  4. Synology- mal wieder Zigbee - CC2531 USB, Gelöst
    6.1k
zigbee cc2531
87 Beiträge 6 Kommentatoren 16.5k Aufrufe 7 Beobachtet
    dos1973
    schrieb am zuletzt editiert von dos1973
    ich hatte einen Stromausfall und zack war die NAS aus.
    Seitdem wird der Zigbee Stick nicht mehr gelb.
    zigbee.0	2020-03-26 22:53:35.167	error	(10500) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsma
    zigbee.0	2020-03-26 22:53:35.166	error	(10500) Failed to start Zigbee
    zigbee.0	2020-03-26 22:53:34.950	info	(10500) Starting Zigbee...
    zigbee.0	2020-03-26 22:53:34.949	info	(10500) Try to reconnect. 1 attempts left
    zigbee.0	2020-03-26 22:53:24.949	error	(10500) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsma
    zigbee.0	2020-03-26 22:53:24.948	error	(10500) Failed to start Zigbee
    zigbee.0	2020-03-26 22:53:24.601	info	(10500) Starting Zigbee...
    zigbee.0	2020-03-26 22:53:24.573	info	(10500) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1
    zigbee.0	2020-03-26 22:53:19.637	info	(8671) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2020-03-26 22:53:19.636	info	(8671) terminating
    zigbee.0	2020-03-26 22:53:19.634	error	at process._tickCallback (internal/process/next_tick.js:68:7))
    zigbee.0	2020-03-26 22:53:19.634	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
    zigbee.0	2020-03-26 22:53:19.634	error	at Controller.stop (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
    zigbee.0	2020-03-26 22:53:19.634	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
    zigbee.0	2020-03-26 22:53:19.634	error	at new Promise (<anonymous>)
    zigbee.0	2020-03-26 22:53:19.634	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
    zigbee.0	2020-03-26 22:53:19.634	error	at Generator.next (<anonymous>)
    zigbee.0	2020-03-26 22:53:19.634	error	at Controller.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
    zigbee.0	2020-03-26 22:53:19.634	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
    zigbee.0	2020-03-26 22:53:19.634	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
    zigbee.0	2020-03-26 22:53:19.634	error	(8671) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-03-26 22:53:19.627	info	(8671) Zigbee: disabling joining new devices.
    zigbee.0	2020-03-26 22:53:19.623	info	(8671) cleaned everything up...
    zigbee.0	2020-03-26 22:53:19.622	info	(8671) Got terminate signal TERMINATE_YOURSELF
    der stick wird gefunden im System
    lsusb
    |__usb1          1d6b:0002:0404 09  2.00  480MBit/s 0mA 1IF  (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:15.0) hub
      |__1-2         0451:16a8:0009 02  2.00   12MBit/s 50mA 2IFs (Texas Instruments TI CC2531 USB CDC __0X00124B0018ED2183)
      |__1-4         f400:f400:0100 00  2.00  480MBit/s 200mA 1IF  (Synology DiskStation 7F00877D96CA6084)
    |__usb2          1d6b:0003:0404 09  3.00 5000MBit/s 0mA 1IF  (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:15.0) hub
    ich habe dem "ttyACM0" chmod 777 verpasst -nix geht.
    crwxrwxrwx  1 root   root  166,   0 Mar 26 23:01 ttyACM0
    Mensch wie mich dieses Zigbee Ding nervt, alle paar Wochen verbringe ich Stunden damit. :-(
    Für Hilfestellung bin ich wirklich sehr dankbar.
    • D dos1973
      lsusb
      arteckA Offline
      arteckA Offline
      arteck
      @dos1973 lass mal fen fixer drüber laufen
      curl -sL https://iobroker.net/fix.sh | bash -
        dos1973
        @arteck
        nee, leider klappt das auch nicht.
        • D dos1973
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          @dos1973
          der Stick nicht durchgereicht..
          oder genau so und nicht anders..sonst kaputt
          dann adapter stopp
          folgende Ordner löschen
          rm -R /opt/iobroker/node_modules/iobroker.zigbee/node_modules
          rm -R /opt/iobroker/node_modules/zigbee-herdsman
          rm -R /opt/iobroker/node_modules/@serialport
          dann von git neu installieren.. danach sollte es wieder tun...
          du hast ein serialport problem.. nicht /dev/ttyACM0.. die Rechtevergabe auf den /dev/ttyACM0 hilft da nicht
          • arteckA arteck
            @dos1973
            dann adapter stopp
            dos1973
            @arteck
            nochmals bitte - das sonst kaputt verwirrt mich ;-)
            so die Reihenfolge korrekt?
            1. Stick abstecken?
            2. adapter stop
            3. ordner löschen
            4. git install
            5. stick wieder drinstecken
            • D dos1973
              @arteck
              1. Stick abstecken?
              2. adapter stop
              3. ordner löschen
              4. git install
              arteckA Offline
              arteckA Offline
              arteck
              @dos1973 jo
              • arteckA arteck
                @dos1973 jo
                dos1973
                @arteck
                leider nicht erfolgreich.
                ich habe bis jetzt nichts an den Rechte o.ä versucht.
                Habe nur in den Einstellungen den COM Anschlußnahmen ausgewählt --> /dev/ttyACM0
                zigbee.0	2020-03-27 10:55:53.721	error	(16039) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/zn
                zigbee.0	2020-03-27 10:55:53.719	error	(16039) Failed to start Zigbee
                zigbee.0	2020-03-27 10:55:53.495	info	(16039) Starting Zigbee...
                zigbee.0	2020-03-27 10:55:53.494	info	(16039) Try to reconnect. 1 attempts left
                zigbee.0	2020-03-27 10:55:43.494	error	at binding.open.then.err (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12)
                zigbee.0	2020-03-27 10:55:43.494	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                zigbee.0	2020-03-27 10:55:43.494	error	at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                zigbee.0	2020-03-27 10:55:43.494	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                zigbee.0	2020-03-27 10:55:43.494	error	at new Promise (<anonymous>)
                zigbee.0	2020-03-27 10:55:43.494	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                zigbee.0	2020-03-27 10:55:43.494	error	at Generator.next (<anonymous>)
                zigbee.0	2020-03-27 10:55:43.494	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                zigbee.0	2020-03-27 10:55:43.494	error	(16039) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'
                zigbee.0	2020-03-27 10:55:43.493	error	(16039) Failed to start Zigbee
                zigbee.0	2020-03-27 10:55:43.144	info	(16039) Starting Zigbee...
                zigbee.0	2020-03-27 10:55:43.114	info	(16039) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1
                host.iobroker	2020-03-27 10:55:40.831	info	instance system.adapter.zigbee.0 started with pid 16039
                host.iobroker	2020-03-27 10:55:40.812	info	"system.adapter.zigbee.0" enabled
                host.iobroker	2020-03-27 10:55:39.647	info	instance system.adapter.zigbee.0 terminated with code 156 (156)
                host.iobroker	2020-03-27 10:55:39.647	error	Caught by controller[2]: (node:15673) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[1]: (node:15673) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7226:22)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Zigbee.emit (events.js:198:13)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:41)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:302:20)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:215:31)
                host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:16)
                host.iobroker	2020-03-27 10:55:39.645	error	Caught by controller[0]: at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55)
                host.iobroker	2020-03-27 10:55:39.645	error	Caught by controller[0]: (node:15673) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'getEntries' of null
                zigbee.0	2020-03-27 10:55:39.111	info	(15673) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                zigbee.0	2020-03-27 10:55:39.110	info	(15673) terminating
                zigbee.0	2020-03-27 10:55:39.110	error	at process._tickCallback (internal/process/next_tick.js:68:7))
                zigbee.0	2020-03-27 10:55:39.110	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:33)
                zigbee.0	2020-03-27 10:55:39.110	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:166:16)
                zigbee.0	2020-03-27 10:55:39.110	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
                zigbee.0	2020-03-27 10:55:39.110	error	at new Promise (<anonymous>)
                zigbee.0	2020-03-27 10:55:39.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
                zigbee.0	2020-03-27 10:55:39.110	error	at Generator.next (<anonymous>)
                zigbee.0	2020-03-27 10:55:39.110	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:170:49)
                zigbee.0	2020-03-27 10:55:39.110	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
                zigbee.0	2020-03-27 10:55:39.110	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
                zigbee.0	2020-03-27 10:55:39.110	error	(15673) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                zigbee.0	2020-03-27 10:55:39.107	info	(15673) Zigbee: disabling joining new devices.
                zigbee.0	2020-03-27 10:55:39.101	info	(15673) cleaned everything up...
                • D dos1973
                  @arteck
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @dos1973 zumindest ist jetzt adapter technisch alles ok
                  ist immer noch dein problem
                  was sagt
                  ls -l /dev/serial/by-id
                  • arteckA arteck
                    was sagt
                    dos1973
                    @arteck sagte in mal wieder Zigbee - CC2531 USB:
                    root@iobroker:/opt/iobroker/node_modules# ls -l /dev/serial/by-id
                    ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden
                    gibt es nicht?!?
                    • D dos1973
                      gibt es nicht?!?
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @dos1973 dann wird der Stick nicht durchgereicht... zumindest nicht bis zum container..
                      • arteckA arteck
                        dos1973
                        @arteck ich boote mal den container durch
                        • D dos1973
                          dos1973
                          @arteck
                          nein, auch ein Reboot hilft nicht.
                          /dev/serial/ gibt es nicht.
                          • D dos1973
                            @arteck
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @dos1973
                            Hinweis .
                            Der Befehl ... funktioniert nicht bei einer Synology !
                            Hatte ich auch letztens das Problem , obwohl ich schon das neue Image von buanet habe .
                            Lösche mal die beiden Dateien und starte die Synology neu
                            • GlasfaserG Glasfaser
                              @dos1973
                              Hinweis .
                              dos1973
                              @Glasfaser
                              ich hatte nur den ttyACM0.
                              den habe ich jetzt gelöscht - reboote die Synology jetzt
                              • D dos1973
                                @Glasfaser
                                dos1973
                                nein, auch das funktioniert nicht.
                                ttyACM0 wurde nach den Neustart wieder angelegt.
                                Ein chmod 777 darauf bringt auch nichts... (meine das hat u.a früher mal geklappt)
                                zigbee.0	2020-03-27 11:43:48.131	error	(2534) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp
                                zigbee.0	2020-03-27 11:43:48.130	error	(2534) Failed to start Zigbee
                                zigbee.0	2020-03-27 11:43:47.887	info	(2534) Starting Zigbee...
                                zigbee.0	2020-03-27 11:43:47.886	info	(2534) Try to reconnect. 1 attempts left
                                zigbee.0	2020-03-27 11:43:37.885	error	at binding.open.then.err (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12)
                                zigbee.0	2020-03-27 11:43:37.885	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                                zigbee.0	2020-03-27 11:43:37.885	error	at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                                zigbee.0	2020-03-27 11:43:37.885	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                                zigbee.0	2020-03-27 11:43:37.885	error	at new Promise (<anonymous>)
                                zigbee.0	2020-03-27 11:43:37.885	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                                zigbee.0	2020-03-27 11:43:37.885	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-03-27 11:43:37.885	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                                zigbee.0	2020-03-27 11:43:37.885	error	(2534) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'
                                zigbee.0	2020-03-27 11:43:37.884	error	(2534) Failed to start Zigbee
                                zigbee.0	2020-03-27 11:43:37.453	info	(2534) Starting Zigbee...
                                • D dos1973
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @dos1973
                                  Hast du das neue Image ( 4.1.0 ) ???
                                    @dos1973
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @Glasfaser hat sich da nicht was im Docker geändert.. seid letzten update.. ??
                                    • arteckA arteck
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @arteck
                                      Ja , seit der Version 4.1.0 braucht nichts gemacht werden , wird ja mit dem Eintrag im Container Docker erledigt ( Bild siehe oben ).
                                      Funktioniert auch zu 100 %
                                        dos1973
                                        puh, wie bekomme ich das raus?
                                        lädt er das nicht automatisch - wenn latest drin ist?
                                        Bildschirmfoto 2020-03-27 um 11.54.49.png Bildschirmfoto 2020-03-27 um 11.55.00.png
                                        • D dos1973
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @dos1973
                                          Hier wird die Version angezeigt :
