sentry issue)
                            • (foxriver76) fix error on caught process exceptions
                            • (foxriver76) make sure that procs[id] is not undefined in some cases (Sentry IOBROKER-JS-CONTROLLER-E/G)
                            • (foxriver76/Apollon77) handle weird case where io-package.json from controller is not on normal place when getInstalledInfo is called (Sentry IOBROKER-JS-CONTROLLER-B/C/D/F/H)
                            • (foxriver76) fix bug for some cases where common.def is used on creation of foreign objects
                            • (Apollon77) make sure error cases are handled on zip file creation for objects (Sentry IOBROKER-JS-CONTROLLER-J)
                            BBTownB dslraserD 3 Antworten Letzte Antwort
                              Flugschüler
                              #120
                              @apollon77 Der Host ist nicht ereichbar weil der 2. Raspberry ausgeschaltet war. Ist aber egal denn sobald ich des Skript ausführe Startet der Java script Adapter neu.
                              • F Flugschüler
                                #121
                                @Flugschüler Ja weil der Fehler nicht abgefangen wird und in dem Zuge das einen harten crash im Nodejs verursacht.Da kann der js adapter nix für ;-) Dein Skript ist nicht dazu ausgelegt um mit Fehlerfällen umzugehen
                                • F Offline
                                  Flugschüler
                                  #122
                                  Und warum funktioniert es mit dem js 2.2.9 ? Ohne Fehler?
                                  • F Flugschüler
                                    #123
                                    @Flugschüler Es gibt jetzt einen speziellen Fehlertyp der bisher (unabsichtlicher weise) nicht beachtet wurde und dazu geführt hat das teilweise Adapter einfach so hä ngen geblieben sindDIese Fehlertypen verursachen ab Nodejs 14 eh einen harten crash. Daher haben wir entschieden das jetzt ebenso schon so zu behandeln
                                      Hey All,
                                      BBTownB Offline
                                      BBTownB Offline
                                      BBTown
                                      #124
                                      @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                                      ist bei mir sauber druchgelaufen und macht offensichtlich was es soll 👍
                                        Flugschüler
                                        #125
                                        @apollon77 node_ssh = require('node-ssh');
                                        ssh = new node_ssh();
                                        ssh.connect({
                                        host: '192.168.1.140',
                                        username: 'pi',
                                        password: '*********'
                                        }).then(() => {
                                        ssh.execCommand("sudo shutdown -h now");
                                        Ist bei meinem Script was falsch? Hat eigentlich immer funktioniert.
                                        • F Flugschüler
                                          ssh.connect({
                                          username: 'pi',
                                          }).then(() => {
                                          #126
                                          @Flugschüler Ja es ist kein
                                          .catch(err => { //Fehlerhandling})
                                          am Ende dran. Daher wandert ein Fehler als "Unhandled Promise Rejection" in den Prozess und damit starte der Adapter neu
