  4. Test Adapter Material Design Widgets v0.2.x
visadapatervisualizationmaterialwidget
902 Beiträge 77 Kommentatoren 343.4k Aufrufe 79 Beobachtet
  • liv-in-skyL liv-in-sky
    @Scrounger
    danke - das war es - beschriftung wieder da - da gibt es echt viel zum einstellen :-)
    und noch ein log - mit funktionierendem widget
    [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
    DevTools failed to parse SourceMap: chrome-extension://iemadiahhbebdklepanmkjenfdebfpfe/static/js/main.6e6198ed.js.map
    DevTools failed to parse SourceMap: http://192.168.178.59:8072/lib/js/socket.io.js.map
    index.html?galaxy:4059 Version vis-colorpicker: 1.0.1
    index.html?galaxy:4907 Version coronavirus-statistics: 0.1.0
    index.html?galaxy:5638 fritzdect widget version: "0.0.1"
    index.html?galaxy:6098 Version vis-history: 1.0.0
    jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/template/words.js 404 (Not Found)
    send @ jquery-1.11.2.min.js:4
    ajax @ jquery-1.11.2.min.js:4
    m.<computed> @ jquery-1.11.2.min.js:4
    (anonymous) @ calendar.js:11
    info.js:22 Version Info-Adapter-Widget: 0.0.9
    index.html?galaxy:7156 Version vis-jqui-mfd: 1.0.12
    justgage.js:115 Version justgage: 1.0.2
    materialdesign.js:25 Version vis-materialdesign: 0.2.78
    index.html?galaxy:13443 Metro version: "1.1.2"
    DevTools failed to parse SourceMap: http://192.168.178.59:8072/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
    lib.min.js:22 Download the Vue Devtools extension for a better development experience:
    https://github.com/vuejs/vue-devtools
    lib.min.js:22 You are running Vue in development mode.
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    players.js:58 Version players: 0.1.0
    rssfeed.js:22 Version rssfeed: 0.0.1
    jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/rssfeed/words.js 404 (Not Found)
    (anonymous) @ rssfeed.js:11
    trashschedule.js:22 Version trashschedule: 0.0.4
    index.html?galaxy:19713 Version vis-weather: 2.4.1
    jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/trashschedule/words.js 404 (Not Found)
    (anonymous) @ trashschedule.js:11
    conn.js:273 2020-04-05T12:48:12.773Z Connected => authenticate
    conn.js:293 2020-04-05T12:48:12.936Z Authenticated: true
    vis.js:3167 Create inner vis object controll-own.0._MenuRaspi
    vis.js:3167 Create inner vis object controll-own.0._MenuVisView8
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestString2
    vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.sortMode
    vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.filterMode
    vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.jsonList
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMaterialWidget
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.test.html
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.EnergyMaterialWidget
    vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkDevicesStatus.filterMode
    vis.js:3167 Create inner vis object controll-own.0.HANDY.edgeBatt
    vis.js:3167 Create inner vis object controll-own.0.HANDY.odysBatt
    vis.js:3167 Create inner vis object iot.0.services.custom__batt_s7
    vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstorebatt2
    vis.js:3167 Create inner vis object controll-own.0.HANDY.t113batt
    vis.js:3167 Create inner vis object controll-own.0.WHATSAPPtext
    vis.js:3167 Create inner vis object controll-own.0.WHATSAPPCheck
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLTodosText
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLToDos
    vis.js:3167 Create inner vis object controll-own.0.HILDE.SQLArmin
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ToDoListLoeschen
    vis.js:3167 Create inner vis object controll-own.0.AlexaSprichMirNach
    vis.js:3167 Create inner vis object controll-own.0.Banane
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL2
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL3
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL4
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL5
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL6
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL7
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_26
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_49
    vis.js:3167 Create inner vis object controll-own.0.statusDLNAReload
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_124
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_113
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpDaten
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpReserve
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpSync
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpmSata
    vis.js:3167 Create inner vis object plex.0.libraries.1-serien.itemsCount
    vis.js:3167 Create inner vis object controll-own.0.statusDLNARestart
    vis.js:3167 Create inner vis object controll-own.0.statusRefresh
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_29
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRoot
    vis.js:3167 Create inner vis object controll-own.0.statusMiniDLNA
    vis.js:3167 Create inner vis object controll-own.0.statusDLNAfind
    vis.js:3167 Create inner vis object mpd.0.state
    vis.js:3167 Create inner vis object controll-own.0.statusFilm
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.checkDaten
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.DatenCheckBackup
    vis.js:3167 Create inner vis object controll-own.0.mounthelpReserve
    vis.js:3167 Create inner vis object controll-own.0.mounthelpSync
    vis.js:3167 Create inner vis object controll-own.0.mounthelpDaten
    vis.js:3167 Create inner vis object controll-own.0.mounthelpmSata
    vis.js:3167 Create inner vis object controll-own.0.HANDY.odysload
    vis.js:3167 Create inner vis object controll-own.0.HANDY.edgeload
    vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstoreLoad
    vis.js:3167 Create inner vis object controll-own.0.HANDY.stromTrekstore
    vis.js:3167 Create inner vis object controll-own.0.HANDY.stromEdge
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.DiskSpace
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.WWWCopy
    vis.js:3167 Create inner vis object controll-own.0.HANDY.stromOdys
    vis.js:3167 Create inner vis object controll-own.0.iobrokerbackup
    vis.js:3167 Create inner vis object controll-own.0.iobrokerbackupstatus
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.SQLConnections
    vis.js:3167 Create inner vis object mclighting.0.fx_mode
    vis.js:3167 Create inner vis object controll-own.0.NeRGB-ID
    vis.js:3167 Create inner vis object mclighting.0.color_R
    vis.js:3167 Create inner vis object mclighting.0.color_G
    vis.js:3167 Create inner vis object mclighting.0.color_B
    vis.js:3167 Create inner vis object mclighting.0.fx_mode_name
    vis.js:3167 Create inner vis object mclighting.1.fx_mode
    vis.js:3167 Create inner vis object controll-own.0.NeRGB-ID2
    vis.js:3167 Create inner vis object mclighting.1.color_R
    vis.js:3167 Create inner vis object mclighting.1.color_G
    vis.js:3167 Create inner vis object mclighting.1.color_B
    vis.js:3167 Create inner vis object mclighting.1.fx_mode_name
    vis.js:3167 Create inner vis object mclighting.0.power
    vis.js:3167 Create inner vis object mclighting.1.power
    vis.js:3167 Create inner vis object mclighting.1.brightness
    vis.js:3167 Create inner vis object mclighting.0.brightness
    vis.js:3167 Create inner vis object controll-own.0.SonoffsRestart
    vis.js:3167 Create inner vis object controll-own.0.SonoffsOff
    vis.js:3167 Create inner vis object sonoff.0.MCUTasmotaMov2.POWER
    vis.js:3167 Create inner vis object sonoff.0.Sonoff11.POWER2
    vis.js:3167 Create inner vis object sonoff.0.Sonoff13.POWER2
    vis.js:3167 Create inner vis object sonoff.0.Sonoff4.POWER2
    vis.js:3167 Create inner vis object sonoff.0.Sonoff5.POWER2
    vis.js:3167 Create inner vis object sonoff.0.MCUTasmotaMov1.POWER
    vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLTodayDelete
    vis.js:3167 Create inner vis object sonoff.0.Sonoff15.AM2301_Temperature
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.MemoryFree
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapSize
    vis.js:3167 Create inner vis object controll-own.0.mount.SQLSizeioBrokerData
    vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_29.Commands.screenOff
    vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoad
    vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadTx
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.LOGSizeVAR
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.LOGSizeIOBroker
    vis.js:3167 Create inner vis object pi-hole.0.summary.domains_being_blocked
    vis.js:3167 Create inner vis object pi-hole.0.summary.dns_queries_today
    vis.js:3167 Create inner vis object pi-hole.0.summary.ads_blocked_today
    vis.js:3167 Create inner vis object pi-hole.0.summary.ads_percentage_today
    vis.js:3167 Create inner vis object pi-hole.0.summary.status
    vis.js:3167 Create inner vis object controll-own.0.PI-HOLE.IPv6
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Bruttopreis 100l
    vis.js:3167 Create inner vis object admin.0.info.updatesNumber
    vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadZaehler
    vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadMIN
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.First
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.SecondtLink
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.SecondLink
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.ThirdLink
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.FirstLink
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.FirstText
    vis.js:3167 Create inner vis object alexa2.0.Smart-Home-Devices.4bfd6fec-5b3d-45e2-ae7a-a38bb9075ac0.powerState
    vis.js:3167 Create inner vis object javascript.0.VIS-Steuerung.Aktuelle_VIS_Seite
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.TimerResetVIS
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Minuten
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Minuten
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.SummeMinuten2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Finished
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Sekunden
    vis.js:3167 Create inner vis object 60
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Name2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Gerät2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Gerät1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.SummeMinuten1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Finished
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Name1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Sekunden
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Ende1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Ende2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Start1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Start2
    vis.js:3167 Create inner vis object controll-own.0.Luefter3
    vis.js:3167 Create inner vis object controll-own.0.Luefter1
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_1
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_36
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_27
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_127
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_88
    vis.js:3167 Create inner vis object controll-own.0.ACER5630Cyber
    vis.js:3167 Create inner vis object controll-own.0.AMD5300
    vis.js:3167 Create inner vis object controll-own.0.fx6300
    vis.js:3167 Create inner vis object controll-own.0.FARBBand
    vis.js:3167 Create inner vis object controll-own.0.HeizungZimmerCounter
    vis.js:3167 Create inner vis object controll-own.0.HeizungZimmer30
    vis.js:3167 Create inner vis object controll-own.0.HeizungZimmer90
    vis.js:3167 Create inner vis object controll-own.0.SchreibtischHAUPT
    vis.js:3167 Create inner vis object controll-own.0.Wechsel
    vis.js:3167 Create inner vis object controll-own.0.WechselHalb
    vis.js:3167 Create inner vis object controll-own.0.fx6300energie
    vis.js:3167 Create inner vis object controll-own.0.AMDM5300Monitor
    vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.targettemp
    vis.js:3167 Create inner vis object controll-own.0.fx63000monitore
    vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSPEED
    vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERION
    vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSWING
    vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERCOOL
    vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERHUM
    vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSPEEDHELP
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.ARIVA1-EIN
    vis.js:3167 Create inner vis object controll-own.0.TV
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-EIN
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_23
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.REVOLT3EIN
    vis.js:3167 Create inner vis object controll-own.0.LG-TV.ChannelWahl
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITSchaltUhrProMain
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScahltUhrStu
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITSchaltUhrMin
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScahltUhrTVEin
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrPro1
    vis.js:3167 Create inner vis object controll-own.0.AlexaTriggerSnc
    vis.js:3167 Create inner vis object controll-own.0.HeizungKuecheCounter
    vis.js:3167 Create inner vis object controll-own.0.HeizungKueche30
    vis.js:3167 Create inner vis object controll-own.0.HeizungKueche90
    vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.targettemp
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119590537608.targettemp
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.targettemp
    vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.temp
    vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.temp
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.temp
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119590537608.temp
    vis.js:3167 Create inner vis object controll-own.0.FX6300alt
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_136
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Total
    vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmer30
    vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmer90
    vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmerCounter
    vis.js:3167 Create inner vis object controll-own.0.MATRIX.ScahlterMatrix
    vis.js:3167 Create inner vis object controll-own.0.schlafen
    vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstoreScreen
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.UnifiController
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioCarPort
    vis.js:3167 Create inner vis object controll-own.0.Atesten
    vis.js:3167 Create inner vis object controll-own.0.PLEX.PlexStart
    vis.js:3167 Create inner vis object controll-own.0.PLEX.PLEXAll
    vis.js:3167 Create inner vis object controll-own.0.PLEX.CheckTautulla
    vis.js:3167 Create inner vis object system.adapter.plex.0.alive
    vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_14
    vis.js:3167 Create inner vis object controll-own.0.PLEX.CheckPlexService
    vis.js:3167 Create inner vis object controll-own.0.PLEX.MountVideoFiles
    vis.js:3167 Create inner vis object controll-own.0.MATRIX2.ScahlterMatrix
    vis.js:3167 Create inner vis object controll-own.0.MATRIX2.MatrixMode
    vis.js:3167 Create inner vis object controll-own.0.MATRIX2.MatrixRefreshTime
    vis.js:3167 Create inner vis object controll-own.0.MATRIX.MatrixMode
    vis.js:3167 Create inner vis object controll-own.0.MATRIX.MatrixRefreshTime
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.endDate
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScalterActiv1
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV2.endDate
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScalterActiv2
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrDel1
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrDel2
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltReset
    vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrPro2
    vis.js:3167 Create inner vis object system.adapter.admin.0.uptime
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestZahl2
    vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.battery
    vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.battery
    vis.js:3167 Create inner vis object lgtv.0.states.youtube
    vis.js:3167 Create inner vis object lgtv.0.states.channel
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestLogic2
    vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_29.Commands.loadStartURL
    vis.js:3167 Create inner vis object controll-own.0.LEDLampe
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_124
    vis.js:3167 Create inner vis object controll-own.0.MOTION.SchalterFlurLicht
    vis.js:3167 Create inner vis object controll-own.0.KuechenLicht
    vis.js:3167 Create inner vis object controll-own.0.KuechenLichLight
    vis.js:3167 Create inner vis object controll-own.0.KuehlschrankTuer
    vis.js:3167 Create inner vis object controll-own.0.NACHTLAMPE
    vis.js:3167 Create inner vis object controll-own.0.RaspBerry-Helper.RaspiMain
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_151
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_73
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_29
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioZimmerBT
    vis.js:3167 Create inner vis object controll-own.0.NACHTKASTENLAMPE
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioZimmerBTonly
    vis.js:3167 Create inner vis object controll-own.0.LEDLangWLED
    vis.js:3167 Create inner vis object controll-own.0.KuehlschrankLicht
    vis.js:3167 Create inner vis object controll-own.0.MOTION.Standort
    vis.js:3167 Create inner vis object controll-own.0.RaspBerry-Helper.RaspiRefreshChrome
    vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerName
    vis.js:3167 Create inner vis object tr-064-community.0.callmonitor.inbound.caller
    vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerVorwahl
    vis.js:3167 Create inner vis object controll-own.0.SAT
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_99
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_82
    vis.js:3167 Create inner vis object mpd.0.title
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_34
    vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananePiPro
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_53
    vis.js:3167 Create inner vis object controll-own.0.HANDY.FlurAnwesenheit
    vis.js:3167 Create inner vis object dwd.0.warning.description
    vis.js:3167 Create inner vis object dwd.0.warning.headline
    vis.js:3167 Create inner vis object controll-own.0.TemperaturWidget
    vis.js:3167 Create inner vis object controll-own.0.MOTION.BADRein
    vis.js:3167 Create inner vis object controll-own.0.GastZugang
    vis.js:3167 Create inner vis object controll-own.0.HANDY.FritzCallHelpVis
    vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananeLAUTER
    vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananeLEISER
    vis.js:3167 Create inner vis object ical.1.data.html
    vis.js:3167 Create inner vis object openweathermap.0.forecast.current.temperature
    vis.js:3167 Create inner vis object openweathermap.0.forecast.day1.temperatureMax
    vis.js:3167 Create inner vis object sonoff.0.Sonoff16.BH1750_Illuminance
    vis.js:3167 Create inner vis object controll-own.0.HILDE.HildeDaheim
    vis.js:3167 Create inner vis object controll-own.0.Heizung30
    vis.js:3167 Create inner vis object controll-own.0.Heizung90
    vis.js:3167 Create inner vis object ical.0.data.html
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Datum
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.TotalText
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Alarm
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Name
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.MPDPlayAuswahl
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.MPDPlayList
    vis.js:3167 Create inner vis object mpd.0.pause
    vis.js:3167 Create inner vis object javascript.0.scriptEnabled.common.ExecuteLinuxMPDVolLauter
    vis.js:3167 Create inner vis object mpd.0.next
    vis.js:3167 Create inner vis object mpd.0.previous
    vis.js:3167 Create inner vis object tr-064.0.states.wlan24
    vis.js:3167 Create inner vis object iot.0.services.custom_hildeloc
    vis.js:3167 Create inner vis object openweathermap.0.forecast.current.icon
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Tage
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Stunden
    vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Minuten
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Sekunden
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Minuten
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Stunden
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Tage
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Sekunden
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Minuten
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Stunden
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Tage
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Start
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Start
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Start
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Stopp
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Reset
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Ausgabehilfe
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Stopp
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Reset
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Ausgabehilfe
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Reset
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Ende
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Stopp
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Ausgabehilfe
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Sekunden
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Minuten
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Stunden
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Tage
    vis.js:3167 Create inner vis object controll-own.0.mount.CPULuefter
    vis.js:3167 Create inner vis object controll-own.0.HeizungCounter
    vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.TimerZaehler
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.reached
    vis.js:3167 Create inner vis object countdown.0.setup.TV1
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.days
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.hours
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.minutes
    vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.months
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Fehler
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Orginal2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Orginal1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.MitStunden2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.MitStunden1
    vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerPicture
    vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerVisSichtbarkeit
    vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerGeraet
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.battery
    vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_73.Commands.screenOff
    vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.title
    vis.js:3167 Create inner vis object plex.0._playing._recent-player.event
    vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.file.name
    vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.thumb
    vis.js:3167 Create inner vis object plex.0._playing._recent-player.datetime
    vis.js:3167 Create inner vis object plex.0._playing.players
    vis.js:3167 Create inner vis object contact.0.photo
    vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.summary
    vis.js:3167 Create inner vis object view
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADLicht
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizluefter
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RM-MINI.L.HEIZLuefterEIN
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADAnwesenheit
    vis.js:3167 Create inner vis object arning.headline
    vis.js:3167 Create inner vis object controll-own.0.MOTION.BADaktiv
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizluefterSTEPs
    vis.js:3167 Create inner vis object mihome.0.devices.magnet_158d0001fa8b82.state
    vis.js:3167 Create inner vis object controll-own.0.MOTION.BADTuerHELP
    vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_42
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADHAUPTSCHALTER
    vis.js:3167 Create inner vis object controll-own.0.HANDY.t113load
    vis.js:3167 Create inner vis object controll-own.0.Lüfter4
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow3.POWER
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.volume
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioEcho
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.currentArtist
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RockAntenneTitle
    vis.js:3167 Create inner vis object sonoff.0.ShellyWC.POWER
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.targettemp
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.temp
    vis.js:3167 Create inner vis object openweathermap.0.forecast.current.precipitationSnow
    vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBad30
    vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBad90
    vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBadCounter
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizungCounter
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizung30
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizung90
    vis.js:3167 Create inner vis object controll-own.0.BAD.BADVisNeu
    vis.js:3167 Create inner vis object controll-own.0.HANDYKLINGELT
    vis.js:3167 Create inner vis object tr-064-community.0.callmonitor.ringing
    vis.js:3167 Create inner vis object trashschedule.0.type.BIOMÜLL.daysleft
    vis.js:3167 Create inner vis object trashschedule.0.type.PAPIER TONNE.daysleft
    vis.js:3167 Create inner vis object trashschedule.0.type.GELBER SACK.daysleft
    vis.js:3167 Create inner vis object trashschedule.0.type.RESTMÜLL.daysleft
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow3.ENERGY_Total
    vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.battery
    vis.js:3167 Create inner vis object alexa2.0.Smart-Home-Devices.a67645b2-910f-4dae-9c3c-6f606a98c95f.powerState
    vis.js:3167 Create inner vis object system.adapter.coronavirus-statistics.0.connected
    vis.js:3167 Create inner vis object coronavirus-statistics.0._Last_Update
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.recovered
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.critical
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.critical
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.recovered
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.critical
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.recovered
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.critical
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.recovered
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.recovered
    vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.deaths
    vis.js:3167 Create inner vis object rssfeed.0.IOBROKER
    vis.js:3167 Create inner vis object rssfeed.0.Formel1
    vis.js:3167 Create inner vis object rssfeed.0.Tagesschau
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.active
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.todayCases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.country
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.flag
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.country
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.flag
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.country
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.flag
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.country
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.flag
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.country
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.flag
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.active
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.todayCases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.active
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.todayCases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.active
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.todayCases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.cases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.active
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.todayCases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.deaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.critical
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.todayCases
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.recovered
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.todayDeaths
    vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.deaths
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSFeedZwitesFensterVIS
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RSSan
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelle
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelleFeed
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelle2VIS
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSFormelEINS2
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Power
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Current
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Voltage
    vis.js:3167 Create inner vis object nut.0.ups.load
    vis.js:3167 Create inner vis object nut.0.status.overload
    vis.js:3167 Create inner vis object nut.0.status.charging
    vis.js:3167 Create inner vis object nut.0.status.online
    vis.js:3167 Create inner vis object nut.0.ups.status
    vis.js:3167 Create inner vis object javascript.0.Datenpunkt.USV_laufzeit_in_Minuten
    vis.js:3167 Create inner vis object javascript.0.Datenpunkt.USV_laufzeit_in_Stunden
    vis.js:3167 Create inner vis object nut.0.battery.charge
    vis.js:3167 Create inner vis object nut.0.battery.voltage
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.RunSuccessful
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.OrdnerCheck
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.RunScript
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP_Factor
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.HTMLTable
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.HistoryAnalyse
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.SmartHomeAnalyse
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.MonsterSearch
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.WertAnalyse
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.TypeAnalyse
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.ObjectAnzahlCheck
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.ohneInstanzAnzeige
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.JavaInstanzCheck
    vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.CheckAliase
    vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.IPDevices_MD_Table
    vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.IPDevices_MD_List
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMaterialWidgetTable
    vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.missedFritzbox
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.EnergyMaterialWidgetTable
    vis.js:3167 Create inner vis object lgtv.0.states.volume
    vis.js:3167 Create inner vis object lgtv.0.remote.enter
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0913L0592570PHD.Player.controlPause
    vis.js:3167 Create inner vis object lgtv.0.states.channelDown
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0913L0592570PHD.Commands.deviceStop
    vis.js:3167 Create inner vis object lgtv.0.states.channelUp
    vis.js:3167 Create inner vis object lgtv.0.remote.cc
    vis.js:3167 Create inner vis object lgtv.0.remote.home
    vis.js:3167 Create inner vis object lgtv.0.remote.menu
    vis.js:3167 Create inner vis object lgtv.0.remote.left
    vis.js:3167 Create inner vis object lgtv.0.remote.right
    vis.js:3167 Create inner vis object lgtv.0.remote.exit
    vis.js:3167 Create inner vis object firetv.0.192_168_178_57.keys.back
    vis.js:3167 Create inner vis object firetv.0.192_168_178_57.keys.down
    vis.js:3167 Create inner vis object lgtv.0.remote.1
    vis.js:3167 Create inner vis object lgtv.0.remote.2
    vis.js:3167 Create inner vis object lgtv.0.remote.3
    vis.js:3167 Create inner vis object lgtv.0.remote.4
    vis.js:3167 Create inner vis object lgtv.0.remote.5
    vis.js:3167 Create inner vis object lgtv.0.remote.6
    vis.js:3167 Create inner vis object lgtv.0.remote.7
    vis.js:3167 Create inner vis object lgtv.0.remote.8
    vis.js:3167 Create inner vis object lgtv.0.remote.9
    vis.js:3167 Create inner vis object lgtv.0.remote.0
    vis.js:3167 Create inner vis object lgtv.0.remote.green
    vis.js:3167 Create inner vis object lgtv.0.remote.dash
    vis.js:3167 Create inner vis object lgtv.0.remote.blue
    vis.js:3167 Create inner vis object lgtv.0.remote.yellow
    vis.js:3167 Create inner vis object lgtv.0.remote.red
    vis.js:3167 Create inner vis object lgtv.0.states.mute
    vis.js:3167 Create inner vis object lgtv.0.states.popup
    vis.js:3167 Create inner vis object lgtv.0.states.turnOff
    vis.js:3167 Create inner vis object lgtv.0.states.input
    vis.js:3167 Create inner vis object lgtv.0.states.currentApp
    vis.js:3167 Create inner vis object lgtv.0.states.soundOutput
    vis.js:3167 Create inner vis object lgtv.0.states.3Dmode
    vis.js:3167 Create inner vis object lgtv.0.states.model
    vis.js:3167 Create inner vis object lgtv.0.info.connection
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVall
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVFlexAnzeige
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVjetzt
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVgleich
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TV2015
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TV2200
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.ALEXAToDo
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.Meisterschaft
    vis.js:3167 Create inner vis object 0_userdata.0.testmailvis
    vis.js:3167 Create inner vis object javascript.0.Tabellen.Web-Speedy-Test.VISAnzeige
    vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.PingAdapter
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestHTML
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-INFO
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.ARIVA1-WEITER
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-ZURUECK
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-OK
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-OBEN
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-HDMI
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-SOURCE
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-RECHTS
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-LINKS
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-PLAY
    vis.js:3167 Create inner vis object controll-own.0.TVLeiser
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-STOP
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-PAUSE
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-EXIT
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-MENU
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RETURN
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-2
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-1
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-3
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-4
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-5
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-6
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-7
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-8
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-9
    vis.js:3167 Create inner vis object scene.AVIRA1-PRO-10
    vis.js:3167 Create inner vis object scene.AVIRA1-PRO-14
    vis.js:3167 Create inner vis object scene.AVIRA1-PRO-15
    vis.js:3167 Create inner vis object scene.AVIRA1-PRO-16
    vis.js:3167 Create inner vis object scene.AVIRA1-PRO-18
    vis.js:3167 Create inner vis object scene.AVIRA1-PRO-13
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-MUTE
    vis.js:3167 Create inner vis object controll-own.0.TVLauter
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-UNTEN
    vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVLauter
    vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVLeiser
    vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVBack
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-MUTE
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-ON
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-AUX1
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-AUX2
    vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-BLUET
    vis.js:3167 Create inner vis object system.adapter.yamaha.0.connected
    vis.js:3167 Create inner vis object system.adapter.web.0.connected
    vis.js:3167 Create inner vis object system.adapter.upnp.0.connected
    vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.connected
    vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.connected
    vis.js:3167 Create inner vis object system.adapter.socketio.0.alive
    vis.js:3167 Create inner vis object system.adapter.socketio.0.connected
    vis.js:3167 Create inner vis object system.adapter.snmp.0.connected
    vis.js:3167 Create inner vis object system.adapter.simple-api.0.connected
    vis.js:3167 Create inner vis object system.adapter.scenes.0.connected
    vis.js:3167 Create inner vis object system.adapter.ping.0.connected
    vis.js:3167 Create inner vis object system.adapter.node-red.0.connected
    vis.js:3167 Create inner vis object system.adapter.musiccast.0.connected
    vis.js:3167 Create inner vis object system.adapter.meross.0.connected
    vis.js:3167 Create inner vis object kodi.0.info.connection
    vis.js:3167 Create inner vis object system.adapter.javascript.0.alive
    vis.js:3167 Create inner vis object system.adapter.javascript.0.connected
    vis.js:3167 Create inner vis object system.adapter.iot.0.connected
    vis.js:3167 Create inner vis object system.adapter.info.0.connected
    vis.js:3167 Create inner vis object system.adapter.ical.2.alive
    vis.js:3167 Create inner vis object system.adapter.ical.1.alive
    vis.js:3167 Create inner vis object system.adapter.ical.0.alive
    vis.js:3167 Create inner vis object system.adapter.hs100.0.connected
    vis.js:3167 Create inner vis object hm-rpc.1.info.connection
    vis.js:3167 Create inner vis object hm-rpc.0.info.connection
    vis.js:3167 Create inner vis object hm-rega.0.info.connection
    vis.js:3167 Create inner vis object system.adapter.history.0.connected
    vis.js:3167 Create inner vis object system.adapter.firetv.0.connected
    vis.js:3167 Create inner vis object system.adapter.email.0.connected
    vis.js:3167 Create inner vis object system.adapter.daswetter.0.alive
    vis.js:3167 Create inner vis object cloud.0.info.connection
    vis.js:3167 Create inner vis object system.adapter.backitup.0.connected
    vis.js:3167 Create inner vis object alexa2.0.info.connection
    vis.js:3167 Create inner vis object system.adapter.admin.0.alive
    vis.js:3167 Create inner vis object system.adapter.admin.0.connected
    vis.js:3167 Create inner vis object admin.0.info.lastUpdateCheck
    vis.js:3167 Create inner vis object system.adapter.iogo.0.connected
    vis.js:3167 Create inner vis object system.host.Medion(Test).alive
    vis.js:3167 Create inner vis object system.adapter.admin.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.admin.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.admin.0.memRss
    vis.js:3167 Create inner vis object system.adapter.javascript.0.memRss
    vis.js:3167 Create inner vis object system.adapter.javascript.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.javascript.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.javascript.0.uptime
    vis.js:3167 Create inner vis object system.adapter.socketio.0.memRss
    vis.js:3167 Create inner vis object system.adapter.socketio.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.socketio.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.socketio.0.uptime
    vis.js:3167 Create inner vis object system.adapter.web.0.alive
    vis.js:3167 Create inner vis object system.adapter.web.0.memRss
    vis.js:3167 Create inner vis object system.adapter.web.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.web.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.web.0.uptime
    vis.js:3167 Create inner vis object system.adapter.history.0.alive
    vis.js:3167 Create inner vis object system.adapter.history.0.memRss
    vis.js:3167 Create inner vis object system.adapter.history.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.history.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.history.0.uptime
    vis.js:3167 Create inner vis object system.adapter.backitup.0.alive
    vis.js:3167 Create inner vis object system.adapter.backitup.0.memRss
    vis.js:3167 Create inner vis object system.adapter.backitup.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.backitup.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.backitup.0.uptime
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.alive
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.alive
    vis.js:3167 Create inner vis object system.adapter.hm-rega.0.alive
    vis.js:3167 Create inner vis object system.adapter.hm-rega.0.uptime
    vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memRss
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memRss
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.uptime
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memRss
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.uptime
    vis.js:3167 Create inner vis object system.adapter.ical.0.memRss
    vis.js:3167 Create inner vis object system.adapter.ical.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.ical.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.ical.0.uptime
    vis.js:3167 Create inner vis object system.adapter.ical.1.memRss
    vis.js:3167 Create inner vis object system.adapter.ical.1.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.ical.1.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.ical.1.uptime
    vis.js:3167 Create inner vis object system.adapter.ical.2.memRss
    vis.js:3167 Create inner vis object system.adapter.ical.2.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.ical.2.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.ical.2.uptime
    vis.js:3167 Create inner vis object system.adapter.iot.0.alive
    vis.js:3167 Create inner vis object system.adapter.cloud.0.alive
    vis.js:3167 Create inner vis object system.adapter.alexa2.0.alive
    vis.js:3167 Create inner vis object system.adapter.alexa2.0.uptime
    vis.js:3167 Create inner vis object system.adapter.alexa2.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.alexa2.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.alexa2.0.memRss
    vis.js:3167 Create inner vis object system.adapter.cloud.0.memRss
    vis.js:3167 Create inner vis object system.adapter.cloud.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.cloud.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.cloud.0.uptime
    vis.js:3167 Create inner vis object system.adapter.iot.0.memRss
    vis.js:3167 Create inner vis object system.adapter.iot.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.iot.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.iot.0.uptime
    vis.js:3167 Create inner vis object system.adapter.ping.0.alive
    vis.js:3167 Create inner vis object system.adapter.ping.0.memRss
    vis.js:3167 Create inner vis object system.adapter.ping.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.ping.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.ping.0.uptime
    vis.js:3167 Create inner vis object system.adapter.simple-api.0.alive
    vis.js:3167 Create inner vis object system.adapter.simple-api.0.memRss
    vis.js:3167 Create inner vis object system.adapter.simple-api.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.simple-api.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.simple-api.0.uptime
    vis.js:3167 Create inner vis object system.host.Medion(Test).memRss
    vis.js:3167 Create inner vis object system.host.Medion(Test).memHeapUsed
    vis.js:3167 Create inner vis object system.host.Medion(Test).memHeapTotal
    vis.js:3167 Create inner vis object system.host.Medion(Test).uptime
    vis.js:3167 Create inner vis object system.adapter.iogo.0.alive
    vis.js:3167 Create inner vis object system.adapter.email.0.alive
    vis.js:3167 Create inner vis object system.adapter.info.0.alive
    vis.js:3167 Create inner vis object system.adapter.info.0.uptime
    vis.js:3167 Create inner vis object system.adapter.info.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.info.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.info.0.memRss
    vis.js:3167 Create inner vis object system.adapter.email.0.memRss
    vis.js:3167 Create inner vis object system.adapter.email.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.email.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.email.0.uptime
    vis.js:3167 Create inner vis object system.adapter.iogo.0.memRss
    vis.js:3167 Create inner vis object system.adapter.iogo.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.iogo.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.iogo.0.uptime
    vis.js:3167 Create inner vis object system.adapter.yamaha.0.alive
    vis.js:3167 Create inner vis object system.adapter.yamaha.0.memRss
    vis.js:3167 Create inner vis object system.adapter.yamaha.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.yamaha.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.yamaha.0.uptime
    vis.js:3167 Create inner vis object system.adapter.musiccast.0.alive
    vis.js:3167 Create inner vis object system.adapter.musiccast.0.memRss
    vis.js:3167 Create inner vis object system.adapter.musiccast.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.musiccast.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.musiccast.0.uptime
    vis.js:3167 Create inner vis object system.adapter.upnp.0.alive
    vis.js:3167 Create inner vis object system.adapter.upnp.0.memRss
    vis.js:3167 Create inner vis object system.adapter.upnp.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.upnp.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.upnp.0.uptime
    vis.js:3167 Create inner vis object system.adapter.firetv.0.alive
    vis.js:3167 Create inner vis object system.adapter.kodi.0.alive
    vis.js:3167 Create inner vis object system.adapter.kodi.0.uptime
    vis.js:3167 Create inner vis object system.adapter.kodi.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.kodi.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.kodi.0.memRss
    vis.js:3167 Create inner vis object system.adapter.firetv.1.memRss
    vis.js:3167 Create inner vis object system.adapter.firetv.1.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.firetv.1.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.firetv.1.uptime
    vis.js:3167 Create inner vis object system.adapter.daswetter.0.memRss
    vis.js:3167 Create inner vis object system.adapter.daswetter.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.daswetter.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.daswetter.0.uptime
    vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.alive
    vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memRss
    vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.uptime
    vis.js:3167 Create inner vis object system.adapter.snmp.0.alive
    vis.js:3167 Create inner vis object system.adapter.snmp.0.memRss
    vis.js:3167 Create inner vis object system.adapter.snmp.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.snmp.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.snmp.0.uptime
    vis.js:3167 Create inner vis object system.adapter.scenes.0.alive
    vis.js:3167 Create inner vis object system.adapter.scenes.0.memRss
    vis.js:3167 Create inner vis object system.adapter.scenes.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.scenes.0.uptime
    vis.js:3167 Create inner vis object system.adapter.hs100.0.alive
    vis.js:3167 Create inner vis object system.adapter.meross.0.alive
    vis.js:3167 Create inner vis object system.adapter.node-red.0.alive
    vis.js:3167 Create inner vis object system.adapter.node-red.0.uptime
    vis.js:3167 Create inner vis object system.adapter.node-red.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.node-red.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.node-red.0.memRss
    vis.js:3167 Create inner vis object system.adapter.meross.0.memRss
    vis.js:3167 Create inner vis object system.adapter.meross.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.meross.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.meross.0.uptime
    vis.js:3167 Create inner vis object system.adapter.hs100.0.memRss
    vis.js:3167 Create inner vis object system.adapter.hs100.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.hs100.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.hs100.0.uptime
    vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.alive
    vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memRss
    vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.uptime
    vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.alive
    vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memRss
    vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.uptime
    vis.js:3167 Create inner vis object system.adapter.iqontrol.0.alive
    vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memRss
    vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memHeapUsed
    vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memHeapTotal
    vis.js:3167 Create inner vis object system.adapter.iqontrol.0.uptime
    vis.js:3167 Create inner vis object system.adapter.iqontrol.0.connected
    vis.js:3167 Create inner vis object controll-own.0._MenuVisView8-BACK
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestHTMLAuswahlDelete
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuAlarm
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.Anlegen
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDelete
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDeleteWerte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDeleteTexte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.Anlegen
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.Anzahl
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.Anzahl
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.DeleteALL
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.DeleteALL
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.SONOFF
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AKKU
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.ENERGY
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMeessage
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TabellenFlexible
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.BackItUp
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AlexaSmartDevices
    vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AnzahlSonoff
    vis.js:3167 Create inner vis object 0_userdata.0.Akkuskript.VISTabelle
    vis.js:3167 Create inner vis object sonoff.0.SonoffPow1.ENERGY_Total
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.TVProgramm
    vis.js:3167 Create inner vis object system.adapter.systeminfo.0.connected
    vis.js:3167 Create inner vis object javascript.0.Park.StringHTML
    vis.js:3167 Create inner vis object javascript.0.Netzwerk.StringHTML
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Title
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Event
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.FileName
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Summary
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Thumb
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Change
    vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Player
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_ClientsOnlyWLAN
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Pause
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Clients_Anzahl
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUbyJSController
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_DeleteVIS
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CodeList2
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.WLAN_DragonRootGuest
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_Delete_Voucher.Delete
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Info
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CreateStandard
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CreateListStandard
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Create
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.WLAN_DragonRoot1
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Dauer
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Anzahl
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.MultiUse
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Mb_Begrenzung
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Download
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Upload
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Notiz
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.SiteLED
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Alarm.Alarm
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Alarm.Alarm_Anzahl
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Clients_Log
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.xxxScriptVersionxxx
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Missing_Name
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.ZyklusZaehler
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Client_WhiteList
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_ClientsOnlyDISC
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferBefore.Before_Uplink_RX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferBefore.Before_Uplink_TX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferMonth.Month_Uplink_RX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferMonth.Month_Uplink_TX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferDaily.Uplink_RX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferDaily.Uplink_TX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.Galaxy-S9
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.GalaxyTabS2
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.GalaxyTabS2
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.Galaxy-S9
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.MediaTabT5
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.FireTablet7
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.FireTablet7
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.TrekStor13
    vis.js:3167 Create inner vis object javascript.0.VoucherKinder.LastSend
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Satisfaction
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Model
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Adopted
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.IP_Adresse
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.ToController
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Satisfaction
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Model
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Adopted
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.IP_Adresse
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.ToController
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.AliasName
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUbyJSAdapter
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUIdleALL
    vis.js:3167 Create inner vis object system.adapter.enigma2.0.connected
    vis.js:3167 Create inner vis object system.adapter.lgtv.0.connected
    vis.js:3167 Create inner vis object system.adapter.amazon-dash.0.connected
    vis.js:3167 Create inner vis object system.adapter.plex.0.connected
    vis.js:3167 Create inner vis object system.adapter.pi-hole.0.connected
    vis.js:3167 Create inner vis object system.adapter.mpd.0.connected
    vis.js:3167 Create inner vis object system.adapter.mihome.0.connected
    vis.js:3167 Create inner vis object system.adapter.sayit.0.connected
    vis.js:3167 Create inner vis object system.adapter.fritzdect.0.connected
    vis.js:3167 Create inner vis object system.adapter.fritzdect.1.connected
    vis.js:3167 Create inner vis object system.adapter.proxmox.0.connected
    vis.js:3167 Create inner vis object system.adapter.unifi.0.connected
    vis.js:3167 Create inner vis object system.adapter.fullybrowser.0.connected
    vis.js:3167 Create inner vis object system.adapter.mclighting.0.connected
    vis.js:3167 Create inner vis object system.adapter.sonoff.0.connected
    vis.js:3167 Create inner vis object system.adapter.pushbullet.0.connected
    vis.js:3167 Create inner vis object system.adapter.sql.0.connected
    vis.js:3167 Create inner vis object system.adapter.pushbullet.1.connected
    vis.js:3167 Create inner vis object javascript.0.Ereignisliste.heute.eventlistHTML
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapTable
    vis.js:3167 Create inner vis object controll-own.0.FUTRO.DevicesIP
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.DiskTable
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.HightCpuProcess
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.NFSExports
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapAlarm
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.MemoryAlarm
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.GetProcessJetzt
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.GetProcessFilter
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.ProcessTable
    vis.js:3167 Create inner vis object javascript.0.GETPROCESS.AlarmCPURunLevel
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootSQLTulla
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootProxmox
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootPlexServer
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootPiHole
    vis.js:3167 Create inner vis object controll-own.0.mount.DiskHelpRootFileserver
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Update
    vis.js:3167 Create inner vis object hm-rpc.0.IEQ0007259.1.STATE
    vis.js:3167 Create inner vis object hm-rpc.0.KEQ0193137.1.STATE
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Temperatur
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Temperatur_Farbe
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.aktiv_parse
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.Load
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.Speicher
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.aktiv_parse
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Speicher
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.Interface
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.FTL
    vis.js:3167 Create inner vis object javascript.2.scriptEnabled.common.VIS.VIS_Pihole_Info
    vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.Pihole
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.TimerResetVIS
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Minuten
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Minuten
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.SummeMinuten2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Sekunden
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Name2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Finished
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Gerät2
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Gerät1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.SummeMinuten1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Finished
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Name1
    vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Sekunden
    vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestZahlPx
    vis.js:3167 Create inner vis object javascript.0.logik.gästebadLicht.bewegungGästebad
    vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_Anzahl
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.Midnight_Uplink_RX
    vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.Midnight_Uplink_TX
    vis.js:3167 Create inner vis object system.adapter.tr-064.1.connected
    vis.js:3167 Create inner vis object system.adapter.tr-064.0.connected
    vis.js:3167 Create inner vis object snmp.1.info.connection
    vis.js:3167 Create inner vis object system.adapter.snmp.1.alive
    vis.js:3167 Create inner vis object snmp.0.info.connection
    vis.js:3167 Create inner vis object system.adapter.rpi2.0.connected
    vis.js:3167 Create inner vis object system.adapter.radar.0.connected
    vis.js:3167 Create inner vis object system.adapter.pushover.0.connected
    vis.js:3167 Create inner vis object system.adapter.paw.0.connected
    vis.js:3167 Create inner vis object system.adapter.paw.0.alive
    vis.js:3167 Create inner vis object mihome-vacuum.0.info.connection
    vis.js:3167 Create inner vis object mihome.0.devices.gateway_7c49eb88c200.connected
    vis.js:3167 Create inner vis object system.adapter.pushbullet.1.alive
    vis.js:3167 Create inner vis object fritzbox.0.system.deltaTimeOK
    vis.js:3167 Create inner vis object javascript.0.Log-Script.logProtokol.logJSON
    vis.js:3167 Create inner vis object javascript.0.Log-Script.logAlexaueberwachung.clearJSON
    vis.js:3167 Create inner vis object javascript.1.mylog.logAllJSON
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.volume
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.currentArtist
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.volume
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.ALLradioALL
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.7dbdc61535fd4214b45ee26d40f00370.Player.currentArtist
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.currentArtist
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.volume
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioKueche
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.currentArtist
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioEchoPlus
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.volume
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.currentArtist
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.providerId
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.currentTitle
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.volume
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioFlur
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.currentArtist
    vis.js:3167 Create inner vis object controll-own.0.RADIOs.EchoShow5Radio
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.volume
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentArtist
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentState
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentTitle
    vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.providerId
    vis.js:3167 Create inner vis object trashschedule.0.type.KrankSchreibung.daysleft
    vis.js:3167 Create inner vis object controll-own.0.MOTION.StandortALT
    vis.js:3167 Create inner vis object controll-own.0.MOTION.StandortALT2
    vis.js:3167 Create inner vis object ping.0.iobroker59.www_google_com
    vis.js:3167 Create inner vis object ping.0.raspberry3.www_google_com
    vis.js:3167 Create inner vis object controll-own.0.mount.CPUTemp
    vis.js:3167 Create inner vis object javascript.0.CountdownPapierTonne.Termin.Rest.Tage
    vis.js:3167 Create inner vis object javascript.0.Speed-Test.data.speeds.download
    vis.js:3167 Create inner vis object tcontroll-own.0.Banane
    vis.js:3167 Create inner vis object trashschedule.1.type.Gelber Sack.daysleft
    vis.js:3167 Create inner vis object trashschedule.1.type.Biomüll.daysleft
    vis.js:3167 Create inner vis object trashschedule.1.type.Restmüll.daysleft
    vis.js:3167 Create inner vis object trashschedule.1.type.Papiertonne.daysleft
    vis.js:3167 Create inner vis object javascript.0.Log-Script.Loganzeige
    vis.js:3167 Create inner vis object web-speedy.0.Results.speeds.download_Mb
    vis.js:3167 Create inner vis object web-speedy.0.Results.speeds.upload_Mb
    vis.js:3167 Create inner vis object trashschedule.0.type.json
    vis.js:3167 Create inner vis object javascript.0.wled.farbe
    vis.js:3167 Create inner vis object javascript.0.wled.effekt
    vis.js:3167 Create inner vis object wled.0.a020a61bbd2c.seg.0.sx
    vis.js:3167 Create inner vis object wled.0.a020a61bbd2c.seg.0.ix
    vis.js:3167 Create inner vis object javascript.0.wled.brightness
    vis.js:3167 Create inner vis object javascript.0.wled.toggle
    vis.js:3167 Create inner vis object javascript.0.wled.palette
    vis.js:3167 Create inner vis object javascript.0.wled.preset
    vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.Alarm
    vis.js:3167 Create inner vis object calendar.0.YXJtaW4uc2xpdmluc2t5QGdtYWlsLm
    vis.js:3167 Create inner vis object calendar.0.YWRkcmVzc2Jvb2sjY29udGFjdHNAZ3
    vis.js:3167 Create inner vis object calendar.0.ZGUuZ2VybWFuI2hvbGlkYXlAZ3JvdX
    vis.js:3167 Create inner vis object calendar.0.cCN3ZWF0aGVyQGdyb3VwLnYuY2FsZW
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.DeleteALL
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.Anzahl
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDelete
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDeleteWerte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDeleteTexte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.Anlegen
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.ALEXAEinkauf
    vis.js:3167 Create inner vis object fritzdect.2.Comet_099950281871.targettemp
    vis.js:3167 Create inner vis object fritzdect.2.Comet_099950284772.targettemp
    vis.js:3167 Create inner vis object fritzdect.2.Comet_099950280789.targettemp
    vis.js:3167 Create inner vis object fritzdect.2.Comet_099950281871.actualtemp
    vis.js:3167 Create inner vis object fritzdect.2.Comet_099950280789.actualtemp
    vis.js:3167 Create inner vis object fritzdect.2.Comet_099950284772.actualtemp
    vis.js:3167 Create inner vis object controll-own.0.HILDE.SQLHilde
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.ALEXAToDo
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.Anlegen
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDelete
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDeleteWerte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDeleteTexte
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.DeleteALL
    vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.Anzahl
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Mail
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Fax
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Telefon
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Adresse
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Name
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Datum
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Änderung zum Vortag
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Trend zum Vortag
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettopreis Gesamt
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettozuschlag Gesamt
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.MwSt Gesamt
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Bruttopreis Gesamt
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettopreis 100l
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettozuschlag 100l
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.MwSt 100l
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Entladestellen
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Heizölsorte ID
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Zahlungsart ID
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Lieferort
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Liefermenge
    vis.js:3167 Create inner vis object javascript.0.Heizoel.Skriptstart
    :8072/vis/index.html?galaxy#99Whatsapp:1 A cookie associated with a cross-site resource at http://www.zeitverschiebung.net/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
    :8072/vis/index.html?galaxy#99Whatsapp:1 A cookie associated with a cross-site resource at http://zeitverschiebung.net/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
    DevTools failed to parse SourceMap: chrome-extension://iemadiahhbebdklepanmkjenfdebfpfe/static/js/main.6e6198ed.js.map
    hqwidgets.js:902 Version vis-hqwidgets: 1.1.4
    bars.js:55 Version vis-bars:0.1.4
    undefined:1 GET http://192.168.178.59:8072/vis/undefined 404 (Not Found)
    Image (async)
    l @ can.custom.min.js:20
    e.buildFragment @ can.custom.min.js:20
    n.frag @ can.custom.min.js:14
    fragment @ can.custom.min.js:58
    frag @ can.custom.min.js:58
    r @ can.custom.min.js:58
    renderTo @ can.custom.min.js:58
    renderAs @ can.custom.min.js:58
    e.view.e.template @ can.custom.min.js:58
    renderWidget @ vis.js:1610
    (anonymous) @ vis.js:887
    (anonymous) @ vis.js:2742
    (anonymous) @ conn.js:730
    r.onack @ index.js:83
    r.onpacket @ index.js:83
    (anonymous) @ index.js:83
    r.emit @ index.js:83
    r.ondecoded @ index.js:83
    a.add @ index.js:83
    r.ondata @ index.js:83
    r.onPacket @ index.js:83
    r.onData @ index.js:83
    ws.onmessage @ index.js:83
    VM19719:1 Uncaught SyntaxError: Unexpected token u in JSON at position 0
       at JSON.parse (<anonymous>)
       at Object.redraw (trashschedule.js:170)
       at Object.createWidget (trashschedule.js:36)
       at trashschedule.js:31
    redraw @ trashschedule.js:170
    createWidget @ trashschedule.js:36
    (anonymous) @ trashschedule.js:31
    setTimeout (async)
    createWidget @ trashschedule.js:30
    eval @ tplTrashscheduleHelper.js:24
    n.render @ can.custom.min.js:76
    t.template.fn @ can.custom.min.js:76
    subscribeStates @ vis.js:2745
    renderView @ vis.js:799
    renderViews @ vis.js:761
    (anonymous) @ vis.js:917
    a.add @ index.js:83
    Show 6 more frames
    widgets.min.js:3 [Line History Chart w02261] widget setting: {"_data":{"wid":"w02261","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"0","visibility-groups-action":"hide","dataCount":"0","aggregate":"average","timeIntervalToShow":"8 hours","refreshMethod":"realtime","refreshTimeInterval":"5 minutes","pointStyle":"line","showLegend":true,"legendPosition":"right","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"true","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.0","oid0":"sonoff.0.Sonoff15.AM2301_Temperature","visibility-oid":"controll-own.0.TV","legendFontColor":"#13f138","dataColor0":"#13f138","xAxisValueLabelColor":"#13f138","yAxisValueLabelColor":"#7bf990","xAxisMaxLabel":"5","yAxisMinValue0":"0","yAxisMaxValue0":"30","yAxisValueMinDigits0":"0","yAxisMaxLabel0":"","lineTension0":"0","lineThikness0":"1","xAxisTitleFontSize":"8","xAxisOffsetGridLines":false,"pointSize":"20","yAxisStep0":"5","yAxisZeroLineWidth0":"","chartPaddingBottom":"10","mdwDebug":true},"_cid":".map9063","_computedAttrs":{},"wid":"w02261","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"0","visibility-groups-action":"hide","dataCount":"0","aggregate":"average","timeIntervalToShow":"8 hours","refreshMethod":"realtime","refreshTimeInterval":"5 minutes","pointStyle":"line","showLegend":true,"legendPosition":"right","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"true","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.0","oid0":"sonoff.0.Sonoff15.AM2301_Temperature","visibility-oid":"controll-own.0.TV","legendFontColor":"#13f138","dataColor0":"#13f138","xAxisValueLabelColor":"#13f138","yAxisValueLabelColor":"#7bf990","xAxisMaxLabel":"5","yAxisMinValue0":"0","yAxisMaxValue0":"30","yAxisValueMinDigits0":"0","yAxisMaxLabel0":"","lineTension0":"0","lineThikness0":"1","xAxisTitleFontSize":"8","xAxisOffsetGridLines":false,"pointSize":"20","yAxisStep0":"5","yAxisZeroLineWidth0":"","chartPaddingBottom":"10","mdwDebug":true,"_bubbleBindings":{},"__bindEvents":{"class":[{"name":"class"}],"backgroundColor":[{"name":"backgroundColor"}],"wid":[{"name":"wid"}]},"_bindings":3}
    widgets.min.js:4 [getTaskForHistoryData w02261] history options for 'sonoff.0.Sonoff15.AM2301_Temperature': {"instance":"sql.0","count":100,"aggregate":"average","start":1586062096052,"end":1586090896053,"timeout":2000}
    widgets.min.js:4 [getTaskForHistoryData w02261] history data result 'sonoff.0.Sonoff15.AM2301_Temperature' length: 69
    widgets.min.js:4 [getTaskForHistoryData w02261] history data result 'sonoff.0.Sonoff15.AM2301_Temperature': [{"ts":1586062096052,"val":null},{"ts":1586068576052,"val":null},{"ts":1586071168052,"val":9.1},{"ts":1586071456052,"val":9.15},{"ts":1586071744052,"val":9.27},{"ts":1586072032052,"val":9.45},{"ts":1586072320052,"val":9.55},{"ts":1586072608052,"val":9.65},{"ts":1586072896052,"val":9.75},{"ts":1586073184052,"val":9.9},{"ts":1586073472052,"val":10.05},{"ts":1586073760052,"val":10.2},{"ts":1586074048052,"val":10.3},{"ts":1586074336052,"val":10.43},{"ts":1586074624052,"val":10.57},{"ts":1586074912052,"val":10.75},{"ts":1586075200052,"val":10.9},{"ts":1586075488052,"val":11},{"ts":1586075776052,"val":11.25},{"ts":1586076064052,"val":11.63},{"ts":1586076352052,"val":11.93},{"ts":1586076640053,"val":12.13},{"ts":1586076928053,"val":12.3},{"ts":1586077216053,"val":12.45},{"ts":1586077504053,"val":12.5},{"ts":1586077792053,"val":12.65},{"ts":1586078080053,"val":12.85},{"ts":1586078368053,"val":13.2},{"ts":1586078656053,"val":13.17},{"ts":1586078944053,"val":13.05},{"ts":1586079232053,"val":13.13},{"ts":1586079520053,"val":13.4},{"ts":1586079808053,"val":13.63},{"ts":1586080096053,"val":13.83},{"ts":1586080384053,"val":13.9},{"ts":1586080672053,"val":13.97},{"ts":1586080960053,"val":14.1},{"ts":1586081248053,"val":14.23},{"ts":1586081536053,"val":14.3},{"ts":1586081824053,"val":14.43},{"ts":1586082112053,"val":14.55},{"ts":1586082400053,"val":14.6},{"ts":1586082688053,"val":14.7},{"ts":1586082976053,"val":14.8},{"ts":1586083264053,"val":14.85},{"ts":1586083840053,"val":14.97},{"ts":1586084128053,"val":15.13},{"ts":1586084416053,"val":15.13},{"ts":1586084704053,"val":null},{"ts":1586084992053,"val":null},{"ts":1586085280053,"val":14.97},{"ts":1586085568053,"val":14.97},{"ts":1586085856053,"val":15.13},{"ts":1586086144053,"val":15.23},{"ts":1586086432053,"val":15.23},{"ts":1586086720053,"val":null},{"ts":1586087008053,"val":null},{"ts":1586087296053,"val":15.65},{"ts":1586087584053,"val":15.8},{"ts":1586087872053,"val":15.67},{"ts":1586088160053,"val":15.65},{"ts":1586088448053,"val":15.75},{"ts":1586088736053,"val":15.87},{"ts":1586089024053,"val":16},{"ts":1586089312053,"val":16.2},{"ts":1586089600053,"val":16.3},{"ts":1586089888053,"val":16.37},{"ts":1586090464053,"val":16.35},{"ts":1586090752053,"val":16.5}]
    widgets.min.js:3 [Line History Chart w02261] promise all datasets - count: 1
    widgets.min.js:4 [getPreparedData w02261] prepare data for 'sonoff.0.Sonoff15.AM2301_Temperature' length: 69
    widgets.min.js:3 [Line History Chart w02261] prepare dataset for 'sonoff.0.Sonoff15.AM2301_Temperature'
    widgets.min.js:3 [Line History Chart w02261] prepare yAxis for 'sonoff.0.Sonoff15.AM2301_Temperature'
    widgets.min.js:3 [Line History Chart w02261] prepare chart options
    widgets.min.js:3 [Line History Chart w02261] chart creating...
    widgets.min.js:3 [Line History Chart w02261] chart successful created
    :8072/vis/index.html?galaxy#99Whatsapp:1 A cookie associated with a cross-site resource at http://www.tagesschau.de/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    #890
    @liv-in-sky sagte in Test Adapter Material Design Widgets v0.2.x:
    und noch ein log - mit funktionierendem widget
    @sigi234 sagte in Test Adapter Material Design Widgets v0.2.x:
    Jetzt keine mehr! 👍
    Perfekt, obwohl ich echt verwundert bin, dann war der meiner Meinung nach Schönheitsfehler im Code wohl die Ursache.
    Dann lad ich es heute abend mal ins latest.
    • ScroungerS Scrounger
      Jetzt keine mehr! 👍
      liv-in-skyL Offline
      liv-in-skyL Offline
      #891
      @Scrounger wenn du gerne fehler suchst, probier mal den brave browser aus, ob es bei dir funktioniert :-) weder runtime noch editor zeigen es unter brave bei mir an (vielleicht stört auch irgendeine erweiterung?)
      firefox und opera zeigen es bei mir an - auch fully browser auf android und auch - verwunderung - brave mit android funktioniert
      ScroungerS 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #892
        ne eigentlich nicht, aber druck wurde zu groß den Fehler endlich mal für euch zu beheben 😁
          @Chris-Tailor, @liv-in-sky, @stockics6, @sigi234, @Coffeelover
          Neuer Versuch Eure Fehler mit dem Line Chart Widget zu fixen.
          Ich hab jetzt einen Debug Modus für das Line Chart Widget hinzugefügt.
          Bitte testet die aktuelle Version von git -> v0.2.77.
          Schaltet den Debug Modus an (unter Allgemein) und reproduziert Eure fehler.
          Hier dann das vollständige consolen log zur runtime vom browser (F12 -> Reiter 'Console') posten - keine Screenshots!!!!
          Ich benötige zwingend die log Infos, weil ich den Fehler bei mir nicht repsoduzieren kann.
          Chris TailorC Offline
          Chris Tailor
          schrieb am zuletzt editiert von Chris Tailor
          #893
          @Scrounger Besten Dank
          Hier das Console Log:
          [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
          index.html?smarthub:3408 Version vis-canvas-gauges: 0.1.5
          index.html?smarthub:3948 Version vis-colorpicker: 1.0.1
          index.html?smarthub:5374 Version vis-history: 1.0.0
          info.js:9 Version Info-Adapter-Widget: 0.0.8
          keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
          index.html?smarthub:8340 Version vis-map: 1.0.3
          DevTools failed to parse SourceMap: http://192.168.86.90:8082/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
          materialdesign.js:25 Version vis-materialdesign: 0.2.77
          lib.min.js:22 Download the Vue Devtools extension for a better development experience:
          https://github.com/vuejs/vue-devtools
          lib.min.js:22 You are running Vue in development mode.
          Make sure to turn on production mode when deploying for production.
          See more tips at https://vuejs.org/guide/deployment.html
          players.js:58 Version players: 0.1.0
          conn.js:273 2020-04-06T04:26:34.511Z Connected => authenticate
          conn.js:293 2020-04-06T04:26:35.096Z Authenticated: true
          vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40083_Batterie_SOC
          vis.js:3167 Create inner vis object javascript.0.adapterdatenpunkte.modbus.Autarkie
          vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40068_PV_Leistung
          vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung
          widgets.min.js:3 [Line History Chart w00477] widget setting: {"_data":{"wid":"w00477","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"1","aggregate":"minmax","timeIntervalToShow":"2 hours","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"center","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"bottom","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"influxdb.0","oid0":"modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung","oid1":"modbus.0.holdingRegisters.40068_PV_Leistung","lineSpanGaps2":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showValues2":"true","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","lineSpanGaps3":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showValues3":"true","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"true","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","legendText0":"Hausverbrauch W","legendText1":"PV Leistung W","dataColor1":"#F3FFBD","dataColor0":"#B2DBBF","useFillColor0":true,"useFillColor1":true,"fillColor1":"","fillColor0":"","yAxisGridLinesColor1":"","yAxisValueColor1":"","yAxisGridLinesColor0":"white","yAxisValueColor0":"white","yAxisValueLabelColor":"#ffffff","yAxisTitleColor":"#ffffff","xAxisTitleColor":"","xAxisValueLabelColor":"#ffffff","time_interval_oid":"0_userdata.0.vis.Timeinterval_iSpeed","legendFontColor":"white","maxDataPoints":"100","commonYAxis0":"1","commonYAxis1":"1","colorScheme":"scrounger.pie","legendFontSize":"20","legendFontFamily":"Jura-Light","legendBoxWidth":"8","legendPadding":"","lineTension0":"","valuesMaxDecimals0":"0","valuesFontFamily0":"Jura-DemiBold","valuesFontSize0":"20","valuesFontFamily1":"Jura-DemiBold","valuesFontSize1":"20","valuesMaxDecimals1":"0","yAxisTitleFontFamily":"Jura-Light","yAxisTitleFontSize":"","yAxisValueFontFamily":"Jura-Light","yAxisValueFontSize":"15","xAxisValueFontFamily":"Jura-Light","xAxisValueFontSize":"15","chartPaddingRight":"20","chartPaddingTop":"22","manualRefreshTrigger":"0_userdata.0.vis.ChartAktualisieren","pointSize":"0","minTimeInterval":"","xAxisMinRotation":"0","xAxisMaxRotation":"0","valuesMinDecimals1":"15","mdwDebug":true},"_cid":".map17","_computedAttrs":{},"wid":"w00477",
          2widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
          (anonymous) @ widgets.min.js:4
          (anonymous) @ conn.js:1299
          setTimeout (async)
          getHistory @ conn.js:1297
          getHistory @ vis.js:2613
          getTaskForHistoryData @ widgets.min.js:4
          (anonymous) @ widgets.min.js:3
          setTimeout (async)
          lineHistory @ widgets.min.js:3
          eval @ tplVis-materialdesign-Chart-Line-History.js:31
          (anonymous) @ can.custom.min.js:64
          a.each @ can.custom.min.js:24
          (anonymous) @ can.custom.min.js:58
          hookup @ can.custom.min.js:58
          a.add @ index.js:83
          Show 11 more frames
          widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 206
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585887997544,"val":18.78092805428227},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893179325,"val":197},{"ts":1585893184213,"val":196},{"ts":1585893204300,"val":193},{"ts":1585895684283,"val":501},{"ts":1585895769586,"val":470},{"ts":1585895774610,"val":480},{"ts":1585897185165,"val":0},{"ts":1585898159180,"val":659},{"ts":1585898364970,"val":628},{"ts":1585898369993,"val":625},{"ts":1585899575029,"val":530},{"ts":1585900945395,"val":987},{"ts":1585900960455,"val":983},{"ts":1585900965472,"val":981},{"ts":1585903529618,"val":2184},{"ts":1585903544678,"val":2184},{"ts":1585903549706,"val":2183},{"ts":1585903554752,"val":2180},{"ts":1585906116541,"val":3555},{"ts":1585906136652,"val":3515},{"ts":1585906141680,"val":3540},{"ts":1585906839996,"val":3192},{"ts":1585908723833,"val":4928},{"ts":1585908728849,"val":4926},{"ts":1585908733864,"val":4919},{"ts":1585908759022,"val":4910},{"ts":1585911325479,"val":5853},{"ts":1585911330492,"val":5854},{"ts":1585913902754,"val":6600},{"ts":1585913912811,"val":6594},{"ts":1585913917834,"val":6598},{"ts":1585914163920,"val":6467},{"ts":1585916384007,"val":6985},{"ts":1585916504542,"val":6936},{"ts":1585916509571,"val":6935},{"ts":1585917263083,"val":6529},{"ts":1585917584464,"val":7089},{"ts":1585919096685,"val":7003},{"ts":1585919101696,"val":7009},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921693478,"val":7030},{"ts":1585921698473,"val":7042},{"ts":1585922783485,"val":7092},{"ts":1585923817824,"val":6552},{"ts":1585924285138,"val":6735},{"ts":1585924290151,"val":6729},{"ts":1585926786616,"val":1903},{"ts":1585926877036,"val":6047},{"ts":1585926882051,"val":6151},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585929469104,"val":5025},{"ts":1585929474125,"val":5006},{"ts":1585932061362,"val":3015},{"ts":1585932066391,"val":2988},{"ts":1585932242172,"val":3059},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978687121,"val":119},{"ts":1585978717233,"val":108},{"ts":1585978722256,"val":115},{"ts":1585978747342,"val":99},{"ts":1585981303931,"val":374},{"ts":1585981308947,"val":372},{"ts":1585981313960,"val":371},{"ts":1585983418325,"val":259},{"ts":1585983820346,"val":543},{"ts":1585983895732,"val":524},{"ts":1585983905765,"val":517},{"ts":1585984789725,"val":22},{"ts":1585986491415,"val":734},{"ts":1585986496435,"val":716},{"ts":1585987214177,"val":0},{"ts":1585989081857,"val":1792},{"ts":1585989086736,"val":1795},{"ts":1585989192086,"val":1778},{"ts":1585991677443,"val":3044},{"ts":1585991682461,"val":3048},{"ts":1585992038901,"val":2880},{"ts":1585994168050,"val":4469},{"ts":1585994268477,"val":4409},{"ts":1585994273492,"val":4456},{"ts":1585994529574,"val":4425},{"ts":1585996844900,"val":5554},{"ts":1585996860023,"val":5554},{"ts":1585996865046,"val":5538},{"ts":1585996875086,"val":5534},{"ts":1585999380974,"val":6507},{"ts":1585999451346,"val":6472},{"ts":1585999456354,"val":6473},{"ts":1585999496486,"val":6420},{"ts":1586002028065,"val":6951},{"ts":1586002043171,"val":6943},{"ts":1586002048187,"val":6945},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004634898,"val":6903},{"ts":1586004639938,"val":6915},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586007226658,"val":7050},{"ts":1586007231700,"val":7044},{"ts":1586007277183,"val":7074},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586014992383,"val":5230},{"ts":1586015002414,"val":5237},{"ts":1586015007423,"val":5240},{"ts":1586017407825,"val":3634},{"ts":1586017588648,"val":3764},{"ts":1586017598695,"val":3752},{"ts":1586020169540,"val":2077},{"ts":1586020184597,"val":2080},{"ts":1586020189630,"val":2083},{"ts":1586022746179,"val":79},{"ts":1586022781371,"val":92},{"ts":1586022786410,"val":73},{"ts":1586022796454,"val":82},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063997372,"val":84},{"ts":1586064248282,"val":70},{"ts":1586064263341,"val":75},{"ts":1586064393948,"val":59},{"ts":1586066843732,"val":276},{"ts":1586066853766,"val":270},{"ts":1586068209595,"val":155},{"ts":1586069384063,"val":433},{"ts":1586069434376,"val":426},{"ts":1586069439382,"val":419},{"ts":1586071758748,"val":563},{"ts":1586071834103,"val":217},{"ts":1586072024984,"val":529},{"ts":1586072029999,"val":535},{"ts":1586072245821,"val":475},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077203046,"val":2650},{"ts":1586077213157,"val":2592},{"ts":1586077218168,"val":2617},{"ts":1586077238247,"val":0},{"ts":1586079738665,"val":4032},{"ts":1586079803897,"val":4013},{"ts":1586079813939,"val":4001},{"ts":1586079839106,"val":3956},{"ts":1586082339629,"val":5323},{"ts":1586082394850,"val":5307},{"ts":1586082399863,"val":5284},{"ts":1586082414917,"val":5281},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586092637546,"val":7053},{"ts":1586092763104,"val":7006},{"ts":1586092768120,"val":7000},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103128895,"val":4612},{"ts":1586103133838,"val":4604},{"ts":1586105724162,"val":3028},{"ts":1586105729185,"val":3041},{"ts":1586108073752,"val":1070},{"ts":1586108314620,"val":1101},{"ts":1586108319639,"val":1093},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147197607,"val":0}]
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 400
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585887997544,"val":993.6004784688995},{"ts":1585887998966,"val":1052},{"ts":1585888189680,"val":147},{"ts":1585889665174,"val":2601},{"ts":1585890588960,"val":1880},{"ts":1585890593982,"val":1100},{"ts":1585891688301,"val":370},{"ts":1585893128983,"val":6513},{"ts":1585893179325,"val":5325},{"ts":1585893184213,"val":5261},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585895769586,"val":1444},{"ts":1585895774610,"val":1215},{"ts":1585896286641,"val":472},{"ts":1585897873089,"val":3202},{"ts":1585898364970,"val":1484},{"ts":1585898369994,"val":1404},{"ts":1585899856172,"val":3180},{"ts":1585900824952,"val":783},{"ts":1585900955432,"val":927},{"ts":1585900960455,"val":2207},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903544678,"val":629},{"ts":1585903549706,"val":714},{"ts":1585904800420,"val":2535},{"ts":1585905036614,"val":109},{"ts":1585906136652,"val":1138},{"ts":1585906141684,"val":1360},{"ts":1585906196884,"val":620},{"ts":1585906789757,"val":7580},{"ts":1585908728849,"val":1621},{"ts":1585908733864,"val":2118},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585911325479,"val":1476},{"ts":1585911330492,"val":1477},{"ts":1585911375779,"val":1454},{"ts":1585912782456,"val":3479},{"ts":1585913912811,"val":1586},{"ts":1585913917834,"val":1579},{"ts":1585914163920,"val":1438},{"ts":1585916414148,"val":2888},{"ts":1585916504542,"val":1860},{"ts":1585916509571,"val":1722},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585919096685,"val":1601},{"ts":1585919101696,"val":1659},{"ts":1585920578494,"val":1454},{"ts":1585920714057,"val":3022},{"ts":1585921693480,"val":1549},{"ts":1585921698473,"val":1578},{"ts":1585922015043,"val":2670},{"ts":1585922220919,"val":979},{"ts":1585924285139,"val":1187},{"ts":1585924290152,"val":1151},{"ts":1585926344500,"val":2383},{"ts":1585926791643,"val":824},{"ts":1585926877036,"val":2139},{"ts":1585926882051,"val":1020},{"ts":1585927389541,"val":2238},{"ts":1585927645698,"val":578},{"ts":1585929464105,"val":883},{"ts":1585929474128,"val":879},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932061362,"val":6360},{"ts":1585932066391,"val":6159},{"ts":1585932186912,"val":6805},{"ts":1585932839608,"val":1735},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585935483710,"val":3882},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939834459,"val":3982},{"ts":1585939839473,"val":3983},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585947609823,"val":1346},{"ts":1585947614761,"val":1849},{"ts":1585948061642,"val":930},{"ts":1585950137489,"val":2922},{"ts":1585950202718,"val":2590},{"ts":1585950207734,"val":1615},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585953647922,"val":1088},{"ts":1585954190090,"val":1137},{"ts":1585956039145,"val":1013},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585958744944,"val":1015},{"ts":1585958815259,"val":995},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963074269,"val":815},{"ts":1585963164598,"val":447},{"ts":1585963169613,"val":445},{"ts":1585963767030,"val":368},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585968345560,"val":450},{"ts":1585968350578,"val":445},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585970941015,"val":387},{"ts":1585970945780,"val":386},{"ts":1585970990956,"val":376},{"ts":1585973415728,"val":1007},{"ts":1585973531270,"val":994},{"ts":1585973541299,"val":988},{"ts":1585973656679,"val":903},{"ts":1585975162738,"val":1677},{"ts":1585976121590,"val":974},{"ts":1585976126607,"val":978},{"ts":1585976432703,"val":1087},{"ts":1585977953951,"val":939},{"ts":1585978717233,"val":964},{"ts":1585978722256,"val":958},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585981308947,"val":381},{"ts":1585981313960,"val":378},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983900745,"val":1609},{"ts":1585983905765,"val":470},{"ts":1585983981076,"val":424},{"ts":1585984217203,"val":2734},{"ts":1585986491415,"val":1012},{"ts":1585986496435,"val":999},{"ts":1585986511507,"val":935},{"ts":158598896
          widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
          widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 1 day
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586060815542,"val":19.947579455043893},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063364835,"val":36},{"ts":1586063389936,"val":36},{"ts":1586063425053,"val":34},{"ts":1586063997372,"val":84},{"ts":1586064268379,"val":79},{"ts":1586064273399,"val":74},{"ts":1586064393948,"val":59},{"ts":1586065131806,"val":145},{"ts":1586065136832,"val":146},{"ts":1586065217180,"val":102},{"ts":1586065925107,"val":196},{"ts":1586065995424,"val":191},{"ts":1586066000439,"val":192},{"ts":1586066035563,"val":185},{"ts":1586066843732,"val":276},{"ts":1586066858788,"val":274},{"ts":1586066863801,"val":268},{"ts":1586067637051,"val":386},{"ts":1586067727427,"val":375},{"ts":1586067732438,"val":359},{"ts":1586068209595,"val":155},{"ts":1586068540859,"val":411},{"ts":1586068591055,"val":389},{"ts":1586068596077,"val":390},{"ts":1586068917655,"val":373},{"ts":1586069384063,"val":433},{"ts":1586069454442,"val":425},{"ts":1586069459493,"val":419},{"ts":1586070197508,"val":390},{"ts":1586070222599,"val":479},{"ts":1586070312906,"val":443},{"ts":1586070322938,"val":450},{"ts":1586070338001,"val":414},{"ts":1586070920499,"val":548},{"ts":1586071181476,"val":478},{"ts":1586071186498,"val":510},{"ts":1586071834103,"val":217},{"ts":1586072040042,"val":586},{"ts":1586072045080,"val":520},{"ts":1586072050089,"val":563},{"ts":1586072245821,"val":475},{"ts":1586072532026,"val":654},{"ts":1586072908547,"val":584},{"ts":1586072913577,"val":583},{"ts":1586073069196,"val":559},{"ts":1586073757247,"val":920},{"ts":1586073772341,"val":887},{"ts":1586073777354,"val":927},{"ts":1586073787388,"val":904},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586076364579,"val":1965},{"ts":1586076369615,"val":2020},{"ts":1586076856750,"val":1835},{"ts":1586077203046,"val":2650},{"ts":1586077228206,"val":2629},{"ts":1586077233227,"val":2636},{"ts":1586077238247,"val":0},{"ts":1586078091881,"val":3081},{"ts":1586078101962,"val":3084},{"ts":1586078116969,"val":3062},{"ts":1586078945609,"val":3555},{"ts":1586078955641,"val":3554},{"ts":1586078960682,"val":3566},{"ts":1586078985780,"val":3543},{"ts":1586079738665,"val":4032},{"ts":1586079818990,"val":3981},{"ts":1586079824022,"val":4019},{"ts":1586079839106,"val":3956},{"ts":1586080672557,"val":4572},{"ts":1586080682581,"val":4547},{"ts":1586080687605,"val":4565},{"ts":1586080787954,"val":4544},{"ts":1586081546248,"val":5004},{"ts":1586081551945,"val":4996},{"ts":1586081566310,"val":4981},{"ts":1586082339629,"val":5323},{"ts":1586082414917,"val":5281},{"ts":1586082419935,"val":5300},{"ts":1586082450037,"val":5298},{"ts":1586083243231,"val":5693},{"ts":1586083278362,"val":5692},{"ts":1586083283382,"val":5695},{"ts":1586083358669,"val":5637},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088460725,"val":6857},{"ts":1586088465726,"val":6845},{"ts":1586088521072,"val":6910},{"ts":1586088757078,"val":6820},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586092637546,"val":7053},{"ts":1586092738000,"val":6989},{"ts":1586092783176,"val":7000},{"ts":1586092788193,"val":7001},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093646660,"val":7038},{"ts":1586093651731,"val":7015},{"ts":1586093681791,"val":7043},{"ts":1586093932788,"val":6972},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096238576,"val":6786},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098549248,"val":6306},{"ts":1586098830323,"val":6332},{"ts":1586098835342,"val":6314},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103143897,"val":4596},{"ts":1586103148901,"val":4602},{"ts":1586103159184,"val":4593},{"ts":1586103173990,"val":4603},{"ts":1586103971920,"val":4118},{"ts":1586104007062,"val":4122},{"ts":1586104017114,"val":4126},{"ts":1586104032183,"val":4133},{"ts":1586104448936,"val":3519},{"ts":1586104875565,"val":3600},{"ts":1586104880592,"val":3594},{"ts":1586105739215,"val":3020},{"ts":1586105744232,"val":3023},{"ts":1586105749245,"val":3028},{"ts":1586106597564,"val":2470},{"ts":1586106607606,"val":2468},{"ts":1586107471103,"val":1809},{"ts":1586107476199,"val":1796},{"ts":1586107481131,"val":1802},{"ts":1586108334704,"val":1067},{"ts":1586108339732,"val":1062},{"ts":1586109198118,"val":169},{"ts":1586109203206,"val":162},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147215543,"val":0}]
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 328
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586060815542,"val":322.84586241276173},{"ts":1586060819569,"val":579},{"ts":1586060859739,"val":0},{"ts":1586061401936,"val":2078},{"ts":1586061678004,"val":583},{"ts":1586061683019,"val":415},{"ts":1586061748667,"val":0},{"ts":1586062104842,"val":1622},{"ts":1586062541545,"val":294},{"ts":1586062546668,"val":0},{"ts":1586062998234,"val":2038},{"ts":1586063405000,"val":135},{"ts":1586063410005,"val":286},{"ts":1586063470272,"val":0},{"ts":1586063967244,"val":2081},{"ts":1586064268379,"val":386},{"ts":1586064273399,"val":1191},{"ts":1586064383908,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065131807,"val":690},{"ts":1586065136832,"val":452},{"ts":1586065583541,"val":0},{"ts":1586065618661,"val":2177},{"ts":1586065995425,"val":886},{"ts":1586066000439,"val":235},{"ts":1586066070684,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066858790,"val":482},{"ts":1586066863801,"val":592},{"ts":1586066883914,"val":0},{"ts":1586067406105,"val":1935},{"ts":1586067727427,"val":468},{"ts":1586067732438,"val":601},{"ts":1586067742470,"val":0},{"ts":1586067812769,"val":1761},{"ts":1586068591055,"val":0},{"ts":1586068596077,"val":170},{"ts":1586068626232,"val":0},{"ts":1586069273632,"val":2032},{"ts":1586069454443,"val":625},{"ts":1586069459493,"val":917},{"ts":1586070242670,"val":2701},{"ts":1586070302873,"val":208},{"ts":1586070317923,"val":899},{"ts":1586070322939,"val":1367},{"ts":1586070624105,"val":207},{"ts":1586071025845,"val":2602},{"ts":1586071181476,"val":846},{"ts":1586071186498,"val":1101},{"ts":1586071628219,"val":2592},{"ts":1586071703481,"val":226},{"ts":1586072045082,"val":845},{"ts":1586072050089,"val":1317},{"ts":1586072230757,"val":413},{"ts":1586072762980,"val":2978},{"ts":1586072908548,"val":975},{"ts":1586072913578,"val":701},{"ts":1586073666896,"val":2709},{"ts":1586073767288,"val":444},{"ts":1586073772347,"val":924},{"ts":1586073777355,"val":1152},{"ts":1586074013295,"val":307},{"ts":1586074093629,"val":2544},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586076289173,"val":1207},{"ts":1586076364579,"val":1265},{"ts":1586076369615,"val":1296},{"ts":1586076610668,"val":1068},{"ts":1586077017357,"val":3198},{"ts":1586077228206,"val":1289},{"ts":1586077233228,"val":1278},{"ts":1586077238248,"val":0},{"ts":1586077685215,"val":1942},{"ts":1586078091881,"val":1158},{"ts":1586078096910,"val":1207},{"ts":1586078106940,"val":1166},{"ts":1586078352967,"val":3369},{"ts":1586078955641,"val":3196},{"ts":1586078960682,"val":3213},{"ts":1586078980763,"val":3257},{"ts":1586079186687,"val":1134},{"ts":1586079818990,"val":1571},{"ts":1586079824022,"val":1507},{"ts":1586080225786,"val":1926},{"ts":1586080486842,"val":1202},{"ts":1586080682581,"val":1333},{"ts":1586080687605,"val":1344},{"ts":1586081455867,"val":1416},{"ts":1586081516117,"val":1298},{"ts":1586081546248,"val":1338},{"ts":1586081551945,"val":1326},{"ts":1586081566310,"val":1308},{"ts":1586081722115,"val":3243},{"ts":1586082414918,"val":3051},{"ts":1586082419935,"val":3098},{"ts":1586082545523,"val":3320},{"ts":1586083223140,"val":1293},{"ts":1586083278363,"val":1324},{"ts":1586083283382,"val":1342},{"ts":1586083398807,"val":1288},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586085732930,"val":1369},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088465726,"val":2059},{"ts":1586088470825,"val":2076},{"ts":1586088561240,"val":2000},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090600065,"val":1956},{"ts":1586090630195,"val":778},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586092627510,"val":2070},{"ts":1586092732971,"val":868},{"ts":1586092783176,"val":888},{"ts":1586092788193,"val":894},{"ts":1586092868521,"val":2080},{"ts":1586093300238,"val":807},{"ts":1586093646660,"val":1057},{"ts":1586093651731,"val":822},{"ts":1586093661724,"val":815},{"ts":1586093787227,"val":2030},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095816995,"val":1322},{"ts":1586095857154,"val":2851},{"ts":1586096238576,"val":1371},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586098800198,"val":2478},{"ts":1586098830323,"val":1316},{"ts":1586098835342,"val":1301},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586103113778,"val":1315},{"ts":1586103148902,"val":1593},{"ts":1586103153929,"val":1261},{"ts":1586103159184,"val":2398},{"ts":1586103981944,"val":687},{"ts":1586104012091,"val":687},{"ts":1586104017115,"val":702},{"ts":1586104474012,"val":1934},{"ts":1586104870548,"val":664},{"ts":1586104875565,"val":693},{"ts":1586104880592,"val":692},{"ts":1586104930783,"val":1839},{"ts":1586105699084,"val":383},{"ts":1586105739216,"val":403},{"ts":1586105744232,"val":588},{"ts":1586105759281,"val":388},{"ts":1586106336553,"val":1621},{"ts":1586106602593,"val":445},{"ts":1586106607606,"val":438},{"ts":1586107144860,"val":431},{"ts":1586107325556,"val":2002},{"ts":1586107471103,"val":514},{"ts":1586107476199,"val":830},{"ts":1586107491177,"val":1670},{"ts":1586108164066,"val":110},{"ts":1586108334704,"val":674},{"ts":1586108339732,"val":357},{"ts":1586109082505,"val":35},{"ts":1586109188056,"val":2119},{"ts":1586109198118,"val":508},{"ts":1586109203206,"val":450},{"ts":1586109218231,"val":0},{"ts":1586109850709,"val":2206},{"ts":1586110061406,"val":232},{"ts":1586110066424,"val":888},{"ts":1586110141653,"val":126},{"ts":1586110252079,"val":2542},{"ts":1586110924465,"val":868},{"ts":1586110929486,"val":857},{"ts":1586111004750,"val":510},{"ts":1586111280685,"val":2601},{"ts":1586111787428,"val":1708},{"ts":1586111792442,"val":1660},{"ts":1586112354474,"val":1076},{"ts":1586112550182,"val":3304},{"ts":1586112655527,"val":1748},{"ts":1586112660537,"val":1783},{"ts":1586112871240,"val":1684},{"ts":1586113513452,"val":3736},{"ts":1586113518453,"val":3723},{"ts":1586113523475,"val":3733},{"ts":1586113628798,"val":3563},{"ts":1586114381222,"val":3680},{"ts":1586114386250,"val":3686},{"ts":1586114792624,"val":3769},{"ts":1586114862881,"val":1929},{"ts":1586115244235,"val":2042},{"ts":1586115249250,"val":2056},{"ts":1586115550299,"val":1166},{"ts":1586116087149,"val":3146},{"ts":1586116107211,"val":3130},{"ts":1586116112226,"val":3132},{"ts":1586116428259,"val":4117},{"ts":1586116779539,"val":1092},{"ts":1586116975168,"val":1093},{"ts":1586116980200,"val":1117},{"ts":1586117769027,"val":1188},{"ts":1586117839517,"val":1042},{"ts":1586117844536,"val":1053},{"ts":1586118065490,"val":983},{"ts":1586118672995,"val":2060},{"ts":1586118703098,"val":1250},{"ts":1586118708114,"val":1239},{"ts":1586118999493,"val":1460},{"ts":1586119561868,"val":1066},{"ts":1586119566886,"val":1072},{"ts":1586119571931,"val":1070},{"ts":1586119617135,"val":994},{"ts":1586120235271,"val":1286},{"ts":1586120430949,"val":1069},{"ts":1586120435977,"val":1068},{"ts":1586120471125,"val":1484},{"ts":1586121294876,"val":1196},{"ts":1586121299896,"val":1197},{"ts":1586121470673,"val":1481},{"ts":1586122012898,"val":876},{"ts":1586122158648,"val":890},{"ts":1586122163668,"val":894},{"ts":1586122399822,"val":1066},{"ts":1586123002470,"val":744},{"ts":1586123022552,"val":856},{"ts":1586123027566,"val":779},{"ts":1586123635474,"val":957},{"ts":1586123846241,"val":733},{"ts":1586123886377,"val":756},{"ts":1586123891397,"val":755},{"ts":1586124057031,"val":740},{"ts":1586124358522,"val":1079},{"ts":1586124750423,"val":822},{"ts":1586124755564,"val":823},{"ts":1586124896001,"val":805},{"ts":1586125483391,"val":978},{"ts":1586125614109,"val":843},{"ts":1586125619128,"val":845},{"ts":1586125694599,"val":851},{"ts":1586126016471,"val":743},{"ts":1586126473161,"val":760},{"ts":1586126483197,"val":753},{"ts":1586126548458,"val":750},{"ts":1586127206643,"val":1195},{"ts":1586127342251,"val":853},{"ts":1586127357302,"val":852},{"ts":1586127563231,"val":817},{"ts":1586127794593,"val":1617},{"ts":1586128201532,"val":900},{"ts":1586128211514,"val":905},{"ts":1586128472584,"val":911},{"ts":1586128608291,"val":819},{"ts":1586129070615,"val":834},{"ts":1586129075630,"val":841},{"ts":1586129136032,"val":846},{"ts":1586129502477,"val":817},{"ts":1586129934382,"val":820},{"ts":1586129939400,"val":829},{"ts":1586130085156,"val":821},{"ts":1586130456695,"val":1010},{"ts":1586130793195,"val":893},{"ts":1586130803232,"val":887},{"ts":1586130904252,"val":909},{"ts":1586131647319,"val":762},{"ts":1586131657353,"val":775},{"ts":1586131667477,"val":774},{"ts":1586131707555,"val":764},{"ts":1586132320385,"val":879},{"ts":1586132526173,"val":869},{"ts":1586132531213,"val":863},{"ts":1586132546279,"val":875},{"ts":1586132712049,"val":768},{"ts":1586133390253,"val":782},{"ts":1586133395276,"val":796},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586134254366,"val":852},{"ts":1586134259404,"val":842},{"ts":1586134284519,"val":858},{"ts":1586134405104,"val":778},{"ts":1586135118594,"val":811},{"ts":1586135123624,"val":820},{"ts":1586135194019,"val":800},{"ts":1586135630884,"val":1070},{"ts":1586135982464,"val":855},{"ts":1586135987482,"val":853},{"ts":1586136333985,"val":787},{"ts":1586136685546,"val":1050},{"ts":1586136846282,"val":878},{"ts":1586136851300,"val":874},{"ts":1586137011970,"val":862},{"ts":1586137288246,"val":1083},{"ts":1586137710306,"val":935},{"ts":1586137715336,"val":929},{"ts":1586137735449,"val":947},{"ts":1586138363143,"val":856},{"ts":1586138574110,"val":866},{"ts":1586138579123,"val":885},{"ts":1586138749901,"val":895},{"ts":1586139287234,"val":805},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141263684,"val":889},{"ts":1586141665342,"val":804},{"ts":1586142026837,"val":827},{"ts":1586142031851,"val":833},{"ts":1586142383576,"val":805},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586144671112,"val":967},{"ts":1586144866935,"val":878},{"ts":1586145484896,"val":892},{"ts":1586145489911,"val":888},{"ts":1586145715999,"val":877},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147215542,"val":963}]
          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 328
          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
          widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 3 days
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 208
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585888021338,"val":18.80886217247979},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893204300,"val":193},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585895684283,"val":501},{"ts":1585895794672,"val":480},{"ts":1585895799700,"val":473},{"ts":1585897185165,"val":0},{"ts":1585898159180,"val":659},{"ts":1585898385040,"val":617},{"ts":1585898390058,"val":628},{"ts":1585899575029,"val":530},{"ts":1585900980520,"val":994},{"ts":1585900985534,"val":1005},{"ts":1585901015644,"val":1003},{"ts":1585903569795,"val":2200},{"ts":1585903574811,"val":2196},{"ts":1585903645071,"val":2181},{"ts":1585906161769,"val":3571},{"ts":1585906166784,"val":3570},{"ts":1585906839996,"val":3192},{"ts":1585908723833,"val":4928},{"ts":1585908754000,"val":4924},{"ts":1585908759022,"val":4910},{"ts":1585911345563,"val":5898},{"ts":1585911350603,"val":5908},{"ts":1585912410550,"val":5877},{"ts":1585913922850,"val":6616},{"ts":1585913932895,"val":6599},{"ts":1585913942936,"val":6605},{"ts":1585914163920,"val":6467},{"ts":1585916384007,"val":6985},{"ts":1585916529650,"val":6944},{"ts":1585916534675,"val":6960},{"ts":1585917263083,"val":6529},{"ts":1585917584464,"val":7089},{"ts":1585919116745,"val":6997},{"ts":1585919126800,"val":7020},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921713534,"val":7025},{"ts":1585921723734,"val":7029},{"ts":1585922783485,"val":7092},{"ts":1585923817824,"val":6552},{"ts":1585924305287,"val":6682},{"ts":1585924310307,"val":6698},{"ts":1585926786616,"val":1903},{"ts":1585926897099,"val":5636},{"ts":1585926902112,"val":5320},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585929489238,"val":4971},{"ts":1585929494237,"val":4964},{"ts":1585929509309,"val":4983},{"ts":1585932066391,"val":2988},{"ts":1585932081439,"val":3016},{"ts":1585932086459,"val":3017},{"ts":1585932242172,"val":3059},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978687121,"val":119},{"ts":1585978737447,"val":112},{"ts":1585978742326,"val":117},{"ts":1585978747342,"val":99},{"ts":1585981303931,"val":374},{"ts":1585981318976,"val":369},{"ts":1585981334020,"val":376},{"ts":1585983418325,"val":259},{"ts":1585983820346,"val":543},{"ts":1585983920820,"val":515},{"ts":1585983925837,"val":521},{"ts":1585984789725,"val":22},{"ts":1585986491415,"val":734},{"ts":1585986516521,"val":711},{"ts":1585986521539,"val":742},{"ts":1585987214177,"val":0},{"ts":1585989086736,"val":1795},{"ts":1585989106800,"val":1779},{"ts":1585989111816,"val":1812},{"ts":1585989192086,"val":1778},{"ts":1585991682461,"val":3048},{"ts":1585991697540,"val":3026},{"ts":1585991702556,"val":3042},{"ts":1585992038901,"val":2880},{"ts":1585994288543,"val":4521},{"ts":1585994293558,"val":4515},{"ts":1585994529574,"val":4425},{"ts":1585996844900,"val":5554},{"ts":1585996885114,"val":5553},{"ts":1585996895147,"val":5562},{"ts":1585999380974,"val":6507},{"ts":1585999476411,"val":6458},{"ts":1585999481423,"val":6465},{"ts":1585999496486,"val":6420},{"ts":1586002028065,"val":6951},{"ts":1586002068265,"val":6928},{"ts":1586002073289,"val":6909},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004660013,"val":6868},{"ts":1586004665028,"val":6897},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586007251982,"val":7062},{"ts":1586007256978,"val":7056},{"ts":1586007277183,"val":7074},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586015012435,"val":5222},{"ts":1586015027508,"val":5225},{"ts":1586015032523,"val":5206},{"ts":1586015037535,"val":5220},{"ts":1586017407825,"val":3634},{"ts":1586017618787,"val":3733},{"ts":1586017628822,"val":3739},{"ts":1586020209705,"val":2037},{"ts":1586020214708,"val":2045},{"ts":1586020224747,"val":2051},{"ts":1586022801468,"val":69},{"ts":1586022806483,"val":79},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063997372,"val":84},{"ts":1586064273399,"val":74},{"ts":1586064283425,"val":70},{"ts":1586064393948,"val":59},{"ts":1586066843732,"val":276},{"ts":1586066868851,"val":273},{"ts":1586066873847,"val":279},{"ts":1586068209595,"val":155},{"ts":1586069384063,"val":433},{"ts":1586069459493,"val":419},{"ts":1586069464488,"val":421},{"ts":1586071834103,"val":217},{"ts":1586072040042,"val":586},{"ts":1586072050089,"val":563},{"ts":1586072055104,"val":537},{"ts":1586072245821,"val":475},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077203046,"val":2650},{"ts":1586077233227,"val":2636},{"ts":1586077238247,"val":0},{"ts":1586079738665,"val":4032},{"ts":1586079824022,"val":4019},{"ts":1586079834067,"val":4026},{"ts":1586079839106,"val":3956},{"ts":1586082339629,"val":5323},{"ts":1586082419935,"val":5300},{"ts":1586082424953,"val":5307},{"ts":1586082450037,"val":5298},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586092637546,"val":7053},{"ts":1586092788193,"val":7001},{"ts":1586092793207,"val":6983},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103143897,"val":4596},{"ts":1586103148901,"val":4602},{"ts":1586103159184,"val":4593},{"ts":1586103173990,"val":4603},{"ts":1586105739215,"val":3020},{"ts":1586105749245,"val":3028},{"ts":1586105754258,"val":3024},{"ts":1586108339732,"val":1062},{"ts":1586108344752,"val":1052},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147221338,"val":0}]
          setTimeout (async)
          o @ widgets.min.js:3
          t.dispatch @ can.custom.min.js:18
          stop @ can.custom.min.js:44
          _setAttrs @ can.custom.min.js:48
          attr @ can.custom.min.js:48
          (anonymous) @ vis.js:311
          a.add @ index.js:83
          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 208
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585888021338,"val":978.7388789148215},{"ts":1585888024034,"val":954},{"ts":1585888189680,"val":147},{"ts":1585889665174,"val":2601},{"ts":1585890609036,"val":1003},{"ts":1585890614058,"val":947},{"ts":1585891688301,"val":370},{"ts":1585893128983,"val":6513},{"ts":1585893204300,"val":5228},{"ts":1585893209725,"val":5304},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585895794674,"val":1409},{"ts":1585895799700,"val":766},{"ts":1585896286641,"val":472},{"ts":1585897873089,"val":3202},{"ts":1585898385040,"val":1490},{"ts":1585898390058,"val":1463},{"ts":1585899856172,"val":3180},{"ts":1585900824952,"val":783},{"ts":1585900980520,"val":1525},{"ts":1585900985534,"val":1361},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903569795,"val":709},{"ts":1585903574811,"val":352},{"ts":1585904800420,"val":2535},{"ts":1585905036614,"val":109},{"ts":1585906161770,"val":1314},{"ts":1585906166784,"val":1319},{"ts":1585906196884,"val":620},{"ts":1585906789757,"val":7580},{"ts":1585908754000,"val":1853},{"ts":1585908759022,"val":2107},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585911345563,"val":1475},{"ts":1585911350603,"val":1800},{"ts":1585911375779,"val":1454},{"ts":1585912782456,"val":3479},{"ts":1585913937908,"val":1581},{"ts":1585913942936,"val":1610},{"ts":1585914163920,"val":1438},{"ts":1585916414148,"val":2888},{"ts":1585916529650,"val":1698},{"ts":1585916534675,"val":1736},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585919121783,"val":1582},{"ts":1585919126800,"val":1788},{"ts":1585920578494,"val":1454},{"ts":1585920714057,"val":3022},{"ts":1585921713534,"val":1572},{"ts":1585921718548,"val":1993},{"ts":1585922015043,"val":2670},{"ts":1585922220919,"val":979},{"ts":1585924305287,"val":1318},{"ts":1585924310307,"val":1138},{"ts":1585926344500,"val":2383},{"ts":1585926791643,"val":824},{"ts":1585926897099,"val":1016},{"ts":1585926902112,"val":1021},{"ts":1585927389541,"val":2238},{"ts":1585927645698,"val":578},{"ts":1585929489239,"val":866},{"ts":1585929494237,"val":1222},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932081440,"val":6083},{"ts":1585932086459,"val":6253},{"ts":1585932186912,"val":6805},{"ts":1585932839608,"val":1735},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585935483710,"val":3882},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939859554,"val":3969},{"ts":1585939864583,"val":3943},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585947634845,"val":1339},{"ts":1585947639854,"val":1342},{"ts":1585948061642,"val":930},{"ts":1585950137489,"val":2922},{"ts":1585950227803,"val":1559},{"ts":1585950232824,"val":1956},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585953647922,"val":1088},{"ts":1585954190090,"val":1137},{"ts":1585956039145,"val":1013},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585958744944,"val":1015},{"ts":1585958815259,"val":995},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963074269,"val":815},{"ts":1585963184681,"val":449},{"ts":1585963189696,"val":448},{"ts":1585963767030,"val":368},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585968365640,"val":449},{"ts":1585968375693,"val":450},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585970960846,"val":383},{"ts":1585970965865,"val":378},{"ts":1585970990956,"val":376},{"ts":1585973415728,"val":1007},{"ts":1585973556359,"val":996},{"ts":1585973561377,"val":993},{"ts":1585973656679,"val":903},{"ts":1585975162738,"val":1677},{"ts":1585976146690,"val":984},{"ts":1585976151706,"val":972},{"ts":1585976432703,"val":1087},{"ts":1585978737447,"val":895},{"ts":1585978742326,"val":892},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585981329005,"val":381},{"ts":1585981334020,"val":390},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983920820,"val":597},{"ts":1585983925837,"val":551},{"ts":1585983981076,"val":424},{"ts":1585984217203,"val":2734},{"ts":1585986516521,"val":988},{"ts":1585986521540,"val":1439},{"ts":1585986702219,"val":949},{"ts":1585988961236,"val":2760},{"ts":1585989106
          widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 7 days
          widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - TimeInterval by Editor **************************************************************
          setTimeout (async)
          r.onack @ index.js:83
          r.onpacket @ index.js:83
          (anonymous) @ index.js:83
          r.emit @ index.js:83
          r.ondecoded @ index.js:83
          a.add @ index.js:83
          r.ondata @ index.js:83
          r.onPacket @ index.js:83
          r.onData @ index.js:83
          ws.onmessage @ index.js:83
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 106
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542427421,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899258798,"val":655},{"ts":1585899263819,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905292697,"val":2903},{"ts":1585905297714,"val":2895},{"ts":1585905307760,"val":2896},{"ts":1585905674398,"val":2619},{"ts":1585911350603,"val":5908},{"ts":1585911355617,"val":5917},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917398670,"val":6958},{"ts":1585917403697,"val":6960},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923451340,"val":6947},{"ts":1585923456353,"val":6960},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929499251,"val":4965},{"ts":1585929504280,"val":4977},{"ts":1585929509309,"val":4983},{"ts":1585935513849,"val":153},{"ts":1585935543974,"val":158},{"ts":1585935549000,"val":160},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977878561,"val":62},{"ts":1585977888595,"val":66},{"ts":1585977898644,"val":59},{"ts":1585983820346,"val":543},{"ts":1585983930849,"val":517},{"ts":1585983935863,"val":522},{"ts":1585987214177,"val":0},{"ts":1585989970447,"val":2198},{"ts":1585989975437,"val":2185},{"ts":1585989980468,"val":2187},{"ts":1585995991077,"val":5337},{"ts":1585996026186,"val":5316},{"ts":1585996031210,"val":5338},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002073289,"val":6909},{"ts":1586002078320,"val":6922},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014168676,"val":5463},{"ts":1586014173704,"val":5469},{"ts":1586014178718,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020214708,"val":2045},{"ts":1586020219725,"val":2048},{"ts":1586020224747,"val":2051},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068601120,"val":382},{"ts":1586068606155,"val":387},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080672557,"val":4572},{"ts":1586080697652,"val":4564},{"ts":1586080702679,"val":4551},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092793207,"val":6983},{"ts":1586092798226,"val":6996},{"ts":1586093596415,"val":7097},{"ts":1586098840356,"val":6296},{"ts":1586098855415,"val":6290},{"ts":1586104448936,"val":3519},{"ts":1586104890630,"val":3594},{"ts":1586104895646,"val":3588},{"ts":1586104900666,"val":3593},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147227422,"val":0}]
          setTimeout (async)
          setInterval (async)
          setTimeout (async)
          frag @ can.custom.min.js:58
          r @ can.custom.min.js:58
          renderTo @ can.custom.min.js:58
          renderAs @ can.custom.min.js:58
          e.view.e.template @ can.custom.min.js:58
          renderWidget @ vis.js:1610
          (anonymous) @ vis.js:887
          (anonymous) @ vis.js:2742
          (anonymous) @ conn.js:730
          a.add @ index.js:83
          Show 13 more frames
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 105
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542427891,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899258798,"val":655},{"ts":1585899263819,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905292697,"val":2903},{"ts":1585905307760,"val":2896},{"ts":1585905312772,"val":2882},{"ts":1585905674398,"val":2619},{"ts":1585911355617,"val":5917},{"ts":1585911360684,"val":5923},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917403697,"val":6960},{"ts":1585917408732,"val":6957},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923451340,"val":6947},{"ts":1585923456353,"val":6960},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929499251,"val":4965},{"ts":1585929504280,"val":4977},{"ts":1585929509309,"val":4983},{"ts":1585935513849,"val":153},{"ts":1585935543974,"val":158},{"ts":1585935549000,"val":160},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977878561,"val":62},{"ts":1585977888595,"val":66},{"ts":1585977898644,"val":59},{"ts":1585983820346,"val":543},{"ts":1585983930849,"val":517},{"ts":1585983935863,"val":522},{"ts":1585987214177,"val":0},{"ts":1585989970447,"val":2198},{"ts":1585989975437,"val":2185},{"ts":1585989980468,"val":2187},{"ts":1585995991077,"val":5337},{"ts":1585996026186,"val":5316},{"ts":1585996031210,"val":5338},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002073289,"val":6909},{"ts":1586002078320,"val":6922},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014168676,"val":5463},{"ts":1586014173704,"val":5469},{"ts":1586014178718,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020219725,"val":2048},{"ts":1586020224747,"val":2051},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068601120,"val":382},{"ts":1586068606155,"val":387},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080672557,"val":4572},{"ts":1586080697652,"val":4564},{"ts":1586080702679,"val":4551},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092793207,"val":6983},{"ts":1586092798226,"val":6996},{"ts":1586093596415,"val":7097},{"ts":1586098840356,"val":6296},{"ts":1586098855415,"val":6290},{"ts":1586104448936,"val":3519},{"ts":1586104890630,"val":3594},{"ts":1586104895646,"val":3588},{"ts":1586104900666,"val":3593},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147227892,"val":0}]
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 192
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542427421,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875066695,"val":990},{"ts":1585875071710,"val":957},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881112719,"val":408},{"ts":1585881117733,"val":328},{"ts":1585881127769,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887160647,"val":814},{"ts":1585887165659,"val":715},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893209725,"val":5304},{"ts":1585893214336,"val":5505},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899258798,"val":1554},{"ts":1585899263819,"val":1807},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905302744,"val":543},{"ts":1585905307760,"val":936},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911350603,"val":1800},{"ts":1585911355618,"val":1458},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917398670,"val":1511},{"ts":1585917403698,"val":1498},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923451340,"val":1211},{"ts":1585923456353,"val":1076},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929499251,"val":863},{"ts":1585929504280,"val":1266},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935543974,"val":2298},{"ts":1585935549000,"val":2222},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941591810,"val":1457},{"ts":1585941596824,"val":1677},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947639854,"val":1342},{"ts":1585947644870,"val":1345},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953688242,"val":1128},{"ts":1585953693097,"val":1129},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971834208,"val":382},{"ts":1585971844242,"val":384},{"ts":1585975162738,"val":1677},{"ts":1585977878561,"val":997},{"ts":1585977883583,"val":1000},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983930849,"val":753},{"ts":1585983935863,"val":1631},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585989975438,"val":1416},{"ts":1585989980469,"val":1778},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996026187,"val":1579},{"ts":1585996031210,"val":1244},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002073290,"val":1403},{"ts":1586002078320,"val":1397},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014168676,"val":1277},{"ts":1586014173704,"val":1301},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020214708,"val":622},{"ts":1586020219725,"val":706},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026262452,"val":218},{"ts":1586026267476,"val":1036},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032310896,"val":652},{"ts":1586032315939,"val":964},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038359695,"val":670},{"ts":1586038364724,"val":1562},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044409399,"val":694},{"ts":1586044414434,"val":484},{"ts":1586044439569,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050458808,"val":608},{"ts":1586050463823,"val":946},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056507278,"val":1202},{"ts":1586056512293,"val":1065},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062551579,"val":119},{"ts":1586062556594,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068601120,"val":331},{"ts":1586068606155,"val":377},{"ts":1586068626232,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080697652,"val":1359},{"ts":1586080702680,"val":1344},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092793207,"val":881},{"ts":1586092798226,"val":1065},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104890630,"val":704},{"ts":1586104895646,"val":691},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110934505,"val":849},{"ts":1586110939527,"val":841},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586116985215,"val":1107},{"ts":1586116990225,"val":1118},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123032579,"val":749},{"ts":1586123037592,"val":752},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129080642,"val":832},{"ts":1586129085656,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135128646,"val":821},{"ts":1586135133700,"val":825},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147227422,"val":963}]
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542427891,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875066695,"val":990},{"ts":1585875071710,"val":957},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881112719,"val":408},{"ts":1585881117733,"val":328},{"ts":1585881127769,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887160647,"val":814},{"ts":1585887165659,"val":715},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893209725,"val":5304},{"ts":1585893214336,"val":5505},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899258798,"val":1554},{"ts":1585899263819,"val":1807},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905307760,"val":936},{"ts":1585905312772,"val":1337},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911355618,"val":1458},{"ts":1585911360684,"val":1565},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917403698,"val":1498},{"ts":1585917408732,"val":2677},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923451340,"val":1211},{"ts":1585923456353,"val":1076},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929499251,"val":863},{"ts":1585929504280,"val":1266},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935543974,"val":2298},{"ts":1585935549000,"val":2222},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941591810,"val":1457},{"ts":1585941596824,"val":1677},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947639854,"val":1342},{"ts":1585947644870,"val":1345},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953688242,"val":1128},{"ts":1585953693097,"val":1129},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971834208,"val":382},{"ts":1585971844242,"val":384},{"ts":1585975162738,"val":1677},{"ts":1585977883583,"val":1000},{"ts":1585977888595,"val":1003},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983930849,"val":753},{"ts":1585983935863,"val":1631},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585989975438,"val":1416},{"ts":1585989980469,"val":1778},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996026187,"val":1579},{"ts":1585996031210,"val":1244},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002073290,"val":1403},{"ts":1586002078320,"val":1397},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014168676,"val":1277},{"ts":1586014173704,"val":1301},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020219725,"val":706},{"ts":1586020224747,"val":626},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026267476,"val":1036},{"ts":1586026272518,"val":667},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032310896,"val":652},{"ts":1586032315939,"val":964},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038359695,"val":670},{"ts":1586038364724,"val":1562},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044409399,"val":694},{"ts":1586044414434,"val":484},{"ts":1586044439569,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050458808,"val":608},{"ts":1586050463823,"val":946},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056507278,"val":1202},{"ts":1586056512293,"val":1065},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062551579,"val":119},{"ts":1586062556594,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068601120,"val":331},{"ts":1586068606155,"val":377},{"ts":1586068626232,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080697652,"val":1359},{"ts":1586080702680,"val":1344},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092793207,"val":881},{"ts":1586092798226,"val":1065},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104890630,"val":704},{"ts":1586104895646,"val":691},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110939527,"val":841},{"ts":1586110944541,"val":525},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586116985215,"val":1107},{"ts":1586116990225,"val":1118},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123032579,"val":749},{"ts":1586123037592,"val":752},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129080642,"val":832},{"ts":1586129085656,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135128646,"val":821},{"ts":1586135133700,"val":825},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147227891,"val":963}]
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 107
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542457581,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893239448,"val":204},{"ts":1585893244471,"val":203},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899288946,"val":642},{"ts":1585899293958,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905332891,"val":2904},{"ts":1585905337924,"val":2896},{"ts":1585905674398,"val":2619},{"ts":1585911365768,"val":5936},{"ts":1585911380802,"val":5916},{"ts":1585911385822,"val":5926},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917428858,"val":6996},{"ts":1585917433849,"val":7003},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923481449,"val":6954},{"ts":1585923486473,"val":6952},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929529383,"val":4954},{"ts":1585929539440,"val":4956},{"ts":1585929594711,"val":4969},{"ts":1585935559025,"val":142},{"ts":1585935574080,"val":147},{"ts":1585935589139,"val":143},{"ts":1585935594162,"val":147},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977908692,"val":63},{"ts":1585977913712,"val":64},{"ts":1585977918743,"val":62},{"ts":1585983820346,"val":543},{"ts":1585983955926,"val":520},{"ts":1585983965996,"val":524},{"ts":1585987214177,"val":0},{"ts":1585989995523,"val":2210},{"ts":1585990005577,"val":2210},{"ts":1585990010587,"val":2211},{"ts":1585990020611,"val":2205},{"ts":1585996031210,"val":5338},{"ts":1585996056364,"val":5329},{"ts":1585996061386,"val":5334},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002098413,"val":6840},{"ts":1586002108453,"val":6837},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014198840,"val":5466},{"ts":1586014209331,"val":5460},{"ts":1586014264186,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020239796,"val":2045},{"ts":1586020249832,"val":2041},{"ts":1586020259865,"val":2042},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068631241,"val":394},{"ts":1586068636256,"val":396},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080717735,"val":4585},{"ts":1586080727764,"val":4565},{"ts":1586080732785,"val":4603},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092823340,"val":7027},{"ts":1586092828356,"val":7033},{"ts":1586093596415,"val":7097},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586104448936,"val":3519},{"ts":1586104920743,"val":3575},{"ts":1586104925757,"val":3576},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147257587,"val":0}]
          widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
          (anonymous) @ widgets.min.js:4
          (anonymous) @ conn.js:1299
          setTimeout (async)
          getHistory @ conn.js:1297
          getHistory @ vis.js:2613
          getTaskForHistoryData @ widgets.min.js:4
          (anonymous) @ widgets.min.js:3
          setInterval (async)
          setTimeout (async)
          lineHistory @ widgets.min.js:3
          eval @ tplVis-materialdesign-Chart-Line-History.js:31
          (anonymous) @ can.custom.min.js:64
          a.each @ can.custom.min.js:24
          (anonymous) @ can.custom.min.js:58
          hookup @ can.custom.min.js:58
          a.add @ index.js:83
          Show 13 more frames
          widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 107
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 194
          widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542457581,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875096810,"val":902},{"ts":1585875101837,"val":964},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881142844,"val":1083},{"ts":1585881147858,"val":781},{"ts":1585881182990,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887190756,"val":1317},{"ts":1585887195774,"val":1228},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893239448,"val":5409},{"ts":1585893244472,"val":5317},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899288946,"val":2198},{"ts":1585899293958,"val":1491},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905332891,"val":756},{"ts":1585905337925,"val":769},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911380802,"val":1477},{"ts":1585911385823,"val":1469},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917428858,"val":1509},{"ts":1585917433849,"val":1518},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923481449,"val":1069},{"ts":1585923486473,"val":1220},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929529383,"val":866},{"ts":1585929534444,"val":2029},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935574081,"val":1616},{"ts":1585935579102,"val":1641},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941621951,"val":1832},{"ts":1585941626967,"val":1563},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947669968,"val":1567},{"ts":1585947675005,"val":1404},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953718193,"val":1133},{"ts":1585953723211,"val":1122},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971864331,"val":437},{"ts":1585971869365,"val":424},{"ts":1585971879417,"val":422},{"ts":1585975162738,"val":1677},{"ts":1585977908693,"val":999},{"ts":1585977913712,"val":1007},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983960967,"val":615},{"ts":1585983965996,"val":695},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585990005577,"val":1765},{"ts":1585990010588,"val":1418},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996056365,"val":1423},{"ts":1585996061386,"val":1496},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002103434,"val":1762},{"ts":1586002108453,"val":1384},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014198840,"val":1278},{"ts":1586014204096,"val":1280},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020244827,"val":632},{"ts":1586020249832,"val":627},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026292628,"val":401},{"ts":1586026297651,"val":748},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032341034,"val":1149},{"ts":1586032346148,"val":1487},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038389857,"val":962},{"ts":1586038394868,"val":1096},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044439569,"val":0},{"ts":1586044444598,"val":103},{"ts":1586044474730,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050488905,"val":1017},{"ts":1586050493929,"val":1689},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056537411,"val":1105},{"ts":1586056542425,"val":617},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062581675,"val":669},{"ts":1586062586691,"val":441},{"ts":1586062621791,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068631241,"val":871},{"ts":1586068636257,"val":285},{"ts":1586068691451,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080727764,"val":1332},{"ts":1586080732785,"val":1341},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092823340,"val":892},{"ts":1586092828356,"val":917},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104920744,"val":676},{"ts":1586104925757,"val":693},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110964619,"val":855},{"ts":1586110969633,"val":836},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586117015295,"val":1126},{"ts":1586117020309,"val":1125},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123062707,"val":754},{"ts":1586123067726,"val":749},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129110768,"val":830},{"ts":1586129115798,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135158842,"val":813},{"ts":1586135163912,"val":815},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147257581,"val":963}]
          ScroungerS 1 Antwort Letzte Antwort
          • Chris TailorC Chris Tailor
            @Scrounger Besten Dank
            Hier das Console Log:
            [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
            index.html?smarthub:3408 Version vis-canvas-gauges: 0.1.5
            index.html?smarthub:3948 Version vis-colorpicker: 1.0.1
            index.html?smarthub:5374 Version vis-history: 1.0.0
            info.js:9 Version Info-Adapter-Widget: 0.0.8
            keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
            index.html?smarthub:8340 Version vis-map: 1.0.3
            DevTools failed to parse SourceMap: http://192.168.86.90:8082/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
            materialdesign.js:25 Version vis-materialdesign: 0.2.77
            lib.min.js:22 Download the Vue Devtools extension for a better development experience:
            https://github.com/vuejs/vue-devtools
            lib.min.js:22 You are running Vue in development mode.
            Make sure to turn on production mode when deploying for production.
            See more tips at https://vuejs.org/guide/deployment.html
            players.js:58 Version players: 0.1.0
            conn.js:273 2020-04-06T04:26:34.511Z Connected => authenticate
            conn.js:293 2020-04-06T04:26:35.096Z Authenticated: true
            vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40083_Batterie_SOC
            vis.js:3167 Create inner vis object javascript.0.adapterdatenpunkte.modbus.Autarkie
            vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40068_PV_Leistung
            vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung
            widgets.min.js:3 [Line History Chart w00477] widget setting: {"_data":{"wid":"w00477","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"1","aggregate":"minmax","timeIntervalToShow":"2 hours","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"center","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"bottom","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"influxdb.0","oid0":"modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung","oid1":"modbus.0.holdingRegisters.40068_PV_Leistung","lineSpanGaps2":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showValues2":"true","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","lineSpanGaps3":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showValues3":"true","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"true","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","legendText0":"Hausverbrauch W","legendText1":"PV Leistung W","dataColor1":"#F3FFBD","dataColor0":"#B2DBBF","useFillColor0":true,"useFillColor1":true,"fillColor1":"","fillColor0":"","yAxisGridLinesColor1":"","yAxisValueColor1":"","yAxisGridLinesColor0":"white","yAxisValueColor0":"white","yAxisValueLabelColor":"#ffffff","yAxisTitleColor":"#ffffff","xAxisTitleColor":"","xAxisValueLabelColor":"#ffffff","time_interval_oid":"0_userdata.0.vis.Timeinterval_iSpeed","legendFontColor":"white","maxDataPoints":"100","commonYAxis0":"1","commonYAxis1":"1","colorScheme":"scrounger.pie","legendFontSize":"20","legendFontFamily":"Jura-Light","legendBoxWidth":"8","legendPadding":"","lineTension0":"","valuesMaxDecimals0":"0","valuesFontFamily0":"Jura-DemiBold","valuesFontSize0":"20","valuesFontFamily1":"Jura-DemiBold","valuesFontSize1":"20","valuesMaxDecimals1":"0","yAxisTitleFontFamily":"Jura-Light","yAxisTitleFontSize":"","yAxisValueFontFamily":"Jura-Light","yAxisValueFontSize":"15","xAxisValueFontFamily":"Jura-Light","xAxisValueFontSize":"15","chartPaddingRight":"20","chartPaddingTop":"22","manualRefreshTrigger":"0_userdata.0.vis.ChartAktualisieren","pointSize":"0","minTimeInterval":"","xAxisMinRotation":"0","xAxisMaxRotation":"0","valuesMinDecimals1":"15","mdwDebug":true},"_cid":".map17","_computedAttrs":{},"wid":"w00477",
            2widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
            setTimeout (async)
            setTimeout (async)
            a.add @ index.js:83
            Show 11 more frames
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 206
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585887997544,"val":18.78092805428227},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893179325,"val":197},{"ts":1585893184213,"val":196},{"ts":1585893204300,"val":193},{"ts":1585895684283,"val":501},{"ts":1585895769586,"val":470},{"ts":1585895774610,"val":480},{"ts":1585897185165,"val":0},{"ts":1585898159180,"val":659},{"ts":1585898364970,"val":628},{"ts":1585898369993,"val":625},{"ts":1585899575029,"val":530},{"ts":1585900945395,"val":987},{"ts":1585900960455,"val":983},{"ts":1585900965472,"val":981},{"ts":1585903529618,"val":2184},{"ts":1585903544678,"val":2184},{"ts":1585903549706,"val":2183},{"ts":1585903554752,"val":2180},{"ts":1585906116541,"val":3555},{"ts":1585906136652,"val":3515},{"ts":1585906141680,"val":3540},{"ts":1585906839996,"val":3192},{"ts":1585908723833,"val":4928},{"ts":1585908728849,"val":4926},{"ts":1585908733864,"val":4919},{"ts":1585908759022,"val":4910},{"ts":1585911325479,"val":5853},{"ts":1585911330492,"val":5854},{"ts":1585913902754,"val":6600},{"ts":1585913912811,"val":6594},{"ts":1585913917834,"val":6598},{"ts":1585914163920,"val":6467},{"ts":1585916384007,"val":6985},{"ts":1585916504542,"val":6936},{"ts":1585916509571,"val":6935},{"ts":1585917263083,"val":6529},{"ts":1585917584464,"val":7089},{"ts":1585919096685,"val":7003},{"ts":1585919101696,"val":7009},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921693478,"val":7030},{"ts":1585921698473,"val":7042},{"ts":1585922783485,"val":7092},{"ts":1585923817824,"val":6552},{"ts":1585924285138,"val":6735},{"ts":1585924290151,"val":6729},{"ts":1585926786616,"val":1903},{"ts":1585926877036,"val":6047},{"ts":1585926882051,"val":6151},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585929469104,"val":5025},{"ts":1585929474125,"val":5006},{"ts":1585932061362,"val":3015},{"ts":1585932066391,"val":2988},{"ts":1585932242172,"val":3059},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978687121,"val":119},{"ts":1585978717233,"val":108},{"ts":1585978722256,"val":115},{"ts":1585978747342,"val":99},{"ts":1585981303931,"val":374},{"ts":1585981308947,"val":372},{"ts":1585981313960,"val":371},{"ts":1585983418325,"val":259},{"ts":1585983820346,"val":543},{"ts":1585983895732,"val":524},{"ts":1585983905765,"val":517},{"ts":1585984789725,"val":22},{"ts":1585986491415,"val":734},{"ts":1585986496435,"val":716},{"ts":1585987214177,"val":0},{"ts":1585989081857,"val":1792},{"ts":1585989086736,"val":1795},{"ts":1585989192086,"val":1778},{"ts":1585991677443,"val":3044},{"ts":1585991682461,"val":3048},{"ts":1585992038901,"val":2880},{"ts":1585994168050,"val":4469},{"ts":1585994268477,"val":4409},{"ts":1585994273492,"val":4456},{"ts":1585994529574,"val":4425},{"ts":1585996844900,"val":5554},{"ts":1585996860023,"val":5554},{"ts":1585996865046,"val":5538},{"ts":1585996875086,"val":5534},{"ts":1585999380974,"val":6507},{"ts":1585999451346,"val":6472},{"ts":1585999456354,"val":6473},{"ts":1585999496486,"val":6420},{"ts":1586002028065,"val":6951},{"ts":1586002043171,"val":6943},{"ts":1586002048187,"val":6945},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004634898,"val":6903},{"ts":1586004639938,"val":6915},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586007226658,"val":7050},{"ts":1586007231700,"val":7044},{"ts":1586007277183,"val":7074},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586014992383,"val":5230},{"ts":1586015002414,"val":5237},{"ts":1586015007423,"val":5240},{"ts":1586017407825,"val":3634},{"ts":1586017588648,"val":3764},{"ts":1586017598695,"val":3752},{"ts":1586020169540,"val":2077},{"ts":1586020184597,"val":2080},{"ts":1586020189630,"val":2083},{"ts":1586022746179,"val":79},{"ts":1586022781371,"val":92},{"ts":1586022786410,"val":73},{"ts":1586022796454,"val":82},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063997372,"val":84},{"ts":1586064248282,"val":70},{"ts":1586064263341,"val":75},{"ts":1586064393948,"val":59},{"ts":1586066843732,"val":276},{"ts":1586066853766,"val":270},{"ts":1586068209595,"val":155},{"ts":1586069384063,"val":433},{"ts":1586069434376,"val":426},{"ts":1586069439382,"val":419},{"ts":1586071758748,"val":563},{"ts":1586071834103,"val":217},{"ts":1586072024984,"val":529},{"ts":1586072029999,"val":535},{"ts":1586072245821,"val":475},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077203046,"val":2650},{"ts":1586077213157,"val":2592},{"ts":1586077218168,"val":2617},{"ts":1586077238247,"val":0},{"ts":1586079738665,"val":4032},{"ts":1586079803897,"val":4013},{"ts":1586079813939,"val":4001},{"ts":1586079839106,"val":3956},{"ts":1586082339629,"val":5323},{"ts":1586082394850,"val":5307},{"ts":1586082399863,"val":5284},{"ts":1586082414917,"val":5281},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586092637546,"val":7053},{"ts":1586092763104,"val":7006},{"ts":1586092768120,"val":7000},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103128895,"val":4612},{"ts":1586103133838,"val":4604},{"ts":1586105724162,"val":3028},{"ts":1586105729185,"val":3041},{"ts":1586108073752,"val":1070},{"ts":1586108314620,"val":1101},{"ts":1586108319639,"val":1093},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147197607,"val":0}]
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 400
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585887997544,"val":993.6004784688995},{"ts":1585887998966,"val":1052},{"ts":1585888189680,"val":147},{"ts":1585889665174,"val":2601},{"ts":1585890588960,"val":1880},{"ts":1585890593982,"val":1100},{"ts":1585891688301,"val":370},{"ts":1585893128983,"val":6513},{"ts":1585893179325,"val":5325},{"ts":1585893184213,"val":5261},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585895769586,"val":1444},{"ts":1585895774610,"val":1215},{"ts":1585896286641,"val":472},{"ts":1585897873089,"val":3202},{"ts":1585898364970,"val":1484},{"ts":1585898369994,"val":1404},{"ts":1585899856172,"val":3180},{"ts":1585900824952,"val":783},{"ts":1585900955432,"val":927},{"ts":1585900960455,"val":2207},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903544678,"val":629},{"ts":1585903549706,"val":714},{"ts":1585904800420,"val":2535},{"ts":1585905036614,"val":109},{"ts":1585906136652,"val":1138},{"ts":1585906141684,"val":1360},{"ts":1585906196884,"val":620},{"ts":1585906789757,"val":7580},{"ts":1585908728849,"val":1621},{"ts":1585908733864,"val":2118},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585911325479,"val":1476},{"ts":1585911330492,"val":1477},{"ts":1585911375779,"val":1454},{"ts":1585912782456,"val":3479},{"ts":1585913912811,"val":1586},{"ts":1585913917834,"val":1579},{"ts":1585914163920,"val":1438},{"ts":1585916414148,"val":2888},{"ts":1585916504542,"val":1860},{"ts":1585916509571,"val":1722},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585919096685,"val":1601},{"ts":1585919101696,"val":1659},{"ts":1585920578494,"val":1454},{"ts":1585920714057,"val":3022},{"ts":1585921693480,"val":1549},{"ts":1585921698473,"val":1578},{"ts":1585922015043,"val":2670},{"ts":1585922220919,"val":979},{"ts":1585924285139,"val":1187},{"ts":1585924290152,"val":1151},{"ts":1585926344500,"val":2383},{"ts":1585926791643,"val":824},{"ts":1585926877036,"val":2139},{"ts":1585926882051,"val":1020},{"ts":1585927389541,"val":2238},{"ts":1585927645698,"val":578},{"ts":1585929464105,"val":883},{"ts":1585929474128,"val":879},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932061362,"val":6360},{"ts":1585932066391,"val":6159},{"ts":1585932186912,"val":6805},{"ts":1585932839608,"val":1735},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585935483710,"val":3882},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939834459,"val":3982},{"ts":1585939839473,"val":3983},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585947609823,"val":1346},{"ts":1585947614761,"val":1849},{"ts":1585948061642,"val":930},{"ts":1585950137489,"val":2922},{"ts":1585950202718,"val":2590},{"ts":1585950207734,"val":1615},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585953647922,"val":1088},{"ts":1585954190090,"val":1137},{"ts":1585956039145,"val":1013},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585958744944,"val":1015},{"ts":1585958815259,"val":995},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963074269,"val":815},{"ts":1585963164598,"val":447},{"ts":1585963169613,"val":445},{"ts":1585963767030,"val":368},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585968345560,"val":450},{"ts":1585968350578,"val":445},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585970941015,"val":387},{"ts":1585970945780,"val":386},{"ts":1585970990956,"val":376},{"ts":1585973415728,"val":1007},{"ts":1585973531270,"val":994},{"ts":1585973541299,"val":988},{"ts":1585973656679,"val":903},{"ts":1585975162738,"val":1677},{"ts":1585976121590,"val":974},{"ts":1585976126607,"val":978},{"ts":1585976432703,"val":1087},{"ts":1585977953951,"val":939},{"ts":1585978717233,"val":964},{"ts":1585978722256,"val":958},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585981308947,"val":381},{"ts":1585981313960,"val":378},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983900745,"val":1609},{"ts":1585983905765,"val":470},{"ts":1585983981076,"val":424},{"ts":1585984217203,"val":2734},{"ts":1585986491415,"val":1012},{"ts":1585986496435,"val":999},{"ts":1585986511507,"val":935},{"ts":158598896
            widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
            widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 1 day
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586060815542,"val":19.947579455043893},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063364835,"val":36},{"ts":1586063389936,"val":36},{"ts":1586063425053,"val":34},{"ts":1586063997372,"val":84},{"ts":1586064268379,"val":79},{"ts":1586064273399,"val":74},{"ts":1586064393948,"val":59},{"ts":1586065131806,"val":145},{"ts":1586065136832,"val":146},{"ts":1586065217180,"val":102},{"ts":1586065925107,"val":196},{"ts":1586065995424,"val":191},{"ts":1586066000439,"val":192},{"ts":1586066035563,"val":185},{"ts":1586066843732,"val":276},{"ts":1586066858788,"val":274},{"ts":1586066863801,"val":268},{"ts":1586067637051,"val":386},{"ts":1586067727427,"val":375},{"ts":1586067732438,"val":359},{"ts":1586068209595,"val":155},{"ts":1586068540859,"val":411},{"ts":1586068591055,"val":389},{"ts":1586068596077,"val":390},{"ts":1586068917655,"val":373},{"ts":1586069384063,"val":433},{"ts":1586069454442,"val":425},{"ts":1586069459493,"val":419},{"ts":1586070197508,"val":390},{"ts":1586070222599,"val":479},{"ts":1586070312906,"val":443},{"ts":1586070322938,"val":450},{"ts":1586070338001,"val":414},{"ts":1586070920499,"val":548},{"ts":1586071181476,"val":478},{"ts":1586071186498,"val":510},{"ts":1586071834103,"val":217},{"ts":1586072040042,"val":586},{"ts":1586072045080,"val":520},{"ts":1586072050089,"val":563},{"ts":1586072245821,"val":475},{"ts":1586072532026,"val":654},{"ts":1586072908547,"val":584},{"ts":1586072913577,"val":583},{"ts":1586073069196,"val":559},{"ts":1586073757247,"val":920},{"ts":1586073772341,"val":887},{"ts":1586073777354,"val":927},{"ts":1586073787388,"val":904},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586076364579,"val":1965},{"ts":1586076369615,"val":2020},{"ts":1586076856750,"val":1835},{"ts":1586077203046,"val":2650},{"ts":1586077228206,"val":2629},{"ts":1586077233227,"val":2636},{"ts":1586077238247,"val":0},{"ts":1586078091881,"val":3081},{"ts":1586078101962,"val":3084},{"ts":1586078116969,"val":3062},{"ts":1586078945609,"val":3555},{"ts":1586078955641,"val":3554},{"ts":1586078960682,"val":3566},{"ts":1586078985780,"val":3543},{"ts":1586079738665,"val":4032},{"ts":1586079818990,"val":3981},{"ts":1586079824022,"val":4019},{"ts":1586079839106,"val":3956},{"ts":1586080672557,"val":4572},{"ts":1586080682581,"val":4547},{"ts":1586080687605,"val":4565},{"ts":1586080787954,"val":4544},{"ts":1586081546248,"val":5004},{"ts":1586081551945,"val":4996},{"ts":1586081566310,"val":4981},{"ts":1586082339629,"val":5323},{"ts":1586082414917,"val":5281},{"ts":1586082419935,"val":5300},{"ts":1586082450037,"val":5298},{"ts":1586083243231,"val":5693},{"ts":1586083278362,"val":5692},{"ts":1586083283382,"val":5695},{"ts":1586083358669,"val":5637},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088460725,"val":6857},{"ts":1586088465726,"val":6845},{"ts":1586088521072,"val":6910},{"ts":1586088757078,"val":6820},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586092637546,"val":7053},{"ts":1586092738000,"val":6989},{"ts":1586092783176,"val":7000},{"ts":1586092788193,"val":7001},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093646660,"val":7038},{"ts":1586093651731,"val":7015},{"ts":1586093681791,"val":7043},{"ts":1586093932788,"val":6972},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096238576,"val":6786},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098549248,"val":6306},{"ts":1586098830323,"val":6332},{"ts":1586098835342,"val":6314},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103143897,"val":4596},{"ts":1586103148901,"val":4602},{"ts":1586103159184,"val":4593},{"ts":1586103173990,"val":4603},{"ts":1586103971920,"val":4118},{"ts":1586104007062,"val":4122},{"ts":1586104017114,"val":4126},{"ts":1586104032183,"val":4133},{"ts":1586104448936,"val":3519},{"ts":1586104875565,"val":3600},{"ts":1586104880592,"val":3594},{"ts":1586105739215,"val":3020},{"ts":1586105744232,"val":3023},{"ts":1586105749245,"val":3028},{"ts":1586106597564,"val":2470},{"ts":1586106607606,"val":2468},{"ts":1586107471103,"val":1809},{"ts":1586107476199,"val":1796},{"ts":1586107481131,"val":1802},{"ts":1586108334704,"val":1067},{"ts":1586108339732,"val":1062},{"ts":1586109198118,"val":169},{"ts":1586109203206,"val":162},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147215543,"val":0}]
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 328
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586060815542,"val":322.84586241276173},{"ts":1586060819569,"val":579},{"ts":1586060859739,"val":0},{"ts":1586061401936,"val":2078},{"ts":1586061678004,"val":583},{"ts":1586061683019,"val":415},{"ts":1586061748667,"val":0},{"ts":1586062104842,"val":1622},{"ts":1586062541545,"val":294},{"ts":1586062546668,"val":0},{"ts":1586062998234,"val":2038},{"ts":1586063405000,"val":135},{"ts":1586063410005,"val":286},{"ts":1586063470272,"val":0},{"ts":1586063967244,"val":2081},{"ts":1586064268379,"val":386},{"ts":1586064273399,"val":1191},{"ts":1586064383908,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065131807,"val":690},{"ts":1586065136832,"val":452},{"ts":1586065583541,"val":0},{"ts":1586065618661,"val":2177},{"ts":1586065995425,"val":886},{"ts":1586066000439,"val":235},{"ts":1586066070684,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066858790,"val":482},{"ts":1586066863801,"val":592},{"ts":1586066883914,"val":0},{"ts":1586067406105,"val":1935},{"ts":1586067727427,"val":468},{"ts":1586067732438,"val":601},{"ts":1586067742470,"val":0},{"ts":1586067812769,"val":1761},{"ts":1586068591055,"val":0},{"ts":1586068596077,"val":170},{"ts":1586068626232,"val":0},{"ts":1586069273632,"val":2032},{"ts":1586069454443,"val":625},{"ts":1586069459493,"val":917},{"ts":1586070242670,"val":2701},{"ts":1586070302873,"val":208},{"ts":1586070317923,"val":899},{"ts":1586070322939,"val":1367},{"ts":1586070624105,"val":207},{"ts":1586071025845,"val":2602},{"ts":1586071181476,"val":846},{"ts":1586071186498,"val":1101},{"ts":1586071628219,"val":2592},{"ts":1586071703481,"val":226},{"ts":1586072045082,"val":845},{"ts":1586072050089,"val":1317},{"ts":1586072230757,"val":413},{"ts":1586072762980,"val":2978},{"ts":1586072908548,"val":975},{"ts":1586072913578,"val":701},{"ts":1586073666896,"val":2709},{"ts":1586073767288,"val":444},{"ts":1586073772347,"val":924},{"ts":1586073777355,"val":1152},{"ts":1586074013295,"val":307},{"ts":1586074093629,"val":2544},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586076289173,"val":1207},{"ts":1586076364579,"val":1265},{"ts":1586076369615,"val":1296},{"ts":1586076610668,"val":1068},{"ts":1586077017357,"val":3198},{"ts":1586077228206,"val":1289},{"ts":1586077233228,"val":1278},{"ts":1586077238248,"val":0},{"ts":1586077685215,"val":1942},{"ts":1586078091881,"val":1158},{"ts":1586078096910,"val":1207},{"ts":1586078106940,"val":1166},{"ts":1586078352967,"val":3369},{"ts":1586078955641,"val":3196},{"ts":1586078960682,"val":3213},{"ts":1586078980763,"val":3257},{"ts":1586079186687,"val":1134},{"ts":1586079818990,"val":1571},{"ts":1586079824022,"val":1507},{"ts":1586080225786,"val":1926},{"ts":1586080486842,"val":1202},{"ts":1586080682581,"val":1333},{"ts":1586080687605,"val":1344},{"ts":1586081455867,"val":1416},{"ts":1586081516117,"val":1298},{"ts":1586081546248,"val":1338},{"ts":1586081551945,"val":1326},{"ts":1586081566310,"val":1308},{"ts":1586081722115,"val":3243},{"ts":1586082414918,"val":3051},{"ts":1586082419935,"val":3098},{"ts":1586082545523,"val":3320},{"ts":1586083223140,"val":1293},{"ts":1586083278363,"val":1324},{"ts":1586083283382,"val":1342},{"ts":1586083398807,"val":1288},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586085732930,"val":1369},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088465726,"val":2059},{"ts":1586088470825,"val":2076},{"ts":1586088561240,"val":2000},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090600065,"val":1956},{"ts":1586090630195,"val":778},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586092627510,"val":2070},{"ts":1586092732971,"val":868},{"ts":1586092783176,"val":888},{"ts":1586092788193,"val":894},{"ts":1586092868521,"val":2080},{"ts":1586093300238,"val":807},{"ts":1586093646660,"val":1057},{"ts":1586093651731,"val":822},{"ts":1586093661724,"val":815},{"ts":1586093787227,"val":2030},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095816995,"val":1322},{"ts":1586095857154,"val":2851},{"ts":1586096238576,"val":1371},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586098800198,"val":2478},{"ts":1586098830323,"val":1316},{"ts":1586098835342,"val":1301},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586103113778,"val":1315},{"ts":1586103148902,"val":1593},{"ts":1586103153929,"val":1261},{"ts":1586103159184,"val":2398},{"ts":1586103981944,"val":687},{"ts":1586104012091,"val":687},{"ts":1586104017115,"val":702},{"ts":1586104474012,"val":1934},{"ts":1586104870548,"val":664},{"ts":1586104875565,"val":693},{"ts":1586104880592,"val":692},{"ts":1586104930783,"val":1839},{"ts":1586105699084,"val":383},{"ts":1586105739216,"val":403},{"ts":1586105744232,"val":588},{"ts":1586105759281,"val":388},{"ts":1586106336553,"val":1621},{"ts":1586106602593,"val":445},{"ts":1586106607606,"val":438},{"ts":1586107144860,"val":431},{"ts":1586107325556,"val":2002},{"ts":1586107471103,"val":514},{"ts":1586107476199,"val":830},{"ts":1586107491177,"val":1670},{"ts":1586108164066,"val":110},{"ts":1586108334704,"val":674},{"ts":1586108339732,"val":357},{"ts":1586109082505,"val":35},{"ts":1586109188056,"val":2119},{"ts":1586109198118,"val":508},{"ts":1586109203206,"val":450},{"ts":1586109218231,"val":0},{"ts":1586109850709,"val":2206},{"ts":1586110061406,"val":232},{"ts":1586110066424,"val":888},{"ts":1586110141653,"val":126},{"ts":1586110252079,"val":2542},{"ts":1586110924465,"val":868},{"ts":1586110929486,"val":857},{"ts":1586111004750,"val":510},{"ts":1586111280685,"val":2601},{"ts":1586111787428,"val":1708},{"ts":1586111792442,"val":1660},{"ts":1586112354474,"val":1076},{"ts":1586112550182,"val":3304},{"ts":1586112655527,"val":1748},{"ts":1586112660537,"val":1783},{"ts":1586112871240,"val":1684},{"ts":1586113513452,"val":3736},{"ts":1586113518453,"val":3723},{"ts":1586113523475,"val":3733},{"ts":1586113628798,"val":3563},{"ts":1586114381222,"val":3680},{"ts":1586114386250,"val":3686},{"ts":1586114792624,"val":3769},{"ts":1586114862881,"val":1929},{"ts":1586115244235,"val":2042},{"ts":1586115249250,"val":2056},{"ts":1586115550299,"val":1166},{"ts":1586116087149,"val":3146},{"ts":1586116107211,"val":3130},{"ts":1586116112226,"val":3132},{"ts":1586116428259,"val":4117},{"ts":1586116779539,"val":1092},{"ts":1586116975168,"val":1093},{"ts":1586116980200,"val":1117},{"ts":1586117769027,"val":1188},{"ts":1586117839517,"val":1042},{"ts":1586117844536,"val":1053},{"ts":1586118065490,"val":983},{"ts":1586118672995,"val":2060},{"ts":1586118703098,"val":1250},{"ts":1586118708114,"val":1239},{"ts":1586118999493,"val":1460},{"ts":1586119561868,"val":1066},{"ts":1586119566886,"val":1072},{"ts":1586119571931,"val":1070},{"ts":1586119617135,"val":994},{"ts":1586120235271,"val":1286},{"ts":1586120430949,"val":1069},{"ts":1586120435977,"val":1068},{"ts":1586120471125,"val":1484},{"ts":1586121294876,"val":1196},{"ts":1586121299896,"val":1197},{"ts":1586121470673,"val":1481},{"ts":1586122012898,"val":876},{"ts":1586122158648,"val":890},{"ts":1586122163668,"val":894},{"ts":1586122399822,"val":1066},{"ts":1586123002470,"val":744},{"ts":1586123022552,"val":856},{"ts":1586123027566,"val":779},{"ts":1586123635474,"val":957},{"ts":1586123846241,"val":733},{"ts":1586123886377,"val":756},{"ts":1586123891397,"val":755},{"ts":1586124057031,"val":740},{"ts":1586124358522,"val":1079},{"ts":1586124750423,"val":822},{"ts":1586124755564,"val":823},{"ts":1586124896001,"val":805},{"ts":1586125483391,"val":978},{"ts":1586125614109,"val":843},{"ts":1586125619128,"val":845},{"ts":1586125694599,"val":851},{"ts":1586126016471,"val":743},{"ts":1586126473161,"val":760},{"ts":1586126483197,"val":753},{"ts":1586126548458,"val":750},{"ts":1586127206643,"val":1195},{"ts":1586127342251,"val":853},{"ts":1586127357302,"val":852},{"ts":1586127563231,"val":817},{"ts":1586127794593,"val":1617},{"ts":1586128201532,"val":900},{"ts":1586128211514,"val":905},{"ts":1586128472584,"val":911},{"ts":1586128608291,"val":819},{"ts":1586129070615,"val":834},{"ts":1586129075630,"val":841},{"ts":1586129136032,"val":846},{"ts":1586129502477,"val":817},{"ts":1586129934382,"val":820},{"ts":1586129939400,"val":829},{"ts":1586130085156,"val":821},{"ts":1586130456695,"val":1010},{"ts":1586130793195,"val":893},{"ts":1586130803232,"val":887},{"ts":1586130904252,"val":909},{"ts":1586131647319,"val":762},{"ts":1586131657353,"val":775},{"ts":1586131667477,"val":774},{"ts":1586131707555,"val":764},{"ts":1586132320385,"val":879},{"ts":1586132526173,"val":869},{"ts":1586132531213,"val":863},{"ts":1586132546279,"val":875},{"ts":1586132712049,"val":768},{"ts":1586133390253,"val":782},{"ts":1586133395276,"val":796},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586134254366,"val":852},{"ts":1586134259404,"val":842},{"ts":1586134284519,"val":858},{"ts":1586134405104,"val":778},{"ts":1586135118594,"val":811},{"ts":1586135123624,"val":820},{"ts":1586135194019,"val":800},{"ts":1586135630884,"val":1070},{"ts":1586135982464,"val":855},{"ts":1586135987482,"val":853},{"ts":1586136333985,"val":787},{"ts":1586136685546,"val":1050},{"ts":1586136846282,"val":878},{"ts":1586136851300,"val":874},{"ts":1586137011970,"val":862},{"ts":1586137288246,"val":1083},{"ts":1586137710306,"val":935},{"ts":1586137715336,"val":929},{"ts":1586137735449,"val":947},{"ts":1586138363143,"val":856},{"ts":1586138574110,"val":866},{"ts":1586138579123,"val":885},{"ts":1586138749901,"val":895},{"ts":1586139287234,"val":805},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141263684,"val":889},{"ts":1586141665342,"val":804},{"ts":1586142026837,"val":827},{"ts":1586142031851,"val":833},{"ts":1586142383576,"val":805},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586144671112,"val":967},{"ts":1586144866935,"val":878},{"ts":1586145484896,"val":892},{"ts":1586145489911,"val":888},{"ts":1586145715999,"val":877},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147215542,"val":963}]
            widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 328
            widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
            widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 3 days
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 208
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585888021338,"val":18.80886217247979},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893204300,"val":193},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585895684283,"val":501},{"ts":1585895794672,"val":480},{"ts":1585895799700,"val":473},{"ts":1585897185165,"val":0},{"ts":1585898159180,"val":659},{"ts":1585898385040,"val":617},{"ts":1585898390058,"val":628},{"ts":1585899575029,"val":530},{"ts":1585900980520,"val":994},{"ts":1585900985534,"val":1005},{"ts":1585901015644,"val":1003},{"ts":1585903569795,"val":2200},{"ts":1585903574811,"val":2196},{"ts":1585903645071,"val":2181},{"ts":1585906161769,"val":3571},{"ts":1585906166784,"val":3570},{"ts":1585906839996,"val":3192},{"ts":1585908723833,"val":4928},{"ts":1585908754000,"val":4924},{"ts":1585908759022,"val":4910},{"ts":1585911345563,"val":5898},{"ts":1585911350603,"val":5908},{"ts":1585912410550,"val":5877},{"ts":1585913922850,"val":6616},{"ts":1585913932895,"val":6599},{"ts":1585913942936,"val":6605},{"ts":1585914163920,"val":6467},{"ts":1585916384007,"val":6985},{"ts":1585916529650,"val":6944},{"ts":1585916534675,"val":6960},{"ts":1585917263083,"val":6529},{"ts":1585917584464,"val":7089},{"ts":1585919116745,"val":6997},{"ts":1585919126800,"val":7020},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921713534,"val":7025},{"ts":1585921723734,"val":7029},{"ts":1585922783485,"val":7092},{"ts":1585923817824,"val":6552},{"ts":1585924305287,"val":6682},{"ts":1585924310307,"val":6698},{"ts":1585926786616,"val":1903},{"ts":1585926897099,"val":5636},{"ts":1585926902112,"val":5320},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585929489238,"val":4971},{"ts":1585929494237,"val":4964},{"ts":1585929509309,"val":4983},{"ts":1585932066391,"val":2988},{"ts":1585932081439,"val":3016},{"ts":1585932086459,"val":3017},{"ts":1585932242172,"val":3059},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978687121,"val":119},{"ts":1585978737447,"val":112},{"ts":1585978742326,"val":117},{"ts":1585978747342,"val":99},{"ts":1585981303931,"val":374},{"ts":1585981318976,"val":369},{"ts":1585981334020,"val":376},{"ts":1585983418325,"val":259},{"ts":1585983820346,"val":543},{"ts":1585983920820,"val":515},{"ts":1585983925837,"val":521},{"ts":1585984789725,"val":22},{"ts":1585986491415,"val":734},{"ts":1585986516521,"val":711},{"ts":1585986521539,"val":742},{"ts":1585987214177,"val":0},{"ts":1585989086736,"val":1795},{"ts":1585989106800,"val":1779},{"ts":1585989111816,"val":1812},{"ts":1585989192086,"val":1778},{"ts":1585991682461,"val":3048},{"ts":1585991697540,"val":3026},{"ts":1585991702556,"val":3042},{"ts":1585992038901,"val":2880},{"ts":1585994288543,"val":4521},{"ts":1585994293558,"val":4515},{"ts":1585994529574,"val":4425},{"ts":1585996844900,"val":5554},{"ts":1585996885114,"val":5553},{"ts":1585996895147,"val":5562},{"ts":1585999380974,"val":6507},{"ts":1585999476411,"val":6458},{"ts":1585999481423,"val":6465},{"ts":1585999496486,"val":6420},{"ts":1586002028065,"val":6951},{"ts":1586002068265,"val":6928},{"ts":1586002073289,"val":6909},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004660013,"val":6868},{"ts":1586004665028,"val":6897},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586007251982,"val":7062},{"ts":1586007256978,"val":7056},{"ts":1586007277183,"val":7074},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586015012435,"val":5222},{"ts":1586015027508,"val":5225},{"ts":1586015032523,"val":5206},{"ts":1586015037535,"val":5220},{"ts":1586017407825,"val":3634},{"ts":1586017618787,"val":3733},{"ts":1586017628822,"val":3739},{"ts":1586020209705,"val":2037},{"ts":1586020214708,"val":2045},{"ts":1586020224747,"val":2051},{"ts":1586022801468,"val":69},{"ts":1586022806483,"val":79},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063997372,"val":84},{"ts":1586064273399,"val":74},{"ts":1586064283425,"val":70},{"ts":1586064393948,"val":59},{"ts":1586066843732,"val":276},{"ts":1586066868851,"val":273},{"ts":1586066873847,"val":279},{"ts":1586068209595,"val":155},{"ts":1586069384063,"val":433},{"ts":1586069459493,"val":419},{"ts":1586069464488,"val":421},{"ts":1586071834103,"val":217},{"ts":1586072040042,"val":586},{"ts":1586072050089,"val":563},{"ts":1586072055104,"val":537},{"ts":1586072245821,"val":475},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077203046,"val":2650},{"ts":1586077233227,"val":2636},{"ts":1586077238247,"val":0},{"ts":1586079738665,"val":4032},{"ts":1586079824022,"val":4019},{"ts":1586079834067,"val":4026},{"ts":1586079839106,"val":3956},{"ts":1586082339629,"val":5323},{"ts":1586082419935,"val":5300},{"ts":1586082424953,"val":5307},{"ts":1586082450037,"val":5298},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586092637546,"val":7053},{"ts":1586092788193,"val":7001},{"ts":1586092793207,"val":6983},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103143897,"val":4596},{"ts":1586103148901,"val":4602},{"ts":1586103159184,"val":4593},{"ts":1586103173990,"val":4603},{"ts":1586105739215,"val":3020},{"ts":1586105749245,"val":3028},{"ts":1586105754258,"val":3024},{"ts":1586108339732,"val":1062},{"ts":1586108344752,"val":1052},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147221338,"val":0}]
            setTimeout (async)
            o @ widgets.min.js:3
            t.dispatch @ can.custom.min.js:18
            stop @ can.custom.min.js:44
            _setAttrs @ can.custom.min.js:48
            attr @ can.custom.min.js:48
            (anonymous) @ vis.js:311
            r.onack @ index.js:83
            r.onpacket @ index.js:83
            (anonymous) @ index.js:83
            r.emit @ index.js:83
            r.ondecoded @ index.js:83
            a.add @ index.js:83
            r.ondata @ index.js:83
            r.onPacket @ index.js:83
            r.onData @ index.js:83
            ws.onmessage @ index.js:83
            widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 208
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585888021338,"val":978.7388789148215},{"ts":1585888024034,"val":954},{"ts":1585888189680,"val":147},{"ts":1585889665174,"val":2601},{"ts":1585890609036,"val":1003},{"ts":1585890614058,"val":947},{"ts":1585891688301,"val":370},{"ts":1585893128983,"val":6513},{"ts":1585893204300,"val":5228},{"ts":1585893209725,"val":5304},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585895794674,"val":1409},{"ts":1585895799700,"val":766},{"ts":1585896286641,"val":472},{"ts":1585897873089,"val":3202},{"ts":1585898385040,"val":1490},{"ts":1585898390058,"val":1463},{"ts":1585899856172,"val":3180},{"ts":1585900824952,"val":783},{"ts":1585900980520,"val":1525},{"ts":1585900985534,"val":1361},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903569795,"val":709},{"ts":1585903574811,"val":352},{"ts":1585904800420,"val":2535},{"ts":1585905036614,"val":109},{"ts":1585906161770,"val":1314},{"ts":1585906166784,"val":1319},{"ts":1585906196884,"val":620},{"ts":1585906789757,"val":7580},{"ts":1585908754000,"val":1853},{"ts":1585908759022,"val":2107},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585911345563,"val":1475},{"ts":1585911350603,"val":1800},{"ts":1585911375779,"val":1454},{"ts":1585912782456,"val":3479},{"ts":1585913937908,"val":1581},{"ts":1585913942936,"val":1610},{"ts":1585914163920,"val":1438},{"ts":1585916414148,"val":2888},{"ts":1585916529650,"val":1698},{"ts":1585916534675,"val":1736},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585919121783,"val":1582},{"ts":1585919126800,"val":1788},{"ts":1585920578494,"val":1454},{"ts":1585920714057,"val":3022},{"ts":1585921713534,"val":1572},{"ts":1585921718548,"val":1993},{"ts":1585922015043,"val":2670},{"ts":1585922220919,"val":979},{"ts":1585924305287,"val":1318},{"ts":1585924310307,"val":1138},{"ts":1585926344500,"val":2383},{"ts":1585926791643,"val":824},{"ts":1585926897099,"val":1016},{"ts":1585926902112,"val":1021},{"ts":1585927389541,"val":2238},{"ts":1585927645698,"val":578},{"ts":1585929489239,"val":866},{"ts":1585929494237,"val":1222},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932081440,"val":6083},{"ts":1585932086459,"val":6253},{"ts":1585932186912,"val":6805},{"ts":1585932839608,"val":1735},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585935483710,"val":3882},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939859554,"val":3969},{"ts":1585939864583,"val":3943},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585947634845,"val":1339},{"ts":1585947639854,"val":1342},{"ts":1585948061642,"val":930},{"ts":1585950137489,"val":2922},{"ts":1585950227803,"val":1559},{"ts":1585950232824,"val":1956},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585953647922,"val":1088},{"ts":1585954190090,"val":1137},{"ts":1585956039145,"val":1013},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585958744944,"val":1015},{"ts":1585958815259,"val":995},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963074269,"val":815},{"ts":1585963184681,"val":449},{"ts":1585963189696,"val":448},{"ts":1585963767030,"val":368},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585968365640,"val":449},{"ts":1585968375693,"val":450},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585970960846,"val":383},{"ts":1585970965865,"val":378},{"ts":1585970990956,"val":376},{"ts":1585973415728,"val":1007},{"ts":1585973556359,"val":996},{"ts":1585973561377,"val":993},{"ts":1585973656679,"val":903},{"ts":1585975162738,"val":1677},{"ts":1585976146690,"val":984},{"ts":1585976151706,"val":972},{"ts":1585976432703,"val":1087},{"ts":1585978737447,"val":895},{"ts":1585978742326,"val":892},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585981329005,"val":381},{"ts":1585981334020,"val":390},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983920820,"val":597},{"ts":1585983925837,"val":551},{"ts":1585983981076,"val":424},{"ts":1585984217203,"val":2734},{"ts":1585986516521,"val":988},{"ts":1585986521540,"val":1439},{"ts":1585986702219,"val":949},{"ts":1585988961236,"val":2760},{"ts":1585989106
            widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 7 days
            widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - TimeInterval by Editor **************************************************************
            setTimeout (async)
            a.add @ index.js:83
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 106
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542427421,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899258798,"val":655},{"ts":1585899263819,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905292697,"val":2903},{"ts":1585905297714,"val":2895},{"ts":1585905307760,"val":2896},{"ts":1585905674398,"val":2619},{"ts":1585911350603,"val":5908},{"ts":1585911355617,"val":5917},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917398670,"val":6958},{"ts":1585917403697,"val":6960},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923451340,"val":6947},{"ts":1585923456353,"val":6960},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929499251,"val":4965},{"ts":1585929504280,"val":4977},{"ts":1585929509309,"val":4983},{"ts":1585935513849,"val":153},{"ts":1585935543974,"val":158},{"ts":1585935549000,"val":160},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977878561,"val":62},{"ts":1585977888595,"val":66},{"ts":1585977898644,"val":59},{"ts":1585983820346,"val":543},{"ts":1585983930849,"val":517},{"ts":1585983935863,"val":522},{"ts":1585987214177,"val":0},{"ts":1585989970447,"val":2198},{"ts":1585989975437,"val":2185},{"ts":1585989980468,"val":2187},{"ts":1585995991077,"val":5337},{"ts":1585996026186,"val":5316},{"ts":1585996031210,"val":5338},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002073289,"val":6909},{"ts":1586002078320,"val":6922},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014168676,"val":5463},{"ts":1586014173704,"val":5469},{"ts":1586014178718,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020214708,"val":2045},{"ts":1586020219725,"val":2048},{"ts":1586020224747,"val":2051},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068601120,"val":382},{"ts":1586068606155,"val":387},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080672557,"val":4572},{"ts":1586080697652,"val":4564},{"ts":1586080702679,"val":4551},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092793207,"val":6983},{"ts":1586092798226,"val":6996},{"ts":1586093596415,"val":7097},{"ts":1586098840356,"val":6296},{"ts":1586098855415,"val":6290},{"ts":1586104448936,"val":3519},{"ts":1586104890630,"val":3594},{"ts":1586104895646,"val":3588},{"ts":1586104900666,"val":3593},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147227422,"val":0}]
            setTimeout (async)
            setInterval (async)
            setTimeout (async)
            frag @ can.custom.min.js:58
            r @ can.custom.min.js:58
            renderTo @ can.custom.min.js:58
            renderAs @ can.custom.min.js:58
            e.view.e.template @ can.custom.min.js:58
            renderWidget @ vis.js:1610
            (anonymous) @ vis.js:887
            (anonymous) @ vis.js:2742
            (anonymous) @ conn.js:730
            a.add @ index.js:83
            Show 13 more frames
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 105
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542427891,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899258798,"val":655},{"ts":1585899263819,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905292697,"val":2903},{"ts":1585905307760,"val":2896},{"ts":1585905312772,"val":2882},{"ts":1585905674398,"val":2619},{"ts":1585911355617,"val":5917},{"ts":1585911360684,"val":5923},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917403697,"val":6960},{"ts":1585917408732,"val":6957},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923451340,"val":6947},{"ts":1585923456353,"val":6960},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929499251,"val":4965},{"ts":1585929504280,"val":4977},{"ts":1585929509309,"val":4983},{"ts":1585935513849,"val":153},{"ts":1585935543974,"val":158},{"ts":1585935549000,"val":160},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977878561,"val":62},{"ts":1585977888595,"val":66},{"ts":1585977898644,"val":59},{"ts":1585983820346,"val":543},{"ts":1585983930849,"val":517},{"ts":1585983935863,"val":522},{"ts":1585987214177,"val":0},{"ts":1585989970447,"val":2198},{"ts":1585989975437,"val":2185},{"ts":1585989980468,"val":2187},{"ts":1585995991077,"val":5337},{"ts":1585996026186,"val":5316},{"ts":1585996031210,"val":5338},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002073289,"val":6909},{"ts":1586002078320,"val":6922},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014168676,"val":5463},{"ts":1586014173704,"val":5469},{"ts":1586014178718,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020219725,"val":2048},{"ts":1586020224747,"val":2051},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068601120,"val":382},{"ts":1586068606155,"val":387},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080672557,"val":4572},{"ts":1586080697652,"val":4564},{"ts":1586080702679,"val":4551},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092793207,"val":6983},{"ts":1586092798226,"val":6996},{"ts":1586093596415,"val":7097},{"ts":1586098840356,"val":6296},{"ts":1586098855415,"val":6290},{"ts":1586104448936,"val":3519},{"ts":1586104890630,"val":3594},{"ts":1586104895646,"val":3588},{"ts":1586104900666,"val":3593},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147227892,"val":0}]
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 192
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542427421,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875066695,"val":990},{"ts":1585875071710,"val":957},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881112719,"val":408},{"ts":1585881117733,"val":328},{"ts":1585881127769,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887160647,"val":814},{"ts":1585887165659,"val":715},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893209725,"val":5304},{"ts":1585893214336,"val":5505},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899258798,"val":1554},{"ts":1585899263819,"val":1807},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905302744,"val":543},{"ts":1585905307760,"val":936},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911350603,"val":1800},{"ts":1585911355618,"val":1458},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917398670,"val":1511},{"ts":1585917403698,"val":1498},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923451340,"val":1211},{"ts":1585923456353,"val":1076},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929499251,"val":863},{"ts":1585929504280,"val":1266},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935543974,"val":2298},{"ts":1585935549000,"val":2222},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941591810,"val":1457},{"ts":1585941596824,"val":1677},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947639854,"val":1342},{"ts":1585947644870,"val":1345},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953688242,"val":1128},{"ts":1585953693097,"val":1129},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971834208,"val":382},{"ts":1585971844242,"val":384},{"ts":1585975162738,"val":1677},{"ts":1585977878561,"val":997},{"ts":1585977883583,"val":1000},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983930849,"val":753},{"ts":1585983935863,"val":1631},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585989975438,"val":1416},{"ts":1585989980469,"val":1778},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996026187,"val":1579},{"ts":1585996031210,"val":1244},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002073290,"val":1403},{"ts":1586002078320,"val":1397},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014168676,"val":1277},{"ts":1586014173704,"val":1301},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020214708,"val":622},{"ts":1586020219725,"val":706},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026262452,"val":218},{"ts":1586026267476,"val":1036},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032310896,"val":652},{"ts":1586032315939,"val":964},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038359695,"val":670},{"ts":1586038364724,"val":1562},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044409399,"val":694},{"ts":1586044414434,"val":484},{"ts":1586044439569,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050458808,"val":608},{"ts":1586050463823,"val":946},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056507278,"val":1202},{"ts":1586056512293,"val":1065},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062551579,"val":119},{"ts":1586062556594,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068601120,"val":331},{"ts":1586068606155,"val":377},{"ts":1586068626232,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080697652,"val":1359},{"ts":1586080702680,"val":1344},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092793207,"val":881},{"ts":1586092798226,"val":1065},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104890630,"val":704},{"ts":1586104895646,"val":691},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110934505,"val":849},{"ts":1586110939527,"val":841},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586116985215,"val":1107},{"ts":1586116990225,"val":1118},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123032579,"val":749},{"ts":1586123037592,"val":752},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129080642,"val":832},{"ts":1586129085656,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135128646,"val":821},{"ts":1586135133700,"val":825},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147227422,"val":963}]
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542427891,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875066695,"val":990},{"ts":1585875071710,"val":957},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881112719,"val":408},{"ts":1585881117733,"val":328},{"ts":1585881127769,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887160647,"val":814},{"ts":1585887165659,"val":715},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893209725,"val":5304},{"ts":1585893214336,"val":5505},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899258798,"val":1554},{"ts":1585899263819,"val":1807},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905307760,"val":936},{"ts":1585905312772,"val":1337},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911355618,"val":1458},{"ts":1585911360684,"val":1565},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917403698,"val":1498},{"ts":1585917408732,"val":2677},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923451340,"val":1211},{"ts":1585923456353,"val":1076},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929499251,"val":863},{"ts":1585929504280,"val":1266},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935543974,"val":2298},{"ts":1585935549000,"val":2222},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941591810,"val":1457},{"ts":1585941596824,"val":1677},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947639854,"val":1342},{"ts":1585947644870,"val":1345},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953688242,"val":1128},{"ts":1585953693097,"val":1129},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971834208,"val":382},{"ts":1585971844242,"val":384},{"ts":1585975162738,"val":1677},{"ts":1585977883583,"val":1000},{"ts":1585977888595,"val":1003},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983930849,"val":753},{"ts":1585983935863,"val":1631},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585989975438,"val":1416},{"ts":1585989980469,"val":1778},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996026187,"val":1579},{"ts":1585996031210,"val":1244},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002073290,"val":1403},{"ts":1586002078320,"val":1397},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014168676,"val":1277},{"ts":1586014173704,"val":1301},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020219725,"val":706},{"ts":1586020224747,"val":626},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026267476,"val":1036},{"ts":1586026272518,"val":667},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032310896,"val":652},{"ts":1586032315939,"val":964},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038359695,"val":670},{"ts":1586038364724,"val":1562},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044409399,"val":694},{"ts":1586044414434,"val":484},{"ts":1586044439569,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050458808,"val":608},{"ts":1586050463823,"val":946},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056507278,"val":1202},{"ts":1586056512293,"val":1065},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062551579,"val":119},{"ts":1586062556594,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068601120,"val":331},{"ts":1586068606155,"val":377},{"ts":1586068626232,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080697652,"val":1359},{"ts":1586080702680,"val":1344},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092793207,"val":881},{"ts":1586092798226,"val":1065},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104890630,"val":704},{"ts":1586104895646,"val":691},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110939527,"val":841},{"ts":1586110944541,"val":525},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586116985215,"val":1107},{"ts":1586116990225,"val":1118},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123032579,"val":749},{"ts":1586123037592,"val":752},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129080642,"val":832},{"ts":1586129085656,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135128646,"val":821},{"ts":1586135133700,"val":825},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147227891,"val":963}]
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 107
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542457581,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893239448,"val":204},{"ts":1585893244471,"val":203},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899288946,"val":642},{"ts":1585899293958,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905332891,"val":2904},{"ts":1585905337924,"val":2896},{"ts":1585905674398,"val":2619},{"ts":1585911365768,"val":5936},{"ts":1585911380802,"val":5916},{"ts":1585911385822,"val":5926},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917428858,"val":6996},{"ts":1585917433849,"val":7003},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923481449,"val":6954},{"ts":1585923486473,"val":6952},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929529383,"val":4954},{"ts":1585929539440,"val":4956},{"ts":1585929594711,"val":4969},{"ts":1585935559025,"val":142},{"ts":1585935574080,"val":147},{"ts":1585935589139,"val":143},{"ts":1585935594162,"val":147},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977908692,"val":63},{"ts":1585977913712,"val":64},{"ts":1585977918743,"val":62},{"ts":1585983820346,"val":543},{"ts":1585983955926,"val":520},{"ts":1585983965996,"val":524},{"ts":1585987214177,"val":0},{"ts":1585989995523,"val":2210},{"ts":1585990005577,"val":2210},{"ts":1585990010587,"val":2211},{"ts":1585990020611,"val":2205},{"ts":1585996031210,"val":5338},{"ts":1585996056364,"val":5329},{"ts":1585996061386,"val":5334},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002098413,"val":6840},{"ts":1586002108453,"val":6837},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014198840,"val":5466},{"ts":1586014209331,"val":5460},{"ts":1586014264186,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020239796,"val":2045},{"ts":1586020249832,"val":2041},{"ts":1586020259865,"val":2042},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068631241,"val":394},{"ts":1586068636256,"val":396},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080717735,"val":4585},{"ts":1586080727764,"val":4565},{"ts":1586080732785,"val":4603},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092823340,"val":7027},{"ts":1586092828356,"val":7033},{"ts":1586093596415,"val":7097},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586104448936,"val":3519},{"ts":1586104920743,"val":3575},{"ts":1586104925757,"val":3576},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147257587,"val":0}]
            widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
            (anonymous) @ widgets.min.js:4
            (anonymous) @ conn.js:1299
            setTimeout (async)
            getHistory @ conn.js:1297
            getHistory @ vis.js:2613
            getTaskForHistoryData @ widgets.min.js:4
            (anonymous) @ widgets.min.js:3
            setInterval (async)
            setTimeout (async)
            lineHistory @ widgets.min.js:3
            eval @ tplVis-materialdesign-Chart-Line-History.js:31
            (anonymous) @ can.custom.min.js:64
            a.each @ can.custom.min.js:24
            (anonymous) @ can.custom.min.js:58
            hookup @ can.custom.min.js:58
            a.add @ index.js:83
            Show 13 more frames
            widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
            widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 107
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 194
            widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542457581,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875096810,"val":902},{"ts":1585875101837,"val":964},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881142844,"val":1083},{"ts":1585881147858,"val":781},{"ts":1585881182990,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887190756,"val":1317},{"ts":1585887195774,"val":1228},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893239448,"val":5409},{"ts":1585893244472,"val":5317},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899288946,"val":2198},{"ts":1585899293958,"val":1491},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905332891,"val":756},{"ts":1585905337925,"val":769},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911380802,"val":1477},{"ts":1585911385823,"val":1469},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917428858,"val":1509},{"ts":1585917433849,"val":1518},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923481449,"val":1069},{"ts":1585923486473,"val":1220},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929529383,"val":866},{"ts":1585929534444,"val":2029},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935574081,"val":1616},{"ts":1585935579102,"val":1641},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941621951,"val":1832},{"ts":1585941626967,"val":1563},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947669968,"val":1567},{"ts":1585947675005,"val":1404},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953718193,"val":1133},{"ts":1585953723211,"val":1122},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971864331,"val":437},{"ts":1585971869365,"val":424},{"ts":1585971879417,"val":422},{"ts":1585975162738,"val":1677},{"ts":1585977908693,"val":999},{"ts":1585977913712,"val":1007},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983960967,"val":615},{"ts":1585983965996,"val":695},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585990005577,"val":1765},{"ts":1585990010588,"val":1418},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996056365,"val":1423},{"ts":1585996061386,"val":1496},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002103434,"val":1762},{"ts":1586002108453,"val":1384},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014198840,"val":1278},{"ts":1586014204096,"val":1280},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020244827,"val":632},{"ts":1586020249832,"val":627},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026292628,"val":401},{"ts":1586026297651,"val":748},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032341034,"val":1149},{"ts":1586032346148,"val":1487},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038389857,"val":962},{"ts":1586038394868,"val":1096},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044439569,"val":0},{"ts":1586044444598,"val":103},{"ts":1586044474730,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050488905,"val":1017},{"ts":1586050493929,"val":1689},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056537411,"val":1105},{"ts":1586056542425,"val":617},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062581675,"val":669},{"ts":1586062586691,"val":441},{"ts":1586062621791,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068631241,"val":871},{"ts":1586068636257,"val":285},{"ts":1586068691451,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080727764,"val":1332},{"ts":1586080732785,"val":1341},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092823340,"val":892},{"ts":1586092828356,"val":917},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104920744,"val":676},{"ts":1586104925757,"val":693},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110964619,"val":855},{"ts":1586110969633,"val":836},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586117015295,"val":1126},{"ts":1586117020309,"val":1125},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123062707,"val":754},{"ts":1586123067726,"val":749},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129110768,"val":830},{"ts":1586129115798,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135158842,"val":813},{"ts":1586135163912,"val":815},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147257581,"val":963}]
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #894
            @Chris-Tailor
            Bitte die aktuelle version von git testen -> v0.2.78
            liv-in-skyL Chris TailorC 2 Antworten Letzte Antwort
            • ScroungerS Scrounger
              @Chris-Tailor
              liv-in-skyL Offline
              liv-in-skyL Offline
              #895
              @Scrounger
              ich habe ein seltsames problem - hast du dazu eine idee
              wenn ich widgets von anderen '"herstellern" (inventwo) in den editor ziehe, bekomme ich dich in den eigenschaften
              ScroungerS 1 Antwort Letzte Antwort
              • liv-in-skyL liv-in-sky
                @Scrounger
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                #896
                @liv-in-sky
                Versteht ich nicht du ziehst erst nen MDW Line Chart Widget, dann nen MDW Button Widget rein - beide haben unter Allgemein die Punkte Anleitung, etc.
                Dann ziehst nen html Widget rein und da findet man unter allgemein keine Angaben zum MDW Widget.
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #897
                  @Scrounger oh - man - ich sollte heute kein iobroker machen - habe nochmal gecheckt
                  habe deine widgets mit anderen verwechselt - ich dachte das MDW Button Widget ist ein anderes - die, die ich suchte, sind viel weiter unten zur auswahl
                  somit alles gut
                  war wohl etwas verwirrt, weil ich andere fehlermeldungen im browser habe, die aber nix mit deinen sachen zu tun haben
                    @Chris-Tailor
                    Chris TailorC Offline
                    Chris Tailor
                    #898
                    @Scrounger ok, eingespielt und getestet. Gefühlt funktionieren die Charts etwas besser und die Linien tauchen häufiger auf. Hier die Log Daten:
                    [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
                    index.html?smarthub:3408 Version vis-canvas-gauges: 0.1.5
                    index.html?smarthub:3948 Version vis-colorpicker: 1.0.1
                    index.html?smarthub:5374 Version vis-history: 1.0.0
                    info.js:9 Version Info-Adapter-Widget: 0.0.8
                    keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
                    index.html?smarthub:8340 Version vis-map: 1.0.3
                    materialdesign.js:25 Version vis-materialdesign: 0.2.78
                    lib.min.js:22 Download the Vue Devtools extension for a better development experience:
                    https://github.com/vuejs/vue-devtools
                    lib.min.js:22 You are running Vue in development mode.
                    Make sure to turn on production mode when deploying for production.
                    See more tips at https://vuejs.org/guide/deployment.html
                    players.js:58 Version players: 0.1.0
                    conn.js:273 2020-04-06T19:02:17.119Z Connected => authenticate
                    conn.js:293 2020-04-06T19:02:17.488Z Authenticated: true
                    vis.js:3167 Create inner vis object 0_userdata.0.vis.Timeinterval_iSpeed
                    vis.js:3167 Create inner vis object 0_userdata.0.vis.ChartAktualisieren
                    vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40083_Batterie_SOC
                    vis.js:3167 Create inner vis object javascript.0.adapterdatenpunkte.modbus.Autarkie
                    vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40068_PV_Leistung
                    vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung
                    widgets.min.js:3 [Line History Chart w00477] widget setting: {"_data":{"wid":"w00477","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"1","aggregate":"minmax","timeIntervalToShow":"2 hours","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"center","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"bottom","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"influxdb.0","oid0":"modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung","oid1":"modbus.0.holdingRegisters.40068_PV_Leistung","lineSpanGaps2":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showValues2":"true","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","lineSpanGaps3":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showValues3":"true","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"true","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","legendText0":"Hausverbrauch W","legendText1":"PV Leistung W","dataColor1":"#F3FFBD","dataColor0":"#B2DBBF","useFillColor0":true,"useFillColor1":true,"fillColor1":"","fillColor0":"","yAxisGridLinesColor1":"","yAxisValueColor1":"","yAxisGridLinesColor0":"white","yAxisValueColor0":"white","yAxisValueLabelColor":"#ffffff","yAxisTitleColor":"#ffffff","xAxisTitleColor":"","xAxisValueLabelColor":"#ffffff","time_interval_oid":"0_userdata.0.vis.Timeinterval_iSpeed","legendFontColor":"white","maxDataPoints":"100","commonYAxis0":"1","commonYAxis1":"1","colorScheme":"scrounger.pie","legendFontSize":"20","legendFontFamily":"Jura-Light","legendBoxWidth":"8","legendPadding":"","lineTension0":"","valuesMaxDecimals0":"0","valuesFontFamily0":"Jura-DemiBold","valuesFontSize0":"20","valuesFontFamily1":"Jura-DemiBold","valuesFontSize1":"20","valuesMaxDecimals1":"0","yAxisTitleFontFamily":"Jura-Light","yAxisTitleFontSize":"","yAxisValueFontFamily":"Jura-Light","yAxisValueFontSize":"15","xAxisValueFontFamily":"Jura-Light","xAxisValueFontSize":"15","chartPaddingRight":"20","chartPaddingTop":"22","manualRefreshTrigger":"0_userdata.0.vis.ChartAktualisieren","pointSize":"0","minTimeInterval":"","xAxisMinRotation":"0","xAxisMaxRotation":"0","valuesMinDecimals1":"15","mdwDebug":true},"_cid":".map17","_computedAttrs":{},"wid":"w00477",
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586113338503,"end":1586199738515,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586113338503,"end":1586199738518,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 326
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586113338503,"val":1723.9014955134596},{"ts":1586113342731,"val":1718},{"ts":1586113513452,"val":3736},{"ts":1586114200643,"val":3644},{"ts":1586114205657,"val":3650},{"ts":1586114792624,"val":3769},{"ts":1586114862881,"val":1929},{"ts":1586115063696,"val":2006},{"ts":1586115068709,"val":2011},{"ts":1586115550299,"val":1166},{"ts":1586115926612,"val":3144},{"ts":1586115931628,"val":3131},{"ts":1586116428259,"val":4117},{"ts":1586116779539,"val":1092},{"ts":1586116789568,"val":1125},{"ts":1586116794584,"val":1118},{"ts":1586117346778,"val":1148},{"ts":1586117542684,"val":1086},{"ts":1586117658265,"val":1113},{"ts":1586117663287,"val":1142},{"ts":1586118065490,"val":983},{"ts":1586118346638,"val":1673},{"ts":1586118517257,"val":1064},{"ts":1586118527297,"val":1071},{"ts":1586118537332,"val":1057},{"ts":1586118672995,"val":2060},{"ts":1586119386223,"val":1146},{"ts":1586119391253,"val":1143},{"ts":1586119617135,"val":994},{"ts":1586120235271,"val":1286},{"ts":1586120250234,"val":1078},{"ts":1586120255317,"val":1073},{"ts":1586120275350,"val":1065},{"ts":1586120471125,"val":1484},{"ts":1586121103849,"val":1288},{"ts":1586121118893,"val":1293},{"ts":1586121470673,"val":1481},{"ts":1586121716647,"val":881},{"ts":1586121977720,"val":889},{"ts":1586121982744,"val":884},{"ts":1586122399822,"val":1066},{"ts":1586122721276,"val":747},{"ts":1586122841782,"val":752},{"ts":1586122846814,"val":757},{"ts":1586123148085,"val":736},{"ts":1586123635474,"val":957},{"ts":1586123700753,"val":755},{"ts":1586123706531,"val":764},{"ts":1586123846241,"val":733},{"ts":1586124358522,"val":1079},{"ts":1586124569659,"val":828},{"ts":1586124574685,"val":836},{"ts":1586124675068,"val":804},{"ts":1586125433185,"val":813},{"ts":1586125438198,"val":815},{"ts":1586125483391,"val":978},{"ts":1586126016471,"val":743},{"ts":1586126297445,"val":766},{"ts":1586126302467,"val":756},{"ts":1586126402869,"val":779},{"ts":1586126548458,"val":750},{"ts":1586127161490,"val":767},{"ts":1586127166510,"val":764},{"ts":1586127171717,"val":761},{"ts":1586127794593,"val":1617},{"ts":1586128025626,"val":905},{"ts":1586128030654,"val":899},{"ts":1586128472584,"val":911},{"ts":1586128608291,"val":819},{"ts":1586128889780,"val":836},{"ts":1586128894822,"val":834},{"ts":1586129060578,"val":847},{"ts":1586129502477,"val":817},{"ts":1586129753556,"val":825},{"ts":1586129758573,"val":835},{"ts":1586129889197,"val":820},{"ts":1586130456695,"val":1010},{"ts":1586130617400,"val":979},{"ts":1586130622414,"val":968},{"ts":1586130692729,"val":999},{"ts":1586131039502,"val":764},{"ts":1586131481564,"val":775},{"ts":1586131486592,"val":773},{"ts":1586131647319,"val":762},{"ts":1586132320385,"val":879},{"ts":1586132345478,"val":872},{"ts":1586132350512,"val":871},{"ts":1586132465939,"val":875},{"ts":1586132712049,"val":768},{"ts":1586133209401,"val":785},{"ts":1586133214435,"val":784},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586134068484,"val":857},{"ts":1586134078520,"val":859},{"ts":1586134234292,"val":865},{"ts":1586134405104,"val":778},{"ts":1586134937634,"val":821},{"ts":1586134947677,"val":820},{"ts":1586135194019,"val":800},{"ts":1586135630884,"val":1070},{"ts":1586135801563,"val":911},{"ts":1586135806673,"val":909},{"ts":1586135856872,"val":978},{"ts":1586136333985,"val":787},{"ts":1586136665476,"val":817},{"ts":1586136670491,"val":807},{"ts":1586137288246,"val":1083},{"ts":1586137529545,"val":1031},{"ts":1586137534575,"val":1024},{"ts":1586137594815,"val":1039},{"ts":1586138363143,"val":856},{"ts":1586138393336,"val":876},{"ts":1586138398351,"val":872},{"ts":1586138523913,"val":898},{"ts":1586139141467,"val":808},{"ts":1586139256924,"val":817},{"ts":1586139261931,"val":820},{"ts":1586139287234,"val":805},{"ts":1586139337603,"val":824},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141263684,"val":889},{"ts":1586141665342,"val":804},{"ts":1586141846088,"val":822},{"ts":1586141851102,"val":815},{"ts":1586142383576,"val":805},{"ts":1586142634874,"val":1082},{"ts":1586142710282,"val":904},{"ts":1586142715298,"val":902},{"ts":1586142735355,"val":900},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586144671112,"val":967},{"ts":1586144866935,"val":878},{"ts":1586145303921,"val":892},{"ts":1586145308942,"val":887},{"ts":1586145715999,"val":877},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147744499,"val":887},{"ts":1586147754537,"val":897},{"ts":1586147779652,"val":888},{"ts":1586149597983,"val":2232},{"ts":1586149602974,"val":2255},{"ts":1586149623100,"val":2236},{"ts":1586149628164,"val":2235},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151865176,"val":517},{"ts":1586151990748,"val":2834},{"ts":1586152216757,"val":1344},{"ts":1586152221803,"val":1581},{"ts":15861522719
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 165
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586113338503,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149618166,"val":31},{"ts":1586149623100,"val":27},{"ts":1586149628164,"val":26},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586152171544,"val":178},{"ts":1586152216757,"val":176},{"ts":1586152221803,"val":179},{"ts":1586152231836,"val":174},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157300246,"val":529},{"ts":1586157400714,"val":479},{"ts":1586157405735,"val":486},{"ts":1586157701981,"val":554},{"ts":1586158214217,"val":431},{"ts":1586158264446,"val":529},{"ts":1586158269465,"val":539},{"ts":1586158274478,"val":484},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160849462,"val":1302},{"ts":1586160854436,"val":1295},{"ts":1586160859472,"val":1311},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163201203,"val":2013},{"ts":1586163432167,"val":2555},{"ts":1586163447246,"val":2505},{"ts":1586163457301,"val":2535},{"ts":1586163492471,"val":2428},{"ts":1586164296369,"val":2949},{"ts":1586164311434,"val":2944},{"ts":1586164316483,"val":2959},{"ts":1586164326546,"val":2944},{"ts":1586165125068,"val":3417},{"ts":1586165175311,"val":3403},{"ts":1586165180333,"val":3422},{"ts":1586165185350,"val":3414},{"ts":1586166023986,"val":3881},{"ts":1586166039028,"val":3875},{"ts":1586166044050,"val":3869},{"ts":1586166069136,"val":3739},{"ts":1586166802237,"val":4301},{"ts":1586166902691,"val":4293},{"ts":1586166907709,"val":4306},{"ts":1586167269338,"val":0},{"ts":1586167736383,"val":4810},{"ts":1586167761481,"val":4799},{"ts":1586167771521,"val":4808},{"ts":1586167776534,"val":4797},{"ts":1586168625287,"val":5207},{"ts":1586168630305,"val":5192},{"ts":1586168635337,"val":5233},{"ts":1586168700563,"val":5197},{"ts":1586169363735,"val":5466},{"ts":1586169494193,"val":5442},{"ts":1586169499209,"val":5445},{"ts":1586169504228,"val":5433},{"ts":1586170327789,"val":5738},{"ts":1586170357902,"val":5688},{"ts":1586170362962,"val":5682},{"ts":1586170383054,"val":5631},{"ts":1586171070939,"val":6003},{"ts":1586171221762,"val":5935},{"ts":1586171226816,"val":5923},{"ts":1586171231815,"val":5902},{"ts":1586172005168,"val":6252},{"ts":1586172085590,"val":6220},{"ts":1586172090633,"val":6228},{"ts":1586172130792,"val":6196},{"ts":1586172949375,"val":6512},{"ts":1586172954397,"val":6506},{"ts":1586172959414,"val":6539},{"ts":1586173486746,"val":6438},{"ts":1586173707772,"val":6618},{"ts":1586173818204,"val":6576},{"ts":1586173823220,"val":6575},{"ts":1586173853322,"val":6555},{"ts":1586174470952,"val":6771},{"ts":1586174681755,"val":6739},{"ts":1586174686775,"val":6695},{"ts":1586174762088,"val":6657},{"ts":1586174817321,"val":6748},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586176878355,"val":6839},{"ts":1586177013882,"val":6751},{"ts":1586177264908,"val":6792},{"ts":1586177274960,"val":6809},{"ts":1586177631651,"val":6903},{"ts":1586178108667,"val":6732},{"ts":1586178133751,"val":6774},{"ts":1586178138772,"val":6762},{"ts":1586178294421,"val":6687},{"ts":1586178927140,"val":6891},{"ts":1586179002448,"val":6874},{"ts":1586179007467,"val":6850},{"ts":1586179052674,"val":6903},{"ts":1586179624982,"val":6728},{"ts":1586179866122,"val":6850},{"ts":1586179871175,"val":6873},{"ts":1586179926359,"val":6915},{"ts":1586180222795,"val":6761},{"ts":1586180729883,"val":6855},{"ts":1586180739936,"val":6862},{"ts":1586180749981,"val":6879},{"ts":1586181588966,"val":6612},{"ts":1586181598931,"val":6617},{"ts":1586181629064,"val":6682},{"ts":1586182427579,"val":6451},{"ts":1586182457710,"val":6503},{"ts":1586182467740,"val":6531},{"ts":1586182482790,"val":6543},{"ts":1586183196081,"val":6296},{"ts":1586183321688,"val":6324},{"ts":1586183326700,"val":6307},{"ts":1586183366863,"val":6328},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586185814664,"val":5688},{"ts":1586185909992,"val":5700},{"ts":1586185915013,"val":5712},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586188440899,"val":4708},{"ts":1586188505968,"val":4726},{"ts":1586188510998,"val":4720},{"ts":1586188516024,"val":4736},{"ts":1586189360264,"val":4243},{"ts":1586189375155,"val":4247},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586191956637,"val":2618},{"ts":1586191961669,"val":2633},{"ts":1586191966693,"val":2622},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586194545428,"val":732},{"ts":1586194550613,"val":733},{"ts":1586194555503,"val":732},{"ts":1586195414466,"val":350},{"ts":1586195419488,"val":349},{"ts":1586195424513,"val":352},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199738518,"val":0}]
                    widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 326
                    widgets.min.js:3 [Line History Chart w00477] prepare dataset for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung'
                    widgets.min.js:3 [Line History Chart w00477] prepare yAxis for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung'
                    widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 165
                    widgets.min.js:3 [Line History Chart w00477] prepare dataset for 'modbus.0.holdingRegisters.40068_PV_Leistung'
                    widgets.min.js:3 [Line History Chart w00477] prepare yAxis for 'modbus.0.holdingRegisters.40068_PV_Leistung'
                    widgets.min.js:3 [Line History Chart w00477] prepare chart options
                    widgets.min.js:3 [Line History Chart w00477] chart creating...
                    widgets.min.js:3 [Line History Chart w00477] chart successful created
                    DevTools failed to parse SourceMap: http://192.168.86.90:8082/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
                    widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
                    widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 3 days
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585940557341,"end":1586199757342,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585940557341,"end":1586199757375,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 207
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585940557341,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585979410331,"val":160},{"ts":1585979425396,"val":160},{"ts":1585979445501,"val":163},{"ts":1585979500832,"val":130},{"ts":1585981580233,"val":416},{"ts":1585982027065,"val":415},{"ts":1585982032097,"val":412},{"ts":1585983418325,"val":259},{"ts":1585984202129,"val":602},{"ts":1585984618801,"val":486},{"ts":1585984623824,"val":542},{"ts":1585984789725,"val":22},{"ts":1585987204134,"val":904},{"ts":1585987209157,"val":903},{"ts":1585987214177,"val":0},{"ts":1585989488310,"val":1986},{"ts":1585989804619,"val":1895},{"ts":1585989809643,"val":1908},{"ts":1585992345235,"val":3430},{"ts":1585992395514,"val":3429},{"ts":1585992400564,"val":3448},{"ts":1585992611497,"val":3229},{"ts":1585994961493,"val":4834},{"ts":1585994986646,"val":4820},{"ts":1585994991617,"val":4829},{"ts":1585995011768,"val":4771},{"ts":1585997573034,"val":5780},{"ts":1585997578049,"val":5768},{"ts":1585997583064,"val":5771},{"ts":1585997658414,"val":5754},{"ts":1586000169320,"val":6703},{"ts":1586000174352,"val":6683},{"ts":1586001113661,"val":6654},{"ts":1586002028065,"val":6951},{"ts":1586002761211,"val":6890},{"ts":1586002766229,"val":6897},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586005353417,"val":7042},{"ts":1586005358433,"val":7047},{"ts":1586005780202,"val":7162},{"ts":1586006664079,"val":6851},{"ts":1586007945317,"val":7021},{"ts":1586007950335,"val":7044},{"ts":1586007965401,"val":7050},{"ts":1586010237076,"val":6617},{"ts":1586010533473,"val":6630},{"ts":1586010543508,"val":6605},{"ts":1586010548528,"val":6618},{"ts":1586013068196,"val":5894},{"ts":1586013128435,"val":5932},{"ts":1586013133457,"val":5934},{"ts":1586015720687,"val":4947},{"ts":1586015725716,"val":4951},{"ts":1586015730742,"val":4959},{"ts":1586018306656,"val":3283},{"ts":1586018316705,"val":3283},{"ts":1586018321812,"val":3267},{"ts":1586018326728,"val":3282},{"ts":1586020902675,"val":1569},{"ts":1586020907697,"val":1579},{"ts":1586020912737,"val":1557},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586064956168,"val":133},{"ts":1586064971234,"val":125},{"ts":1586064976257,"val":108},{"ts":1586064981268,"val":102},{"ts":1586067446285,"val":364},{"ts":1586067561788,"val":357},{"ts":1586067581866,"val":358},{"ts":1586068209595,"val":155},{"ts":1586070142281,"val":469},{"ts":1586070157356,"val":460},{"ts":1586070162372,"val":452},{"ts":1586071834103,"val":217},{"ts":1586072532026,"val":654},{"ts":1586072747921,"val":578},{"ts":1586072752947,"val":610},{"ts":1586072838255,"val":557},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586077926193,"val":2957},{"ts":1586077931233,"val":2946},{"ts":1586077936285,"val":2950},{"ts":1586077941281,"val":2947},{"ts":1586080521962,"val":4460},{"ts":1586080526978,"val":4466},{"ts":1586080537014,"val":4460},{"ts":1586083082597,"val":5622},{"ts":1586083112710,"val":5559},{"ts":1586083117723,"val":5597},{"ts":1586083127753,"val":5580},{"ts":1586085702830,"val":6392},{"ts":1586085707844,"val":6367},{"ts":1586085712863,"val":6336},{"ts":1586085763023,"val":6326},{"ts":1586088300106,"val":6946},{"ts":1586088305124,"val":6947},{"ts":1586088757078,"val":6820},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586092863505,"val":7061},{"ts":1586093300238,"val":6972},{"ts":1586093480888,"val":7021},{"ts":1586093485903,"val":7042},{"ts":1586093596415,"val":7097},{"ts":1586095897296,"val":6757},{"ts":1586096072966,"val":6802},{"ts":1586096078005,"val":6803},{"ts":1586098549248,"val":6306},{"ts":1586098664679,"val":6366},{"ts":1586098669704,"val":6372},{"ts":1586098689771,"val":6376},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103831452,"val":4215},{"ts":1586103851517,"val":4228},{"ts":1586103856531,"val":4234},{"ts":1586103896694,"val":4243},{"ts":1586106431949,"val":2610},{"ts":1586106441980,"val":2613},{"ts":1586106446995,"val":2612},{"ts":1586109032347,"val":342},{"ts":1586109037359,"val":347},{"ts":1586109042375,"val":336},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157701981,"val":554},{"ts":1586158284528,"val":494},{"ts":1586158289593,"val":515},{"ts":1586158294569,"val":486},{"ts":1586160874540,"val":1323},{"ts":1586160879573,"val":1330},{"ts":1586160889593,"val":1320},{"ts":1586163467336,"val":2581},{"ts":1586163472352,"val":2575},{"ts":1586163492471,"val":2428},{"ts":1586166023986,"val":3881},{"ts":1586166059103,"val":3875},{"ts":1586166069136,"val":3739},{"ts":1586167269338,"val":0},{"ts":1586168635337,"val":5233},{"ts":1586168650393,"val":5223},{"ts":1586168660426,"val":5221},{"ts":1586168700563,"val":5197},{"ts":1586171070939,"val":6003},{"ts":1586171241844,"val":5963},{"ts":1586171246863,"val":5986},{"ts":1586171322201,"val":5958},{"ts":1586173707772,"val":6618},{"ts":1586173833259,"val":6562},{"ts":1586173838275,"val":6568},{"ts":1586173853322,"val":6555},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586177631651,"val":6903},{"ts":1586178294421,"val":6687},{"ts":1586179017513,"val":6839},{"ts":1586179022544,"val":6850},{"ts":1586179926359,"val":6915},{"ts":1586181588966,"val":6612},{"ts":1586181608974,"val":6647},{"ts":1586181613979,"val":6653},{"ts":1586181629064,"val":6682},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586189385203,"val":4233},{"ts":1586189390219,"val":4236},{"ts":1586191976725,"val":2617},{"ts":1586191981746,"val":2614},{"ts":1586191986769,"val":2617},{"ts":1586194570862,"val":725},{"ts":1586194575555,"val":723},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199757375,"val":0}]
                    setTimeout (async)
                    o @ widgets.min.js:3
                    t.dispatch @ can.custom.min.js:18
                    stop @ can.custom.min.js:44
                    _setAttrs @ can.custom.min.js:48
                    attr @ can.custom.min.js:48
                    (anonymous) @ vis.js:311
                    r.onack @ index.js:83
                    r.onpacket @ index.js:83
                    (anonymous) @ index.js:83
                    r.emit @ index.js:83
                    r.ondecoded @ index.js:83
                    a.add @ index.js:83
                    r.ondata @ index.js:83
                    r.onPacket @ index.js:83
                    r.onData @ index.js:83
                    ws.onmessage @ index.js:83
                    widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 207
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 397
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585940557341,"val":1493.966487133453},{"ts":1585940557509,"val":1494},{"ts":1585941119725,"val":4620},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585948217175,"val":1651},{"ts":1585950067209,"val":1609},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585950920474,"val":1458},{"ts":1585950925489,"val":1441},{"ts":1585951005790,"val":2281},{"ts":1585951030887,"val":1036},{"ts":1585953512452,"val":1128},{"ts":1585953517472,"val":1125},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585956104350,"val":922},{"ts":1585956109368,"val":927},{"ts":1585956164595,"val":918},{"ts":1585956209779,"val":1009},{"ts":1585958699755,"val":1001},{"ts":1585958704778,"val":997},{"ts":1585958744944,"val":1015},{"ts":1585961256928,"val":374},{"ts":1585961292052,"val":375},{"ts":1585961297064,"val":387},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585963882496,"val":591},{"ts":1585963887522,"val":585},{"ts":1585963892538,"val":591},{"ts":1585966297472,"val":369},{"ts":1585966473174,"val":384},{"ts":1585966478204,"val":388},{"ts":1585966483209,"val":384},{"ts":1585966598601,"val":768},{"ts":1585969068361,"val":447},{"ts":1585969073380,"val":443},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585971658569,"val":388},{"ts":1585971663581,"val":390},{"ts":1585971763990,"val":377},{"ts":1585973827422,"val":1271},{"ts":1585974249062,"val":978},{"ts":1585974254074,"val":972},{"ts":1585975162738,"val":1677},{"ts":1585976834267,"val":953},{"ts":1585976844306,"val":961},{"ts":1585976849318,"val":965},{"ts":1585977411665,"val":1070},{"ts":1585979345075,"val":872},{"ts":1585979435460,"val":891},{"ts":1585979440480,"val":890},{"ts":1585980003100,"val":912},{"ts":1585980148705,"val":348},{"ts":1585982027065,"val":389},{"ts":1585982032097,"val":380},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585984618801,"val":641},{"ts":1585984623824,"val":983},{"ts":1585985718318,"val":879},{"ts":1585987194094,"val":2630},{"ts":1585987209157,"val":1471},{"ts":1585987214177,"val":1428},{"ts":1585987244266,"val":1332},{"ts":1585989161988,"val":3025},{"ts":1585989804620,"val":1735},{"ts":1585989809643,"val":2760},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992395514,"val":1674},{"ts":1585992400564,"val":1330},{"ts":1585992661663,"val":917},{"ts":1585994248405,"val":3707},{"ts":1585994986646,"val":1593},{"ts":1585994991618,"val":1562},{"ts":1585995252796,"val":2874},{"ts":1585996704240,"val":1231},{"ts":1585997578049,"val":1275},{"ts":1585997583064,"val":1309},{"ts":1585997663448,"val":1258},{"ts":1585998266153,"val":2610},{"ts":1586000169320,"val":1314},{"ts":1586000174353,"val":1308},{"ts":1586001113661,"val":1185},{"ts":1586002610627,"val":2655},{"ts":1586002761211,"val":1532},{"ts":1586002766231,"val":1533},{"ts":1586003238503,"val":6525},{"ts":1586005338344,"val":1427},{"ts":1586005353417,"val":2541},{"ts":1586005358434,"val":1430},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586007945317,"val":1407},{"ts":1586007950335,"val":1432},{"ts":1586007995500,"val":2551},{"ts":1586010262197,"val":1360},{"ts":1586010538490,"val":1390},{"ts":1586010543509,"val":1370},{"ts":1586012500505,"val":2479},{"ts":1586012972700,"val":334},{"ts":1586013128435,"val":2425},{"ts":1586013133457,"val":1550},{"ts":1586014048013,"val":1255},{"ts":1586014384795,"val":2524},{"ts":1586015720687,"val":1261},{"ts":1586015725735,"val":1274},{"ts":1586015881337,"val":1170},{"ts":1586017402800,"val":2539},{"ts":1586018316705,"val":1475},{"ts":1586018321812,"val":1188},{"ts":1586018447204,"val":2311},{"ts":1586020882757,"val":607},{"ts":1586020907697,"val":622},{"ts":1586020912755,"val":620},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586023499221,"val":357},{"ts":1586023504304,"val":327},{"ts":1586023514357,"val":0},{"ts":1586024840244,"val":2290},{"ts":1586026091762,"val":1026},{"ts":1586026096785,"val":510},{"ts":1586026111837,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586028683486,"val":702},{"ts":1586028688500,"val":0},{"ts":1586031230910,"val":2558},{"ts":1586031276229,"val":809},{"ts":1586031281181,"val":918},{"ts":1586032536892,"val":150},{"ts":1586033536704,"val":2855},{"ts":1586033868131,"val":1139},{"ts":1586033873142,"val":1577},{"ts":1586034682203,"val":291},{"ts":1586036078983,"val":2692},{"ts":1586036460721,"val":853},{"ts":1586036465735,"val":1001},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586039053191,"val":1032},{"ts":1586039058211,"val":590},{"ts":1586039113413,"val":0},{"ts":1586040704830,"val"
                    widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 7 days
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594965660,"end":1586199765664,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594965660,"end":1586199765672,"timeout":2000}
                    2widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                    setTimeout (async)
                    a.add @ index.js:83
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 133
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585594965660,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585891306695,"val":46},{"ts":1585891316733,"val":43},{"ts":1585891321759,"val":53},{"ts":1585897185165,"val":0},{"ts":1585897305676,"val":596},{"ts":1585897361130,"val":575},{"ts":1585897365959,"val":584},{"ts":1585897747504,"val":269},{"ts":1585903394072,"val":2106},{"ts":1585903409019,"val":2106},{"ts":1585903414039,"val":2116},{"ts":1585903419055,"val":2093},{"ts":1585909457181,"val":5275},{"ts":1585909462256,"val":5273},{"ts":1585909532468,"val":5220},{"ts":1585915334368,"val":6874},{"ts":1585915505122,"val":6855},{"ts":1585915510143,"val":6857},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921552767,"val":7068},{"ts":1585921557800,"val":7070},{"ts":1585921628137,"val":7093},{"ts":1585927444855,"val":1193},{"ts":1585927600539,"val":1279},{"ts":1585927605707,"val":1271},{"ts":1585927926879,"val":6109},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585981580233,"val":416},{"ts":1585982037109,"val":411},{"ts":1585982042123,"val":414},{"ts":1585987214177,"val":0},{"ts":1585988067501,"val":1294},{"ts":1585988082563,"val":1281},{"ts":1585988087572,"val":1293},{"ts":1585988092587,"val":1291},{"ts":1585994117847,"val":4449},{"ts":1585994132909,"val":4376},{"ts":1585994137923,"val":4362},{"ts":1585994248405,"val":4116},{"ts":1586000179374,"val":6704},{"ts":1586000184399,"val":6718},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586006227106,"val":7039},{"ts":1586006232205,"val":7057},{"ts":1586007086047,"val":7110},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586018321812,"val":3267},{"ts":1586018326728,"val":3282},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586066698141,"val":255},{"ts":1586066708178,"val":253},{"ts":1586066713192,"val":254},{"ts":1586068209595,"val":155},{"ts":1586072532026,"val":654},{"ts":1586072752947,"val":610},{"ts":1586072757965,"val":566},{"ts":1586077238247,"val":0},{"ts":1586078784835,"val":3492},{"ts":1586078804939,"val":3458},{"ts":1586078810042,"val":3456},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093596415,"val":7097},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586102993321,"val":4694},{"ts":1586102998338,"val":4683},{"ts":1586109042375,"val":336},{"ts":1586109047386,"val":329},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586157300246,"val":529},{"ts":1586157425812,"val":518},{"ts":1586157430842,"val":498},{"ts":1586158214217,"val":431},{"ts":1586163467336,"val":2581},{"ts":1586163477369,"val":2581},{"ts":1586163487412,"val":2566},{"ts":1586167269338,"val":0},{"ts":1586169363735,"val":5466},{"ts":1586169524305,"val":5448},{"ts":1586169529329,"val":5469},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586179926359,"val":6915},{"ts":1586181588966,"val":6612},{"ts":1586181619171,"val":6664},{"ts":1586181624020,"val":6653},{"ts":1586181629064,"val":6682},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199765672,"val":0}]
                    widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - TimeInterval by Editor **************************************************************
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594968557,"end":1586199768562,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594968557,"end":1586199768567,"timeout":2000}
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 230
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585594965660,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585860971999,"val":1361},{"ts":1585861809586,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585867125428,"val":608},{"ts":1585867130446,"val":807},{"ts":1585871728785,"val":2806},{"ts":1585872582450,"val":259},{"ts":1585873169522,"val":956},{"ts":1585873174535,"val":390},{"ts":1585873425472,"val":2692},{"ts":1585875468113,"val":0},{"ts":1585879220150,"val":216},{"ts":1585879225212,"val":219},{"ts":1585879300521,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585885263599,"val":282},{"ts":1585885273627,"val":327},{"ts":1585885368978,"val":0},{"ts":1585891211257,"val":2620},{"ts":1585891316733,"val":1650},{"ts":1585891321769,"val":1277},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585897361130,"val":1548},{"ts":1585897365959,"val":1455},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903409020,"val":712},{"ts":1585903414039,"val":872},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585909457181,"val":2250},{"ts":1585909462258,"val":2204},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585915505124,"val":1641},{"ts":1585915510143,"val":1637},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585921552767,"val":1540},{"ts":1585921557800,"val":1536},{"ts":1585921663313,"val":2673},{"ts":1585927419689,"val":696},{"ts":1585927600539,"val":1376},{"ts":1585927605707,"val":868},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939698950,"val":1980},{"ts":1585939703970,"val":1825},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585963892538,"val":591},{"ts":1585963897559,"val":588},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585969936897,"val":380},{"ts":1585969941912,"val":377},{"ts":1585970172785,"val":376},{"ts":1585970197879,"val":1802},{"ts":1585975981062,"val":976},{"ts":1585975991103,"val":983},{"ts":1585976432703,"val":1087},{"ts":1585980148705,"val":348},{"ts":1585982037109,"val":391},{"ts":1585982042123,"val":390},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585988082563,"val":1564},{"ts":1585988087572,"val":1563},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585994132910,"val":2150},{"ts":1585994137923,"val":2553},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1586000179374,"val":1686},{"ts":1586000184399,"val":1310},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586006222093,"val":1436},{"ts":1586006232206,"val":1442},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017402800,"val":2539},{"ts":1586018321812,"val":1188},{"ts":1586018326728,"val":2304},{"ts":1586018447204,"val":2311},{"ts":1586022484981,"val":0},{"ts":1586024373037,"val":612},{"ts":1586024378059,"val":574},{"ts":1586024508643,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586030416942,"val":296},{"ts":1586030423081,"val":228},{"ts":1586030522456,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586036465735,"val":1001},{"ts":1586036470755,"val":973},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586042516828,"val":410},{"ts":1586042521838,"val":283},{"ts":1586042526870,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586048561350,"val":553},{"ts":1586048566369,"val":326},{"ts":1586048611524,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586054610113,"val":871},{"ts":1586054615138,"val":838},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586060658896,"val":400},{"ts":1586060663945,"val":354},{"ts":1586060673971,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066708178,"val":553},{"ts":1586066713192,"val":443},{"ts":1586066738312,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586072752947,"val":1278},{"ts":1586072757965,"val":1122},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586078804939,"val":3104},{"ts":1586078810043,"val":3049},{"ts":1586079186687,"val":1134},{"ts":1586082545523,"val":3320},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586102621756,"val":6094},{"ts":1586102993321,"val":1357},{"ts":1586102998338,"val":1352},{"ts":1586103083636,"val":2490},{"ts":1586108164066,"val":110},{"ts":1586109042375,"val":735},{"ts":1586109047387,"val":837},{"ts":1586109218231,"val":0},{"ts":1586114792624,"val":3769},{"ts":1586115088771,"val":2002},{"ts":1586115093790,"val":2011},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586121138991,"val":1289},{"ts":1586121144012,"val":1291},{"ts":1586121470673,"val":1481},{"ts":1586123846241,"val":733},{"ts":1586127186563,"val":775},{"ts":1586127191579,"val":766},{"ts":1586127201621,"val":762},{"ts":1586127794593,"val":1617},{"ts":1586133234497,"val":784},{"ts":1586133239574,"val":786},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586139282099,"val":820},{"ts":1586139287234,"val":805},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586145329017,"val":891},{"ts":1586145334099,"val":890},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586152271986,"val":459},{"ts":1586157059190,"val":2999},{"ts":1586157425813,"val":815},{"ts":1586157430842,"val":988},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586163477370,"val":1600},{"ts":1586163482397,"val":1589},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586169524306,"val":5683},{"ts":1586169529329,"val":1743},{"ts":1586169634764,"val":5949},{"ts":1586169770472,"val":1072},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586181619171,"val":1147},{"ts":1586181624020,"val":1253},{"ts":1586182377307,"val":2336},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586199761872,"val":1223},{"ts":1586199765664,"val":1223}]
                    setTimeout (async)
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585594968557,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585891306695,"val":46},{"ts":1585891316733,"val":43},{"ts":1585891321759,"val":53},{"ts":1585897185165,"val":0},{"ts":1585897305676,"val":596},{"ts":1585897365959,"val":584},{"ts":1585897370985,"val":576},{"ts":1585897747504,"val":269},{"ts":1585903414039,"val":2116},{"ts":1585903419055,"val":2093},{"ts":1585909457181,"val":5275},{"ts":1585909462256,"val":5273},{"ts":1585909467217,"val":5281},{"ts":1585909532468,"val":5220},{"ts":1585915334368,"val":6874},{"ts":1585915510143,"val":6857},{"ts":1585915515159,"val":6867},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921557800,"val":7070},{"ts":1585921562829,"val":7068},{"ts":1585921628137,"val":7093},{"ts":1585927444855,"val":1193},{"ts":1585927605707,"val":1271},{"ts":1585927610569,"val":1270},{"ts":1585927926879,"val":6109},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585981580233,"val":416},{"ts":1585982037109,"val":411},{"ts":1585982042123,"val":414},{"ts":1585987214177,"val":0},{"ts":1585988067501,"val":1294},{"ts":1585988087572,"val":1293},{"ts":1585988092587,"val":1291},{"ts":1585994117847,"val":4449},{"ts":1585994132909,"val":4376},{"ts":1585994137923,"val":4362},{"ts":1585994248405,"val":4116},{"ts":1586000184399,"val":6718},{"ts":1586000189417,"val":6719},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586006232205,"val":7057},{"ts":1586006237201,"val":7051},{"ts":1586007086047,"val":7110},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586018321812,"val":3267},{"ts":1586018326728,"val":3282},{"ts":1586018331752,"val":3261},{"ts":1586018341800,"val":3265},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586066698141,"val":255},{"ts":1586066708178,"val":253},{"ts":1586066713192,"val":254},{"ts":1586068209595,"val":155},{"ts":1586072532026,"val":654},{"ts":1586072757965,"val":566},{"ts":1586072762980,"val":581},{"ts":1586077238247,"val":0},{"ts":1586078784835,"val":3492},{"ts":1586078804939,"val":3458},{"ts":1586078810042,"val":3456},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093596415,"val":7097},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586102998338,"val":4683},{"ts":1586103003361,"val":4677},{"ts":1586103008412,"val":4681},{"ts":1586109047386,"val":329},{"ts":1586109052403,"val":325},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586157300246,"val":529},{"ts":1586157430842,"val":498},{"ts":1586157435871,"val":489},{"ts":1586158214217,"val":431},{"ts":1586163467336,"val":2581},{"ts":1586163477369,"val":2581},{"ts":1586163487412,"val":2566},{"ts":1586167269338,"val":0},{"ts":1586169363735,"val":5466},{"ts":1586169524305,"val":5448},{"ts":1586169529329,"val":5469},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586179926359,"val":6915},{"ts":1586181588966,"val":6612},{"ts":1586181624020,"val":6653},{"ts":1586181629064,"val":6682},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199768567,"val":0}]
                    widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585594968557,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585860971999,"val":1361},{"ts":1585861809586,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585867125428,"val":608},{"ts":1585867130446,"val":807},{"ts":1585871728785,"val":2806},{"ts":1585872582450,"val":259},{"ts":1585873174535,"val":390},{"ts":1585873179557,"val":914},{"ts":1585873425472,"val":2692},{"ts":1585875468113,"val":0},{"ts":1585879220150,"val":216},{"ts":1585879225212,"val":219},{"ts":1585879300521,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585885263599,"val":282},{"ts":1585885273627,"val":327},{"ts":1585885368978,"val":0},{"ts":1585891211257,"val":2620},{"ts":1585891316733,"val":1650},{"ts":1585891321769,"val":1277},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585897365959,"val":1455},{"ts":1585897370985,"val":1462},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903414039,"val":872},{"ts":1585903419055,"val":637},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585909462258,"val":2204},{"ts":1585909467218,"val":2375},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585915510143,"val":1637},{"ts":1585915515159,"val":1652},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585921557800,"val":1536},{"ts":1585921562829,"val":1553},{"ts":1585921663313,"val":2673},{"ts":1585927419689,"val":696},{"ts":1585927605707,"val":868},{"ts":1585927610570,"val":924},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939703970,"val":1825},{"ts":1585939708998,"val":3971},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585963892538,"val":591},{"ts":1585963897559,"val":588},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585969941912,"val":377},{"ts":1585969946930,"val":379},{"ts":1585970172785,"val":376},{"ts":1585970197879,"val":1802},{"ts":1585975991103,"val":983},{"ts":1585975996118,"val":988},{"ts":1585976432703,"val":1087},{"ts":1585980148705,"val":348},{"ts":1585982037109,"val":391},{"ts":1585982042123,"val":390},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585988087572,"val":1563},{"ts":1585988092588,"val":2034},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585994132910,"val":2150},{"ts":1585994137923,"val":2553},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1586000184399,"val":1310},{"ts":1586000189417,"val":1311},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586006232206,"val":1442},{"ts":1586006237202,"val":1429},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017402800,"val":2539},{"ts":1586018326728,"val":2304},{"ts":1586018331753,"val":1199},{"ts":1586018447204,"val":2311},{"ts":1586022484981,"val":0},{"ts":1586024373037,"val":612},{"ts":1586024378059,"val":574},{"ts":1586024508643,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586030423081,"val":228},{"ts":1586030426972,"val":389},{"ts":1586030522456,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586036470755,"val":973},{"ts":1586036475773,"val":995},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586042516828,"val":410},{"ts":1586042521838,"val":283},{"ts":1586042526870,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586048566369,"val":326},{"ts":1586048571383,"val":1088},{"ts":1586048611524,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586054615138,"val":838},{"ts":1586054620170,"val":397},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586060663945,"val":354},{"ts":1586060668943,"val":304},{"ts":1586060673971,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066708178,"val":553},{"ts":1586066713192,"val":443},{"ts":1586066738312,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586072757965,"val":1122},{"ts":1586072762980,"val":2978},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586078804939,"val":3104},{"ts":1586078810043,"val":3049},{"ts":1586079186687,"val":1134},{"ts":1586082545523,"val":3320},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586102621756,"val":6094},{"ts":1586102998338,"val":1352},{"ts":1586103003361,"val":1350},{"ts":1586103083636,"val":2490},{"ts":1586108164066,"val":110},{"ts":1586109047387,"val":837},{"ts":1586109052404,"val":306},{"ts":1586109218231,"val":0},{"ts":1586114792624,"val":3769},{"ts":1586115093790,"val":2011},{"ts":1586115098809,"val":2006},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586121144012,"val":1291},{"ts":1586121149035,"val":1295},{"ts":1586121470673,"val":1481},{"ts":1586123846241,"val":733},{"ts":1586127191579,"val":766},{"ts":1586127196605,"val":772},{"ts":1586127201621,"val":762},{"ts":1586127794593,"val":1617},{"ts":1586133239574,"val":786},{"ts":1586133244601,"val":791},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586139287234,"val":805},{"ts":1586139292143,"val":813},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586145334099,"val":890},{"ts":1586145339142,"val":892},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586152271986,"val":459},{"ts":1586157059190,"val":2999},{"ts":1586157430842,"val":988},{"ts":1586157435871,"val":734},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586163477370,"val":1600},{"ts":1586163482397,"val":1589},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586169524306,"val":5683},{"ts":1586169529329,"val":1743},{"ts":1586169634764,"val":5949},{"ts":1586169770472,"val":1072},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586181624020,"val":1253},{"ts":1586181629064,"val":1202},{"ts":1586182377307,"val":2336},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586199761872,"val":1223},{"ts":1586199768562,"val":1223}]
                    Vielen Dank!
                    • Chris TailorC Chris Tailor
                      widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
                      (anonymous) @ widgets.min.js:4
                      (anonymous) @ conn.js:1299
                      setTimeout (async)
                      getHistory @ conn.js:1297
                      getHistory @ vis.js:2613
                      getTaskForHistoryData @ widgets.min.js:4
                      a.add @ index.js:83
                      setTimeout (async)
                      a.add @ index.js:83
                      setTimeout (async)
                      (anonymous) @ widgets.min.js:3
                      Vielen Dank!
                      ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      #899
                      @Chris-Tailor
                      Also laut log werden die Daten modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung nicht korrekt geladen, bekomst einen timeout - werden diese trotzdem angezeit?
                      Ich hab den timeout jetzt mal erhöht und noch eine kleine Optimierung eingebaut.
                      Bitte teste die aktuelle git version 0.2.79 und stell dann wieder das consolen log zur verfügung
                      Chris TailorC 1 Antwort Letzte Antwort
                        @Chris-Tailor
                        Chris Tailor
                        schrieb am zuletzt editiert von Chris Tailor
                        #900
                        @Scrounger Super, mit der neusten Version hatte ich nur beim ersten Test ein Timeout. Nach einem Refresh der Seite konnte ich dann den Fehler nicht mehr reproduzieren (PV Daten für 1 Tag, 3 tage, 7 Tage, 1 Monat und 7 Monate). Nachfolgend findest du noch die Log Daten vom ersten Versuch mit einem einmaligen Timeout. Das Timeout wird nun auf direkt in der Grafik rot dargestellt, verschwindet dann aber auch bei erfolgreicher Aktualisierung nicht mehr. Evtl. ist das noch ein kleiner Bug oder ist so gewollt.
                        Vielen Dank für die super Widgets!
                        materialdesign.js:25 Version vis-materialdesign: 0.2.79
                        conn.js:273 2020-04-07T04:46:12.512Z Connected => authenticate
                        conn.js:293 2020-04-07T04:46:12.777Z Authenticated: true
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586148374187,"end":1586234774189,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586148374187,"end":1586234774196,"timeout":5000}
                        widgets.min.js:1 version: "0.2.79"
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 286
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586148374187,"val":1327.4442156021098},{"ts":1586149597983,"val":2232},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151835018,"val":1543},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586152397495,"val":1130},{"ts":1586154246636,"val":796},{"ts":1586154352009,"val":2636},{"ts":1586154417313,"val":634},{"ts":1586154422357,"val":955},{"ts":1586154663511,"val":2283},{"ts":1586154723886,"val":583},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586156823024,"val":487},{"ts":1586156948480,"val":2873},{"ts":1586157013929,"val":1085},{"ts":1586157019290,"val":1299},{"ts":1586157059190,"val":2999},{"ts":1586157501173,"val":456},{"ts":1586157877787,"val":1058},{"ts":1586157882817,"val":1094},{"ts":1586158133821,"val":2445},{"ts":1586158173998,"val":241},{"ts":1586158299582,"val":1174},{"ts":1586160116497,"val":1260},{"ts":1586160141561,"val":699},{"ts":1586160352393,"val":2481},{"ts":1586160467840,"val":1229},{"ts":1586160472858,"val":1048},{"ts":1586160668587,"val":692},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586162915020,"val":842},{"ts":1586163025417,"val":2587},{"ts":1586163060542,"val":2114},{"ts":1586163065583,"val":1685},{"ts":1586163859139,"val":608},{"ts":1586163894422,"val":3020},{"ts":1586163924599,"val":1270},{"ts":1586163929732,"val":1557},{"ts":1586164326546,"val":343},{"ts":1586164547538,"val":2657},{"ts":1586164788528,"val":619},{"ts":1586164793558,"val":839},{"ts":1586164803603,"val":179},{"ts":1586164833735,"val":2418},{"ts":1586165652422,"val":1180},{"ts":1586165657413,"val":1042},{"ts":1586165833241,"val":2857},{"ts":1586165843277,"val":518},{"ts":1586166516032,"val":1036},{"ts":1586166521148,"val":1032},{"ts":1586167264278,"val":0},{"ts":1586167304445,"val":3352},{"ts":1586167379784,"val":1133},{"ts":1586167384773,"val":1116},{"ts":1586167580686,"val":6177},{"ts":1586168223534,"val":1011},{"ts":1586168243644,"val":1195},{"ts":1586168248660,"val":1193},{"ts":1586168660426,"val":969},{"ts":1586169006924,"val":5908},{"ts":1586169107536,"val":2328},{"ts":1586169112558,"val":4193},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586169971411,"val":1122},{"ts":1586169976352,"val":1885},{"ts":1586169981368,"val":1101},{"ts":1586170784666,"val":3550},{"ts":1586170834915,"val":2165},{"ts":1586170839942,"val":2184},{"ts":1586171608485,"val":3424},{"ts":1586171683774,"val":1561},{"ts":1586171698823,"val":1740},{"ts":1586171703843,"val":1591},{"ts":1586171874540,"val":1483},{"ts":1586171959900,"val":3358},{"ts":1586172562761,"val":1589},{"ts":1586172567779,"val":1584},{"ts":1586172587859,"val":2730},{"ts":1586172733478,"val":1364},{"ts":1586173426515,"val":1396},{"ts":1586173431530,"val":1403},{"ts":1586173582135,"val":2597},{"ts":1586174204747,"val":1274},{"ts":1586174290075,"val":1319},{"ts":1586174295089,"val":1302},{"ts":1586174315178,"val":2468},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586176737808,"val":1169},{"ts":1586176813130,"val":2340},{"ts":1586176883374,"val":1182},{"ts":1586176888399,"val":1257},{"ts":1586177059091,"val":1173},{"ts":1586177174546,"val":2474},{"ts":1586177747129,"val":1785},{"ts":1586177752151,"val":1205},{"ts":1586178083588,"val":2360},{"ts":1586178309483,"val":1067},{"ts":1586178610816,"val":1102},{"ts":1586178615809,"val":1121},{"ts":1586179112913,"val":2420},{"ts":1586179429232,"val":1008},{"ts":1586179474399,"val":1104},{"ts":1586179479418,"val":1113},{"ts":1586179680252,"val":1066},{"ts":1586180298136,"val":2347},{"ts":1586180338299,"val":1240},{"ts":1586180343322,"val":1536},{"ts":1586180493947,"val":2418},{"ts":1586181151867,"val":1137},{"ts":1586181202061,"val":1166},{"ts":1586181207076,"val":2261},{"ts":1586181488430,"val":1103},{"ts":1586181850020,"val":2312},{"ts":1586182065925,"val":1178},{"ts":1586182070988,"val":1166},{"ts":1586182377307,"val":2336},{"ts":1586182427580,"val":1108},{"ts":1586182929855,"val":2113},{"ts":1586182934864,"val":1112},{"ts":1586182969994,"val":2313},{"ts":1586183743608,"val":1052},{"ts":1586183793806,"val":1070},{"ts":1586183798847,"val":1084},{"ts":1586183879231,"val":2297},{"ts":1586183919347,"val":589},{"ts":1586185769496,"val":858},{"ts":1586185809646,"val":1722},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586188104226,"val":525},{"ts":1586188114254,"val":533},{"ts":1586188119270,"val":524},{"ts":1586188264864,"val":1683},{"ts":1586188591383,"val":482},{"ts":1586188978417,"val":494},{"ts":1586188983441,"val":1004},{"ts":1586189360267,"val":464},{"ts":1586189515728,"val":1656},{"ts":1586189761817,"val":960},{"ts":1586191579896,"val":1463},{"ts":1586191670467,"val":649},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194048203,"val":861},{"ts":1586194123540,"val":2252},{"ts":1586194163696,"val":1231},{"ts":1586194168712,"val":698},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586195027708,"val":2012},{"ts":1586195032801,"val":1232},{"ts":1586195113268,"val":2421},{"ts":1586195595240,"val":341},{"ts":1586195891661,"val":1067},{"ts":1586195896677,"val":1048},{"ts":1586196052372,"val":1061},{"ts":1586196107619,"val":1008},{"ts":1586196152901,"val":1046},{"ts":1586198002185,"val":1024},{"ts":1586198227952,"val":1009},{"ts":1586198423669,"val":1050},{"ts":1586198483865,"val":1035},{"ts":1586198488881,"val":1043},{"ts":1586198644430,"val":1533},{"ts":1586198860059,"val":986},{"ts":1586199349454,"val":1184},{"ts":1586199354483,"val":1173},{"ts":1586199445083,"val":1156},{"ts":1586199475251,"val":1385},{"ts":1586200209314,"val":1214},{"ts":1586200214344,"val":1201},{"ts":1586200962577,"val":891},{"ts":1586200977621,"val":1396},{"ts":1586201078091,"val":1363},{"ts":1586201083300,"val":1372},{"ts":1586201228710,"val":1401},{"ts":1586201851444,"val":1206},{"ts":1586201941764,"val":1224},{"ts":1586201946777,"val":1216},{"ts":1586202107409,"val":1711},{"ts":1586202373415,"val":1210},{"ts":1586202805391,"val":1235},{"ts":1586202810411,"val":1239},{"ts":1586202815428,"val":1249},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586205393574,"val":750},{"ts":1586205398606,"val":749},{"ts":1586206096897,"val":613},{"ts":1586206257486,"val":645},{"ts":1586206262504,"val":652},{"ts":1586206302655,"val":612},{"ts":1586206403066,"val":644},{"ts":1586208252581,"val":690},{"ts":1586208342895,"val":0},{"ts":1586208362985,"val":779},{"ts":1586208378051,"val":754},{"ts":1586210196393,"val":560},{"ts":1586210321912,"val":545},{"ts":1586210403395,"val":564},{"ts":1586210577994,"val":554},{"ts":1586210583013,"val":548},{"ts":1586210613137,"val":544},{"ts":1586210753758,"val":678},{"ts":1586211341349,"val":547},{"ts":1586213190303,"val":298},{"ts":1586213260773,"val":309},{"ts":1586213406398,"val":287},{"ts":1586213436537,"val":301},{"ts":1586215291547,"val":882},{"ts":1586215296559,"val":886},{"ts":1586215605005,"val":747},{"ts":1586215765662,"val":795},{"ts":1586215770697,"val":800},{"ts":1586215896315,"val":784},{"ts":1586216061985,"val":811},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218188358,"val":925},{"ts":1586218348946,"val":1032},{"ts":1586218353962,"val":1029},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586219217540,"val":866},{"ts":1586219227581,"val":869},{"ts":1586219232600,"val":864},{"ts":1586219272768,"val":896},{"ts":1586219438425,"val":877},{"ts":1586221288103,"val":876},{"ts":1586221303149,"val":872},{"ts":1586221313182,"val":885},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223262888,"val":268},{"ts":1586223539019,"val":1082},{"ts":1586223544144,"val":463},{"ts":1586223800107,"val":333},{"ts":1586224402596,"val":363},{"ts":1586224407611,"val":361},{"ts":1586224613434,"val":366},{"ts":1586225020230,"val":262},{"ts":1586225266226,"val":263},{"ts":1586225271240,"val":270},{"ts":1586225642729,"val":300},{"ts":1586225768246,"val":259},{"ts":1586225923884,"val":279},{"ts":1586227741595,"val":418},{"ts":1586227862087,"val":336},{"ts":1586227867114,"val":335},{"ts":1586228173435,"val":324},{"ts":1586228509926,"val":444},{"ts":1586228725822,"val":381},{"ts":1586228730838,"val":350},{"ts":1586229343264,"val":327},{"ts":1586229544046,"val":354},{"ts":1586229589180,"val":335},{"ts":1586229594214,"val":330},{"ts":1586229614279,"val":329},{"ts":1586229634350,"val":484},{"ts":1586230452867,"val":351},{"ts":1586230457902,"val":352},{"ts":1586230593504,"val":357},{"ts":1586231045444,"val":274},{"ts":1586231170977,"val":276},{"ts":1586233021191,"val":1662},{"ts":1586233026198,"val":1666},{"ts":1586233031215,"val":1656},{"ts":1586233041249,"val":1660},{"ts":1586233046265,"val":1663},{"ts":1586233051280,"val":1661},{"ts":1586234311418,"val":1661},{"ts":1586234317314,"val":1661},{"ts":1586234774189,"val":1661}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586148374187,"val":22.852575024652907},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151850123,"val":161},{"ts":1586151870190,"val":154},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154326917,"val":352},{"ts":1586154382143,"val":327},{"ts":1586154417313,"val":340},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157009004,"val":489},{"ts":1586157013929,"val":475},{"ts":1586157019289,"val":455},{"ts":1586157164657,"val":422},{"ts":1586157701981,"val":554},{"ts":1586157877787,"val":528},{"ts":1586157882817,"val":484},{"ts":1586158028351,"val":550},{"ts":1586158214217,"val":431},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160467840,"val":1122},{"ts":1586160472858,"val":1131},{"ts":1586160512990,"val":1121},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163030429,"val":2099},{"ts":1586163060542,"val":2116},{"ts":1586163070600,"val":2126},{"ts":1586163201203,"val":2013},{"ts":1586163919495,"val":2785},{"ts":1586163924598,"val":2783},{"ts":1586163934646,"val":2791},{"ts":1586164100481,"val":2746},{"ts":1586164778599,"val":3246},{"ts":1586164788528,"val":3222},{"ts":1586164793558,"val":3238},{"ts":1586164803603,"val":3200},{"ts":1586165652422,"val":3718},{"ts":1586165657413,"val":3713},{"ts":1586165873391,"val":3676},{"ts":1586166511020,"val":4153},{"ts":1586166516032,"val":4147},{"ts":1586166521148,"val":4134},{"ts":1586167269338,"val":0},{"ts":1586167374687,"val":4561},{"ts":1586167379784,"val":4552},{"ts":1586167384773,"val":4556},{"ts":1586168243644,"val":5082},{"ts":1586168248660,"val":5091},{"ts":1586168308842,"val":5018},{"ts":1586169047220,"val":5333},{"ts":1586169102514,"val":5326},{"ts":1586169112557,"val":5320},{"ts":1586169760442,"val":5592},{"ts":1586169971410,"val":5562},{"ts":1586169976352,"val":5554},{"ts":1586170036595,"val":5533},{"ts":1586170834915,"val":5909},{"ts":1586170839942,"val":5931},{"ts":1586171131274,"val":5882},{"ts":1586171653656,"val":6133},{"ts":1586171698823,"val":6109},{"ts":1586171703843,"val":6128},{"ts":1586171754011,"val":6076},{"ts":1586172422129,"val":6381},{"ts":1586172562761,"val":6378},{"ts":1586172567778,"val":6389},{"ts":1586172633100,"val":6316},{"ts":1586173150581,"val":6570},{"ts":1586173426515,"val":6481},{"ts":1586173431530,"val":6462},{"ts":1586173486746,"val":6438},{"ts":1586174290074,"val":6756},{"ts":1586174295089,"val":6724},{"ts":1586174470952,"val":6771},{"ts":1586174762088,"val":6657},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586176772949,"val":6756},{"ts":1586176878355,"val":6839},{"ts":1586176898433,"val":6833},{"ts":1586177013882,"val":6751},{"ts":1586177631651,"val":6903},{"ts":1586177747128,"val":6809},{"ts":1586177762220,"val":6808},{"ts":1586178294421,"val":6687},{"ts":1586178575601,"val":6886},{"ts":1586178610816,"val":6839},{"ts":1586178615804,"val":6844},{"ts":1586179052674,"val":6903},{"ts":1586179474399,"val":6750},{"ts":1586179479418,"val":6774},{"ts":1586179624982,"val":6728},{"ts":1586179926359,"val":6915},{"ts":1586180338299,"val":6821},{"ts":1586180343322,"val":6844},{"ts":1586180749981,"val":6879},{"ts":1586181151867,"val":6763},{"ts":1586181202061,"val":6774},{"ts":1586181207075,"val":6780},{"ts":1586181227186,"val":6808},{"ts":1586181714505,"val":6515},{"ts":1586182065924,"val":6584},{"ts":1586182070988,"val":6612},{"ts":1586182849534,"val":6377},{"ts":1586182929854,"val":6389},{"ts":1586182934864,"val":6401},{"ts":1586182949913,"val":6416},{"ts":1586183773727,"val":6220},{"ts":1586183793806,"val":6232},{"ts":1586183798846,"val":6231},{"ts":1586183844189,"val":6251},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188104226,"val":4842},{"ts":1586188114254,"val":4850},{"ts":1586188119270,"val":4839},{"ts":1586188139365,"val":4870},{"ts":1586188978417,"val":4461},{"ts":1586188983441,"val":4457},{"ts":1586188988479,"val":4461},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586194158774,"val":1032},{"ts":1586194163695,"val":1039},{"ts":1586194168712,"val":1038},{"ts":1586195027708,"val":438},{"ts":1586195032801,"val":442},{"ts":1586195093282,"val":450},{"ts":1586195891661,"val":79},{"ts":1586195896677,"val":92},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234774196,"val":0}]
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 286
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585975595024,"end":1586234795032,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585975595024,"end":1586234795039,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585975595024,"val":968.2274900398406},{"ts":1585975599473,"val":970},{"ts":1585976432703,"val":1087},{"ts":1585977953951,"val":939},{"ts":1585978185139,"val":945},{"ts":1585978189981,"val":953},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585980771608,"val":435},{"ts":1585980781658,"val":445},{"ts":1585982343403,"val":339},{"ts":1585983312823,"val":1590},{"ts":1585983368074,"val":497},{"ts":1585983373095,"val":492},{"ts":1585983458448,"val":348},{"ts":1585984217203,"val":2734},{"ts":1585985959326,"val":1028},{"ts":1585985964348,"val":2091},{"ts":1585986511507,"val":935},{"ts":1585988504257,"val":2740},{"ts":1585988554474,"val":1588},{"ts":1585988559497,"val":1586},{"ts":1585990352016,"val":1308},{"ts":1585990914291,"val":3516},{"ts":1585991145112,"val":3363},{"ts":1585991150131,"val":2075},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585993736307,"val":2155},{"ts":1585993741353,"val":2375},{"ts":1585994248405,"val":3707},{"ts":1585996031210,"val":1244},{"ts":1585996327815,"val":1909},{"ts":1585996332831,"val":1290},{"ts":1585996704240,"val":1231},{"ts":1585998266153,"val":2610},{"ts":1585998919075,"val":1299},{"ts":1585998924097,"val":1287},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586001510457,"val":1332},{"ts":1586001515478,"val":1460},{"ts":1586001711430,"val":1317},{"ts":1586003238503,"val":6525},{"ts":1586004102681,"val":6288},{"ts":1586004107707,"val":4715},{"ts":1586004147878,"val":5465},{"ts":1586006664079,"val":1370},{"ts":1586006694221,"val":1402},{"ts":1586006699275,"val":1407},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010262197,"val":1360},{"ts":1586010523424,"val":2534},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586014384795,"val":2524},{"ts":1586014470188,"val":1346},{"ts":1586014475204,"val":1936},{"ts":1586015881337,"val":1170},{"ts":1586017056341,"val":2532},{"ts":1586017066383,"val":1335},{"ts":1586017071424,"val":1341},{"ts":1586017402800,"val":2539},{"ts":1586019567023,"val":634},{"ts":1586019657432,"val":657},{"ts":1586019662468,"val":656},{"ts":1586022032554,"val":1964},{"ts":1586022213521,"val":170},{"ts":1586022248752,"val":319},{"ts":1586022253765,"val":673},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586024840244,"val":2290},{"ts":1586024845260,"val":618},{"ts":1586024850281,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586027432732,"val":335},{"ts":1586027437837,"val":366},{"ts":1586027854628,"val":2254},{"ts":1586027874750,"val":0},{"ts":1586030025219,"val":584},{"ts":1586030030269,"val":2102},{"ts":1586030070486,"val":0},{"ts":1586032391334,"val":2744},{"ts":1586032617389,"val":1120},{"ts":1586032622407,"val":1070},{"ts":1586033536704,"val":2855},{"ts":1586034682203,"val":291},{"ts":1586035209862,"val":896},{"ts":1586035214877,"val":889},{"ts":1586037269627,"val":2751},{"ts":1586037701658,"val":245},{"ts":1586037802128,"val":833},{"ts":1586037807140,"val":1061},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586040393597,"val":501},{"ts":1586040398609,"val":457},{"ts":1586040493959,"val":0},{"ts":1586040704830,"val":2247},{"ts":1586042983665,"val":499},{"ts":1586042988681,"val":112},{"ts":1586043008746,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586045574048,"val":561},{"ts":1586045579062,"val":451},{"ts":1586045604206,"val":0},{"ts":1586047512093,"val":2054},{"ts":1586048169783,"val":0},{"ts":1586048174807,"val":233},{"ts":1586048204933,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050759988,"val":2457},{"ts":1586050765005,"val":1012},{"ts":1586050845298,"val":2651},{"ts":1586053129518,"val":209},{"ts":1586053350266,"val":923},{"ts":1586053355289,"val":901},{"ts":1586054695420,"val":288},{"ts":1586055488482,"val":2686},{"ts":1586055945279,"val":887},{"ts":1586055950295,"val":538},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586058535519,"val":304},{"ts":1586058540535,"val":325},{"ts":1586058590704,"val":0},{"ts":1586059012299,"val":2348},{"ts":1586061130886,"val":123},{"ts":1586061135908,"val":590},{"ts":1586061201161,"val":0},{"ts":1586061401936,"val":2078},{"ts":1586063721185,"val":526},{"ts":1586063726206,"val":1251},{"ts":1586063801693,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586066311611,"val":324},{"ts":1586066316626,"val":390},{"ts":1586066366803,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068902230,"val":405},{"ts":1586068907250,"val":343},{"ts":1586068912275,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071497690,"val":950},{"ts":1586071502717,"val":895},{"ts":1586071703481,"val":226},{"ts":1586072762980,"val":2978},{"ts":1586074088589,"val":1158},{"ts":1586074093629,"val":2544},{"ts":1586074133748,"val":617},{"ts":1586076203797,"
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 203
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585975595024,"val":20.79800990397711},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978139770,"val":84},{"ts":1585978185139,"val":79},{"ts":1585978194995,"val":83},{"ts":1585978230205,"val":77},{"ts":1585980721437,"val":311},{"ts":1585980771607,"val":306},{"ts":1585980781658,"val":304},{"ts":1585981163296,"val":294},{"ts":1585983312823,"val":518},{"ts":1585983368074,"val":444},{"ts":1585983373093,"val":417},{"ts":1585984789725,"val":22},{"ts":1585985638026,"val":646},{"ts":1585985959326,"val":581},{"ts":1585985964348,"val":598},{"ts":1585987214177,"val":0},{"ts":1585988554474,"val":1570},{"ts":1585988559497,"val":1564},{"ts":1585991130118,"val":2729},{"ts":1585991145112,"val":2707},{"ts":1585991150131,"val":2729},{"ts":1585991175308,"val":2691},{"ts":1585993721236,"val":4193},{"ts":1585993736307,"val":4160},{"ts":1585993741353,"val":4180},{"ts":1585993806645,"val":3923},{"ts":1585996277559,"val":5402},{"ts":1585996327815,"val":5381},{"ts":1585996332831,"val":5368},{"ts":1585996347883,"val":5107},{"ts":1585998914062,"val":6306},{"ts":1585998924097,"val":6300},{"ts":1585999160025,"val":6279},{"ts":1586001495373,"val":6897},{"ts":1586001510457,"val":6891},{"ts":1586001515478,"val":6889},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004102679,"val":6908},{"ts":1586004107706,"val":6909},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586006694220,"val":7057},{"ts":1586006699273,"val":7068},{"ts":1586007086047,"val":7110},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586014470188,"val":5411},{"ts":1586014475203,"val":5405},{"ts":1586014490251,"val":5408},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586019652398,"val":2444},{"ts":1586019657432,"val":2452},{"ts":1586019662468,"val":2456},{"ts":1586022248752,"val":462},{"ts":1586022253765,"val":443},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063706151,"val":46},{"ts":1586063721185,"val":43},{"ts":1586063726205,"val":41},{"ts":1586066211238,"val":210},{"ts":1586066311611,"val":200},{"ts":1586066316626,"val":206},{"ts":1586068209595,"val":155},{"ts":1586068801844,"val":414},{"ts":1586068902229,"val":404},{"ts":1586068907250,"val":405},{"ts":1586068917655,"val":373},{"ts":1586071221625,"val":554},{"ts":1586071497689,"val":551},{"ts":1586071502717,"val":500},{"ts":1586071834103,"val":217},{"ts":1586074078555,"val":1069},{"ts":1586074088589,"val":1066},{"ts":1586074093629,"val":1063},{"ts":1586074098636,"val":1059},{"ts":1586076384660,"val":2046},{"ts":1586076681006,"val":1928},{"ts":1586076686023,"val":1924},{"ts":1586077238247,"val":0},{"ts":1586079251896,"val":3776},{"ts":1586079271955,"val":3758},{"ts":1586079281993,"val":3794},{"ts":1586079287009,"val":3782},{"ts":1586081862870,"val":5104},{"ts":1586081867874,"val":5094},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586102601680,"val":4867},{"ts":1586102606842,"val":4856},{"ts":1586105191869,"val":3375},{"ts":1586105196900,"val":3369},{"ts":1586105201917,"val":3375},{"ts":1586107782298,"val":1524},{"ts":1586107787323,"val":1518},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586151850123,"val":161},{"ts":1586151865175,"val":162},{"ts":1586151870190,"val":154},{"ts":1586154442438,"val":353},{"ts":1586154447450,"val":337},{"ts":1586154628301,"val":333},{"ts":1586157009004,"val":489},{"ts":1586157034004,"val":463},{"ts":1586157039305,"val":492},{"ts":1586157164657,"val":422},{"ts":1586157701981,"val":554},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163201203,"val":2013},{"ts":1586164808936,"val":3247},{"ts":1586164813646,"val":3216},{"ts":1586167269338,"val":0},{"ts":1586167394824,"val":4574},{"ts":1586167404870,"val":4573},{"ts":1586169760442,"val":5592},{"ts":1586169991401,"val":5573},{"ts":1586169996425,"val":5565},{"ts":1586170036595,"val":5533},{"ts":1586172582835,"val":6410},{"ts":1586172587859,"val":6401},{"ts":1586172633100,"val":6316},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586177013882,"val":6751},{"ts":1586177631651,"val":6903},{"ts":1586177767206,"val":6821},{"ts":1586177772229,"val":6808},{"ts":1586178294421,"val":6687},{"ts":1586179926359,"val":6915},{"ts":1586180358377,"val":6797},{"ts":1586180363395,"val":6827},{"ts":1586180749981,"val":6879},{"ts":1586182944896,"val":6369},{"ts":1586182954923,"val":6411},{"ts":1586182959958,"val":6379},{"ts":1586182964977,"val":6415},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586188119270,"val":4839},{"ts":1586188134349,"val":4857},{"ts":1586188139365,"val":4870},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586195891661,"val":79},{"ts":1586195906715,"val":79},{"ts":1586195916741,"val":82},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234795039,"val":0}]
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 203
                        widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630002994,"end":1586234802995,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630002994,"end":1586234803002,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630004246,"end":1586234804246,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630004246,"end":1586234804256,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 253
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585630002994,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585858669660,"val":654},{"ts":1585858746453,"val":4252},{"ts":1585859826500,"val":3279},{"ts":1585859827521,"val":2982},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585865870728,"val":1115},{"ts":1585865875737,"val":1025},{"ts":1585871231935,"val":299},{"ts":1585871728785,"val":2806},{"ts":1585871919569,"val":1735},{"ts":1585871924581,"val":1490},{"ts":1585872195774,"val":2702},{"ts":1585875468113,"val":0},{"ts":1585877970344,"val":343},{"ts":1585877975360,"val":115},{"ts":1585877985395,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585884018872,"val":496},{"ts":1585884023883,"val":1333},{"ts":1585884064025,"val":0},{"ts":1585889665174,"val":2601},{"ts":1585890066872,"val":562},{"ts":1585890071882,"val":995},{"ts":1585890378178,"val":253},{"ts":1585893505542,"val":6581},{"ts":1585896111023,"val":1502},{"ts":1585896115932,"val":1472},{"ts":1585896286641,"val":472},{"ts":1585901110985,"val":3204},{"ts":1585902160322,"val":1446},{"ts":1585902165343,"val":1418},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585908206385,"val":2846},{"ts":1585908211400,"val":3800},{"ts":1585908603295,"val":5922},{"ts":1585910547158,"val":1413},{"ts":1585914254312,"val":1473},{"ts":1585914259334,"val":1683},{"ts":1585914786772,"val":1440},{"ts":1585917710085,"val":4053},{"ts":1585920302216,"val":1534},{"ts":1585920307263,"val":1520},{"ts":1585920714057,"val":3022},{"ts":1585922220919,"val":979},{"ts":1585926354537,"val":1192},{"ts":1585926359563,"val":1179},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932402808,"val":1878},{"ts":1585932407821,"val":1907},{"ts":1585933095645,"val":5320},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585950543925,"val":2052},{"ts":1585950548938,"val":2069},{"ts":1585950694493,"val":3047},{"ts":1585956084287,"val":918},{"ts":1585956591488,"val":982},{"ts":1585956596383,"val":976},{"ts":1585958744944,"val":1015},{"ts":1585961362271,"val":370},{"ts":1585962642564,"val":476},{"ts":1585962647602,"val":466},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585968686863,"val":531},{"ts":1585968696903,"val":535},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585974731052,"val":979},{"ts":1585974741088,"val":978},{"ts":1585975162738,"val":1677},{"ts":1585980148705,"val":348},{"ts":1585980786682,"val":444},{"ts":1585980791713,"val":432},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585986832829,"val":1175},{"ts":1585986837852,"val":1155},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992882588,"val":2074},{"ts":1585992887613,"val":1648},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1585998929111,"val":1284},{"ts":1585998934133,"val":1281},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586004976531,"val":2043},{"ts":1586004981635,"val":1549},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017056341,"val":2532},{"ts":1586017071424,"val":1341},{"ts":1586017076460,"val":1327},{"ts":1586017402800,"val":2539},{"ts":1586022484981,"val":0},{"ts":1586023122859,"val":350},{"ts":1586023127882,"val":369},{"ts":1586023253307,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586029170933,"val":405},{"ts":1586029175946,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586035214877,"val":889},{"ts":1586035219972,"val":1109},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586041262025,"val":51},{"ts":1586041267241,"val":907},{"ts":1586041287170,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586047311222,"val":0},{"ts":1586047316235,"val":177},{"ts":1586047346350,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586053360302,"val":842},{"ts":1586053365316,"val":736},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586059408863,"val":600},{"ts":1586059413913,"val":470},{"ts":1586059428959,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065458076,"val":399},{"ts":1586065463096,"val":749},{"ts":1586065583541,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071502717,"val":895},{"ts":1586071507737,"val":896},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586077554539,"val":1161},{"ts":1586077559561,"val":1128},{"ts":1586077780632,"val":1090},{"ts":1586078352967,"val":3369},{"ts":1586083599519,"val":1329},{"ts":1586083604540,"val":1318},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090630195,"val":778},{"ts":1586092868521,"val":2080},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095857154,"val":2851},{"ts":1586098177848,"val":1267},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586107646783,"val":342},{"ts":1586107792345,"val":404},{"ts":1586107797363,"val":352},{"ts":1586109218231,"val":0},{"ts":1586113513452,"val":3736},{"ts":1586113839491,"val":3588},{"ts":1586113844698,"val":3591},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586119883341,"val":1066},{"ts":1586119893418,"val":1083},{"ts":1586120471125,"val":1484},{"ts":1586123846241,"val":733},{"ts":1586125935887,"val":764},{"ts":1586125940895,"val":758},{"ts":1586126016471,"val":743},{"ts":1586127794593,"val":1617},{"ts":1586131983847,"val":777},{"ts":1586131988867,"val":779},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586138031625,"val":880},{"ts":1586138036640,"val":877},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586168273731,"val":4717},{"ts":1586168278743,"val":1198},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586174320192,"val":1322},{"ts":1586174325211,"val":1308},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586180368441,"val":1242},{"ts":1586180373438,"val":1201},{"ts":1586180493947,"val":2418},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586198513968,"val":1081},{"ts":1586198519017,"val":1075},{"ts":1586200962577,"val":891},{"ts":1586202107409,"val":1711},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586208362985,"val":779},{"ts":1586210608114,"val":553},{"ts":1586210613137,"val":544},{"ts":1586213406398,"val":287},{"ts":1586215296559,"val":886},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223539019,"val":1082},{"ts":1586225768246,"val":259},{"ts":1586228750899,"val":347},{"ts":1586228755914,"val":344},{"ts":1586231045444,"val":274},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234802995,"val":1661}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 141
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585630002994,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585895950314,"val":526},{"ts":1585896111023,"val":466},{"ts":1585896115932,"val":484},{"ts":1585897185165,"val":0},{"ts":1585902160322,"val":1491},{"ts":1585902165342,"val":1495},{"ts":1585908206385,"val":4677},{"ts":1585908211400,"val":4663},{"ts":1585908241498,"val":4550},{"ts":1585914254312,"val":6764},{"ts":1585914259334,"val":6782},{"ts":1585917263083,"val":6529},{"ts":1585920005966,"val":7206},{"ts":1585920302216,"val":7072},{"ts":1585920307263,"val":7068},{"ts":1585920392679,"val":7177},{"ts":1585920578493,"val":4454},{"ts":1585926354537,"val":6259},{"ts":1585926359563,"val":6256},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585932402807,"val":2886},{"ts":1585932407820,"val":2889},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585980721437,"val":311},{"ts":1585980786682,"val":306},{"ts":1585980801746,"val":311},{"ts":1585984789725,"val":22},{"ts":1585986802724,"val":806},{"ts":1585986832829,"val":785},{"ts":1585986837852,"val":774},{"ts":1585987214177,"val":0},{"ts":1585992877572,"val":3776},{"ts":1585992882588,"val":3564},{"ts":1585992887613,"val":3585},{"ts":1585993178846,"val":3480},{"ts":1585998914062,"val":6306},{"ts":1585998929111,"val":6281},{"ts":1585998934133,"val":6285},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004976531,"val":6856},{"ts":1586004981635,"val":6874},{"ts":1586005780202,"val":7162},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586023012362,"val":23},{"ts":1586023122859,"val":34},{"ts":1586023127882,"val":36},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586065432983,"val":165},{"ts":1586065458076,"val":158},{"ts":1586065463096,"val":157},{"ts":1586065593575,"val":155},{"ts":1586071221625,"val":554},{"ts":1586071502717,"val":500},{"ts":1586071507737,"val":503},{"ts":1586077238247,"val":0},{"ts":1586077514400,"val":2727},{"ts":1586077554539,"val":2702},{"ts":1586077559561,"val":2717},{"ts":1586077700285,"val":2672},{"ts":1586083448954,"val":5755},{"ts":1586083594501,"val":5742},{"ts":1586083609556,"val":5755},{"ts":1586083664769,"val":5751},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586107792345,"val":1513},{"ts":1586107797363,"val":1507},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586167269338,"val":0},{"ts":1586168263702,"val":5093},{"ts":1586168273730,"val":5089},{"ts":1586168278743,"val":5098},{"ts":1586168308842,"val":5018},{"ts":1586174290074,"val":6756},{"ts":1586174320192,"val":6709},{"ts":1586174325211,"val":6711},{"ts":1586174762088,"val":6657},{"ts":1586179926359,"val":6915},{"ts":1586180368441,"val":6809},{"ts":1586180373438,"val":6774},{"ts":1586180749981,"val":6879},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234803002,"val":0}]
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 253
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 141
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585630004246,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585858669660,"val":654},{"ts":1585858746453,"val":4252},{"ts":1585859827521,"val":2982},{"ts":1585859828540,"val":3236},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585865875737,"val":1025},{"ts":1585865880749,"val":1049},{"ts":1585871231935,"val":299},{"ts":1585871728785,"val":2806},{"ts":1585871919569,"val":1735},{"ts":1585871924581,"val":1490},{"ts":1585872195774,"val":2702},{"ts":1585875468113,"val":0},{"ts":1585877970344,"val":343},{"ts":1585877975360,"val":115},{"ts":1585877985395,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585884018872,"val":496},{"ts":1585884023883,"val":1333},{"ts":1585884064025,"val":0},{"ts":1585889665174,"val":2601},{"ts":1585890066872,"val":562},{"ts":1585890071882,"val":995},{"ts":1585890378178,"val":253},{"ts":1585893505542,"val":6581},{"ts":1585896115932,"val":1472},{"ts":1585896120981,"val":1975},{"ts":1585896286641,"val":472},{"ts":1585901110985,"val":3204},{"ts":1585902160322,"val":1446},{"ts":1585902165343,"val":1418},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585908211400,"val":3800},{"ts":1585908216420,"val":4140},{"ts":1585908603295,"val":5922},{"ts":1585910547158,"val":1413},{"ts":1585914259334,"val":1683},{"ts":1585914264352,"val":1468},{"ts":1585914786772,"val":1440},{"ts":1585917710085,"val":4053},{"ts":1585920307263,"val":1520},{"ts":1585920312285,"val":1532},{"ts":1585920714057,"val":3022},{"ts":1585922220919,"val":979},{"ts":1585926354537,"val":1192},{"ts":1585926359563,"val":1179},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932402808,"val":1878},{"ts":1585932407821,"val":1907},{"ts":1585933095645,"val":5320},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585950543925,"val":2052},{"ts":1585950548938,"val":2069},{"ts":1585950694493,"val":3047},{"ts":1585956084287,"val":918},{"ts":1585956591488,"val":982},{"ts":1585956596383,"val":976},{"ts":1585958744944,"val":1015},{"ts":1585961362271,"val":370},{"ts":1585962642564,"val":476},{"ts":1585962647602,"val":466},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585968686863,"val":531},{"ts":1585968696903,"val":535},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585974731052,"val":979},{"ts":1585974741088,"val":978},{"ts":1585975162738,"val":1677},{"ts":1585980148705,"val":348},{"ts":1585980786682,"val":444},{"ts":1585980791713,"val":432},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585986832829,"val":1175},{"ts":1585986837852,"val":1155},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992882588,"val":2074},{"ts":1585992887613,"val":1648},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1585998929111,"val":1284},{"ts":1585998934133,"val":1281},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586004976531,"val":2043},{"ts":1586004981635,"val":1549},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017056341,"val":2532},{"ts":1586017071424,"val":1341},{"ts":1586017076460,"val":1327},{"ts":1586017402800,"val":2539},{"ts":1586022484981,"val":0},{"ts":1586023122859,"val":350},{"ts":1586023127882,"val":369},{"ts":1586023253307,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586029170933,"val":405},{"ts":1586029175946,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586035219972,"val":1109},{"ts":1586035224988,"val":1083},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586041267241,"val":907},{"ts":1586041272068,"val":409},{"ts":1586041287170,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586047316235,"val":177},{"ts":1586047321262,"val":908},{"ts":1586047346350,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586053360302,"val":842},{"ts":1586053365316,"val":736},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586059408863,"val":600},{"ts":1586059413913,"val":470},{"ts":1586059428959,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065458076,"val":399},{"ts":1586065463096,"val":749},{"ts":1586065583541,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071507737,"val":896},{"ts":1586071512748,"val":904},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586077554539,"val":1161},{"ts":1586077559561,"val":1128},{"ts":1586077780632,"val":1090},{"ts":1586078352967,"val":3369},{"ts":1586083599519,"val":1329},{"ts":1586083604540,"val":1318},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090630195,"val":778},{"ts":1586092868521,"val":2080},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095857154,"val":2851},{"ts":1586098177848,"val":1267},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586107646783,"val":342},{"ts":1586107792345,"val":404},{"ts":1586107797363,"val":352},{"ts":1586109218231,"val":0},{"ts":1586113513452,"val":3736},{"ts":1586113839491,"val":3588},{"ts":1586113844698,"val":3591},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586119883341,"val":1066},{"ts":1586119893418,"val":1083},{"ts":1586120471125,"val":1484},{"ts":1586123846241,"val":733},{"ts":1586125935887,"val":764},{"ts":1586125940895,"val":758},{"ts":1586126016471,"val":743},{"ts":1586127794593,"val":1617},{"ts":1586131983847,"val":777},{"ts":1586131988867,"val":779},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586138031625,"val":880},{"ts":1586138036640,"val":877},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586168273731,"val":4717},{"ts":1586168278743,"val":1198},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586174320192,"val":1322},{"ts":1586174325211,"val":1308},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586180368441,"val":1242},{"ts":1586180373438,"val":1201},{"ts":1586180493947,"val":2418},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586198513968,"val":1081},{"ts":1586198519017,"val":1075},{"ts":1586200962577,"val":891},{"ts":1586202107409,"val":1711},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586208362985,"val":779},{"ts":1586210608114,"val":553},{"ts":1586210613137,"val":544},{"ts":1586213406398,"val":287},{"ts":1586215296559,"val":886},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223539019,"val":1082},{"ts":1586225768246,"val":259},{"ts":1586228755914,"val":344},{"ts":1586228760946,"val":348},{"ts":1586231045444,"val":274},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234804246,"val":1661}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                        setTimeout (async)
                        o @ widgets.min.js:3
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 142
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585630004246,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585895950314,"val":526},{"ts":1585896115932,"val":484},{"ts":1585896120980,"val":478},{"ts":1585897185165,"val":0},{"ts":1585902160322,"val":1491},{"ts":1585902165342,"val":1495},{"ts":1585908206385,"val":4677},{"ts":1585908211400,"val":4663},{"ts":1585908216419,"val":4683},{"ts":1585908241498,"val":4550},{"ts":1585914259334,"val":6782},{"ts":1585914264351,"val":6763},{"ts":1585917263083,"val":6529},{"ts":1585920005966,"val":7206},{"ts":1585920307263,"val":7068},{"ts":1585920312285,"val":7102},{"ts":1585920392679,"val":7177},{"ts":1585920578493,"val":4454},{"ts":1585926354537,"val":6259},{"ts":1585926359563,"val":6256},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585932402807,"val":2886},{"ts":1585932407820,"val":2889},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585980721437,"val":311},{"ts":1585980786682,"val":306},{"ts":1585980801746,"val":311},{"ts":1585984789725,"val":22},{"ts":1585986802724,"val":806},{"ts":1585986832829,"val":785},{"ts":1585986837852,"val":774},{"ts":1585987214177,"val":0},{"ts":1585992877572,"val":3776},{"ts":1585992882588,"val":3564},{"ts":1585992887613,"val":3585},{"ts":1585993178846,"val":3480},{"ts":1585998914062,"val":6306},{"ts":1585998929111,"val":6281},{"ts":1585998934133,"val":6285},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004976531,"val":6856},{"ts":1586004981635,"val":6874},{"ts":1586005780202,"val":7162},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586023012362,"val":23},{"ts":1586023122859,"val":34},{"ts":1586023127882,"val":36},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586065432983,"val":165},{"ts":1586065458076,"val":158},{"ts":1586065463096,"val":157},{"ts":1586065593575,"val":155},{"ts":1586071221625,"val":554},{"ts":1586071507737,"val":503},{"ts":1586071512747,"val":513},{"ts":1586077238247,"val":0},{"ts":1586077514400,"val":2727},{"ts":1586077554539,"val":2702},{"ts":1586077559561,"val":2717},{"ts":1586077700285,"val":2672},{"ts":1586083448954,"val":5755},{"ts":1586083594501,"val":5742},{"ts":1586083609556,"val":5755},{"ts":1586083664769,"val":5751},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586107792345,"val":1513},{"ts":1586107797363,"val":1507},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586167269338,"val":0},{"ts":1586168263702,"val":5093},{"ts":1586168273730,"val":5089},{"ts":1586168278743,"val":5098},{"ts":1586168308842,"val":5018},{"ts":1586174290074,"val":6756},{"ts":1586174320192,"val":6709},{"ts":1586174325211,"val":6711},{"ts":1586174762088,"val":6657},{"ts":1586179926359,"val":6915},{"ts":1586180368441,"val":6809},{"ts":1586180373438,"val":6774},{"ts":1586180749981,"val":6879},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234804256,"val":0}]
                        widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 1 month
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1583606816475,"end":1586234816475,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1583606816475,"end":1586234816475,"timeout":5000}
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 48
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1583606816475,"val":0},{"ts":1585857922009,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893174183,"val":193},{"ts":1585893179325,"val":197},{"ts":1585897185165,"val":0},{"ts":1585917584464,"val":7089},{"ts":1585919453326,"val":7068},{"ts":1585919458361,"val":7056},{"ts":1585920005966,"val":7206},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585998291250,"val":5976},{"ts":1585998296276,"val":5970},{"ts":1585998301336,"val":5980},{"ts":1586005780202,"val":7162},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586077132776,"val":2587},{"ts":1586077137791,"val":2585},{"ts":1586077238247,"val":0},{"ts":1586093596415,"val":7097},{"ts":1586103414867,"val":4471},{"ts":1586103419882,"val":4459},{"ts":1586103429906,"val":4468},{"ts":1586109905885,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586167269338,"val":0},{"ts":1586179926359,"val":6915},{"ts":1586182251826,"val":6561},{"ts":1586182256996,"val":6572},{"ts":1586182271904,"val":6584},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234816475,"val":0}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 62
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1583606816475,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585866894468,"val":1083},{"ts":1585866899491,"val":1590},{"ts":1585875468113,"val":0},{"ts":1585893128983,"val":6513},{"ts":1585893174183,"val":6372},{"ts":1585893179325,"val":5325},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585919453326,"val":1636},{"ts":1585919458362,"val":1626},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585946826408,"val":3103},{"ts":1585963054196,"val":341},{"ts":1585972004945,"val":918},{"ts":1585972020004,"val":913},{"ts":1585982343403,"val":339},{"ts":1585991642299,"val":3828},{"ts":1585998296276,"val":1387},{"ts":1585998301336,"val":1832},{"ts":1586003238503,"val":6525},{"ts":1586022484981,"val":0},{"ts":1586024573904,"val":389},{"ts":1586024578917,"val":968},{"ts":1586024619113,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586050855348,"val":675},{"ts":1586050860376,"val":904},{"ts":1586057380892,"val":0},{"ts":1586076203797,"val":5655},{"ts":1586077132776,"val":1181},{"ts":1586077137791,"val":1228},{"ts":1586077238248,"val":0},{"ts":1586102621756,"val":6094},{"ts":1586103414867,"val":1915},{"ts":1586103419882,"val":775},{"ts":1586109218231,"val":0},{"ts":1586116428259,"val":4117},{"ts":1586129693337,"val":830},{"ts":1586129698348,"val":817},{"ts":1586133897547,"val":0},{"ts":1586151990748,"val":2834},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586182251826,"val":1128},{"ts":1586182256996,"val":1157},{"ts":1586191690404,"val":6163},{"ts":1586205378506,"val":0},{"ts":1586208378051,"val":754},{"ts":1586210196393,"val":560},{"ts":1586225768246,"val":259},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234816475,"val":1661}]
                        widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 62
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 48
                        EDIT:
                        zu früh gefreut. Ich habe nun von InfluxDB wieder auf MariaDB als Datenquelle gewechselt. Die Timeouts treten nun wieder deutlich häufiger auf. Auch beim Wechsel zurück auf InfluxDB gab es viele Timeouts....
                        ScroungerS 1 Antwort Letzte Antwort
                        • Chris TailorC Chris Tailor
                          @Scrounger Super, mit der neusten Version hatte ich nur beim ersten Test ein Timeout. Nach einem Refresh der Seite konnte ich dann den Fehler nicht mehr reproduzieren (PV Daten für 1 Tag, 3 tage, 7 Tage, 1 Monat und 7 Monate). Nachfolgend findest du noch die Log Daten vom ersten Versuch mit einem einmaligen Timeout. Das Timeout wird nun auf direkt in der Grafik rot dargestellt, verschwindet dann aber auch bei erfolgreicher Aktualisierung nicht mehr. Evtl. ist das noch ein kleiner Bug oder ist so gewollt.
                          Vielen Dank für die super Widgets!
                          Version vis-canvas-gauges: 0.1.5
                          index.html?smarthub:3948 Version vis-colorpicker: 1.0.1
                          index.html?smarthub:5374 Version vis-history: 1.0.0
                          info.js:9 Version Info-Adapter-Widget: 0.0.8
                          keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
                          index.html?smarthub:8340 Version vis-map: 1.0.3
                          materialdesign.js:25 Version vis-materialdesign: 0.2.79
                          lib.min.js:22 Download the Vue Devtools extension for a better development experience:
                          https://github.com/vuejs/vue-devtools
                          lib.min.js:22 You are running Vue in development mode.
                          Make sure to turn on production mode when deploying for production.
                          See more tips at https://vuejs.org/guide/deployment.html
                          players.js:58 Version players: 0.1.0
                          conn.js:273 2020-04-07T04:46:12.512Z Connected => authenticate
                          conn.js:293 2020-04-07T04:46:12.777Z Authenticated: true
                          vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40083_Batterie_SOC
                          vis.js:3167 Create inner vis object javascript.0.adapterdatenpunkte.modbus.Autarkie
                          vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40068_PV_Leistung
                          vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung
                          widgets.min.js:3 [Line History Chart w00477] widget setting: {"_data":{"wid":"w00477","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"1","aggregate":"minmax","timeIntervalToShow":"2 hours","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"center","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"bottom","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"influxdb.0","oid0":"modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung","oid1":"modbus.0.holdingRegisters.40068_PV_Leistung","lineSpanGaps2":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showValues2":"true","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","lineSpanGaps3":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showValues3":"true","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"true","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","legendText0":"Hausverbrauch W","legendText1":"PV Leistung W","dataColor1":"#F3FFBD","dataColor0":"#B2DBBF","useFillColor0":true,"useFillColor1":true,"fillColor1":"","fillColor0":"","yAxisGridLinesColor1":"","yAxisValueColor1":"","yAxisGridLinesColor0":"white","yAxisValueColor0":"white","yAxisValueLabelColor":"#ffffff","yAxisTitleColor":"#ffffff","xAxisTitleColor":"","xAxisValueLabelColor":"#ffffff","time_interval_oid":"0_userdata.0.vis.Timeinterval_iSpeed","legendFontColor":"white","maxDataPoints":"100","commonYAxis0":"1","commonYAxis1":"1","colorScheme":"scrounger.pie","legendFontSize":"20","legendFontFamily":"Jura-Light","legendBoxWidth":"8","legendPadding":"","lineTension0":"","valuesMaxDecimals0":"0","valuesFontFamily0":"Jura-DemiBold","valuesFontSize0":"20","valuesFontFamily1":"Jura-DemiBold","valuesFontSize1":"20","valuesMaxDecimals1":"0","yAxisTitleFontFamily":"Jura-Light","yAxisTitleFontSize":"","yAxisValueFontFamily":"Jura-Light","yAxisValueFontSize":"15","xAxisValueFontFamily":"Jura-Light","xAxisValueFontSize":"15","chartPaddingRight":"20","chartPaddingTop":"22","manualRefreshTrigger":"0_userdata.0.vis.ChartAktualisieren","pointSize":"0","minTimeInterval":"","xAxisMinRotation":"0","xAxisMaxRotation":"0","valuesMinDecimals1":"15","mdwDebug":true},"_cid":".map17","_computedAttrs":{},"wid":"w00477",
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586148374187,"end":1586234774189,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586148374187,"end":1586234774196,"timeout":5000}
                          widgets.min.js:1 version: "0.2.79"
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 286
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586148374187,"val":1327.4442156021098},{"ts":1586149597983,"val":2232},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151835018,"val":1543},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586152397495,"val":1130},{"ts":1586154246636,"val":796},{"ts":1586154352009,"val":2636},{"ts":1586154417313,"val":634},{"ts":1586154422357,"val":955},{"ts":1586154663511,"val":2283},{"ts":1586154723886,"val":583},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586156823024,"val":487},{"ts":1586156948480,"val":2873},{"ts":1586157013929,"val":1085},{"ts":1586157019290,"val":1299},{"ts":1586157059190,"val":2999},{"ts":1586157501173,"val":456},{"ts":1586157877787,"val":1058},{"ts":1586157882817,"val":1094},{"ts":1586158133821,"val":2445},{"ts":1586158173998,"val":241},{"ts":1586158299582,"val":1174},{"ts":1586160116497,"val":1260},{"ts":1586160141561,"val":699},{"ts":1586160352393,"val":2481},{"ts":1586160467840,"val":1229},{"ts":1586160472858,"val":1048},{"ts":1586160668587,"val":692},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586162915020,"val":842},{"ts":1586163025417,"val":2587},{"ts":1586163060542,"val":2114},{"ts":1586163065583,"val":1685},{"ts":1586163859139,"val":608},{"ts":1586163894422,"val":3020},{"ts":1586163924599,"val":1270},{"ts":1586163929732,"val":1557},{"ts":1586164326546,"val":343},{"ts":1586164547538,"val":2657},{"ts":1586164788528,"val":619},{"ts":1586164793558,"val":839},{"ts":1586164803603,"val":179},{"ts":1586164833735,"val":2418},{"ts":1586165652422,"val":1180},{"ts":1586165657413,"val":1042},{"ts":1586165833241,"val":2857},{"ts":1586165843277,"val":518},{"ts":1586166516032,"val":1036},{"ts":1586166521148,"val":1032},{"ts":1586167264278,"val":0},{"ts":1586167304445,"val":3352},{"ts":1586167379784,"val":1133},{"ts":1586167384773,"val":1116},{"ts":1586167580686,"val":6177},{"ts":1586168223534,"val":1011},{"ts":1586168243644,"val":1195},{"ts":1586168248660,"val":1193},{"ts":1586168660426,"val":969},{"ts":1586169006924,"val":5908},{"ts":1586169107536,"val":2328},{"ts":1586169112558,"val":4193},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586169971411,"val":1122},{"ts":1586169976352,"val":1885},{"ts":1586169981368,"val":1101},{"ts":1586170784666,"val":3550},{"ts":1586170834915,"val":2165},{"ts":1586170839942,"val":2184},{"ts":1586171608485,"val":3424},{"ts":1586171683774,"val":1561},{"ts":1586171698823,"val":1740},{"ts":1586171703843,"val":1591},{"ts":1586171874540,"val":1483},{"ts":1586171959900,"val":3358},{"ts":1586172562761,"val":1589},{"ts":1586172567779,"val":1584},{"ts":1586172587859,"val":2730},{"ts":1586172733478,"val":1364},{"ts":1586173426515,"val":1396},{"ts":1586173431530,"val":1403},{"ts":1586173582135,"val":2597},{"ts":1586174204747,"val":1274},{"ts":1586174290075,"val":1319},{"ts":1586174295089,"val":1302},{"ts":1586174315178,"val":2468},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586176737808,"val":1169},{"ts":1586176813130,"val":2340},{"ts":1586176883374,"val":1182},{"ts":1586176888399,"val":1257},{"ts":1586177059091,"val":1173},{"ts":1586177174546,"val":2474},{"ts":1586177747129,"val":1785},{"ts":1586177752151,"val":1205},{"ts":1586178083588,"val":2360},{"ts":1586178309483,"val":1067},{"ts":1586178610816,"val":1102},{"ts":1586178615809,"val":1121},{"ts":1586179112913,"val":2420},{"ts":1586179429232,"val":1008},{"ts":1586179474399,"val":1104},{"ts":1586179479418,"val":1113},{"ts":1586179680252,"val":1066},{"ts":1586180298136,"val":2347},{"ts":1586180338299,"val":1240},{"ts":1586180343322,"val":1536},{"ts":1586180493947,"val":2418},{"ts":1586181151867,"val":1137},{"ts":1586181202061,"val":1166},{"ts":1586181207076,"val":2261},{"ts":1586181488430,"val":1103},{"ts":1586181850020,"val":2312},{"ts":1586182065925,"val":1178},{"ts":1586182070988,"val":1166},{"ts":1586182377307,"val":2336},{"ts":1586182427580,"val":1108},{"ts":1586182929855,"val":2113},{"ts":1586182934864,"val":1112},{"ts":1586182969994,"val":2313},{"ts":1586183743608,"val":1052},{"ts":1586183793806,"val":1070},{"ts":1586183798847,"val":1084},{"ts":1586183879231,"val":2297},{"ts":1586183919347,"val":589},{"ts":1586185769496,"val":858},{"ts":1586185809646,"val":1722},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586188104226,"val":525},{"ts":1586188114254,"val":533},{"ts":1586188119270,"val":524},{"ts":1586188264864,"val":1683},{"ts":1586188591383,"val":482},{"ts":1586188978417,"val":494},{"ts":1586188983441,"val":1004},{"ts":1586189360267,"val":464},{"ts":1586189515728,"val":1656},{"ts":1586189761817,"val":960},{"ts":1586191579896,"val":1463},{"ts":1586191670467,"val":649},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194048203,"val":861},{"ts":1586194123540,"val":2252},{"ts":1586194163696,"val":1231},{"ts":1586194168712,"val":698},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586195027708,"val":2012},{"ts":1586195032801,"val":1232},{"ts":1586195113268,"val":2421},{"ts":1586195595240,"val":341},{"ts":1586195891661,"val":1067},{"ts":1586195896677,"val":1048},{"ts":1586196052372,"val":1061},{"ts":1586196107619,"val":1008},{"ts":1586196152901,"val":1046},{"ts":1586198002185,"val":1024},{"ts":1586198227952,"val":1009},{"ts":1586198423669,"val":1050},{"ts":1586198483865,"val":1035},{"ts":1586198488881,"val":1043},{"ts":1586198644430,"val":1533},{"ts":1586198860059,"val":986},{"ts":1586199349454,"val":1184},{"ts":1586199354483,"val":1173},{"ts":1586199445083,"val":1156},{"ts":1586199475251,"val":1385},{"ts":1586200209314,"val":1214},{"ts":1586200214344,"val":1201},{"ts":1586200962577,"val":891},{"ts":1586200977621,"val":1396},{"ts":1586201078091,"val":1363},{"ts":1586201083300,"val":1372},{"ts":1586201228710,"val":1401},{"ts":1586201851444,"val":1206},{"ts":1586201941764,"val":1224},{"ts":1586201946777,"val":1216},{"ts":1586202107409,"val":1711},{"ts":1586202373415,"val":1210},{"ts":1586202805391,"val":1235},{"ts":1586202810411,"val":1239},{"ts":1586202815428,"val":1249},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586205393574,"val":750},{"ts":1586205398606,"val":749},{"ts":1586206096897,"val":613},{"ts":1586206257486,"val":645},{"ts":1586206262504,"val":652},{"ts":1586206302655,"val":612},{"ts":1586206403066,"val":644},{"ts":1586208252581,"val":690},{"ts":1586208342895,"val":0},{"ts":1586208362985,"val":779},{"ts":1586208378051,"val":754},{"ts":1586210196393,"val":560},{"ts":1586210321912,"val":545},{"ts":1586210403395,"val":564},{"ts":1586210577994,"val":554},{"ts":1586210583013,"val":548},{"ts":1586210613137,"val":544},{"ts":1586210753758,"val":678},{"ts":1586211341349,"val":547},{"ts":1586213190303,"val":298},{"ts":1586213260773,"val":309},{"ts":1586213406398,"val":287},{"ts":1586213436537,"val":301},{"ts":1586215291547,"val":882},{"ts":1586215296559,"val":886},{"ts":1586215605005,"val":747},{"ts":1586215765662,"val":795},{"ts":1586215770697,"val":800},{"ts":1586215896315,"val":784},{"ts":1586216061985,"val":811},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218188358,"val":925},{"ts":1586218348946,"val":1032},{"ts":1586218353962,"val":1029},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586219217540,"val":866},{"ts":1586219227581,"val":869},{"ts":1586219232600,"val":864},{"ts":1586219272768,"val":896},{"ts":1586219438425,"val":877},{"ts":1586221288103,"val":876},{"ts":1586221303149,"val":872},{"ts":1586221313182,"val":885},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223262888,"val":268},{"ts":1586223539019,"val":1082},{"ts":1586223544144,"val":463},{"ts":1586223800107,"val":333},{"ts":1586224402596,"val":363},{"ts":1586224407611,"val":361},{"ts":1586224613434,"val":366},{"ts":1586225020230,"val":262},{"ts":1586225266226,"val":263},{"ts":1586225271240,"val":270},{"ts":1586225642729,"val":300},{"ts":1586225768246,"val":259},{"ts":1586225923884,"val":279},{"ts":1586227741595,"val":418},{"ts":1586227862087,"val":336},{"ts":1586227867114,"val":335},{"ts":1586228173435,"val":324},{"ts":1586228509926,"val":444},{"ts":1586228725822,"val":381},{"ts":1586228730838,"val":350},{"ts":1586229343264,"val":327},{"ts":1586229544046,"val":354},{"ts":1586229589180,"val":335},{"ts":1586229594214,"val":330},{"ts":1586229614279,"val":329},{"ts":1586229634350,"val":484},{"ts":1586230452867,"val":351},{"ts":1586230457902,"val":352},{"ts":1586230593504,"val":357},{"ts":1586231045444,"val":274},{"ts":1586231170977,"val":276},{"ts":1586233021191,"val":1662},{"ts":1586233026198,"val":1666},{"ts":1586233031215,"val":1656},{"ts":1586233041249,"val":1660},{"ts":1586233046265,"val":1663},{"ts":1586233051280,"val":1661},{"ts":1586234311418,"val":1661},{"ts":1586234317314,"val":1661},{"ts":1586234774189,"val":1661}]
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586148374187,"val":22.852575024652907},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151850123,"val":161},{"ts":1586151870190,"val":154},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154326917,"val":352},{"ts":1586154382143,"val":327},{"ts":1586154417313,"val":340},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157009004,"val":489},{"ts":1586157013929,"val":475},{"ts":1586157019289,"val":455},{"ts":1586157164657,"val":422},{"ts":1586157701981,"val":554},{"ts":1586157877787,"val":528},{"ts":1586157882817,"val":484},{"ts":1586158028351,"val":550},{"ts":1586158214217,"val":431},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160467840,"val":1122},{"ts":1586160472858,"val":1131},{"ts":1586160512990,"val":1121},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163030429,"val":2099},{"ts":1586163060542,"val":2116},{"ts":1586163070600,"val":2126},{"ts":1586163201203,"val":2013},{"ts":1586163919495,"val":2785},{"ts":1586163924598,"val":2783},{"ts":1586163934646,"val":2791},{"ts":1586164100481,"val":2746},{"ts":1586164778599,"val":3246},{"ts":1586164788528,"val":3222},{"ts":1586164793558,"val":3238},{"ts":1586164803603,"val":3200},{"ts":1586165652422,"val":3718},{"ts":1586165657413,"val":3713},{"ts":1586165873391,"val":3676},{"ts":1586166511020,"val":4153},{"ts":1586166516032,"val":4147},{"ts":1586166521148,"val":4134},{"ts":1586167269338,"val":0},{"ts":1586167374687,"val":4561},{"ts":1586167379784,"val":4552},{"ts":1586167384773,"val":4556},{"ts":1586168243644,"val":5082},{"ts":1586168248660,"val":5091},{"ts":1586168308842,"val":5018},{"ts":1586169047220,"val":5333},{"ts":1586169102514,"val":5326},{"ts":1586169112557,"val":5320},{"ts":1586169760442,"val":5592},{"ts":1586169971410,"val":5562},{"ts":1586169976352,"val":5554},{"ts":1586170036595,"val":5533},{"ts":1586170834915,"val":5909},{"ts":1586170839942,"val":5931},{"ts":1586171131274,"val":5882},{"ts":1586171653656,"val":6133},{"ts":1586171698823,"val":6109},{"ts":1586171703843,"val":6128},{"ts":1586171754011,"val":6076},{"ts":1586172422129,"val":6381},{"ts":1586172562761,"val":6378},{"ts":1586172567778,"val":6389},{"ts":1586172633100,"val":6316},{"ts":1586173150581,"val":6570},{"ts":1586173426515,"val":6481},{"ts":1586173431530,"val":6462},{"ts":1586173486746,"val":6438},{"ts":1586174290074,"val":6756},{"ts":1586174295089,"val":6724},{"ts":1586174470952,"val":6771},{"ts":1586174762088,"val":6657},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586176772949,"val":6756},{"ts":1586176878355,"val":6839},{"ts":1586176898433,"val":6833},{"ts":1586177013882,"val":6751},{"ts":1586177631651,"val":6903},{"ts":1586177747128,"val":6809},{"ts":1586177762220,"val":6808},{"ts":1586178294421,"val":6687},{"ts":1586178575601,"val":6886},{"ts":1586178610816,"val":6839},{"ts":1586178615804,"val":6844},{"ts":1586179052674,"val":6903},{"ts":1586179474399,"val":6750},{"ts":1586179479418,"val":6774},{"ts":1586179624982,"val":6728},{"ts":1586179926359,"val":6915},{"ts":1586180338299,"val":6821},{"ts":1586180343322,"val":6844},{"ts":1586180749981,"val":6879},{"ts":1586181151867,"val":6763},{"ts":1586181202061,"val":6774},{"ts":1586181207075,"val":6780},{"ts":1586181227186,"val":6808},{"ts":1586181714505,"val":6515},{"ts":1586182065924,"val":6584},{"ts":1586182070988,"val":6612},{"ts":1586182849534,"val":6377},{"ts":1586182929854,"val":6389},{"ts":1586182934864,"val":6401},{"ts":1586182949913,"val":6416},{"ts":1586183773727,"val":6220},{"ts":1586183793806,"val":6232},{"ts":1586183798846,"val":6231},{"ts":1586183844189,"val":6251},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188104226,"val":4842},{"ts":1586188114254,"val":4850},{"ts":1586188119270,"val":4839},{"ts":1586188139365,"val":4870},{"ts":1586188978417,"val":4461},{"ts":1586188983441,"val":4457},{"ts":1586188988479,"val":4461},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586194158774,"val":1032},{"ts":1586194163695,"val":1039},{"ts":1586194168712,"val":1038},{"ts":1586195027708,"val":438},{"ts":1586195032801,"val":442},{"ts":1586195093282,"val":450},{"ts":1586195891661,"val":79},{"ts":1586195896677,"val":92},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234774196,"val":0}]
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 286
                          widgets.min.js:3 [Line History Chart w00477] prepare dataset for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung'
                          widgets.min.js:3 [Line History Chart w00477] prepare yAxis for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung'
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                          widgets.min.js:3 [Line History Chart w00477] prepare dataset for 'modbus.0.holdingRegisters.40068_PV_Leistung'
                          widgets.min.js:3 [Line History Chart w00477] prepare yAxis for 'modbus.0.holdingRegisters.40068_PV_Leistung'
                          widgets.min.js:3 [Line History Chart w00477] prepare chart options
                          widgets.min.js:3 [Line History Chart w00477] chart creating...
                          widgets.min.js:3 [Line History Chart w00477] chart successful created
                          DevTools failed to parse SourceMap: http://192.168.86.90:8082/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
                          widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 3 days
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585975595024,"end":1586234795032,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585975595024,"end":1586234795039,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585975595024,"val":968.2274900398406},{"ts":1585975599473,"val":970},{"ts":1585976432703,"val":1087},{"ts":1585977953951,"val":939},{"ts":1585978185139,"val":945},{"ts":1585978189981,"val":953},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585980771608,"val":435},{"ts":1585980781658,"val":445},{"ts":1585982343403,"val":339},{"ts":1585983312823,"val":1590},{"ts":1585983368074,"val":497},{"ts":1585983373095,"val":492},{"ts":1585983458448,"val":348},{"ts":1585984217203,"val":2734},{"ts":1585985959326,"val":1028},{"ts":1585985964348,"val":2091},{"ts":1585986511507,"val":935},{"ts":1585988504257,"val":2740},{"ts":1585988554474,"val":1588},{"ts":1585988559497,"val":1586},{"ts":1585990352016,"val":1308},{"ts":1585990914291,"val":3516},{"ts":1585991145112,"val":3363},{"ts":1585991150131,"val":2075},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585993736307,"val":2155},{"ts":1585993741353,"val":2375},{"ts":1585994248405,"val":3707},{"ts":1585996031210,"val":1244},{"ts":1585996327815,"val":1909},{"ts":1585996332831,"val":1290},{"ts":1585996704240,"val":1231},{"ts":1585998266153,"val":2610},{"ts":1585998919075,"val":1299},{"ts":1585998924097,"val":1287},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586001510457,"val":1332},{"ts":1586001515478,"val":1460},{"ts":1586001711430,"val":1317},{"ts":1586003238503,"val":6525},{"ts":1586004102681,"val":6288},{"ts":1586004107707,"val":4715},{"ts":1586004147878,"val":5465},{"ts":1586006664079,"val":1370},{"ts":1586006694221,"val":1402},{"ts":1586006699275,"val":1407},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010262197,"val":1360},{"ts":1586010523424,"val":2534},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586014384795,"val":2524},{"ts":1586014470188,"val":1346},{"ts":1586014475204,"val":1936},{"ts":1586015881337,"val":1170},{"ts":1586017056341,"val":2532},{"ts":1586017066383,"val":1335},{"ts":1586017071424,"val":1341},{"ts":1586017402800,"val":2539},{"ts":1586019567023,"val":634},{"ts":1586019657432,"val":657},{"ts":1586019662468,"val":656},{"ts":1586022032554,"val":1964},{"ts":1586022213521,"val":170},{"ts":1586022248752,"val":319},{"ts":1586022253765,"val":673},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586024840244,"val":2290},{"ts":1586024845260,"val":618},{"ts":1586024850281,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586027432732,"val":335},{"ts":1586027437837,"val":366},{"ts":1586027854628,"val":2254},{"ts":1586027874750,"val":0},{"ts":1586030025219,"val":584},{"ts":1586030030269,"val":2102},{"ts":1586030070486,"val":0},{"ts":1586032391334,"val":2744},{"ts":1586032617389,"val":1120},{"ts":1586032622407,"val":1070},{"ts":1586033536704,"val":2855},{"ts":1586034682203,"val":291},{"ts":1586035209862,"val":896},{"ts":1586035214877,"val":889},{"ts":1586037269627,"val":2751},{"ts":1586037701658,"val":245},{"ts":1586037802128,"val":833},{"ts":1586037807140,"val":1061},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586040393597,"val":501},{"ts":1586040398609,"val":457},{"ts":1586040493959,"val":0},{"ts":1586040704830,"val":2247},{"ts":1586042983665,"val":499},{"ts":1586042988681,"val":112},{"ts":1586043008746,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586045574048,"val":561},{"ts":1586045579062,"val":451},{"ts":1586045604206,"val":0},{"ts":1586047512093,"val":2054},{"ts":1586048169783,"val":0},{"ts":1586048174807,"val":233},{"ts":1586048204933,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050759988,"val":2457},{"ts":1586050765005,"val":1012},{"ts":1586050845298,"val":2651},{"ts":1586053129518,"val":209},{"ts":1586053350266,"val":923},{"ts":1586053355289,"val":901},{"ts":1586054695420,"val":288},{"ts":1586055488482,"val":2686},{"ts":1586055945279,"val":887},{"ts":1586055950295,"val":538},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586058535519,"val":304},{"ts":1586058540535,"val":325},{"ts":1586058590704,"val":0},{"ts":1586059012299,"val":2348},{"ts":1586061130886,"val":123},{"ts":1586061135908,"val":590},{"ts":1586061201161,"val":0},{"ts":1586061401936,"val":2078},{"ts":1586063721185,"val":526},{"ts":1586063726206,"val":1251},{"ts":1586063801693,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586066311611,"val":324},{"ts":1586066316626,"val":390},{"ts":1586066366803,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068902230,"val":405},{"ts":1586068907250,"val":343},{"ts":1586068912275,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071497690,"val":950},{"ts":1586071502717,"val":895},{"ts":1586071703481,"val":226},{"ts":1586072762980,"val":2978},{"ts":1586074088589,"val":1158},{"ts":1586074093629,"val":2544},{"ts":1586074133748,"val":617},{"ts":1586076203797,"
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 203
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585975595024,"val":20.79800990397711},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978139770,"val":84},{"ts":1585978185139,"val":79},{"ts":1585978194995,"val":83},{"ts":1585978230205,"val":77},{"ts":1585980721437,"val":311},{"ts":1585980771607,"val":306},{"ts":1585980781658,"val":304},{"ts":1585981163296,"val":294},{"ts":1585983312823,"val":518},{"ts":1585983368074,"val":444},{"ts":1585983373093,"val":417},{"ts":1585984789725,"val":22},{"ts":1585985638026,"val":646},{"ts":1585985959326,"val":581},{"ts":1585985964348,"val":598},{"ts":1585987214177,"val":0},{"ts":1585988554474,"val":1570},{"ts":1585988559497,"val":1564},{"ts":1585991130118,"val":2729},{"ts":1585991145112,"val":2707},{"ts":1585991150131,"val":2729},{"ts":1585991175308,"val":2691},{"ts":1585993721236,"val":4193},{"ts":1585993736307,"val":4160},{"ts":1585993741353,"val":4180},{"ts":1585993806645,"val":3923},{"ts":1585996277559,"val":5402},{"ts":1585996327815,"val":5381},{"ts":1585996332831,"val":5368},{"ts":1585996347883,"val":5107},{"ts":1585998914062,"val":6306},{"ts":1585998924097,"val":6300},{"ts":1585999160025,"val":6279},{"ts":1586001495373,"val":6897},{"ts":1586001510457,"val":6891},{"ts":1586001515478,"val":6889},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004102679,"val":6908},{"ts":1586004107706,"val":6909},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586006694220,"val":7057},{"ts":1586006699273,"val":7068},{"ts":1586007086047,"val":7110},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586014470188,"val":5411},{"ts":1586014475203,"val":5405},{"ts":1586014490251,"val":5408},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586019652398,"val":2444},{"ts":1586019657432,"val":2452},{"ts":1586019662468,"val":2456},{"ts":1586022248752,"val":462},{"ts":1586022253765,"val":443},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063706151,"val":46},{"ts":1586063721185,"val":43},{"ts":1586063726205,"val":41},{"ts":1586066211238,"val":210},{"ts":1586066311611,"val":200},{"ts":1586066316626,"val":206},{"ts":1586068209595,"val":155},{"ts":1586068801844,"val":414},{"ts":1586068902229,"val":404},{"ts":1586068907250,"val":405},{"ts":1586068917655,"val":373},{"ts":1586071221625,"val":554},{"ts":1586071497689,"val":551},{"ts":1586071502717,"val":500},{"ts":1586071834103,"val":217},{"ts":1586074078555,"val":1069},{"ts":1586074088589,"val":1066},{"ts":1586074093629,"val":1063},{"ts":1586074098636,"val":1059},{"ts":1586076384660,"val":2046},{"ts":1586076681006,"val":1928},{"ts":1586076686023,"val":1924},{"ts":1586077238247,"val":0},{"ts":1586079251896,"val":3776},{"ts":1586079271955,"val":3758},{"ts":1586079281993,"val":3794},{"ts":1586079287009,"val":3782},{"ts":1586081862870,"val":5104},{"ts":1586081867874,"val":5094},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586102601680,"val":4867},{"ts":1586102606842,"val":4856},{"ts":1586105191869,"val":3375},{"ts":1586105196900,"val":3369},{"ts":1586105201917,"val":3375},{"ts":1586107782298,"val":1524},{"ts":1586107787323,"val":1518},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586151850123,"val":161},{"ts":1586151865175,"val":162},{"ts":1586151870190,"val":154},{"ts":1586154442438,"val":353},{"ts":1586154447450,"val":337},{"ts":1586154628301,"val":333},{"ts":1586157009004,"val":489},{"ts":1586157034004,"val":463},{"ts":1586157039305,"val":492},{"ts":1586157164657,"val":422},{"ts":1586157701981,"val":554},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163201203,"val":2013},{"ts":1586164808936,"val":3247},{"ts":1586164813646,"val":3216},{"ts":1586167269338,"val":0},{"ts":1586167394824,"val":4574},{"ts":1586167404870,"val":4573},{"ts":1586169760442,"val":5592},{"ts":1586169991401,"val":5573},{"ts":1586169996425,"val":5565},{"ts":1586170036595,"val":5533},{"ts":1586172582835,"val":6410},{"ts":1586172587859,"val":6401},{"ts":1586172633100,"val":6316},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586177013882,"val":6751},{"ts":1586177631651,"val":6903},{"ts":1586177767206,"val":6821},{"ts":1586177772229,"val":6808},{"ts":1586178294421,"val":6687},{"ts":1586179926359,"val":6915},{"ts":1586180358377,"val":6797},{"ts":1586180363395,"val":6827},{"ts":1586180749981,"val":6879},{"ts":1586182944896,"val":6369},{"ts":1586182954923,"val":6411},{"ts":1586182959958,"val":6379},{"ts":1586182964977,"val":6415},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586188119270,"val":4839},{"ts":1586188134349,"val":4857},{"ts":1586188139365,"val":4870},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586195891661,"val":79},{"ts":1586195906715,"val":79},{"ts":1586195916741,"val":82},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234795039,"val":0}]
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 203
                          widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
                          widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 7 days
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630002994,"end":1586234802995,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630002994,"end":1586234803002,"timeout":5000}
                          widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - TimeInterval by Editor **************************************************************
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630004246,"end":1586234804246,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630004246,"end":1586234804256,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 253
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585630002994,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585858669660,"val":654},{"ts":1585858746453,"val":4252},{"ts":1585859826500,"val":3279},{"ts":1585859827521,"val":2982},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585865870728,"val":1115},{"ts":1585865875737,"val":1025},{"ts":1585871231935,"val":299},{"ts":1585871728785,"val":2806},{"ts":1585871919569,"val":1735},{"ts":1585871924581,"val":1490},{"ts":1585872195774,"val":2702},{"ts":1585875468113,"val":0},{"ts":1585877970344,"val":343},{"ts":1585877975360,"val":115},{"ts":1585877985395,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585884018872,"val":496},{"ts":1585884023883,"val":1333},{"ts":1585884064025,"val":0},{"ts":1585889665174,"val":2601},{"ts":1585890066872,"val":562},{"ts":1585890071882,"val":995},{"ts":1585890378178,"val":253},{"ts":1585893505542,"val":6581},{"ts":1585896111023,"val":1502},{"ts":1585896115932,"val":1472},{"ts":1585896286641,"val":472},{"ts":1585901110985,"val":3204},{"ts":1585902160322,"val":1446},{"ts":1585902165343,"val":1418},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585908206385,"val":2846},{"ts":1585908211400,"val":3800},{"ts":1585908603295,"val":5922},{"ts":1585910547158,"val":1413},{"ts":1585914254312,"val":1473},{"ts":1585914259334,"val":1683},{"ts":1585914786772,"val":1440},{"ts":1585917710085,"val":4053},{"ts":1585920302216,"val":1534},{"ts":1585920307263,"val":1520},{"ts":1585920714057,"val":3022},{"ts":1585922220919,"val":979},{"ts":1585926354537,"val":1192},{"ts":1585926359563,"val":1179},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932402808,"val":1878},{"ts":1585932407821,"val":1907},{"ts":1585933095645,"val":5320},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585950543925,"val":2052},{"ts":1585950548938,"val":2069},{"ts":1585950694493,"val":3047},{"ts":1585956084287,"val":918},{"ts":1585956591488,"val":982},{"ts":1585956596383,"val":976},{"ts":1585958744944,"val":1015},{"ts":1585961362271,"val":370},{"ts":1585962642564,"val":476},{"ts":1585962647602,"val":466},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585968686863,"val":531},{"ts":1585968696903,"val":535},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585974731052,"val":979},{"ts":1585974741088,"val":978},{"ts":1585975162738,"val":1677},{"ts":1585980148705,"val":348},{"ts":1585980786682,"val":444},{"ts":1585980791713,"val":432},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585986832829,"val":1175},{"ts":1585986837852,"val":1155},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992882588,"val":2074},{"ts":1585992887613,"val":1648},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1585998929111,"val":1284},{"ts":1585998934133,"val":1281},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586004976531,"val":2043},{"ts":1586004981635,"val":1549},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017056341,"val":2532},{"ts":1586017071424,"val":1341},{"ts":1586017076460,"val":1327},{"ts":1586017402800,"val":2539},{"ts":1586022484981,"val":0},{"ts":1586023122859,"val":350},{"ts":1586023127882,"val":369},{"ts":1586023253307,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586029170933,"val":405},{"ts":1586029175946,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586035214877,"val":889},{"ts":1586035219972,"val":1109},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586041262025,"val":51},{"ts":1586041267241,"val":907},{"ts":1586041287170,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586047311222,"val":0},{"ts":1586047316235,"val":177},{"ts":1586047346350,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586053360302,"val":842},{"ts":1586053365316,"val":736},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586059408863,"val":600},{"ts":1586059413913,"val":470},{"ts":1586059428959,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065458076,"val":399},{"ts":1586065463096,"val":749},{"ts":1586065583541,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071502717,"val":895},{"ts":1586071507737,"val":896},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586077554539,"val":1161},{"ts":1586077559561,"val":1128},{"ts":1586077780632,"val":1090},{"ts":1586078352967,"val":3369},{"ts":1586083599519,"val":1329},{"ts":1586083604540,"val":1318},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090630195,"val":778},{"ts":1586092868521,"val":2080},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095857154,"val":2851},{"ts":1586098177848,"val":1267},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586107646783,"val":342},{"ts":1586107792345,"val":404},{"ts":1586107797363,"val":352},{"ts":1586109218231,"val":0},{"ts":1586113513452,"val":3736},{"ts":1586113839491,"val":3588},{"ts":1586113844698,"val":3591},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586119883341,"val":1066},{"ts":1586119893418,"val":1083},{"ts":1586120471125,"val":1484},{"ts":1586123846241,"val":733},{"ts":1586125935887,"val":764},{"ts":1586125940895,"val":758},{"ts":1586126016471,"val":743},{"ts":1586127794593,"val":1617},{"ts":1586131983847,"val":777},{"ts":1586131988867,"val":779},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586138031625,"val":880},{"ts":1586138036640,"val":877},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586168273731,"val":4717},{"ts":1586168278743,"val":1198},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586174320192,"val":1322},{"ts":1586174325211,"val":1308},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586180368441,"val":1242},{"ts":1586180373438,"val":1201},{"ts":1586180493947,"val":2418},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586198513968,"val":1081},{"ts":1586198519017,"val":1075},{"ts":1586200962577,"val":891},{"ts":1586202107409,"val":1711},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586208362985,"val":779},{"ts":1586210608114,"val":553},{"ts":1586210613137,"val":544},{"ts":1586213406398,"val":287},{"ts":1586215296559,"val":886},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223539019,"val":1082},{"ts":1586225768246,"val":259},{"ts":1586228750899,"val":347},{"ts":1586228755914,"val":344},{"ts":1586231045444,"val":274},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234802995,"val":1661}]
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 141
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585630002994,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585895950314,"val":526},{"ts":1585896111023,"val":466},{"ts":1585896115932,"val":484},{"ts":1585897185165,"val":0},{"ts":1585902160322,"val":1491},{"ts":1585902165342,"val":1495},{"ts":1585908206385,"val":4677},{"ts":1585908211400,"val":4663},{"ts":1585908241498,"val":4550},{"ts":1585914254312,"val":6764},{"ts":1585914259334,"val":6782},{"ts":1585917263083,"val":6529},{"ts":1585920005966,"val":7206},{"ts":1585920302216,"val":7072},{"ts":1585920307263,"val":7068},{"ts":1585920392679,"val":7177},{"ts":1585920578493,"val":4454},{"ts":1585926354537,"val":6259},{"ts":1585926359563,"val":6256},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585932402807,"val":2886},{"ts":1585932407820,"val":2889},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585980721437,"val":311},{"ts":1585980786682,"val":306},{"ts":1585980801746,"val":311},{"ts":1585984789725,"val":22},{"ts":1585986802724,"val":806},{"ts":1585986832829,"val":785},{"ts":1585986837852,"val":774},{"ts":1585987214177,"val":0},{"ts":1585992877572,"val":3776},{"ts":1585992882588,"val":3564},{"ts":1585992887613,"val":3585},{"ts":1585993178846,"val":3480},{"ts":1585998914062,"val":6306},{"ts":1585998929111,"val":6281},{"ts":1585998934133,"val":6285},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004976531,"val":6856},{"ts":1586004981635,"val":6874},{"ts":1586005780202,"val":7162},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586023012362,"val":23},{"ts":1586023122859,"val":34},{"ts":1586023127882,"val":36},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586065432983,"val":165},{"ts":1586065458076,"val":158},{"ts":1586065463096,"val":157},{"ts":1586065593575,"val":155},{"ts":1586071221625,"val":554},{"ts":1586071502717,"val":500},{"ts":1586071507737,"val":503},{"ts":1586077238247,"val":0},{"ts":1586077514400,"val":2727},{"ts":1586077554539,"val":2702},{"ts":1586077559561,"val":2717},{"ts":1586077700285,"val":2672},{"ts":1586083448954,"val":5755},{"ts":1586083594501,"val":5742},{"ts":1586083609556,"val":5755},{"ts":1586083664769,"val":5751},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586107792345,"val":1513},{"ts":1586107797363,"val":1507},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586167269338,"val":0},{"ts":1586168263702,"val":5093},{"ts":1586168273730,"val":5089},{"ts":1586168278743,"val":5098},{"ts":1586168308842,"val":5018},{"ts":1586174290074,"val":6756},{"ts":1586174320192,"val":6709},{"ts":1586174325211,"val":6711},{"ts":1586174762088,"val":6657},{"ts":1586179926359,"val":6915},{"ts":1586180368441,"val":6809},{"ts":1586180373438,"val":6774},{"ts":1586180749981,"val":6879},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234803002,"val":0}]
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 253
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 141
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585630004246,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585858669660,"val":654},{"ts":1585858746453,"val":4252},{"ts":1585859827521,"val":2982},{"ts":1585859828540,"val":3236},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585865875737,"val":1025},{"ts":1585865880749,"val":1049},{"ts":1585871231935,"val":299},{"ts":1585871728785,"val":2806},{"ts":1585871919569,"val":1735},{"ts":1585871924581,"val":1490},{"ts":1585872195774,"val":2702},{"ts":1585875468113,"val":0},{"ts":1585877970344,"val":343},{"ts":1585877975360,"val":115},{"ts":1585877985395,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585884018872,"val":496},{"ts":1585884023883,"val":1333},{"ts":1585884064025,"val":0},{"ts":1585889665174,"val":2601},{"ts":1585890066872,"val":562},{"ts":1585890071882,"val":995},{"ts":1585890378178,"val":253},{"ts":1585893505542,"val":6581},{"ts":1585896115932,"val":1472},{"ts":1585896120981,"val":1975},{"ts":1585896286641,"val":472},{"ts":1585901110985,"val":3204},{"ts":1585902160322,"val":1446},{"ts":1585902165343,"val":1418},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585908211400,"val":3800},{"ts":1585908216420,"val":4140},{"ts":1585908603295,"val":5922},{"ts":1585910547158,"val":1413},{"ts":1585914259334,"val":1683},{"ts":1585914264352,"val":1468},{"ts":1585914786772,"val":1440},{"ts":1585917710085,"val":4053},{"ts":1585920307263,"val":1520},{"ts":1585920312285,"val":1532},{"ts":1585920714057,"val":3022},{"ts":1585922220919,"val":979},{"ts":1585926354537,"val":1192},{"ts":1585926359563,"val":1179},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932402808,"val":1878},{"ts":1585932407821,"val":1907},{"ts":1585933095645,"val":5320},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585950543925,"val":2052},{"ts":1585950548938,"val":2069},{"ts":1585950694493,"val":3047},{"ts":1585956084287,"val":918},{"ts":1585956591488,"val":982},{"ts":1585956596383,"val":976},{"ts":1585958744944,"val":1015},{"ts":1585961362271,"val":370},{"ts":1585962642564,"val":476},{"ts":1585962647602,"val":466},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585968686863,"val":531},{"ts":1585968696903,"val":535},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585974731052,"val":979},{"ts":1585974741088,"val":978},{"ts":1585975162738,"val":1677},{"ts":1585980148705,"val":348},{"ts":1585980786682,"val":444},{"ts":1585980791713,"val":432},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585986832829,"val":1175},{"ts":1585986837852,"val":1155},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992882588,"val":2074},{"ts":1585992887613,"val":1648},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1585998929111,"val":1284},{"ts":1585998934133,"val":1281},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586004976531,"val":2043},{"ts":1586004981635,"val":1549},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017056341,"val":2532},{"ts":1586017071424,"val":1341},{"ts":1586017076460,"val":1327},{"ts":1586017402800,"val":2539},{"ts":1586022484981,"val":0},{"ts":1586023122859,"val":350},{"ts":1586023127882,"val":369},{"ts":1586023253307,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586029170933,"val":405},{"ts":1586029175946,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586035219972,"val":1109},{"ts":1586035224988,"val":1083},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586041267241,"val":907},{"ts":1586041272068,"val":409},{"ts":1586041287170,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586047316235,"val":177},{"ts":1586047321262,"val":908},{"ts":1586047346350,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586053360302,"val":842},{"ts":1586053365316,"val":736},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586059408863,"val":600},{"ts":1586059413913,"val":470},{"ts":1586059428959,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065458076,"val":399},{"ts":1586065463096,"val":749},{"ts":1586065583541,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071507737,"val":896},{"ts":1586071512748,"val":904},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586077554539,"val":1161},{"ts":1586077559561,"val":1128},{"ts":1586077780632,"val":1090},{"ts":1586078352967,"val":3369},{"ts":1586083599519,"val":1329},{"ts":1586083604540,"val":1318},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090630195,"val":778},{"ts":1586092868521,"val":2080},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095857154,"val":2851},{"ts":1586098177848,"val":1267},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586107646783,"val":342},{"ts":1586107792345,"val":404},{"ts":1586107797363,"val":352},{"ts":1586109218231,"val":0},{"ts":1586113513452,"val":3736},{"ts":1586113839491,"val":3588},{"ts":1586113844698,"val":3591},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586119883341,"val":1066},{"ts":1586119893418,"val":1083},{"ts":1586120471125,"val":1484},{"ts":1586123846241,"val":733},{"ts":1586125935887,"val":764},{"ts":1586125940895,"val":758},{"ts":1586126016471,"val":743},{"ts":1586127794593,"val":1617},{"ts":1586131983847,"val":777},{"ts":1586131988867,"val":779},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586138031625,"val":880},{"ts":1586138036640,"val":877},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586168273731,"val":4717},{"ts":1586168278743,"val":1198},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586174320192,"val":1322},{"ts":1586174325211,"val":1308},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586180368441,"val":1242},{"ts":1586180373438,"val":1201},{"ts":1586180493947,"val":2418},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586198513968,"val":1081},{"ts":1586198519017,"val":1075},{"ts":1586200962577,"val":891},{"ts":1586202107409,"val":1711},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586208362985,"val":779},{"ts":1586210608114,"val":553},{"ts":1586210613137,"val":544},{"ts":1586213406398,"val":287},{"ts":1586215296559,"val":886},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223539019,"val":1082},{"ts":1586225768246,"val":259},{"ts":1586228755914,"val":344},{"ts":1586228760946,"val":348},{"ts":1586231045444,"val":274},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234804246,"val":1661}]
                          widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                          (anonymous) @ widgets.min.js:4
                          (anonymous) @ conn.js:1299
                          setTimeout (async)
                          getHistory @ conn.js:1297
                          getHistory @ vis.js:2613
                          getTaskForHistoryData @ widgets.min.js:4
                          o @ widgets.min.js:3
                          (anonymous) @ widgets.min.js:3
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 142
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585630004246,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585895950314,"val":526},{"ts":1585896115932,"val":484},{"ts":1585896120980,"val":478},{"ts":1585897185165,"val":0},{"ts":1585902160322,"val":1491},{"ts":1585902165342,"val":1495},{"ts":1585908206385,"val":4677},{"ts":1585908211400,"val":4663},{"ts":1585908216419,"val":4683},{"ts":1585908241498,"val":4550},{"ts":1585914259334,"val":6782},{"ts":1585914264351,"val":6763},{"ts":1585917263083,"val":6529},{"ts":1585920005966,"val":7206},{"ts":1585920307263,"val":7068},{"ts":1585920312285,"val":7102},{"ts":1585920392679,"val":7177},{"ts":1585920578493,"val":4454},{"ts":1585926354537,"val":6259},{"ts":1585926359563,"val":6256},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585932402807,"val":2886},{"ts":1585932407820,"val":2889},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585980721437,"val":311},{"ts":1585980786682,"val":306},{"ts":1585980801746,"val":311},{"ts":1585984789725,"val":22},{"ts":1585986802724,"val":806},{"ts":1585986832829,"val":785},{"ts":1585986837852,"val":774},{"ts":1585987214177,"val":0},{"ts":1585992877572,"val":3776},{"ts":1585992882588,"val":3564},{"ts":1585992887613,"val":3585},{"ts":1585993178846,"val":3480},{"ts":1585998914062,"val":6306},{"ts":1585998929111,"val":6281},{"ts":1585998934133,"val":6285},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004976531,"val":6856},{"ts":1586004981635,"val":6874},{"ts":1586005780202,"val":7162},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586023012362,"val":23},{"ts":1586023122859,"val":34},{"ts":1586023127882,"val":36},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586065432983,"val":165},{"ts":1586065458076,"val":158},{"ts":1586065463096,"val":157},{"ts":1586065593575,"val":155},{"ts":1586071221625,"val":554},{"ts":1586071507737,"val":503},{"ts":1586071512747,"val":513},{"ts":1586077238247,"val":0},{"ts":1586077514400,"val":2727},{"ts":1586077554539,"val":2702},{"ts":1586077559561,"val":2717},{"ts":1586077700285,"val":2672},{"ts":1586083448954,"val":5755},{"ts":1586083594501,"val":5742},{"ts":1586083609556,"val":5755},{"ts":1586083664769,"val":5751},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586107792345,"val":1513},{"ts":1586107797363,"val":1507},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586167269338,"val":0},{"ts":1586168263702,"val":5093},{"ts":1586168273730,"val":5089},{"ts":1586168278743,"val":5098},{"ts":1586168308842,"val":5018},{"ts":1586174290074,"val":6756},{"ts":1586174320192,"val":6709},{"ts":1586174325211,"val":6711},{"ts":1586174762088,"val":6657},{"ts":1586179926359,"val":6915},{"ts":1586180368441,"val":6809},{"ts":1586180373438,"val":6774},{"ts":1586180749981,"val":6879},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234804256,"val":0}]
                          widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 1 month
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1583606816475,"end":1586234816475,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1583606816475,"end":1586234816475,"timeout":5000}
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 48
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1583606816475,"val":0},{"ts":1585857922009,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893174183,"val":193},{"ts":1585893179325,"val":197},{"ts":1585897185165,"val":0},{"ts":1585917584464,"val":7089},{"ts":1585919453326,"val":7068},{"ts":1585919458361,"val":7056},{"ts":1585920005966,"val":7206},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585998291250,"val":5976},{"ts":1585998296276,"val":5970},{"ts":1585998301336,"val":5980},{"ts":1586005780202,"val":7162},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586077132776,"val":2587},{"ts":1586077137791,"val":2585},{"ts":1586077238247,"val":0},{"ts":1586093596415,"val":7097},{"ts":1586103414867,"val":4471},{"ts":1586103419882,"val":4459},{"ts":1586103429906,"val":4468},{"ts":1586109905885,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586167269338,"val":0},{"ts":1586179926359,"val":6915},{"ts":1586182251826,"val":6561},{"ts":1586182256996,"val":6572},{"ts":1586182271904,"val":6584},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234816475,"val":0}]
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 62
                          widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1583606816475,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585866894468,"val":1083},{"ts":1585866899491,"val":1590},{"ts":1585875468113,"val":0},{"ts":1585893128983,"val":6513},{"ts":1585893174183,"val":6372},{"ts":1585893179325,"val":5325},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585919453326,"val":1636},{"ts":1585919458362,"val":1626},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585946826408,"val":3103},{"ts":1585963054196,"val":341},{"ts":1585972004945,"val":918},{"ts":1585972020004,"val":913},{"ts":1585982343403,"val":339},{"ts":1585991642299,"val":3828},{"ts":1585998296276,"val":1387},{"ts":1585998301336,"val":1832},{"ts":1586003238503,"val":6525},{"ts":1586022484981,"val":0},{"ts":1586024573904,"val":389},{"ts":1586024578917,"val":968},{"ts":1586024619113,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586050855348,"val":675},{"ts":1586050860376,"val":904},{"ts":1586057380892,"val":0},{"ts":1586076203797,"val":5655},{"ts":1586077132776,"val":1181},{"ts":1586077137791,"val":1228},{"ts":1586077238248,"val":0},{"ts":1586102621756,"val":6094},{"ts":1586103414867,"val":1915},{"ts":1586103419882,"val":775},{"ts":1586109218231,"val":0},{"ts":1586116428259,"val":4117},{"ts":1586129693337,"val":830},{"ts":1586129698348,"val":817},{"ts":1586133897547,"val":0},{"ts":1586151990748,"val":2834},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586182251826,"val":1128},{"ts":1586182256996,"val":1157},{"ts":1586191690404,"val":6163},{"ts":1586205378506,"val":0},{"ts":1586208378051,"val":754},{"ts":1586210196393,"val":560},{"ts":1586225768246,"val":259},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234816475,"val":1661}]
                          widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 62
                          widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 48
                          EDIT:
                          zu früh gefreut. Ich habe nun von InfluxDB wieder auf MariaDB als Datenquelle gewechselt. Die Timeouts treten nun wieder deutlich häufiger auf. Auch beim Wechsel zurück auf InfluxDB gab es viele Timeouts....
                          ScroungerS Offline
                          ScroungerS Offline
                          Scrounger
                          #901
                          @Chris-Tailor
                          Hab nochmal bissle optimiert, bitte teste die version von git -> v0.2.80.
                          Hier kannst du jetzt selbst den timeout einstellen (in Sekunden):
                          Erhöh mal den bis bei dir keine fehlermeldungen mehr auftauchen.
                          Reduzier auch mal die max. Anzahl der anzuzeigenden Datenpunkte: und den timeout. Müssten direkt zusammenhängen, d.h. um so weniger Datenpunkte um so niedriger kannst den timeout wählen.
                          Und noch kleiner Tipp: max. Anzahl der anzuzeigenden Datenpunkte: 100 brauchst du sicher nicht in der VIS. Denke das hier 30 völlig ausreichend sind. Bedenke je höher der Wert desto mehr daten müssen geladen werden, was sich auf die preformance auswirkt!
                          • ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            #902
                            Version 0.3.0 veröffentlicht, ab sofort geht es hier weiter:
                            https://forum.iobroker.net/topic/32018/test-adapter-material-design-widgets-v0-3-x
