2.9k Beiträge 248 Kommentatoren 2.5m Aufrufe 123 Beobachtet
  • C
    C
    csamaggi
    schrieb am zuletzt editiert von csamaggi
    #1675
    Hallo ihre lieben,
    ich habe nun meinen VMs/Docker Server von proxmox auf unRaid umgestellt und in diesem Zuge auch von einer ioBroker VM auf Container von buanet gewechselt der soweit auch läuft ausser der Radar2 Adapter.
    Da bekomme ich im Log
    radar2.0 2020-04-11 19:36:10.985 info (2356) Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.0 2020-04-11 19:36:10.984 error at process._tickCallback (internal/process/next_tick.js:63:19)
    radar2.0 2020-04-11 19:36:10.984 error at onErrorNT (internal/child_process.js:415:16)
    radar2.0 2020-04-11 19:36:10.984 error at Process.ChildProcess._handle.onexit (internal/child_process.js:240:19)
    radar2.0 2020-04-11 19:36:10.984 error (2356) Error: spawn arp ENOENT
    radar2.0 2020-04-11 19:36:10.984 error (2356) uncaught exception: spawn arp ENOENT
    radar2.0 2020-04-11 19:36:10.930 info (2356) Will try to scan BT devices: false
    radar2.0 2020-04-11 19:36:10.923 info (2356) radar2 set to scan every 20 seconds and printers every 720 minutes.
    radar2.0 2020-04-11 19:36:10.923 info (2356) arp-scan will use the following interfaces: [ 'eth0' ]
    radar2.0 2020-04-11 19:36:10.923 info (2356) Remove name end for host names: .fritz.box
    radar2.0 2020-04-11 19:36:10.923 info (2356) use known IP list: [ '1.1.1.1' ]
    radar2.0 2020-04-11 19:36:10.923 info (2356) use known BT list: [ '01:12:23:34:45:56' ]
    radar2.0 2020-04-11 19:36:10.923 info (2356) radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0 2020-04-11 19:36:10.923 warn (2356) node-bluetooth not found!
    radar2.0 2020-04-11 19:36:10.922 warn (2356) Noble not available, Error: { Error: EAFNOSUPPORT, Address family not supported by protocolat new Hci (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:74:18)at new NobleBin
    radar2.0 2020-04-11 19:36:10.889 info (2356) Connected with '0.0.0.0' for DHCP Scan
    radar2.0 2020-04-11 19:36:10.852 info (2356) radar2 initialization started...
    radar2.0 2020-04-11 19:36:10.798 info (2356) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v10.19.0
    Mir ist im Prinzip klar was da fehlt nämlich node-bluetooth wenn ich das richtig verstanden habe.
    Nur meine Frage ist wie bekomme ich das nach instaliert damit der Adapter läuft ohne kann ich irgendwie das BT ausschalten denn ich nutze es nicht. Aber wäre gut wenn man das irgendwie nach installieren kann.
    Hoffe auf eure Hilfe
    MFG Maggi
    • C csamaggi
      Hallo ihre lieben,
      MFG Maggi
      apollon77A
      apollon77A
      #1676
      @csamaggi sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
      Das ist das relevante. Du hast "arp" als Kommando nicht installiert
      • C
        C
        csamaggi
        #1677
        So ich habe nun Bluetooth und arp hiemit installiert
        apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev
        Doch nun bekomme ich folgende Meldung wenn ich hciconfig ausführe
        Can't open HCI socket.: Address family not supported by protocol
        Auch im Log ändert nicht die gleiche Meldung.
        MFG Maggi
        apollon77A T andreA 3 Antworten Letzte Antwort
        • C csamaggi
          MFG Maggi
          apollon77A
          apollon77A
          #1678
          @csamaggi Naja jetzt musst Du schauen wie Du im Docker auf quasi ein Serielles Devcie zugreifst ... hci/bluetooth ist ja nix anderes, Da bin ich jetzt raus
          • C csamaggi
            MFG Maggi
            T
            T
            ts020339
            schrieb am zuletzt editiert von ts020339
            #1679
            @andre : hast Du einen Tip, wie ich in Deinem docker container den neuen mihome vacuum adapter (Version 2.0.9) installiert bekomme.?
            github seite mihome-vacuum
            Direkt im iobroker (also in deinem docker image) scheitert das bei mir immer an der Installation des Pakets canvas 2.6.1. Auf der github Seite des Adapters wird dieser Fehler beschrieben:
            Error at installation
            if your installation runs in error. The canvas package could not be install
            npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
            Please install canvas and the libs manually with:
            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
            sudo npm install canvas --unsafe-perm=true
            Leider scheitert bei mir im docker image immer dann das "npm install canvas --unsafe-perm=true" (außerdem wäre das ganze vermutlich auch nicht persistent).
            Ich poster gerne noch ausführliche logs/Fehlermeldungen wenn Du brauchst.
            Danke für Deine Hilfe!
            Tim
            andreA 1 Antwort Letzte Antwort
            • C csamaggi
              MFG Maggi
              andreA
              andreA
              andre
              #1680
              @csamaggi
              Hast du dich um die Capabilities gekümmert? Siehe "Installation" auf github (https://github.com/frankjoke/ioBroker.radar2).
              Die Capabilities müssen auch in der Konfiguration des Containers gesetzt werden.
              Außerdem empfehle ich die die benötigten Linux Pakete über die ENV PACKAGES installieren zu lassen.
              MfG,
              André
              • T ts020339
                Tim
                andreA
                andreA
                andre
                #1681
                @ts020339
                Hallo Tim,
                irgendwo ist mir das doch die Tage schonmal über den Weg gelaufen... Schreib mir doch bitte dazu mal einen Issue auf github, dann kann ich sehen was man da machen kann.
                Wenn das Voraussetzungen für einen Adapter sind, will ich die gerne im Image unterstützen.
                MfG,
                André
                • FoodFighterF
                  FoodFighterF
                  FoodFighter
                  schrieb am zuletzt editiert von FoodFighter
                  #1682
                  @andre said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                  Das könnte ich gewesen sein (28.03.20) Hier ist der Beitrag .
                  Bei mir lag es daran, dass die benötigten Pakete über die ENV-Variable nicht installiert wurden, da die Installation durch das nicht vorhandene vi-Paket auf dem RaspPi abgebrochen wurde und mir das durch in der Log nicht aufgefallen ist.
                  Das hast Du ja mittlerweile freundlicherweise alles behoben :)
                  @ts020339
                  trage mal folgende Pakete in die ENV-PACKAGES-Variable ein:
                  Danach sollte es laufen.
                  Für die Karten-Darstellung dann evtl. noch "canvas" als zusätzliches Modul in der javascript-Adapter-Einstellungen eintragen
                  andreA T 2 Antworten Letzte Antwort
                  • andreA andre
                    @Holzlenkrad sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                    Du bist immer noch auf Stretch, weil es irgendwann mal irgendwelche Probleme gab oder?
                    Ich weiß nicht mehr woran es damals lag. Seitdem fehlte einfach die Zeit es nochmal zu probieren.
                    Hast du mittlerweile mal wieder Buster ausprobiert?
                    Gerade eben. Der Build ist durch gelaufen. Die aktuelle Beta-Version ist jetzt Buster. Wenn ihr fleißig testet geht das zeitnah in eine neue Latest-Version. :)
                    Können wir dir vielleicht bei konkreten Problemen weiter helfen?
                    Da du dich ja gerade freiwillig gemeldet hast, bitte testen.
                    Und was ist der Hintergrund, dass du für ARM das Balena-Image nutzt?
                    Wie @duffbeer2000 schon gesagt hat. Mit den Standard-Images (https://hub.docker.com/_/debian) ist leider offenbar kein cross build möglich. Habe aber auch das Balena-Image auf Buster gewechselt...
                    MfG,
                    André
                    H
                    H
                    Holzlenkrad
                    #1683
                    @andre
                    Ich habe das aktuelle Beta-Image installieren. Bin beim Testen fast verrückt geworden, weil nichts funktioniert hat. Leider bin ich gleichzeitig auch auf einen Raspberry Pi 4 umgestiegen und dort gibt es im Kernel einen Bug im ARP Stack, sodass das Interface nicht erreichbar war. Lösung und Beschreibung hier: https://forums.docker.com/t/docker-container-not-reachable-from-the-outside-only-after-ping-from-the-inside-macvlan/89629
                    Hab das ganze natürlich erstmal auf dein Image geschoben :D Deswegen, nie zu viel auf einmal ändern...
                    Aber jetzt wo es läuft funktioniert alles ohne Probleme. Ich sehe keinen Grund, wieso du nicht auf Buster setzen solltest. Natürlich müssen noch mehr Leute die Beta testen, vor allem die x64 Version sollte wohl noch getestet werden :)
                    Danke!
                    andreA FoodFighterF 2 Antworten Letzte Antwort
                    • FoodFighterF FoodFighter
                      @ts020339
                      andreA
                      andreA
                      andre
                      #1684
                      @FoodFighter Danke, das war es. :) Hirn ist gerade im Ostermodus. Das mit dem Modul im Javascript ist interessant. Hast du da mal nen Screenshot? Installiert er darüber dann npm Module nach? Wäre auch für andere Sachen interessant. :)
                      MfG,
                      André
                      • H Holzlenkrad
                        @andre
                        Danke!
                        andreA
                        andreA
                        andre
                        #1685
                        @Holzlenkrad Da stimme ich dir zu. Bloß nicht zu viel auf einmal ändern.
                        Ich habe gestern auch alles auf einmal gemacht. Habe mein Livesystem von der DS (musste ein paar Ressourcen frei machen) auf eine Debian VM mit Docker unter Hyper-V auf einem Win 10 Intel Nuc umgezogen und bin gleichzeitig auf das neue Beta Image gewechselt...
                        Mit umgezogen sind natürlich auch die weiteren Container mit redis, mariadb, influxdb und grafana. Zum Glück alles ohne größere Probleme. :)
                        Jetzt hab ich endlich produktiv mal mit "Stack" im Portainer gearbeitet. Das schreit irgendwie nach nem neuen Tutorial...
                        In diesem Zusammenhang kann ich jetzt übrigens endlich auch bestätigen, dass der Restore vom "iobroker backup" (nur Backup file im iobroker Ordner, beim Start des Containers) auch bei umfangreichen Installationen problemlos funktioniert. Allerdings hat es ca. 1,5 Stunden gedauert, bis iobroker meine 51 Adapter nachinstalliert hatte...
                        Zeitaufwand für den kompletten Umzug ca. 4 Stunden (inklusive Einrichtung eines neuen Backup Scripts).
                        MfG,
                        André
                        H D 2 Antworten Letzte Antwort
                        • FoodFighterF
                          FoodFighterF
                          FoodFighter
                          #1686
                          So wie ich das verstehe installiert er dadrüber dann die eingetragenen NPM-Module nach, ja
                          Bezüglich der Karte vom RoboRock-S5-Staubsauger (mit Valetudo) funktioniert das bei mir.
                          Ich hatte das aus mehreren Quellen zusammen getragen.
                          Zum einen hier im Video
                          Zum Anderen hier bei Github (ich nutze den V3-Script)
                          Hier steht auch beschrieben, dass der Script eigentlich gar nicht mehr nötig ist und die Live-Map direkt über den Adapter konfiguriert werden kann.
                          Ist auch ziemlich verwirrend, weil die Repo einmal über iobroker-community-adapters (scheint die "offizielle" zu sein) und einmal über MeisterTR läuft.
                          Über den Mihome-Adapter soll das HTML-Bild in mihome-vacuum.0.map.map64 liegen, dieses Objekt bleibt bei mir allerdings leer (der Rest des Adapters funktioniert einwandfrei).
                          Über den JS-Script landet das HTML-Bild in javascript.0.vis.RockroboMap - das funktioniert bei mir sehr gut - auch wenn es ärgerlich ist, weil ein "unnötiger" Script läuft.
                          Vielleicht liegt das einfach daran, dass "canvas" und "xmlhttprequest" im javascript als NPM-Modul nachinstallieren lassen kann, im Mihome-Adapter aber nicht (bzw. dieses anderweitig erledigen müsste?)
                          Ich wüsste nicht, wie ich das anderweitig im Container löse.
                          • H Holzlenkrad
                            @andre
                            Danke!
                            FoodFighterF
                            FoodFighterF
                            FoodFighter
                            #1687
                            @Holzlenkrad said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                            woah...ernsthaft - DANKE!
                            Ich habe schon an meinem Verstand gezweifelt, weil ich das macvlan nicht zum laufen bekam (exakt das gleiche Verhalten -> alles funktionierte erst nach einem Ping von innen heraus).
                            Ich habe es dann aufgegeben und im Bridge-Mode alle Ports durch geroutet.
                            Im Host-Modus startet der Container bei mir zwar erfolgreich, aber der Admin-Adapter bricht seinen Dienst direkt wieder ab, was ich mir auch überhaupt nicht erklären kann.
                            Über die Log des Containers erhalte ich folgende Fehler:
                            ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting],
                            ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped],
                            ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging],
                            Das hatte ich hier schon mal angefragt - war vermutlich die falsche Anlaufstelle.
                            Im Bridgemode mit entsprechenden Ports funktioniert soweit alles. (Komplett identische Container-Einstellungen wie im Host-Mode, nur der Netzwermodus wurde von Host auf Brige geändert und die paar Ports durchgeroutet)
                            • C
                              C
                              csamaggi
                              #1688
                              Kann man das BT im Adapter deaktivieren?
                              Da ich im Moment kein Device dran habe und er im Log meckert und nicht startet
                              host.iobroker	2020-04-12 12:39:48.678	info	Do not restart adapter system.adapter.radar2.0 because disabled or deleted
                              host.iobroker	2020-04-12 12:39:48.678	error	instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                              radar2.0	2020-04-12 12:39:48.169	warn	(9677) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                              radar2.0	2020-04-12 12:39:48.165	error	(9677) adapter disabled
                              host.iobroker	2020-04-12 12:39:46.739	info	"system.adapter.radar2.0" disabled
                              host.iobroker	2020-04-12 12:39:46.127	info	Restart adapter system.adapter.radar2.0 because enabled
                              host.iobroker	2020-04-12 12:39:46.127	info	instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
                              host.iobroker	2020-04-12 12:39:46.127	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:61:11) errno: 19, code: 'ENODEV', syscall: 'bind' }
                              host.iobroker	2020-04-12 12:39:46.127	error	Caught by controller[0]: at process.nextTick (/opt/iobroker/node_modules/@abandonware/noble/lib/noble.js:60:24)
                              host.iobroker	2020-04-12 12:39:46.127	error	Caught by controller[0]: at NobleBindings.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:78:13)
                              host.iobroker	2020-04-12 12:39:46.127	error	Caught by controller[0]: at Hci.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:100:35)
                              host.iobroker	2020-04-12 12:39:46.127	error	Caught by controller[0]: { Error: ENODEV, No such device
                              radar2.0	2020-04-12 12:39:46.102	info	(9655) Adapter disconnected and stopped with dostop(false) and callback(true)
                              radar2.0	2020-04-12 12:39:46.102	error	(9655) Error: ENODEV, No such device at Hci.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:100:35) at NobleBindings.init (/opt/iobroker/node_modules/@abandonware/nob
                              radar2.0	2020-04-12 12:39:46.101	error	(9655) uncaught exception: ENODEV, No such device
                              radar2.0	2020-04-12 12:39:46.096	info	(9655) radar2 set to scan every 20 seconds and printers every 720 minutes.
                              radar2.0	2020-04-12 12:39:46.096	info	(9655) arp-scan will use the following interfaces: [ 'enp1s0' ]
                              radar2.0	2020-04-12 12:39:46.096	info	(9655) Remove name end for host names: .fritz.box
                              radar2.0	2020-04-12 12:39:46.095	info	(9655) use known IP list: [ '1.1.1.1' ]
                              radar2.0	2020-04-12 12:39:46.095	info	(9655) use known BT list: [ '01:12:23:34:45:56' ]
                              radar2.0	2020-04-12 12:39:46.095	info	(9655) radar2 set to flag items away if they are not seen for 2 minutes
                              radar2.0	2020-04-12 12:39:46.094	info	(9655) found 'node-bluetooth'
                              radar2.0	2020-04-12 12:39:46.092	info	(9655) found '@abandonware/noble'
                              radar2.0	2020-04-12 12:39:46.048	info	(9655) Connected with '0.0.0.0' for DHCP Scan
                              radar2.0	2020-04-12 12:39:46.000	info	(9655) radar2 initialization started...
                              radar2.0	2020-04-12 12:39:45.923	info	(9655) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v10.20.0
                              MFG Maggi
                                @ts020339
                                T
                                T
                                ts020339
                                #1689
                                @FoodFighter said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                @ts020339
                                @FoodFighter : Danke für den Hinweis! Habe die Pakete wie von Dir erwähnt eingetragen in die ENV Variable und diese sind auch installiert worden. Leider scheitert das Adapter-Upgrade (von 1.1.5 auf 2.0.7) weiterhin:
                                $ ./iobroker upgrade mihome-vacuum
                                Update mihome-vacuum from @1.1.5 to @2.0.7
                                NPM version: 6.13.4
                                npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp
                                 ERR! configure error gyp ERR! stack Error: write EPROTO 140440310937408:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:gyp ERR! stack gyp ERR! stack     at WriteWrap.afterWrite [as oncomplete] (net.js:789:14)gyp ERR! System Linux 4.14.24-qnapgyp ERR!
                                command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR!
                                 node-gyp -v v5.0.5gyp ERR! not ok
                                node-pre-gyp
                                 ERR! build error
                                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp
                                ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.14.24-qnap
                                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR!
                                node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                                npm
                                 ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                npm ERR! A complete log of this run can be found in:npm ERR!     /opt/iobroker/.npm/_logs/2020-04-12T11_43_21_011Z-debug.log
                                ERROR: host.ioBroker-Host Cannot install iobroker.mihome-vacuum@2.0.7: 1
                                @andre : habe mal wie von Dir vorgeschlagen ein github issue erstellt (https://github.com/buanet/docker-iobroker/issues/91).
                                Danke Euch!
                                Tim
                                • T ts020339
                                  @ts020339
                                  NPM version: 6.13.4
                                  gyp
                                  node-pre-gyp
                                   ERR! build error
                                  npm
                                  Danke Euch!
                                  Tim
                                  T
                                  T
                                  ts020339
                                  #1690
                                  @FoodFighter :
                                  wenn ich wie von Dir vorgeschlagen das Modul "canvas" im javascript Adapter eintrage, bekomme ich im Übrigen folgende Fehlermeldung im Log (Achtung: umgekehrte zeitliche Reihenfolge):
                                  javascript.0	2020-04-12 14:11:41.034	error	(28605) Cannot install canvas: 1
                                  javascript.0	2020-04-12 14:11:41.024	error	npm ERR! /opt/iobroker/.npm/_logs/2020-04-12T12_11_41_017Z-debug.log
                                  javascript.0	2020-04-12 14:11:41.024	error	(28605) npm ERR! A complete log of this run can be found in:
                                  javascript.0	2020-04-12 14:11:41.023	error	(28605)
                                  javascript.0	2020-04-12 14:11:41.007	error	npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                  javascript.0	2020-04-12 14:11:41.007	error	npm ERR! Failed at the canvas@2.6.1 install script.
                                  javascript.0	2020-04-12 14:11:41.007	error	npm ERR! Exit status 1
                                  javascript.0	2020-04-12 14:11:41.007	error	(28605) npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                                  javascript.0	2020-04-12 14:11:41.004	error	npm ERR! errno 1
                                  javascript.0	2020-04-12 14:11:41.004	error	(28605) ERR! code ELIFECYCLE
                                  javascript.0	2020-04-12 14:11:41.003	error	(28605) npm
                                  javascript.0	2020-04-12 14:11:40.781	info	(28605) Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.javascript/node_mod
                                  javascript.0	2020-04-12 14:11:40.780	error	(28605) not ok
                                  javascript.0	2020-04-12 14:11:40.780	error	node-pre-gyp ERR!
                                  javascript.0	2020-04-12 14:11:40.780	error	node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                  javascript.0	2020-04-12 14:11:40.780	error	node-pre-gyp ERR! node -v v10.19.0
                                  javascript.0	2020-04-12 14:11:40.780	error	(28605) cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/canvas
                                  javascript.0	2020-04-12 14:11:40.779	error	node-pre-gyp ERR!
                                  javascript.0	2020-04-12 14:11:40.779	error	node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                  javascript.0	2020-04-12 14:11:40.779	error	(28605) System Linux 4.14.24-qnap
                                  javascript.0	2020-04-12 14:11:40.779	error	(28605) node-pre-gyp ERR!
                                  javascript.0	2020-04-12 14:11:40.778	error	node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                  javascript.0	2020-04-12 14:11:40.778	error	node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)
                                  javascript.0	2020-04-12 14:11:40.778	error	node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                                  javascript.0	2020-04-12 14:11:40.778	error	(28605) ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                  javascript.0	2020-04-12 14:11:40.778	error	node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/iobrok
                                  javascript.0	2020-04-12 14:11:40.778	error	(28605) ERR! build error
                                  javascript.0	2020-04-12 14:11:40.777	error	(28605) node-pre-gyp
                                  javascript.0	2020-04-12 14:11:40.773	error	(28605)
                                  javascript.0	2020-04-12 14:11:40.772	error	gyp ERR! not ok
                                  javascript.0	2020-04-12 14:11:40.772	error	gyp ERR! node-gyp -v v5.0.5
                                  javascript.0	2020-04-12 14:11:40.772	error	gyp ERR! node -v v10.19.0
                                  javascript.0	2020-04-12 14:11:40.772	error	(28605) ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/canvas
                                  javascript.0	2020-04-12 14:11:40.772	error	gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.javascript/node_modul
                                  javascript.0	2020-04-12 14:11:40.772	error	(28605) ERR! System Linux 4.14.24-qnap
                                  javascript.0	2020-04-12 14:11:40.771	error	gyp
                                  javascript.0	2020-04-12 14:11:40.771	error	gyp ERR! stack at WriteWrap.afterWrite [as oncomplete] (net.js:789:14)
                                  javascript.0	2020-04-12 14:11:40.771	error	gyp ERR! stack Error: write EPROTO 140309190592320:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
                                  javascript.0	2020-04-12 14:11:40.771	error	(28605) ERR! configure error
                                  javascript.0	2020-04-12 14:11:40.771	error	(28605) gyp
                                  javascript.0	2020-04-12 14:11:40.750	error	(28605) WARN install got an error, rolling back install
                                  javascript.0	2020-04-12 14:11:40.749	error	(28605) gyp
                                  javascript.0	2020-04-12 14:11:40.010	error
                                  javascript.0	2020-04-12 14:11:40.010	error	node-pre-gyp WARN Hit error write EPROTO 140394849888064:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
                                  javascript.0	2020-04-12 14:11:40.010	error	(28605) WARN Pre-built binaries not installable for canvas@2.6.1 and node@10.19.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                                  javascript.0	2020-04-12 14:11:40.009	error	(28605) node-pre-gyp
                                  javascript.0	2020-04-12 14:11:39.689	error	(28605) WARN Using request for node-pre-gyp https download
                                  javascript.0	2020-04-12 14:11:39.688	error	(28605) node-pre-gyp
                                  javascript.0	2020-04-12 14:11:39.283	info	> node-pre-gyp install --fallback-to-build
                                  javascript.0	2020-04-12 14:11:39.283	info	> canvas@2.6.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/canvas
                                  javascript.0	2020-04-12 14:11:39.283	info	(28605)
                                  javascript.0	2020-04-12 14:11:33.999	info	(28605) npm install canvas --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                  javascript.0	2020-04-12 14:11:33.970	info	(28605) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.19.0
                                  ist das bei Dir eingetragene Modul "xmlhttprequest" relevant für den mihome-vacuum?
                                  Gruß,
                                  Tim
                                  • FoodFighterF
                                    FoodFighterF
                                    FoodFighter
                                    #1691
                                    @ts020339 said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                    Beide im Javascript-Adapter eingetragenen Module sind nur dann notwendig, wenn du die Live-Karte über den Javascript-Adapter erstellen lassen willst. (siehe 4 Beiträge weiter oben)
                                    Über den Mihome-Adapter hat das bei mir nicht funktioniert...da habe ich aber grade mal im Partner-Thread eine Anfrage gestartet.
                                    Wieso die Installation/upgrade bei dir scheitert kann ich mir nicht erklären.
                                    Bei mir hatte es funktioniert - ich habe da aber auch viel rum gespielt, weil das mit der ENV-Variable vorerst nicht funktionierte. Scheinbar habe ich dann irgendwo unbewusst was richtig gemacht.
                                    Letzten Endes funktionierte bei mir erst alles schlagartig auf Anhieb, nachdem die Pakete erfolgreich über die ENV-Variable installiert wurden.
                                    Hier muss ich passen.
                                    Hoffentlich kann dir wer anders weiter helfen.
                                    (PS: Meine NPM-Version ist ebenfalls 6.13.4 und meine MiHome-vacuum-Version ist die 2.0.7
                                    Ich hatte vorher keine alte Version des Adapters installiert...vielleicht bringt es stumpf was den Adapter über den Admin-Adapter nochmal komplett raus zu werfen und anschließend über den Admin-Adapter komplett in aktueller Version zu installieren?...sieht wenig vielversprechend aus, wäre aber einen schnellen Versuch wert)
                                      T
                                      T
                                      ts020339
                                      #1692
                                      habs schnell mal ausprobiert, leider ohne Erfolg
                                      😬 ... NUR... wie bekomme ich denn jetzt meine alte 1.1.5 zurück?? Die hat wenigstens funktioniert... Eine Auswahl der zu installierenden Version im Expertenmodus gibt es offenbar nur, wenn der Adapter selber installiert ist... habe ich gerade festgestellt... 😕
                                      • andreA andre
                                        MfG,
                                        André
                                        H
                                        H
                                        Holzlenkrad
                                        #1693
                                        Ich habe auch noch andere Container mit umgezogen. Bei denen hat der Zugriff übers Netzwerk aber funktioniert, weil ich nur für iobroker MACVLAN nutze. Und das hat natürlich dann umso mehr dazu geführt, dass ich die Ursache beim Image gesehen habe :D
                                        Die Stack Funktion in Portainer wollte ich in diesem Zuge auch mal ausprobieren, hat aber ebenfalls nicht funktioniert, wenn ich in dem yaml File noch eine Network config mit angegeben habe. Gab einen tollen Fehler "page not found" und dann habe ich wieder regulär docker-compose genutzt. Kann natürlich auch einfach am genannten Kernel Bug gelegen haben....
                                        Generell ist diese Funktion in Portainer auch einfach schlecht bis gar nicht dokumentiert oder täuscht das? Lohnt es sich das Thema noch mal anzugehen?
                                        @FoodFighter
                                        Bei solchen absurden Fehlern ist es wirklich nur Glück ob man die Lösung findet oder nicht. Hätte ich nicht aus reiner Verzweiflung das mit dem Ping probiert, hätte ich ja nicht mal gewusst wonach ich googeln soll...
                                        Aber auch irgendwie verwunderlich, dass ein solcher Bug seit Mitte Januar im Kernel ist und noch kein offizieller Patch veröffentlicht wurde.
                                        • andreA andre
                                          MfG,
                                          André
                                          D
                                          D
                                          darkiop
                                          #1694
                                          @andre Hi Andre, d.h. du hast jetzt eine docker-compose mit macvlan für den ioBroker? Würdest du diese mal zeigen?
                                          ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                          H andreA 2 Antworten Letzte Antwort
                                          33.2k
                                          84.3k
