  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • V Voltage
    Eben noch mal das Thema override direkt am Thermostat versucht - hier mal ein Debug von mir, hoffe es hilft dir so weiter
    heatingcontrol.0 2020-04-11 09:07:00.591 info (31476) set thermostat hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE to 19; current is 18.5
    heatingcontrol.0 2020-04-11 09:07:00.273 info (31476) set thermostat hm-rpc.2.000A1709A64260.1.SET_POINT_TEMPERATURE to 20; current is 19
    heatingcontrol.0 2020-04-11 09:07:00.200 warn (31476) override temperature not valid: 0
    heatingcontrol.0 2020-04-11 09:07:00.155 info (31476) change temperature override for room Wohnzimmer
    heatingcontrol.0 2020-04-11 09:07:00.143 info (31476) ### Rooms.Wohnzimmer.TemperaturOverride
    heatingcontrol.0 2020-04-11 09:07:00.061 info (31476) Stop Temperatur Override Wohnzimmer
    heatingcontrol.0 2020-04-11 09:05:27.853 info (31476) set thermostat hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE to 18; current is 19.5
    heatingcontrol.0 2020-04-11 09:05:27.847 info (31476) room Wohnzimmer Thermostat Wohnzimmer 1.SET_POINT_TEMPERATURE set to 18
    heatingcontrol.0 2020-04-11 09:05:27.781 info (31476) change temperature override for room Wohnzimmer
    heatingcontrol.0 2020-04-11 09:05:09.025 info (31476) set thermostat hm-rpc.2.000A1709A646C1.1.SET_POINT_TEMPERATURE to 18; current is 19.5
    heatingcontrol.0 2020-04-11 09:05:09.019 info (31476) room Flur Thermostat Flur 1.SET_POINT_TEMPERATURE set to 18
    heatingcontrol.0 2020-04-11 09:05:08.954 info (31476) change temperature override for room Flur
    heatingcontrol.0 2020-04-11 09:00:41.497 warn (31476) override temperature not valid: 0
    heatingcontrol.0 2020-04-11 09:00:41.492 info (31476) change temperature override for room Wohnzimmer
    heatingcontrol.0 2020-04-11 09:00:41.485 warn (31476) override temperature not valid: 0
    heatingcontrol.0 2020-04-11 09:00:41.479 info (31476) change temperature override for room Wohnzimmer
    heatingcontrol.0 2020-04-11 09:00:32.681 warn (31476) override temperature not valid: 0
    heatingcontrol.0 2020-04-11 09:00:32.673 info (31476) change temperature override for room Flur
    heatingcontrol.0 2020-04-11 08:59:59.480 info (31476) set thermostat hm-rpc.2.000A1709A646C1.1.SET_POINT_TEMPERATURE to 19; current is 17
    heatingcontrol.0 2020-04-11 08:59:59.242 info (31476) set thermostat hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE to 19; current is 17
    heatingcontrol.0 2020-04-11 08:59:58.997 info (31476) set thermostat hm-rpc.2.000A1709A64260.1.SET_POINT_TEMPERATURE to 20; current is 17
    heatingcontrol.0 2020-04-11 08:59:45.129 info (31476) set thermostat hm-rpc.2.000A1709A646C1.1.SET_POINT_TEMPERATURE to 17; current is 19
    heatingcontrol.0 2020-04-11 08:59:45.122 info (31476) setting to reduced/increased temperature in Flur to 17
    heatingcontrol.0 2020-04-11 08:59:44.893 info (31476) set thermostat hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE to 17; current is 19
    heatingcontrol.0 2020-04-11 08:59:44.885 info (31476) setting to reduced/increased temperature in Wohnzimmer to 17
    heatingcontrol.0 2020-04-11 08:59:44.657 info (31476) set thermostat hm-rpc.2.000A1709A64260.1.SET_POINT_TEMPERATURE to 17; current is 20
    heatingcontrol.0 2020-04-11 08:59:44.649 info (31476) setting to reduced/increased temperature in Esszimmer to 17
    heatingcontrol.0 2020-04-11 08:59:40.412 info (31476) subscribe Wohnzimmer hm-rpc.1.NEQ1483063.1.STATE
    heatingcontrol.0 2020-04-11 08:59:40.408 info (31476) subscribe Esszimmer hm-rpc.2.0000D7099A7A99.1.STATE
    heatingcontrol.0 2020-04-11 08:59:40.404 info (31476) subscribe radar2.0.Sven._here
    heatingcontrol.0 2020-04-11 08:59:40.401 info (31476) subscribe Feiertage.0.heute.boolean
    heatingcontrol.0 2020-04-11 08:59:40.097 info (31476) set thermostat hm-rpc.2.000A1709A646C1.1.SET_POINT_TEMPERATURE to 19; current is 18
    heatingcontrol.0 2020-04-11 08:59:39.869 info (31476) set thermostat hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE to 19; current is 17.5
    heatingcontrol.0 2020-04-11 08:59:39.640 info (31476) set thermostat hm-rpc.2.000A1709A64260.1.SET_POINT_TEMPERATURE to 20; current is 18
    heatingcontrol.0 2020-04-11 08:59:39.520 info (31476) external states checked, done
    heatingcontrol.0 2020-04-11 08:59:39.508 info (31476) setting Present to true
    heatingcontrol.0 2020-04-11 08:59:39.498 info (31476) checking all external states
    heatingcontrol.0 2020-04-11 08:59:37.192 info (31476) starting. Version 0.3.19 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v10.16.0
    Was mir aufgefallen ist, dass er unter "objekte" den "State" nicht von normal auf override setzt, aber ist vermutlich bekannt und recht kompliziert. Danke für die Mühe
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #1010
    @Voltage in der 0.4.0 wird das Feature integriert sein. Bin derzeit noch am testen... In der 0.3.19 (d.h. master branch im github) sind die notwendigen Änderungen noch nicht drin. Im Moment müsstest du die 0.4.0 aus dem branch V0.4 installieren.
    • C Offline
      CaptainBalou
      #1011
      Hallo zusammen, gibt es ein HowTo wie man den Debug Mode für den Adapter aktiviert um Logs zu generieren? Ich bin noch recht neu bei iobroker und heatingcontrol.
      G 1 Antwort Letzte Antwort
      • C CaptainBalou
        guergen
        #1012
        @CaptainBalou Expertenmodus und dann dort:
        C 1 Antwort Letzte Antwort
        • G Offline
          guergen
          #1013
          Was hat es denn jetzt damit auf sich:
          Warum steht dieser Wert schon wieder auf 0, hatte ihn auf 5 eingestellt?
          Gibt es für den Wert auch irgendwo einen DP? Hab keinen gefunden....
          Rene_HMR 1 Antwort Letzte Antwort
          • G guergen
            Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #1014
            @guergen das sind zwei features:
            1. es gibt pro Raum eine Minumum-Temperatur. Die ist für jeden Raum per DP einstellbar. (wie oben markiert). Wenn durch Absenkung diese Minimum-Temperatur unterschritten wird, wird die Zieltemperatur auf diesen Wert gesetzt.
            2. wenn keine Heizperiode vorliegt, gibt es die Möglchkeit
              2.1) für alle Räume eine Zieltemperatur vorzugeben. Diese Temperatur ist im admin eingestellt und hat keinen DP
              2.2.) für jeden Raum separat eine Zieltemperatur einzustellen. Dafür wird dann eine Zieltemperatur als DP angelegt
              2.3) oder gar nichts machen
            • G guergen
              CaptainBalou
              #1015
              Danke @guergen hat prima geklappt!
              • Rene_HMR Rene_HM
                guergen
                #1016
                @Rene_HM Ja, hatte ich wohl gefunden...
                Den 1. Kannte ich ja schon
                2.1 war halt nur eine Frage
                Das unsubscribe hatte mich gewundert...
                Jetzt habe ich vorhin au f JS-controller 3.xx upgedatet und die zwei-Fenster-Option mit mehreren Thermostaten geht schon wieder nicht mehr....
                heatingcontrol.0	2020-04-19 12:03:11.639	debug	(20299) thermostat maxcul.0.KEQ0346189.desiredTemperature nothing to do, already 15
                heatingcontrol.0	2020-04-19 12:03:11.597	debug	(20299) got {"val":5,"ack":false,"ts":1577548968524,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1577548968524}
                heatingcontrol.0	2020-04-19 12:03:11.595	debug	(20299) checking min temp with Rooms.Toilette.MinimumTemperature
                heatingcontrol.0	2020-04-19 12:03:11.595	debug	(20299) room Toilette Thermostat Thermostat KEQ0346189 set temperature target is 15
                heatingcontrol.0	2020-04-19 12:03:11.595	debug	(20299) room Toilette setting new target 15
                heatingcontrol.0	2020-04-19 12:03:11.594	info	(20299) unsubscribe Schlafzimmer maxcul.0.KEQ0335101.desiredTemperature
                heatingcontrol.0	2020-04-19 12:03:11.594	info	(20299) unsubscribe Toilette maxcul.0.KEQ0346189.desiredTemperature
                heatingcontrol.0	2020-04-19 12:03:11.594	info	(20299) unsubscribe Küche maxcul.0.KEQ0340391.desiredTemperature
                heatingcontrol.0	2020-04-19 12:03:11.594	info	(20299) unsubscribe Bad maxcul.0.KEQ0334837.desiredTemperature
                heatingcontrol.0	2020-04-19 12:03:11.593	info	(20299) unsubscribe Kaminzimmer maxcul.0.KEQ0340448.desiredTemperature
                heatingcontrol.0	2020-04-19 12:03:11.593	info	(20299) unsubscribe Wohnzimmer maxcul.0.KEQ0340464.desiredTemperature
                heatingcontrol.0	2020-04-19 12:03:11.593	debug	(20299) need to unsubscribe states
                heatingcontrol.0	2020-04-19 12:03:11.593	debug	(20299) ### new target temp 15 0 0 0 0 0
                heatingcontrol.0	2020-04-19 12:03:11.592	debug	(20299) ### current > 1 1 1
                heatingcontrol.0	2020-04-19 12:03:11.591	debug	(20299) Toilette found period 1 with 15 on 07,00
                heatingcontrol.0	2020-04-19 12:03:11.590	debug	(20299) ### set ActiveTimeSlot to 25 period 1
                heatingcontrol.0	2020-04-19 12:03:11.589	debug	(20299) check ID Profiles.0.Toilette.Sun.Periods.3.time period 3
                heatingcontrol.0	2020-04-19 12:03:11.588	debug	(20299) check ID Profiles.0.Toilette.Sun.Periods.2.time period 2
                heatingcontrol.0	2020-04-19 12:03:11.587	debug	(20299) check time for Toilette Profiles.0.Toilette.Sun.Periods.1.time 15
                heatingcontrol.0	2020-04-19 12:03:11.544	debug	(20299) check ID Profiles.0.Toilette.Sun.Periods.1.time period 1
                heatingcontrol.0	2020-04-19 12:03:11.543	debug	(20299) check time for Toilette Profiles.0.Toilette.Sun.Periods.0.time 15
                heatingcontrol.0	2020-04-19 12:03:11.495	debug	(20299) check ID Profiles.0.Toilette.Sun.Periods.0.time period 0
                heatingcontrol.0	2020-04-19 12:03:11.495	debug	(20299) ### set ActiveTimeSlot to 24
                heatingcontrol.0	2020-04-19 12:03:11.494	debug	(20299) FindNextPeriod for 2020-4-19 12:03:11 PM in Toilette
                heatingcontrol.0	2020-04-19 12:03:11.494	debug	(20299) relative GuestIncrease {"val":0,"ack":true,"ts":1577550099031,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577548489229}
                heatingcontrol.0	2020-04-19 12:03:11.493	debug	(20299) relative AbsentDecrease {"val":0,"ack":true,"ts":1577550097867,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577548489265}
                heatingcontrol.0	2020-04-19 12:03:11.491	debug	(20299) relative PartyDecrease {"val":0,"ack":true,"ts":1577548489244,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577548489244}
                heatingcontrol.0	2020-04-19 12:03:11.490	debug	(20299) relative VacationAbsentDecrease {"val":0,"ack":true,"ts":1577548489275,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577548489275}
                heatingcontrol.0	2020-04-19 12:03:11.489	debug	(20299) relative WindowOpenDecrease {"val":20,"ack":true,"ts":1578570839286,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578570837006}
                heatingcontrol.0	2020-04-19 12:03:11.488	debug	(20299) Toilette window open is false
                heatingcontrol.0	2020-04-19 12:03:11.488	debug	(20299) check room Toilette
                heatingcontrol.0	2020-04-19 12:03:11.488	debug	(20299) profile 0
                heatingcontrol.0	2020-04-19 12:03:11.481	debug	(20299) get profile
                heatingcontrol.0	2020-04-19 12:03:11.481	debug	(20299) profile type 3
                heatingcontrol.0	2020-04-19 12:03:11.389	debug	(20299) ### not handled maxcul.0.JEQ0512273.isOpen {"val":false,"ack":true,"ts":1587290591331,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1581529664716}
                heatingcontrol.0	2020-04-19 12:03:11.388	debug	(20299) ### 222 not handled yet
                heatingcontrol.0	2020-04-19 12:03:11.388	debug	(20299) calculating new target temperatures
                heatingcontrol.0	2020-04-19 12:03:11.388	debug	(20299) room to check is Toilette
                heatingcontrol.0	2020-04-19 12:03:11.341	debug	(20299) Toilette window open is false
                heatingcontrol.0	2020-04-19 12:03:11.341	debug	(20299) got sensor state {"val":false,"ack":true,"ts":1587290591331,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1581529664716} from maxcul.0.JEQ0512273.isOpen
                heatingcontrol.0	2020-04-19 12:03:11.337	debug	(20299) Check sensors for Toilette
                heatingcontrol.0	2020-04-19 12:03:11.336	debug	(20299) ### handle devices [{"id":12,"name":"Contact JEQ0512273 opened","OID_Current":"maxcul.0.JEQ0512273.isOpen","isActive":true,"type":3,"room":"Toilette"}]
                heatingcontrol.0	2020-04-19 12:03:11.336	debug	(20299) handle id maxcul.0.JEQ0512273.isOpen state {"val":false,"ack":true,"ts":1587290591331,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1581529664716}
                heatingcontrol.0	2020-04-19 12:03:11.336	debug	(20299) ### 111 not handled yet
                heatingcontrol.0	2020-04-19 12:03:11.336	debug	(20299) ### maxcul.0.JEQ0512273.isOpen maxcul.0.JEQ0161176.isOpen false true
                heatingcontrol.0	2020-04-19 12:03:11.335	debug	(20299) ### handle state change maxcul.0.JEQ0512273.isOpen {"val":false,"ack":true,"ts":1587290591331,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1581529664716}
                heatingcontrol.0	2020-04-19 12:02:23.168	debug	(20299) need to subscribe states now
                heatingcontrol.0	2020-04-19 12:02:13.556	info	(20299) 91 cron jobs created
                heatingcontrol.0	2020-04-19 12:02:13.555	debug	(20299) [INFO] status = true next event: 19 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.555	debug	(20299) [INFO] status = true next event: 25 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.554	debug	(20299) [INFO] status = true next event: 24 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.554	debug	(20299) [INFO] status = true next event: 23 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.553	debug	(20299) [INFO] status = true next event: 22 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.552	debug	(20299) [INFO] status = true next event: 21 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.551	debug	(20299) [INFO] status = true next event: 20 Apr 2020 18:00:00
                heatingcontrol.0	2020-04-19 12:02:13.550	debug	(20299) [INFO] status = true next event: 26 Apr 2020 10:00:00
                heatingcontrol.0	2020-04-19 12:02:13.549	debug	(20299) [INFO] status = true next event: 25 Apr 2020 10:00:00
                heatingcontrol.0	2020-04-19 12:02:13.548	debug	(20299) [INFO] status = true next event: 19 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.547	debug	(20299) [INFO] status = true next event: 26 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.545	debug	(20299) [INFO] status = true next event: 25 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.544	debug	(20299) [INFO] status = true next event: 25 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.543	debug	(20299) [INFO] status = true next event: 25 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.542	debug	(20299) [INFO] status = true next event: 24 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.541	debug	(20299) [INFO] status = true next event: 24 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.539	debug	(20299) [INFO] status = true next event: 24 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.538	debug	(20299) [INFO] status = true next event: 24 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.538	debug	(20299) [INFO] status = true next event: 23 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.537	debug	(20299) [INFO] status = true next event: 23 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.537	debug	(20299) [INFO] status = true next event: 23 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.536	debug	(20299) [INFO] status = true next event: 23 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.536	debug	(20299) [INFO] status = true next event: 22 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.535	debug	(20299) [INFO] status = true next event: 22 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.534	debug	(20299) [INFO] status = true next event: 22 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.534	debug	(20299) [INFO] status = true next event: 22 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.533	debug	(20299) [INFO] status = true next event: 21 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.532	debug	(20299) [INFO] status = true next event: 21 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.532	debug	(20299) [INFO] status = true next event: 21 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.531	debug	(20299) [INFO] status = true next event: 21 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.531	debug	(20299) [INFO] status = true next event: 20 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.530	debug	(20299) [INFO] status = true next event: 20 Apr 2020 19:00:00
                heatingcontrol.0	2020-04-19 12:02:13.529	debug	(20299) [INFO] status = true next event: 20 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.529	debug	(20299) [INFO] status = true next event: 20 Apr 2020 05:00:00
                heatingcontrol.0	2020-04-19 12:02:13.529	debug	(20299) [INFO] status = true next event: 19 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.528	debug	(20299) [INFO] status = true next event: 26 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.528	debug	(20299) [INFO] status = true next event: 26 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.527	debug	(20299) [INFO] status = true next event: 25 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.526	debug	(20299) [INFO] status = true next event: 25 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.525	debug	(20299) [INFO] status = true next event: 25 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.525	debug	(20299) [INFO] status = true next event: 25 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.525	debug	(20299) [INFO] status = true next event: 19 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.524	debug	(20299) [INFO] status = true next event: 19 Apr 2020 15:00:00
                heatingcontrol.0	2020-04-19 12:02:13.524	debug	(20299) [INFO] status = true next event: 26 Apr 2020 11:00:00
                heatingcontrol.0	2020-04-19 12:02:13.522	debug	(20299) [INFO] status = true next event: 25 Apr 2020 15:00:00
                heatingcontrol.0	2020-04-19 12:02:13.521	debug	(20299) [INFO] status = true next event: 25 Apr 2020 09:09:00
                heatingcontrol.0	2020-04-19 12:02:13.520	debug	(20299) [INFO] status = true next event: 24 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.519	debug	(20299) [INFO] status = true next event: 24 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.518	debug	(20299) [INFO] status = true next event: 24 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.516	debug	(20299) [INFO] status = true next event: 23 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.515	debug	(20299) [INFO] status = true next event: 23 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.514	debug	(20299) [INFO] status = true next event: 23 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.513	debug	(20299) [INFO] status = true next event: 22 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.512	debug	(20299) [INFO] status = true next event: 22 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.510	debug	(20299) [INFO] status = true next event: 22 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.508	debug	(20299) [INFO] status = true next event: 21 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.507	debug	(20299) [INFO] status = true next event: 21 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.506	debug	(20299) [INFO] status = true next event: 21 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.505	debug	(20299) [INFO] status = true next event: 20 Apr 2020 20:00:00
                heatingcontrol.0	2020-04-19 12:02:13.502	debug	(20299) [INFO] status = true next event: 20 Apr 2020 17:00:00
                heatingcontrol.0	2020-04-19 12:02:13.502	debug	(20299) [INFO] status = true next event: 20 Apr 2020 07:00:00
                heatingcontrol.0	2020-04-19 12:02:13.501	debug	(20299) [INFO] status = true next event: 19 Apr 2020 22:00:00
                heatingcontrol.0	2020-04-19 12:02:13.501	debug	(20299) [INFO] status = true next event: 19 Apr 2020 16:00:00
                heatingcontrol.0	2020-04-19 12:02:13.501	debug	(20299) [INFO] status = true next event: 26 Apr 2020 12:00:00
                heatingcontrol.0	2020-04-19 12:02:13.499	debug	(20299) [INFO] status = true next event: 26 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.498	debug	(20299) [INFO] status = true next event: 25 Apr 2020 23:00:00
                heatingcontrol.0	2020-04-19 12:02:13.497	debug	(20299) [INFO] status = true next event: 25 Apr 2020 16:00:00
                heatingcontrol.0	2020-04-19 12:02:13.497	debug	(20299) [INFO] status = true next event: 25 Apr 2020 12:00:00
                heatingcontrol.0	2020-04-19 12:02:13.496	debug	(20299) [INFO] status = true next event: 25 Apr 2020 08:00:00
                heatingcontrol.0	2020-04-19 12:02:13.496	debug	(20299) [INFO] status = true next event: 24 Apr 2020 23:00:00
                heatingcontrol.0	2020-04-19 12:02:13.495	debug	(20299) [INFO] status = true next event: 24 Apr 2020 13:00:00
                heatingcontrol.0	2020-04-19 12:02:13.483	debug	(20299) [INFO] status = true next event: 24 Apr 2020 07:15:00
                heatingcontrol.0	2020-04-19 12:02:13.482	debug	(20299) [INFO] status = true next event: 24 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.481	debug	(20299) [INFO] status = true next event: 23 Apr 2020 23:00:00
                heatingcontrol.0	2020-04-19 12:02:13.480	debug	(20299) [INFO] status = true next event: 23 Apr 2020 16:00:00
                heatingcontrol.0	2020-04-19 12:02:13.480	debug	(20299) [INFO] status = true next event: 23 Apr 2020 07:15:00
                heatingcontrol.0	2020-04-19 12:02:13.479	debug	(20299) [INFO] status = true next event: 23 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.479	debug	(20299) [INFO] status = true next event: 22 Apr 2020 23:00:00
                heatingcontrol.0	2020-04-19 12:02:13.478	debug	(20299) [INFO] status = true next event: 22 Apr 2020 16:00:00
                heatingcontrol.0	2020-04-19 12:02:13.477	debug	(20299) [INFO] status = true next event: 22 Apr 2020 07:15:00
                heatingcontrol.0	2020-04-19 12:02:13.477	debug	(20299) [INFO] status = true next event: 22 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.476	debug	(20299) [INFO] status = true next event: 21 Apr 2020 23:00:00
                heatingcontrol.0	2020-04-19 12:02:13.475	debug	(20299) [INFO] status = true next event: 21 Apr 2020 16:00:00
                heatingcontrol.0	2020-04-19 12:02:13.475	debug	(20299) [INFO] status = true next event: 21 Apr 2020 07:15:00
                heatingcontrol.0	2020-04-19 12:02:13.474	debug	(20299) [INFO] status = true next event: 21 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.474	debug	(20299) [INFO] status = true next event: 20 Apr 2020 23:00:00
                heatingcontrol.0	2020-04-19 12:02:13.473	debug	(20299) [INFO] status = true next event: 20 Apr 2020 16:00:00
                heatingcontrol.0	2020-04-19 12:02:13.472	debug	(20299) [INFO] status = true next event: 20 Apr 2020 07:15:00
                heatingcontrol.0	2020-04-19 12:02:13.472	debug	(20299) [INFO] status = true next event: 20 Apr 2020 06:00:00
                heatingcontrol.0	2020-04-19 12:02:13.471	debug	(20299) [INFO] status = true next event: 24 Apr 2020 23:55:00
                heatingcontrol.0	2020-04-19 12:02:13.470	debug	(20299) [INFO] status = true next event: 1 Oct 2020 00:05:00
                heatingcontrol.0	2020-04-19 12:02:13.218	info	(20299) set thermostat maxcul.0.KEQ0340464.desiredTemperature to 5; current is 20
                heatingcontrol.0	2020-04-19 12:02:13.170	info	(20299) target 0 lower then minimum 5 : setting to min
                heatingcontrol.0	2020-04-19 12:02:13.170	debug	(20299) got {"val":5,"ack":false,"ts":1577548975275,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1577548975275}
                heatingcontrol.0	2020-04-19 12:02:13.168	debug	(20299) checking min temp with Rooms.Wohnzimmer.MinimumTemperature
                heatingcontrol.0	2020-04-19 12:02:13.168	debug	(20299) room Wohnzimmer Thermostat Thermostat KEQ0340464 set temperature target is 0
                heatingcontrol.0	2020-04-19 12:02:13.168	debug	(20299) room Wohnzimmer setting new target 0
                heatingcontrol.0	2020-04-19 12:02:13.168	info	(20299) unsubscribe Schlafzimmer maxcul.0.KEQ0335101.desiredTemperature
                heatingcontrol.0	2020-04-19 12:02:13.167	info	(20299) unsubscribe Toilette maxcul.0.KEQ0346189.desiredTemperature
                heatingcontrol.0	2020-04-19 12:02:13.167	info	(20299) unsubscribe Küche maxcul.0.KEQ0340391.desiredTemperature
                heatingcontrol.0	2020-04-19 12:02:13.167	info	(20299) unsubscribe Bad maxcul.0.KEQ0334837.desiredTemperature
                heatingcontrol.0	2020-04-19 12:02:13.167	info	(20299) unsubscribe Kaminzimmer maxcul.0.KEQ0340448.desiredTemperature
                heatingcontrol.0	2020-04-19 12:02:13.166	info	(20299) unsubscribe Wohnzimmer maxcul.0.KEQ0340464.desiredTemperature
                heatingcontrol.0	2020-04-19 12:02:13.166	debug	(20299) need to unsubscribe states
                heatingcontrol.0	2020-04-19 12:02:13.166	debug	(20299) ### new target temp 20 0 0 0 0 20
                heatingcontrol.0	2020-04-19 12:02:13.166	debug	(20299) ### current > 1 1 1
                heatingcontrol.0	2020-04-19 12:02:13.166	debug	(20299) Wohnzimmer found period 1 with 20 on 12,00
                heatingcontrol.0	2020-04-19 12:02:13.166	debug	(20299) ### set ActiveTimeSlot to 25 period 1
                heatingcontrol.0	2020-04-19 12:02:13.165	debug	(20299) check ID Profiles.0.Wohnzimmer.Sun.Periods.3.time period 3
                heatingcontrol.0	2020-04-19 12:02:13.160	debug	(20299) check ID Profiles.0.Wohnzimmer.Sun.Periods.2.time period 2
                heatingcontrol.0	2020-04-19 12:02:13.159	debug	(20299) check time for Wohnzimmer Profiles.0.Wohnzimmer.Sun.Periods.1.time 20
                heatingcontrol.0	2020-04-19 12:02:13.116	debug	(20299) check ID Profiles.0.Wohnzimmer.Sun.Periods.1.time period 1
                heatingcontrol.0	2020-04-19 12:02:13.115	debug	(20299) check time for Wohnzimmer Profiles.0.Wohnzimmer.Sun.Periods.0.time 18
                heatingcontrol.0	2020-04-19 12:02:13.021	debug	(20299) check ID Profiles.0.Wohnzimmer.Sun.Periods.0.time period 0
                heatingcontrol.0	2020-04-19 12:02:13.021	debug	(20299) ### set ActiveTimeSlot to 24
                heatingcontrol.0	2020-04-19 12:02:13.021	debug	(20299) FindNextPeriod for 2020-4-19 12:02:12 PM in Wohnzimmer
                heatingcontrol.0	2020-04-19 12:02:13.020	debug	(20299) use window open decrease
                heatingcontrol.0	2020-04-19 12:02:13.020	debug	(20299) relative GuestIncrease {"val":2,"ack":true,"ts":1577816488017,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577816488013}
                heatingcontrol.0	2020-04-19 12:02:12.974	debug	(20299) relative AbsentDecrease {"val":2,"ack":true,"ts":1586838339158,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1586838339155}
                heatingcontrol.0	2020-04-19 12:02:12.973	debug	(20299) relative PartyDecrease {"val":0,"ack":true,"ts":1577548489019,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577548489019}
                heatingcontrol.0	2020-04-19 12:02:12.972	debug	(20299) relative VacationAbsentDecrease {"val":0,"ack":true,"ts":1577548489032,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577548489032}
                heatingcontrol.0	2020-04-19 12:02:12.929	debug	(20299) relative WindowOpenDecrease {"val":20,"ack":true,"ts":1577550043192,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577550043190}
                heatingcontrol.0	2020-04-19 12:02:12.928	debug	(20299) Wohnzimmer window open is true
                heatingcontrol.0	2020-04-19 12:02:12.928	debug	(20299) check room Wohnzimmer
                heatingcontrol.0	2020-04-19 12:02:12.928	debug	(20299) profile 0
                heatingcontrol.0	2020-04-19 12:02:12.925	debug	(20299) get profile
                heatingcontrol.0	2020-04-19 12:02:12.925	debug	(20299) profile type 3
                heatingcontrol.0	2020-04-19 12:02:12.837	debug	(20299) calculating new target temperatures
                heatingcontrol.0	2020-04-19 12:02:12.836	debug	(20299) room to check is Wohnzimmer
                heatingcontrol.0	2020-04-19 12:01:52.884	debug	(20299) ### not handled maxcul.0.JEQ0161176.isOpen {"val":true,"ack":true,"ts":1587290512784,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1587290512784}
                heatingcontrol.0	2020-04-19 12:01:52.884	debug	(20299) ### 222 not handled yet
                heatingcontrol.0	2020-04-19 12:01:52.884	debug	(20299) sensor delay 20000
                heatingcontrol.0	2020-04-19 12:01:52.838	debug	(20299) Kaminzimmer window open is true
                heatingcontrol.0	2020-04-19 12:01:52.838	debug	(20299) got sensor state {"val":false,"ack":true,"ts":1586079832926,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1586079832926} from maxcul.0.JEQ0510563.isOpen
                heatingcontrol.0	2020-04-19 12:01:52.837	info	(20299) Kaminzimmer window open on Contact JEQ0161176 opened
                heatingcontrol.0	2020-04-19 12:01:52.837	debug	(20299) got sensor state {"val":true,"ack":true,"ts":1587290512784,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1587290512784} from maxcul.0.JEQ0161176.isOpen
                heatingcontrol.0	2020-04-19 12:01:52.836	debug	(20299) Check sensors for Kaminzimmer
                heatingcontrol.0	2020-04-19 12:01:52.836	debug	(20299) sensor delay 20000
                heatingcontrol.0	2020-04-19 12:01:52.792	debug	(20299) Wohnzimmer window open is true
                heatingcontrol.0	2020-04-19 12:01:52.792	debug	(20299) got sensor state {"val":false,"ack":true,"ts":1586079832926,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1586079832926} from maxcul.0.JEQ0510563.isOpen
                heatingcontrol.0	2020-04-19 12:01:52.791	info	(20299) Wohnzimmer window open on Contact JEQ0161176 opened
                heatingcontrol.0	2020-04-19 12:01:52.791	debug	(20299) got sensor state {"val":true,"ack":true,"ts":1587290512784,"q":0,"from":"system.adapter.maxcul.0","user":"system.user.admin","lc":1587290512784} from maxcul.0.JEQ0161176.isOpen
                heatingcontrol.0	2020-04-19 12:01:52.787	debug	(20299) Check sensors for Wohnzimmer
                Könnte es am JS-Controller liegen?
                • G Offline
                  guergen
                  #1017
                  Wie ich die LOG-Daten so lese, scheint das ganze entweder am admin oder am js zu liegen.
                  Habe die selben LOG-Einträge in anderen Adaptern!
                  heatingcontrol.0	2020-04-19 12:09:44.215	error	(29938) exception in HandleStateChange [Error: undefined is not a valid state value]
                  heatingcontrol.0	2020-04-19 12:09:44.214	warn	(29938) This value will not be set in future versions. Please report this to the developer.
                  heatingcontrol.0	2020-04-19 12:09:44.214	warn	(29938) State value to set is invalid for heatingcontrol.0.Rooms.Wohnzimmer.TemperatureIfNoHeatingPeriod: The state is missing the required property val!
                  heatingcontrol.0	2020-04-19 12:09:44.214	debug	(29938) ### handle state change heatingcontrol.0.Rooms.Wohnzimmer.TemperatureIfNoHeatingPeriod {"val":5,"ack":false,"ts":1587290984212,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin"
                  Rene_HMR DutchmanD 2 Antworten Letzte Antwort
                  • P Offline
                    Pittini
                    schrieb am zuletzt editiert von Pittini
                    #1018
                    [Edit 23.4. Hat sich erledigt, die Datenpunkte wurden zur vorherigen Version zurückgeändert]
                    Achtung Nutzer von meinem Vis Projekt!
                    Nach update auf Adapterversion 0.4.0 wird der Einstellungsblock (zumindest bei der Variante Mo-Fr / Sa-Su und Mo-Su) nicht mehr angezeigt aufgrund einer Textänderung im Adapter welche in meinem Projekt die Sichtbarkeit der Blöcke steuert.
                    Also entweder mit update warten oder folgenden Workaround durchführen:
                    • Vis Editor aufrufen
                    • Seite contHzng laden
                    • bei dem im Bild gezeigten Widget im markierten Bereich der Sichtbarkeitseinstellungen den Text "Mo - Fr / Sa - Su" abändern zu "Mo-Fr / Sa-Su". Dies gilt analog auch für die Variante "Mo - Su" , diese ist zu ändern auf "Mo-Su". Bei "every Day" hat sich nix geändert.
                      Die aktuell jeweils richtige Schreibweise findet ihr bei den Adapterobjekten unter: "heatingcontrol.0.info.ProfileType"
                    Das wars schon, kleine Ursache, große Wirkung. Ich weis nicht ob das jetzt so bleibt oder ob Rene das wieder zurückändert, auf jeden Fall wisst Ihr jetzt wie Ihr das Problem lösen könnt.
                    • G guergen
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      schrieb am zuletzt editiert von Rene_HM
                      #1019
                      @guergen sagte in Test Adapter HeatingControl v0.3.x:
                      JS-controller 3.xx
                      für JS controller 3.x gibt es bereits ein Ticket. Damit muss ich mich noch beschäftigen...
                      https://github.com/rg-engineering/ioBroker.heatingcontrol/issues/92
                      G 2 Antworten Letzte Antwort
                      • Rene_HMR Rene_HM
                        JS-controller 3.xx
                        guergen
                        #1020
                        @Rene_HM Ok, da ich ganz viele Probleme habe, bin ich wieder auf 2.2.10 zurück...
                        Schont auch etwas meine Nerven :-)
                        • G guergen
                          Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          #1021
                          Das führt dazu, dass das Handling nicht weiter ausgeführt wird. Liegt also am Adapter...
                          • Rene_HMR Rene_HM
                            JS-controller 3.xx
                            guergen
                            #1022
                            @Rene_HM Aber dieses unsubscribe finde ich ebenfalls komisch
                            • G guergen
                              Rene_HMR Offline
                              Rene_HMR Offline
                              Rene_HM
                              #1023
                              @guergen das musste ich für das ThermostatHandling einbauen. Wenn vom Thermostat eine Änderung kommt, fange ich die. Dann schreibt der Adapter den neuen Wert auf seine internen Variablen, was wieder dazu führt, dass auch der Thermostat neue/alte Daten bekommt... das würde zu einer Endlosschleife führen. Also muss ich unsubscriben, Daten ändern und wieder subscriben...
                              G P 2 Antworten Letzte Antwort
                                Denkra
                                TeamSpeak
                                #1024
                                Ich bekomme jetzt auch die ganze Zeit Fehlermeldungen wie
                                error: info.0 (13244) Error: Request failed with status code 503
                                oder
                                [{"date":"17:44:40","level":"<span class='log-error'>error<span class='log-error'>","source":"info.0","msg":"(13244) Error: Request failed with status code 503"}]
                                • Rene_HMR Rene_HM
                                  guergen
                                  #1025
                                  @Rene_HM Mich wunderte es, weil es im Info-Log läuft...
                                  • Rene_HMR Rene_HM
                                    Pittini
                                    #1026
                                    @Rene_HM sagte in Test Adapter HeatingControl v0.3.x:
                                    Hmm, verstehe dann aber nicht wieso er das bei mir auch macht, obwohl ich "Verwendung von Änderungen vom Thermostat" auf no stehen hab? 🤔
                                    • G guergen
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #1027
                                      @guergen naja, 0.4.0 ist eben noch im Test, ich schiebe die logs noch nach debug...
                                      das sollte nicht sein...
                                      • D Denkra
                                        oder
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #1028
                                        @Denkra sagte in Test Adapter HeatingControl v0.3.x:
                                        error: info.0
                                        das betrifft den info-Adapter, oder?
                                        • Rene_HMR Rene_HM
                                          guergen
                                          #1029
                                          @Rene_HM Ist nicht schlimm, ich binnach der ganzen js-controller-Nummer eh grade wieder zurück auf 0.3.19
